path: root/arch/xtensa/kernel/platform.c
2013-07-08xtensa: cleanup ccount frequency trackingBaruch Siach
Remove unused nsec_per_ccount, and rename ccount_per_jiffy to ccount_preq. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-06-05xtensa: remove unused platform_init_irq()Baruch Siach
Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09xtensa: provide default platform_pcibios_init implementationMax Filippov
This fixes the following build error: arch/xtensa/kernel/built-in.o:(.init.literal+0xe8): undefined reference to `platform_pcibios_init' arch/xtensa/kernel/built-in.o: In function `setup_arch': (.init.text+0x20e): undefined reference to `platform_pcibios_init' and allows platform to omit definition of platform_pcibios_init if it's empty. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-12-18xtensa: clean up files to make them code-style compliantChris Zankel
Remove heading and trailing spaces, trim trailing lines, and wrap lines that are longer than 80 characters. Signed-off-by: Chris Zankel <chris@zankel.net>
2012-10-03xtensa: change default platform clock frequency to 10MHzMax Filippov
Existing simulators show this level of performance. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-04-02xtensa: remove platform rtc hooksJohannes Weiner
platform_get/set_rtc_time() is not implemented by any of the supported xtensa platforms. Remove the facility completely. The initial seconds for xtime come from read_persistent_clock() which returns just 0 in the generic implementation. Platforms that sport a persistent clock can implement this function. This is needed to implement the ccount as a clock source. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Chris Zankel <chris@zankel.net>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] xtensa: remove io_remap_page_range and minor clean-upsChris Zankel
Remove io_remap_page_range() from all of Linux 2.6.x (as requested and suggested by Randy Dunlap) and minor clean-ups. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xtensa: Architecture support for Tensilica Xtensa Part 3Chris Zankel
The attached patches provides part 3 of an architecture implementation for the Tensilica Xtensa CPU series. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
