path: root/arch/xtensa
2015-05-25xtensa: Provide dummy dma_alloc_attrs() and dma_free_attrs()Guenter Roeck
xtensa:allmodconfig fails to build with the following errors. drivers/gpu/drm/nouveau/nvkm/subdev/instmem/gk20a.c: In function ‘gk20a_instobj_dtor_dma’: drivers/gpu/drm/nouveau/nvkm/subdev/instmem/gk20a.c:154:2: error: implicit declaration of function ‘dma_free_attrs’ drivers/gpu/drm/nouveau/nvkm/subdev/instmem/gk20a.c: In function ‘gk20a_instobj_ctor_dma’: drivers/gpu/drm/nouveau/nvkm/subdev/instmem/gk20a.c:218:2: error: implicit declaration of function ‘dma_alloc_attrs’ Xtensa does not provide those functions at this time. Provide dummy implementations to avoid build errors. Acked-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Chris Zankel <chris@zankel.net>
2015-04-17Merge tag 'xtensa-20150416' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa updates from Chris Zankel: - fix linker script transformation for .text / .text.fixup - wire bpf and execveat syscalls - provide __NR_sync_file_range2 instead of __NR_sync_file_range, as that's what xtensa uses. - make xtfpgs LCD driver functional and configurable. This fixes hardware lockup on KC705/ML605 boot - add audio subsystem bits to xtfpga DTS and provide sample KC705 config with audio features enabled - add CY7C67300 USB controller support to XTFPGA - fix locking issues in ISS network driver - document PIC and MX interrupt distributor device tree bindings * tag 'xtensa-20150416' of git://github.com/czankel/xtensa-linux: xtensa: xtfpga: add CY7C67300 USB controller support irqchip: xtensa-pic: xtensa-mx: document DT bindings xtensa: ISS: fix locking in TAP network adapter xtensa: Fix fix linker script transformation for .text / .text.fixup xtensa: provide __NR_sync_file_range2 instead of __NR_sync_file_range xtensa: wire bpf and execveat syscalls xtensa: xtfpga: fix hardware lockup caused by LCD driver xtensa: xtfpga: provide defconfig with audio subsystem xtensa: xtfpga: add audio card to xtfpga DTS
2015-04-15Merge branch 'exec_domain_rip_v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc Pull exec domain removal from Richard Weinberger: "This series removes execution domain support from Linux. The idea behind exec domains was to support different ABIs. The feature was never complete nor stable. Let's rip it out and make the kernel signal handling code less complicated" * 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits) arm64: Removed unused variable sparc: Fix execution domain removal Remove rest of exec domains. arch: Remove exec_domain from remaining archs arc: Remove signal translation and exec_domain xtensa: Remove signal translation and exec_domain xtensa: Autogenerate offsets in struct thread_info x86: Remove signal translation and exec_domain unicore32: Remove signal translation and exec_domain um: Remove signal translation and exec_domain tile: Remove signal translation and exec_domain sparc: Remove signal translation and exec_domain sh: Remove signal translation and exec_domain s390: Remove signal translation and exec_domain mn10300: Remove signal translation and exec_domain microblaze: Remove signal translation and exec_domain m68k: Remove signal translation and exec_domain m32r: Remove signal translation and exec_domain m32r: Autogenerate offsets in struct thread_info frv: Remove signal translation and exec_domain ...
