commit 8b39da985194aac2998dd9e3a22d00b596cebf1e upstream.
Custom outs*/ins* implementations are long gone from the xtensa port,
remove matching EXPORT_SYMBOLs.
This fixes the following build warnings issued by modpost since commit
15bfc2348d54 ("modpost: check for static EXPORT_SYMBOL* functions"):
WARNING: "insb" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "insw" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "insl" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsb" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsw" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsl" [vmlinux] is a static EXPORT_SYMBOL
Cc: stable@vger.kernel.org
Fixes: d38efc1f150f ("xtensa: adopt generic io routines")
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit cd8869f4cb257f22b89495ca40f5281e58ba359c upstream.
ITLB entry modifications must be followed by the isync instruction
before the new entries are possibly used. cpu_reset lacks one isync
between ITLB way 6 initialization and jump to the identity mapping.
Add missing isync to xtensa cpu_reset.
[ Upstream commit adefd051a6707a6ca0ebad278d3c1c05c960fc3b ]
Since commit 9012d011660ea5cf2 ("compiler: allow all arches to enable
CONFIG_OPTIMIZE_INLINING"), xtensa:tinyconfig fails to build with section
mismatch errors.
WARNING: vmlinux.o(.text.unlikely+0x68): Section mismatch in reference
from the function ___pa()
to the function .meminit.text:memblock_reserve()
WARNING: vmlinux.o(.text.unlikely+0x74): Section mismatch in reference
from the function mem_reserve()
FATAL: modpost: Section mismatches detected.
This was not seen prior to the above mentioned commit because mem_reserve()
was always inlined.
Mark mem_reserve(() as __init_memblock to have it reside in the same
section as memblock_reserve().
Message-Id: <1559220098-9955-1-git-send-email-linux@roeck-us.net>
commit ada770b1e74a77fff2d5f539bf6c42c25f4784db upstream.
return_address returns the address that is one level higher in the call
stack than requested in its argument, because level 0 corresponds to its
caller's return address. Use requested level as the number of stack
frames to skip.
This fixes the address reported by might_sleep and friends.
[ Upstream commit 25384ce5f9530def39421597b1457d9462df6455 ]
This fixes the following warning at boot when the kernel is booted on a
board with more CPU cores than was configured in NR_CPUS:
smp_init_cpus: Core Count = 8
smp_init_cpus: Core Id = 0
WARNING: CPU: 0 PID: 0 at include/linux/cpumask.h:121 smp_init_cpus+0x54/0x74
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 5.0.0-rc3-00015-g1459333f88a0 #124
Call Trace:
__warn$part$3+0x6a/0x7c
warn_slowpath_null+0x35/0x3c
setup_arch+0x1c0/0x1d0
start_kernel+0x44/0x310
_startup+0x107/0x107
[ Upstream commit 8b1c42cdd7181200dc1fff39dcb6ac1a3fac2c25 ]
Otherwise it is impossible to enable CPUs after booting with 'maxcpus'
parameter.
[ Upstream commit 32a7726c4f4aadfabdb82440d84f88a5a2c8fe13 ]
- add missing memory barriers to the secondary CPU synchronization spin
loops; add comment to the matching memory barrier in the boot_secondary
and __cpu_die functions;
- use READ_ONCE/WRITE_ONCE to access cpu_start_id/cpu_start_ccount
instead of reading/writing them directly;
- re-initialize cpu_running every time before starting secondary CPU to
flush possible previous CPU startup results.
[ Upstream commit 4fe8713b873fc881284722ce4ac47995de7cf62c ]
ccount_timer_shutdown is called from the atomic context in the
secondary_start_kernel, resulting in the following BUG:
BUG: sleeping function called from invalid context
in_atomic(): 1, irqs_disabled(): 1, pid: 0, name: swapper/1
Preemption disabled at:
secondary_start_kernel+0xa1/0x130
Call Trace:
___might_sleep+0xe7/0xfc
__might_sleep+0x41/0x44
synchronize_irq+0x24/0x64
disable_irq+0x11/0x14
ccount_timer_shutdown+0x12/0x20
clockevents_switch_state+0x82/0xb4
clockevents_exchange_device+0x54/0x60
tick_check_new_device+0x46/0x70
clockevents_register_device+0x8c/0xc8
clockevents_config_and_register+0x1d/0x2c
local_timer_setup+0x75/0x7c
secondary_start_kernel+0xb4/0x130
should_never_return+0x32/0x35
Use disable_irq_nosync instead of disable_irq to avoid it.
