path: root/arch/xtensa/kernel
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25xtensa: prevent arbitrary read in ptraceDan Rosenberg
Prevent an arbitrary kernel read. Check the user pointer with access_ok() before copying data in. [akpm@linux-foundation.org: s/EIO/EFAULT/] Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Christian Zankel <chris@zankel.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-04-20xtensa: Fixup irq conversion fallout and nmi_countThomas Gleixner
Some unnamed moron fatfingered the arguments of the irq chip callbacks to irq_chip instead of irq_data. While at it remove the nmi_count() print in arch_show_interrupts() which has been broken before the irq conversion already. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-24xtensa: Use generic show_interrupts()Thomas Gleixner
2011-03-24xtensa: Convert genirq namespaceThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-24xtensa: Convert main irq_chip to new functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110206211137.653005586@linutronix.de>
2011-03-24percpu: Always align percpu output section to PAGE_SIZETejun Heo
Percpu allocator honors alignment request upto PAGE_SIZE and both the percpu addresses in the percpu address space and the translated kernel addresses should be aligned accordingly. The calculation of the former depends on the alignment of percpu output section in the kernel image. The linker script macros PERCPU_VADDR() and PERCPU() are used to define this output section and the latter takes @align parameter. Several architectures are using @align smaller than PAGE_SIZE breaking percpu memory alignment. This patch removes @align parameter from PERCPU(), renames it to PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it, add PCPU_SETUP_BUG_ON() checks such that alignment problems are reliably detected and remove percpu alignment comment recently added in workqueue.c as the condition would trigger BUG way before reaching there. For um, this patch raises the alignment of percpu area. As the area is in .init, there shouldn't be any noticeable difference. This problem was discovered by David Howells while debugging boot failure on mn10300. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net
2011-03-16Merge branch 'for-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support percpu: Generic support for this_cpu_cmpxchg_double() alpha: use L1_CACHE_BYTES for cacheline size in the linker script percpu: align percpu readmostly subsection to cacheline Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the percpu alignment having changed ("x86: Reduce back the alignment of the per-CPU data section")
2011-01-31xtensa: Switch do_timer() to xtime_update()Torben Hohn
xtime_update() takes the xtime_lock itself. set_linux_timer() does not need to be protected by xtime_lock. [ tglx: This code is broken on SMP anyway. ] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Chris Zankel <chris@zankel.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: hch@infradead.org Cc: yong.zhang0@gmail.com LKML-Reference: <20110127150027.23248.61798.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-25percpu: align percpu readmostly subsection to cachelineTejun Heo
Currently percpu readmostly subsection may share cachelines with other percpu subsections which may result in unnecessary cacheline bounce and performance degradation. This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR() linker macros, makes each arch linker scripts specify its cacheline size and use it to align percpu subsections. This is based on Shaohua's x86 only patch. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Shaohua Li <shaohua.li@intel.com>
2010-10-27ptrace: cleanup arch_ptrace() on xtensaNamhyung Kim
Use new 'datap' variable in order to remove unnecessary castings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-23genirq: Cleanup irq_chip->typename leftoversThomas Gleixner
3 years transition phase is enough. Cleanup the last users and remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Leo Chen <leochen@broadcom.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-03Merge remote branch 'origin/master'Chris Zankel
2010-05-25xtensa: includecheck fix: vectors.SJaswinder Singh Rajput
fix the following 'make includecheck' warnings: arch/xtensa/kernel/vectors.S: asm/processor.h is included more than once. arch/xtensa/kernel/vectors.S: asm/ptrace.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25xtensa: convert to asm-generic/hardirq.hChristoph Hellwig
Also remove lots of unused irq_cpustat fields. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-19Merge branch 'timers-for-linus-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix typo in read_persistent_clock() sparc: Convert sparc to use read/update_persistent_clock cris: Convert cris to use read/update_persistent_clock m68k: Convert m68k to use read/update_persistent_clock m32r: Convert m32r to use read/update_peristent_clock blackfin: Convert blackfin to use read/update_persistent_clock ia64: Convert ia64 to use read/update_persistent_clock avr32: Convert avr32 to use read/update_persistent_clock h8300: Convert h8300 to use read/update_persistent_clock frv: Convert frv to use read/update_persistent_clock mn10300: Convert mn10300 to use read/update_persistent_clock alpha: Convert alpha to use read/update_persistent_clock xtensa: Fix unnecessary setting of xtime time: Clean up direct xtime usage in xen
2010-05-02xtensa: Shuffle include statements to fix linker scriptChris Zankel
The linker script was including assembly macros from the coprocessor header file that is not otherwise used by the script. Signed-off-by: Chris Zankel <chris@zankel.net>
2010-05-01xtensa: Fixes due to bss boundary symbol name changes.Chris Zankel
The bss start and end symbols have changed to __bss_start and __bss_stop. Signed-off-by: Chris Zankel <chris@zankel.net>
2010-05-01xtensa: Fix linker script patch-upChris Zankel
The Xtensa architecture requires to patch the generated linker script to insert precede certain sections with a .literal section. Ammend the sed script to fix-up only sequences that start with a '*': '*(.init.text)' -> '*(.init.literal .init.text)' Signed-off-by: Chris Zankel <chris@zankel.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12xtensa: use generic ptrace_resume codeChristoph Hellwig
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT, PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining arch_has_single_step in <asm/ptrace.h> and implementing the user_enable_single_step and user_disable_single_step functions, which also causes the breakpoint information to be cleared on fork, which could be considered a bug fix. Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which it previously wasn't which is consistent with all architectures using the modern ptrace code. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-13xtensa: Fix unnecessary setting of xtimeJohn Stultz
