commit e68503bd6836ba765dc8e0ee77ea675fedc07e41 upstream
Generalise system_verify_data() to provide access to internal content
through a callback. This allows all the PKCS#7 stuff to be hidden inside
this function and removed from the PE file parser and the PKCS#7 test key.
If external content is not required, NULL should be passed as data to the
function. If the callback is not required, that can be set to NULL.
The function is now called verify_pkcs7_signature() to contrast with
verify_pefile_signature() and the definitions of both have been moved into
linux/verification.h along with the key_being_used_for enum.
Tune Colibri VF SoM defconfig for backports-5.4.
Related-to: ELB-2724
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This is the 4.4.220 stable release
commit e78e5a91456fcecaa2efbb3706572fe043766f4d upstream.
In the __getcpu function, lsl is using the wrong target and destination
registers. Luckily, the compiler tends to choose %eax for both variables,
so it has been working so far.
Fixes: a582c540ac1b ("x86/vdso: Use RDPID in preference to LSL when available")
Signed-off-by: Samuel Neves <sneves@dei.uc.pt>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20180901201452.27828-1-sneves@dei.uc.pt
Signed-off-by: Nobuhiro Iwamatsu (CIP) <nobuhiro1.iwamatsu@toshiba.co.jp>
On Intel it is required to do CPUID(1) before reading the microcode
revision MSR. Current code in 4.4 an 4.9 relies on sync_core() to call
CPUID, unfortunately on 32 bit machines code inside sync_core() always
jumps past CPUID instruction as it depends on data structure boot_cpu_data
witch are not populated correctly so early in boot sequence.
It depends on:
commit 5dedade6dfa2 ("x86/CPU: Add native CPUID variants returning a single
datum")
This patch is for 4.4 but also should apply to 4.9
Signed-off-by: Evalds Iodzevics <evalds.iodzevics@gmail.com>
commit 5dedade6dfa243c130b85d1e4daba6f027805033 upstream.
... similarly to the cpuid_<reg>() variants.
Link: http://lkml.kernel.org/r/20170109114147.5082-2-bp@alien8.de
Cc: Evalds Iodzevics <evalds.iodzevics@gmail.com>
The fast SYSCALL exit path returns with SYSRET to userspace after
verifying that there's no pending work. MDS mitigation mandates that CPU
buffers must be cleared on transition from kernel to userspace so do
that here too.
commit 396d2e878f92ec108e4293f1c77ea3bc90b414ff upstream.
The host reports support for the synthetic feature X86_FEATURE_SSBD
when any of the three following hardware features are set:
CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31]
CPUID.80000008H:EBX.AMD_SSBD[bit 24]
CPUID.80000008H:EBX.VIRT_SSBD[bit 25]
Either of the first two hardware features implies the existence of the
IA32_SPEC_CTRL MSR, but CPUID.80000008H:EBX.VIRT_SSBD[bit 25] does
not. Therefore, CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31] should only be
set in the guest if CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31] or
CPUID.80000008H:EBX.AMD_SSBD[bit 24] is set on the host.
Fixes: 0c54914d0c52a ("KVM: x86: use Intel speculation bugs and features as derived in generic x86 code")
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Jacob Xu <jacobhxu@google.com>
Reviewed-by: Peter Shier <pshier@google.com>
Reported-by: Eric Biggers <ebiggers@kernel.org>
[bwh: Backported to 4.x: adjust indentation]
[ Upstream commit aa4113340ae6c2811e046f08c2bc21011d20a072 ]
In the current implementation, the call to loadcam_multi() is wrapped
between switch_to_as1() and restore_to_as0() calls so, when it tries
to create its own temporary AS=1 TLB1 entry, it ends up duplicating
the existing one created by switch_to_as1(). Add a check to skip
creating the temporary entry if already running in AS=1.
Fixes: d9e1831a4202 ("powerpc/85xx: Load all early TLB entries at once")
Cc: stable@vger.kernel.org # v4.4+
Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com>
Acked-by: Scott Wood <oss@buserror.net>
Link: https://lore.kernel.org/r/20200123111914.2565-1-laurentiu.tudor@nxp.com
commit c7def7fbdeaa25feaa19caf4a27c5d10bd8789e4 upstream.
In restore_tm_sigcontexts() we take the trap value directly from the
user sigcontext with no checking:
err |= __get_user(regs->trap, &sc->gp_regs[PT_TRAP]);
This means we can be in the kernel with an arbitrary regs->trap value.
Although that's not immediately problematic, there is a risk we could
trigger one of the uses of CHECK_FULL_REGS():
#define CHECK_FULL_REGS(regs) BUG_ON(regs->trap & 1)
It can also cause us to unnecessarily save non-volatile GPRs again in
save_nvgprs(), which shouldn't be problematic but is still wrong.
It's also possible it could trick the syscall restart machinery, which
relies on regs->trap not being == 0xc00 (see 9a81c16b5275 ("powerpc:
fix double syscall restarts")), though I haven't been able to make
that happen.