This is safe because the ccount timer IRQ is per-CPU, and once IRQ is
masked the ISR will not be called.
commit d90b88fd3653f1fb66ecc6571b860d5a5749fa56 upstream.
Stack unwinding is implemented incorrectly in xtensa get_wchan: instead
of extracting a0 and a1 registers from the spill location under the
stack pointer it extracts a word pointed to by the stack pointer and
subtracts 4 or 3 from it.
commit 38a35a78c5e270cbe53c4fef6b0d3c2da90dd849 upstream.
Layout of coprocessor registers in the elf_xtregs_t and
xtregs_coprocessor_t may be different due to alignment. Thus it is not
always possible to copy data between the xtregs_coprocessor_t structure
and the elf_xtregs_t and get correct values for all registers.
Use a table of offsets and sizes of individual coprocessor register
groups to do coprocessor context copying in the ptrace_getxregs and
ptrace_setxregs.
This fixes incorrect coprocessor register values reading from the user
process by the native gdb on an xtensa core with multiple coprocessors
and registers with high alignment requirements.
commit 03bc996af0cc71c7f30c384d8ce7260172423b34 upstream.
Coprocessor context offsets are used by the assembly code that moves
coprocessor context between the individual fields of the
thread_info::xtregs_cp structure and coprocessor registers.
This fixes coprocessor context clobbering on flushing and reloading
during normal user code execution and user process debugging in the
presence of more than one coprocessor in the core configuration.
commit 2958b66694e018c552be0b60521fec27e8d12988 upstream.
coprocessor_flush_all may be called from a context of a thread that is
different from the thread being flushed. In that case contents of the
cpenable special register may not match ti->cpenable of the target
thread, resulting in unhandled coprocessor exception in the kernel
context.
Set cpenable special register to the ti->cpenable of the target register
for the duration of the flush and restore it afterwards.
This fixes the following crash caused by coprocessor register inspection
in native gdb:
(gdb) p/x $w0
Illegal instruction in kernel: sig: 9 [#1] PREEMPT
Call Trace:
___might_sleep+0x184/0x1a4
__might_sleep+0x41/0xac
exit_signals+0x14/0x218
do_exit+0xc9/0x8b8
die+0x99/0xa0
do_illegal_instruction+0x18/0x6c
common_exception+0x77/0x77
coprocessor_flush+0x16/0x3c
arch_ptrace+0x46c/0x674
sys_ptrace+0x2ce/0x3b4
system_call+0x54/0x80
note: gdb[100] exited with preempt_count 1
Killed
commit 40dc948f234b73497c3278875eb08a01d5854d3f upstream.
The bootloader may pass physical address of the boot parameters structure
to the MMUv3 kernel in the register a2. Code in the _SetupMMU block in
the arch/xtensa/kernel/head.S is supposed to map that physical address to
the virtual address in the configured virtual memory layout.
This code haven't been updated when additional 256+256 and 512+512
memory layouts were introduced and it may produce wrong addresses when
used with these layouts.
commit 4119ba211bc4f1bf638f41e50b7a0f329f58aa16 upstream.
This section collects all source .note.* sections together in the
vmlinux image. Without it .note.Linux section may be placed at address
0, while the rest of the kernel is at its normal address, resulting in a
huge vmlinux.bin image that may not be linked into the xtensa Image.elf.
commit 7de712ccc096b81d23cc0a941cd9b8cb3956605d upstream.
While working on changing this code to use force_sig_fault I
discovered that do_unaliged_user is sets si_signo to SIGBUS and passes
SIGSEGV to force_sig_info. Which is just b0rked.
The code is reporting a SIGBUS error so replace the SIGSEGV with SIGBUS.