xtensa supports read_persisitent_clock(), so there is no reason for the arch specific code to be setting xtime. Setting xtime will be done by the generic timekeeping code. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-22resource/PCI: mark struct resource as constDominik Brodowski
Now that we return the new resource start position, there is no need to update "struct resource" inside the align function. Therefore, mark the struct resource as const. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: align functions now return start of resourceDominik Brodowski
As suggested by Linus, align functions should return the start of a resource, not void. An update of "res->start" is no longer necessary. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-16sanitize do_pipe_flags() callers in archAl Viro
* hpux_pipe() - no need to take BKL * sys32_pipe() in arch/x86/ia32 and xtensa_pipe() in arch/xtensa - no need at all, since both functions are open-coded sys_pipe() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-24xtensa: Cleanup linker script using new linker script macros.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Chris Zankel <chris@zankel.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Use macros for .bss.page_aligned section.Tim Abbott
This patch changes the remaining direct references to .bss.page_aligned in C and assembly code to use the macros in include/linux/linkage.h. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0Sam Ravnborg
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported: Bash 4 filters out variables which contain a dot in them. This happends to be the case of CPPFLAGS_vmlinux.lds. This is rather unfortunate, as it now causes build failures when using SHELL=/bin/bash to compile, or when bash happens to be used by make (eg when it's /bin/sh) Remove the common definition of CPPFLAGS_vmlinux.lds by pushing relevant stuff to either Makefile.build or the arch specific kernel/Makefile where we build the linker script. This is also nice cleanup as we move the information out where it is used. Notes for the different architectures touched: arm - we use an already exported symbol cris - we use a config symbol aleady available [Not build tested] mips - the jiffies complexity has moved to vmlinux.lds.S where we need it. Added a few variables to CPPFLAGS - they are only used by the linker script. [Not build tested] powerpc - removed assignment that is not needed [not build tested] sparc - simplified it using $(BITS) um - introduced a few new exported variables to deal with this xtensa - added options to CPP invocation [not build tested] Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-18Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (34 commits) time: Prevent 32 bit overflow with set_normalized_timespec() clocksource: Delay clocksource down rating to late boot clocksource: clocksource_select must be called with mutex locked clocksource: Resolve cpu hotplug dead lock with TSC unstable, fix crash timers: Drop a function prototype clocksource: Resolve cpu hotplug dead lock with TSC unstable timer.c: Fix S/390 comments timekeeping: Fix invalid getboottime() value timekeeping: Fix up read_persistent_clock() breakage on sh timekeeping: Increase granularity of read_persistent_clock(), build fix time: Introduce CLOCK_REALTIME_COARSE x86: Do not unregister PIT clocksource on PIT oneshot setup/shutdown clocksource: Avoid clocksource watchdog circular locking dependency clocksource: Protect the watchdog rating changes with clocksource_mutex clocksource: Call clocksource_change_rating() outside of watchdog_lock timekeeping: Introduce read_boot_clock timekeeping: Increase granularity of read_persistent_clock() timekeeping: Update clocksource with stop_machine timekeeping: Add timekeeper read_clock helper functions timekeeping: Move NTP adjusted clock multiplier to struct timekeeper ... Fix trivial conflict due to MIPS lemote -> loongson renaming.
2009-08-15timekeeping: Increase granularity of read_persistent_clock()Martin Schwidefsky
The persistent clock of some architectures (e.g. s390) have a better granularity than seconds. To reduce the delta between the host clock and the guest clock in a virtualized system change the read_persistent_clock function to return a struct timespec. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.013873340@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-07-09linker script: unify usage of discard definitionTejun Heo
Discarded sections in different archs share some commonality but have considerable differences. This led to linker script for each arch implementing its own /DISCARD/ definition, which makes maintaining tedious and adding new entries error-prone. This patch makes all linker scripts to move discard definitions to the end of the linker script and use the common DISCARDS macro. As ld uses the first matching section definition, archs can include default discarded sections by including them earlier in the linker script. ia64 is notable because it first throws away some ia64 specific subsections and then include the rest of the sections into the final image, so those sections must be discarded before the inclusion. defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64, alpha, sparc, sparc64 and s390. Michal Simek tested microblaze. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Michal Simek <monstr@monstr.eu> Cc: linux-arch@vger.kernel.org Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-04Merge branch 'master' into for-nextTejun Heo
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix changes. As alpha in percpu tree uses 'weak' attribute instead of inline assembly, there's no need for __used attribute. Conflicts: arch/alpha/include/asm/percpu.h arch/mn10300/kernel/vmlinux.lds.S include/linux/percpu-defs.h
2009-06-24linker script: throw away .discard sectionTejun Heo
x86 throws away .discard section but no other archs do. Also, .discard is not thrown away while linking modules. Make every arch and module linking throw it away. This will be used to define dummy variables for percpu declarations and definitions. This patch is based on Ivan Kokshaysky's alpha percpu patch. [ Impact: always throw away everything in .discard ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-22xtensa: allow variant to initialize own irq chipsDaniel Glöckner
There was already a PLATFORM_NR_IRQS define, which is now accompanied by a VARIANT_NR_IRQS. To be able to initialize these interrupts, init_IRQ now calls a variant specific hook. Changes compared to v1: - adapted to new CONFIG_VARIANT_IRQ_EXT - removed definition and call of platform_init_IRQ as there already is a platform_init_irq defined in asm/platform.h with a weak default in kernel/platform.c - renamed variant_init_IRQ to variant_init_irq Note that I could not find the call site of platform_init_irq although it is stated in platform.h that it is called from init_IRQ. Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