Finally it doesn't match the behaviour of the non-TM case, in
restore_sigcontext() which zeroes regs->trap.
So change restore_tm_sigcontexts() to zero regs->trap.
This was discovered while testing Nick's upcoming rewrite of the
syscall entry path. In that series the call to save_nvgprs() prior to
signal handling (do_notify_resume()) is removed, which leaves the
low-bit of regs->trap uncleared which can then trigger the FULL_REGS()
WARNs in setup_tm_sigcontexts().
Fixes: 2b0a576d15e0 ("powerpc: Add new transactional memory state to the signal context")
Cc: stable@vger.kernel.org # v3.9+
Link: https://lore.kernel.org/r/20200401023836.3286664-1-mpe@ellerman.id.au
commit 6c7c851f1b666a8a455678a0b480b9162de86052 upstream.
Show the full diag statistic table and not just parts of it.
The issue surfaced in a KVM guest with a number of vcpus
defined smaller than NR_DIAG_STAT.
Fixes: 1ec2772e0c3c ("s390/diag: add a statistic for diagnose calls")
Signed-off-by: Michael Mueller <mimu@linux.ibm.com>
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
commit fc2266011accd5aeb8ebc335c381991f20e26e33 upstream.
For thumb instructions, call_undef_hook() in traps.c first reads a u16,
and if the u16 indicates a T32 instruction (u16 >= 0xe800), a second
u16 is read, which then makes up the the lower half-word of a T32
instruction. For T16 instructions, the second u16 is not read,
which makes the resulting u32 opcode always have the upper half set to
0.
However, having the upper half of instr_mask in the undef_hook set to 0
masks out the upper half of all thumb instructions - both T16 and T32.
This results in trapped T32 instructions with the lower half-word equal
to the T16 encoding of setend (b650) being matched, even though the upper
half-word is not 0000 and thus indicates a T32 opcode.
An example of such a T32 instruction is eaa0b650, which should raise a
SIGILL since T32 instructions with an eaa prefix are unallocated as per
Arm ARM, but instead works as a SETEND because the second half-word is set
to b650.
This patch fixes the issue by extending instr_mask to include the
upper u32 half, which will still match T16 instructions where the upper
half is 0, but not T32 instructions.
Fixes: 2d888f48e056 ("arm64: Emulate SETEND for AArch32 tasks")
Cc: <stable@vger.kernel.org> # 4.0.x-
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Fredrik Strupe <fredrik@strupe.net>
commit edd4fa37baa6ee8e44dc65523b27bd6fe44c94de upstream.
Reallocate a rmap array and recalcuate large page compatibility when
moving an existing memslot to correctly handle the alignment properties
of the new memslot. The number of rmap entries required at each level
is dependent on the alignment of the memslot's base gfn with respect to
that level, e.g. moving a large-page aligned memslot so that it becomes
unaligned will increase the number of rmap entries needed at the now
unaligned level.
Not updating the rmap array is the most obvious bug, as KVM accesses
garbage data beyond the end of the rmap. KVM interprets the bad data as
pointers, leading to non-canonical #GPs, unexpected #PFs, etc...
general protection fault: 0000 [#1] SMP
CPU: 0 PID: 1909 Comm: move_memory_reg Not tainted 5.4.0-rc7+ #139
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 0.0.0 02/06/2015
RIP: 0010:rmap_get_first+0x37/0x50 [kvm]
Code: <48> 8b 3b 48 85 ff 74 ec e8 6c f4 ff ff 85 c0 74 e3 48 89 d8 5b c3
RSP: 0018:ffffc9000021bbc8 EFLAGS: 00010246
RAX: ffff00617461642e RBX: ffff00617461642e RCX: 0000000000000012
RDX: ffff88827400f568 RSI: ffffc9000021bbe0 RDI: ffff88827400f570
RBP: 0010000000000000 R08: ffffc9000021bd00 R09: ffffc9000021bda8
R10: ffffc9000021bc48 R11: 0000000000000000 R12: 0030000000000000
R13: 0000000000000000 R14: ffff88827427d700 R15: ffffc9000021bce8
FS: 00007f7eda014700(0000) GS:ffff888277a00000(0000) knlGS:0000000000000000
CR2: 00007f7ed9216ff8 CR3: 0000000274391003 CR4: 0000000000162eb0
Call Trace:
kvm_mmu_slot_set_dirty+0xa1/0x150 [kvm]
__kvm_set_memory_region.part.64+0x559/0x960 [kvm]
kvm_set_memory_region+0x45/0x60 [kvm]
kvm_vm_ioctl+0x30f/0x920 [kvm]
do_vfs_ioctl+0xa1/0x620
ksys_ioctl+0x66/0x70
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x4c/0x170
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x7f7ed9911f47
Code: <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 21 6f 2c 00 f7 d8 64 89 01 48
RSP: 002b:00007ffc00937498 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 0000000001ab0010 RCX: 00007f7ed9911f47
RDX: 0000000001ab1350 RSI: 000000004020ae46 RDI: 0000000000000004
RBP: 000000000000000a R08: 0000000000000000 R09: 00007f7ed9214700
R10: 00007f7ed92149d0 R11: 0000000000000246 R12: 00000000bffff000
R13: 0000000000000003 R14: 00007f7ed9215000 R15: 0000000000000000
Modules linked in: kvm_intel kvm irqbypass
---[ end trace 0c5f570b3358ca89 ]---
The disallow_lpage tracking is more subtle. Failure to update results
in KVM creating large pages when it shouldn't, either due to stale data
or again due to indexing beyond the end of the metadata arrays, which
can lead to memory corruption and/or leaking data to guest/userspace.
