commit e43b3cec711a61edf047adf6204d542f3a659ef8 upstream.
early_pci_allowed() and read_pci_config_16() are only available if
CONFIG_PCI is defined.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
commit b8f2c21db390273c3eaf0e5308faeaeb1e233840 upstream.
Update efi_call_phys_prelog to install an identity mapping of all available
memory. This corrects a bug on very large systems with more then 512 GB in
which bios would not be able to access addresses above not in the mapping.
The result is a crash that looks much like this.
BUG: unable to handle kernel paging request at 000000effd870020
IP: [<0000000078bce331>] 0x78bce330
PGD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU 0
Pid: 0, comm: swapper/0 Tainted: G W 3.8.0-rc1-next-20121224-medusa_ntz+ #2 Intel Corp. Stoutland Platform
RIP: 0010:[<0000000078bce331>] [<0000000078bce331>] 0x78bce330
RSP: 0000:ffffffff81601d28 EFLAGS: 00010006
RAX: 0000000078b80e18 RBX: 0000000000000004 RCX: 0000000000000004
RDX: 0000000078bcf958 RSI: 0000000000002400 RDI: 8000000000000000
RBP: 0000000078bcf760 R08: 000000effd870000 R09: 0000000000000000
R10: 0000000000000000 R11: 00000000000000c3 R12: 0000000000000030
R13: 000000effd870000 R14: 0000000000000000 R15: ffff88effd870000
FS: 0000000000000000(0000) GS:ffff88effe400000(0000) knlGS:0000000000000000
CR2: 000000effd870020 CR3: 000000000160c000 CR4: 00000000000006b0
Process swapper/0 (pid: 0, threadinfo ffffffff81600000, task ffffffff81614400)
Stack:
0000000078b80d18 0000000000000004 0000000078bced7b ffff880078b81fff
0000000000000000 0000000000000082 0000000078bce3a8 0000000000002400
0000000060000202 0000000078b80da0 0000000078bce45d ffffffff8107cb5a
Call Trace:
[<ffffffff8107cb5a>] ? on_each_cpu+0x77/0x83
[<ffffffff8102f4eb>] ? change_page_attr_set_clr+0x32f/0x3ed
[<ffffffff81035946>] ? efi_call4+0x46/0x80
[<ffffffff816c5abb>] ? efi_enter_virtual_mode+0x1f5/0x305
[<ffffffff816aeb24>] ? start_kernel+0x34a/0x3d2
[<ffffffff816ae5ed>] ? repair_env_string+0x60/0x60
[<ffffffff816ae2be>] ? x86_64_start_reservations+0xba/0xc1
[<ffffffff816ae120>] ? early_idt_handlers+0x120/0x120
[<ffffffff816ae419>] ? x86_64_start_kernel+0x154/0x163
Code: Bad RIP value.
RIP [<0000000078bce331>] 0x78bce330
RSP <ffffffff81601d28>
---[ end trace ead828934fef5eab ]---
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Signed-off-by: Robin Holt <holt@sgi.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit c903f0456bc69176912dee6dd25c6a66ee1aed00 upstream.
At the moment the MSR driver only relies upon file system
checks. This means that anything as root with any capability set
can write to MSRs. Historically that wasn't very interesting but
on modern processors the MSRs are such that writing to them
provides several ways to execute arbitary code in kernel space.
Sample code and documentation on doing this is circulating and
MSR attacks are used on Windows 64bit rootkits already.
In the Linux case you still need to be able to open the device
file so the impact is fairly limited and reduces the security of
some capability and security model based systems down towards
that of a generic "root owns the box" setup.
Therefore they should require CAP_SYS_RAWIO to prevent an
elevation of capabilities. The impact of this is fairly minimal
on most setups because they don't have heavy use of
capabilities. Those using SELinux, SMACK or AppArmor rules might
want to consider if their rulesets on the MSR driver could be
tighter.
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream.
Subhash Jadavani reported this partial backtrace:
Now consider this call stack from MMC block driver (this is on the ARMv7
based board):
[<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c)
[<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c)
[<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114)
This is caused by incrementing the struct page pointer, and running off
the end of the sparsemem page array. Fix this by incrementing by pfn
instead, and convert the pfn to a struct page.
Suggested-by: James Bottomley <JBottomley@Parallels.com>
Tested-by: Subhash Jadavani <subhashj@codeaurora.org>
[Based on commit c94082656dac74257f63e91f78d5d458ac781fa5 upstream, only
taking the traps.h portion.]
The traps are referred to by their numbers and it can be difficult to
understand them while reading the code without context. This patch adds
enumeration of the trap numbers and replaces the numbers with the correct
enum for x86.
Link: http://lkml.kernel.org/r/20120310000710.GA32667@www.outflux.net
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 9174adbee4a9a49d0139f5d71969852b36720809 upstream.
