commit 7b27718bdb1b70166383dec91391df5534d449ee upstream
yesterday I tried to reactivate my old 486 box and wanted to install a
current Linux with latest kernel on it. But it turned out that the
latest kernel does not boot because the machine crashes early in the
setup code.
After some debugging it turned out that the problem is the query_ist()
function. If this interrupt with that function is called the machine
simply locks up. It looks like a BIOS bug. Looking for a workaround for
this problem I wrote the attached patch. It checks for the CPUID
instruction and if it is not implemented it does not call the speedstep
BIOS function. As far as I know speedstep should be available since some
Pentium earliest.
Alan Cox observed that it's available since the Pentium II, so cpuid
levels 4 and 5 can be excluded altogether.
H. Peter Anvin cleaned up the code some more:
> Right in concept, but I dislike the implementation (duplication of the
> CPU detect code we already have). Could you try this patch and see if
> it works for you?
which, with a small modification to fix a build error with it the
resulting kernel boots on my machine.
Signed-off-by: Joerg Roedel <joro@8bytes.org>
Signed-off-by: "H. Peter Anvin" <hpa@zytor.com>
commit b6d8adf477439e7086224bc9674c6b6638780783 upstream.
Include limits.h to get a definition of PATH_MAX.
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
commit 7c1fed03b9fa32d4323d5caa6a9c7dcdd7eba767 upstream
My copying of linux/init.h didn't go far enough. The definition of
__used singled out gcc minor version 3, but didn't care what the major
version was. This broke when unit-at-a-time was added and gcc started
throwing out initcalls.
This results in an early boot crash when ptrace tries to initialize a
process with an empty, uninitialized register set.
commit 4f81c5350b44bcc501ab6f8a089b16d064b4d2f6 upstream
There are various constraints on the use of unit-at-a-time:
- i386 uses no-unit-at-a-time for pre-4.0 (not 4.3)
- x86_64 uses unit-at-a-time always
Uli reported a crash on x86_64 with gcc 4.1.2 with unit-at-a-time,
resulting in commit c0a18111e571138747a98af18b3a2124df56a0d1
Ingo reported a gcc internal error with gcc 4.3 with no-unit-at-a-timem,
resulting in 22eecde2f9034764a3fd095eecfa3adfb8ec9a98
Benny Halevy is seeing extern inlines not resolved with gcc 4.3 with
no-unit-at-a-time
This patch reintroduces unit-at-a-time for gcc >= 4.0, bringing back the
possibility of Uli's crash. If that happens, we'll debug it.
I started seeing both the internal compiler errors and unresolved
inlines on Fedora 9. This patch fixes both problems, without so far
reintroducing the crash reported by Uli.
Cc: Benny Halevy <bhalevy@panasas.com>
Cc: Adrian Bunk <bunk@kernel.org>
Cc: Ulrich Drepper <drepper@redhat.com>
commit f1ef9167ca4494a8c6d71d0031c73e9c8841eadd upstream
Fedora broke PTRACE_SYSEMU again, and UML crashes as a result when it
doesn't need to. This patch makes the PTRACE_SYSEMU check fail gracefully
and makes UML fall back to PTRACE_SYSCALL.
commit 3d5ede6f776bdb1483bcd086f79c3bf41fed3865 upstream
We lost the marking of SIGWINCH as being OK to receive during stub
execution, causing a panic should that happen.
Cc: Benedict Verheyen <benedict.verheyen@gmail.com>
commit 8bfd04b974689f700bbd053ad6e66b0a95fb80c9 upstream
x86_64 defines either memcpy or __memcpy depending on the gcc version, and
it looks like UML needs to follow that in its exporting.
Cc: Gabriel C <nix.or.die@googlemail.com>
commit 3e3b48e5198544dd90e27265a70c1a834139e025 upstream
Cc: Jeff Dike <jdike@addtoit.com>
commit 40fb16a360d9c6459afee91dc793c1e3374feb94 upstream
This patch makes os_get_task_size locate the bottom of the address space,
as well as the top. This is for systems which put a lower limit on mmap
addresses. It works by manually scanning pages from zero onwards until a
valid page is found.
