path: root/arch
2013-07-31colibri_t20: also define COLIBRI_T20_VI when VIDEO_TEGRA is a kernel modulePeter Gielda
2013-07-31colibri_t30: also define COLIBRI_T30_VI when VIDEO_TEGRA is a kernel module.Peter Gielda
2013-07-16apalis_t30: fix build without SATA supportMarcel Ziswiler
This patch fixes building without CONFIG_SATA_AHCI_TEGRA aka SATA support which previously failed as follows: ... CC arch/arm/mach-tegra/board-apalis_t30.o ~/linux-toradex/arch/arm/mach-tegra/board-apalis_t30.c:571:31: error: 'apalis_led_gpio_device' defined but not used [-Werror=unused-variable] cc1: all warnings being treated as errors make[2]: *** [arch/arm/mach-tegra/board-apalis_t30.o] Error 1 make[1]: *** [arch/arm/mach-tegra] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [sub-make] Error 2
2013-06-24colibri_t30: set local critical temperatur to 95°CMax Krummenacher
If the local critical temperature is reached the power is unconditionally switched off. At 70°C ambient the default of 85°C can be reached. So increase the limit in the hwmon chip to 95°C.
2013-06-24apalis_t30: set local critical temperatur to 95°CMax Krummenacher
2013-06-21apalis_t30: fix PCIe by forcing GEN1 speedMarcel Ziswiler
Enable PCI quirk support resp. don't explicitly disable it in order for the following fix to take effect. The Apalis evaluation board needs to set the link speed to 2.5 GT/s (GEN1). The default link speed setting is 5 GT/s (GEN2). 0x98 is the Link Control 2 PCIe Capability Register of the PEX8605 PCIe switch. The switch supports link speed auto negotiation, but falsely sets the link speed to 5 GT/s.
2013-06-12apalis_t30: v4l2: adv7180 and max9526 integrationMarcel Ziswiler
Integrate ADV7180 and MAX9526 video decoder support and prepare for drivers as modules. The following gstreamer pipeline shows a preview window: gst-launch v4l2src ! deinterlace tff=1 method=4 ! nv_omx_videomixer ! nv_gl_eglimagesink
2013-06-12colibri_t30: adv7180 and max9526 integrationPiotr Zierhoffer
2013-06-12apalis/colibri_t30: remove spurious tegra_aes_devicePeter Gielda
Remove tegra_aes_device from the platform device list as it was listed twice.
2013-06-12colibri_t20: v4l2: adv7180 integrationPeter Gielda
Integrate ADV7180 video decoder support. While at it prepare for ADV7180 as well as MAX9526 drivers as module.
2013-06-12colibri_t20: support for tegra_v4l2_camera as modulePiotr Zierhoffer
2013-06-07tegra: pcie: fix AXI response decoding errorsMarcel Ziswiler
Avoid AXI response decoding errors of the following form by properly setting the root bus number: [ 3.377991] PCIE: AXI response decoding error, signature: ff01003d [ 3.384174] PCIE: AXI response decoding error, signature: ff01003c
2013-06-07apalis_t30: fix PCIe reset issueMarcel Ziswiler
Implement workaround for PLX PEX 8605 errata 5 (PEX_REFCLK_OUTpx/nx Clock Outputs is not Guaranteed Until 900 us After PEX_PERST# De-assertion) by releasing RESET_MOCI_N 1 ms after releasing PEX_PERST_N.
2013-06-05colibri_t20/30: add comment about GMI_ADV_N usageMarcel Ziswiler
Add a comment about conflicting use of SODIMM pin 150 as GPIO K0 resp. GMI_ADV_N used for multiplexed address/data bus courtesy of Stéphane Gonnella from Multitel ASBL.
2013-05-28tegra: pcie: revert driverMarcel Ziswiler
Revert the following commit: 4bb48c289cdfddf02673b5b3dd1a735dfd5d972e
2013-05-27colibri_t30: export some gpio on /sys/class/gpio/...Max Krummenacher
Added skeleton code to define userspace accessable gpio. Export gpios which are unlikely to be used for other functions.