This fixes CVE-2013-0190 / XSA-40
There has been an error on the xen_failsafe_callback path for failed
iret, which causes the stack pointer to be wrong when entering the
iret_exc error path. This can result in the kernel crashing.
In the classic kernel case, the relevant code looked a little like:
popl %eax # Error code from hypervisor
jz 5f
addl $16,%esp
jmp iret_exc # Hypervisor said iret fault
5: addl $16,%esp
# Hypervisor said segment selector fault
Here, there are two identical addls on either option of a branch which
appears to have been optimised by hoisting it above the jz, and
converting it to an lea, which leaves the flags register unaffected.
In the PVOPS case, the code looks like:
popl_cfi %eax # Error from the hypervisor
lea 16(%esp),%esp # Add $16 before choosing fault path
CFI_ADJUST_CFA_OFFSET -16
jz 5f
addl $16,%esp # Incorrectly adjust %esp again
jmp iret_exc
It is possible unprivileged userspace applications to cause this
behaviour, for example by loading an LDT code selector, then changing
the code selector to be not-present. At this point, there is a race
condition where it is possible for the hypervisor to return back to
userspace from an interrupt, fault on its own iret, and inject a
failsafe_callback into the kernel.
This bug has been present since the introduction of Xen PVOPS support
in commit 5ead97c84 (xen: Core Xen implementation), in 2.6.23.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[not upstream as the code involved was removed in the 3.3.0 release]
Fix wii_memory_fixups() the following compile error on 3.0.y tree with
wii_defconfig on 3.0.y tree.
CC arch/powerpc/platforms/embedded6xx/wii.o
arch/powerpc/platforms/embedded6xx/wii.c: In function ‘wii_memory_fixups’:
arch/powerpc/platforms/embedded6xx/wii.c:88:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 2 has type ‘phys_addr_t’ [-Werror=format]
arch/powerpc/platforms/embedded6xx/wii.c:88:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘phys_addr_t’ [-Werror=format]
arch/powerpc/platforms/embedded6xx/wii.c:90:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 2 has type ‘phys_addr_t’ [-Werror=format]
arch/powerpc/platforms/embedded6xx/wii.c:90:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘phys_addr_t’ [-Werror=format]
cc1: all warnings being treated as errors
make[2]: *** [arch/powerpc/platforms/embedded6xx/wii.o] Error 1
make[1]: *** [arch/powerpc/platforms/embedded6xx] Error 2
make: *** [arch/powerpc/platforms] Error 2
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
commit a9acc5365dbda29f7be2884efb63771dc24bd815 upstream.
SNB graphics devices have a bug that prevent them from accessing certain
memory ranges, namely anything below 1M and in the pages listed in the
table. So reserve those at boot if set detect a SNB gfx device on the
CPU to avoid GPU hangs.
Stephane Marchesin had a similar patch to the page allocator awhile
back, but rather than reserving pages up front, it leaked them at
allocation time.
[ hpa: made a number of stylistic changes, marked arrays as static
const, and made less verbose; use "memblock=debug" for full
verbosity. ]
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: CAI Qian <caiqian@redhat.com>
commit ed4f20943cd4c7b55105c04daedf8d63ab6d499c upstream.
Converting a 64 Bit TOD format value to nanoseconds means that the value
must be divided by 4.096. In order to achieve that we multiply with 125
and divide by 512.
When used within sched_clock() this triggers an overflow after appr.
417 days. Resulting in a sched_clock() return value that is much smaller
than previously and therefore may cause all sort of weird things in
subsystems that rely on a monotonic sched_clock() behaviour.
To fix this implement a tod_to_ns() helper function which converts TOD
values without overflow and call this function from both places that
open coded the conversion: sched_clock() and kvm_s390_handle_wait().
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 4a71997a3279a339e7336ea5d0cd27282e2dea44 upstream.
Ensure that the aux table is properly initialized, even when optional features
are missing. Without this, the FDPIC loader did not work. This was meant to
be included in commit d5ab780305bb6d60a7b5a74f18cf84eb6ad153b1.
Signed-off-by: Thomas Schwinge <thomas@codesourcery.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit e43a028752fed049e4bd94ef895542f96d79fa74 upstream.
When remembering the direction of a DCR transaction, we should write
to the same variable that we interpret on later when doing vcpu_run
again.
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit 2bbf0a1427c377350f001fbc6260995334739ad7 upstream.
The Way Access Filter in recent AMD CPUs may hurt the performance of
some workloads, caused by aliasing issues in the L1 cache.
This patch disables it on the affected CPUs.
The issue is similar to that one of last year:
http://lkml.indiana.edu/hypermail/linux/kernel/1107.3/00041.html
This new patch does not replace the old one, we just need another
quirk for newer CPUs.
The performance penalty without the patch depends on the
circumstances, but is a bit less than the last year's 3%.
