commit 2ec420b26f7b6ff332393f0bb5a7d245f7ad87f0 upstream.
The inline asm retry check in the MIPS_ATOMIC_SET operation of the
sysmips system call has been backwards since commit f1e39a4a616c ("MIPS:
Rewrite sysmips(MIPS_ATOMIC_SET, ...) in C with inline assembler")
merged in v2.6.32, resulting in the non R10000_LLSC_WAR case retrying
until the operation was inatomic, before returning the new value that
was probably just written multiple times instead of the old value.
Invert the branch condition to fix that particular issue.
Fixes: f1e39a4a616c ("MIPS: Rewrite sysmips(MIPS_ATOMIC_SET, ...) in C with inline assembler")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/16148/
commit c46fc0424ced3fb71208e72bd597d91b9169a781 upstream.
Zorro reported following crash while having enabled
syscall tracing (CONFIG_FTRACE_SYSCALLS):
Unable to handle kernel pointer dereference at virtual ...
Oops: 0011 [#1] SMP DEBUG_PAGEALLOC
SNIP
Call Trace:
([<000000000024d79c>] ftrace_syscall_enter+0xec/0x1d8)
[<00000000001099c6>] do_syscall_trace_enter+0x236/0x2f8
[<0000000000730f1c>] sysc_tracesys+0x1a/0x32
[<000003fffcf946a2>] 0x3fffcf946a2
INFO: lockdep is turned off.
Last Breaking-Event-Address:
[<000000000022dd44>] rb_event_data+0x34/0x40
---[ end trace 8c795f86b1b3f7b9 ]---
The crash happens in syscall_get_arguments function for
syscalls with zero arguments, that will try to access
first argument (args[0]) in event entry, but it's not
allocated.
Bail out of there are no arguments.
Reported-by: Zorro Lang <zlang@redhat.com>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
commit c54590cac51db8ab5fd30156bdaba34af915e629 upstream.
Userspace application can do a hypercall through /dev/xen/privcmd, and
some for some hypercalls argument is a pointers to user-provided
structure. When SMAP is supported and enabled, hypervisor can't access.
So, lets allow it.
The same applies to HYPERVISOR_dm_op, where additionally privcmd driver
carefully verify buffer addresses.
Cc: stable@vger.kernel.org
Signed-off-by: Marek Marczykowski-Górecki <marmarek@invisiblethingslab.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
[HYPERVISOR_dm_op dropped - not present until 4.11]
Signed-off-by: Juergen Gross <jgross@suse.com>
commit 13cfc732160f7bc7e596128ce34cda361c556966 upstream.
Neither soft poweroff (transition to ACPI power state S5) nor
suspend-to-RAM (transition to state S3) works on the Macbook Pro 11,4 and
11,5.
The problem is related to the [mem 0x7fa00000-0x7fbfffff] space. When we
use that space, e.g., by assigning it to the 00:1c.0 Root Port, the ACPI
Power Management 1 Control Register (PM1_CNT) at [io 0x1804] doesn't work
anymore.
Linux does a soft poweroff (transition to S5) by writing to PM1_CNT. The
theory about why this doesn't work is:
- The write to PM1_CNT causes an SMI
- The BIOS SMI handler depends on something in
- When Linux assigns [mem 0x7fa00000-0x7fbfffff] to the 00:1c.0 Port, it
covers up whatever the SMI handler uses, so the SMI handler no longer
works correctly
Reserve the [mem 0x7fa00000-0x7fbfffff] space so we don't assign it to
anything.
This is voodoo programming, since we don't know what the real conflict is,
but we've failed to find the root cause.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=103211
Tested-by: thejoe@gmail.com
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Rafael J. Wysocki <rafael@kernel.org>
Cc: Lukas Wunner <lukas@wunner.de>
Cc: Chen Yu <yu.c.chen@intel.com>
commit c6bb0b8d426a8cf865ca9c8a532cc3a2927cfceb upstream.
On radix, the process table entry we want to clear when destroying a
context is entry 0, not entry 1. This has no *immediate* consequence
on Power9, but it can cause other bugs to become worse.
Fixes: 7e381c0ff618 ("powerpc/mm/radix: Add mmu context handling callback for radix")
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 2400fd822f467cb4c886c879d8ad99feac9cf319 upstream.
The workaround for the CELL timebase bug does not correctly mark cr0 as
being clobbered. This means GCC doesn't know that the asm block changes cr0 and
might leave the result of an unrelated comparison in cr0 across the block, which
we then trash, leading to basically random behaviour.
Fixes: 859deea949c3 ("[POWERPC] Cell timebase bug workaround")
Signed-off-by: Oliver O'Halloran <oohall@gmail.com>
[mpe: Tweak change log and flag for stable]
commit 64e756c55aa46fc18fd53e8f3598b73b528d8637 upstream.
From POWER4 onwards, mfocrf() only places the specified CR field into
the destination GPR, and the rest of it is set to 0. The PowerPC AS
from version 3.0 now requires this behaviour.
The emulation code currently puts the entire CR into the destination GPR.
Fix it.
Fixes: 6888199f7fe5 ("[POWERPC] Emulate more instructions in software")
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit 87c4b83e0fe234a1f0eed131ab6fa232036860d5 upstream.