2015-04-14Merge branch 'for-linus-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: "Part one: - struct filename-related cleanups - saner iov_iter_init() replacements (and switching the syscalls to use of those) - ntfs switch to ->write_iter() (Anton) - aio cleanups and splitting iocb into common and async parts (Christoph) - assorted fixes (me, bfields, Andrew Elble) There's a lot more, including the completion of switchover to ->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags race fixes, etc, but that goes after #for-davem merge. David has pulled it, and once it's in I'll send the next vfs pull request" * 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits) sg_start_req(): use import_iovec() sg_start_req(): make sure that there's not too many elements in iovec blk_rq_map_user(): use import_single_range() sg_io(): use import_iovec() process_vm_access: switch to {compat_,}import_iovec() switch keyctl_instantiate_key_common() to iov_iter switch {compat_,}do_readv_writev() to {compat_,}import_iovec() aio_setup_vectored_rw(): switch to {compat_,}import_iovec() vmsplice_to_user(): switch to import_iovec() kill aio_setup_single_vector() aio: simplify arguments of aio_setup_..._rw() aio: lift iov_iter_init() into aio_setup_..._rw() lift iov_iter into {compat_,}do_readv_writev() NFS: fix BUG() crash in notify_change() with patch to chown_common() dcache: return -ESTALE not -EBUSY on distributed fs race NTFS: Version 2.1.32 - Update file write from aio_write to write_iter. VFS: Add iov_iter_fault_in_multipages_readable() drop bogus check in file_open_root() switch security_inode_getattr() to struct path * constify tomoyo_realpath_from_path() ...
2015-04-14Merge tag 'xtensa-for-next-20150413' of ↵Chris Zankel
git://github.com/jcmvbkbc/linux-xtensa into for_next Xtensa improvements for 4.1: - fix locking issues in ISS network driver; - document PIC and MX interrupt distributor device tree bindings; - add CY7C67300 USB controller support to XTFPGA. Signed-off-by: Chris Zankel <chris@zankel.net>
2015-04-14Merge tag 'v4.0' into for_nextChris Zankel
Linux 4.0
2015-04-13xtensa: xtfpga: add CY7C67300 USB controller supportMax Filippov
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2015-04-13xtensa: ISS: fix locking in TAP network adapterMax Filippov
- don't lock lp->lock in the iss_net_timer for the call of iss_net_poll, it will lock it itself; - invert order of lp->lock and opened_lock acquisition in the iss_net_open to make it consistent with iss_net_poll; - replace spin_lock with spin_lock_bh when acquiring locks used in iss_net_timer from non-atomic context; - replace spin_lock_irqsave with spin_lock_bh in the iss_net_start_xmit as the driver doesn't use lp->lock in the hard IRQ context; - replace __SPIN_LOCK_UNLOCKED(lp.lock) with spin_lock_init, otherwise lockdep is unhappy about using non-static key. Cc: <stable@vger.kernel.org> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2015-04-12xtensa: Remove signal translation and exec_domainRichard Weinberger
As execution domain support is gone we can remove signal translation from the signal code and remove exec_domain from thread_info. Signed-off-by: Richard Weinberger <richard@nod.at>
2015-04-12xtensa: Autogenerate offsets in struct thread_infoRichard Weinberger
Maintaining offsets by hand is no fun. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Richard Weinberger <richard@nod.at>
2015-04-11whack-a-mole: there's no point doing set_fs(USER_DS) in sigframe setupAl Viro
2015-04-10xtensa: Fix fix linker script transformation for .text / .text.fixupGuenter Roeck
Commit 779c88c94c34 ("ARM: 8321/1: asm-generic: introduce .text.fixup input section") introduced a new .text.fixup section which is merged with .text at link time. This causes xtensa builds to fail with lots of error messages similar to the following. lib/lib.a(kobject.o): In function `kobject_create': (.text+0x498): dangerous relocation: l32r: literal placed after use: (.literal+0x150) Linker script transformation needs to be updated to detect and handle the new section. Fixes: 779c88c94c34 ("ARM: 8321/1: asm-generic: introduce .text.fixup input section") Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Chris Zankel <chris@zankel.net>