The workloads affected would be those that access code from the same
physical page under different virtual addresses, so different
processes using the same libraries with ASLR or multiple instances of
PIE-binaries. The code needs to be accessed simultaneously from both
cores of the same compute unit.
More details can be found here:
http://developer.amd.com/Assets/SharedL1InstructionCacheonAMD15hCPU.pdf
CPUs affected are anything with the core known as Piledriver.
That includes the new parts of the AMD A-Series (aka Trinity) and the
just released new CPUs of the FX-Series (aka Vishera).
The model numbering is a bit odd here: FX CPUs have model 2,
A-Series has model 10h, with possible extensions to 1Fh. Hence the
range of model ids.
Signed-off-by: Andre Przywara <osp@andrep.de>
Link: http://lkml.kernel.org/r/1351700450-9277-1-git-send-email-osp@andrep.de
commit ce73ec6db47af84d1466402781ae0872a9e7873c upstream.
The locking in update_vsyscall_tz() is not only unnecessary because the vdso
code copies the data unproteced in __kernel_gettimeofday() but also
introduces a hard to reproduce race condition between update_vsyscall()
and update_vsyscall_tz(), which causes user space process to loop
forever in vdso code.
The following patch removes the locking from update_vsyscall_tz().
Locking is not only unnecessary because the vdso code copies the data
unprotected in __kernel_gettimeofday() but also erroneous because updating
the tb_update_count is not atomic and introduces a hard to reproduce race
condition between update_vsyscall() and update_vsyscall_tz(), which further
causes user space process to loop forever in vdso code.
The below scenario describes the race condition,
x==0 Boot CPU other CPU
proc_P: x==0
timer interrupt
update_vsyscall
x==1 x++;sync settimeofday
update_vsyscall_tz
x==2 x++;sync
x==3 sync;x++
sync;x++
proc_P: x==3 (loops until x becomes even)
Because the ++ operator would be implemented as three instructions and not
atomic on powerpc.
A similar change was made for x86 in commit 6c260d58634
("x86: vdso: Remove bogus locking in update_vsyscall_tz")
Signed-off-by: Shan Hai <shan.hai@windriver.com>
commit 11ee7e99f35ecb15f59b21da6a82d96d2cd3fcc8 upstream.
If we build a kernel with CONFIG_RELOCATABLE=y CONFIG_CRASH_DUMP=n,
the kernel fails when we run at a non zero offset. It turns out
we were incorrectly wrapping some of the relocatable kernel code
with CONFIG_CRASH_DUMP.
commit c24bf9b4cc6a0f330ea355d73bfdf1dae7e63a05 upstream.
The inb/outb macros for CRIS are broken from a number of points of view,
missing () around parameters and they have an unprotected if statement
in them. This was breaking the compile of IPMI on CRIS and thus I was
being annoyed by build regressions, so I fixed them.
Plus I don't think they would have worked at all, since the data values
were missing "&" and the outsl had a "3" instead of a "4" for the size.
From what I can tell, this stuff is not used at all, so this can't be
any more broken than it was before, anyway.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Mikael Starvik <starvik@axis.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
commit 7bf9b7bef881aac820bf1f2e9951a17b09bd7e04 upstream.
find_vma() is *not* safe when somebody else is removing vmas. Not just
the return value might get bogus just as you are getting it (this instance
doesn't try to dereference the resulting vma), the search itself can get
buggered in rather spectacular ways. IOW, ->mmap_sem really, really is
not optional here.
commit 864aa04cd02979c2c755cb28b5f4fe56039171c0 upstream.
When updating the page protection map after calculating the user_pgprot
value, the base protection map is temporarily stored in an unsigned long
type, causing truncation of the protection bits when LPAE is enabled.
This effectively means that calls to mprotect() will corrupt the upper
page attributes, clearing the XN bit unconditionally.
This patch uses pteval_t to store the intermediate protection values,
preserving the upper bits for 64-bit descriptors.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
[ Upstream commit 6cb9c3697585c47977c42c5cc1b9fc49247ac530 ]
Modifying the huge pte's requires that all the underlying pte's be
modified.
Version 2: added missing flush_tlb_page()
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Cc: sparclinux@vger.kernel.org
range of model ids.
commit 00ca0de02f80924dfff6b4f630e1dff3db005e35 upstream.
When we update the DSCR either via emulation of mtspr(DSCR) or via
a change to dscr_default in sysfs we don't update thread.dscr.
We will eventually update it at context switch time but there is
a period where thread.dscr is incorrect.
If we fork at this point we will copy the old value of thread.dscr
into the child. To avoid this, always keep thread.dscr in sync with
reality.
This issue was found with the following testcase:
http://ozlabs.org/~anton/junkcode/dscr_inherit_test.c
Signed-off-by: Haren Myneni <haren@us.ibm.com>
commit 1b6ca2a6fe56e7697d57348646e07df08f43b1bb upstream.