The mcrf emulation code was using the CR field number directly as the shift
value, without taking into account that CR fields are numbered from 0-7 starting
at the high bits. That meant it was looking at the CR fields in the reverse
order.
Fixes: cf87c3f6b647 ("powerpc: Emulate icbi, mcrf and conditional-trap instructions")
commit 01e6a61aceb82e13bec29502a8eb70d9574f97ad upstream.
Although it's not documented anywhere, there is an expectation that
atomic64_inc_not_zero() returns a result which fits in an int. This is
the behaviour implemented on all arches except powerpc.
This has caused at least one bug in practice, in the percpu-refcount
code, where the long result from our atomic64_inc_not_zero() was
truncated to an int leading to lost references and stuck systems. That
was worked around in that code in commit 966d2b04e070 ("percpu-refcount:
fix reference leak during percpu-atomic transition").
To the best of my grepping abilities there are no other callers
in-tree which truncate the value, but we should fix it anyway. Because
the breakage is subtle and potentially very harmful I'm also tagging
it for stable.
Code generation is largely unaffected because in most cases the
callers are just using the result for a test anyway. In particular the
case of fget() that was mentioned in commit a6cf7ed5119f
("powerpc/atomic: Implement atomic*_inc_not_zero") generates exactly
the same code.
Fixes: a6cf7ed5119f ("powerpc/atomic: Implement atomic*_inc_not_zero")
Noticed-by: Linus Torvalds <torvalds@linux-foundation.org>
commit e71ff982ae4c17d176e9f0132157d54973788377 upstream.
Once upon a time there were only two PP (page protection) bits. In ISA
2.03 an additional PP bit was added, but because of the layout of the
HPTE it could not be made contiguous with the existing PP bits.
The result is that we now have three PP bits, named pp0, pp1, pp2,
where pp0 occupies bit 63 of dword 1 of the HPTE and pp1 and pp2
occupy bits 1 and 0 respectively. Until recently Linux hasn't used
pp0, however with the addition of _PAGE_KERNEL_RO we started using it.
The problem arises in the LPAR code, where we need to translate the PP
bits into the argument for the H_PROTECT hypercall. Currently the code
only passes bits 0-2 of newpp, which covers pp1, pp2 and N (no
execute), meaning pp0 is not passed to the hypervisor at all.
We can't simply pass it through in bit 63, as that would collide with a
different field in the flags argument, as defined in PAPR. Instead we
have to shift it down to bit 8 (IBM bit 55).
Fixes: e58e87adc8bf ("powerpc/mm: Update _PAGE_KERNEL_RO")
Signed-off-by: Balbir Singh <bsingharora@gmail.com>
[mpe: Simplify the test, rework change log]
commit 691bd4340bef49cf7e5855d06cf24444b5bf2d85 upstream.
It's easier for host applications, such as QEMU, if they can always
access guest MSR_IA32_BNDCFGS in VMCS, even though MPX is disabled in
guest cpuid.
Signed-off-by: Haozhong Zhang <haozhong.zhang@intel.com>
commit 4531662d1abf6c1f0e5c2b86ddb60e61509786c8 upstream.
Bits 11:2 must be zero and the linear addess in bits 63:12 must be
canonical. Otherwise, WRMSR(BNDCFGS) should raise #GP.
Fixes: 0dd376e709975779 ("KVM: x86: add MSR_IA32_BNDCFGS to msrs_to_save")
Signed-off-by: Jim Mattson <jmattson@google.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 4439af9f911ae0243ffe4e2dfc12bace49605d8b upstream.
The BNDCFGS MSR should only be exposed to the guest if the guest
supports MPX. (cf. the TSC_AUX MSR and RDTSCP.)
Change-Id: I3ad7c01bda616715137ceac878f3fa7e66b6b387
commit a8b6fda38f80e75afa3b125c9e7f2550b579454b upstream.
The MSR permission bitmaps are shared by all VMs. However, some VMs
may not be configured to support MPX, even when the host does. If the
host supports VMX and the guest does not, we should intercept accesses
to the BNDCFGS MSR, so that we can synthesize a #GP
fault. Furthermore, if the host does not support MPX and the
"ignore_msrs" kvm kernel parameter is set, then we should intercept
accesses to the BNDCFGS MSR, so that we can skip over the rdmsr/wrmsr
without raising a #GP fault.
Fixes: da8999d31818fdc8 ("KVM: x86: Intel MPX vmx and msr handle")
commit b82ce24426a4071da9529d726057e4e642948667 upstream.
It has been reported that sha1-avx2 can cause page faults by reading
beyond the end of the input. This patch disables it until it can be
fixed.
Fixes: 7c1da8d0d046 ("crypto: sha - SHA1 transform x86_64 AVX2")
Reported-by: Jan Stancek <jstancek@redhat.com>
commit 88cda00733f0731711c76e535d4972c296ac512e upstream.
Contrary to popular belief, PPIs connected to a GICv3 to not have
an affinity field similar to that of GICv2. That is consistent
with the fact that GICv3 is designed to accomodate thousands of
CPUs, and fitting them as a bitmap in a byte is... difficult.