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: linux-xtensa@linux-xtensa.org
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Fixes: 5a0015d62668 ("[PATCH] xtensa: Architecture support for Tensilica Xtensa Part 3")
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Mark _stext and _end as character arrays instead of single
character variables, like include/asm-generic/sections.h does.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Francis Deslauriers <francis.deslauriers@efficios.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-cris-kernel@axis.com
Cc: mathieu.desnoyers@efficios.com
Link: http://lkml.kernel.org/r/150172775958.27216.12951305461398200544.stgit@devbox
csum_partial and csum_partial_copy_generic are defined unconditionally
and are available even when CONFIG_NET is disabled. They are used not
only by the network drivers, but also by scsi and media.
Don't limit these functions export by CONFIG_NET.
Pick up dependent changes.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
The function name is now renamed to 'timer_probe' for consistency with
the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Pull Xtensa fixes from Max Filippov:
- don't use linux IRQ #0 in legacy irq domains: fixes timer interrupt
assignment when it's hardware IRQ # is 0 and the kernel is built w/o
device tree support
- reduce reservation size for double exception vector literals from 48
to 20 bytes: fixes build on cores with small user exception vector
- cleanups: use kmalloc_array instead of kmalloc in simdisk_init and
seq_puts instead of seq_printf in c_show.
* tag 'xtensa-20170612' of git://github.com/jcmvbkbc/linux-xtensa:
xtensa: don't use linux IRQ #0
xtensa: reduce double exception literal reservation
xtensa: ISS: Use kmalloc_array() in simdisk_init()
xtensa: Use seq_puts() in c_show()
Linux IRQ #0 is reserved for error reporting and may not be used.
Increase NR_IRQS for one additional slot and increase
irq_domain_add_legacy parameter first_irq value to 1, so that linux
IRQ #0 is not associated with hardware IRQ #0 in legacy IRQ domains.
Introduce macro XTENSA_PIC_LINUX_IRQ for static translation of xtensa
PIC hardware IRQ # to linux IRQ #. Use this macro in XTFPGA platform
data definitions.
This fixes inability to use hardware IRQ #0 in configurations that don't
use device tree and allows for non-identity mapping between linux IRQ #
and hardware IRQ #.
Double exception vector only needs 20 bytes of space for 5 literals, not
48. Reduce the reservation for double exception vector literals
accordingly. This fixes build for configurations with small user
exception vector size.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add framework for supporting PCIe devices in Endpoint mode (Kishon
Vijay Abraham I)
- use non-postable PCI config space mappings when possible (Lorenzo
Pieralisi)
- clean up and unify mmap of PCI BARs (David Woodhouse)
- export and unify Function Level Reset support (Christoph Hellwig)
- avoid FLR for Intel 82579 NICs (Sasha Neftin)
- add pci_request_irq() and pci_free_irq() helpers (Christoph Hellwig)
- short-circuit config access failures for disconnected devices (Keith
Busch)
- remove D3 sleep delay when possible (Adrian Hunter)
- freeze PME scan before suspending devices (Lukas Wunner)
- stop disabling MSI/MSI-X in pci_device_shutdown() (Prarit Bhargava)
- disable boot interrupt quirk for ASUS M2N-LR (Stefan Assmann)
- add arch-specific alignment control to improve device passthrough by
avoiding multiple BARs in a page (Yongji Xie)
- add sysfs sriov_drivers_autoprobe to control VF driver binding
(Bodong Wang)
- allow slots below PCI-to-PCIe "reverse bridges" (Bjorn Helgaas)
- fix crashes when unbinding host controllers that don't support
removal (Brian Norris)
