commit 01e84c70fe40c8111f960987bcf7f931842e6d07 upstream.
xtensa actually uses sync_file_range2 implementation, so it should
define __NR_sync_file_range2 as other architectures that use that
function. That fixes userspace interface (that apparently never worked)
and avoids special-casing xtensa in libc implementations.
See the thread ending at
http://lists.busybox.net/pipermail/uclibc/2015-February/048833.html
for more details.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 4949009eb8d40a441dcddcd96e101e77d31cf1b2 upstream.
LCD driver is always built for the XTFPGA platform, but its base address
is not configurable, and is wrong for ML605/KC705. Its initialization
locks up KC705 board hardware.
Make the whole driver optional, and its base address and bus width
configurable. Implement 4-bit bus access method.
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
[shengyong: Backport to 3.10
- adjust context
- ignore modification for arch nios2, because 3.10 does not support it
- ignore modification for driver lustre, because 3.10 does not support it
- ignore VM_FAULT_FALLBACK in VM_FAULT_ERROR, becase 3.10 does not support
this flag
- add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.10 does not
separate it to copro_fault.c
- add SIGSEGV handling in mm/memory.c, because 3.10 does not separate it
to gup.c
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
commit 759496ba6407c6994d6a5ce3a5e74937d7816208 upstream.
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
commit 2651cc6974d47fc43bef1cd8cd26966e4f5ba306 upstream.
Userspace actually passes single parameter (path name) to the umount
syscall, so new umount just fails. Fix it by requesting old umount
syscall implementation and re-wiring umount to it.
commit d1b6ba82a50cecf94be540a3a153aa89d97511a0 upstream.
Remove restoring a6 on some return paths and instead modify and restore
it in a single place, using symbolic name.
Correctly restore a7 from PT_AREG7 in case of illegal a6 value.
commit 7128039fe2dd3d59da9e4ffa036f3aaa3ba87b9f upstream.
Current definition of TLBTEMP_BASE_2 is always 32K above the
TLBTEMP_BASE_1, whereas fast_second_level_miss handler for the TLBTEMP
region analyzes virtual address bit (PAGE_SHIFT + DCACHE_ALIAS_ORDER)
to determine TLBTEMP region where the fault happened. The size of the
TLBTEMP region is also checked incorrectly: not 64K, but twice data
cache way size (whicht may as well be less than the instruction cache
way size).
Fix TLBTEMP_BASE_2 to be TLBTEMP_BASE_1 + data cache way size.
Provide TLBTEMP_SIZE that is a greater of doubled data cache way size or
the instruction cache way size, and use it to determine if the second
level TLB miss occured in the TLBTEMP region.
Practical occurence of page faults in the TLBTEMP area is extremely
rare, this code can be tested by deletion of all w[di]tlb instructions
in the tlbtemp_mapping region.
commit 52247123749cc3cbc30168b33ad8c69515c96d23 upstream.
With SMP and a lot of debug options enabled task_struct::thread gets out
of reach of s32i/l32i instructions with base pointing at task_struct,
breaking build with the following messages:
arch/xtensa/kernel/entry.S: Assembler messages:
arch/xtensa/kernel/entry.S:1002: Error: operand 3 of 'l32i.n' has invalid value '1048'
arch/xtensa/kernel/entry.S:1831: Error: operand 3 of 's32i.n' has invalid value '1040'
arch/xtensa/kernel/entry.S:1832: Error: operand 3 of 's32i.n' has invalid value '1044'
Change base to point to task_struct::thread in such cases.
Don't use a10 in _switch_to to save/restore prev pointer as a2 is not
clobbered.
commit 1ca49463c44c970b1ab1d71b0f268bfdf8427a7e upstream.
Virtual address is translated to the XCHAL_KSEG_CACHED region in the
dma_free_coherent, but is checked to be in the 0...XCHAL_KSEG_SIZE
range.
Change check for end of the range from 'addr >= X' to 'addr > X - 1' to
handle the case of X == 0.
Replace 'if (C) BUG();' construct with 'BUG_ON(C);'.
Signed-off-by: Alan Douglas <adouglas@cadence.com>
commit f61bf8e7d19e0a3456a7a9ed97c399e4353698dc upstream.