Fixes: adbc3695d9e4 ("arm64: dts: add the Marvell Armada 3700 family and a development board")
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit a73dc5370e153ac63718d850bddf0c9aa9d871e6 upstream.
Now that explicitly executed loaders are loaded in the mmap region, we
have more freedom to decide where we position PIE binaries in the
address space to avoid possible collisions with mmap or stack regions.
For 64-bit, align to 4GB to allow runtimes to use the entire 32-bit
address space for 32-bit pointers. On 32-bit use 4MB, which is the
traditional x86 minimum load location, likely to avoid historically
requiring a 4MB page table entry when only a portion of the first 4MB
would be used (since the NULL address is avoided). For s390 the
position could be 0x10000, but that is needlessly close to the NULL
address.
Link: http://lkml.kernel.org/r/1498154792-49952-5-git-send-email-keescook@chromium.org
Cc: Russell King <linux@armlinux.org.uk>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Pratyush Anand <panand@redhat.com>
commit 47ebb09d54856500c5a5e14824781902b3bb738e upstream.
Link: http://lkml.kernel.org/r/1498154792-49952-4-git-send-email-keescook@chromium.org
Tested-by: Michael Ellerman <mpe@ellerman.id.au>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
commit 02445990a96e60a67526510d8b00f7e3d14101c3 upstream.
address space for 32-bit pointers. On 32-bit use 4MB, to match ARM.
This could be 0x8000, the standard ET_EXEC load address, but that is
needlessly close to the NULL address, and anyone running arm compat PIE
will have an MMU, so the tight mapping is not needed.
Link: http://lkml.kernel.org/r/1498251600-132458-4-git-send-email-keescook@chromium.org
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Mark Rutland <mark.rutland@arm.com>
commit 6a9af90a3bcde217a1c053e135f5f43e5d5fafbd upstream.
4MB is chosen here mainly to have parity with x86, where this is the
traditional minimum load location, likely to avoid historically
For ARM the position could be 0x8000, the standard ET_EXEC load address,
but that is needlessly close to the NULL address, and anyone running PIE
on 32-bit ARM will have an MMU, so the tight mapping is not needed.
Link: http://lkml.kernel.org/r/1498154792-49952-2-git-send-email-keescook@chromium.org
Cc: Daniel Micay <danielmicay@gmail.com>
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: Grzegorz Andrejczuk <grzegorz.andrejczuk@intel.com>
Cc: Qualys Security Advisory <qsa@qualys.com>
commit eab09532d40090698b05a07c1c87f39fdbc5fab5 upstream.
The ELF_ET_DYN_BASE position was originally intended to keep loaders
away from ET_EXEC binaries. (For example, running "/lib/ld-linux.so.2
/bin/cat" might cause the subsequent load of /bin/cat into where the
loader had been loaded.)
With the advent of PIE (ET_DYN binaries with an INTERP Program Header),
ELF_ET_DYN_BASE continued to be used since the kernel was only looking
at ET_DYN. However, since ELF_ET_DYN_BASE is traditionally set at the
top 1/3rd of the TASK_SIZE, a substantial portion of the address space
is unused.
For 32-bit tasks when RLIMIT_STACK is set to RLIM_INFINITY, programs are
loaded above the mmap region. This means they can be made to collide
(CVE-2017-1000370) or nearly collide (CVE-2017-1000371) with
pathological stack regions.
Lowering ELF_ET_DYN_BASE solves both by moving programs below the mmap
region in all cases, and will now additionally avoid programs falling
back to the mmap region by enforcing MAP_FIXED for program loads (i.e.
if it would have collided with the stack, now it will fail to load
instead of falling back to the mmap region).
To allow for a lower ELF_ET_DYN_BASE, loaders (ET_DYN without INTERP)
are loaded into the mmap region, leaving space available for either an
ET_EXEC binary with a fixed location or PIE being loaded into mmap by
the loader. Only PIE programs are loaded offset from ELF_ET_DYN_BASE,
which means architectures can now safely lower their values without risk
of loaders colliding with their subsequently loaded programs.
For 64-bit, ELF_ET_DYN_BASE is best set to 4GB to allow runtimes to use
the entire 32-bit address space for 32-bit pointers.
Thanks to PaX Team, Daniel Micay, and Rik van Riel for inspiration and
suggestions on how to implement this solution.
Fixes: d1fd836dcf00 ("mm: split ET_DYN ASLR from mmap ASLR")
Link: http://lkml.kernel.org/r/20170621173201.GA114489@beast
commit 649aa24254e85bf6bd7807dd372d083707852b1f upstream.
This is because of commit f98db6013c55 ("sched/core: Add switch_mm_irqs_off()
and use it in the scheduler") in which switch_mm_irqs_off() is called by the
scheduler, vs switch_mm() which is used by use_mm().
This patch lets the parisc code mirror the x86 and powerpc code, ie. it
disables interrupts in switch_mm(), and optimises the scheduler case by
defining switch_mm_irqs_off().
Signed-off-by: Helge Deller <deller@gmx.de>
commit 33f9e02495d15a061f0c94ef46f5103a2d0c20f3 upstream.
