commit af438fec6cb99fc2e2faf8b16b865af26ce722e6 upstream.
Use the corresponding compatibles to identify the devices.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
Tested-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit d26a7730b5874a5fa6779c62f4ad7c5065a94723 upstream.
In spite of what the GCC manual says, the -mfast-indirect-calls has
never been supported in the 64-bit parisc compiler. Indirect calls have
always been done using function descriptors irrespective of the
-mfast-indirect-calls option.
Recently, it was noticed that a function descriptor was always requested
when the -mfast-indirect-calls option was specified. This caused
problems when the option was used in application code and doesn't make
any sense because the whole point of the option is to avoid using a
function descriptor for indirect calls.
Fixing this broke 64-bit kernel builds.
I will fix GCC but for now we need the attached change. This results in
the same kernel code as before.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
commit 03bd4e1f7265548832a76e7919a81f3137c44fd1 upstream.
The following bug can be triggered by hot adding and removing a large number of
xen domain0's vcpus repeatedly:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [..] find_busiest_group
PGD 5a9d5067 PUD 13067 PMD 0
Oops: 0000 [#3] SMP
Call Trace:
load_balance
? _raw_spin_unlock_irqrestore
idle_balance
__schedule
schedule
schedule_timeout
? lock_timer_base
schedule_timeout_uninterruptible
msleep
lock_device_hotplug_sysfs
online_store
dev_attr_store
sysfs_write_file
vfs_write
SyS_write
system_call_fastpath
Last level cache shared mask is built during CPU up and the
build_sched_domain() routine takes advantage of it to setup
the sched domain CPU topology.
However, llc_shared_mask is not released during CPU disable,
which leads to an invalid sched domainCPU topology.
This patch fix it by releasing the llc_shared_mask correctly
during CPU disable.
Yasuaki also reported that this can happen on real hardware:
https://lkml.org/lkml/2014/7/22/1018
His case is here:
Here is an example on my system.
My system has 4 sockets and each socket has 15 cores and HT is
enabled. In this case, each core of sockes is numbered as
follows:
| CPU#
Socket#0 | 0-14 , 60-74
Socket#1 | 15-29, 75-89
Socket#2 | 30-44, 90-104
Socket#3 | 45-59, 105-119
Then llc_shared_mask of CPU#30 has 0x3fff80000001fffc0000000.
It means that last level cache of Socket#2 is shared with
CPU#30-44 and 90-104.
When hot-removing socket#2 and #3, each core of sockets is
numbered as follows:
| CPU#
But llc_shared_mask is not cleared. So llc_shared_mask of CPU#30
remains having 0x3fff80000001fffc0000000.
After that, when hot-adding socket#2 and #3, each core of
sockets is numbered as follows:
| CPU#
Socket#2 | 30-59
Socket#3 | 90-119
Then llc_shared_mask of CPU#30 becomes
0x3fff8000fffffffc0000000. It means that last level cache of
Socket#2 is shared with CPU#30-59 and 90-104. So the mask has
the wrong value.
Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com>
Tested-by: Linn Crosetto <linn@hp.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Link: http://lkml.kernel.org/r/1411547885-48165-1-git-send-email-wanpeng.li@linux.intel.com
commit ab3f285f227fec62868037e9b1b1fd18294a83b8 upstream.
The PFMF instruction handler blindly wrote the storage key even if
the page was mapped R/O in the host. Lets try a COW before continuing
and bail out in case of errors.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reviewed-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
commit 8a574cfa2652545eb95595d38ac2a0bb501af0ae upstream.
Every mcount() call in the MIPS 32-bit kernel is done as follows:
move at, ra
jal _mcount
addiu sp, sp, -8
but upon returning from the mcount() function, the stack pointer
is not adjusted properly. This is explained in details in 58b69401c797
(MIPS: Function tracer: Fix broken function tracing).
Commit ad8c396936e3 ("MIPS: Unbreak function tracer for 64-bit kernel.)
fixed the stack manipulation for 64-bit but it didn't fix it completely
for MIPS32.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/7792/
commit 29593fd5a8149462ed6fad0d522234facdaee6c8 upstream.
Commit dc4d7b37 (MIPS: ZBOOT: gather string functions into string.c)
moved the string related functions into a separate file, which might
cause the following build error, depending on the configuration:
| CC arch/mips/boot/compressed/decompress.o
| In file included from linux/arch/mips/boot/compressed/../../../../lib/decompress_unxz.c:234:0,
| from linux/arch/mips/boot/compressed/decompress.c:67:
| linux/arch/mips/boot/compressed/../../../../lib/xz/xz_dec_stream.c: In function 'fill_temp':
| linux/arch/mips/boot/compressed/../../../../lib/xz/xz_dec_stream.c:162:2: error: implicit declaration of function 'memcpy' [-Werror=implicit-function-declaration]
| cc1: some warnings being treated as errors
| linux/scripts/Makefile.build:308: recipe for target 'arch/mips/boot/compressed/decompress.o' failed
| make[6]: *** [arch/mips/boot/compressed/decompress.o] Error 1
| linux/arch/mips/Makefile:308: recipe for target 'vmlinuz' failed
It does not fail with the standard configuration, as when
CONFIG_DYNAMIC_DEBUG is not enabled <linux/string.h> gets included in
include/linux/dynamic_debug.h. There might be other ways for it to
get indirectly included.
We can't add the include directly in xz_dec_stream.c as some
architectures might want to use a different version for the boot/
directory (see for example arch/x86/boot/string.h).
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Patchwork: https://patchwork.linux-mips.org/patch/7420/
commit 5ca918e5e3f9df4634077c06585c42bc6a8d699a upstream.