This fixes userspace code that builds on other architectures but fails
on xtensa due to references to structures that other architectures don't
refer to. E.g. this fixes the following issue with python-2.7.8:
python-2.7.8/Modules/termios.c:861:25: error: invalid application
of 'sizeof' to incomplete type 'struct serial_multiport_struct'
{"TIOCSERGETMULTI", TIOCSERGETMULTI},
python-2.7.8/Modules/termios.c:870:25: error: invalid application
{"TIOCSERSETMULTI", TIOCSERSETMULTI},
python-2.7.8/Modules/termios.c:900:24: error: invalid application
of 'sizeof' to incomplete type 'struct tty_struct'
{"TIOCTTYGSTRUCT", TIOCTTYGSTRUCT},
commit e2fd1374c705abe4661df3fb6fadb3879c7c1846 upstream.
Most in-kernel users want registers spilled on the kernel stack and
don't require PS.EXCM to be set. That means that they don't need fixup
routine and could reuse regular window overflow mechanism for that,
which makes spill routine very simple.
Suggested-by: Chris Zankel <chris@zankel.net>
commit a558d99263936b8a67d4eff8918745a77bfd8c31 upstream.
Remove __initdata attribute, as the devices may be used after init
sections are freed.
commit cba9a90053e3b7973eff4f1946f33032e98eeed5 upstream.
According to create_thread(3): "The new thread does not inherit the creating
thread's alternate signal stack". Since commit f9a3879a (Fix sigaltstack
corruption among cloned threads), current->sas_ss_size is set to 0 for cloned
processes sharing VM with their parent. Don't use the (nonexistent) alternate
signal stack in this case. This has been broken since commit 29c4dfd9 ([XTENSA]
Remove non-rt signal handling).
Fixes the SA_ONSTACK part of the nptl/tst-cancel20 test from uClibc.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Chris Zankel <chris@zankel.net>
INITIALIZE_XTENSA_MMU_INSIDE_VMLINUX is selected
commit c5a771d0678f9613e9f89cf1a5bdcfa5b08b225b upstream.
The virtual address of boot parameters chain is passed to the kernel via
a2 register. Adjust it in case it is remapped during MMUv3 -> MMUv2
mapping change, i.e. when it is in the first 128M.
Also fix interpretation of initrd and FDT addresses passed in the boot
parameters: these are physical addresses.
Reported-by: Baruch Siach <baruch@tkos.co.il>
Pull xtensa updates from Chris Zankel:
"Support for the latest MMU architecture that allows for a larger
accessible memory region, and various bug-fixes"
* tag 'xtensa-next-20130508' of git://github.com/czankel/xtensa-linux:
xtensa: Switch to asm-generic/linkage.h
xtensa: fix redboot load address
xtensa: ISS: fix timer_lock usage in rs_open
xtensa: disable IRQs while IRQ handler is running
xtensa: enable lockdep support
xtensa: fix arch_irqs_disabled_flags implementation
xtensa: add irq flags trace support
xtensa: provide custom CALLER_ADDR* implementations
xtensa: add stacktrace support
xtensa: clean up stpill_registers
xtensa: don't use a7 in simcalls
xtensa: don't attempt to use unconfigured timers
xtensa: provide default platform_pcibios_init implementation
xtensa: remove KCORE_ELF again
xtensa: document MMUv3 setup sequence
xtensa: add MMU v3 support
xtensa: fix ibreakenable register update
xtensa: fix oprofile building as module
Pull more vfs fixes from Al Viro:
"Regression fix from Geert + yet another open-coded kernel_read()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ecryptfs: don't open-code kernel_read()
xtensa simdisk: Fix proc_create_data() conversion fallout
arch/xtensa/platforms/iss/simdisk.c: In function 'proc_read_simdisk':
arch/xtensa/platforms/iss/simdisk.c:220:12: warning: initialization discards 'const' qualifier from pointer target type [enabled by default]
arch/xtensa/platforms/iss/simdisk.c: In function 'proc_write_simdisk':
arch/xtensa/platforms/iss/simdisk.c:241:38: error: 'buffer' undeclared (first use in this function)
arch/xtensa/platforms/iss/simdisk.c:241:38: note: each undeclared identifier is reported only once for each function it appears in
Introduced by commit a69755b187749e7cc020e17127a54f395aea4eaa ("xtensa
simdisk: switch to proc_create_data()")
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
With the patch to support MMUv3, the base address for the loaded
binary image has changed, and a fix was applied to the U-Boot image.
