path: root/arch/xtensa
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26h8300/m68k/xtensa: __FD_ISSET should return 0/1Andrew Morton
Harmonise these return values with other architectures. In some cases this affects all compilers and in other cases non-gcc compilers only. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Chris Zankel <chris@zankel.net> Cc: Ulrich Drepper <drepper@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25xtensa: fix a build error in arch/xtensa/include/asm/uaccess.hWANG Cong
Fix the following build error: arch/xtensa/include/asm/uaccess.h:403: error: implicit declaration of function 'prefetch' arch/xtensa/include/asm/uaccess.h:412: error: implicit declaration of function 'prefetchw' Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25xtensa: prevent arbitrary read in ptraceDan Rosenberg
Prevent an arbitrary kernel read. Check the user pointer with access_ok() before copying data in. [akpm@linux-foundation.org: s/EIO/EFAULT/] Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Christian Zankel <chris@zankel.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-11XTENSA: static should be at beginning of declarationJesper Juhl
Make sure that the 'static' keywork is at the beginning of declaration for arch/xtensa/variants/s6000/include/variant/dmac.h This gets rid of warnings like warning: ‘static’ is not at beginning of declaration when building with -Wold-style-declaration (and/or -Wextra which also enables it). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-05xtensa: Use generic config PREEMPT definitionFrederic Weisbecker
So that it can handle the new CONFIG_PREEMPT_COUNT. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Chris Zankel <chris@zankel.net>
2011-06-20treewide: remove duplicate includesVitaliy Ivanov
Many stupid corrections of duplicated includes based on the output of scripts/checkincludes.pl. Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25xtensa/mm: remove WANT_PAGE_VIRTUALSebastian Andrzej Siewior
This is not useful: it provides page->virtual and is used with highmem. xtensa has no support for highmem and those HIGHMEM bits which are found by grep are partly implemented. The interesting functions like kmap() are missing. If someone actually implements the complete HIGHMEM support he could use HASHED_PAGE_VIRTUAL like most others do. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Chris Zankel <chris@zankel.net> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25xtensa/mm: remove pgtable.cSebastian Andrzej Siewior
It is not referenced by any Makefile. pte_alloc_one_kernel() and pte_alloc_one() is implemented in arch/xtensa/include/asm/pgalloc.h. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Chris Zankel <chris@zankel.net> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-20xtensa: Fixup irq conversion fallout and nmi_countThomas Gleixner
Some unnamed moron fatfingered the arguments of the irq chip callbacks to irq_chip instead of irq_data. While at it remove the nmi_count() print in arch_show_interrupts() which has been broken before the irq conversion already. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-04-11xtensa: remove obsolete BKL kernel option from defconfigAlessio Igor Bogani
The BKL doesn't exist anymore so remove CONFIG_LOCK_KERNEL. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-25Merge branch 'irq-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits) genirq: Expand generic show_interrupts() gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler gpio: Cleanup genirq namespace arm: ep93xx: Add basic interrupt info arm/gpio: Remove three copies of broken and racy debug code xtensa: Use generic show_interrupts() xtensa: Convert genirq namespace xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED xtensa: Convert s6000 gpio irq_chip to new functions xtensa: Convert main irq_chip to new functions um: Use generic show_interrupts() um: Convert genirq namespace m32r: Use generic show_interrupts() m32r: Convert genirq namespace h8300: Use generic show_interrupts() h8300: Convert genirq namespace avr32: Cleanup eic_set_irq_type() avr32: Use generic show_interrupts() avr: Cleanup genirq namespace avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED ... Fix up trivial conflict in drivers/gpio/timbgpio.c
2011-03-24xtensa: Use generic show_interrupts()Thomas Gleixner
2011-03-24xtensa: Convert genirq namespaceThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-24xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATEDThomas Gleixner
All chips converted. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110206211137.849317253@linutronix.de>
2011-03-24xtensa: Convert s6000 gpio irq_chip to new functionsThomas Gleixner
Also use proper wrappers for irq_desc access. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110206211137.750284615@linutronix.de>
2011-03-24xtensa: Convert main irq_chip to new functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110206211137.653005586@linutronix.de>