The alignment fixup incorrectly decodes faulting ARM VLDn/VSTn
instructions (where the optional alignment hint is given but incorrect)
as LDR/STR, leading to register corruption. Detect these and correctly
treat them as unhandled, so that userspace gets the fault it expects.
Reported-by: Simon Hosie <simon.hosie@arm.com>
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
commit fbfb872f5f417cea48760c535e0ff027c88b507a upstream.
The TPIDRURO and TPIDRURW registers need to be flushed during exec;
otherwise TLS information is potentially leaked. TPIDRURO in
particular needs careful treatment. Since flush_thread basically
needs the same code used to set the TLS in arm_syscall, pull that into
a common set_tls helper in tls.h and use it in both places.
Similarly, TEEHBR needs to be cleared during exec as well. Clearing
its save slot in thread_info isn't right as there is no guarantee
that a thread switch will occur before the new program runs. Just
setting the register directly is sufficient.
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
Acked-by: Will Deacon <will.deacon@arm.com>
commit a040803a9d6b8c1876d3487a5cb69602ebcbb82c upstream.
Since commit 1dbfa187dad ("ARM: irq migration: force migration off CPU
going down") the ARM interrupt migration code on cpu offline calls
irqchip.irq_set_affinity() with the argument force=true. At the point
of this change the argument had no effect because it was not used by
any interrupt chip driver and there was no semantics defined.
This changed with commit 01f8fa4f01d8 ("genirq: Allow forcing cpu
affinity of interrupts") which made the force argument useful to route
interrupts to not yet online cpus without checking the target cpu
against the cpu online mask. The following commit ffde1de64012
("irqchip: gic: Support forced affinity setting") implemented this for
the GIC interrupt controller.
As a consequence the ARM cpu offline irq migration fails if CPU0 is
offlined, because CPU0 is still set in the affinity mask and the
validataion against cpu online mask is skipped to the force argument
being true. The following first_cpu(mask) selection always selects
CPU0 as the target.
Solve the issue by calling irq_set_affinity() with force=false from
the CPU offline irq migration code so the GIC driver validates the
affinity mask against CPU online mask and therefore removes CPU0 from
the possible target candidates.
Tested on TC2 hotpluging CPU0 in and out. Without this patch the system
locks up as the IRQs are not migrated away from CPU0.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
commit 85868313177700d20644263a782351262d2aff84 upstream.
The ARMv6 and ARMv7 early abort handlers clear the exclusive monitors
upon entry to the kernel, but this is redundant:
- We clear the monitors on every exception return since commit
200b812d0084 ("Clear the exclusive monitor when returning from an
exception"), so this is not necessary to ensure the monitors are
cleared before returning from a fault handler.
- Any dummy STREX will target a temporary scratch area in memory, and
may succeed or fail without corrupting useful data. Its status value
will not be used.
- Any other STREX in the kernel must be preceded by an LDREX, which
will initialise the monitors consistently and will not depend on the
earlier state of the monitors.
Therefore we have no reason to care about the initial state of the
exclusive monitors when a data abort is taken, and clearing the monitors
prior to exception return (as we already do) is sufficient.
This patch removes the redundant clearing of the exclusive monitors from
the early abort handlers.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
commit d1b6ba82a50cecf94be540a3a153aa89d97511a0 upstream.
Remove restoring a6 on some return paths and instead modify and restore
it in a single place, using symbolic name.
Correctly restore a7 from PT_AREG7 in case of illegal a6 value.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 7128039fe2dd3d59da9e4ffa036f3aaa3ba87b9f upstream.
Current definition of TLBTEMP_BASE_2 is always 32K above the
TLBTEMP_BASE_1, whereas fast_second_level_miss handler for the TLBTEMP
region analyzes virtual address bit (PAGE_SHIFT + DCACHE_ALIAS_ORDER)
to determine TLBTEMP region where the fault happened. The size of the
TLBTEMP region is also checked incorrectly: not 64K, but twice data
cache way size (whicht may as well be less than the instruction cache
way size).
Fix TLBTEMP_BASE_2 to be TLBTEMP_BASE_1 + data cache way size.
Provide TLBTEMP_SIZE that is a greater of doubled data cache way size or
the instruction cache way size, and use it to determine if the second
level TLB miss occured in the TLBTEMP region.
Practical occurence of page faults in the TLBTEMP area is extremely
rare, this code can be tested by deletion of all w[di]tlb instructions
in the tlbtemp_mapping region.
commit 52247123749cc3cbc30168b33ad8c69515c96d23 upstream.
With SMP and a lot of debug options enabled task_struct::thread gets out
of reach of s32i/l32i instructions with base pointing at task_struct,
breaking build with the following messages:
arch/xtensa/kernel/entry.S: Assembler messages:
arch/xtensa/kernel/entry.S:1002: Error: operand 3 of 'l32i.n' has invalid value '1048'
arch/xtensa/kernel/entry.S:1831: Error: operand 3 of 's32i.n' has invalid value '1040'
arch/xtensa/kernel/entry.S:1832: Error: operand 3 of 's32i.n' has invalid value '1044'
Change base to point to task_struct::thread in such cases.
Don't use a10 in _switch_to to save/restore prev pointer as a2 is not
clobbered.
commit 1ca49463c44c970b1ab1d71b0f268bfdf8427a7e upstream.
Virtual address is translated to the XCHAL_KSEG_CACHED region in the
dma_free_coherent, but is checked to be in the 0...XCHAL_KSEG_SIZE
range.
Change check for end of the range from 'addr >= X' to 'addr > X - 1' to
handle the case of X == 0.
