commit 36de10c4788efc6efe6ff9aa10d38cb7eea4c818 upstream.
Virtual and translated addresses retrieved by the xtensa TLB sanity
checker must be consistent, i.e. correspond to the same state of the
checked TLB entry. KASAN shadow memory is mapped dynamically using
auto-refill TLB entries and thus may change TLB state between the
virtual and translated address retrieval, resulting in false TLB
insanity report.
Move read_xtlb_translation close to read_xtlb_virtual to make sure that
read values are consistent.
Cc: stable@vger.kernel.org
Fixes: a99e07ee5e88 ("xtensa: check TLB sanity on return to userspace")
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 8b39da985194aac2998dd9e3a22d00b596cebf1e upstream.
Custom outs*/ins* implementations are long gone from the xtensa port,
remove matching EXPORT_SYMBOLs.
This fixes the following build warnings issued by modpost since commit
15bfc2348d54 ("modpost: check for static EXPORT_SYMBOL* functions"):
WARNING: "insb" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "insw" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "insl" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsb" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsw" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsl" [vmlinux] is a static EXPORT_SYMBOL
Fixes: d38efc1f150f ("xtensa: adopt generic io routines")
commit cd8869f4cb257f22b89495ca40f5281e58ba359c upstream.
ITLB entry modifications must be followed by the isync instruction
before the new entries are possibly used. cpu_reset lacks one isync
between ITLB way 6 initialization and jump to the identity mapping.
Add missing isync to xtensa cpu_reset.
[ Upstream commit adefd051a6707a6ca0ebad278d3c1c05c960fc3b ]
Since commit 9012d011660ea5cf2 ("compiler: allow all arches to enable
CONFIG_OPTIMIZE_INLINING"), xtensa:tinyconfig fails to build with section
mismatch errors.
WARNING: vmlinux.o(.text.unlikely+0x68): Section mismatch in reference
from the function ___pa()
to the function .meminit.text:memblock_reserve()
WARNING: vmlinux.o(.text.unlikely+0x74): Section mismatch in reference
from the function mem_reserve()
FATAL: modpost: Section mismatches detected.
This was not seen prior to the above mentioned commit because mem_reserve()
was always inlined.
Mark mem_reserve(() as __init_memblock to have it reside in the same
section as memblock_reserve().
Message-Id: <1559220098-9955-1-git-send-email-linux@roeck-us.net>
[ Upstream commit f37598be4e3896359e87c824be57ddddc280cc3f ]
Rename SPI controller node in the XTFPGA DTS to spi@...
This fixes the following build warnings:
arch/xtensa/boot/dts/kc705_nommu.dtb: Warning (spi_bus_bridge):
/soc/spi-master@0d0a0000: node name for SPI buses should be 'spi'
arch/xtensa/boot/dts/kc705_nommu.dtb: Warning (spi_bus_reg):
Failed prerequisite 'spi_bus_bridge'
arch/xtensa/boot/dts/lx200mx.dtb: Warning (spi_bus_bridge):
arch/xtensa/boot/dts/lx200mx.dtb: Warning (spi_bus_reg):
arch/xtensa/boot/dts/kc705.dtb: Warning (spi_bus_bridge):
arch/xtensa/boot/dts/kc705.dtb: Warning (spi_bus_reg):
arch/xtensa/boot/dts/ml605.dtb: Warning (spi_bus_bridge):
arch/xtensa/boot/dts/ml605.dtb: Warning (spi_bus_reg):
arch/xtensa/boot/dts/lx60.dtb: Warning (spi_bus_bridge):
arch/xtensa/boot/dts/lx60.dtb: Warning (spi_bus_reg):
commit ada770b1e74a77fff2d5f539bf6c42c25f4784db upstream.
return_address returns the address that is one level higher in the call
stack than requested in its argument, because level 0 corresponds to its
caller's return address. Use requested level as the number of stack
frames to skip.
This fixes the address reported by might_sleep and friends.
[ Upstream commit 25384ce5f9530def39421597b1457d9462df6455 ]
This fixes the following warning at boot when the kernel is booted on a
board with more CPU cores than was configured in NR_CPUS:
smp_init_cpus: Core Count = 8
smp_init_cpus: Core Id = 0
WARNING: CPU: 0 PID: 0 at include/linux/cpumask.h:121 smp_init_cpus+0x54/0x74
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 5.0.0-rc3-00015-g1459333f88a0 #124
Call Trace:
__warn$part$3+0x6a/0x7c
warn_slowpath_null+0x35/0x3c
setup_arch+0x1c0/0x1d0
start_kernel+0x44/0x310
_startup+0x107/0x107
[ Upstream commit 8b1c42cdd7181200dc1fff39dcb6ac1a3fac2c25 ]
Otherwise it is impossible to enable CPUs after booting with 'maxcpus'
parameter.
