commit ada770b1e74a77fff2d5f539bf6c42c25f4784db upstream.
return_address returns the address that is one level higher in the call
stack than requested in its argument, because level 0 corresponds to its
caller's return address. Use requested level as the number of stack
frames to skip.
This fixes the address reported by might_sleep and friends.
Cc: stable@vger.kernel.org
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Define macros SPILL_SLOT* that return a reference to the stack location
of the spill slot for specific register and use them instead of opencoded
address calculations.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Old oprofile interface will share user stack tracing with new perf
interface. Move oprofile user/kernel stack tracing to stacktrace.c to
make it possible.
Definition of CALLER_ADDR* through __builtin_return_address makes
compiler insert calls to __xtensa_libgcc_window_spill, which in turn
makes fast_syscall_spill_registers syscall that clobbers registers when
called from the kernel mode, leading to invalid opcode exceptions on
return to userspace.
Provide definition for CALLER_ADDR0 as MAKE_PC_FROM_RA(a0, a1) and in
case CONFIG_FRAME_POINTER is enabled extract CALLER_ADDR{1-3} from
stack.
Signed-off-by: Chris Zankel <chris@zankel.net>
