path: root/arch/xtensa
2008-08-05remove unneeded #include <linux/ide.h>'sAdrian Bunk
This patch remove unneeded #include <linux/ide.h>'s. It also adds a required #include <linux/interrupt.h> that was previously implicitely pulled by ide.h Signed-off-by: Adrian Bunk <bunk@kernel.org> [bart: revert change to tests/lkdtm.c (spotted by Stephen Rothwell)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-26xtensa: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() - pages in swapcache, printed by show_swap_cache_info() where show_mem() calls show_free_areas(), which calls show_swap_cache_info(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: pipeUlrich Drepper
This patch introduces the new syscall pipe2 which is like pipe but it also takes an additional parameter which takes a flag value. This patch implements the handling of O_CLOEXEC for the flag. I did not add support for the new syscall for the architectures which have a special sys_pipe implementation. I think the maintainers of those archs have the chance to go with the unified implementation but that's up to them. The implementation introduces do_pipe_flags. I did that instead of changing all callers of do_pipe because some of the callers are written in assembler. I would probably screw up changing the assembly code. To avoid breaking code do_pipe is now a small wrapper around do_pipe_flags. Once all callers are changed over to do_pipe_flags the old do_pipe function can be removed. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_pipe2 # ifdef __x86_64__ # define __NR_pipe2 293 # elif defined __i386__ # define __NR_pipe2 331 # else # error "need __NR_pipe2" # endif #endif int main (void) { int fd[2]; if (syscall (__NR_pipe2, fd, 0) != 0) { puts ("pipe2(0) failed"); return 1; } for (int i = 0; i < 2; ++i) { int coe = fcntl (fd[i], F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { printf ("pipe2(0) set close-on-exit for fd[%d]\n", i); return 1; } } close (fd[0]); close (fd[1]); if (syscall (__NR_pipe2, fd, O_CLOEXEC) != 0) { puts ("pipe2(O_CLOEXEC) failed"); return 1; } for (int i = 0; i < 2; ++i) { int coe = fcntl (fd[i], F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { printf ("pipe2(O_CLOEXEC) does not set close-on-exit for fd[%d]\n", i); return 1; } } close (fd[0]); close (fd[1]); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22remove mention of CONFIG_KMOD from documentationJohannes Berg
Also includes a few Kconfig files (xtensa, blackfin) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: linux-doc@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-04-29xtensa: use kbuild.h macros instead of defining them in asm-offsets.cChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-13[XTENSA] Allow debugger to modify the WINDOWBASE register.Chris Zankel
For the 'return' command, GDB needs to adjust WINDOWBASE. In case WB is different from 0, we need to rotate the window register file and update WINDOWSTART and WMASK. This patch also removes some ret|= statements for __get_user/__put_user as the address range was alrady checked a couple of lines earlier. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix makefile to work with binutils-2.18.Bob Wilson
When building with binutils-2.18, vmlinux includes .note.gnu.build-id sections that need to be stripped out when building the binary image. The old .xt.insn sections haven't been used for a long time, so don't bother stripping them. Signed-off-by: Bob Wilson <bob.wilson@acm.org> Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix register corruption for certain processor configurationsChris Zankel
For processor configurations that have optional registers (compiler-used but non-coprocessor), user space registers might get corrupted when there are only 4 registers in the current window-frame, ie. register a4 belongs to the oldest frame in the register file. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Add support for the sa_restorer functionChris Zankel
Supporting the sa_restorer function allows for better security since the sigreturn system call doesn't need to be placed on the stack, so the stack doesn't need to be executable. This requires support from the c-library as it has to provide the restorer function. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Add support for configurable registers and coprocessorsChris Zankel
The Xtensa architecture allows to define custom instructions and registers. Registers that are bound to a coprocessor are only accessible if the corresponding enable bit is set, which allows to implement a 'lazy' context switch mechanism. Other registers needs to be saved and restore at the time of the context switch or during interrupt handling. This patch adds support for these additional states: - save and restore registers that are used by the compiler upon interrupt entry and exit. - context switch additional registers unbound to any coprocessor - 'lazy' context switch of registers bound to a coprocessor - ptrace interface to provide access to additional registers - update configuration files in include/asm-xtensa/variant-fsf Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Use preprocessor to generate the linker script for the ELF boot imageChris Zankel
Signed-off-by: Marc Gauthier <marc@tensilica.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Add missing RELOCATE_ENTRY for debug vectorMarc Gauthier
We also need to relocate the debug vector if in RAM. Signed-off-by: Marc Gauthier <marc@tensilica.com>
2008-02-13[XTENSA] Remove unused codeChris Zankel