This fixes the RedBoot image.
This fixes the following lockdep splat:
[ 66.460000] =================================
[ 66.460000] [ INFO: inconsistent lock state ]
[ 66.460000] 3.9.0-rc5-00161-ga48dd49 #4 Not tainted
[ 66.460000] ---------------------------------
[ 66.460000] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
[ 66.460000] swapper/1 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 66.460000] (timer_lock){+.?...}, at: [<d0006cde>] rs_poll+0x12/0xdc
[ 66.460000] {SOFTIRQ-ON-W} state was registered at:
[ 66.460000] [<d00421f0>] lock_acquire+0xec/0x13c
[ 66.460000] [<d01ea036>] _raw_spin_lock+0x3a/0x84
[ 66.460000] [<d0006c8c>] rs_open+0x18/0x58
[ 66.460000] [<d0139ea2>] tty_open+0x262/0x3cc
[ 66.460000] [<d00942e0>] chrdev_open+0x8c/0xe0
[ 66.460000] [<d00907b2>] do_dentry_open$isra$16+0x10e/0x190
[ 66.460000] [<d0091141>] finish_open+0x39/0x48
[ 66.460000] [<d009a0b4>] do_last$isra$34+0x6c4/0x824
[ 66.460000] [<d009a27a>] path_openat+0x66/0x310
[ 66.460000] [<d009a53a>] do_filp_open+0x16/0x44
[ 66.460000] [<d0091445>] do_sys_open+0xd5/0x13c
[ 66.460000] [<d00914be>] sys_open+0x12/0x18
[ 66.460000] [<d0413ffc>] kernel_init_freeable+0xe4/0x12c
[ 66.460000] [<d01e2a9c>] kernel_init+0xc/0x9c
[ 66.460000] [<d00044fc>] ret_from_kernel_thread+0x8/0xc
[ 66.460000] irq event stamp: 132542
[ 66.460000] hardirqs last enabled at (132542): [<d01ea2ec>] _raw_spin_unlock_irq+0x30/0x44
[ 66.460000] hardirqs last disabled at (132541): [<d01ea11e>] _raw_spin_lock_irq+0xe/0x8c
[ 66.460000] softirqs last enabled at (132234): [<d0017d32>] __do_softirq+0x216/0x2a4
[ 66.460000] softirqs last disabled at (132539): [<d0018024>] irq_exit+0x38/0x40
[ 66.460000]
[ 66.460000] other info that might help us debug this:
[ 66.460000] Possible unsafe locking scenario:
[ 66.460000]
[ 66.460000] CPU0
[ 66.460000] ----
[ 66.460000] lock(timer_lock);
[ 66.460000] <Interrupt>
[ 66.460000]
[ 66.460000] *** DEADLOCK ***
[ 66.460000]
[ 66.460000] 1 lock held by swapper/1:
[ 66.460000] #0: (((&serial_timer))){+.-...}, at: [<d001c65c>] call_timer_fn+0x0/0x1f0
[ 66.460000]
Stack: d7c2fac0 00000018 00000004 00000001 d7c2faa0 00000004 00000006 d7c2fa90
9003e87c d7c2fae0 d7c30000 d025a87c 00000001 0000000f 00000000 d7c2fac0
9004005d d7c2fb10 d7c30000 d7c30338 00000001 00000001 00000000 d7c30338
[ 66.460000] Call Trace:
[ 66.460000] [<d01e4f93>] print_usage_bug$part$26+0x1c3/0x1c8
[ 66.460000] [<d003e87c>] mark_lock+0x2b4/0x440
[ 66.460000] [<d004005d>] __lock_acquire+0x54d/0x16c4
[ 66.460000] [<d0006cde>] rs_poll+0x12/0xdc
[ 66.460000] [<d001c71a>] call_timer_fn+0xbe/0x1f0
[ 66.460000] [<d001cd90>] run_timer_softirq+0x198/0x1f4
[ 66.460000] [<d0017c30>] __do_softirq+0x114/0x2a4
[ 66.460000] [<d0018024>] irq_exit+0x38/0x40
[ 66.460000] [<d00046c0>] do_IRQ+0x44/0x48
[ 66.460000] [<d0005c58>] do_interrupt+0x4c/0x54
[ 66.460000] [<d0003c80>] common_exception_return+0x0/0x5c
[ 66.460000] [<d006682c>] free_pcppages_bulk+0x254/0x308
[ 66.460000]
IRQ handlers are expected to run with IRQs disabled.