Because the bottom of the address space may not be zero, it's not
sufficient to assume the top of the address space is the size of the
address space. The size is the difference between the top address and
bottom address.
[jdike@addtoit.com: changed the name to reflect that this function is
supposed to return the top of the process address space, not its size and
changed the return value to reflect that. Also some minor formatting
changes]
Signed-off-by: Tom Spink <tspink@gmail.com>
commit 06e1e4ffbd1932e288839b3140cda6b8141eb684 upstream
Protection against the host's time going backwards (eg, ntp activity on
the host) by keeping track of the time at the last tick and if it's
greater than the current time, keep time stopped until the host catches
up.
Cc: Nix <nix@esperi.org.uk>
commit 296cd66f7f6e130fe08e6880ecb13c3fc615a8db upstream
Acked-by: Jeff Dike <jdike@addtoit.com>
commit fe2cc53ee013a4d4d0317d418e7019fe6533a5a8 upstream
Alarm delivery could be noticably late in the !CONFIG_NOHZ case because lost
ticks weren't being taken into account. This is now treated more carefully,
with the time between ticks being calculated and the appropriate number of
ticks delivered to the timekeeping system.
commit 60a2988aea701a6424809a5432bf068667aac177 upstream
The top of physical memory should be below the initial process stack, not the
top of the address space, at least for as long as the stack isn't known to the
kernel VM system and appropriately reserved.
Cc: "Christopher S. Aker" <caker@theshore.net>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
commit cfd28f6695d0fc047478480791a21bdd4967f98e upstream
UML's supposed nanosecond clock interacts badly with NTP when NTP
decides that the clock has drifted ahead and needs to be slowed down.
Slowing down the clock is done by decrementing the cycle-to-nanosecond
multiplier, which is 1. Decrementing that gives you 0 and time is
stopped.
This is fixed by switching to a microsecond clock, with a multiplier
of 1000.
commit 43f5b3085fdd27c4edf535d938b2cb0ccead4f75 upstream
Reintroduce uml_kmalloc for the benefit of UML libc code. The
previous tactic of declaring __kmalloc so it could be called directly
from the libc side of the house turned out to be getting too intimate
with slab, and it doesn't work with slob.
So, the uml_kmalloc wrapper is back. It calls kmalloc or whatever
that translates into, and libc code calls it.
kfree is left alone since that still works, leaving a somewhat
inconsistent API.
[ Upstream commit 0a4949c4414af2eb91414bcd8e2a8ac3706f7dde ]
That's the userland thread register, so we should never try to change
it like this.
Based upon glibc bug nptl/6577 and suggestions by Jakub Jelinek.
commit e4cc58944c1e2ce41e3079d4eb60c95e7ce04b2b upstream
Current versions of gdb require a working implementation of
PTRACE_GETSIGINFO for proper watchpoint support. Since struct siginfo
contains pointers it must be converted when passed to a 32-bit debugger.
Signed-off-by: Andreas Schwab <schwab@suse.de>
commit 756a6c68556600aec9460346332884d891d5beb4 upstream
x86: ioremap of 64-bit resource on 32-bit kernel fix
Cc: Chuck Ebbert <cebbert@redhat.com>
commit a1531acd43310a7e4571d52e8846640667f4c74b upstream
Ingo Molnar provided a fix to not call _PPC at processor driver
initialization time in "[PATCH] ACPI: fix cpufreq regression" (git
commit e4233dec749a3519069d9390561b5636a75c7579)
But it can still happen that _PPC is called at processor driver
initialization time.
This patch should make sure that this is not possible anymore.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Cc: Len Brown <lenb@kernel.org>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
based on e22146e610bb7aed63282148740ab1d1b91e1d90 upstream
Fix bug in kernel_physical_mapping_init() that causes kernel
page table to be built incorrectly for systems with greater
than 512GB of memory.
Signed-off-by: Jack Steiner <steiner@sgi.com>
Cc: linux-mm@kvack.org
Cc: Oliver Pinter <oliver.pntr@gmail.com>
[ Upstream commit 7ae93f51d7fa8b9130d47e0b7d17979a165c5bc3 ]
Based upon a report by Daniel Smolik.