Note, the arrays for the old memslot are freed by the unconditional call
to kvm_free_memslot() in __kvm_set_memory_region().
Fixes: 05da45583de9b ("KVM: MMU: large page support")
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
Reviewed-by: Peter Xu <peterx@redhat.com>
commit 3d51507f29f2153a658df4a0674ec5b592b62085 upstream.
All exception entry points must have ASM_CLAC right at the
beginning. The general_protection entry is missing one.
Fixes: e59d1b0a2419 ("x86-32, smap: Add STAC/CLAC instructions to 32-bit kernel entry")
Reviewed-by: Frederic Weisbecker <frederic@kernel.org>
Reviewed-by: Alexandre Chartre <alexandre.chartre@oracle.com>
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Link: https://lkml.kernel.org/r/20200225220216.219537887@linutronix.de
commit 792a402c2840054533ef56279c212ef6da87d811 upstream.
There is a potential NULL pointer dereference in case kzalloc()
fails and returns NULL.
Fix this by adding a NULL check on *cd*
This bug was detected with the help of Coccinelle.
Fixes: 64b139f97c01 ("MIPS: OCTEON: irq: add CIB and other fixes")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
commit ecb9c790999fd6c5af0f44783bd0217f0b89ec2b upstream.
The value in "new" is constructed from "old" such that all bits defined
as reserved by the ACPI spec[1] are left untouched. But if those bits
do not happen to be all zero, "new < 3" will not evaluate to true.
The firmware of the laptop(s) Medion MD63490 / Akoya P15648 comes with
garbage inside the "FACS" ACPI table. The starting value is
old=0x4944454d, therefore new=0x4944454e, which is >= 3. Mask off
the reserved bits.
[1] https://uefi.org/sites/default/files/resources/ACPI_6_2.pdf
Link: https://bugzilla.kernel.org/show_bug.cgi?id=206553
Cc: All applicable <stable@vger.kernel.org>
Signed-off-by: Jan Engelhardt <jengelh@inai.de>
[ Upstream commit 81a34892c2c7c809f9c4e22c5ac936ae673fb9a2 ]
The load address is compared with LOAD_PHYSICAL_ADDR using a signed
comparison currently (using jge instruction).
When loading a 64-bit kernel using the new efi32_pe_entry() point added by:
97aa276579b2 ("efi/x86: Add true mixed mode entry point into .compat section")
using Qemu with -m 3072, the firmware actually loads us above 2Gb,
resulting in a very early crash.
Use the JAE instruction to perform a unsigned comparison instead, as physical
addresses should be considered unsigned.
Signed-off-by: Arvind Sankar <nivedita@alum.mit.edu>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Link: https://lore.kernel.org/r/20200301230436.2246909-6-nivedita@alum.mit.edu
Link: https://lore.kernel.org/r/20200308080859.21568-14-ardb@kernel.org
[ Upstream commit c4409905cd6eb42cfd06126e9226b0150e05a715 ]
Re-execution after an emulation decode failure is only intended to
handle a case where two or vCPUs race to write a shadowed page, i.e.
we should never re-execute an instruction as part of MMIO emulation.
As handle_ept_misconfig() is only used for MMIO emulation, it should
pass EMULTYPE_NO_REEXECUTE when using the emulator to skip an instr
in the fast-MMIO case where VM_EXIT_INSTRUCTION_LEN is invalid.
And because the cr2 value passed to x86_emulate_instruction() is only
destined for use when retrying or reexecuting, we can simply call
emulate_instruction().
Fixes: d391f1207067 ("x86/kvm/vmx: do not use vm-exit instruction length
for fast MMIO when running nested")
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit d0bab0c39e32d39a8c5cddca72e5b4a3059fe050 upstream.
On a system with only one CPU online, when another one CPU panics while
starting-up, smp_send_stop() will fail to send any STOP message to the
other already online core, resulting in a system still responsive and
alive at the end of the panic procedure.
[ 186.700083] CPU3: shutdown
[ 187.075462] CPU2: shutdown
[ 187.162869] CPU1: shutdown
[ 188.689998] ------------[ cut here ]------------
[ 188.691645] kernel BUG at arch/arm64/kernel/cpufeature.c:886!