2011-03-24percpu: Always align percpu output section to PAGE_SIZETejun Heo
Percpu allocator honors alignment request upto PAGE_SIZE and both the percpu addresses in the percpu address space and the translated kernel addresses should be aligned accordingly. The calculation of the former depends on the alignment of percpu output section in the kernel image. The linker script macros PERCPU_VADDR() and PERCPU() are used to define this output section and the latter takes @align parameter. Several architectures are using @align smaller than PAGE_SIZE breaking percpu memory alignment. This patch removes @align parameter from PERCPU(), renames it to PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it, add PCPU_SETUP_BUG_ON() checks such that alignment problems are reliably detected and remove percpu alignment comment recently added in workqueue.c as the condition would trigger BUG way before reaching there. For um, this patch raises the alignment of percpu area. As the area is in .init, there shouldn't be any noticeable difference. This problem was discovered by David Howells while debugging boot failure on mn10300. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce CONFIG_GENERIC_FIND_BIT_LEAkinobu Mita
This introduces CONFIG_GENERIC_FIND_BIT_LE to tell whether to use generic implementation of find_*_bit_le() in lib/find_next_bit.c or not. For now we select CONFIG_GENERIC_FIND_BIT_LE for all architectures which enable CONFIG_GENERIC_FIND_NEXT_BIT. But m68knommu wants to define own faster find_next_zero_bit_le() and continues using generic find_next_{,zero_}bit(). (CONFIG_GENERIC_FIND_NEXT_BIT and !CONFIG_GENERIC_FIND_BIT_LE) Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17xtensa: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-16Merge branch 'for-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support percpu: Generic support for this_cpu_cmpxchg_double() alpha: use L1_CACHE_BYTES for cacheline size in the linker script percpu: align percpu readmostly subsection to cacheline Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the percpu alignment having changed ("x86: Reduce back the alignment of the per-CPU data section")
2011-03-15Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits) posix-clocks: Check write permissions in posix syscalls hrtimer: Remove empty hrtimer_init_hres_timer() hrtimer: Update hrtimer->state documentation hrtimer: Update base[CLOCK_BOOTTIME].offset correctly timers: Export CLOCK_BOOTTIME via the posix timers interface timers: Add CLOCK_BOOTTIME hrtimer base time: Extend get_xtime_and_monotonic_offset() to also return sleep time: Introduce get_monotonic_boottime and ktime_get_boottime hrtimers: extend hrtimer base code to handle more then 2 clockids ntp: Remove redundant and incorrect parameter check mn10300: Switch do_timer() to xtimer_update() posix clocks: Introduce dynamic clocks posix-timers: Cleanup namespace posix-timers: Add support for fd based clocks x86: Add clock_adjtime for x86 posix-timers: Introduce a syscall for clock tuning. time: Splitout compat timex accessors ntp: Add ADJ_SETOFFSET mode bit time: Introduce timekeeping_inject_offset posix-timer: Update comment ... Fix up new system-call-related conflicts in arch/x86/ia32/ia32entry.S arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/syscall_table_32.S (name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some due to movement of get_jiffies_64() in: kernel/time.c
2011-02-17tty: add TIOCVHANGUP to allow clean tty shutdown of all ttysKay Sievers
This is useful for system management software so that it can kick off things like gettys and everything that's started from a tty, before we reuse it from/for something else or shut it down. Without this ioctl it would have to temporarily become the owner of the tty, then call vhangup() and then give it up again. Cc: Lennart Poettering <lennart@poettering.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-15Merge branch 'master' into for-nextJiri Kosina
2011-01-31xtensa: Switch do_timer() to xtime_update()Torben Hohn
xtime_update() takes the xtime_lock itself. set_linux_timer() does not need to be protected by xtime_lock. [ tglx: This code is broken on SMP anyway. ] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Chris Zankel <chris@zankel.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: hch@infradead.org Cc: yong.zhang0@gmail.com LKML-Reference: <20110127150027.23248.61798.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-27rwsem: Move duplicate function prototypes to linux/rwsem.hThomas Gleixner
All architecture specific rwsem headers carry the same function prototypes. Just x86 adds asmregparm, which is an empty define on all other architectures. S390 has a stale rwsem_downgrade_write() prototype. Remove the duplicates and add the prototypes to linux/rwsem.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.970840140@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