We do it too early, which triggers a BUG in
cpufreq_register_notifier().
[ Upstream commit b7c2a75725dee9b5643a0aae3a4cb47f52e00a49 ]
We're calling request_irq() with a IRQs disabled.
No straightforward fix exists because we want to
enable these IRQs and setup state atomically before
getting into the IRQ handler the first time.
What happens now is that we mark the VIRQ to not be
automatically enabled by request_irq(). Then we
make explicit enable_irq() calls when we grab the
LDC channel.
This way we don't need to call request_irq() illegally
under the LDC channel lock any more.
Bump LDC version and release date.
commit d536b1f86591fb081c7a56eab04e711eb4dab951 upstream
currently if you use PTRACE_SINGLEBLOCK on AMD K6-3 (i586) it will crash.
Kernel now wrongly assumes existing DEBUGCTLMSR MSR register there.
Removed the assumption also for some other non-K6 CPUs but I am not sure there
(but it can only bring small inefficiency there if my assumption is wrong).
Based on info from Roland McGrath, Chuck Ebbert and Mikulas Patocka.
More info at:
https://bugzilla.redhat.com/show_bug.cgi?id=456175
Signed-off-by: Jan Kratochvil <jan.kratochvil@redhat.com>
commit ba0fc709e197415aadd46b9ec208dc4abaa21edd upstream
There is dma_mask in of_device upon of_platform_device_create()
but we don't actually set coherent_dma_mask. This may cause weird
behavior of USB subsystem using of_device USB host drivers.
Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
Commit fcb43042ef55d2f46b0efa5d7746967cef38f056 upstream
x86: fix cpu hotplug crash
Vegard Nossum reported crashes during cpu hotplug tests:
http://marc.info/?l=linux-kernel&m=121413950227884&w=4
In function _cpu_up, the panic happens when calling
__raw_notifier_call_chain at the second time. Kernel doesn't panic when
calling it at the first time. If just say because of nr_cpu_ids, that's
not right.
By checking the source code, I found that function do_boot_cpu is the culprit.
Consider below call chain:
_cpu_up=>__cpu_up=>smp_ops.cpu_up=>native_cpu_up=>do_boot_cpu.
So do_boot_cpu is called in the end. In do_boot_cpu, if
boot_error==true, cpu_clear(cpu, cpu_possible_map) is executed. So later
on, when _cpu_up calls __raw_notifier_call_chain at the second time to
report CPU_UP_CANCELED, because this cpu is already cleared from
cpu_possible_map, get_cpu_sysdev returns NULL.
Many resources are related to cpu_possible_map, so it's better not to
change it.
Below patch against 2.6.26-rc7 fixes it by removing the bit clearing in
cpu_possible_map.
Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com>
Tested-by: Vegard Nossum <vegard.nossum@gmail.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Commit 11dbc963a8f6128595d0f6ecf138dc369e144997 upstream
ptrace GET/SET FPXREGS broken
When I update kernel 2.6.25 from 2.6.24, gdb does not work.
On 2.6.25, ptrace(PTRACE_GETFPXREGS, ...) returns ENODEV.
But 2.6.24 kernel's ptrace() returns EIO.
It is issue of compatibility.
I attached test program as pt.c and patch for fix it.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <signal.h>
#include <errno.h>
#include <sys/ptrace.h>
#include <sys/types.h>
struct user_fxsr_struct {
unsigned short cwd;
unsigned short swd;
unsigned short twd;
unsigned short fop;
long fip;
long fcs;
long foo;
long fos;
long mxcsr;
long reserved;
long st_space[32]; /* 8*16 bytes for each FP-reg = 128 bytes */
long xmm_space[32]; /* 8*16 bytes for each XMM-reg = 128 bytes */
long padding[56];
int main(void)
pid_t pid;
pid = fork();
switch(pid){
case -1:/* error */
break;
case 0:/* child */
child();
break;
default:
parent(pid);
break;
return 0;
int child(void)
ptrace(PTRACE_TRACEME);
kill(getpid(), SIGSTOP);
sleep(10);
return 0;
int parent(pid_t pid)
int ret;
struct user_fxsr_struct fpxregs;
ret = ptrace(PTRACE_GETFPXREGS, pid, 0, &fpxregs);
if(ret < 0){
printf("%d: %s.\n", errno, strerror(errno));
kill(pid, SIGCONT);
wait(pid);
return 0;
/* in the kerel, at kernel/i387.c get_fpxregs() */
Commit 5a4646a4efed8c835f76c3b88f3155f6ab5b8d9b introduced a leak of
task_struct refs into sys32_ptrace. This bug has already gone away in
for 2.6.26 in commit 562b80bafffaf42a6d916b0a2ee3d684220a1c10.
