As we don't want to exclusively reserve the detection GPIO temporarily
enabling it is still required.
Hack to force WIRELESS_EXT required to build Redpine Signals LiteFi driver.
Enable kernel configuration for USB audio.
As Colibris are usually self powered default drawn VBUS to 2 mA rather
than demanding 500 mA. This should fix it running from not self powered
USB hubs as well.
Activate Android rather than mass storage gadget driver to support
multiple USB functions. The functions can be configured via a board
file and may be enabled and disabled dynamically. E.g. the following
enables regular Ethernet aka RNDIS functionality once booted:
echo rndis > /sys/class/android_usb/android0/functions
echo 1 > /sys/class/android_usb/android0/enable
Activate Colibri rather than Tegra USB OTG driver as used on
Colibri T20 as well.
Integrate USB OTG functionality similar to Colibri T20.
Clean up various comments, indentation and white space issues.
Get rid of duplicate USB EHCI ULPI VIEWPORT stuff in Kconfig.
Several file names and paths showed copy/paste or otherwise issues.
Add default kernel configuration in order to run oe-core on any of the
Colibri PXA series modules. So far no further platform data additions
have been committed meaning only older PXA270 v1.x, PXA300/310 v1.x or
PXA320 v1.x modules as anyway supported in mainline will work.
So far only Income's board advertised PWM availability but of course
any Colibri is potentially PWM capable.
Due to a missing else if always the GPIO number as on colibri_pxa320
was being used which of course failed card detection.
The definition of __exception_irq_entry for
CONFIG_FUNCTION_GRAPH_TRACER=y needs linux/ftrace.h, but this creates a
circular dependency with it's current home in asm/system.h. Create
asm/exception.h and update all current users.
v4: - rebase to rmk/for-next
v3: - remove redundant includes of linux/ftrace.h
v2: - document the usage restricitions of __exception*
Cc: Zoltan Devai <zdevai@gmail.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
As pageattr.c gets built unconditionally it fails linking on none v7
arms (e.g. PXA) with the following error message:
arch/arm/mm/pageattr.c:38:
undefined reference to `v7_flush_kern_cache_all'
Looks like this DPD stuff whatever it is fails eMMC detection on our
current Colibri T30 prototypes.
See f4cd0d4448d65a42b65c338f85a3ab8064923c61.
USB hubs as well.
Activate Android rather than Ethernet gadget driver to support multiple
USB functions. The functions can be configured via a board file and may
be enabled and disabled dynamically. E.g. the following enables regular
Android R14 userspace seems to have issues with timestamp support:
[ 14.764337] host1x host1x: SurfaceFlinger: syncpoint id 8 (disp0_a) stuck waiting 3, timeout=2147483447
[ 14.773845] host1x host1x: id 8 (disp0_a) min 2 max 4
[ 14.779163] host1x host1x: id 9 (disp1_a) min 2 max 4
[ 14.784316] host1x host1x: id 18 (2d_0) min 21 max 25
[ 14.789586] host1x host1x: id 20 (disp0_b) min 2 max 4
[ 14.794889] host1x host1x: id 21 (disp1_b) min 2 max 4
[ 14.800241] host1x host1x: id 22 (3d) min 77 max 95
[ 14.805217] host1x host1x: id 24 (disp0_c) min 2 max 4
[ 14.810573] host1x host1x: id 25 (disp1_c) min 2 max 4
[ 14.815873] host1x host1x: id 26 (vblank0) min 800 max 0
[ 14.821264] host1x host1x: id 27 (vblank1) min 684 max 0
[ 14.826810] host1x host1x: waitbase id 3 val 77
Therefore conditionally revert it in that case for now.
See e4e2e776a3d4bf1adf37fc061cfdfb92281f3ace.
Use the existing boardfile for everything, just match using DT.
See df80522dd557e2759552b6c6b0f1f1c8ad1c5614.
Add configurability support for i2s parameters.
See 907bac80691c7df5b5b57cbf27f91e8bb1dcf434.
This is a WAR solution that allows for the turning on SD DPD feature.
The original issue is that enabling SD DPD immediately after device
comes out of LP0 causes ULPI disconnect. The root cause of that is not
known.
The WAR is to delay the enabling of SD DPD for 100ms after
device comes out of LP0.
While at it remove commented out tegra_reserve stuff.
See 5e07056dc8b922b8b43a01b60a949c1dda75d9a9.