Writing to dscr_default in sysfs doesn't actually change the DSCR -
we rely on a context switch on each CPU to do the work. There is no
guarantee we will get a context switch in a reasonable amount of time
so fire off an IPI to force an immediate change.
This issue was found with the following test case:
http://ozlabs.org/~anton/junkcode/dscr_explicit_test.c
commit 6acf5a8c931da9d26c8dd77d784daaf07fa2bff0 upstream.
HPET_TN_FSB is not a proper mask bit; it merely toggles between MSI and
legacy interrupt delivery. The proper mask bit is HPET_TN_ENABLE, so
use both bits when (un)masking the interrupt.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Link: http://lkml.kernel.org/r/5093E09002000078000A60E6@nat28.tlf.novell.com
commit e69b742a6793dc5bf16f6eedca534d4bc10d68b2 upstream.
gcc (rightfully) complains that we are accessing beyond the
end of the fpr array (we do, to access the fpscr).
The only sane thing to do (whether anything in that code can be
called remotely sane is debatable) is to special case fpscr and
handle it as a separate statement.
I initially tried to do it it by making the array access conditional
to index < PT_FPSCR and using a 3rd else leg but for some reason gcc
was unable to understand it and still spewed the warning.
So I ended up with something a tad more intricated but it seems to
build on 32-bit and on 64-bit with and without VSX.
Signed-off-by: Michael Neuling <mikey@neuling.org>
CONFIG_VFPv3 set
commit 39141ddfb63a664f26d3f42f64ee386e879b492c upstream.
After commit 846a136881b8f73c1f74250bf6acfaa309cab1f2 ("ARM: vfp: fix
saving d16-d31 vfp registers on v6+ kernels"), the OMAP 2430SDP board
started crashing during boot with omap2plus_defconfig:
[ 3.875122] mmcblk0: mmc0:e624 SD04G 3.69 GiB
[ 3.915954] mmcblk0: p1
[ 4.086639] Internal error: Oops - undefined instruction: 0 [#1] SMP ARM
[ 4.093719] Modules linked in:
[ 4.096954] CPU: 0 Not tainted (3.6.0-02232-g759e00b #570)
[ 4.103149] PC is at vfp_reload_hw+0x1c/0x44
[ 4.107666] LR is at __und_usr_fault_32+0x0/0x8
It turns out that the context save/restore fix unmasked a latent bug
in commit 5aaf254409f8d58229107b59507a8235b715a960 ("ARM: 6203/1: Make
VFPv3 usable on ARMv6"). When CONFIG_VFPv3 is set, but the kernel is
booted on a pre-VFPv3 core, the code attempts to save and restore the
d16-d31 VFP registers. These are only present on non-D16 VFPv3+, so
this results in an undefined instruction exception. The code didn't
crash before commit 846a136 because the save and restore code was
only touching d0-d15, present on all VFP.
Fix by implementing a request from Russell King to add a new HWCAP
flag that affirmatively indicates the presence of the d16-d31
registers:
http://marc.info/?l=linux-arm-kernel&m=135013547905283&w=2
and some feedback from Måns to clarify the name of the HWCAP flag.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Dave Martin <dave.martin@linaro.org>
Cc: Måns Rullgård <mans.rullgard@linaro.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit d356cf5a74afa32b40decca3c9dd88bc3cd63eb5 upstream.
PMU interrupts start at IRQ_DOVE_PMU_START, not IRQ_DOVE_PMU_START + 1.
Fix the condition. (It may have been less likely to occur had the code
been written "if (irq >= IRQ_DOVE_PMU_START" which imho is the easier
to understand notation, and matches the normal way of thinking about
these things.)
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit 5d3df935426271016b895aecaa247101b4bfa35e upstream.
Fix the acknowledgement of PMU interrupts on Dove: some Dove hardware
has not been sensibly designed so that interrupts can be handled in a
race free manner. The PMU is one such instance.
The pending (aka 'cause') register is a bunch of RW bits, meaning that
these bits can be both cleared and set by software (confirmed on the
Armada-510 on the cubox.)
Hardware sets the appropriate bit when an interrupt is asserted, and
software is required to clear the bits which are to be processed. If
we write ~(1 << bit), then we end up asserting every other interrupt
except the one we're processing. So, we need to do a read-modify-write
cycle to clear the asserted bit.
However, any interrupts which occur in the middle of this cycle will
also be written back as zero, which will also clear the new interrupts.
The upshot of this is: there is _no_ way to safely clear down interrupts
in this register (and other similarly behaving interrupt pending
registers on this device.) The patch below at least stops us creating
new interrupts.
commit cb57a2b4cff7edf2a4e32c0163200e9434807e0a upstream.
Modules, in particular oprofile (and possibly other similar tools)
need kernel_stack_pointer(), so export it using EXPORT_SYMBOL_GPL().