Signed-off-by: Roland McGrath <roland@redhat.com>
commit d3942cff620bea073fc4e3c8ed878eb1e84615ce upstream
This patch uses the BOOTMEM_EXCLUSIVE for crashkernel reservation also for
i386 and prints a error message on failure.
The patch is still for 2.6.26 since it is only bug fixing. The unification
of reserve_crashkernel() between i386 and x86_64 should be done for 2.6.27.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
commit 89f5b7da2a6bad2e84670422ab8192382a5aeb9f upstream
KAMEZAWA Hiroyuki and Oleg Nesterov point out that since the commit
557ed1fa2620dc119adb86b34c614e152a629a80 ("remove ZERO_PAGE") removed
the ZERO_PAGE from the VM mappings, any users of get_user_pages() will
generally now populate the VM with real empty pages needlessly.
We used to get the ZERO_PAGE when we did the "handle_mm_fault()", but
since fault handling no longer uses ZERO_PAGE for new anonymous pages,
we now need to handle that special case in follow_page() instead.
In particular, the removal of ZERO_PAGE effectively removed the core
file writing optimization where we would skip writing pages that had not
been populated at all, and increased memory pressure a lot by allocating
all those useless newly zeroed pages.
This reinstates the optimization by making the unmapped PTE case the
same as for a non-existent page table, which already did this correctly.
While at it, this also fixes the XIP case for follow_page(), where the
caller could not differentiate between the case of a page that simply
could not be used (because it had no "struct page" associated with it)
and a page that just wasn't mapped.
We do that by simply returning an error pointer for pages that could not
be turned into a "struct page *". The error is arbitrarily picked to be
EFAULT, since that was what get_user_pages() already used for the
equivalent IO-mapped page case.
[ Also removed an impossible test for pte_offset_map_lock() failing:
that's not how that function works ]
Acked-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-by: Nick Piggin <npiggin@suse.de>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Roland McGrath <roland@redhat.com>
back-ported from upstream commit e9623b35599fcdbc00c16535cbefbb4d5578f4ab by Vegard Nossum
The previous revert of 0c07ee38c9d4eb081758f5ad14bbffa7197e1aec left
out the mwait disable condition for AMD family 10H/11H CPUs.
Andreas Herrman said:
It depends on the CPU. For AMD CPUs that support MWAIT this is wrong.
Family 0x10 and 0x11 CPUs will enter C1 on HLT. Powersavings then
depend on a clock divisor and current Pstate of the core.
If all cores of a processor are in halt state (C1) the processor can
enter the C1E (C1 enhanced) state. If mwait is used this will never
happen.
Thus HLT saves more power than MWAIT here.
It might be best to switch off the mwait flag for these AMD CPU
families like it was introduced with commit
f039b754714a422959027cb18bb33760eb8153f0 (x86: Don't use MWAIT on AMD
Family 10)
Re-add the AMD families 10H/11H check and disable the mwait usage for
those.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
back-ported from upstream commit a738d897b7b03b83488ae74a9bc03d26a2875dc6 by Vegard Nossum
Vegard Nossum reports:
| powertop shows between 200-400 wakeups/second with the description
| "<kernel IPI>: Rescheduling interrupts" when all processors have load (e.g.
| I need to run two busy-loops on my 2-CPU system for this to show up).
| The bisect resulted in this commit:
| commit 0c07ee38c9d4eb081758f5ad14bbffa7197e1aec
| Date: Wed Jan 30 13:33:16 2008 +0100
| x86: use the correct cpuid method to detect MWAIT support for C states
remove the functional effects of this patch and make mwait unconditional.