Enabling parport pc driver on a B2600 (and probably other 64bit PARISC
systems) produced following BUG:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.12.0-rc5-30198-g1132d5e #156
task: 000000009e050000 task.stack: 000000009e04c000
YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI
PSW: 00001000000001101111111100001111 Not tainted
r00-03 000000ff0806ff0f 000000009e04c990 0000000040871b78 000000009e04cac0
r04-07 0000000040c14de0 ffffffffffffffff 000000009e07f098 000000009d82d200
r08-11 000000009d82d210 0000000000000378 0000000000000000 0000000040c345e0
r12-15 0000000000000005 0000000040c345e0 0000000000000000 0000000040c9d5e0
r16-19 0000000040c345e0 00000000f00001c4 00000000f00001bc 0000000000000061
r20-23 000000009e04ce28 0000000000000010 0000000000000010 0000000040b89e40
r24-27 0000000000000003 0000000000ffffff 000000009d82d210 0000000040c14de0
r28-31 0000000000000000 000000009e04ca90 000000009e04cb40 0000000000000000
sr00-03 0000000000000000 0000000000000000 0000000000000000 0000000000000000
sr04-07 0000000000000000 0000000000000000 0000000000000000 0000000000000000
IASQ: 0000000000000000 0000000000000000 IAOQ: 00000000404aece0 00000000404aece4
IIR: 03ffe01f ISR: 0000000010340000 IOR: 000001781304cac8
CPU: 0 CR30: 000000009e04c000 CR31: 00000000e2976de2
ORIG_R28: 0000000000000200
IAOQ[0]: sba_dma_supported+0x80/0xd0
IAOQ[1]: sba_dma_supported+0x84/0xd0
RP(r2): parport_pc_probe_port+0x178/0x1200
Cause is a call to dma_coerce_mask_and_coherenet in parport_pc_probe_port,
which PARISC DMA API doesn't handle very nicely. This commit gives back
DMA_ERROR_CODE for DMA API calls, if device isn't capable of DMA
transaction.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
commit b0f94efd5aa8daa8a07d7601714c2573266cd4c9 upstream.
Architectures with a compat syscall table must put compat_sys_keyctl()
in it, not sys_keyctl(). The parisc architecture was not doing this;
fix it.
Acked-by: Helge Deller <deller@gmx.de>
commit 247462316f85a9e0479445c1a4223950b68ffac1 upstream.
When a process runs out of stack the parisc kernel wrongly faults with SIGBUS
instead of the expected SIGSEGV signal.
This example shows how the kernel faults:
do_page_fault() command='a.out' type=15 address=0xfaac2000 in libc-2.24.so[f8308000+16c000]
trap #15: Data TLB miss fault, vm_start = 0xfa2c2000, vm_end = 0xfaac2000
The vma->vm_end value is the first address which does not belong to the vma, so
adjust the check to include vma->vm_end to the range for which to send the
SIGSEGV signal.
This patch unbreaks building the debian libsigsegv package.
commit 99c13b8c8896d7bcb92753bf0c63a8de4326e78d upstream.
The pat_enabled() logic is broken on CPUs which do not support PAT and
where the initialization code fails to call pat_init(). Due to that the
enabled flag stays true and pat_enabled() returns true wrongfully.
As a consequence the mappings, e.g. for Xorg, are set up with the wrong
caching mode and the required MTRR setups are omitted.
To cure this the following changes are required:
1) Make pat_enabled() return true only if PAT initialization was
invoked and successful.
2) Invoke init_cache_modes() unconditionally in setup_arch() and
remove the extra callsites in pat_disable() and the pat disabled
code path in pat_init().
Also rename __pat_enabled to pat_disabled to reflect the real purpose of
this variable.
Fixes: 9cd25aac1f44 ("x86/mm/pat: Emulate PAT when it is disabled")
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Bernhard Held <berny156@gmx.de>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: "Luis R. Rodriguez" <mcgrof@suse.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1707041749300.3456@file01.intranet.prod.int.rdu2.redhat.com
commit 236222d39347e0e486010f10c1493e83dbbdfba8 upstream.
According to the Intel datasheet, the REP MOVSB instruction
exposes a pretty heavy setup cost (50 ticks), which hurts
short string copy operations.
This change tries to avoid this cost by calling the explicit
loop available in the unrolled code for strings shorter
than 64 bytes.
The 64 bytes cutoff value is arbitrary from the code logic
point of view - it has been selected based on measurements,
as the largest value that still ensures a measurable gain.
Micro benchmarks of the __copy_from_user() function with
lengths in the [0-63] range show this performance gain
(shorter the string, larger the gain):
- in the [55%-4%] range on Intel Xeon(R) CPU E5-2690 v4
- in the [72%-9%] range on Intel Core i7-4810MQ
Other tested CPUs - namely Intel Atom S1260 and AMD Opteron
8216 - show no difference, because they do not expose the
ERMS feature bit.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Link: http://lkml.kernel.org/r/4533a1d101fd460f80e21329a34928fad521c1d4.1498744345.git.pabeni@redhat.com
[ Clarified the changelog. ]
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
commit 7ebb916782949621ff6819acf373a06902df7679 upstream.
gcc-7 warns:
In file included from arch/x86/tools/relocs_64.c:17:0:
arch/x86/tools/relocs.c: In function ‘process_64’:
arch/x86/tools/relocs.c:953:2: warning: argument 1 null where non-null expected [-Wnonnull]
qsort(r->offset, r->count, sizeof(r->offset[0]), cmp_relocs);
In file included from arch/x86/tools/relocs.h:6:0,
from arch/x86/tools/relocs_64.c:1:
/usr/include/stdlib.h:741:13: note: in a call to function ‘qsort’ declared here
extern void qsort
This happens because relocs16 is not used for ELF_BITS == 64,
so there is no point in trying to sort it.