[ 188.692079] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 188.692444] Modules linked in:
[ 188.693031] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.6.0-rc4-00001-g338d25c35a98 #104
[ 188.693175] Hardware name: Foundation-v8A (DT)
[ 188.693492] pstate: 200001c5 (nzCv dAIF -PAN -UAO)
[ 188.694183] pc : has_cpuid_feature+0xf0/0x348
[ 188.694311] lr : verify_local_elf_hwcaps+0x84/0xe8
[ 188.694410] sp : ffff800011b1bf60
[ 188.694536] x29: ffff800011b1bf60 x28: 0000000000000000
[ 188.694707] x27: 0000000000000000 x26: 0000000000000000
[ 188.694801] x25: 0000000000000000 x24: ffff80001189a25c
[ 188.694905] x23: 0000000000000000 x22: 0000000000000000
[ 188.694996] x21: ffff8000114aa018 x20: ffff800011156a38
[ 188.695089] x19: ffff800010c944a0 x18: 0000000000000004
[ 188.695187] x17: 0000000000000000 x16: 0000000000000000
[ 188.695280] x15: 0000249dbde5431e x14: 0262cbe497efa1fa
[ 188.695371] x13: 0000000000000002 x12: 0000000000002592
[ 188.695472] x11: 0000000000000080 x10: 00400032b5503510
[ 188.695572] x9 : 0000000000000000 x8 : ffff800010c80204
[ 188.695659] x7 : 00000000410fd0f0 x6 : 0000000000000001
[ 188.695750] x5 : 00000000410fd0f0 x4 : 0000000000000000
[ 188.695836] x3 : 0000000000000000 x2 : ffff8000100939d8
[ 188.695919] x1 : 0000000000180420 x0 : 0000000000180480
[ 188.696253] Call trace:
[ 188.696410] has_cpuid_feature+0xf0/0x348
[ 188.696504] verify_local_elf_hwcaps+0x84/0xe8
[ 188.696591] check_local_cpu_capabilities+0x44/0x128
[ 188.696666] secondary_start_kernel+0xf4/0x188
[ 188.697150] Code: 52805001 72a00301 6b01001f 54000ec0 (d4210000)
[ 188.698639] ---[ end trace 3f12ca47652f7b72 ]---
[ 188.699160] Kernel panic - not syncing: Attempted to kill the idle task!
[ 188.699546] Kernel Offset: disabled
[ 188.699828] CPU features: 0x00004,20c02008
[ 188.700012] Memory Limit: none
[ 188.700538] ---[ end Kernel panic - not syncing: Attempted to kill the idle task! ]---
[root@arch ~]# echo Helo
Helo
[root@arch ~]# cat /proc/cpuinfo | grep proce
processor : 0
Make smp_send_stop() account also for the online status of the calling CPU
while evaluating how many CPUs are effectively online: this way, the right
number of STOPs is sent, so enforcing a proper freeze of the system at the
end of panic even under the above conditions.
Fixes: 08e875c16a16c ("arm64: SMP support")
Reported-by: Dave Martin <Dave.Martin@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Cristian Marussi <cristian.marussi@arm.com>
Signed-off-by: Will Deacon <will@kernel.org>
commit 763802b53a427ed3cbd419dbba255c414fdd9e7c upstream.
Commit 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in
__purge_vmap_area_lazy()") introduced a call to vmalloc_sync_all() in
the vunmap() code-path. While this change was necessary to maintain
correctness on x86-32-pae kernels, it also adds additional cycles for
architectures that don't need it.
Specifically on x86-64 with CONFIG_VMAP_STACK=y some people reported
severe performance regressions in micro-benchmarks because it now also
calls the x86-64 implementation of vmalloc_sync_all() on vunmap(). But
the vmalloc_sync_all() implementation on x86-64 is only needed for newly
created mappings.
To avoid the unnecessary work on x86-64 and to gain the performance
back, split up vmalloc_sync_all() into two functions:
* vmalloc_sync_mappings(), and
* vmalloc_sync_unmappings()
Most call-sites to vmalloc_sync_all() only care about new mappings being
synchronized. The only exception is the new call-site added in the
above mentioned commit.
Shile Zhang directed us to a report of an 80% regression in reaim
throughput.