A future patch will turn off mwait on specific CPUs where that causes
power to be wasted.
Bisected-by: Vegard Nossum <vegard.nossum@gmail.com>
commit 42a886af728c089df8da1b0017b0e7e6c81b5335 upstream
Most users by far do not care about the exact return value (they only
really care about whether the copy succeeded in its entirety or not),
but a few special core routines actually care deeply about exactly how
many bytes were copied from user space.
And the unrolled versions of the x86-64 user copy routines would
sometimes report that it had copied more bytes than it actually had.
Very few uses actually have partial copies to begin with, but to make
this bug even harder to trigger, most x86 CPU's use the "rep string"
instructions for normal user copies, and that version didn't have this
issue.
To make it even harder to hit, the one user of this that really cared
about the return value (and used the uncached version of the copy that
doesn't use the "rep string" instructions) was the generic write
routine, which pre-populated its source, once more hiding the problem by
avoiding the exception case that triggers the bug.
In other words, very special thanks to Bron Gondwana who not only
triggered this, but created a test-program to show it, and bisected the
behavior down to commit 08291429cfa6258c4cd95d8833beb40f828b194e ("mm:
fix pagecache write deadlocks") which changed the access pattern just
enough that you can now trigger it with 'writev()' with multiple
iovec's.
That commit itself was not the cause of the bug, it just allowed all the
stars to align just right that you could trigger the problem.
[ Side note: this is just the minimal fix to make the copy routines
(with __copy_from_user_inatomic_nocache as the particular version that
was involved in showing this) have the right return values.
We really should improve on the exceptional case further - to make the
copy do a byte-accurate copy up to the exact page limit that causes it
to fail. As it is, the callers have to do extra work to handle the
limit case gracefully. ]
Reported-by: Bron Gondwana <brong@fastmail.fm>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
commit 823c248e7cc75b4f22da914b01f8e5433cff197e in mainline
The proper dependency check uncovered a few dependency problems,
the subarchitecture used a mixture of selects and depends on SMP
and PCI dependency was messed up.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
commit 73531905ed53576d9e8707659a761e7046a60497 in mainline.
init/Kconfig contains a list of configs that are searched
for if 'make *config' are used with no .config present.
Extend this list to look at the config identified by
ARCH_DEFCONFIG.
With this change we now try the defconfig targets last.
This fixes a regression reported
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
upstream commit: 2884f110d5409714f3a04eeb6d2ecd77da66b242
OGAWA Hirofumi and Fede have reported rare pmd_ERROR messages:
mm/memory.c:127: bad pmd ffff810000207xxx(9090909090909090).
Initialization's cleanup_highmap was leaving alignment filler
behind in the pmd for MODULES_VADDR: when vmalloc's guard page
would occupy a new page table, it's not allocated, and then
module unload's vfree hits the bad 9090 pmd entry left over.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Hugh notes:
It's actually not a serious problem, but it does look as if it's a
serious problem, so we should stamp it out.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
upstream commit: 870568b39064cab2dd971fe57969916036982862
Jürgen Mell reported an FPU state corruption bug under CONFIG_PREEMPT,
and bisected it to commit v2.6.19-1363-gacc2076, "i386: add sleazy FPU
optimization".
Add tsk_used_math() checks to prevent calling math_state_restore()
which can sleep in the case of !tsk_used_math(). This prevents
making a blocking call in __switch_to().
Apparently "fpu_counter > 5" check is not enough, as in some signal handling
and fork/exec scenarios, fpu_counter > 5 and !tsk_used_math() is possible.
It's a side effect though. This is the failing scenario:
process 'A' in save_i387_ia32() just after clear_used_math()
Got an interrupt and pre-empted out.
At the next context switch to process 'A' again, kernel tries to restore
the math state proactively and sees a fpu_counter > 0 and !tsk_used_math()
This results in init_fpu() during the __switch_to()'s math_state_restore()
And resulting in fpu corruption which will be saved/restored
(save_i387_fxsave and restore_i387_fxsave) during the remaining
part of the signal handling after the context switch.