Replace 'if (C) BUG();' construct with 'BUG_ON(C);'.
Signed-off-by: Alan Douglas <adouglas@cadence.com>
commit f61bf8e7d19e0a3456a7a9ed97c399e4353698dc upstream.
This fixes userspace code that builds on other architectures but fails
on xtensa due to references to structures that other architectures don't
refer to. E.g. this fixes the following issue with python-2.7.8:
python-2.7.8/Modules/termios.c:861:25: error: invalid application
of 'sizeof' to incomplete type 'struct serial_multiport_struct'
{"TIOCSERGETMULTI", TIOCSERGETMULTI},
python-2.7.8/Modules/termios.c:870:25: error: invalid application
{"TIOCSERSETMULTI", TIOCSERSETMULTI},
python-2.7.8/Modules/termios.c:900:24: error: invalid application
of 'sizeof' to incomplete type 'struct tty_struct'
{"TIOCTTYGSTRUCT", TIOCTTYGSTRUCT},
commit 27d7ff273c2aad37b28f6ff0cab2cfa35b51e648 upstream.
I'm not sure what I was on when I wrote this, but when iterating over
the hardware watchpoint array (hbp_watch_array), our index is off by
ARM_MAX_BRP, so we walk off the end of our thread_struct...
... except, a dodgy condition in the loop means that it never executes
at all (bp cannot be NULL).
This patch fixes the code so that we remove the bp check and use the
correct index for accessing the watchpoint structures.
commit e2ccba49085ab5d71b092de2a5176eb9b19cc876 upstream.
Copying a function with memcpy() and then trying to execute the
result isn't trivially portable to Thumb.
This patch modifies the kexec soft restart code to copy its
assembler trampoline relocate_new_kernel() using fncpy() instead,
so that relocate_new_kernel can be in the same ISA as the rest of
the kernel without problems.
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
Reported-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Tested-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
commit b745bc85f21ea707e4ea1a91948055fa3e72c77b upstream.
cold is a bool, make it one. Make the likely case the "if" part of the
block instead of the else as according to the optimisation manual this is
preferred.
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
of flushing the TLB
commit b13b1d2d8692b437203de7a404c6b809d2cc4d99 upstream.
We use the accessed bit to age a page at page reclaim time,
and currently we also flush the TLB when doing so.
But in some workloads TLB flush overhead is very heavy. In my
simple multithreaded app with a lot of swap to several pcie
SSDs, removing the tlb flush gives about 20% ~ 30% swapout
speedup.
Fortunately just removing the TLB flush is a valid optimization:
on x86 CPUs, clearing the accessed bit without a TLB flush
doesn't cause data corruption.
It could cause incorrect page aging and the (mistaken) reclaim of
hot pages, but the chance of that should be relatively low.
So as a performance optimization don't flush the TLB when
clearing the accessed bit, it will eventually be flushed by
a context switch or a VM operation anyway. [ In the rare
event of it not getting flushed for a long time the delay
shouldn't really matter because there's no real memory
pressure for swapout to react to. ]
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Shaohua Li <shli@fusionio.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20140408075809.GA1764@kernel.org
[ Rewrote the changelog and the code comments. ]
commit 615d6e8756c87149f2d4c1b93d471bca002bd849 upstream.
This patch is a continuation of efforts trying to optimize find_vma(),
avoiding potentially expensive rbtree walks to locate a vma upon faults.
The original approach (https://lkml.org/lkml/2013/11/1/410), where the
largest vma was also cached, ended up being too specific and random,
thus further comparison with other approaches were needed. There are
two things to consider when dealing with this, the cache hit rate and
the latency of find_vma(). Improving the hit-rate does not necessarily
translate in finding the vma any faster, as the overhead of any fancy
caching schemes can be too high to consider.
We currently cache the last used vma for the whole address space, which
provides a nice optimization, reducing the total cycles in find_vma() by
up to 250%, for workloads with good locality. On the other hand, this
simple scheme is pretty much useless for workloads with poor locality.
Analyzing ebizzy runs shows that, no matter how many threads are
running, the mmap_cache hit rate is less than 2%, and in many situations
below 1%.
The proposed approach is to replace this scheme with a small per-thread
cache, maximizing hit rates at a very low maintenance cost.
Invalidations are performed by simply bumping up a 32-bit sequence
number. The only expensive operation is in the rare case of a seq
number overflow, where all caches that share the same address space are
flushed. Upon a miss, the proposed replacement policy is based on the
page number that contains the virtual address in question. Concretely,
the following results are seen on an 80 core, 8 socket x86-64 box:
1) System bootup: Most programs are single threaded, so the per-thread
scheme does improve ~50% hit rate by just adding a few more slots to
the cache.
| caching scheme | hit-rate | cycles (billion) |
| baseline | 50.61% | 19.90 |
| patched | 73.45% | 13.58 |
2) Kernel build: This one is already pretty good with the current
approach as we're dealing with good locality.
| baseline | 75.28% | 11.03 |
| patched | 88.09% | 9.31 |
3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload.
| baseline | 70.66% | 17.14 |
| patched | 91.15% | 12.57 |
4) Ebizzy: There's a fair amount of variation from run to run, but this
approach always shows nearly perfect hit rates, while baseline is just
about non-existent. The amounts of cycles can fluctuate between
anywhere from ~60 to ~116 for the baseline scheme, but this approach
reduces it considerably. For instance, with 80 threads:
| baseline | 1.06% | 91.54 |
| patched | 99.97% | 14.18 |
[akpm@linux-foundation.org: fix nommu build, per Davidlohr]
[akpm@linux-foundation.org: document vmacache_valid() logic]
[akpm@linux-foundation.org: attempt to untangle header files]
[akpm@linux-foundation.org: add vmacache_find() BUG_ON]
[hughd@google.com: add vmacache_valid_mm() (from Oleg)]
[akpm@linux-foundation.org: adjust and enhance comments]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Michel Lespinasse <walken@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
commit 71b54f8263860a37dd9f50f81880a9d681fd9c10 upstream.
