path: root/arch
2013-03-03Merge tag 'stable/for-linus-3.9-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen bug-fixes from Konrad Rzeszutek Wilk: - Update the Xen ACPI memory and CPU hotplug locking mechanism. - Fix PAT issues wherein various applications would not start - Fix handling of multiple MSI as AHCI now does it. - Fix ARM compile failures. * tag 'stable/for-linus-3.9-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xenbus: fix compile failure on ARM with Xen enabled xen/pci: We don't do multiple MSI's. xen/pat: Disable PAT using pat_enabled value. xen/acpi: xen cpu hotplug minor updates xen/acpi: xen memory hotplug minor updates
2013-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more VFS bits from Al Viro: "Unfortunately, it looks like xattr series will have to wait until the next cycle ;-/ This pile contains 9p cleanups and fixes (races in v9fs_fid_add() etc), fixup for nommu breakage in shmem.c, several cleanups and a bit more file_inode() work" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: constify path_get/path_put and fs_struct.c stuff fix nommu breakage in shmem.c cache the value of file_inode() in struct file 9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry 9p: make sure ->lookup() adds fid to the right dentry 9p: untangle ->lookup() a bit 9p: double iput() in ->lookup() if d_materialise_unique() fails 9p: v9fs_fid_add() can't fail now v9fs: get rid of v9fs_dentry 9p: turn fid->dlist into hlist 9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine more file_inode() open-coded instances selinux: opened file can't have NULL or negative ->f_path.dentry (In the meantime, the hlist traversal macros have changed, so this required a semantic conflict fixup for the newly hlistified fid->dlist)
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull second set of s390 patches from Martin Schwidefsky: "The main part of this merge are Heikos uaccess patches. Together with commit 09884964335e ("mm: do not grow the stack vma just because of an overrun on preceding vma") the user string access is hopefully fixed for good. In addition some bug fixes and two cleanup patches." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/module: fix compile warning qdio: remove unused parameters s390/uaccess: fix kernel ds access for page table walk s390/uaccess: fix strncpy_from_user string length check input: disable i8042 PC Keyboard controller for s390 s390/dis: Fix invalid array size s390/uaccess: remove pointless access_ok() checks s390/uaccess: fix strncpy_from_user/strnlen_user zero maxlen case s390/uaccess: shorten strncpy_from_user/strnlen_user s390/dasd: fix unresponsive device after all channel paths were lost s390/mm: ignore change bit for vmemmap s390/page table dumper: add support for change-recording override bit
2013-03-03Merge branch 'fixes-for-3.9-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull second round of PARISC updates from Helge Deller: "The most important fix in this branch is the switch of io_setup, io_getevents and io_submit syscalls to use the available compat syscalls when running 32bit userspace on 64bit kernel. Other than that it's mostly removal of compile warnings." * 'fixes-for-3.9-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: fix redefinition of SET_PERSONALITY parisc: do not install modules when installing kernel parisc: fix compile warnings triggered by atomic_sub(sizeof(),v) parisc: check return value of down_interruptible() in hp_sdc_rtc.c parisc: avoid unitialized variable warning in pa_memcpy() parisc: remove unused variable 'compat_val' parisc: switch to compat_functions of io_setup, io_getevents and io_submit parisc: select ARCH_WANT_FRAME_POINTERS
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-03Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull late ARM updates from Russell King: "Here is the late set of ARM updates for this merge window; in here is: - The ARM parts of the broadcast timer support, core parts merged through tglx's tree. This was left over from the previous merge to allow the dependency on tglx's tree to be resolved. - A fix to the VFP code which shows up on Raspberry Pi's, as well as fixing the fallout from a previous commit in this area. - A number of smaller fixes scattered throughout the ARM tree" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: ARM: Fix broken commit 0cc41e4a21d43 corrupting kernel messages ARM: fix scheduling while atomic warning in alignment handling code ARM: VFP: fix emulation of second VFP instruction ARM: 7656/1: uImage: Error out on build of multiplatform without LOADADDR ARM: 7640/1: memory: tegra_ahb_enable_smmu() depends on TEGRA_IOMMU_SMMU ARM: 7654/1: Preserve L_PTE_VALID in pte_modify() ARM: 7653/2: do not scale loops_per_jiffy when using a constant delay clock ARM: 7651/1: remove unused smp_timer_broadcast #define
2013-03-03Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This contains: - fixes and improvements - devicetree bindings - conversion to watchdog generic framework of the following drivers: - booke_wdt - bcm47xx_wdt.c - at91sam9_wdt - Removal of old STMP3xxx driver - Addition of following new drivers: - new driver for STMP3xxx and i.MX23/28 - Retu watchdog driver" * git://www.linux-watchdog.org/linux-watchdog: (30 commits) watchdog: sp805_wdt depends on ARM watchdog: davinci_wdt: update to devm_* API watchdog: davinci_wdt: use devm managed clk get watchdog: at91rm9200: add DT support watchdog: add timeout-sec property binding watchdog: at91sam9_wdt: Convert to use the watchdog framework watchdog: omap_wdt: Add option nowayout watchdog: core: dt: add support for the timeout-sec dt property watchdog: bcm47xx_wdt.c: add hard timer watchdog: bcm47xx_wdt.c: rename wdt_time to timeout watchdog: bcm47xx_wdt.c: rename ops methods watchdog: bcm47xx_wdt.c: use platform device watchdog: bcm47xx_wdt.c: convert to watchdog core api watchdog: Convert BookE watchdog driver to watchdog infrastructure watchdog: s3c2410_wdt: Use devm_* functions watchdog: remove old STMP3xxx driver watchdog: add new driver for STMP3xxx and i.MX23/28 rtc: stmp3xxx: add wdt-accessor function watchdog: introduce retu_wdt driver watchdog: intel_scu_watchdog: fix Kconfig dependency ...