[ Upstream commit 306b38305c0f86de7f17c5b091a95451dcc93d7d ]
Secondary CPU reset vector overlaps part of the double exception handler
code, resulting in weird crashes and hangups when running user code.
Move exception vectors one page up so that they don't clash with the
secondary CPU reset vector.
[ Upstream commit 32a7726c4f4aadfabdb82440d84f88a5a2c8fe13 ]
- add missing memory barriers to the secondary CPU synchronization spin
loops; add comment to the matching memory barrier in the boot_secondary
and __cpu_die functions;
- use READ_ONCE/WRITE_ONCE to access cpu_start_id/cpu_start_ccount
instead of reading/writing them directly;
- re-initialize cpu_running every time before starting secondary CPU to
flush possible previous CPU startup results.
[ Upstream commit 4fe8713b873fc881284722ce4ac47995de7cf62c ]
ccount_timer_shutdown is called from the atomic context in the
secondary_start_kernel, resulting in the following BUG:
BUG: sleeping function called from invalid context
in_atomic(): 1, irqs_disabled(): 1, pid: 0, name: swapper/1
Preemption disabled at:
secondary_start_kernel+0xa1/0x130
Call Trace:
___might_sleep+0xe7/0xfc
__might_sleep+0x41/0x44
synchronize_irq+0x24/0x64
disable_irq+0x11/0x14
ccount_timer_shutdown+0x12/0x20
clockevents_switch_state+0x82/0xb4
clockevents_exchange_device+0x54/0x60
tick_check_new_device+0x46/0x70
clockevents_register_device+0x8c/0xc8
clockevents_config_and_register+0x1d/0x2c
local_timer_setup+0x75/0x7c
secondary_start_kernel+0xb4/0x130
should_never_return+0x32/0x35
Use disable_irq_nosync instead of disable_irq to avoid it.
This is safe because the ccount timer IRQ is per-CPU, and once IRQ is
masked the ISR will not be called.
commit d90b88fd3653f1fb66ecc6571b860d5a5749fa56 upstream.
Stack unwinding is implemented incorrectly in xtensa get_wchan: instead
of extracting a0 and a1 registers from the spill location under the
stack pointer it extracts a word pointed to by the stack pointer and
subtracts 4 or 3 from it.
commit 38a35a78c5e270cbe53c4fef6b0d3c2da90dd849 upstream.
Layout of coprocessor registers in the elf_xtregs_t and
xtregs_coprocessor_t may be different due to alignment. Thus it is not
always possible to copy data between the xtregs_coprocessor_t structure
and the elf_xtregs_t and get correct values for all registers.
Use a table of offsets and sizes of individual coprocessor register
groups to do coprocessor context copying in the ptrace_getxregs and
ptrace_setxregs.
This fixes incorrect coprocessor register values reading from the user
process by the native gdb on an xtensa core with multiple coprocessors
and registers with high alignment requirements.
commit 03bc996af0cc71c7f30c384d8ce7260172423b34 upstream.
Coprocessor context offsets are used by the assembly code that moves
coprocessor context between the individual fields of the
thread_info::xtregs_cp structure and coprocessor registers.
This fixes coprocessor context clobbering on flushing and reloading
during normal user code execution and user process debugging in the
presence of more than one coprocessor in the core configuration.
commit 2958b66694e018c552be0b60521fec27e8d12988 upstream.
coprocessor_flush_all may be called from a context of a thread that is
different from the thread being flushed. In that case contents of the
cpenable special register may not match ti->cpenable of the target
thread, resulting in unhandled coprocessor exception in the kernel
context.
Set cpenable special register to the ti->cpenable of the target register
for the duration of the flush and restore it afterwards.
This fixes the following crash caused by coprocessor register inspection
in native gdb:
(gdb) p/x $w0
Illegal instruction in kernel: sig: 9 [#1] PREEMPT
Call Trace:
___might_sleep+0x184/0x1a4
__might_sleep+0x41/0xac
exit_signals+0x14/0x218
do_exit+0xc9/0x8b8
die+0x99/0xa0
do_illegal_instruction+0x18/0x6c
common_exception+0x77/0x77
coprocessor_flush+0x16/0x3c
arch_ptrace+0x46c/0x674
sys_ptrace+0x2ce/0x3b4
system_call+0x54/0x80
note: gdb[100] exited with preempt_count 1
Killed
commit 40dc948f234b73497c3278875eb08a01d5854d3f upstream.