Fixes: 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()")
Reported-by: kernel test robot <oliver.sang@intel.com>
Reported-by: Shile Zhang <shile.zhang@linux.alibaba.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Tested-by: Borislav Petkov <bp@suse.de>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [GHES]
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Link: http://lkml.kernel.org/r/20191009124418.8286-1-joro@8bytes.org
Link: https://lists.01.org/hyperkitty/list/lkp@lists.01.org/thread/4D3JPPHBNOSPFK2KEPC6KGKS6J25AIDB/
Link: http://lkml.kernel.org/r/20191113095530.228959-1-shile.zhang@linux.alibaba.com
[ Upstream commit 27f13774654ea6bd0b6fc9b97cce8d19e5735661 ]
'dma-ranges' in a PCI bridge node does correctly set dma masks for PCI
devices not described in the DT. Certain DRA7 platforms (e.g., DRA76)
has RAM above 32-bit boundary (accessible with LPAE config) though the
PCIe bridge will be able to access only 32-bits. Add 'dma-ranges'
property in PCIe RC DT nodes to indicate the host bridge can access
only 32 bits.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
[ Upstream commit cb0cc635c7a9fa8a3a0f75d4d896721819c63add ]
Selecting CONFIG_DEBUG_INFO_BTF results in the below warning from ld:
ld: warning: orphan section `.BTF' from `.btf.vmlinux.bin.o' being placed in section `.BTF'
Include .BTF section in vmlinux explicitly to fix the same.
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Link: https://lore.kernel.org/r/20200220113132.857132-1-naveen.n.rao@linux.vnet.ibm.com
This is the 4.4.217 stable release
commit f87b1c49bc675da30d8e1e8f4b60b800312c7b90 upstream.
When the uaccess .fixup section was renamed to .text.fixup, one case was
missed. Under ld.bfd, the orphaned section was moved close to .text
(since they share the "ax" bits), so things would work normally on
uaccess faults. Under ld.lld, the orphaned section was placed outside
the .text section, making it unreachable.
Link: https://github.com/ClangBuiltLinux/linux/issues/282
Link: https://bugs.chromium.org/p/chromium/issues/detail?id=1020633#c44
Link: https://lore.kernel.org/r/nycvar.YSQ.7.76.1912032147340.17114@knanqh.ubzr
Link: https://lore.kernel.org/lkml/202002071754.F5F073F1D@keescook/
Fixes: c4a84ae39b4a5 ("ARM: 8322/1: keep .text and .fixup regions closer together")
Reviewed-by: Ard Biesheuvel <ardb@kernel.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 45939ce292b4b11159719faaf60aba7d58d5fe33 upstream.
It is possible for a system with an ARMv8 timer to run a 32-bit kernel.
When this happens we will unconditionally have the vDSO code remove the
__vdso_gettimeofday and __vdso_clock_gettime symbols because
cntvct_functional() returns false since it does not match that
compatibility string.
Fixes: ecf99a439105 ("ARM: 8331/1: VDSO initialization, mapping, and synchronization")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit f967140dfb7442e2db0868b03b961f9c59418a1b ]
Enable the sampling check in kernel/events/core.c::perf_event_open(),
which returns the more appropriate -EOPNOTSUPP.
BEFORE:
$ sudo perf record -a -e instructions,l3_request_g1.caching_l3_cache_accesses true
Error:
The sys_perf_event_open() syscall returned with 22 (Invalid argument) for event (l3_request_g1.caching_l3_cache_accesses).
/bin/dmesg | grep -i perf may provide additional information.
With nothing relevant in dmesg.
AFTER:
Error:
l3_request_g1.caching_l3_cache_accesses: PMU Hardware doesn't support sampling/overflow-interrupts. Try 'perf stat'
Fixes: c43ca5091a37 ("perf/x86/amd: Add support for AMD NB and L2I "uncore" counters")
Signed-off-by: Kim Phillips <kim.phillips@amd.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: https://lkml.kernel.org/r/20200311191323.13124-1-kim.phillips@amd.com
commit 8d92e992a785f35d23f845206cf8c6cafbc264e0 upstream.
The default defintions use fill pattern 0x90 for padding which for ARC
generates unintended "ldh_s r12,[r0,0x20]" corresponding to opcode 0x9090
So use ".align 4" which insert a "nop_s" instruction instead.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 342993f96ab24d5864ab1216f46c0b199c2baf8e upstream.
After commit 07721feee46b ("KVM: nVMX: Don't emulate instructions in guest
mode") Hyper-V guests on KVM stopped booting with:
kvm_nested_vmexit: rip fffff802987d6169 reason EPT_VIOLATION info1 181
info2 0 int_info 0 int_info_err 0
kvm_page_fault: address febd0000 error_code 181
kvm_emulate_insn: 0:fffff802987d6169: f3 a5
kvm_emulate_insn: 0:fffff802987d6169: f3 a5 FAIL
kvm_inj_exception: #UD (0x0)
"f3 a5" is a "rep movsw" instruction, which should not be intercepted
at all. Commit c44b4c6ab80e ("KVM: emulate: clean up initializations in
init_decode_cache") reduced the number of fields cleared by
init_decode_cache() claiming that they are being cleared elsewhere,
'intercept', however, is left uncleared if the instruction does not have
any of the "slow path" flags (NotImpl, Stack, Op3264, Sse, Mmx, CheckPerm,
NearBranch, No16 and of course Intercept itself).
Fixes: c44b4c6ab80e ("KVM: emulate: clean up initializations in init_decode_cache")
Fixes: 07721feee46b ("KVM: nVMX: Don't emulate instructions in guest mode")
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Reviewed-by: Sean Christopherson <sean.j.christopherson@intel.com>
commit fc37a1632d40c80c067eb1bc235139f5867a2667 upstream.