- add driver for MicroSemi Switchtec management interface (Logan
Gunthorpe)
- add driver for Faraday Technology FTPCI100 host bridge (Linus
Walleij)
- add i.MX7D support (Andrey Smirnov)
- use generic MSI support for Aardvark (Thomas Petazzoni)
- make Rockchip driver modular (Brian Norris)
- advertise 128-byte Read Completion Boundary support for Rockchip
(Shawn Lin)
- advertise PCI_EXP_LNKSTA_SLC for Rockchip root port (Shawn Lin)
- convert atomic_t to refcount_t in HV driver (Elena Reshetova)
- add CPU IRQ affinity in HV driver (K. Y. Srinivasan)
- fix PCI bus removal in HV driver (Long Li)
- add support for ThunderX2 DMA alias topology (Jayachandran C)
- add ThunderX pass2.x 2nd node MCFG quirk (Tomasz Nowicki)
- add ITE 8893 bridge DMA alias quirk (Jarod Wilson)
- restrict Cavium ACS quirk only to CN81xx/CN83xx/CN88xx devices
(Manish Jaggi)
* tag 'pci-v4.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (146 commits)
PCI: Don't allow unbinding host controllers that aren't prepared
ARM: DRA7: clockdomain: Change the CLKTRCTRL of CM_PCIE_CLKSTCTRL to SW_WKUP
MAINTAINERS: Add PCI Endpoint maintainer
Documentation: PCI: Add userguide for PCI endpoint test function
tools: PCI: Add sample test script to invoke pcitest
tools: PCI: Add a userspace tool to test PCI endpoint
Documentation: misc-devices: Add Documentation for pci-endpoint-test driver
misc: Add host side PCI driver for PCI test function device
PCI: Add device IDs for DRA74x and DRA72x
dt-bindings: PCI: dra7xx: Add DT bindings to enable unaligned access
PCI: dwc: dra7xx: Workaround for errata id i870
dt-bindings: PCI: dra7xx: Add DT bindings for PCI dra7xx EP mode
PCI: dwc: dra7xx: Add EP mode support
PCI: dwc: dra7xx: Facilitate wrapper and MSI interrupts to be enabled independently
dt-bindings: PCI: Add DT bindings for PCI designware EP mode
PCI: dwc: designware: Add EP mode support
Documentation: PCI: Add binding documentation for pci-test endpoint function
ixgbe: Use pcie_flr() instead of duplicating it
IB/hfi1: Use pcie_flr() instead of duplicating it
PCI: imx6: Fix spelling mistake: "contol" -> "control"
A string which did not contain a data format specification should be put
into a sequence. Thus use the corresponding function "seq_puts".
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Define macros SPILL_SLOT* that return a reference to the stack location
of the spill slot for specific register and use them instead of opencoded
address calculations.
Use tracehook_report_syscall_{entry,exit} instead of a local copy of it
in do_syscall_trace. Allow tracehook to cancel syscall by returning
invalid syscall number to the system_call function.
- make locally-used functions static;
- drop meaningless comments and commented out code;
- fix code style and alignment.
fast_io_protect is not used anywhere, drop its definition.
There is ITLB_HIT_BIT macro, no need to use 0x8 to check for TLB hit.
In all cases we know which BAR it is. Passing it in means that arch code
(or generic code; watch this space) won't have to go looking for it again.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
These should be uncached, not write-through.
Use %pB in pr_cont format string instead of calling print_symbol
separately. It turns
[ 19.166249] Call Trace:
[ 19.167265] [<a000e50a>]
[ 19.167843] __warn+0x92/0xa0
[ 19.169656] [<a000e554>]
[ 19.170059] warn_slowpath_fmt+0x3c/0x40
[ 19.171934] [<a02d5bd8>]
back into
[ 18.123240] Call Trace:
[ 18.125039] [<a000e4f6>] __warn+0x92/0xa0
[ 18.126961] [<a000e540>] warn_slowpath_fmt+0x3c/0x40
Move platform_setup call higher in initialization sequence so that it
could change kernel command line.
Check command line passed to simulator in ISS platform_stup and update
kernel command line if there's anything.
