use right parameter when calling mxc_free_iomux
Signed-off-by: Fred Fan <r01011@freescale.com>
(cherry picked from commit f5e011cda199c05f25e217c33974dfae9940c8d8)
register gpio sysdev after avic sysdev
(cherry picked from commit 3ff35c4ccb2b6d642d42176b429fddd7bd0bef68)
fix compile error for mx27/mx31/mxc91321
Signed-off-by: Kevin Shen <b00984@freescale.com>
(cherry picked from commit eb0fde96097717b412502c06deff42800ab6e570)
add interrupt handle for on-off key
(cherry picked from commit 021b66f90e97984a360c0d02f43463963fb69eda)
Add empty function for on-off key configure
add a empty function for on-off key configure for mx27 and mx31
fix this CR by configure on/off gpio pin
Map IRAM playback buffer to user space for power saving
Map SDMA buffer descriptors to IRAM
Signed-off-by: Laura Lawrence <Laura.Lawrence@freescale.com>
Added keypad driver for MX37 3 stack board.
Signed-off-by: Raj Rajasekaran <b10872@freescale.com>
Enable access to IRAM through the SCC2 module
SDHC PIO, and the DMAs are still in dbging
Signed-off-by: Richard Zhu <r65037@freescale.com>
Add close interface to input device. And change the wait_for_complete
to wait_for_complete_interruptible_timeout, because driver can not
get the event about singals. So thread can not terminate.
The fixes the DDR clock value returned by the clocking API
Signed-off-by: Mahesh Mahadevan <r9aadq@freescale.com>
Update the devices file to point to the latest mcu_2_app SDMA script
Fix error gpio inactive interface of SPI. and Enable wakeup interrupt for
RM mode. And add code to skip suspend check for un-attached spi client device
Signed-off-by: Sam Yang <r52096@freescale.com>
Set regulator GPO1 to be the parent of regulator GPO3 and GPO4 for MX31_3stack
Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
support device mma7450
Change IPU internal RAM param base address. Enable CLAA WVGA LCD
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
Add pmic source code
Signed-off-by: Zhou Jingyu <Jingyu.Zhou@freescale.com>
SPI driver update for i.MX35
Signed-off-by: Katherine Lu <r63906@freescale.com>
1. Add FM item in MX31 3DS and MX37 3DS default config.
2. Fix wrong HW event Macro in pmic_battery.c
MXC_HWEVENT
To
CONFIG_MXC_HWEVENT
3. Delete duplicated I2C register code in mx3_3stack.c
MX35 I2C master driver
Signed-off-by: Guoxing Wu <b02248@freescale.com>
add mx35 nor flash support
Signed-off-by: Jason Liu <r64343@freescale.com>
Implimentaion nand driver on mx35 platform
Add the support for S20_LE and S24_LE audio format in spdif driver
Signed-off-by: Wallace Wang <r59996@freescale.com>
Add supporting i.MX35 EVB and 3STACK board. The common modules such as
clock, iomux, platform device, cpu and etc has implemented. And support
machine specific layer code for EVB and 3STACK board. Just on 3STACK board,
the virtual interrupts which is generated by CPLD has implemented.
Signed-off-by:Fred Fan <r01011@freescale.com>
FM chip set si4702 support
Add check_fb function to wm8350 backlight driver, so that only
fb0 blank/unblank will change the backlight state.
Signed-off-by: Rob Herring <r.herring@freescale.com>
missed including a header file
Merge ENGR0006861
Remove platform_device register in mxc-alsa-pmic.c
Move clk_put to device.c
Turn off spdif alsa audio by default.
Signed-off-by: Alan Tull <r80115@freescale.com>
Added PATA driver for i.MX31ADS and i.MX37 3 stack boards.
MX31 3stack board boot problem with jffs2. It was caused by recent
community JFFS2 patch to support MLC nand by NOT writing to oob
area. Even though this is not needed for the NFC on MX31, we have
to set the flag:
mtd->flags &= ~MTD_OOB_WRITEABLE
in the mxc_nd.c driver.
Signed-off-by: Kevin Zhang <k.zhang@freescale.com>
Add Support for Touchscreen on the 3-Stack board
Set regulator GPO1 to be the parent of regulator GPO2 for MX31_3stack
sets the table pointer to NULL in this case (see devices.c)
modified plat-mxc/dptc.c such that in this case, an error
message is printed and DPTC is not init'ed.
Signed-off-by: Yves vandervennet <r55763@freescale.com>
added function dptc_suspend(), called from clock.c
tables for TO 2.0 monotonic
tables for TO 1.x unchanged
Adjust nand partition table to accommodate with redboot
Add spdif driver to imx37 defconfig
For some imx37 boards, the first time to play pcm out from spdif fails
Enable the uart2 for BT
Fix the mxc_gpio_request for none gpio pins
enable MMC/SD/CAMERA/DAB
Signed-off-by: Eric Chen <xinyu.chen@freescale.com>
Update MX37 defconfig to enable SLUB allocator
Mx37: add USB controller driver for device mode
Signed-off-by: Albert Chen <r65187@freescale.com>
Add missing OV2640 config to ADS defconfigs
Add driver for TVE TV encoder module on MX37.
Add IPUv3 driver
Update framebuffer driver for IPUv3
Update V4L2 output driver for IPUv3
This patch adds support for the MX31 3-Stack Chrontel CH7024 TV encoder driver.
Add missing .valid function for power management due to kernel upgrade.
It was fixed in the 2.6.22 but was dropped when upgrading to 2.6.24.
This fix impacts on MX27, MX31 and MXC91321 based platforms.
Add spdif tx driver
DMA mode
transfer bit: 16bit/32bit