The bootloader may pass physical address of the boot parameters structure
to the MMUv3 kernel in the register a2. Code in the _SetupMMU block in
the arch/xtensa/kernel/head.S is supposed to map that physical address to
the virtual address in the configured virtual memory layout.
This code haven't been updated when additional 256+256 and 512+512
memory layouts were introduced and it may produce wrong addresses when
used with these layouts.
commit 0773495b1f5f1c5e23551843f87b5ff37e7af8f7 upstream.
Xtensa ABI requires stack alignment to be at least 16. In noMMU
configuration ARCH_SLAB_MINALIGN is used to align stack. Make it at
least 16.
This fixes the following runtime error in noMMU configuration, caused by
interaction between insufficiently aligned stack and alloca function,
that results in corruption of on-stack variable in the libc function
glob:
Caught unhandled exception in 'sh' (pid = 47, pc = 0x02d05d65)
- should not happen
EXCCAUSE is 15
commit 4119ba211bc4f1bf638f41e50b7a0f329f58aa16 upstream.
This section collects all source .note.* sections together in the
vmlinux image. Without it .note.Linux section may be placed at address
0, while the rest of the kernel is at its normal address, resulting in a
huge vmlinux.bin image that may not be linked into the xtensa Image.elf.
commit ef439d49e0bfb26cd5f03c88b4cb7cc9073ed30c upstream.
Memory allocator is not initialized at that point yet, use static array
instead.
commit fec3259c9f747c039f90e99570540114c8d81a14 upstream.
Cache invalidation macros use cache line size to iterate over
invalidated cache lines, assuming that all cache ways are invalidated by
single instruction, but xtensa ISA recommends to not assume that for
future compatibility:
In some implementations all ways at index Addry-1..z are invalidated
regardless of the specified way, but for future compatibility this
behavior should not be assumed.
Iterate over all cache ways in ___invalidate_icache_all and
___invalidate_dcache_all.
commit be75de25251f7cf3e399ca1f584716a95510d24a upstream.
When building kernel for xtensa cores with big cache lines (e.g. 128
bytes or more) __loop_cache_all and __loop_cache_page may generate
assembly instructions with immediate fields that are too big. This
results in the following build errors:
arch/xtensa/mm/misc.S: Assembler messages:
arch/xtensa/mm/misc.S:464: Error: operand 2 of 'diwbi' has invalid value '256'
arch/xtensa/mm/misc.S:464: Error: operand 2 of 'diwbi' has invalid value '384'
arch/xtensa/kernel/head.S: Assembler messages:
arch/xtensa/kernel/head.S:172: Error: operand 2 of 'diu' has invalid value '256'
arch/xtensa/kernel/head.S:172: Error: operand 2 of 'diu' has invalid value '384'
arch/xtensa/kernel/head.S:176: Error: operand 2 of 'iiu' has invalid value '256'
arch/xtensa/kernel/head.S:176: Error: operand 2 of 'iiu' has invalid value '384'
arch/xtensa/kernel/head.S:255: Error: operand 2 of 'diwb' has invalid value '256'
arch/xtensa/kernel/head.S:255: Error: operand 2 of 'diwb' has invalid value '384'
Add parameter max_immed to these macros and use it to limit values of
immediate operands. Extract common code of these macros into the new
macro __loop_cache_unroll.
commit 7de712ccc096b81d23cc0a941cd9b8cb3956605d upstream.
While working on changing this code to use force_sig_fault I
discovered that do_unaliged_user is sets si_signo to SIGBUS and passes
SIGSEGV to force_sig_info. Which is just b0rked.
The code is reporting a SIGBUS error so replace the SIGSEGV with SIGBUS.
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: linux-xtensa@linux-xtensa.org
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Fixes: 5a0015d62668 ("[PATCH] xtensa: Architecture support for Tensilica Xtensa Part 3")
commit 6ac5a11dc674bc5016ea716e8082fff61f524dc1 upstream.