2015-03-19PCI: Assign resources before drivers claim devices (pci_scan_root_bus())Yijing Wang
Previously, pci_scan_root_bus() created a root PCI bus, enumerated the devices on it, and called pci_bus_add_devices(), which made the devices available for drivers to claim them. Most callers assigned resources to devices after pci_scan_root_bus() returns, which may be after drivers have claimed the devices. This is incorrect; the PCI core should not change device resources while a driver is managing the device. Remove pci_bus_add_devices() from pci_scan_root_bus() and do it after any resource assignment in the callers. Note that ARM's pci_common_init_dev() already called pci_bus_add_devices() after pci_scan_root_bus(), so we only need to remove the first call: pci_common_init_dev pcibios_init_hw pci_scan_root_bus pci_bus_add_devices # first call pci_bus_assign_resources pci_bus_add_devices # second call [bhelgaas: changelog, drop "root_bus" var in alpha common_init_pci(), return failure earlier in mn10300, add "return" in x86 pcibios_scan_root(), return early if xtensa platform_pcibios_fixup() fails] Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: Matt Turner <mattst88@gmail.com> CC: David Howells <dhowells@redhat.com> CC: Tony Luck <tony.luck@intel.com> CC: Michal Simek <monstr@monstr.eu> CC: Ralf Baechle <ralf@linux-mips.org> CC: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> CC: Sebastian Ott <sebott@linux.vnet.ibm.com> CC: "David S. Miller" <davem@davemloft.net> CC: Chris Metcalf <cmetcalf@ezchip.com> CC: Chris Zankel <chris@zankel.net> CC: Max Filippov <jcmvbkbc@gmail.com> CC: Thomas Gleixner <tglx@linutronix.de>
2015-03-13Merge tag 'xtensa-for-next-20150304' of ↵Chris Zankel
git://github.com/jcmvbkbc/linux-xtensa into for_next Xtensa fixes for 4.0: - make xtfpgs LCD driver functional and configurable. This fixes hardware lockup on KC705/ML605 boot; - wire bpf and execveat syscalls; - provide __NR_sync_file_range2 instead of __NR_sync_file_range, as that's what xtensa uses.
2015-03-04xtensa: provide __NR_sync_file_range2 instead of __NR_sync_file_rangeMax Filippov
xtensa actually uses sync_file_range2 implementation, so it should define __NR_sync_file_range2 as other architectures that use that function. That fixes userspace interface (that apparently never worked) and avoids special-casing xtensa in libc implementations. See the thread ending at http://lists.busybox.net/pipermail/uclibc/2015-February/048833.html for more details. Cc: stable@vger.kernel.org Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2015-03-04xtensa: wire bpf and execveat syscallsMax Filippov
2015-02-27xtensa: xtfpga: fix hardware lockup caused by LCD driverMax Filippov
LCD driver is always built for the XTFPGA platform, but its base address is not configurable, and is wrong for ML605/KC705. Its initialization locks up KC705 board hardware. Make the whole driver optional, and its base address and bus width configurable. Implement 4-bit bus access method. Cc: stable@vger.kernel.org Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2015-02-18Merge tag 'asm-generic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic uaccess.h cleanup from Arnd Bergmann: "Like in 3.19, I once more have a multi-stage cleanup for one asm-generic header file, this time the work was done by Michael Tsirkin and cleans up the uaccess.h file in asm-generic, as well as all architectures for which the respective maintainers did not pick up his patches directly" * tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (37 commits) sparc32: nocheck uaccess coding style tweaks sparc64: nocheck uaccess coding style tweaks xtensa: macro whitespace fixes sh: macro whitespace fixes parisc: macro whitespace fixes m68k: macro whitespace fixes m32r: macro whitespace fixes frv: macro whitespace fixes cris: macro whitespace fixes avr32: macro whitespace fixes arm64: macro whitespace fixes arm: macro whitespace fixes alpha: macro whitespace fixes blackfin: macro whitespace fixes sparc64: uaccess_64 macro whitespace fixes sparc32: uaccess_32 macro whitespace fixes avr32: whitespace fix sh: fix put_user sparse errors metag: fix put_user sparse errors ia64: fix put_user sparse errors ...