2013-04-02colibri_t20: android: enable back key wakeMarcel Ziswiler
Enable the back key as a wake-up source as well.
2013-04-02colibri_t20: android: use 32bppMarcel Ziswiler
Use 32 rather than 16 bits per pixel as otherwise it looks so ugly.
2013-03-24colibri_t20: android: kernel configurationMarcel Ziswiler
Add initial Android kernel configuration adopted from tegra_android_defconfig.
2013-03-24Revert "colibri_t20: android: 720p as default none VGA TFTLCD resolution"Marcel Ziswiler
Due to 720p not working well with most regular analogue screens and as customers rather might want to evaluate using our 7 inch EDT ET070080DH6 panel revert to 800x480 if not default VGA TFTLCD resolution is chosen. This reverts commit 0fc41ea361c79175f2076a349a0ba0dcc7e71131.
2013-03-24colibri_t20: android: revert to default VGA TFTLCD resolutionMarcel Ziswiler
As customers might want to evaluate using a regular VGA screen or our 5.7 inch EDT ET057090DHU panel revert to default VGA TFTLCD resolution. This is a partial revert of the following commit: 106ac0436290a98ecc5e3dfc75d0d7f104ef0ff4
2013-03-24colibri_t20: fix menu-keyMarcel Ziswiler
Due to a strong pull-down on the menu-key multiplexed ACC1_DETECT pin Android unintentionally entered safe-mode. Fix this by making the menu-key active-high as well.
2013-03-14apalis_t30: default full HD LVDS resolutionMarcel Ziswiler
By default configure for LG LP156WF1 15.6 inch full HD dual channel LVDS panel.
2013-03-14apalis_t30: audio: integrate HDA codec supportMarcel Ziswiler
Integrate support for the Realtek ALC898 as found on the Apalis Evaluation Board V1.0a. Please note that the following HDA rewiring needs to be done: remove jumpers X6-5 and 7 to 9 rewire as follows: X5 X7 5 9 7 8 8 5 9 7 Please further note that currently only noise is heard during playback.
2013-03-13board-colibri-t20: do not set PWM<A>, PWM<D> as GPIO inputMax Krummenacher
SODIMM-59, SODIMM-67 is no longer a GPIO and thus the PWM are usable again. PWM<D>
2013-03-12colibri_t20/30: usb: otg: fix host to peripheral transitionMarcel Ziswiler
Fix null pointer during USB OTG host to peripheral transition caused by freeing the platform data twice. See the following Tegra OTG driver commit for reference: 8acf989d5896b152cc88f8b29afd11d522f903e3
2013-03-12colibri_t20/30: can: integrate mcp251x and sja1000 supportMarcel Ziswiler
Integrate CAN support for the Colibri Evaluation Board V3.1a with built-in MCP2515 SPI CAN controller resp. the Colibri Evaluation Board V2.1c with its built-in SJA1000 CAN controller connected to the GMI bus. The following kernel configuration needs to be enabled as well: CONFIG_CAN CONFIG_CAN_RAW CONFIG_CAN_BCM CONFIG_CAN_DEV Plus depending on the Evaluation Board revision: CONFIG_CAN_MCP251X or CONFIG_CAN_SJA1000 CONFIG_CAN_SJA1000_PLATFORM Optional support for 32-bit GMI as well as xPOD CAN on MECS Tellurium for Colibri T20 is provided via commented defines in arch/arm/mach-tegra/board-colibri_t20.h.
2013-03-06colibri_t30: android: kernel configurationMarcel Ziswiler
Add initial Android kernel configuration adopted from tegra3_android_defconfig.
2013-03-06colibri_t30: android: enable hdaMarcel Ziswiler
Unless HDA driver is enabled device enters safe mode upon start-up.