Bisected-by: Jürgen Mell <j.mell@t-online.de>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Tested-by: Jürgen Mell <j.mell@t-online.de>
back.
upstream commit: e56a727b023d40d1adf660168883f30f2e6abe0a
We checked the hardware freq with OS cached freq value in get_cur_freqon_cpu().
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Thomas Renninger <trenn@suse.de>
Cc: "Anthony L. Awtrey" <tony@awtrey.com>
[chrisw: backport to 2.6.25.4]
upstream commit: 8d539108560ec121d59eee05160236488266221c
This reverts commit 9f8daccaa05c14e5643bdd4faf5aed9cc8e6f11e, which was
reported to break X startup (xf86-video-ati-6.8.0). See
http://bugs.freedesktop.org/show_bug.cgi?id=15523
for details.
Reported-by: Laurence Withers <l@lwithers.me.uk>
Cc: Gary Hade <garyhade@us.ibm.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jan Beulich <jbeulich@novell.com>
Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com>
[cebbert@redhat.com: backport, remove first hunk to make port easier]
[chrisw@sous-sol.org: add back first hunk]
upstream commit: 74dc51a3de06aa516e3b9fdc4017b2aeb38bf44b
When the TSC calibration fails then TSC is still used in
sched_clock(). Disable it completely in that case.
Cc: stable@kernel.org
upstream commit: 9ccc906c97e34fd91dc6aaf5b69b52d824386910
tsc_enabled is set to 0 from the command line switch "notsc" and from
the mark_tsc_unstable code. Seperate those functionalities and replace
tsc_enable with tsc_disable. This makes also the native_sched_clock()
decision when to use TSC understandable.
Preparatory patch to solve the sched_clock() issue on 32 bit.
upstream commit: 3c2047cd32b1a8c782d7efab72707e7daa251625
The current tsc_init() clears the TSC feature bit if the TSC khz
cannot be calculated, causing us to panic in
arch/x86/kernel/cpu/bugs.c check_config(). We should simply mark it
unstable.
Frankly, someone should take an axe to this code. mark_tsc_unstable()
not only marks it unstable, but sets tsc_enabled to 0, which seems
redundant but is actually important here because means it won't be
used by sched_clock() either. Perhaps a tristate enum "UNUSABLE,
UNSTABLE, OK" would be clearer, and separate mark_tsc_unstable() and
mark_tsc_broken() functions?
upstream commit: b6db80ee1331e7beaeb91b4b3d946dd16c72e388
When the TSC is calibrated against the PIT due to the nonavailability
of PMTIMER/HPET or due to SMI interference then the setup of the per
CPU cyc2ns variables is skipped. This is unlikely to happen but it
would definitely render sched_clock() unusable.
This was introduced with commit 53d517cdbaac704352b3d0c10fecb99e0b54572e
x86: scale cyc_2_nsec according to CPU frequency
Update the per CPU cyc2ns variables in all exit pathes of tsc_calibrate.
upstream commit: 2584a82deed7196f48066f1b1a7fad4ec5bea961
A check for unmapped apic was added before reading maxlvt but the early
read of maxlvt wasn't removed.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Cc: Andi Kleen <ak@suse.de>
upstream commit: 5065dbafc299507f16731434e95b91dadff03006
i386: fix asm constraint in do_IRQ()
Two prior changes resulted in the "ecx" clobber being lost.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
commit 1f465f4e475454b8bb590846c50a9d16e8046f3d upstream
The user_regset_view table for the 32-bit regsets on the 64-bit build had
the wrong sizes for the FP regsets. This bug had no user-visible effect
(just on kernel modules using the user_regset interfaces and the like).
But the fix is trivial and risk-free.
This is upstream as commit 3b5750644b2ffa2a76fdfe7b4e00e4af2ecf3539.
This fixes a regression reported by Kamalesh Bulabel where a POWER4
machine would crash because of an SLB miss at a point where the SLB
miss exception was unrecoverable. This regression is tracked at:
http://bugzilla.kernel.org/show_bug.cgi?id=10082
SLB misses at such points shouldn't happen because the kernel stack is
the only memory accessed other than things in the first segment of the
linear mapping (which is mapped at all times by entry 0 of the SLB).