2015-02-13xtensa: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12all arches, signal: move restart_block to struct task_structAndy Lutomirski
If an attacker can cause a controlled kernel stack overflow, overwriting the restart block is a very juicy exploit target. This is because the restart_block is held in the same memory allocation as the kernel stack. Moving the restart block to struct task_struct prevents this exploit by making the restart_block harder to locate. Note that there are other fields in thread_info that are also easy targets, at least on some architectures. It's also a decent simplification, since the restart code is more or less identical on all architectures. [james.hogan@imgtec.com: metag: align thread_info::supervisor_stack] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Steven Miao <realmz6@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: make FIRST_USER_ADDRESS unsigned long on all archsKirill A. Shutemov
LKP has triggered a compiler warning after my recent patch "mm: account pmd page tables to the process": mm/mmap.c: In function 'exit_mmap': >> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default] The code: > 2857 WARN_ON(mm_nr_pmds(mm) > 2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT); In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has the same type -- int. PUD_SHIFT. I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned long. On every arch for consistency. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10xtensa: drop _PAGE_FILE and pte_file()-related helpersKirill A. Shutemov
We've replaced remap_file_pages(2) implementation with emulation. Nobody creates non-linear mapping anymore. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-07xtensa: xtfpga: provide defconfig with audio subsystemMax Filippov
This is the generic KC705 defconfig with all pieces of xtfpga audio subsystem enabled: I2C, SPI and ASoC support, I2C master, SPI master, clock synthesizer, I2S master, audio codec and audio card drivers. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2015-02-07xtensa: xtfpga: add audio card to xtfpga DTSMax Filippov
This includes OpenCores I2C host controller, TI CDCE706 clock generator, xtfpga I2S master controller, xtfpga SPI master controller, TI TLV320AIC23 audio codec and a simple audio card. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2015-01-29vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-13xtensa: macro whitespace fixesMichael S. Tsirkin
While working on arch/xtensa/include/asm/uaccess.h, I noticed that some macros within this header are made harder to read because they violate a coding style rule: space is missing after comma. Fix it up. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Max Filippov <jcmvbkbc@gmail.com>
2014-12-16Merge tag 'xtensa-next-20141215' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa fixes from Chris Zankel: - fix nommu support - remove s6000 variant and s6105 platform - fix permissions for kmapped pages so that copy_to_user_page works with them - add power management menu to Kconfig to allow use of runtime PM - disable linker optimizations because of a linker bug - fix sparse error * tag 'xtensa-next-20141215' of git://github.com/czankel/xtensa-linux: xtensa: disable link optimization xtensa/uaccess: fix sparse errors xtensa: fix kmap_prot definition xtensa: add power management menu to Kconfig xtensa: remove s6000 variant and s6105 platform xtensa: make PLATFORM_DEFAULT_MEM parameters configurable xtensa: nommu: clean up memory map dump xtensa: nommu: reserve memory below PLATFORM_DEFAULT_MEM_START xtensa: nommu: set up cache and atomctl in initialize_mmu xtensa: move vecbase SR initialization to _startup xtensa: nommu: fix uImage load address xtensa: nommu: fix load address definitions xtensa: nommu: fix Image.elf reset code and ld script xtensa: nommu: add MMU dependency to DEBUG_TLB_SANITY xtensa: nommu: don't build most of the cache flushing code xtensa: nommu: don't provide arch_get_unmapped_area xtensa: nommu: provide MAP_UNINITIALIZED definition xtensa: nommu: provide _PAGE_CHG_MASK definition xtensa: nommu: provide __invalidate_dcache_page_alias stub xtensa: nommu: move init_mmu stub to nommu_context.h
2014-12-15xtensa: disable link optimizationChris Zankel
The default linker behavior is to optimize identical literal values and remove unnecessary overhead. However, because of a bug in the linker, this currently results in an error ('call target out of range'). Disable link-time optimizations per default until there is a fix for the linker and add the option to iss_defconfig. Signed-off-by: Chris Zankel <chris@zankel.net>
2014-12-15xtensa/uaccess: fix sparse errorsMichael S. Tsirkin
virtio wants to read bitwise types from userspace using get_user. At the moment this triggers sparse errors, since the value is passed through an integer. Fix that up using __force. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2014-12-15Merge tag 'xtensa-for-next-20141213' of ↵Chris Zankel
git://github.com/jcmvbkbc/linux-xtensa into for_next Xtensa improvements for 3.19: - fix permissions for kmapped pages so that copy_to_user_page works with them; - add power management menu to Kconfig to allow use of runtime PM.