See e.g. http://lwn.net/Articles/380931/ for a longer story.
This was overlooked in the commit
2d1c645 xtensa: dispatch medium-priority interrupts
Revert to old behavior and simplify interrupt entry and exit code.
Interrupt handler still honours IRQ priority.
do_notify_resume/schedule must be called with interrupts enabled, enable
interrupts if we return from user exception.
IRQs are disabled when PS.EXCM is set or PS.INTLEVEL is equal to or
higher than LOCKLEVEL.
Definition of CALLER_ADDR* through __builtin_return_address makes
compiler insert calls to __xtensa_libgcc_window_spill, which in turn
makes fast_syscall_spill_registers syscall that clobbers registers when
called from the kernel mode, leading to invalid opcode exceptions on
return to userspace.
Provide definition for CALLER_ADDR0 as MAKE_PC_FROM_RA(a0, a1) and in
case CONFIG_FRAME_POINTER is enabled extract CALLER_ADDR{1-3} from
stack.
- remove unused asm parameters;
- fix EXCM bit setting in the PS SR during _spill_registers call.
To support FRAME_POINTER avoid using a7 in __simc (none of the existing
simcalls needs it). Replace calls to __simc with more specific
simc_read, simc_write and simc_lseek calls.
This fixes the following build error:
arch/xtensa/kernel/built-in.o:(.init.literal+0xe8): undefined reference
to `platform_pcibios_init'
arch/xtensa/kernel/built-in.o: In function `setup_arch':
(.init.text+0x20e): undefined reference to `platform_pcibios_init'
and allows platform to omit definition of platform_pcibios_init if it's
empty.
The Kconfig symbol KCORE_ELF was removed in v2.6.0, but reappeared in two
architectures. It is useless. Remove it again.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
MMUv3 comes out of reset with identity vaddr -> paddr mapping in the TLB
way 6:
Way 6 (512 MB)
Vaddr Paddr ASID Attr RWX Cache
0x00000000 0x00000000 0x01 0x03 RWX Bypass
0x20000000 0x20000000 0x01 0x03 RWX Bypass
0x40000000 0x40000000 0x01 0x03 RWX Bypass
0x60000000 0x60000000 0x01 0x03 RWX Bypass
0x80000000 0x80000000 0x01 0x03 RWX Bypass
0xa0000000 0xa0000000 0x01 0x03 RWX Bypass
0xc0000000 0xc0000000 0x01 0x03 RWX Bypass
0xe0000000 0xe0000000 0x01 0x03 RWX Bypass
This patch adds remapping code at the reset vector or at the kernel
_start (depending on CONFIG_INITIALIZE_XTENSA_MMU_INSIDE_VMLINUX) that
reconfigures MMUv3 as MMUv2:
Way 5 (128 MB)
0xd0000000 0x00000000 0x01 0x07 RWX WB
0xd8000000 0x00000000 0x01 0x03 RWX Bypass
Way 6 (256 MB)
0xe0000000 0xf0000000 0x01 0x07 RWX WB
0xf0000000 0xf0000000 0x01 0x03 RWX Bypass
Only set the register when there is at least one ibreak register,
otherwise the build fails:
arch/xtensa/kernel/head.S:105: Error: invalid register 'ibreakenable'
for 'wsr' instruction
arch/xtensa/platforms/iss/setup.c:67: Error: invalid register
'ibreakenable' for 'wsr' instruction
The value passed is 0 in all but "it can never happen" cases (and those
only in a couple of drivers) *and* it would've been lost on the way
out anyway, even if something tried to pass something meaningful.