2013-03-03Merge branches 'devel-stable', 'fixes' and 'mmci' into for-linusRussell King
2013-03-02metag: Provide dma_get_sgtable()James Hogan
metag/allmodconfig: drivers/media/v4l2-core/videobuf2-dma-contig.c: In function 'vb2_dc_get_base_sgt': drivers/media/v4l2-core/videobuf2-dma-contig.c:387: error: implicit declaration of function 'dma_get_sgtable' For architectures using dma_map_ops, dma_get_sgtable() is provided in <asm-generic/dma-mapping-common.h>. Metag does not use dma_map_ops yet, hence it should implement it as an inline stub using dma_common_get_sgtable(). Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
2013-03-02metag: prom.h: remove declaration of metag_dt_memblock_reserve()James Hogan
Metag doesn't have a metag_dt_memblock_reserve() function so remove the declaration from asm/prom.h. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: copy devicetree to non-init memoryJames Hogan
Make a copy of the device tree blob in non-init memory. It is required when using built-in device tree files that the platform code copies the blob to non-init memory prior to calling unflatten_device_tree(), otherwise the strings that the device tree refer to will get poisoned and potentially reused, breaking later reading of the device tree post-init (such as compatible matching in modules, debugfs, and the procfs interface). Signed-off-by: James Hogan <james.hogan@imgtec.com> Reviewed-by: Vineet Gupta <vgupta@synopsys.com>
2013-03-02metag: cleanup metag_ksyms.c includesJames Hogan
Minimise metag_ksyms.c includes to directly include the <asm/*.h> files that declare a particular symbol, and not include any unnecessary ones. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move mm/init.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in mm/init.c into mm/init.c. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move usercopy.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in usercopy.c into usercopy.c Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move setup.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in setup.c into setup.c Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move kick.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in kick.c into kick.c Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move traps.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in traps.c into traps.c Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move irq enable out of irqflags.h on SMPJames Hogan
The SMP version of arch_local_irq_enable() uses preempt_disable(), but <asm/irqflags.h> doesn't include <linux/preempt.h> causing the following errors on SMP when pstore/ftrace is enabled (caught by buildbot smp allyesconfig): In file included from include/linux/irqflags.h:15, from fs/pstore/ftrace.c:16: arch/metag/include/asm/irqflags.h: In function 'arch_local_irq_enable': arch/metag/include/asm/irqflags.h:84: error: implicit declaration of function 'preempt_disable' arch/metag/include/asm/irqflags.h:86: error: implicit declaration of function 'preempt_enable_no_resched' However <linux/preempt.h> cannot be easily included from <asm/irqflags.h> as it can cause circular include dependencies in the !SMP case, and potentially in the SMP case in the future. Therefore move the SMP implementation of arch_local_irq_enable() into traps.c and use an inline version of get_trigger_mask() which is also defined in traps.c for SMP. This adds an extra layer of function call / stack push when preempt_disable needs to call other functions, however in the non-preemptive SMP case it should be about as fast, as it was already calling the get_trigger_mask() function which is now used inline. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: hugetlb: convert to vm_unmapped_area()James Hogan
Convert hugetlb_get_unmapped_area_new_pmd() to use vm_unmapped_area() rather than searching the virtual address space itself. This fixes the following errors in linux-next due to the specified members being removed after other architectures have already been converted: arch/metag/mm/hugetlbpage.c: In function 'hugetlb_get_unmapped_area_new_pmd': arch/metag/mm/hugetlbpage.c:199: error: 'struct mm_struct' has no member named 'cached_hole_size' arch/metag/mm/hugetlbpage.c:200: error: 'struct mm_struct' has no member named 'free_area_cache' arch/metag/mm/hugetlbpage.c:215: error: 'struct mm_struct' has no member named 'cached_hole_size' Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Michel Lespinasse <walken@google.com>
2013-03-02metag: export clear_page and copy_pageJames Hogan
Various file systems use clear_page() and copy_page(), so when they're built as modules we get build errors like the following: ERROR: "clear_page" [fs/ntfs/ntfs.ko] undefined! ERROR: "copy_page" [fs/nilfs2/nilfs2.ko] undefined! Therefore export these functions to modules from metag_ksyms.c to fix the errors. This was hit by a randconfig build. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: export metag_code_cache_flush_allJames Hogan