Enable device tree support for Colibri T20 by adding board compatible
table.
See 293b009a282e1508a4947d84463fdfe820445a50.
Since there is no PMC available in tegra2 we will not be able to get
any remote wakeup events. Hence do not power of the phy during usb
suspend.
See c4a5c51e493a8d4154c15c95d2bd93b348090892.
SODIMM pin 135 is really GPIO K6 multiplexed with ACC1_DETECT. Unfortunately the later can't be tri-stated but since it is anyway always an input it should not interfere. Please note however that this SODIMM pin is rather low resistance.
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
Add emc table for 256 MB module version. Assume less than 256 MB of
kernel memory (e.g. physical memory minus carveout and framebuffers)
means we are running on a 256 MB module.
Implement the following GPIO keys:
- find (SODIMM pin 77)
- home (SODIMM pin 127)
- back (SODIMM pin 133, Iris X16-14)
- volume up (SODIMM pin 22)
- volume down (SODIMM pin 24)
- power (SODIMM pin 45, Iris X16-20)
- menu (SODIMM pin 135)
After fixing Ethernet detection faults in the T20 BSP V1.x based Linux kernel 2.6.36.2 and U-Boot 2011.06 unify the Ethernet initialisation.
While at it fix some minor white space issue plus add some clarifying ifdef comments.
we will not be able to get any remote wakeup events. Hence do not
power of the phy during usb suspend.
Bug 1166740
Change-Id: I882066a283af2e574b111da3472eb3f8f8a9d6eb
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/160593
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
GVS: Gerrit_Virtual_Submit
Activate parallel camera interface aka video input port (VIP) which
conflicts with the default Colibri pinmux configuration.
Actually enable none VGA TFTLCD resolution to activate previously
commited 720p Android resolution.
Using 720p as Android's default none VGA TFTLCD resolution allows for
the default tablet mode layout to be run which makes most sense for
evaluation purpose on regular monitors.
Due to a pin muxing conflict between the regular backlight PWM and the
camera we do have to make this code not CAMERA_INTERFACE define
dependant.
NVIDIA's Android for their Ventana developer tablet is looking for the
machine name in order to initialise certain things. For now just hack
it to be able to use their regular initrd.
NVIDIA's Android employs its own proprietary camera stack therefore
make sure no V4L2 sensor drivers are registered.
As the camera master clock is an output no input driver is required on
the external clk2 out pin we use for that purpose.
Note: We do not use the regular camera MCLK due to this pin being 1.8V
only.
At least our early Colibri T30 prototypes exhibit an issue that often
times kernel locks-up during boot-up due to missing pll_a lock bit.
Fix Android RAM console by reserving 1 MB of memory.
Add Samsung K9K8G08U0B NAND parameters usded for TSOP testing.
Backlight PWM now runs at 1 kHZ rather than 500kHz.
Make PWM B, C, D accessible from userspace. e.g as /sys/class/leds/pwm_b.
Make PWM A or C a led PWM depending on MECS_TELLURIUM.
Fix PWM clock's special registry layout for parent clock.
To avoid the following systemd failure and as recommended we activate
IPv6 kernel configuration straight from NVIDIA's tegra_defconfig.
[ 21.532106] systemd[1]: could not find module by name='ipv6'
[ 21.555061] systemd[1]: Failed to insert 'ipv6'
While the ADC platform data passing worked just fine in kernel 2.6.36.2
this currently fails. Therefore introduce an ugly hack to explicitly
get said data via a board level call back.
Clean-up ADC platform data.
While at it fix some white space in the clock initialisation table and
add some comment concerning missing AC97 clock mux availability.
The fuse driver registers parameters and thus
create a /sys/module/fuse directory which collides
with the fuse filesystem driver.
Rename fuse.c to tegra-fuse.c to fix this.
Bug 1058350
Change-Id: I5201bc43fcb44df8181085322bc40d1f6e99bf93
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Reviewed-on: http://git-master/r/143206
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Add the following tested (e.g. framebuffer console and X) video modes:
- 800x480@60 (e.g. for EDT ET070080DH6)
- 800x600@60
- 1024x768@60
- 1024x768@75
- 1280x720@60 aka 720p
- 1366x768@60
The define TEGRA_FB_VGA in board-colibri_t30.h can be used to switch
between VGA and 800x480.
Enable touch interrupt GPIO and tune STMPE811 platform parameters for
better touch responsiveness.