PowerVM systems running compatibility mode on a few Power8 revisions are
still vulnerable to the hardware defect that loses PMU exceptions arriving
prior to a context switch.
The software fix for this issue is enabled through the CPU_FTR_PMAO_BUG
cpu_feature bit, nevertheless this bit also needs to be set for PowerVM
compatibility mode systems.
Fixes: 68f2f0d431d9ea4 ("powerpc: Add a cpu feature CPU_FTR_PMAO_BUG")
Signed-off-by: Desnes A. Nunes do Rosario <desnesn@linux.ibm.com>
Reviewed-by: Leonardo Bras <leonardo@linux.ibm.com>
Link: https://lore.kernel.org/r/20200227134715.9715-1-desnesn@linux.ibm.com
commit 512a928affd51c2dc631401e56ad5ee5d5dd68b6 upstream.
This function is not only needed by the platform suspend code, but is also
reused as the CPU resume function when the ARM cores can be powered down
completely in deep idle, which is the case on i.MX6SX and i.MX6UL(L).
Providing the static inline stub whenever CONFIG_SUSPEND is disabled means
that those platforms will hang on resume from cpuidle if suspend is disabled.
So there are two problems:
- The static inline stub masks the linker error
- The function is not available where needed
Fix both by just building the function unconditionally, when
CONFIG_SOC_IMX6 is enabled. The actual code is three instructions long,
so it's arguably ok to just leave it in for all i.MX6 kernel configurations.
Fixes: 05136f0897b5 ("ARM: imx: support arm power off in cpuidle for i.mx6sx")
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Ahmad Fatoum <a.fatoum@pengutronix.de>
Signed-off-by: Rouven Czerwinski <r.czerwinski@pengutronix.de>
commit 8fde12ca79aff9b5ba951fce1a2641901b8d8e64 upstream.
If the page refcount wraps around past zero, it will be freed while
there are still four billion references to it. One of the possible
avenues for an attacker to try to make this happen is by doing direct IO
on a page multiple times. This patch makes get_user_pages() refuse to
take a new page reference if there are already more than two billion
references to the page.
Reported-by: Jann Horn <jannh@google.com>
Acked-by: Matthew Wilcox <willy@infradead.org>
Cc: stable@kernel.org
[ 4.4.y backport notes:
Ajay: - Added local variable 'err' with-in follow_hugetlb_page()
from 2be7cfed995e, to resolve compilation error
- Added page_ref_count()
- Added missing refcount overflow checks on x86 and s390
(Vlastimil, thanks for this change)
Srivatsa: - Replaced call to get_page_foll() with try_get_page_foll() ]
Signed-off-by: Srivatsa S. Bhat (VMware) <srivatsa@csail.mit.edu>
Signed-off-by: Ajay Kaher <akaher@vmware.com>
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
commit bef8e2dfceed6daeb6ca3e8d33f9c9d43b926580 upstream.
Pointer on the memory allocated by 'alloc_progmem()' is stored in
'v->load_addr'. So this is this memory that should be freed by
'release_progmem()'.
'release_progmem()' is only a call to 'kfree()'.
With the current code, there is both a double free and a memory leak.
Fix it by passing the correct pointer to 'release_progmem()'.
Fixes: e01402b115ccc ("More AP / SP bits for the 34K, the Malta bits and things. Still wants")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Paul Burton <paulburton@kernel.org>
Cc: ralf@linux-mips.org
Cc: linux-mips@vger.kernel.org
Cc: kernel-janitors@vger.kernel.org
commit 23520b2def95205f132e167cf5b25c609975e959 upstream.
When pv_eoi_get_user() fails, 'val' may remain uninitialized and the return
value of pv_eoi_get_pending() becomes random. Fix the issue by initializing
the variable.
Reviewed-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: Miaohe Lin <linmiaohe@huawei.com>
commit 35a571346a94fb93b5b3b6a599675ef3384bc75c upstream.
Consult the 'unconditional IO exiting' and 'use IO bitmaps' VM-execution
controls when checking instruction interception. If the 'use IO bitmaps'
VM-execution control is 1, check the instruction access against the IO
bitmaps to determine if the instruction causes a VM-exit.
Signed-off-by: Oliver Upton <oupton@google.com>
commit e71237d3ff1abf9f3388337cfebf53b96df2020d upstream.
Checks against the IO bitmap are useful for both instruction emulation
and VM-exit reflection. Refactor the IO bitmap checks into a helper
function.
[ Upstream commit 07721feee46b4b248402133228235318199b05ec ]
vmx_check_intercept is not yet fully implemented. To avoid emulating
instructions disallowed by the L1 hypervisor, refuse to emulate
instructions by default.
[Made commit, added commit msg - Oliver]
commit 51dede9c05df2b78acd6dcf6a17d21f0877d2d7b upstream.