Pull Xtensa updates from Max Filippov:
- clean up bootable image build targets: provide separate 'Image',
'zImage' and 'uImage' make targets that only build corresponding
image type. Make 'all' build all images appropriate for a platform
- allow merging vectors code into .text section as a preparation step
for XIP support
- fix handling external FDT when the kernel is built without
BLK_DEV_INITRD support
* tag 'xtensa-20170303' of git://github.com/jcmvbkbc/linux-xtensa:
xtensa: allow merging vectors into .text section
xtensa: clean up bootable image build targets
xtensa: move parse_tag_fdt out of #ifdef CONFIG_BLK_DEV_INITRD
Move the following task->mm helper APIs into a new header file,
<linux/sched/mm.h>, to further reduce the size and complexity
of <linux/sched.h>.
Here are how the APIs are used in various kernel files:
# mm_alloc():
arch/arm/mach-rpc/ecard.c
fs/exec.c
include/linux/sched/mm.h
kernel/fork.c
# __mmdrop():
arch/arc/include/asm/mmu_context.h
kernel/fork.c
# mmdrop():
arch/m68k/sun3/mmu_emu.c
arch/x86/mm/tlb.c
drivers/gpu/drm/amd/amdkfd/kfd_process.c
drivers/gpu/drm/i915/i915_gem_userptr.c
drivers/infiniband/hw/hfi1/file_ops.c
drivers/vfio/vfio_iommu_spapr_tce.c
fs/exec.c
fs/proc/base.c
fs/proc/task_mmu.c
fs/proc/task_nommu.c
fs/userfaultfd.c
include/linux/mmu_notifier.h
kernel/fork.c
kernel/futex.c
kernel/sched/core.c
mm/khugepaged.c
mm/ksm.c
mm/mmu_context.c
mm/mmu_notifier.c
mm/oom_kill.c
virt/kvm/kvm_main.c
# mmdrop_async_fn():
# mmdrop_async():
kernel/fork.c
# mmget_not_zero():
fs/userfaultfd.c
mm/oom_kill.c
# mmput():
arch/arc/kernel/troubleshoot.c
arch/frv/mm/mmu-context.c
arch/powerpc/platforms/cell/spufs/context.c
arch/sparc/include/asm/mmu_context_32.h
drivers/android/binder.c
drivers/gpu/drm/etnaviv/etnaviv_gem.c
drivers/infiniband/core/umem.c
drivers/infiniband/core/umem_odp.c
drivers/infiniband/core/uverbs_main.c
drivers/infiniband/hw/mlx4/main.c
drivers/infiniband/hw/mlx5/main.c
drivers/infiniband/hw/usnic/usnic_uiom.c
drivers/iommu/amd_iommu_v2.c
drivers/iommu/intel-svm.c
drivers/lguest/lguest_user.c
drivers/misc/cxl/fault.c
drivers/misc/mic/scif/scif_rma.c
drivers/oprofile/buffer_sync.c
drivers/vfio/vfio_iommu_type1.c
drivers/vhost/vhost.c
drivers/xen/gntdev.c
fs/exec.c
fs/proc/array.c
fs/proc/base.c
fs/proc/task_mmu.c
fs/userfaultfd.c
kernel/cpuset.c
kernel/events/core.c
kernel/events/uprobes.c
kernel/exit.c
kernel/fork.c
kernel/ptrace.c
kernel/sys.c
kernel/trace/trace_output.c
kernel/tsacct.c
mm/memcontrol.c
mm/memory.c
mm/mempolicy.c
mm/migrate.c
mm/mmu_notifier.c
mm/nommu.c
mm/oom_kill.c
mm/process_vm_access.c
mm/rmap.c
mm/swapfile.c
mm/util.c
virt/kvm/async_pf.c
# mmput_async():
kernel/fork.c
mm/oom_kill.c
# get_task_mm():
fs/proc/array.c
fs/proc/base.c
fs/proc/task_mmu.c
kernel/cpuset.c
kernel/exit.c
kernel/fork.c
kernel/ptrace.c
kernel/sys.c
kernel/tsacct.c
mm/memcontrol.c
mm/memory.c
mm/mempolicy.c
mm/migrate.c
mm/mmu_notifier.c
mm/nommu.c
mm/util.c
# mm_access():
fs/proc/base.c
kernel/fork.c
# mm_release():
fs/exec.c
include/uapi/linux/sched.h
kernel/exit.c
kernel/fork.c
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched/task_stack.h>
But first update the usage sites with the new header dependency.