Cc: Yang Wei <wei.yang@windriver.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Jun Zhang <jun.zhang@intel.com>
Link: http://lkml.kernel.org/r/20120912135059.GZ8285@erda.amd.com
Cc: Robert Richter <rric@kernel.org>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Philip Müller <philm@manjaro.org>
throttle events in mcelog
commit 29e9bf1841e4f9df13b4992a716fece7087dd237 upstream.
Thermal throttle and power limit events are not defined as MCE errors in x86
architecture and should not generate MCE errors in mcelog.
Current kernel generates fake software defined MCE errors for these events.
This may confuse users because they may think the machine has real MCE errors
while actually only thermal throttle or power limit events happen.
To make it worse, buggy firmware on some platforms may falsely generate
the events. Therefore, kernel reports MCE errors which users think as real
hardware errors. Although the firmware bugs should be fixed, on the other hand,
kernel should not report MCE errors either.
So mcelog is not a good mechanism to report these events. To report the events, we count them in respective counters (core_power_limit_count,
package_power_limit_count, core_throttle_count, and package_throttle_count) in
/sys/devices/system/cpu/cpu#/thermal_throttle/. Users can check the counters
for each event on each CPU. Please note that all CPU's on one package report
duplicate counters. It's user application's responsibity to retrieve a package
level counter for one package.
This patch doesn't report package level power limit, core level power limit, and
package level thermal throttle events in mcelog. When the events happen, only
report them in respective counters in sysfs.
Since core level thermal throttle has been legacy code in kernel for a while and
users accepted it as MCE error in mcelog, core level thermal throttle is still
reported in mcelog. In the mean time, the event is counted in a counter in sysfs
as well.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Acked-by: Borislav Petkov <bp@amd64.org>
Acked-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/20111215001945.GA21009@linux-os.sc.intel.com
Cc: maximilian attems <max@stro.at>
commit fae2ae2a900a5c7bb385fe4075f343e7e2d5daa2 upstream.
If a signal handler is executed on altstack and another signal comes,
we will end up with rt_sigreturn() on return from the second handler
getting -EPERM from do_sigaltstack(). It's perfectly OK, since we
are not asking to change the settings; in fact, they couldn't have been
changed during the second handler execution exactly because we'd been
on altstack all along. 64bit sigreturn on sparc treats any error from
do_sigaltstack() as "SIGSEGV now"; we need to switch to the same semantics
we are using on other architectures.
commit 441a179dafc0f99fc8b3a8268eef66958621082e upstream.
int sys32_rt_sigprocmask(int how, compat_sigset_t __user *set, compat_sigset_t __user *oset,
unsigned int sigsetsize)
sigset_t old_set, new_set;
int ret;
if (set && get_sigset32(set, &new_set, sigsetsize))
static int
get_sigset32(compat_sigset_t __user *up, sigset_t *set, size_t sz)
compat_sigset_t s;
int r;
if (sz != sizeof *set) panic("put_sigset32()");
In other words, rt_sigprocmask(69, (void *)69, 69) done by 32bit process
will promptly panic the box.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 949a05d03490e39e773e8652ccab9157e6f595b4 upstream.
On Thu, 2012-11-01 at 16:45 -0700, Michel Lespinasse wrote:
> Looking at the arch/parisc/kernel/sys_parisc.c implementation of
> get_shared_area(), I do have a concern though. The function basically
> ignores the pgoff argument, so that if one creates a shared mapping of
> pages 0-N of a file, and then a separate shared mapping of pages 1-N
> of that same file, both will have the same cache offset for their
> starting address.
> This looks like this would create obvious aliasing issues. Am I
> misreading this ? I can't understand how this could work good enough
> to be undetected, so there must be something I'm missing here ???
This turns out to be correct and we need to pay attention to the pgoff as
well as the address when creating the virtual address for the area.
Fortunately, the bug is rarely triggered as most applications which use pgoff
tend to use large values (git being the primary one, and it uses pgoff in
multiples of 16MB) which are larger than our cache coherency modulus, so the
problem isn't often seen in practise.
Reported-by: Michel Lespinasse <walken@google.com>
commit 36c46ca4f322a7bf89aad5462a3a1f61713edce7 upstream.
Add valid patch size for family 16h processors.
[ hpa: promoting to urgent/stable since it is hw enabling and trivial ]
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
Acked-by: Andreas Herrmann <herrmann.der.user@googlemail.com>
Link: http://lkml.kernel.org/r/1353004910-2204-1-git-send-email-boris.ostrovsky@amd.com
commit 1022623842cb72ee4d0dbf02f6937f38c92c3f41 upstream.
In 32 bit the stack address provided by kernel_stack_pointer() may
point to an invalid range causing NULL pointer access or page faults
while in NMI (see trace below). This happens if called in softirq
context and if the stack is empty. The address at ®s->sp is then
out of range.