Make the sort_relocs(&relocs16) call 32bit only.
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Link: http://lkml.kernel.org/r/20161215124513.GA289@x4
commit d4912215d1031e4fb3d1038d2e1857218dba0d0a upstream.
WARNING: CPU: 3 PID: 2840 at arch/x86/kvm/vmx.c:10966 nested_vmx_vmexit+0xdcd/0xde0 [kvm_intel]
CPU: 3 PID: 2840 Comm: qemu-system-x86 Tainted: G OE 4.12.0-rc3+ #23
RIP: 0010:nested_vmx_vmexit+0xdcd/0xde0 [kvm_intel]
Call Trace:
? kvm_check_async_pf_completion+0xef/0x120 [kvm]
? rcu_read_lock_sched_held+0x79/0x80
vmx_queue_exception+0x104/0x160 [kvm_intel]
? vmx_queue_exception+0x104/0x160 [kvm_intel]
kvm_arch_vcpu_ioctl_run+0x1171/0x1ce0 [kvm]
? kvm_arch_vcpu_load+0x47/0x240 [kvm]
? kvm_arch_vcpu_load+0x62/0x240 [kvm]
kvm_vcpu_ioctl+0x384/0x7b0 [kvm]
? kvm_vcpu_ioctl+0x384/0x7b0 [kvm]
? __fget+0xf3/0x210
do_vfs_ioctl+0xa4/0x700
? __fget+0x114/0x210
SyS_ioctl+0x79/0x90
do_syscall_64+0x81/0x220
entry_SYSCALL64_slow_path+0x25/0x25
This is triggered occasionally by running both win7 and win2016 in L2, in
addition, EPT is disabled on both L1 and L2. It can't be reproduced easily.
Commit 0b6ac343fc (KVM: nVMX: Correct handling of exception injection) mentioned
that "KVM wants to inject page-faults which it got to the guest. This function
assumes it is called with the exit reason in vmcs02 being a #PF exception".
Commit e011c663 (KVM: nVMX: Check all exceptions for intercept during delivery to
L2) allows to check all exceptions for intercept during delivery to L2. However,
there is no guarantee the exit reason is exception currently, when there is an
external interrupt occurred on host, maybe a time interrupt for host which should
not be injected to guest, and somewhere queues an exception, then the function
nested_vmx_check_exception() will be called and the vmexit emulation codes will
try to emulate the "Acknowledge interrupt on exit" behavior, the warning is
triggered.
Reusing the exit reason from the L2->L0 vmexit is wrong in this case,
the reason must always be EXCEPTION_NMI when injecting an exception into
L1 as a nested vmexit.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Fixes: e011c663b9c7 ("KVM: nVMX: Check all exceptions for intercept during delivery to L2")
commit f0367ee1d64d27fa08be2407df5c125442e885e3 upstream.
Static checker noticed that base3 could be used uninitialized if the
segment was not present (useable). Random stack values probably would
not pass VMCS entry checks.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: 1aa366163b8b ("KVM: x86 emulator: consolidate segment accessors")
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
commit 34b0dadbdf698f9b277a31b2747b625b9a75ea1f upstream.
Static analysis noticed that pmu->nr_arch_gp_counters can be 32
(INTEL_PMC_MAX_GENERIC) and therefore cannot be used to shift 'int'.
I didn't add BUILD_BUG_ON for it as we have a better checker.
Fixes: 25462f7f5295 ("KVM: x86/vPMU: Define kvm_pmu_ops to support vPMU function dispatch")
commit 6ed071f051e12cf7baa1b69d3becb8f232fdfb7b upstream.
On AMD, the effect of set_nmi_mask called by emulate_iret_real and em_rsm
on hflags is reverted later on in x86_emulate_instruction where hflags are
overwritten with ctxt->emul_flags (the kvm_set_hflags call). This manifests
as a hang when rebooting Windows VMs with QEMU, OVMF, and >1 vcpu.
Instead of trying to merge ctxt->emul_flags into vcpu->arch.hflags after
an instruction is emulated, this commit deletes emul_flags altogether and
makes the emulator access vcpu->arch.hflags using two new accessors. This
way all changes, on the emulator side as well as in functions called from
the emulator and accessing vcpu state with emul_to_vcpu, are preserved.
More details on the bug and its manifestation with Windows and OVMF:
It's a KVM bug in the interaction between SMI/SMM and NMI, specific to AMD.
I believe that the SMM part explains why we started seeing this only with
OVMF.
KVM masks and unmasks NMI when entering and leaving SMM. When KVM emulates
the RSM instruction in em_rsm, the set_nmi_mask call doesn't stick because
later on in x86_emulate_instruction we overwrite arch.hflags with
ctxt->emul_flags, effectively reverting the effect of the set_nmi_mask call.