Xtensa memory initialization code frees high memory pages without
checking whether they are in the reserved memory regions or not. That
results in invalid value of totalram_pages and duplicate page usage by
CMA and highmem. It produces a bunch of BUGs at startup looking like
this:
BUG: Bad page state in process swapper pfn:70800
page:be60c000 count:0 mapcount:-127 mapping: (null) index:0x1
flags: 0x80000000()
raw: 80000000 00000000 00000001 ffffff80 00000000 be60c014 be60c014 0000000a
page dumped because: nonzero mapcount
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Tainted: G B 4.16.0-rc1-00015-g7928b2cbe55b-dirty #23
Stack:
bd839d33 00000000 00000018 ba97b64c a106578c bd839d70 be60c000 00000000
a1378054 bd86a000 00000003 ba97b64c a1066166 bd839da0 be60c000 ffe00000
a1066b58 bd839dc0 be504000 00000000 000002f4 bd838000 00000000 0000001e
Call Trace:
[<a1065734>] bad_page+0xac/0xd0
[<a106578c>] free_pages_check_bad+0x34/0x4c
[<a1066166>] __free_pages_ok+0xae/0x14c
[<a1066b58>] __free_pages+0x30/0x64
[<a1365de5>] init_cma_reserved_pageblock+0x35/0x44
[<a13682dc>] cma_init_reserved_areas+0xf4/0x148
[<a10034b8>] do_one_initcall+0x80/0xf8
[<a1361c16>] kernel_init_freeable+0xda/0x13c
[<a125b59d>] kernel_init+0x9/0xd0
[<a1004304>] ret_from_kernel_thread+0xc/0x18
Only free high memory pages that are not reserved.
commit ca47480921587ae30417dd234a9f79af188e3666 upstream.
Return 0 if the operation was successful, not the userspace memory
value. Check that userspace value equals passed oldval, not itself.
Don't update *uval if the value wasn't read from userspace memory.
This fixes process hang due to infinite loop in futex_lock_pi.
It also fixes a bunch of glibc tests nptl/tst-mutexpi*.
commit 10b62a2f785ab55857380f0c63d9fa468fd8c676 upstream.
Most of DT files are compiled under arch/*/boot/dts/, but we have some
other directories, like drivers/of/unittest-data/. We often miss to
add gitignore patterns per directory. Since there are no source files
that end with .dtb or .dtb.S, we can ignore the patterns globally.
Signed-off-by: Rob Herring <robh@kernel.org>
Many user space API headers have licensing information, which is either
incomplete, badly formatted or just a shorthand for referring to the
license under which the file is supposed to be. This makes it hard for
compliance tools to determine the correct license.
Update these files with an SPDX license identifier. The identifier was
chosen based on the license information in the file.
GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license
identifier with the added 'WITH Linux-syscall-note' exception, which is
the officially assigned exception identifier for the kernel syscall
exception:
NOTE! This copyright does *not* cover user programs that use kernel
services by normal system calls - this is merely considered normal use
of the kernel, and does *not* fall under the heading of "derived work".
This exception makes it possible to include GPL headers into non GPL
code, without confusing license compliance tools.
Headers which have either explicit dual licensing or are just licensed
under a non GPL license are updated with the corresponding SPDX
identifier and the GPLv2 with syscall exception identifier. The format
is:
((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE)
SPDX license identifiers are a legally binding shorthand, which can be
used instead of the full boiler plate text. The update does not remove
existing license information as this has to be done on a case by case
basis and the copyright holders might have to be consulted. This will
happen in a separate step.
Philippe Ombredanne. See the previous patch in this series for the
methodology of how this patch was researched.
license
Many user space API headers are missing licensing information, which
makes it hard for compliance tools to determine the correct license.
By default are files without license information under the default
license of the kernel, which is GPLV2. Marking them GPLV2 would exclude
them from being included in non GPLV2 code, which is obviously not
intended. The user space API headers fall under the syscall exception
which is in the kernels COPYING file:
otherwise syscall usage would not be possible.
Update the files which contain no license information with an SPDX
license identifier. The chosen identifier is 'GPL-2.0 WITH
Linux-syscall-note' which is the officially assigned identifier for the
Linux syscall exception. SPDX license identifiers are a legally binding
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Some architectures define the no-op macros/functions copy_segments,
release_segments and forget_segments. These are used nowhere in the
tree, so removed them.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Vineet Gupta <vgupta@synopsys.com> [for arch/arc]
Merge updates from Andrew Morton:
- various misc bits
- DAX updates
- OCFS2
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (119 commits)
mm,fork: introduce MADV_WIPEONFORK
x86,mpx: make mpx depend on x86-64 to free up VMA flag
mm: add /proc/pid/smaps_rollup
mm: hugetlb: clear target sub-page last when clearing huge page
mm: oom: let oom_reap_task and exit_mmap run concurrently
swap: choose swap device according to numa node
mm: replace TIF_MEMDIE checks by tsk_is_oom_victim
mm, oom: do not rely on TIF_MEMDIE for memory reserves access
z3fold: use per-cpu unbuddied lists
mm, swap: don't use VMA based swap readahead if HDD is used as swap
mm, swap: add sysfs interface for VMA based swap readahead
mm, swap: VMA based swap readahead
mm, swap: fix swap readahead marking
mm, swap: add swap readahead hit statistics
mm/vmalloc.c: don't reinvent the wheel but use existing llist API
mm/vmstat.c: fix wrong comment
selftests/memfd: add memfd_create hugetlbfs selftest
mm/shmem: add hugetlbfs support to memfd_create()
mm, devm_memremap_pages: use multi-order radix for ZONE_DEVICE lookups
mm/vmalloc.c: halve the number of comparisons performed in pcpu_get_vm_areas()
Introduce MADV_WIPEONFORK semantics, which result in a VMA being empty
in the child process after fork. This differs from MADV_DONTFORK in one
important way.