When choosing between doing an address space or ranged flush,
the x86 implementation of flush_tlb_mm_range takes into account
whether there are any large pages in the range. A per-page
flush typically requires fewer entries than would covered by a
single large page and the check is redundant.
There is one potential exception. THP migration flushes single
THP entries and it conceivably would benefit from flushing a
single entry instead of the mm. However, this flush is after a
THP allocation, copy and page table update potentially with any
other threads serialised behind it. In comparison to that, the
flush is noise. It makes more sense to optimise balancing to
require fewer flushes than to optimise the flush itself.
This patch deletes the redundant huge page check.
Tested-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Alex Shi <alex.shi@linaro.org>
Link: http://lkml.kernel.org/n/tip-sgei1drpOcburujPsfh6ovmo@git.kernel.org
commit 15aa368255f249df0b2af630c9487bb5471bd7da upstream.
NR_TLB_LOCAL_FLUSH_ALL is not always accounted for correctly and
the comparison with total_vm is done before taking
tlb_flushall_shift into account. Clean it up.
Reviewed-by: Alex Shi <alex.shi@linaro.org>
Link: http://lkml.kernel.org/n/tip-Iz5gcahrgskIldvukulzi0hh@git.kernel.org
commit ec65993443736a5091b68e80ff1734548944a4b8 upstream.
Bisection between 3.11 and 3.12 fingered commit 9824cf97 ("mm:
vmstats: tlb flush counters") to cause overhead problems.
The counters are undeniably useful but how often do we really
need to debug TLB flush related issues? It does not justify
taking the penalty everywhere so make it a debugging option.
Link: http://lkml.kernel.org/n/tip-XzxjntugxuwpxXhcrxqqh53b@git.kernel.org
commit eb35bdd7bca29a13c8ecd44e6fd747a84ce675db upstream.
Nathan reports that we leak TLS information from the parent context
during an exec, as we don't clear the TLS registers when flushing the
thread state.
This patch updates the flushing code so that we:
(1) Unconditionally zero the tpidr_el0 register (since this is fully
context switched for native tasks and zeroed for compat tasks)
(2) Zero the tp_value state in thread_info before clearing the
tpidrr0_el0 register for compat tasks (since this is only writable
by the set_tls compat syscall and therefore not fully switched).
A missing compiler barrier is also added to the compat set_tls syscall.
Acked-by: Nathan Lynch <Nathan_Lynch@mentor.com>
Reported-by: Nathan Lynch <Nathan_Lynch@mentor.com>
commit 608308682addfdc7b8e2aee88f0e028331d88e4d upstream.
get_system_type() is not thread-safe on OCTEON. It uses static data,
also more dangerous issue is that it's calling cvmx_fuse_read_byte()
every time without any synchronization. Currently it's possible to get
processes stuck looping forever in kernel simply by launching multiple
readers of /proc/cpuinfo:
(while true; do cat /proc/cpuinfo > /dev/null; done) &
Fix by initializing the system type string only once during the early
boot.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nsn.com>
Reviewed-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: http://patchwork.linux-mips.org/patch/7437/
Signed-off-by: James Hogan <james.hogan@imgtec.com>
commit 2e5767a27337812f6850b3fa362419e2f085e5c3 upstream.
In do_ade(), is_fpu_owner() isn't preempt-safe. For example, when an
unaligned ldc1 is executed, do_cpu() is called and then FPU will be
enabled (and TIF_USEDFPU will be set for the current process). Then,
do_ade() is called because the access is unaligned. If the current
process is preempted at this time, TIF_USEDFPU will be cleard. So when
the process is scheduled again, BUG_ON(!is_fpu_owner()) is triggered.
This small program can trigger this BUG in a preemptible kernel:
int main (int argc, char *argv[])
double u64[2];
while (1) {
asm volatile (
".set push \n\t"
".set noreorder \n\t"
"ldc1 $f3, 4(%0) \n\t"
".set pop \n\t"
::"r"(u64):
return 0;
V2: Remove the BUG_ON() unconditionally due to Paul's suggestion.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Signed-off-by: Jie Chen <chenj@lemote.com>
Signed-off-by: Rui Wang <wangr@lemote.com>
Cc: John Crispin <john@phrozen.org>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
commit 8393c524a25609a30129e4a8975cf3b91f6c16a5 upstream.
In commit 2c8c53e28f1 (MIPS: Optimize TLB handlers for Octeon CPUs)
build_r4000_tlb_refill_handler() is modified. But it doesn't compatible
with the original code in HUGETLB case. Because there is a copy & paste
error and one line of code is missing. It is very easy to produce a bug
with LTP's hugemmap05 test.
Signed-off-by: Binbin Zhou <zhoubb@lemote.com>
Patchwork: https://patchwork.linux-mips.org/patch/7496/
commit b1442d39fac2fcfbe6a4814979020e993ca59c9e upstream.
If one or more matching FCSR cause & enable bits are set in saved thread
context then when that context is restored the kernel will take an FP
exception. This is of course undesirable and considered an oops, leading
to the kernel writing a backtrace to the console and potentially
rebooting depending upon the configuration. Thus the kernel avoids this
situation by clearing the cause bits of the FCSR register when handling
FP exceptions and after emulating FP instructions.