Just don't bother.
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
show_regs() is inherently arch-dependent but it does make sense to print
generic debug information and some archs already do albeit in slightly
different forms. This patch introduces a generic function to print debug
information from show_regs() so that different archs print out the same
information and it's much easier to modify what's printed.
show_regs_print_info() prints out the same debug info as dump_stack()
does plus task and thread_info pointers.
* Archs which didn't print debug info now do.
alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r,
metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc,
um, xtensa
* Already prints debug info. Replaced with show_regs_print_info().
The printed information is superset of what used to be there.
arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86
* s390 is special in that it used to print arch-specific information
along with generic debug info. Heiko and Martin think that the
arch-specific extra isn't worth keeping s390 specfic implementation.
Converted to use the generic version.
Note that now all archs print the debug info before actual register
dumps.
An example BUG() dump follows.
kernel BUG at /work/os/work/kernel/workqueue.c:4841!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000
RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6
RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246
RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a
RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0
Stack:
ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650
0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d
ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760
Call Trace:
[<ffffffff81000312>] do_one_initcall+0x122/0x170
[<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8
[<ffffffff81c47760>] ? rest_init+0x140/0x140
[<ffffffff81c4776e>] kernel_init+0xe/0xf0
[<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0
v2: Typo fix in x86-32.
v3: CPU number dropped from show_regs_print_info() as
dump_stack_print_info() has been updated to print it. s390
specific implementation dropped as requested by s390 maintainers.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Pull SMP/hotplug changes from Ingo Molnar:
"This is a pretty large, multi-arch series unifying and generalizing
the various disjunct pieces of idle routines that architectures have
historically copied from each other and have grown in random, wildly
inconsistent and sometimes buggy directions:
101 files changed, 455 insertions(+), 1328 deletions(-)
this went through a number of review and test iterations before it was
committed, it was tested on various architectures, was exposed to
linux-next for quite some time - nevertheless it might cause problems
on architectures that don't read the mailing lists and don't regularly
test linux-next.
This cat herding excercise was motivated by the -rt kernel, and was
brought to you by Thomas "the Whip" Gleixner."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
idle: Remove GENERIC_IDLE_LOOP config switch
um: Use generic idle loop
ia64: Make sure interrupts enabled when we "safe_halt()"
sparc: Use generic idle loop
idle: Remove unused ARCH_HAS_DEFAULT_IDLE
bfin: Fix typo in arch_cpu_idle()
xtensa: Use generic idle loop
x86: Use generic idle loop
unicore: Use generic idle loop
tile: Use generic idle loop
tile: Enter idle with preemption disabled
sh: Use generic idle loop
score: Use generic idle loop
s390: Use generic idle loop
powerpc: Use generic idle loop
parisc: Use generic idle loop
openrisc: Use generic idle loop
mn10300: Use generic idle loop
mips: Use generic idle loop
microblaze: Use generic idle loop
Use common help functions to free reserved pages.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
All archs are converted over. Remove the config switch and the
fallback code.
GENERIC_GPIO has been made equivalent to GPIOLIB in architecture code
and all driver code has been switch to depend on GPIOLIB. It is thus
safe to have GENERIC_GPIO removed.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
The only part of proc_dir_entry the code outside of fs/proc
really cares about is PDE(inode)->data. Provide a helper
for that; static inline for now, eventually will be moved
to fs/proc, along with the knowledge of struct proc_dir_entry
layout.
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Acked-by: Chris Zankel <chris@zankel.net>
Link: http://lkml.kernel.org/r/20130321215235.546600507@linutronix.de
Currently, when a socket receives something on the error queue it only wakes up
the socket on select if it is in the "read" list, that is the socket has
something to read. It is useful also to wake the socket if it is in the error
list, which would enable software to wait on error queue packets without waking
up for regular data on the socket. The main use case is for receiving
timestamped transmit packets which return the timestamp to the socket via the
error queue. This enables an application to select on the socket for the error
queue only instead of for the regular traffic.
-v2-
* Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file
* Modified every socket poll function that checks error queue
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Matthew Vick <matthew.vick@intel.com>