If a child process accesses memory that was MADV_WIPEONFORK, it will get
zeroes. The address ranges are still valid, they are just empty.
If a child process accesses memory that was MADV_DONTFORK, it will get a
segmentation fault, since those address ranges are no longer valid in
the child after fork.
Since MADV_DONTFORK also seems to be used to allow very large programs
to fork in systems with strict memory overcommit restrictions, changing
the semantics of MADV_DONTFORK might break existing programs.
MADV_WIPEONFORK only works on private, anonymous VMAs.
The use case is libraries that store or cache information, and want to
know that they need to regenerate it in the child process after fork.
Examples of this would be:
- systemd/pulseaudio API checks (fail after fork) (replacing a getpid
check, which is too slow without a PID cache)
- PKCS#11 API reinitialization check (mandated by specification)
- glibc's upcoming PRNG (reseed after fork)
- OpenSSL PRNG (reseed after fork)
The security benefits of a forking server having a re-inialized PRNG in
every child process are pretty obvious. However, due to libraries
having all kinds of internal state, and programs getting compiled with
many different versions of each library, it is unreasonable to expect
calling programs to re-initialize everything manually after fork.
A further complication is the proliferation of clone flags, programs
bypassing glibc's functions to call clone directly, and programs calling
unshare, causing the glibc pthread_atfork hook to not get called.
It would be better to have the kernel take care of this automatically.
The patch also adds MADV_KEEPONFORK, to undo the effects of a prior
MADV_WIPEONFORK.
This is similar to the OpenBSD minherit syscall with MAP_INHERIT_ZERO:
https://man.openbsd.org/minherit.2
[akpm@linux-foundation.org: numerically order arch/parisc/include/uapi/asm/mman.h #defines]
Link: http://lkml.kernel.org/r/20170811212829.29186-3-riel@redhat.com
Signed-off-by: Rik van Riel <riel@redhat.com>
Reported-by: Florian Weimer <fweimer@redhat.com>
Reported-by: Colm MacCártaigh <colm@allcosts.net>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Helge Deller <deller@gmx.de>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Will Drewry <wad@chromium.org>
Cc: <linux-api@vger.kernel.org>
A non-default huge page size can be encoded in the flags argument of the
mmap system call. The definitions for these encodings are in arch
specific header files. However, all architectures use the same values.
Consolidate all the definitions in the primary user header file
(uapi/linux/mman.h). Include definitions for all known huge page sizes.
Use the generic encoding definitions in hugetlb_encode.h as the basis
for these definitions.
Link: http://lkml.kernel.org/r/1501527386-10736-3-git-send-email-mike.kravetz@oracle.com
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Pull networking updates from David Miller:
1) Support ipv6 checksum offload in sunvnet driver, from Shannon
Nelson.
2) Move to RB-tree instead of custom AVL code in inetpeer, from Eric
Dumazet.
3) Allow generic XDP to work on virtual devices, from John Fastabend.
4) Add bpf device maps and XDP_REDIRECT, which can be used to build
arbitrary switching frameworks using XDP. From John Fastabend.
5) Remove UFO offloads from the tree, gave us little other than bugs.
6) Remove the IPSEC flow cache, from Florian Westphal.
7) Support ipv6 route offload in mlxsw driver.
8) Support VF representors in bnxt_en, from Sathya Perla.
9) Add support for forward error correction modes to ethtool, from
Vidya Sagar Ravipati.
10) Add time filter for packet scheduler action dumping, from Jamal Hadi
Salim.
11) Extend the zerocopy sendmsg() used by virtio and tap to regular
sockets via MSG_ZEROCOPY. From Willem de Bruijn.
12) Significantly rework value tracking in the BPF verifier, from Edward
Cree.
13) Add new jump instructions to eBPF, from Daniel Borkmann.
14) Rework rtnetlink plumbing so that operations can be run without
taking the RTNL semaphore. From Florian Westphal.
15) Support XDP in tap driver, from Jason Wang.
16) Add 32-bit eBPF JIT for ARM, from Shubham Bansal.