We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task_stack.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
<linux/sched/task.h>
We are going to split <linux/sched/task.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/task.h> file that just
bisectable.
<linux/sched/hotplug.h>
We are going to split <linux/sched/hotplug.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/hotplug.h> file that just
bisectable.
<linux/sched/debug.h>
We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/debug.h> file that just
bisectable.
to <linux/sched/mm.h>
We are going to split more MM APIs out of <linux/sched.h>, which
will have to be picked up from a couple of .c files.
The APIs that we are going to move are:
arch_pick_mmap_layout()
arch_get_unmapped_area_topdown()
mm_update_next_owner()
Include the header in the files that are going to need it.
<linux/sched/signal.h>
We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/signal.h> file that just
bisectable.
Currently code for exception/IRQ vectors is stored in kernel image as
initialization data and is copied to its working addresses during
startup. It doesn't always make sense. In many cases vectors location
can be automatically decided at kernel link time and code can be placed
right there. This is especially useful for XIP kernel.
FDT tag parsing is not related to whether BLK_DEV_INITRD is configured
or not, move it out of the corresponding #ifdef/#endif block.
This fixes passing external FDT to the kernel configured w/o
BLK_DEV_INITRD support.
Apart from adding the helper function itself, the rest of the kernel is
converted mechanically using:
git grep -l 'atomic_inc.*mm_users' | xargs sed -i 's/atomic_inc(&\(.*\)->mm_users);/mmget\(\1\);/'
git grep -l 'atomic_inc.*mm_users' | xargs sed -i 's/atomic_inc(&\(.*\)\.mm_users);/mmget\(\&\1\);/'
This is needed for a later patch that hooks into the helper, but might
be a worthwhile cleanup on its own.
(Michal Hocko provided most of the kerneldoc comment.)
Link: http://lkml.kernel.org/r/20161218123229.22952-2-vegard.nossum@oracle.com
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: David Rientjes <rientjes@google.com>
git grep -l 'atomic_inc.*mm_count' | xargs sed -i 's/atomic_inc(&\(.*\)->mm_count);/mmgrab\(\1\);/'
git grep -l 'atomic_inc.*mm_count' | xargs sed -i 's/atomic_inc(&\(.*\)\.mm_count);/mmgrab\(\&\1\);/'
Link: http://lkml.kernel.org/r/20161218123229.22952-1-vegard.nossum@oracle.com
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull rdma DMA mapping updates from Doug Ledford:
"Drop IB DMA mapping code and use core DMA code instead.
Bart Van Assche noted that the ib DMA mapping code was significantly
similar enough to the core DMA mapping code that with a few changes it
was possible to remove the IB DMA mapping code entirely and switch the
RDMA stack to use the core DMA mapping code.
This resulted in a nice set of cleanups, but touched the entire tree
and has been kept separate for that reason."
* tag 'for-next-dma_ops' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (37 commits)
IB/rxe, IB/rdmavt: Use dma_virt_ops instead of duplicating it
IB/core: Remove ib_device.dma_device
nvme-rdma: Switch from dma_device to dev.parent
RDS: net: Switch from dma_device to dev.parent
IB/srpt: Modify a debug statement
IB/srp: Switch from dma_device to dev.parent
IB/iser: Switch from dma_device to dev.parent
IB/IPoIB: Switch from dma_device to dev.parent
IB/rxe: Switch from dma_device to dev.parent
IB/vmw_pvrdma: Switch from dma_device to dev.parent
IB/usnic: Switch from dma_device to dev.parent
IB/qib: Switch from dma_device to dev.parent
IB/qedr: Switch from dma_device to dev.parent
IB/ocrdma: Switch from dma_device to dev.parent
IB/nes: Remove a superfluous assignment statement
IB/mthca: Switch from dma_device to dev.parent
IB/mlx5: Switch from dma_device to dev.parent
IB/mlx4: Switch from dma_device to dev.parent
IB/i40iw: Remove a superfluous assignment statement
IB/hns: Switch from dma_device to dev.parent