However the kernel does not prevent userland from setting arbitrary FCSR
cause & enable bits via ptrace, using either the PTRACE_POKEUSR or
PTRACE_SETFPREGS requests. This means userland can trivially cause the
kernel to oops on any system with an FPU. Prevent this from happening
by clearing the cause bits when writing to the saved FCSR context via
ptrace.
This problem appears to exist at least back to the beginning of the git
era in the PTRACE_POKEUSR case.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: stable@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/7438/
commit ffc8415afab20bd97754efae6aad1f67b531132b upstream.
A GIC interrupt which is declared as having a GIC_MAP_TO_NMI_MSK
mapping causes the cpu parameter to gic_setup_intr() to be increased
to 32, causing memory corruption when pcpu_masks[] is written to again
later in the function.
Signed-off-by: Jeffrey Deans <jeffrey.deans@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/7375/
commit 7e467245bf5226db34c4b12d3cbacfa2f7a15a8b upstream.
We would get wrong results in compiler recomputed old_pmd. Avoid
that by using ACCESS_ONCE
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 969b7b208f7408712a3526856e4ae60ad13f6928 upstream.
As per ISA, for 4k base page size we compare 14..65 bits of VA specified
with the entry_VA in tlb. That implies we need to make sure we do a
tlbie with all the possible 4k va we used to access the 16MB hugepage.
With 64k base page size we compare 14..57 bits of VA. Hence we cannot
ignore the lower 24 bits of va while tlbie .We also cannot tlb
invalidate a 16MB entry with just one tlbie instruction because
we don't track which va was used to instantiate the tlb entry.
commit fc0479557572375100ef16c71170b29a98e0d69a upstream.
If we changed base page size of the segment, either via sub_page_protect
or via remap_4k_pfn, we do a demote_segment which doesn't flush the hash
table entries. We do a lazy hash page table flush for all mapped pages
in the demoted segment. This happens when we handle hash page fault for
these pages.
We use _PAGE_COMBO bit along with _PAGE_HASHPTE to indicate whether a
pte is backed by 4K hash pte. If we find _PAGE_COMBO not set on the pte,
that implies that we could possibly have older 64K hash pte entries in
the hash page table and we need to invalidate those entries.
Use _PAGE_COMBO to determine the page size with which we should
invalidate the hash table entries on unmap.
commit 629149fae478f0ac6bf705a535708b192e9c6b59 upstream.
for these pages.
Handle this correctly for 16M pages
commit fa1f8ae80f8bb996594167ff4750a0b0a5a5bb5d upstream.
The segment identifier and segment size will remain the same in
the loop, So we can compute it outside. We also change the
hugepage_invalidate interface so that we can use it the later patch
commit b0aa44a3dfae3d8f45bd1264349aa87f87b7774f upstream.
With hugepages, we store the hpte valid information in the pte page
whose address is stored in the second half of the PMD. Use a
write barrier to make sure clearing pmd busy bit and updating
hpte valid info are ordered properly.
commit 5efbabe09d986f25c02d19954660238fcd7f008a upstream.
Function remove_ddw() could be called in of_reconfig_notifier and
we potentially remove the dynamic DMA window property, which invokes
of_reconfig_notifier again. Eventually, it leads to the deadlock as
following backtrace shows.
The patch fixes the above issue by deferring releasing the dynamic
DMA window property while releasing the device node.
[ INFO: possible recursive locking detected ]
3.16.0+ #428 Tainted: G W
drmgr/2273 is trying to acquire lock:
((of_reconfig_chain).rwsem){.+.+..}, at: [<c000000000091890>] \
.__blocking_notifier_call_chain+0x40/0x78
but task is already holding lock:
Possible unsafe locking scenario:
CPU0
lock((of_reconfig_chain).rwsem);
*** DEADLOCK ***
May be due to missing lock nesting notation
2 locks held by drmgr/2273:
#0: (sb_writers#4){.+.+.+}, at: [<c0000000001cbe70>] \
.vfs_write+0xb0/0x1f8
#1: ((of_reconfig_chain).rwsem){.+.+..}, at: [<c000000000091890>] \
stack backtrace:
CPU: 17 PID: 2273 Comm: drmgr Tainted: G W 3.16.0+ #428
Call Trace:
[c0000000137e7000] [c000000000013d9c] .show_stack+0x88/0x148 (unreliable)
[c0000000137e70b0] [c00000000083cd34] .dump_stack+0x7c/0x9c
[c0000000137e7130] [c0000000000b8afc] .__lock_acquire+0x128c/0x1c68
[c0000000137e7280] [c0000000000b9a4c] .lock_acquire+0xe8/0x104
[c0000000137e7350] [c00000000083588c] .down_read+0x4c/0x90
[c0000000137e73e0] [c000000000091890] .__blocking_notifier_call_chain+0x40/0x78
[c0000000137e7490] [c000000000091900] .blocking_notifier_call_chain+0x38/0x48
[c0000000137e7520] [c000000000682a28] .of_reconfig_notify+0x34/0x5c
[c0000000137e75b0] [c000000000682a9c] .of_property_notify+0x4c/0x54
[c0000000137e7650] [c000000000682bf0] .of_remove_property+0x30/0xd4
[c0000000137e76f0] [c000000000052a44] .remove_ddw+0x144/0x168
[c0000000137e7790] [c000000000053204] .iommu_reconfig_notifier+0x30/0xe0
[c0000000137e7820] [c00000000009137c] .notifier_call_chain+0x6c/0xb4
[c0000000137e78c0] [c0000000000918ac] .__blocking_notifier_call_chain+0x5c/0x78
[c0000000137e7970] [c000000000091900] .blocking_notifier_call_chain+0x38/0x48
[c0000000137e7a00] [c000000000682a28] .of_reconfig_notify+0x34/0x5c
[c0000000137e7a90] [c000000000682e14] .of_detach_node+0x44/0x1fc
[c0000000137e7b40] [c0000000000518e4] .ofdt_write+0x3ac/0x688
[c0000000137e7c20] [c000000000238430] .proc_reg_write+0xb8/0xd4
[c0000000137e7cd0] [c0000000001cbeac] .vfs_write+0xec/0x1f8
[c0000000137e7d70] [c0000000001cc3b0] .SyS_write+0x58/0xa0
[c0000000137e7e30] [c00000000000a064] syscall_exit+0x0/0x98
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit f1b3929c232784580e5d8ee324b6bc634e709575 upstream.