17) Add Huawei hinic ethernet driver.
18) Allow to report MD5 keys in TCP inet_diag dumps, from Ivan
Delalande.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1780 commits)
i40e: point wb_desc at the nvm_wb_desc during i40e_read_nvm_aq
i40e: avoid NVM acquire deadlock during NVM update
drivers: net: xgene: Remove return statement from void function
drivers: net: xgene: Configure tx/rx delay for ACPI
drivers: net: xgene: Read tx/rx delay for ACPI
rocker: fix kcalloc parameter order
rds: Fix non-atomic operation on shared flag variable
net: sched: don't use GFP_KERNEL under spin lock
vhost_net: correctly check tx avail during rx busy polling
net: mdio-mux: add mdio_mux parameter to mdio_mux_init()
rxrpc: Make service connection lookup always check for retry
net: stmmac: Delete dead code for MDIO registration
gianfar: Fix Tx flow control deactivation
cxgb4: Ignore MPS_TX_INT_CAUSE[Bubble] for T6
cxgb4: Fix pause frame count in t4_get_port_stats
cxgb4: fix memory leak
tun: rename generic_xdp to skb_xdp
tun: reserve extra headroom only when XDP is set
net: dsa: bcm_sf2: Configure IMP port TC2QOS mapping
net: dsa: bcm_sf2: Advertise number of egress queues
Pull locking updates from Ingo Molnar:
- Add 'cross-release' support to lockdep, which allows APIs like
completions, where it's not the 'owner' who releases the lock, to be
tracked. It's all activated automatically under
CONFIG_PROVE_LOCKING=y.
- Clean up (restructure) the x86 atomics op implementation to be more
readable, in preparation of KASAN annotations. (Dmitry Vyukov)
- Fix static keys (Paolo Bonzini)
- Add killable versions of down_read() et al (Kirill Tkhai)
- Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini)
- Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra)
- Remove smp_mb__before_spinlock() and convert its usages, introduce
smp_mb__after_spinlock() (Peter Zijlstra)
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits)
locking/lockdep/selftests: Fix mixed read-write ABBA tests
sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK()
acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse
locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures
smp: Avoid using two cache lines for struct call_single_data
locking/lockdep: Untangle xhlock history save/restore from task independence
locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being
futex: Remove duplicated code and fix undefined behaviour
Documentation/locking/atomic: Finish the document...
locking/lockdep: Fix workqueue crossrelease annotation
workqueue/lockdep: 'Fix' flush_work() annotation
locking/lockdep/selftests: Add mixed read-write ABBA tests
mm, locking/barriers: Clarify tlb_flush_pending() barriers
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive
locking/lockdep: Explicitly initialize wq_barrier::done::map
locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS
locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING
locking/refcounts, x86/asm: Implement fast refcount overflow protection
locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease
Pull perf updates from Ingo Molnar:
"Kernel side changes:
- Add branch type profiling/tracing support. (Jin Yao)
- Add the PERF_SAMPLE_PHYS_ADDR ABI to allow the tracing/profiling of
physical memory addresses, where the PMU supports it. (Kan Liang)
- Export some PMU capability details in the new
/sys/bus/event_source/devices/cpu/caps/ sysfs directory. (Andi
Kleen)
- Aux data fixes and updates (Will Deacon)
- kprobes fixes and updates (Masami Hiramatsu)
- AMD uncore PMU driver fixes and updates (Janakarajan Natarajan)
On the tooling side, here's a (limited!) list of highlights - there
were many other changes that I could not list, see the shortlog and
git history for details:
UI improvements:
- Implement a visual marker for fused x86 instructions in the
annotate TUI browser, available now in 'perf report', more work
needed to have it available as well in 'perf top' (Jin Yao)
Further explanation from one of Jin's patches:
│ ┌──cmpl $0x0,argp_program_version_hook
81.93 │ ├──je 20
│ │ lock cmpxchg %esi,0x38a9a4(%rip)
│ │↓ jne 29
│ │↓ jmp 43
11.47 │20:└─→cmpxch %esi,0x38a999(%rip)
That means the cmpl+je is a fused instruction pair and they should
be considered together.