Various file systems indirectly use metag_code_cache_flush_all(), so when they're built as modules we get build errors like the following: ERROR: "metag_code_cache_flush_all" [fs/xfs/xfs.ko] undefined! Therefore export this function to modules to fix the errors. This was hit by a randconfig build. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: protect more non-MMU memory regionsJames Hogan
Rename setup_txprivext() to setup_priv() and add initialisation of some more per-thread privilege protection registers: - TxPRIVSYSR: 0x04400000-0x047fffff 0x05000000-0x07ffffff 0x84000000-0x87ffffff - TxPIOREG: 0x02000000-0x02ffffff 0x04800000-0x048fffff - TxSYREG: 0x04000000-0x04000fff (except write fetch system event) Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: make TXPRIVEXT bits explicitJames Hogan
Define PRIV_BITS using explicit constants from <asm/metag_regs.h> rather than with a hard coded value. This also adds a couple of missing definitions for the TXPRIVEXT priv bits for protecting writes to TXTIMER and the trace registers. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: kernel/setup.c: sort includesJames Hogan
Sort includes in kernel/setup.c. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: add boot time LNKGET/LNKSET checkJames Hogan
Add boot time check for whether LNKGET/LNKSET go through or around the cache. Depending on the configuration an info message (no harm), warning (technically wrong but no harm), or big WARN (expect failure in either kernel or userland) may be emitted if the behaviour is not as expected: Configuration Hardware Response ------------------------------------------ -------- -------- AROUND_CACHE through pr_info !AROUND_CACHE && ATOMICITY_LNKGET around WARN (kernel) " && !ATOMICITY_LNKGET && SMP around WARN (user) " " && !SMP around pr_warn Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: add __init to metag_cache_probe()James Hogan
metag_cache_probe() is only called from setup_arch(), so add the __init attribute to it. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Add JTAG Debug Adapter (DA) supportJames Hogan
Add basic JTAG Debug Adapter (DA) support so that drivers which communicate with the DA can detect whether one is actually present (otherwise the target will halt indefinitely). This allows the metag_da TTY driver and imgdafs filesystem driver to be built, updates defconfigs, and sets up the metag_da console early if it's configured in. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: ftrace supportJames Hogan
Add ftrace support for metag. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-02metag: PerfJames Hogan
Add Perf support for metag. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2013-03-02metag: Build infrastructureJames Hogan
Add metag build infrastructure. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Various other headersJames Hogan
Add the remaining metag header files: - byteorder.h, swab.h (byte order and swapping) - barrier.h, cpu.h. hwthread.h, processor.h (hardware thread related) - bug.h, elf.h, gpio.h, linkage.h, resource.h (other) Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Stack unwindingJames Hogan
Add stack unwinding support for metag. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Optimised library functionsJames Hogan
Add optimised library functions for metag. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: DMAJames Hogan
Add DMA mapping code. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: SMP supportJames Hogan
Add SMP support for metag. This allows Linux to take control of multiple hardware threads on a single Meta core, treating them as separate Linux CPUs. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Atomics, locks and bitopsJames Hogan
Add header files to implement Meta hardware thread locks (used by some other atomic operations), atomics, spinlocks, and bitops. There are 2 main types of atomic primitives for metag (in addition to IRQs off on UP): - LOCK instructions provide locking between hardware threads. - LNKGET/LNKSET instructions provide load-linked/store-conditional operations allowing for lighter weight atomics on Meta2 LOCK instructions allow for hardware threads to acquire voluntary or exclusive hardware thread locks: - LOCK0 releases exclusive and voluntary lock from the running hardware thread. - LOCK1 acquires the voluntary hardware lock, blocking until it becomes available. - LOCK2 implies LOCK1, and additionally acquires the exclusive hardware lock, blocking all other hardware threads from executing. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Module supportJames Hogan
2013-03-02metag: Scheduling/Process managementJames Hogan
2013-03-02metag: System CallsJames Hogan
Add metag system call and gateway page interfaces. The metag architecture port uses the generic system call numbers from asm-generic/unistd.h, as well as a user gateway page mapped at 0x6ffff000 which contains fast atomic primitives (depending on SMP) and a fast method of accessing TLS data. System calls use the SWITCH instruction with the immediate 0x440001 to signal a system call. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Internal and external irqchipsJames Hogan