2014-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) New offloading infrastructure and example 'rocker' driver for offloading of switching and routing to hardware. This work was done by a large group of dedicated individuals, not limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend, Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu 2) Start making the networking operate on IOV iterators instead of modifying iov objects in-situ during transfers. Thanks to Al Viro and Herbert Xu. 3) A set of new netlink interfaces for the TIPC stack, from Richard Alpe. 4) Remove unnecessary looping during ipv6 routing lookups, from Martin KaFai Lau. 5) Add PAUSE frame generation support to gianfar driver, from Matei Pavaluca. 6) Allow for larger reordering levels in TCP, which are easily achievable in the real world right now, from Eric Dumazet. 7) Add a variable of napi_schedule that doesn't need to disable cpu interrupts, from Eric Dumazet. 8) Use a doubly linked list to optimize neigh_parms_release(), from Nicolas Dichtel. 9) Various enhancements to the kernel BPF verifier, and allow eBPF programs to actually be attached to sockets. From Alexei Starovoitov. 10) Support TSO/LSO in sunvnet driver, from David L Stevens. 11) Allow controlling ECN usage via routing metrics, from Florian Westphal. 12) Remote checksum offload, from Tom Herbert. 13) Add split-header receive, BQL, and xmit_more support to amd-xgbe driver, from Thomas Lendacky. 14) Add MPLS support to openvswitch, from Simon Horman. 15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen Klassert. 16) Do gro flushes on a per-device basis using a timer, from Eric Dumazet. This tries to resolve the conflicting goals between the desired handling of bulk vs. RPC-like traffic. 17) Allow userspace to ask for the CPU upon what a packet was received/steered, via SO_INCOMING_CPU. From Eric Dumazet. 18) Limit GSO packets to half the current congestion window, from Eric Dumazet. 19) Add a generic helper so that all drivers set their RSS keys in a consistent way, from Eric Dumazet. 20) Add xmit_more support to enic driver, from Govindarajulu Varadarajan. 21) Add VLAN packet scheduler action, from Jiri Pirko. 22) Support configurable RSS hash functions via ethtool, from Eyal Perry. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits) Fix race condition between vxlan_sock_add and vxlan_sock_release net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header net/mlx4: Add support for A0 steering net/mlx4: Refactor QUERY_PORT net/mlx4_core: Add explicit error message when rule doesn't meet configuration net/mlx4: Add A0 hybrid steering net/mlx4: Add mlx4_bitmap zone allocator net/mlx4: Add a check if there are too many reserved QPs net/mlx4: Change QP allocation scheme net/mlx4_core: Use tasklet for user-space CQ completion events net/mlx4_core: Mask out host side virtualization features for guests net/mlx4_en: Set csum level for encapsulated packets be2net: Export tunnel offloads only when a VxLAN tunnel is created gianfar: Fix dma check map error when DMA_API_DEBUG is enabled cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call net: fec: only enable mdio interrupt before phy device link up net: fec: clear all interrupt events to support i.MX6SX net: fec: reset fep link status in suspend function net: sock: fix access via invalid file descriptor net: introduce helper macro for_each_cmsghdr ...