While running command "drmgr -c phb -r -s 'PHB 528'", following
backtrace jumped out because the target device node isn't marked
with OF_DETACHED by of_detach_node(), which caused by error
returned from memory hotplug related reconfig notifier when
disabling CONFIG_MEMORY_HOTREMOVE. The patch fixes it.
ERROR: Bad of_node_put() on /pci@800000020000210/ethernet@0
CPU: 14 PID: 2252 Comm: drmgr Tainted: G W 3.16.0+ #427
Call Trace:
[c000000012a776a0] [c000000000013d9c] .show_stack+0x88/0x148 (unreliable)
[c000000012a77750] [c00000000083cd34] .dump_stack+0x7c/0x9c
[c000000012a777d0] [c0000000006807c4] .of_node_release+0x58/0xe0
[c000000012a77860] [c00000000038a7d0] .kobject_release+0x174/0x1b8
[c000000012a77900] [c00000000038a884] .kobject_put+0x70/0x78
[c000000012a77980] [c000000000681680] .of_node_put+0x28/0x34
[c000000012a77a00] [c000000000681ea8] .__of_get_next_child+0x64/0x70
[c000000012a77a90] [c000000000682138] .of_find_node_by_path+0x1b8/0x20c
[c000000012a77b40] [c000000000051840] .ofdt_write+0x308/0x688
[c000000012a77c20] [c000000000238430] .proc_reg_write+0xb8/0xd4
[c000000012a77cd0] [c0000000001cbeac] .vfs_write+0xec/0x1f8
[c000000012a77d70] [c0000000001cc3b0] .SyS_write+0x58/0xa0
[c000000012a77e30] [c00000000000a064] syscall_exit+0x0/0x98
commit 85c1fafd7262e68ad821ee1808686b1392b1167d upstream.
On ppc64 we support 4K hash pte with 64K page size. That requires
us to track the hash pte slot information on a per 4k basis. We do that
by storing the slot details in the second half of pte page. The pte bit
_PAGE_COMBO is used to indicate whether the second half need to be
looked while building real_pte. We need to use read memory barrier while
doing that so that load of hidx is not reordered w.r.t _PAGE_COMBO
check. On the store side we already do a lwsync in __hash_page_4K
commit b00fc6ec1f24f9d7af9b8988b6a198186eb3408c upstream.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81631
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
commit 36e7fdaa1a04fcf65b864232e1af56a51c7814d6 upstream.
commit 4badad352a6bb202ec68afa7a574c0bb961e5ebc (locking/mutex: Disable
optimistic spinning on some architectures) fenced spinning for
architectures without proper cmpxchg.
There is no need to disable mutex spinning on s390, though:
The instructions CS,CSG and friends provide the proper guarantees.
(We dont implement cmpxchg with locks).
commit 39424e89d64661faa0a2e00c5ad1e6dbeebfa972 upstream.
Further discussion here: http://marc.info/?l=linux-kernel&m=139073901101034&w=2
kbuild, 0day kernel build service, outputs the warning:
arch/x86/kernel/irq.c:333:1: warning: the frame size of 2056 bytes
is larger than 2048 bytes [-Wframe-larger-than=]
because check_irq_vectors_for_cpu_disable() allocates two cpumasks on the
stack. Fix this by moving the two cpumasks to a global file context.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: David Rientjes <rientjes@google.com>
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Link: http://lkml.kernel.org/r/1390915331-27375-1-git-send-email-prarit@redhat.com
Cc: Michel Lespinasse <walken@google.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Yang Zhang <yang.z.zhang@Intel.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Janet Morgan <janet.morgan@intel.com>
Cc: Ruiv Wang <ruiv.wang@gmail.com>
Cc: Gong Chen <gong.chen@linux.intel.com>
Cc: Yinghai Lu <yinghai@kernel.org>
commit da6139e49c7cb0f4251265cb5243b8d220adb48d upstream.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=64791
When a cpu is downed on a system, the irqs on the cpu are assigned to
other cpus. It is possible, however, that when a cpu is downed there
aren't enough free vectors on the remaining cpus to account for the
vectors from the cpu that is being downed.
This results in an interesting "overflow" condition where irqs are
"assigned" to a CPU but are not handled.