Fixing this by checking if regs and ®s->sp are in the same stack
context. Otherwise return the previous stack pointer stored in struct
thread_info. If that address is invalid too, return address of regs.
BUG: unable to handle kernel NULL pointer dereference at 0000000a
IP: [<c1004237>] print_context_stack+0x6e/0x8d
*pde = 00000000
Oops: 0000 [#1] SMP
Modules linked in:
Pid: 4434, comm: perl Not tainted 3.6.0-rc3-oprofile-i386-standard-g4411a05 #4 Hewlett-Packard HP xw9400 Workstation/0A1Ch
EIP: 0060:[<c1004237>] EFLAGS: 00010093 CPU: 0
EIP is at print_context_stack+0x6e/0x8d
EAX: ffffe000 EBX: 0000000a ECX: f4435f94 EDX: 0000000a
ESI: f4435f94 EDI: f4435f94 EBP: f5409ec0 ESP: f5409ea0
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
CR0: 8005003b CR2: 0000000a CR3: 34ac9000 CR4: 000007d0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
Process perl (pid: 4434, ti=f5408000 task=f5637850 task.ti=f4434000)
Stack:
000003e8 ffffe000 00001ffc f4e39b00 00000000 0000000a f4435f94 c155198c
f5409ef0 c1003723 c155198c f5409f04 00000000 f5409edc 00000000 00000000
f5409ee8 f4435f94 f5409fc4 00000001 f5409f1c c12dce1c 00000000 c155198c
Call Trace:
[<c1003723>] dump_trace+0x7b/0xa1
[<c12dce1c>] x86_backtrace+0x40/0x88
[<c12db712>] ? oprofile_add_sample+0x56/0x84
[<c12db731>] oprofile_add_sample+0x75/0x84
[<c12ddb5b>] op_amd_check_ctrs+0x46/0x260
[<c12dd40d>] profile_exceptions_notify+0x23/0x4c
[<c1395034>] nmi_handle+0x31/0x4a
[<c1029dc5>] ? ftrace_define_fields_irq_handler_entry+0x45/0x45
[<c13950ed>] do_nmi+0xa0/0x2ff
[<c13949e5>] nmi_stack_correct+0x28/0x2d
[<c1003603>] ? do_softirq+0x4b/0x7f
<IRQ>
[<c102a06f>] irq_exit+0x35/0x5b
[<c1018f56>] smp_apic_timer_interrupt+0x6c/0x7a
[<c1394746>] apic_timer_interrupt+0x2a/0x30
Code: 89 fe eb 08 31 c9 8b 45 0c ff 55 ec 83 c3 04 83 7d 10 00 74 0c 3b 5d 10 73 26 3b 5d e4 73 0c eb 1f 3b 5d f0 76 1a 3b 5d e8 73 15 <8b> 13 89 d0 89 55 e0 e8 ad 42 03 00 85 c0 8b 55 e0 75 a6 eb cc
EIP: [<c1004237>] print_context_stack+0x6e/0x8d SS:ESP 0068:f5409ea0
CR2: 000000000000000a
---[ end trace 62afee3481b00012 ]---
Kernel panic - not syncing: Fatal exception in interrupt
V2:
* add comments to kernel_stack_pointer()
* always return a valid stack address by falling back to the address
of regs
Reported-by: Yang Wei <wei.yang@windriver.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream.
The correct syntax for gcc -x is "gcc -x assembler", not
"gcc -xassembler". Even though the latter happens to work, the former
is what is documented in the manual page and thus what gcc wrappers
such as icecream do expect.
This isn't a cosmetic change. The missing space prevents icecream from
recognizing compilation tasks it can't handle, leading to silent kernel
miscompilations.
Besides me, credits go to Michael Matz and Dirk Mueller for
investigating the miscompilation issue and tracking it down to this
incorrect -x parameter syntax.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Bernhard Walle <bernhard@bwalle.de>
Cc: Michal Marek <mmarek@suse.cz>
commit 34fa78b59c52d1db3513db4c1a999db26b2e9ac2 upstream.
The sigaddset/sigdelset/sigismember functions that are implemented with
bitfield insn cannot allow the sigset argument to be placed in a data
register since the sigset is wider than 32 bits. Remove the "d"
constraint from the asm statements.
The effect of the bug is that sending RT signals does not work, the signal
number is truncated modulo 32.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit d55c4c613fc4d4ad2ba0fc6fa2b57176d420f7e4 upstream.
When walking page tables we need to make sure that everything
is within bounds of the ASCE limit of the task's address space.
Otherwise we might calculate e.g. a pud pointer which is not
within a pud and dereference it.
So check against TASK_SIZE (which is the ASCE limit) before
walking page tables.
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit f6365201d8a21fb347260f89d6e9b3e718d63c70 upstream.