The AMD-specific hflag of interest here is HF_NMI_MASK.
When rebooting the system, Windows sends an NMI IPI to all but the current
cpu to shut them down. Only after all of them are parked in HLT will the
initiating cpu finish the restart. If NMI is masked, other cpus never get
the memo and the initiating cpu spins forever, waiting for
hal!HalpInterruptProcessorsStarted to drop. That's the symptom we observe.
Fixes: a584539b24b8 ("KVM: x86: pass the whole hflags field to emulator and back")
Signed-off-by: Ladi Prosek <lprosek@redhat.com>
commit 335d2c2d192266358c5dfa64953a4c162f46e464 upstream.
Commit 5c492c3f5255 ("arm64: smp: Add function to determine if cpus are
stuck in the kernel") added a helper function to determine if die() is
supported in cpu_ops. This function assumes a cpu will have a valid
cpu_ops entry, but that may not be the case for cpu0 is spin-table or
parking protocol is used to boot secondary cpus. In that case, there
is a NULL dereference if have_cpu_die() is called by cpu0. So add a
check for a valid cpu_ops before dereferencing it.
Fixes: 5c492c3f5255 ("arm64: smp: Add function to determine if cpus are stuck in the kernel")
Signed-off-by: Mark Salter <msalter@redhat.com>
commit dbd68d8e84c606673ebbcf15862f8c155fa92326 upstream.
flush_tlb_page() passes a bogus range to flush_tlb_others() and
expects the latter to fix it up. native_flush_tlb_others() has the
fixup but Xen's version doesn't. Move the fixup to
flush_tlb_others().
AFAICS the only real effect is that, without this fix, Xen would
flush everything instead of just the one page on remote vCPUs in
when flush_tlb_page() was called.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Nadav Amit <namit@vmware.com>
Fixes: e7b52ffd45a6 ("x86/flush_tlb: try flush_tlb_single one by one in flush_tlb_range")
Link: http://lkml.kernel.org/r/10ed0e4dfea64daef10b87fb85df1746999b4dba.1492844372.git.luto@kernel.org
commit 5ed386ec09a5d75bcf073967e55e895c2607a5c3 upstream.
When this function fails it just sends a SIGSEGV signal to
user-space using force_sig(). This signal is missing
essential information about the cause, e.g. the trap_nr or
an error code.
Fix this by propagating the error to the only caller of
mpx_handle_bd_fault(), do_bounds(), which sends the correct
SIGSEGV signal to the process.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Fixes: fe3d197f84319 ('x86, mpx: On-demand kernel allocation of bounds tables')
Link: http://lkml.kernel.org/r/1491488362-27198-1-git-send-email-joro@8bytes.org
commit 8eabf42ae5237e6b699aeac687b5b629e3537c8d upstream.
Kernel text KASLR is separated into physical address and virtual
address randomization. And for virtual address randomization, we
only randomiza to get an offset between 16M and KERNEL_IMAGE_SIZE.
So the initial value of 'virt_addr' should be LOAD_PHYSICAL_ADDR,
but not the original kernel loading address 'output'.
The bug will cause kernel boot failure if kernel is loaded at a different
position than the address, 16M, which is decided at compiled time.
Kexec/kdump is such practical case.
To fix it, just assign LOAD_PHYSICAL_ADDR to virt_addr as initial
value.
Tested-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Baoquan He <bhe@redhat.com>
Fixes: 8391c73 ("x86/KASLR: Randomize virtual address separately")
Link: http://lkml.kernel.org/r/1498567146-11990-3-git-send-email-bhe@redhat.com
commit 9e25ebfe56ece7541cd10a20d715cbdd148a2e06 upstream.
The pmd containing memblock_limit is cleared by prepare_page_table()
which creates the opportunity for early_alloc() to allocate unmapped
memory if memblock_limit is not pmd aligned causing a boot-time hang.
Commit 965278dcb8ab ("ARM: 8356/1: mm: handle non-pmd-aligned end of RAM")
attempted to resolve this problem, but there is a path through the
adjust_lowmem_bounds() routine where if all memory regions start and
end on pmd-aligned addresses the memblock_limit will be set to
arm_lowmem_limit.
Since arm_lowmem_limit can be affected by the vmalloc early parameter,
the value of arm_lowmem_limit may not be pmd-aligned. This commit
corrects this oversight such that memblock_limit is always rounded
down to pmd-alignment.
Fixes: 965278dcb8ab ("ARM: 8356/1: mm: handle non-pmd-aligned end of RAM")
Signed-off-by: Doug Berger <opendmb@gmail.com>
Suggested-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit cb7cf772d83d2d4e6995c5bb9e0fb59aea8f7080 upstream.
