This is not useful: it provides page->virtual and is used with highmem.
xtensa has no support for highmem and those HIGHMEM bits which are found
by grep are partly implemented. The interesting functions like kmap() are
missing. If someone actually implements the complete HIGHMEM support he
could use HASHED_PAGE_VIRTUAL like most others do.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Chris Zankel <chris@zankel.net>
The current asm-generic/page.h only contains the get_order
function, and asm-generic/uaccess.h only implements
unaligned accesses. This renames the file to getorder.h
and uaccess-unaligned.h to make room for new page.h
and uaccess.h file that will be usable by all simple
(e.g. nommu) architectures.
Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com>
Add support for !CONFIG_MMU setups.
Signed-off-by: Johannes Weiner <jw@emlix.com>
Signed-off-by: Chris Zankel <chris@zankel.net>
The current assumption of the memory code is that the first RAM PFN in
the system is 0.
Adjust the relevant code to play well with setups where memory starts
at higher addresses, indicated by PLATFORM_DEFAULT_MEM_START.
The new memory model looks like this:
| | | RAM | |
+- PFN 0 | +- min_low_pfn +- max_low_pfn +- max_pfn
+- ARCH_PFN_OFFSET
+- PLATFORM_DEFAULT_MEM_START >> PAGE_SIZE
The memory map contains pages starting from pfn ARCH_PFN_OFFSET up to
max_low_pfn. The only zone used right now will span exactly the same
region.
Usually, ARCH_PFN_OFFSET and min_low_pfn are the same value. Handle
them separately for robustness. Gapping pages will be in the memory
map but marked as reserved and won't be touched.
Move all header files for xtensa to arch/xtensa/include and platform and
variant header files to the appropriate arch/xtensa/platforms/ and
arch/xtensa/variants/ directories.
Moving the files gets also rid of all uses of symlinks in the Makefile.
This has been completed already for the majority of the architectures
and xtensa is one out of six missing.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