For example, when downing cpus on a 1-64 logical processor system:
<snip>
[ 232.021745] smpboot: CPU 61 is now offline
[ 238.480275] smpboot: CPU 62 is now offline
[ 245.991080] ------------[ cut here ]------------
[ 245.996270] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:264 dev_watchdog+0x246/0x250()
[ 246.005688] NETDEV WATCHDOG: p786p1 (ixgbe): transmit queue 0 timed out
[ 246.013070] Modules linked in: lockd sunrpc iTCO_wdt iTCO_vendor_support sb_edac ixgbe microcode e1000e pcspkr joydev edac_core lpc_ich ioatdma ptp mdio mfd_core i2c_i801 dca pps_core i2c_core wmi acpi_cpufreq isci libsas scsi_transport_sas
[ 246.037633] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.12.0+ #14
[ 246.044451] Hardware name: Intel Corporation S4600LH ........../SVRBD-ROW_T, BIOS SE5C600.86B.01.08.0003.022620131521 02/26/2013
[ 246.057371] 0000000000000009 ffff88081fa03d40 ffffffff8164fbf6 ffff88081fa0ee48
[ 246.065728] ffff88081fa03d90 ffff88081fa03d80 ffffffff81054ecc ffff88081fa13040
[ 246.074073] 0000000000000000 ffff88200cce0000 0000000000000040 0000000000000000
[ 246.082430] Call Trace:
[ 246.085174] <IRQ> [<ffffffff8164fbf6>] dump_stack+0x46/0x58
[ 246.091633] [<ffffffff81054ecc>] warn_slowpath_common+0x8c/0xc0
[ 246.098352] [<ffffffff81054fb6>] warn_slowpath_fmt+0x46/0x50
[ 246.104786] [<ffffffff815710d6>] dev_watchdog+0x246/0x250
[ 246.110923] [<ffffffff81570e90>] ? dev_deactivate_queue.constprop.31+0x80/0x80
[ 246.119097] [<ffffffff8106092a>] call_timer_fn+0x3a/0x110
[ 246.125224] [<ffffffff8106280f>] ? update_process_times+0x6f/0x80
[ 246.132137] [<ffffffff81570e90>] ? dev_deactivate_queue.constprop.31+0x80/0x80
[ 246.140308] [<ffffffff81061db0>] run_timer_softirq+0x1f0/0x2a0
[ 246.146933] [<ffffffff81059a80>] __do_softirq+0xe0/0x220
[ 246.152976] [<ffffffff8165fedc>] call_softirq+0x1c/0x30
[ 246.158920] [<ffffffff810045f5>] do_softirq+0x55/0x90
[ 246.164670] [<ffffffff81059d35>] irq_exit+0xa5/0xb0
[ 246.170227] [<ffffffff8166062a>] smp_apic_timer_interrupt+0x4a/0x60
[ 246.177324] [<ffffffff8165f40a>] apic_timer_interrupt+0x6a/0x70
[ 246.184041] <EOI> [<ffffffff81505a1b>] ? cpuidle_enter_state+0x5b/0xe0
[ 246.191559] [<ffffffff81505a17>] ? cpuidle_enter_state+0x57/0xe0
[ 246.198374] [<ffffffff81505b5d>] cpuidle_idle_call+0xbd/0x200
[ 246.204900] [<ffffffff8100b7ae>] arch_cpu_idle+0xe/0x30
[ 246.210846] [<ffffffff810a47b0>] cpu_startup_entry+0xd0/0x250
[ 246.217371] [<ffffffff81646b47>] rest_init+0x77/0x80
[ 246.223028] [<ffffffff81d09e8e>] start_kernel+0x3ee/0x3fb
[ 246.229165] [<ffffffff81d0989f>] ? repair_env_string+0x5e/0x5e
[ 246.235787] [<ffffffff81d095a5>] x86_64_start_reservations+0x2a/0x2c
[ 246.242990] [<ffffffff81d0969f>] x86_64_start_kernel+0xf8/0xfc
[ 246.249610] ---[ end trace fb74fdef54d79039 ]---
[ 246.254807] ixgbe 0000:c2:00.0 p786p1: initiating reset due to tx timeout
[ 246.262489] ixgbe 0000:c2:00.0 p786p1: Reset adapter
Last login: Mon Nov 11 08:35:14 from 10.18.17.119
[root@(none) ~]# [ 246.792676] ixgbe 0000:c2:00.0 p786p1: detected SFP+: 5
[ 249.231598] ixgbe 0000:c2:00.0 p786p1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
(last lines keep repeating. ixgbe driver is dead until module reload.)
If the downed cpu has more vectors than are free on the remaining cpus on the
system, it is possible that some vectors are "orphaned" even though they are
assigned to a cpu. In this case, since the ixgbe driver had a watchdog, the
watchdog fired and notified that something was wrong.
This patch adds a function, check_vectors(), to compare the number of vectors
on the CPU going down and compares it to the number of vectors available on
the system. If there aren't enough vectors for the CPU to go down, an
error is returned and propogated back to userspace.
v2: Do not need to look at percpu irqs
v3: Need to check affinity to prevent counting of MSIs in IOAPIC Lowest
Priority Mode
v4: Additional changes suggested by Gong Chen.
v5/v6/v7/v8: Updated comment text
Link: http://lkml.kernel.org/r/1389613861-3853-1-git-send-email-prarit@redhat.com
Reviewed-by: Gong Chen <gong.chen@linux.intel.com>
Cc: <stable@vger.kernel.org>
commit 10f67dbf6add97751050f294d4c8e0cc1e5c2c23 upstream.
The mainline signal handling code for OpenRISC has been buggy since day
one with respect to syscall restart. This patch significantly reworks
the signal handling code:
i) Move the "work pending" loop to C code (borrowed from ARM arch)
ii) Allow a tracer to muck about with the IP and skip syscall restart
in that case (again, borrowed from ARM)
iii) Make signal handling WRT syscall restart actually work
v) Make the signal handling code look more like that of other
architectures so that it's easier for others to follow
Reported-by: Anders Nystrom <anders@southpole.se>
Signed-off-by: Jonas Bonn <jonas@southpole.se>
commit 8d5999df35314607c38fbd6bdd709e25c3a4eeab upstream.