2013-03-06colibri_t30: android: hack to allow using cardhu initrdMarcel Ziswiler
NVIDIA's Android for their Cardhu developer tablet is looking for the machine name in order to initialise certain things. For now just hack it to be able to use their regular initrd.
2013-03-06colibri_t30: android: 32 bits per pixelMarcel Ziswiler
Android uses 32 bits per pixel and fails otherwise. While at it increase the default DVI-D aka HDMI resolution to full HD.
2013-03-03colibri_t20/30: v4l2: max9526 integrationMarcel Ziswiler
Integrate MAX9526 video decoder support as found on our analogous camera module (ACM) connected to a Colibri Evaluation carrier board. The following kernel configuration options are required to be enabled: CONFIG_VIDEO_V4L2=y CONFIG_SOC_CAMERA=y CONFIG_SOC_CAMERA_MAX9526=y CONFIG_VIDEO_TEGRA=y
2013-03-03Conflicts:Marcel Ziswiler
arch/arm/mach-tegra/common.c drivers/ata/ahci-tegra.c
2013-03-02colibri_t20/30: move gpio definesMarcel Ziswiler
Move GPIO defines to header file. While at it get rid of spurious AVDD_DSI_CSI_ENB_GPIO define.
2013-03-02apalis/colibri_t30: clean-up defines in header fileMarcel Ziswiler
Re-arrange defines in header file.
2013-03-02apalis/colibri_t30:Marcel Ziswiler
Get rid of spurious AC_PRESENT_GPIO/INT defines.
2013-03-02colibri_t30: 4-bit mmc/sd cardMarcel Ziswiler
Explicitly configure MMC/SD card as 4-bit only by default.
2013-03-02colibri_t20/30: rename uartsMarcel Ziswiler
Rename UARTs to be consistent with Colibri FF/BT/STDUART naming.
2013-03-02colibri_t20/30: rename pwm ledsMarcel Ziswiler
Rename PWM LEDs to be consistent with Colibri PWM<X> naming.
2013-03-02apalis/colibri_t20/30: migrate gpio to irq conversionMarcel Ziswiler
Migrate from static TEGRA_GPIO_TO_IRQ macro to run-time gpio_to_irq function. While at it clean-up some comments and fix some long lines in order to adhere to Linux kernel coding style.
2013-03-02apalis_t30: clocks clean-upMarcel Ziswiler
Clean-up clocks. HDA clocks are of course required on Apalis T30.
2013-03-02apalis_t30: power: fix fixed regulator init namingMarcel Ziswiler
Fix naming of fixed regulator initialisation function.
2013-03-02apalis_t30: fix can init namingMarcel Ziswiler
Fix naming of CAN initialisation function.
2013-03-02tegra: makefile clean-upMarcel Ziswiler
Move Apalis T30 specific entries for alphabetical consistency. Put Colibri T30 items in alphabetical order.
2013-02-21colibri_t30: enable back key wake-upMarcel Ziswiler
Enable back key wake-up source.
2013-02-21colibri_t30: fix gpio-key pull-upsMarcel Ziswiler
Due to missing pull-ups on the gpio-key pins Android unintentionally entered safe-mode.
2013-02-20apalis_t30: fix 24 bpp rgb outputMarcel Ziswiler
Activate 24 bpp RGB output. Please not that this is just the backend configuration. For true 24 bpp output the framebuffer as well as driver have to be configured for 24 resp. 32 bpp as well.
2013-02-19apalis_t30: fix analog audioMarcel Ziswiler
The audio_port_id in the audio platform data really has to be the index of the registered tegra_i2s_device rather than the I2S interface instance.
2013-02-19apalis_t30: enable b43 driver as moduleMarcel Ziswiler
Enable building b43 driver as a module to demo Broadcom AirForce BCM4311 based mini-PCIe Wi-Fi 802.11a/b/g module.
2013-02-19apalis_t30: reset PLX PEX 8605 PCIe switchMarcel Ziswiler
Reset PLX PEX 8605 PCIe Switch on Apalis Evaluation Board to enable X43, X44 and X45.