The X86_32-only disable_hlt/enable_hlt mechanism was used by the
32-bit floppy driver. Its effect was to replace the use of the
HLT instruction inside default_idle() with cpu_relax() - essentially
it turned off the use of HLT.
This workaround was commented in the code as:
"disable hlt during certain critical i/o operations"
"This halt magic was a workaround for ancient floppy DMA
wreckage. It should be safe to remove."
H. Peter Anvin additionally adds:
"To the best of my knowledge, no-hlt only existed because of
flaky power distributions on 386/486 systems which were sold to
run DOS. Since DOS did no power management of any kind,
including HLT, the power draw was fairly uniform; when exposed
to the much hhigher noise levels you got when Linux used HLT
caused some of these systems to fail.
They were by far in the minority even back then."
Alan Cox further says:
"Also for the Cyrix 5510 which tended to go castors up if a HLT
occurred during a DMA cycle and on a few other boxes HLT during
DMA tended to go astray.
Do we care ? I doubt it. The 5510 was pretty obscure, the 5520
fixed it, the 5530 is probably the oldest still in any kind of
use."
So, let's finally drop this.
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Stephen Hemminger <shemminger@vyatta.com
Link: http://lkml.kernel.org/n/tip-3rhk9bzf0x9rljkv488tloib@git.kernel.org
[ If anyone cares then alternative instruction patching could be
used to replace HLT with a one-byte NOP instruction. Much simpler. ]
commit f82f64dd9f485e13f29f369772d4a0e868e5633a upstream.
Commit
844ab6f9 x86, mm: Find_early_table_space based on ranges that are actually being mapped
added back some lines back wrongly that has been removed in commit
7b16bbf97 Revert "x86/mm: Fix the size calculation of mapping tables"
remove them again.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/CAE9FiQW_vuaYQbmagVnxT2DGsYc=9tNeAbdBq53sYkitPOwxSQ@mail.gmail.com
Acked-by: Jacob Shin <jacob.shin@amd.com>
commit 844ab6f993b1d32eb40512503d35ff6ad0c57030 upstream.
Current logic finds enough space for direct mapping page tables from 0
to end. Instead, we only need to find enough space to cover mr[0].start
to mr[nr_range].end -- the range that is actually being mapped by
init_memory_mapping()
This is needed after 1bbbbe779aabe1f0768c2bf8f8c0a5583679b54a, to address
the panic reported here:
https://lkml.org/lkml/2012/10/20/160
https://lkml.org/lkml/2012/10/21/157
Signed-off-by: Jacob Shin <jacob.shin@amd.com>
Link: http://lkml.kernel.org/r/20121024195311.GB11779@jshin-Toonie
Tested-by: Tom Rini <trini@ti.com>
commit 7840487cd6298f9f931103b558290d8d98d41c49 upstream.
The i2c core driver will turn the platform device ID to busnum
When using platfrom device ID as -1, it means dynamically assigned
the busnum. When writing code, we need to make sure the busnum,
and call i2c_register_board_info(int busnum, ...) to register device
if using -1, we do not know the value of busnum
In order to solve this issue, set the platform device ID as a fix number
Here using 0 to match the busnum used in i2c_regsiter_board_info()
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
commit 5f40b909728ad784eb43aa309d3c4e9bdf050781 upstream.
When booting a secondary CPU, the primary CPU hands two sets of page
tables via the secondary_data struct:
(1) swapper_pg_dir: a normal, cacheable, shared (if SMP) mapping
of the kernel image (i.e. the tables used by init_mm).
(2) idmap_pgd: an uncached mapping of the .idmap.text ELF
section.
The idmap is generally used when enabling and disabling the MMU, which
includes early CPU boot. In this case, the secondary CPU switches to
swapper as soon as it enters C code:
struct mm_struct *mm = &init_mm;
unsigned int cpu = smp_processor_id();
* All kernel threads share the same mm context; grab a
* reference and switch to it.
atomic_inc(&mm->mm_count);
current->active_mm = mm;
cpumask_set_cpu(cpu, mm_cpumask(mm));
cpu_switch_mm(mm->pgd, mm);
This causes a problem on ARMv7, where the identity mapping is treated as
strongly-ordered leading to architecturally UNPREDICTABLE behaviour of
exclusive accesses, such as those used by atomic_inc.
This patch re-orders the secondary_start_kernel function so that we
switch to swapper before performing any exclusive accesses.
Reported-by: Gilles Chanteperdrix <gilles.chanteperdrix@xenomai.org>
Cc: David McKay <david.mckay@st.com>
[ Upstream commit 2856cc2e4d0852c3ddaae9dcb19cb9396512eb08 ]
On a 2-node machine with 256GB of ram we get 512 lines of
console output, which is just too much.
This mimicks Yinghai Lu's x86 commit c2b91e2eec9678dbda274e906cc32ea8f711da3b
(x86_64/mm: check and print vmemmap allocation continuous) except that
we aren't ever going to get contiguous block pointers in between calls
so just print when the virtual address or node changes.