Accessing the MCA thresholding controls in sysfs concurrently with CPU
hotplug can lead to a couple of KASAN-reported issues:
BUG: KASAN: use-after-free in sysfs_file_ops+0x155/0x180
Read of size 8 at addr ffff888367578940 by task grep/4019
and
BUG: KASAN: use-after-free in show_error_count+0x15c/0x180
Read of size 2 at addr ffff888368a05514 by task grep/4454
for example. Both result from the fact that the threshold block
creation/teardown code frees the descriptor memory itself instead of
defining proper ->release function and leaving it to the driver core to
take care of that, after all sysfs accesses have completed.
Do that and get rid of the custom freeing code, fixing the above UAFs in
the process.
[ bp: write commit message. ]
Fixes: 95268664390b ("[PATCH] x86_64: mce_amd support for family 0x10 processors")
Link: https://lkml.kernel.org/r/20200214082801.13836-1-bp@alien8.de
[ Upstream commit 061d2c1d593076424c910cb1b64ecdb5c9a6923f ]
In case the start + cache size is more than the max int the
start overflows.
Prevent the same.
Signed-off-by: Shubhrajyoti Datta <shubhrajyoti.datta@xilinx.com>
[ Upstream commit 76950f7162cad51d2200ebd22c620c14af38f718 ]
To perform the reserve_crashkernel() operation kexec uses SECTION_SIZE to
find a memblock in a range.
SECTION_SIZE is not defined for nommu systems. Trying to compile kexec in
these conditions results in a build error:
linux/arch/arm/kernel/setup.c: In function ‘reserve_crashkernel’:
linux/arch/arm/kernel/setup.c:1016:25: error: ‘SECTION_SIZE’ undeclared
(first use in this function); did you mean ‘SECTIONS_WIDTH’?
crash_size, SECTION_SIZE);
SECTIONS_WIDTH
linux/arch/arm/kernel/setup.c:1016:25: note: each undeclared identifier
is reported only once for each function it appears in
linux/scripts/Makefile.build:265: recipe for target 'arch/arm/kernel/setup.o'
failed
Make KEXEC depend on MMU to fix the compilation issue.
Signed-off-by: Vincenzo Frascino <vincenzo.frascino@arm.com>
[ Upstream commit 45f7a0da600d3c409b5ad8d5ddddacd98ddc8840 ]
Currently backtrace from ftraced function does not contain ftraced
function itself. e.g. for "path_openat":
arch_stack_walk+0x15c/0x2d8
stack_trace_save+0x50/0x68
stack_trace_call+0x15e/0x3d8
ftrace_graph_caller+0x0/0x1c <-- ftrace code
do_filp_open+0x7c/0xe8 <-- ftraced function caller
do_open_execat+0x76/0x1b8
open_exec+0x52/0x78
load_elf_binary+0x180/0x1160
search_binary_handler+0x8e/0x288
load_script+0x2a8/0x2b8
__do_execve_file.isra.39+0x6fa/0xb40
__s390x_sys_execve+0x56/0x68
system_call+0xdc/0x2d8
Ftraced function is expected in the backtrace by ftrace kselftests, which
are now failing. It would also be nice to have it for clarity reasons.
"ftrace_caller" itself is called without stack frame allocated for it
and does not store its caller (ftraced function). Instead it simply
allocates a stack frame for "ftrace_trace_function" and sets backchain
to point to ftraced function stack frame (which contains ftraced function
caller in saved r14).
To fix this issue make "ftrace_caller" allocate a stack frame
for itself just to store ftraced function for the stack unwinder.
As a result backtrace looks like the following:
path_openat+0x6/0xd60 <-- ftraced function
open_exec+0x52/0x78
Reported-by: Sven Schnelle <sven.schnelle@ibm.com>
Tested-by: Sven Schnelle <sven.schnelle@ibm.com>
[ Upstream commit 02aeb2f21530c98fc3ca51028eda742a3fafbd9f ]
pinmux_func_gpios[] contains a hole due to the missing function GPIO
definition for the "CTX0&CTX1" signal, which is the logical "AND" of the
first two CAN outputs.
A closer look reveals other issues:
- Some functionality is available on alternative pins, but the
PINMUX_DATA() entries is using the wrong marks,
- Several configurations are missing.
Fix this by:
- Renaming CTX0CTX1CTX2_MARK, CRX0CRX1_PJ22_MARK, and
CRX0CRX1CRX2_PJ20_MARK to CTX0_CTX1_CTX2_MARK, CRX0_CRX1_PJ22_MARK,
resp. CRX0_CRX1_CRX2_PJ20_MARK for consistency with the
corresponding enum IDs,
- Adding all missing enum IDs and marks,
- Use the right (*_PJ2x) variants for alternative pins,
- Adding all missing configurations to pinmux_data[],
- Adding all missing function GPIO definitions to pinmux_func_gpios[].