The context switch code ensures that SLB entry 2 covers the kernel
stack, if it is not already covered by entry 0. None of entries 0
to 2 are ever replaced by the SLB miss handler.
Where this went wrong is that the context switch code assumes it
doesn't have to write to SLB entry 2 if the new kernel stack is in the
same segment as the old kernel stack, since entry 2 should already be
correct. However, when we start up a secondary cpu, it calls
slb_initialize, which doesn't set up entry 2. This is correct for
the boot cpu, where we will be using a stack in the kernel BSS at this
point (i.e. init_thread_union), but not necessarily for secondary
cpus, whose initial stack can be allocated anywhere. This doesn't
cause any immediate problem since the SLB miss handler will just
create an SLB entry somewhere else to cover the initial stack.
In fact it's possible for the cpu to go quite a long time without SLB
entry 2 being valid. Eventually, though, the entry created by the SLB
miss handler will get overwritten by some other entry, and if the next
access to the stack is at an unrecoverable point, we get the crash.
This fixes the problem by making slb_initialize create a suitable
entry for the kernel stack, if we are on a secondary cpu and the stack
isn't covered by SLB entry 0. This requires initializing the
get_paca()->kstack field earlier, so I do that in smp_create_idle
where the current field is initialized. This also abstracts a bit of
the computation that mk_esid_data in slb.c does so that it can be used
in slb_initialize.
[ Upstream commit: c07c6053c41f736711ed856aa377007078c7c396 ]
That bit isn't used on this platform.
[ This is a 2.6.25 backport of upstream changeset
28e6103665301ce60634e8a77f0b657c6cc099de with sparc32 build
fixes from Robert Reif ]
So, forever, we've had this ptrace_signal_deliver implementation
which tries to handle all of the nasties that can occur when the
debugger looks at a process about to take a signal. It's meant
to address all of these issues inside of the kernel so that the
debugger need not be mindful of such things.
Problem is, this doesn't work.
The idea was that we should do the syscall restart business first, so
that the debugger captures that state. Otherwise, if the debugger for
example saves the child's state, makes the child execute something
else, then restores the saved state, we won't handle the syscall
restart properly because we lose the "we're in a syscall" state.
The code here worked for most cases, but if the debugger actually
passes the signal through to the child unaltered, it's possible that
we would do a syscall restart when we shouldn't have.
In particular this breaks the case of debugging a process under a gdb
which is being debugged by yet another gdb. gdb uses sigsuspend
to wait for SIGCHLD of the inferior, but if gdb itself is being
debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb
does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the
signal. But ptrace_signal_deliver() assumed the debugger would cancel
out the signal and therefore did a syscall restart, because the return
error was ERESTARTNOHAND.
Fix this by simply making ptrace_signal_deliver() a nop, and providing
a way for the debugger to control system call restarting properly:
1) Report a "in syscall" software bit in regs->{tstate,psr}.
It is set early on in trap entry to a system call and is fully
visible to the debugger via ptrace() and regsets.
2) Test this bit right before doing a syscall restart. We have
to do a final recheck right after get_signal_to_deliver() in
case the debugger cleared the bit during ptrace_stop().
3) Clear the bit in trap return so we don't accidently try to set
that bit in the real register.
As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just
like sparc64 has.
M68K has this same exact bug, and is now the only other user of the
ptrace_signal_deliver hook. It needs to be fixed in the same exact
way as sparc.
Just like mmap, we need to validate address ranges regardless
of MAP_FIXED.
sparc{,64}_mmap_check()'s flag argument is unused, remove.
Based upon a report and preliminary patch by
Jan Lieskovsky <jlieskov@redhat.com>
[ Upstream commit: 986bef854fab44012df678a5b51817d5274d3ca1 ]
Forever we had a PTRACE_SUNOS_DETACH which was unconditionally
recognized, regardless of the personality of the process.
Unfortunately, this value is what ended up in the GLIBC sys/ptrace.h
header file on sparc as PTRACE_DETACH and PT_DETACH.
So continue to recognize this old value. Luckily, it doesn't conflict
with anything we actually care about.