This decreases the output by an order of 16.
Also demote this to KERN_DEBUG.
[ Upstream commit a27032eee8cb6e16516f13c8a9752e9d5d4cc430 ]
There are multiple errors in how sys_sparc64_personality() handles
personality flags stored in top three bytes.
- directly comparing current->personality against PER_LINUX32 doesn't work
in cases when any of the personality flags stored in the top three bytes
are used.
- directly forcefully setting personality to PER_LINUX32 or PER_LINUX
discards any flags stored in the top three bytes
Fix the first one by properly using personality() macro to compare only
PER_MASK bytes.
Fix the second one by setting only the bits that should be set, instead of
overwriting the whole value.
[ Upstream commit e793d8c6740f8fe704fa216e95685f4d92c4c4b9 ]
There was a serious disconnect in the logic happening in
sparc_pmu_disable_event() vs. sparc_pmu_enable_event().
Event disable is implemented by programming a NOP event into the PCR.
However, event enable was not reversing this operation. Instead, it
was setting the User/Priv/Hypervisor trace enable bits.
That's not sparc_pmu_enable_event()'s job, that's what
sparc_pmu_enable() and sparc_pmu_disable() do .
The intent of sparc_pmu_enable_event() is clear, since it first clear
out the event type encoding field. So fix this by OR'ing in the event
encoding rather than the trace enable bits.
[ Upstream commit 08280e6c4c2e8049ac61d9e8e3536ec1df629c0d ]
If the MM is not active, only report the top-level PC. Do not try to
access the address space.
[ Upstream commit 55c2770e413e96871147b9406a9c41fe9bc5209c ]
we want syscall_trace_leave() called on exit from any syscall;
skipping its call in case we'd done force_successful_syscall_return()
is broken...
commit a349e23d1cf746f8bdc603dcc61fae9ee4a695f6 upstream.
In 32 bit guests, if a userspace process has %eax == -ERESTARTSYS
(-512) or -ERESTARTNOINTR (-513) when it is interrupted by an event
/and/ the process has a pending signal then %eip (and %eax) are
corrupted when returning to the main process after handling the
signal. The application may then crash with SIGSEGV or a SIGILL or it
may have subtly incorrect behaviour (depending on what instruction it
returned to).
The occurs because handle_signal() is incorrectly thinking that there
is a system call that needs to restarted so it adjusts %eip and %eax
to re-execute the system call instruction (even though user space had
not done a system call).
If %eax == -514 (-ERESTARTNOHAND (-514) or -ERESTART_RESTARTBLOCK
(-516) then handle_signal() only corrupted %eax (by setting it to
-EINTR). This may cause the application to crash or have incorrect
behaviour.
handle_signal() assumes that regs->orig_ax >= 0 means a system call so
any kernel entry point that is not for a system call must push a
negative value for orig_ax. For example, for physical interrupts on
bare metal the inverse of the vector is pushed and page_fault() sets
regs->orig_ax to -1, overwriting the hardware provided error code.
xen_hypervisor_callback() was incorrectly pushing 0 for orig_ax
instead of -1.
Classic Xen kernels pushed %eax which works as %eax cannot be both
non-negative and -RESTARTSYS (etc.), but using -1 is consistent with
other non-system call entry points and avoids some of the tests in
handle_signal().
There were similar bugs in xen_failsafe_callback() of both 32 and
64-bit guests. If the fault was corrected and the normal return path
was used then 0 was incorrectly pushed as the value for orig_ax.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Jan Beulich <JBeulich@suse.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
mapping.
commit 1bbbbe779aabe1f0768c2bf8f8c0a5583679b54a upstream.
On systems with very large memory (1 TB in our case), BIOS may report a
reserved region or a hole in the E820 map, even above the 4 GB range. Exclude
these from the direct mapping.
[ hpa: this should be done not just for > 4 GB but for everything above the legacy
region (1 MB), at the very least. That, however, turns out to require significant
restructuring. That work is well underway, but is not suitable for rc/stable. ]
Link: http://lkml.kernel.org/r/1319145326-13902-1-git-send-email-jacob.shin@amd.com
commit 44009105081b51417f311f4c3be0061870b6b8ed upstream.
The "event" variable is a u16 so the shift will always wrap to zero
making the line a no-op.
commit 627072b06c362bbe7dc256f618aaa63351f0cfe6 upstream.
The tile tool chain uses the .eh_frame information for backtracing.
The vmlinux build drops any .eh_frame sections at link time, but when
present in kernel modules, it causes a module load failure due to the
presence of unsupported pc-relative relocations. When compiling to
use compiler feedback support, the compiler by default omits .eh_frame
information, so we don't see this problem. But when not using feedback,
we need to explicitly suppress the .eh_frame.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