2014-12-10net, lib: kill arch_fast_hash library bitsDaniel Borkmann
As there are now no remaining users of arch_fast_hash(), lets kill it entirely. This basically reverts commit 71ae8aac3e19 ("lib: introduce arch optimized hash library") and follow-up work, that is f.e., commit 237217546d44 ("lib: hash: follow-up fixups for arch hash"), commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for asm-generic/hash.h") and last but not least commit 6a02652df511 ("perf tools: Fix include for non x86 architectures"). Cc: Francesco Fusco <fusco@ntop.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09Merge tag 'asm-generic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic asm/io.h rewrite from Arnd Bergmann: "While there normally is no reason to have a pull request for asm-generic but have all changes get merged through whichever tree needs them, I do have a series for 3.19. There are two sets of patches that change significant portions of asm/io.h, and this branch contains both in order to resolve the conflicts: - Will Deacon has done a set of patches to ensure that all architectures define {read,write}{b,w,l,q}_relaxed() functions or get them by including asm-generic/io.h. These functions are commonly used on ARM specific drivers to avoid expensive L2 cache synchronization implied by the normal {read,write}{b,w,l,q}, but we need to define them on all architectures in order to share the drivers across architectures and to enable CONFIG_COMPILE_TEST configurations for them - Thierry Reding has done an unrelated set of patches that extends the asm-generic/io.h file to the degree necessary to make it useful on ARM64 and potentially other architectures" * tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (29 commits) ARM64: use GENERIC_PCI_IOMAP sparc: io: remove duplicate relaxed accessors on sparc32 ARM: sa11x0: Use void __iomem * in MMIO accessors arm64: Use include/asm-generic/io.h ARM: Use include/asm-generic/io.h asm-generic/io.h: Implement generic {read,write}s*() asm-generic/io.h: Reconcile I/O accessor overrides /dev/mem: Use more consistent data types Change xlate_dev_{kmem,mem}_ptr() prototypes ARM: ixp4xx: Properly override I/O accessors ARM: ixp4xx: Fix build with IXP4XX_INDIRECT_PCI ARM: ebsa110: Properly override I/O accessors ARC: Remove redundant PCI_IOBASE declaration documentation: memory-barriers: clarify relaxed io accessor semantics x86: io: implement dummy relaxed accessor macros for writes tile: io: implement dummy relaxed accessor macros for writes sparc: io: implement dummy relaxed accessor macros for writes powerpc: io: implement dummy relaxed accessor macros for writes parisc: io: implement dummy relaxed accessor macros for writes mn10300: io: implement dummy relaxed accessor macros for writes ...
2014-12-09xtensa: fix kmap_prot definitionMax Filippov
Replace PAGE_KERNEL with PAGE_KERNEL_EXEC to allow copy_to_user_page invalidate icache for pages mapped with kmap. Cc: stable@vger.kernel.org Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-12-09xtensa: add power management menu to KconfigMax Filippov
This allows using runtime power management feature on Xtensa. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-12-05net: sock: allow eBPF programs to be attached to socketsAlexei Starovoitov
introduce new setsockopt() command: setsockopt(sock, SOL_SOCKET, SO_ATTACH_BPF, &prog_fd, sizeof(prog_fd)) where prog_fd was received from syscall bpf(BPF_PROG_LOAD, attr, ...) and attr->prog_type == BPF_PROG_TYPE_SOCKET_FILTER setsockopt() calls bpf_prog_get() which increments refcnt of the program, so it doesn't get unloaded while socket is using the program. The same eBPF program can be attached to multiple sockets. User task exit automatically closes socket which calls sk_filter_uncharge() which decrements refcnt of eBPF program Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/chelsio/cxgb4vf/sge.c drivers/net/ethernet/intel/ixgbe/ixgbe_phy.c sge.c was overlapping two changes, one to use the new __dev_alloc_page() in net-next, and one to use s->fl_pg_order in net. ixgbe_phy.c was a set of overlapping whitespace changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-11net: introduce SO_INCOMING_CPUEric Dumazet
Alternative to RPS/RFS is to use hardware support for multiple queues. Then split a set of million of sockets into worker threads, each one using epoll() to manage events on its own socket pool. Ideally, we want one thread per RX/TX queue/cpu, but we have no way to know after accept() or connect() on which queue/cpu a socket is managed. We normally use one cpu per RX queue (IRQ smp_affinity being properly set), so remembering on socket structure which cpu delivered last packet is enough to solve the problem. After accept(), connect(), or even file descriptor passing around processes, applications can use : int cpu; socklen_t len = sizeof(cpu); getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len); And use this information to put the socket into the right silo for optimal performance, as all networking stack should run on the appropriate cpu, without need to send IPI (RPS/RFS). Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-10Merge tag 'xtensa-for-next-20141021-2' of ↵Chris Zankel
git://github.com/jcmvbkbc/linux-xtensa into for_next Xtensa improvements for 3.18: - fix nommu support; - remove s6000 variant and s6105 platform.