- Record the branch type and then show statistics and info about in
callchain entries (Jin Yao)
Example from one of Jin's patches:
# perf record -g -j any,save_type
# perf report --branch-history --stdio --no-children
38.50% div.c:45 [.] main div
---main div.c:42 (RET CROSS_2M cycles:2)
compute_flag div.c:28 (cycles:2)
compute_flag div.c:27 (RET CROSS_2M cycles:1)
rand rand.c:28 (cycles:1)
rand rand.c:28 (RET CROSS_2M cycles:1)
__random random.c:298 (cycles:1)
__random random.c:297 (COND_BWD CROSS_2M cycles:1)
__random random.c:295 (cycles:1)
__random random.c:295 (COND_BWD CROSS_2M cycles:1)
__random random.c:295 (RET CROSS_2M cycles:9)
namespaces support:
- Add initial support for namespaces, using setns to access files in
namespaces, grabbing their build-ids, etc. (Krister Johansen)
perf trace enhancements:
- Beautify pkey_{alloc,free,mprotect} arguments in 'perf trace'
(Arnaldo Carvalho de Melo)
- Add initial 'clone' syscall args beautifier in 'perf trace'
- Ignore 'fd' and 'offset' args for MAP_ANONYMOUS in 'perf trace'
- Beautifiers for the 'cmd' arg of several ioctl types, including:
sound, DRM, KVM, vhost virtio and perf_events. (Arnaldo Carvalho de
Melo)
- Add PERF_SAMPLE_CALLCHAIN and PERF_RECORD_MMAP[2] to 'perf data'
CTF conversion, allowing CTF trace visualization tools to show
callchains and to resolve symbols (Geneviève Bastien)
- Beautify the fcntl syscall, which is an interesting one in the
sense that infrastructure had to be put in place to change the
formatters of some arguments according to the value in a previous
one, i.e. cmd dictates how arg and the syscall return will be
formatted. (Arnaldo Carvalho de Melo
perf stat enhancements:
- Use group read for event groups in 'perf stat', reducing overhead
when groups are defined in the event specification, i.e. when using
{} to enclose a list of events, asking them to be read at the same
time, e.g.: "perf stat -e '{cycles,instructions}'" (Jiri Olsa)
pipe mode improvements:
- Process tracing data in 'perf annotate' pipe mode (David
Carrillo-Cisneros)
- Add header record types to pipe-mode, now this command:
$ perf record -o - -e cycles sleep 1 | perf report --stdio --header
Will show the same as in non-pipe mode, i.e. involving a perf.data
file (David Carrillo-Cisneros)
Vendor specific hardware event support updates/enhancements:
- Update POWER9 vendor events tables (Sukadev Bhattiprolu)
- Add POWER9 PMU events Sukadev (Bhattiprolu)
- Support additional POWER8+ PVR in PMU mapfile (Shriya)
- Add Skylake server uncore JSON vendor events (Andi Kleen)
- Support exporting Intel PT data to sqlite3 with python perf
scripts, this is in addition to the postgresql support that was
already there (Adrian Hunter)"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (253 commits)
perf symbols: Fix plt entry calculation for ARM and AARCH64
perf probe: Fix kprobe blacklist checking condition
perf/x86: Fix caps/ for !Intel
perf/core, x86: Add PERF_SAMPLE_PHYS_ADDR
perf/core, pt, bts: Get rid of itrace_started
perf trace beauty: Beautify pkey_{alloc,free,mprotect} arguments
tools headers: Sync cpu features kernel ABI headers with tooling headers
perf tools: Pass full path of FEATURES_DUMP
perf tools: Robustify detection of clang binary
tools lib: Allow external definition of CC, AR and LD
perf tools: Allow external definition of flex and bison binary names
tools build tests: Don't hardcode gcc name
perf report: Group stat values on global event id
perf values: Zero value buffers
perf values: Fix allocation check
perf values: Fix thread index bug
perf report: Add dump_read function
perf record: Set read_format for inherit_stat
perf c2c: Fix remote HITM detection for Skylake
perf tools: Fix static build with newer toolchains
There is code duplicated over all architecture's headers for
futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr,
and comparison of the result.
Remove this duplication and leave up to the arches only the needed
assembly which is now in arch_futex_atomic_op_inuser.
This effectively distributes the Will Deacon's arm64 fix for undefined
behaviour reported by UBSAN to all architectures. The fix was done in
commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with
FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump.
And as suggested by Thomas, check for negative oparg too, because it was
also reported to cause undefined behaviour report.
Note that s390 removed access_ok check in d12a29703 ("s390/uaccess:
remove pointless access_ok() checks") as access_ok there returns true.
We introduce it back to the helper for the sake of simplicity (it gets
optimized away anyway).