The BAD_MADT_GICC_ENTRY() macro checks if a GICC MADT entry passes
muster from an ACPI specification standpoint. Current macro detects the
MADT GICC entry length through ACPI firmware version (it changed from 76
to 80 bytes in the transition from ACPI 5.1 to ACPI 6.0 specification)
but always uses (erroneously) the ACPICA (latest) struct (ie struct
acpi_madt_generic_interrupt - that is 80-bytes long) length to check if
the current GICC entry memory record exceeds the MADT table end in
memory as defined by the MADT table header itself, which may result in
false negatives depending on the ACPI firmware version and how the MADT
entries are laid out in memory (ie on ACPI 5.1 firmware MADT GICC
entries are 76 bytes long, so by adding 80 to a GICC entry start address
in memory the resulting address may well be past the actual MADT end,
triggering a false negative).
Fix the BAD_MADT_GICC_ENTRY() macro by reshuffling the condition checks
and update them to always use the firmware version specific MADT GICC
entry length in order to carry out boundary checks.
Fixes: b6cfb277378e ("ACPI / ARM64: add BAD_MADT_GICC_ENTRY() macro")
Reported-by: Julien Grall <julien.grall@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Julien Grall <julien.grall@arm.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Al Stone <ahs3@redhat.com>
commit 06e1a5cc570703796ff1bd3a712e8e3b15c6bb0d upstream.
The manufacturing information is stored in the EEPROM. This chip
is an AT24C64 not not (nor has it ever been) 24C02. This patch will
correctly address the EEPROM to read the entire contents and not just
256 bytes (of 0xff).
Fixes: 5e3447a29a38 ("ARM: dts: LogicPD Torpedo: Add AT24 EEPROM Support")
commit 04abaf07f6d5cdf22b7a478a86e706dfeeeef960 upstream.
Starting from commit 5de85b9d57ab ("PM / runtime: Re-init runtime PM
states at probe error and driver unbind") pm_runtime core now changes
device runtime_status back to after RPM_SUSPENDED after a probe defer.
Certain OMAP devices make use of "ti,no-idle-on-init" flag which causes
omap_device_enable to be called during the BUS_NOTIFY_ADD_DEVICE event
during probe, along with pm_runtime_set_active.
This call to pm_runtime_set_active typically will prevent a call to
pm_runtime_get in a driver probe function from re-enabling the
omap_device. However, in the case of a probe defer that happens before
the driver probe function is able to run, such as a missing pinctrl
states defer, pm_runtime_reinit will set the device as RPM_SUSPENDED and
then once driver probe is actually able to run, pm_runtime_get will see
the device as suspended and call through to the omap_device layer,
attempting to enable the already enabled omap_device and causing errors
like this:
omap-gpmc 50000000.gpmc: omap_device: omap_device_enable() called from
invalid state 1
omap-gpmc 50000000.gpmc: use pm_runtime_put_sync_suspend() in driver?
We can avoid this error by making sure the pm_runtime status of a device
matches the omap_device state before a probe attempt. By extending the
omap_device bus notifier to act on the BUS_NOTIFY_BIND_DRIVER event we
can check if a device is enabled in omap_device but with a pm_runtime
status of RPM_SUSPENDED and once again mark the device as RPM_ACTIVE to
avoid a second incorrect call to omap_device_enable.
Fixes: 5de85b9d57ab ("PM / runtime: Re-init runtime PM states at probe
Tested-by: Franklin S Cooper Jr. <fcooper@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
[ Upstream commit e991c24d68b8c0ba297eeb7af80b1e398e98c33f ]
We have quite a lot of code that depends on the order of the
__ctl_load inline assemby and subsequent memory accesses, like
e.g. disabling lowcore protection and the writing to lowcore.
Since the __ctl_load macro does not have memory barrier semantics, nor
any other dependencies the compiler is, theoretically, free to shuffle
code around. Or in other words: storing to lowcore could happen before
lowcore protection is disabled.
In order to avoid this class of potential bugs simply add a full
memory barrier to the __ctl_load macro.
[ Upstream commit 18e7a45af91acdde99d3aa1372cc40e1f8142f7b ]
As Peter suggested [1] rejecting non sampling PEBS events,
because they dont make any sense and could cause bugs
in the NMI handler [2].
[1] http://lkml.kernel.org/r/20170103094059.GC3093@worktop
[2] http://lkml.kernel.org/r/1482931866-6018-3-git-send-email-jolsa@kernel.org
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/20170103142454.GA26251@krava
[ Upstream commit 453828625731d0ba7218242ef6ec88f59408f368 ]
info->si_addr is of type void __user *, so it should be compared against
something from the same address space.
This fixes the following sparse error:
arch/x86/mm/mpx.c:296:27: error: incompatible types in comparison expression (different address spaces)
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
[ Upstream commit 695085b4bc7603551db0b3da897b8bf9893ca218 ]
The Intel Denverton microserver uses a 25 MHz TSC crystal,
so we can derive its exact [*] TSC frequency
using CPUID and some arithmetic, eg.:
TSC: 1800 MHz (25000000 Hz * 216 / 3 / 1000000)
[*] 'exact' is only as good as the crystal, which should be +/- 20ppm
Signed-off-by: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/r/306899f94804aece6d8fa8b4223ede3b48dbb59c.1484287748.git.len.brown@intel.com
[ Upstream commit 41c066f2c4d436c535616fe182331766c57838f0 ]
When CONFIG_RANDOMIZE_MODULE_REGION_FULL=y, the offset between loaded
modules and the core kernel may exceed 4 GB, putting symbols exported
by the core kernel out of the reach of the ordinary adrp/add instruction
pairs used to generate relative symbol references. So make the adr_l
macro emit a movz/movk sequence instead when executing in module context.
