path: root/arch/xtensa/variants
2013-02-23xtensa: Add config files for Diamond 233L - Rev C processor variantPete Delaney
The Diamond 233L processor is a pre-configured Xtensa processor tailored for Linux application. Signed-off-by: Pete Delaney <piet@tensilica.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-12-18xtensa: unbalanced parenthesesNicolas Kaiser
Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-05-17xtensa: Change mail addresses of Hannes Weiner and Oskar SchirmerOskar Schirmer
These old mail addresses dont exist any more. This changes all occurences to the authors' current addresses. Signed-off-by: Oskar Schirmer <oskar@scara.com> Cc: Chris Zankel <chris@zankel.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-11XTENSA: static should be at beginning of declarationJesper Juhl
Make sure that the 'static' keywork is at the beginning of declaration for arch/xtensa/variants/s6000/include/variant/dmac.h This gets rid of warnings like warning: ‘static’ is not at beginning of declaration when building with -Wold-style-declaration (and/or -Wextra which also enables it). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-24xtensa: Convert genirq namespaceThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-24xtensa: Convert s6000 gpio irq_chip to new functionsThomas Gleixner
Also use proper wrappers for irq_desc access. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110206211137.750284615@linutronix.de>
2009-06-22xtensa: support s6000 gpio irqs and alternate function selectionDaniel Glöckner
Implement an irq chip to handle interrupts via gpio. The GPIO chip initialization function now takes a bitmask denoting pins that should be configured for their alternate function. changes compared to v1: - fixed bug on edge interrupt configuration - accommodated to function name change - moved definition of VARIANT_NR_IRQS to this patch - renamed __XTENSA_S6000_IRQ_H to _XTENSA_S6000_IRQ_H as requested Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Johannes Weiner <jw@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-06-22xtensa: s6000 dma engine supportOskar Schirmer
There are four slightly different dma engines on the s6000 family. One for memory-memory transfers, the other three for memory-device. This patch implements a platform-specific kernel-API to control these engines. It is needed for the network, video, audio peripherals on s6000. Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Daniel Glockner <dg@emlix.com> Signed-off-by: Fabian Godehardt <fg@emlix.com> Cc: Daniel Glockner <dg@emlix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-05-11xtensa: implement ccount calibration for s6000Oskar Schirmer
Calculate core frequency from timers at boot time instead of assuming a fixed frequency. This is useful as the true frequency is set up by the boot loader, thus variable. Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-05-11xtensa: register gpio chip before useJohannes Weiner
Platform initialization sets up the LED heartbeat that is controlled via GPIO. Requesting the GPIO pins fails, however, as the chip is only initialized later by a device_initcall(). Fix this up by exporting the initialization function. Let the platform set up the chip before it starts using it. Signed-off-by: Johannes Weiner <jw@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-04-03xtensa: only build platform or variant if they contain a MakefileChris Zankel
We only add the platform or variant directory to core-y if it contains a Makefile. Consequently, we can remove the Makefiles for the dc232b and fsf processor variants. Signed-off-by: Chris Zankel <chris@zankel.net>
2009-04-02xtensa: s6000 variantJohannes Weiner
Support for the Stretch S6000 Xtensa core variant. Signed-off-by: Johannes Weiner <jw@emlix.com> Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-04-02xtensa: s6000 variant core definitionsJohannes Weiner
S6000 core configuration files from Tensilica. Signed-off-by: Johannes Weiner <jw@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-04-02xtensa: variant-specific codeJohannes Weiner
Allow the variant to provide real code. Add empty dummy Makefiles for the existing variants. Signed-off-by: Johannes Weiner <jw@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2008-11-06xtensa: move headers files to arch/xtensa/includeChris Zankel
Move all header files for xtensa to arch/xtensa/include and platform and variant header files to the appropriate arch/xtensa/platforms/ and arch/xtensa/variants/ directories. Moving the files gets also rid of all uses of symlinks in the Makefile. This has been completed already for the majority of the architectures and xtensa is one out of six missing. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Chris Zankel <chris@zankel.net>