Meta core internal interrupts (from HWSTATMETA and friends) are vectored onto the TR1 core trigger for the current thread. This is demultiplexed in irq-metag.c to individual Linux IRQs for each internal interrupt. External SoC interrupts (from HWSTATEXT and friends) are vectored onto the TR2 core trigger for the current thread. This is demultiplexed in irq-metag-ext.c to individual Linux IRQs for each external SoC interrupt. The external irqchip has devicetree bindings for configuring the number of irq banks and the type of masking available. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Rob Landley <rob@landley.net> Cc: Dom Cobley <popcornmix@gmail.com> Cc: Simon Arlott <simon@fire.lp0.eu> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: devicetree-discuss@lists.ozlabs.org Cc: linux-doc@vger.kernel.org
2013-03-02metag: IRQ handlingJames Hogan
Add core IRQ handling for metag. The code in irq.c exposes the TBX signal numbers as Linux IRQs. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: TrapsJames Hogan
Add trap code for metag. At the lowest level Meta traps (and return from interrupt instruction - RTI) simply swap the PC and PCX registers and optionally toggle the interrupt status bit (ISTAT). Low level TBX code in tbipcx.S handles the core context save, determine the TBX signal number based on the core trigger that fired (using the TXSTATI status register), and call TBX signal handlers (mostly in traps.c) via a vector table. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Al Viro <viro@zeniv.linux.org.uk>
2013-03-02metag: Time keepingJames Hogan
Add time keeping code for metag. Meta hardware threads have 2 timers. The background timer (TXTIMER) is used as a free-running time base, and the interrupt timer (TXTIMERI) is used for the timer interrupt. Both counters traditionally count at approximately 1MHz. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-03-02metag: ptraceJames Hogan
The ptrace interface for metag provides access to some core register sets using the PTRACE_GETREGSET and PTRACE_SETREGSET operations. The details of the internal context structures is abstracted into user API structures to both ease use and allow flexibility to change the internal context layouts. Copyin and copyout functions for these register sets are exposed to allow signal handling code to use them to copy to and from the signal context. struct user_gp_regs (NT_PRSTATUS) provides access to the core general purpose register context. struct user_cb_regs (NT_METAG_CBUF) provides access to the TXCATCH* registers which contains information abuot a memory fault, unaligned access error or watchpoint. This can be modified to alter the way the fault is replayed on resume ("catch replay"), or to prevent the replay taking place. struct user_rp_state (NT_METAG_RPIPE) provides access to the state of the Meta read pipeline which can be used to hide memory latencies in hand optimised data loops. Extended DSP register state, DSP RAM, and hardware breakpoint registers aren't yet exposed through ptrace. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Tony Lindgren <tony@atomide.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
2013-03-02metag: Device treeJames Hogan
Add device tree files to arch/metag. Signed-off-by: James Hogan <james.hogan@imgtec.com> Reviewed-by: Vineet Gupta <vgupta@synopsys.com>
2013-03-02metag: Signal handlingJames Hogan
Add signal handling code for metag. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Al Viro <viro@zeniv.linux.org.uk>
2013-03-02metag: TCM supportJames Hogan
Add some TCM support Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Highmem supportJames Hogan
2013-03-02metag: Huge TLBJames Hogan
Add huge TLB support to the metag architecture. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: Memory handlingJames Hogan
Meta has instructions for accessing: - bytes - GETB (1 byte) - words - GETW (2 bytes) - doublewords - GETD (4 bytes) - longwords - GETL (8 bytes) All accesses must be aligned. Unaligned accesses can be detected and made to fault on Meta2, however it isn't possible to fix up unaligned writes so we don't bother fixing up reads either. This patch adds metag memory handling code including: - I/O memory (io.h, ioremap.c): Actually any virtual memory can be accessed with these helpers. A part of the non-MMUable address space is used for memory mapped I/O. The ioremap() function is implemented one to one for non-MMUable addresses. - User memory (uaccess.h, usercopy.c): User memory is directly accessible from privileged code. - Kernel memory (maccess.c): probe_kernel_write() needs to be overwridden to use the I/O functions when doing a simple aligned write to non-writecombined memory, otherwise the write may be split by the generic version. Note that due to the fact that a portion of the virtual address space is non-MMUable, and therefore always maps directly to the physical address space, metag specific I/O functions are made available (metag_in32, metag_out32 etc). These cast the address argument to a pointer so that they can be used with raw physical addresses. These accessors are only to be used for accessing fixed core Meta architecture registers in the non-MMU region, and not for any SoC/peripheral registers. Signed-off-by: James Hogan <james.hogan@imgtec.com>