If the timer irqs are resumed during device resume it is possible in
certain circumstances for the resume to hang early on, before device
interrupts are resumed. For an Ubuntu 14.04 PVHVM guest this would
occur in ~0.5% of resume attempts.
It is not entirely clear what is occuring the point of the hang but I
think a task necessary for the resume calls schedule_timeout(),
waiting for a timer interrupt (which never arrives). This failure may
require specific tasks to be running on the other VCPUs to trigger
(processes are not frozen during a suspend/resume if PREEMPT is
disabled).
Add IRQF_EARLY_RESUME to the timer interrupts so they are resumed in
syscore_resume().
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit 7b2a583afb4ab894f78bc0f8bd136e96b6499a7e upstream.
Without CONFIG_RELOCATABLE the early boot code will decompress the
kernel to LOAD_PHYSICAL_ADDR. While this may have been fine in the BIOS
days, that isn't going to fly with UEFI since parts of the firmware
code/data may be located at LOAD_PHYSICAL_ADDR.
Straying outside of the bounds of the regions we've explicitly requested
from the firmware will cause all sorts of trouble. Bruno reports that
his machine resets while trying to decompress the kernel image.
We already go to great pains to ensure the kernel is loaded into a
suitably aligned buffer, it's just that the address isn't necessarily
LOAD_PHYSICAL_ADDR, because we can't guarantee that address isn't in-use
by the firmware.
Explicitly enforce CONFIG_RELOCATABLE for the EFI boot stub, so that we
can load the kernel at any address with the correct alignment.
Reported-by: Bruno Prémont <bonbons@linux-vserver.org>
Tested-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit 53b884ac3745353de220d92ef792515c3ae692f0 upstream.
This commit in Linux 3.6:
commit c767a54ba0657e52e6edaa97cbe0b0a8bf1c1655
Author: Joe Perches <joe@perches.com>
Date: Mon May 21 19:50:07 2012 -0700
x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>
caused warn_bad_vsyscall to output garbage in the middle of the
line. Revert the bad part of it.
The printk in question isn't actually bare; the level is "%s".
The bug this fixes is purely cosmetic; backports are optional.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/03eac1f24110bbe496ecc12a4df467e0d88466d4.1406330947.git.luto@amacapital.net
commit cbace46a9710a480cae51e4611697df5de41713e upstream.
Commit 30919b0bf356 ("x86: avoid low BIOS area when allocating address
space") moved the test for resource allocations that fall within the first
1MB of address space from the PCI-specific path to a generic path, such
that all resource allocations will avoid this area. However, this breaks
ISA cards which need to allocate a memory region within the first 1MB. An
example is the i82365 PCMCIA controller and derivatives like the Ricoh
RF5C296/396 which map part of the PCMCIA socket memory address space into
the first 1MB of system memory address space. They do not work anymore as
no usable memory region exists due to this change:
Intel ISA PCIC probe: Ricoh RF5C296/396 ISA-to-PCMCIA at port 0x3e0 ofs 0x00, 2 sockets
host opts [0]: none
host opts [1]: none
ISA irqs (scanned) = 3,4,5,9,10 status change on irq 10
pcmcia_socket pcmcia_socket1: pccard: PCMCIA card inserted into slot 1
pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcff: excluding 0xcf8-0xcff
pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3ff: excluding 0x170-0x177 0x1f0-0x1f7 0x2f8-0x2ff 0x370-0x37f 0x3c0-0x3e7 0x3f0-0x3ff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0a0000-0x0affff: excluding 0xa0000-0xaffff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0b0000-0x0bffff: excluding 0xb0000-0xbffff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcbfff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0d0000-0x0dffff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0e0000-0x0effff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcff: excluding 0xcf8-0xcff
pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3ff: excluding 0x170-0x177 0x1f0-0x1f7 0x2f8-0x2ff 0x370-0x37f 0x3c0-0x3e7 0x3f0-0x3ff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0a0000-0x0affff: excluding 0xa0000-0xaffff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0b0000-0x0bffff: excluding 0xb0000-0xbffff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcbfff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0d0000-0x0dffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0e0000-0x0effff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x60000000-0x60ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0xa0000000-0xa0ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0cc000-0x0effff: excluding 0xe0000-0xeffff
pcmcia_socket pcmcia_socket1: cs: unable to map card memory!
If filtering out the first 1MB is reverted, everything works as expected.
Tested-by: Robert Resch <fli4l@robert.reschpara.de>
Signed-off-by: Christoph Schulz <develop@kristov.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 0d234daf7e0a3290a3a20c8087eefbd6335a5bd4 upstream.
This reverts commit 682367c494869008eb89ef733f196e99415ae862,
which causes 32-bit SMP Windows 7 guests to panic.
SeaBIOS has a limit on the number of MTRRs that it can handle,
and this patch exceeded the limit. Better revert it.
Thanks to Nadav Amit for debugging the cause.
Reported-by: Wanpeng Li <wanpeng.li@linux.intel.com>
commit 9e8919ae793f4edfaa29694a70f71a515ae9942a upstream.
Return unhandlable error on inter-privilege level ret instruction. This is
since the current emulation does not check the privilege level correctly when
loading the CS, and does not pop RSP/SS as needed.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
commit 9b5f7428f8b16bd8980213f2b70baf1dd0b9e36c upstream.
According to the comment “restore_es3: applies to 34xx >= ES3.0" in
"arch/arm/mach-omap2/sleep34xx.S”, omap3_restore_es3 should be used
if the revision of an OMAP34xx is ES3.1.2.
Signed-off-by: Jeremy Vial <jvial@adeneo-embedded.com>