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64]
Cc: linux-mips@linux-mips.org
Cc: Rich Felker <dalias@libc.org>
Cc: linux-ia64@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: peterz@infradead.org
Cc: sparclinux@vger.kernel.org
Cc: Jonas Bonn <jonas@southpole.se>
Cc: linux-s390@vger.kernel.org
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-hexagon@vger.kernel.org
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: openrisc@lists.librecores.org
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: linux-parisc@vger.kernel.org
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-alpha@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- Removal of spin_unlock_wait()
- SRCU updates
- Torture-test updates
- Documentation updates
- Miscellaneous fixes
- CPU-hotplug fixes
- Miscellaneous non-RCU fixes
There is no agreed-upon definition of spin_unlock_wait()'s semantics,
and it appears that all callers could do just as well with a lock/unlock
pair. This commit therefore removes the underlying arch-specific
arch_spin_unlock_wait() for all architectures providing them.
Cc: <linux-arch@vger.kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Andrea Parri <parri.andrea@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Boqun Feng <boqun.feng@gmail.com>
Mark _stext and _end as character arrays instead of single
character variables, like include/asm-generic/sections.h does.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Francis Deslauriers <francis.deslauriers@efficios.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: linux-cris-kernel@axis.com
Cc: mathieu.desnoyers@efficios.com
Link: http://lkml.kernel.org/r/150172775958.27216.12951305461398200544.stgit@devbox
The UDP offload conflict is dealt with by simply taking what is
in net-next where we have removed all of the UFO handling code
entirely.
The TCP conflict was a case of local variables in a function
being removed from both net and net-next.
In netvsc we had an assignment right next to where a missing
set of u64 stats sync object inits were added.
Pull Xtensa fixes from Max Filippov:
- use asm-generic instances of asm/param.h and asm/device.h instead of
exact copies in arch/xtensa/include/asm;
- fix build error for xtensa cores with aliasing WT cache: define cache
flushing functions and copy_{to,from}_user_page;
- add missing EXPORT_SYMBOLs for clear_user_highpage, copy_user_highpage,
flush_dcache_page, local_flush_cache_range, local_flush_cache_page,
csum_partial and csum_partial_copy_generic.
* tag 'xtensa-20170807' of git://github.com/jcmvbkbc/linux-xtensa:
xtensa: mm/cache: add missing EXPORT_SYMBOLs
xtensa: don't limit csum_partial export by CONFIG_NET
xtensa: fix cache aliasing handling code for WT cache
xtensa: remove wrapper header for asm/param.h
xtensa: remove wrapper header for asm/device.h
The send call ignores unknown flags. Legacy applications may already
unwittingly pass MSG_ZEROCOPY. Continue to ignore this flag unless a
socket opts in to zerocopy.
Introduce socket option SO_ZEROCOPY to enable MSG_ZEROCOPY processing.
Processes can also query this socket option to detect kernel support
for the feature. Older kernels will return ENOPROTOOPT.
Signed-off-by: Willem de Bruijn <willemb@google.com>
Functions clear_user_highpage, copy_user_highpage, flush_dcache_page,
local_flush_cache_range and local_flush_cache_page may be used from
modules. Export them.
csum_partial and csum_partial_copy_generic are defined unconditionally
and are available even when CONFIG_NET is disabled. They are used not
only by the network drivers, but also by scsi and media.
Don't limit these functions export by CONFIG_NET.
Currently building kernel for xtensa core with aliasing WT cache fails
with the following messages:
mm/memory.c:2152: undefined reference to `flush_dcache_page'
mm/memory.c:2332: undefined reference to `local_flush_cache_page'
mm/memory.c:1919: undefined reference to `local_flush_cache_range'
mm/memory.c:4179: undefined reference to `copy_to_user_page'
mm/memory.c:4183: undefined reference to `copy_from_user_page'
This happens because implementation of these functions is only compiled
when data cache is WB, which looks wrong: even when data cache doesn't
need flushing it still needs invalidation. The functions like
__flush_[invalidate_]dcache_* are correctly defined for both WB and WT
caches (and even if they weren't that'd still be ok, just slower).
Fix this by providing the same implementation of the above functions for
both WB and WT cache.
xtensa's asm/device.h is a verbatim copy of asm-generic/device.h and
does not add any arch specific extensions. Thus, use the asm-generic
header directly.
header directly.
This ioctl does nothing to justify an _IOC_READ or _IOC_WRITE flag
because it doesn't copy anything from/to userspace to access the
argument.
Fixes: 54ebbfb16034 ("tty: add TIOCGPTPEER ioctl")
Signed-off-by: Gleb Fotengauer-Malinovskiy <glebfm@altlinux.org>
Acked-by: Aleksa Sarai <asarai@suse.de>
Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
The arch uses a verbatim copy of the asm-generic version and does not
add any own implementations to the header, so use asm-generic/fb.h
instead of duplicating code.
Link: http://lkml.kernel.org/r/20170517083545.2115-1-tklauser@distanz.ch