While at it, remove the pointless special case for the stack pointer.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[ Upstream commit ad5013d5699d30ded0cdbbc68b93b2aa28222c6e ]
When x86_pmu.num_counters is 32 the shift of the integer constant 1 is
exceeding 32bit and therefor undefined behaviour.
Fix this by shifting 1ULL instead of 1.
Reported-by: CoverityScan CID#1192105 ("Bad bit shift operation")
Cc: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/20170111114310.17928-1-colin.king@canonical.com
code
[ Upstream commit 6d6daa20945f3f598e56e18d1f926c08754f5801 ]
hswep_uncore_cpu_init() uses a hardcoded physical package id 0 for the boot
cpu. This works as long as the boot CPU is actually on the physical package
0, which is normaly the case after power on / reboot.
But it fails with a NULL pointer dereference when a kdump kernel is started
on a secondary socket which has a different physical package id because the
locigal package translation for physical package 0 does not exist.
Use the logical package id of the boot cpu instead of hard coded 0.
[ tglx: Rewrote changelog once more ]
Fixes: cf6d445f6897 ("perf/x86/uncore: Track packages, not per CPU data")
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Harish Chegondi <harish.chegondi@intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1483628965-2890-1-git-send-email-prarit@redhat.com
[ Upstream commit 387bbc974f6adf91aa635090f73434ed10edd915 ]
We give up recovery on permanent error, simply shutdown the affected
devices and remove them. If the devices can't be put into quiet state,
they spew more traffic that is likely to cause another unexpected EEH
error. This was observed on "p8dtu2u" machine:
0002:00:00.0 PCI bridge: IBM Device 03dc
0002:01:00.0 Ethernet controller: Intel Corporation \
Ethernet Controller X710/X557-AT 10GBASE-T (rev 02)
0002:01:00.1 Ethernet controller: Intel Corporation \
0002:01:00.2 Ethernet controller: Intel Corporation \
0002:01:00.3 Ethernet controller: Intel Corporation \
On P8 PowerNV platform, the IO path is frozen when shutdowning the
devices, meaning the memory registers are inaccessible. It is why
the devices can't be put into quiet state before removing them.
This fixes the issue by enabling IO path prior to putting the devices
into quiet state.
Reported-by: Pridhiviraj Paidipeddi <ppaidipe@linux.vnet.ibm.com>
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Acked-by: Russell Currey <ruscur@russell.cc>
[ Upstream commit 4e71de7986386d5fd3765458f27d612931f27f5e ]
The CPU hotplug function intel_pmu_cpu_starting() sets
cpu_hw_events.excl_thread_id unconditionally to 1 when the shared exclusive
counters data structure is already availabe for the sibling thread.
This works during the boot process because the first sibling gets threadid
0 assigned and the second sibling which shares the data structure gets 1.
But when the first thread of the core is offlined and onlined again it
shares the data structure with the second thread and gets exclusive thread
id 1 assigned as well.
Prevent this by checking the threadid of the already online thread.
[ tglx: Rewrote changelog ]
Signed-off-by: Zhou Chengming <zhouchengming1@huawei.com>
Cc: NuoHan Qiao <qiaonuohan@huawei.com>
Cc: ak@linux.intel.com
Cc: peterz@infradead.org
Cc: kan.liang@intel.com
Cc: dave.hansen@linux.intel.com
Cc: eranian@google.com
Cc: qiaonuohan@huawei.com
Cc: davidcc@google.com
Cc: guohanjun@huawei.com
Link: http://lkml.kernel.org/r/1484536871-3131-1-git-send-email-zhouchengming1@huawei.com
[ Upstream commit ce2e852ecc9a42e4b8dabb46025cfef63209234a ]
emulator_fix_hypercall() replaces hypercall with vmcall instruction,
but it does not handle GP exception properly when writes the new instruction.
It can return X86EMUL_PROPAGATE_FAULT without setting exception information.
This leads to incorrect emulation and triggers
WARN_ON(ctxt->exception.vector > 0x1f) in x86_emulate_insn()
as discovered by syzkaller fuzzer:
WARNING: CPU: 2 PID: 18646 at arch/x86/kvm/emulate.c:5558
Call Trace:
warn_slowpath_null+0x2c/0x40 kernel/panic.c:582
x86_emulate_insn+0x16a5/0x4090 arch/x86/kvm/emulate.c:5572
x86_emulate_instruction+0x403/0x1cc0 arch/x86/kvm/x86.c:5618
emulate_instruction arch/x86/include/asm/kvm_host.h:1127 [inline]
handle_exception+0x594/0xfd0 arch/x86/kvm/vmx.c:5762
vmx_handle_exit+0x2b7/0x38b0 arch/x86/kvm/vmx.c:8625
vcpu_enter_guest arch/x86/kvm/x86.c:6888 [inline]
vcpu_run arch/x86/kvm/x86.c:6947 [inline]
Set exception information when write in emulator_fix_hypercall() fails.
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: kvm@vger.kernel.org
Cc: syzkaller@googlegroups.com