2014-10-23Merge tag 'xtensa-for-next-20141021-1' of ↵Chris Zankel
git://github.com/jcmvbkbc/linux-xtensa into for_next Xtensa improvements for 3.18: - add seccomp, getrandom, and memfd_create syscalls; - add defconfigs for KC705 and SMP LX200; - fix ISS and xtfpga Kconfig dependencies so that more randconfigs are buildable; - fix umount syscall; - implement pgprot_noncached.
2014-10-21xtensa: remove s6000 variant and s6105 platformDaniel Glöckner
The Stretch s6000 family support has been merged into mainline 5 years ago. There appear to be no users of this code since nobody complained that there is a merge error preventing compilation. Apart from the s6105 IP camera reference design there are no s6000 devices known to ever have run Linux and as the chips are out of production there probably never will be. The successor s7000 no longer uses an Xtensa core for the OS. Let's remove the code until someone is found who actually needs it. Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: make PLATFORM_DEFAULT_MEM parameters configurableMax Filippov
This allows using xtfpga platform with both MMU and noMMU cores. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: nommu: clean up memory map dumpMax Filippov
noMMU configuration doesn't use special area for vmalloc allocations, don't print it in the memory map. PAGE_OFFSET is fixed to 0 in noMMU, use min_low_pfn and max_low_pfn for lowmem range display. Make all XCHAL_KSEG_* constants unsigned long for consistency with other addresses. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: nommu: reserve memory below PLATFORM_DEFAULT_MEM_STARTMax Filippov
Memory accounting code can't handle pages below PLATFORM_DEFAULT_MEM_START. Reserve those pages if they exist. When PLATFORM_DEFAULT_MEM_START is zero reserve one page at address 0 to make sure that successfull memory allocations don't return NULL. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: nommu: set up cache and atomctl in initialize_mmuMax Filippov
initialize_mmu sets up atomctl SR which is needed for s32c1i to function correctly even in noMMU configurations. It's also a good place to set up caching attributes of physical memory. Allow enabling INITIALIZE_XTENSA_MMU_INSIDE_VMLINUX in noMMU configurations for setting up atomctl and cache attributes. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: move vecbase SR initialization to _startupMax Filippov
Instead of initializing vecbase in initialize_mmu macro, which may be expanded either in Image.elf reset vector hadler or in the kernel head.S, both times only when CONFIG_MMU is enabled, do this initialization once in _startup function. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: nommu: fix uImage load addressMax Filippov
Use the same offset from the default physical memory start address as in LOAD_MEMORY_ADDRESS definition. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: nommu: fix load address definitionsMax Filippov
Change KERNELOFFSET, LOAD_MEMORY_ADDRESS and VIRTUAL_MEMORY_ADDRESS to be relative to the start of physical memory in noMMU configuration, as there's no uniform memory remapping to KSEG starting at 0xd0000000. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: nommu: fix Image.elf reset code and ld scriptMax Filippov
Don't hardcode kernel entry address as 0x3000 or 0xd0003000, use LOAD_MEMORY_ADDRESS macro. Don't compile MMU remapping code and don't try to link it when building noMMU configuration. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-10-21xtensa: nommu: add MMU dependency to DEBUG_TLB_SANITYMax Filippov
TLB sanity checking code depends on full MMU presence and may not be built in noMMU confgiuration. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