See SH7268 Group, SH7269 Group User’s Manual: Hardware, Rev. 2.00:
[1] Table 1.4 List of Pins
[2] Figure 23.29 Connection Example when Using Channels 0 and 1 as One
Channel (64 Mailboxes × 1 Channel) and Channel 2 as One Channel
(32 Mailboxes × 1 Channel),
[3] Figure 23.30 Connection Example when Using Channels 0, 1, and 2 as
One Channel (96 Mailboxes × 1 Channel),
[4] Table 48.3 Multiplexed Pins (Port B),
[5] Table 48.4 Multiplexed Pins (Port C),
[6] Table 48.10 Multiplexed Pins (Port J),
[7] Section 48.2.4 Port B Control Registers 0 to 5 (PBCR0 to PBCR5).
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Link: https://lore.kernel.org/r/20191218194812.12741-5-geert+renesas@glider.be
[ Upstream commit bff47c2302cc249bcd550b17067f8dddbd4b6f77 ]
When building with C=1, sparse issues a warning:
CHECK arch/x86/entry/vdso/vdso32-setup.c
arch/x86/entry/vdso/vdso32-setup.c:28:28: warning: symbol 'vdso32_enabled' was not declared. Should it be static?
Provide the missing header file.
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/36224.1575599767@turing-police
[ Upstream commit 8443ffd1bbd5be74e9b12db234746d12e8ea93e2 ]
Add a device node for the global timer, which is part of the Cortex-A9
MPCore.
The global timer can serve as an accurate (4 ns) clock source for
scheduling and delay loops.
Link: https://lore.kernel.org/r/20191211135222.26770-4-geert+renesas@glider.be
[ Upstream commit 72d052e28d1d2363f9107be63ef3a3afdea6143c ]
If kzalloc fails, it should return -ENOMEM, otherwise may trigger a NULL
pointer dereference.
Fixes: 3adeb2566b9b ("MIPS: Loongson: Improve LEFI firmware interface")
Signed-off-by: Tiezhu Yang <yangtiezhu@loongson.cn>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Jiaxun Yang <jiaxun.yang@flygoat.com>
[ Upstream commit ffc2760bcf2dba0dbef74013ed73eea8310cc52c ]
Fix a couple of issues with the way we map and copy the vendor string:
- we map only 2 bytes, which usually works since you get at least a
page, but if the vendor string happens to cross a page boundary,
a crash will result
- only call early_memunmap() if early_memremap() succeeded, or we will
call it with a NULL address which it doesn't like,
- while at it, switch to early_memremap_ro(), and array indexing rather
than pointer dereferencing to read the CHAR16 characters.
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Arvind Sankar <nivedita@alum.mit.edu>
Cc: Matthew Garrett <mjg59@google.com>
Cc: linux-efi@vger.kernel.org
Fixes: 5b83683f32b1 ("x86: EFI runtime service support")
Link: https://lkml.kernel.org/r/20200103113953.9571-5-ardb@kernel.org
This reverts commit 57211b7366cc2abf784c35e537b256e7fcddc91e.
This patch isn't needed on 4.19 and older.
commit 0f8a206df7c920150d2aa45574fba0ab7ff6be4f upstream.
Clang warns:
In file included from ../arch/s390/boot/startup.c:3:
In file included from ../include/linux/elf.h:5:
In file included from ../arch/s390/include/asm/elf.h:132:
In file included from ../include/linux/compat.h:10:
In file included from ../include/linux/time.h:74:
In file included from ../include/linux/time32.h:13:
In file included from ../include/linux/timex.h:65:
../arch/s390/include/asm/timex.h:160:20: warning: passing 'unsigned char
[16]' to parameter of type 'char *' converts between pointers to integer
types with different sign [-Wpointer-sign]
get_tod_clock_ext(clk);
../arch/s390/include/asm/timex.h:149:44: note: passing argument to
parameter 'clk' here
static inline void get_tod_clock_ext(char *clk)
Change clk's type to just be char so that it matches what happens in
get_tod_clock_ext.
Fixes: 57b28f66316d ("[S390] s390_hypfs: Add new attributes")
Link: https://github.com/ClangBuiltLinux/linux/issues/861
Link: http://lkml.kernel.org/r/20200208140858.47970-1-natechancellor@gmail.com
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit fb6d4d340e0532032c808a9933eaaa7b8de435ab upstream.
This is encoded as F3 0F C7 /7 with a register argument. The register
argument is the second array in the group9 GroupDual, while F3 is the
fourth element of a Prefix.
Reviewed-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit a582c540ac1b10f0a7d37415e04c4af42409fd08 upstream.
RDPID is a new instruction that reads MSR_TSC_AUX quickly. This
should be considerably faster than reading the GDT. Add a
cpufeature for it and use it from __vdso_getcpu() when available.
Tested-by: Megha Dey <megha.dey@intel.com>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/4f6c3a22012d10f1c65b9ca15800e01b42c7d39d.1479320367.git.luto@kernel.org
This is the 4.4.214 stable release