We will never (need to) support signal handling coming from a double exception. There are too many things that could go wrong and delivering signals is not the fastest method for IPC, anyway. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix modules for non-exec processor configurationsChris Zankel
We need to use vmalloc_exec for module loading. Also remove the definitions MODULE_START and MODULE_END, which wasn't used, and increase the VMALLOC memory range accordingly. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix comments regarding the number of frames to saveChris Zankel
2008-02-13[XTENSA] Add missing a2 register restore in register spill routineChris Zankel
Register a2 is saved in depc but wasn't getting restored before returning from _spill_registers when there weren't any registers to spill. The mask to cut the top bit from the rotated WINDOWMASK register was also one bit short. Signed-off-by: CHris Zankel <chris@zankel.net>
2008-02-13[XTENSA] adjust boot linker script start addressesMarc Gauthier
Move boot-redboot load address from 0xD0200000 to 0xD1000000 to make space for larger kernel images, in particular those with an embedded initramfs filesystem. Also properly set the ELF start address in boot-elf images so that PC need not be set manually when loading them using GDB. Signed-off-by: Marc Gauthier <marc@tensilica.com>
2008-02-13[XTENSA] Remove oldmask from sigcontext and fix register flushChris Zankel
Remove oldmask from the sigcontext structure. Also update wmask and windowstart when we flush the AR registers to stack. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Clean up elf-gregset.Chris Zankel
Remove additional registers from the ELF gregset structure that are only used by the kernel or are not required or invalid in user-space. The ar registers are always aligned to a windowbase value of 0, and the WB register is always assumed to be 0. Increase the size of the structure to 128 entries. This will provide enough space in future. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix icache flush for cache aliasingChris Zankel
Set the execution bit in the temporary TLB when we flush the instruction cache. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Prevent inlining ISS platform asm constructsMarc Gauthier
The simcall asm macro assumes Windowed ABI parameter passing in registers, and doesn't work if its containing function gets inlined. This fix prevents that from happening. Signed-off-by: Marc Gauthier <marc@tensilica.com>
2008-02-13[XTENSA] Flush the page-address in update-mmu instead of user-addressChris Zankel
The TLB entry for the user address doesn't exist at the time we want to flush the caches, so use the page address. Note that processor configurations with cache-aliasing issues are treated separately. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix argument list for pgd_ctor constructor.Chris Zankel
The argument list for ctor function element in the kmem_cache structure has changed. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Concentrate platforms into one platforms directory.Chris Zankel
Create arch/xtensa/platforms/ directory to concentrate all platforms under that subdirectory and moves the ISS platform to that directory. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Add .literal sections for various init sectiont to linker scriptChris Zankel
Xtensa requires separate .literal section for each .text section. Adding addition init sections for cpuinit, meminit, and devinit, broke the Xtensa linker script, so, add these literal sections manually for now. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Remove dead code reported by Robert P. J. Day.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Christian Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-02-13[XTENSA] Remove duplicate includes.Chris Zankel
Signed-off-by: Lucas Woods <woodzy@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Christian Zankel <chris@zankel.net>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-08avoid overflows in kernel/time.cH. Peter Anvin
When the conversion factor between jiffies and milli- or microseconds is not a single multiply or divide, as for the case of HZ == 300, we currently do a multiply followed by a divide. The intervening result, however, is subject to overflows, especially since the fraction is not simplified (for HZ == 300, we multiply by 300 and divide by 1000). This is exposed to the user when passing a large timeout to poll(), for example. This patch replaces the multiply-divide with a reciprocal multiplication on 32-bit platforms. When the input is an unsigned long, there is no portable way to do this on 64-bit platforms there is no portable way to do this since it requires a 128-bit intermediate result (which gcc does support on 64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but since the output is a 32-bit integer in the cases affected, just simplify the multiply-divide (*3/10 instead of *300/1000). The reciprocal multiply used can have off-by-one errors in the upper half of the valid output range. This could be avoided at the expense of having to deal with a potential 65-bit intermediate result. Since the intent is to avoid overflow problems and most of the other time conversions are only semiexact, the off-by-one errors were considered an acceptable tradeoff. At Ralf Baechle's suggestion, this version uses a Perl script to compute the necessary constants. We already have dependencies on Perl for kernel compiles. This does, however, require the Perl module Math::BigInt, which is included in the standard Perl distribution starting with version 5.8.0. In order to support older versions of Perl, include a table of canned constants in the script itself, and structure the script so that Math::BigInt isn't required if pulling values from said table. Running the script requires that the HZ value is available from the Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the architectures which didn't already have it (alpha, cris, frv, h8300, m32r, m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or sh64 architectures, since Paul Mundt has dealt with those separately in the sh tree. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>, Cc: Sam Ravnborg <sam@ravnborg.org>, Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Richard Henderson <rth@twiddle.net>, Cc: Michael Starvik <starvik@axis.com>, Cc: David Howells <dhowells@redhat.com>, Cc: Yoshinori Sato <ysato@users.sourceforge.jp>, Cc: Hirokazu Takata <takata@linux-m32r.org>, Cc: Geert Uytterhoeven <geert@linux-m68k.org>, Cc: Roman Zippel <zippel@linux-m68k.org>, Cc: William L. Irwin <sparclinux@vger.kernel.org>, Cc: Chris Zankel <chris@zankel.net>, Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08procfs: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06calibrate_delay() must be __cpuinitAdrian Bunk
calibrate_delay() must be __cpuinit, not __{dev,}init. I've verified that this is correct for all users. While doing the latter, I also did the following cleanups: - remove pointless additional prototypes in C files - ensure all users #include <linux/delay.h> This fixes the following section mismatches with CONFIG_HOTPLUG=n, CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x1128d): Section mismatch: reference to .init.text.1:calibrate_delay (between 'check_cx686_slop' and 'set_cx86_reorder') WARNING: vmlinux.o(.text+0x25102): Section mismatch: reference to .init.text.1:calibrate_delay (between 'smp_callin' and 'cpu_coregroup_map') Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christian Zankel <chris@zankel.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03Move Kconfig.instrumentation to arch/Kconfig and init/KconfigMathieu Desnoyers
Move the instrumentation Kconfig to arch/Kconfig for architecture dependent options - oprofile - kprobes and init/Kconfig for architecture independent options - profiling - markers Remove the "Instrumentation Support" menu. Everything moves to "General setup". Delete the kernel/Kconfig.instrumentation file. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-01PCI: Kconfig help: don't refer to the PCI-HOWTOAdrian Bunk
A HOWTO that hasn't been updated for half a dozen years no longer "contains valuable information about which PCI hardware does work under Linux and which doesn't". Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-28Remove references to "make dep"Adrian Bunk
"make dep" is no longer required in kernel 2.6, but was still mentioned in some places. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-12-11[XTENSA]: Fix use of skb after netif_rxJulia Lawall
Recently, Wang Chen submitted a patch (d30f53aeb31d453a5230f526bea592af07944564) to move a call to netif_rx(skb) after a subsequent reference to skb, because netif_rx may call kfree_skb on its argument. The same problem occurs in some other drivers as well. This was found using the following semantic match. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression skb, e,e1; @@ ( netif_rx(skb); | netif_rx_ni(skb); ) ... when != skb = e ( skb = e1 | * skb ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-30Kbuild/doc: fix links to Documentation filesDirk Hohndel
Fix links to files in Documentation/* in various Kconfig files Signed-off-by: Dirk Hohndel <hohndel@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20kbuild: restore arch/{ppc/xtensa}/boot cflagsMilton Miller
Commit 9a39e273d4df0560c724c5fe71f6314a0583ca2b removed the boot directory addition to CFLAGS that was being used by the subdirectory builds. For the other files, that patch set EXTRA_CFLAGS, but Makefile.build explicitly sets that to empty as it is explicitly for a single directory only. Append to KBUILD_CFLAGS instead. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-20XTENSA: Emphasize that the "eth" boot-time parm takes a valueRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Use helpers to obtain task pid in printks (arch code)Alexey Dobriyan
One of the easiest things to isolate is the pid printed in kernel log. There was a patch, that made this for arch-independent code, this one makes so for arch/xxx files. It took some time to cross-compile it, but hopefully these are all the printks in arch code. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-16During VM oom condition, kill all threads in process groupWill Schmidt
We have had complaints where a threaded application is left in a bad state after one of it's threads is killed when we hit a VM: out_of_memory condition. Killing just one of the process threads can leave the application in a bad state, whereas killing the entire process group would allow for the application to restart, or be otherwise handled, and makes it very obvious that something has gone wrong. This change allows the entire process group to be taken down, rather than just the one thread. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Consolidate PTRACE_DETACHAlexey Dobriyan
Identical handlers of PTRACE_DETACH go into ptrace_request(). Not touching compat code. Not touching archs that don't call ptrace_request. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
