3.3V consumers
PLLE: now supplied by LDO6 - Put the limits of the supplied circuit as constraints - Moved derived rails from 1.8V to 3.3V where applicable
Looks like we mixed up the low-active buffer enable GPIOs. This fixes
GMI_WR_N on SODIMM pin 93 RDnWR curtsey Tord Andersson from Endian
Technologies AB.
After having registered the following proper machine type migrate to
actually using it.
http://www.arm.linux.org.uk/developer/machines/list.php?id=4493
Well commit bfd8d6dc27ccf00bf89b0a7bb3d359bab2142376 got rid of the w1
include a little prematurely.
Add one-wire platform data. Still requires explicitly enabling the
following two kernel configuration options:
CONFIG_W1
CONFIG_W1_MASTER_TEGRA
Make PWM B, C, D accessible from userspace. e.g as
/sys/class/leds/pwm_b.
Can be initiated both by LXDE Logout - Suspend or manually doing
'echo mem > /sys/power/state'. Uses GPIO key power (SODIMM pin 45,
Iris X16-20) as wake-up source. If woken-up LXDE session does not
automatically activate desktop again try manually doing a 'chvt 7'.
Implement the following GPIO keys:
- find (SODIMM pin 77)
- home (SODIMM pin 127)
- back (SODIMM pin 133, Iris X16-14)
- volume up (SODIMM pin 22)
- volume down (SODIMM pin 24)
- power (SODIMM pin 45, Iris X16-20)
- menu (SODIMM pin 135)
Now simply enabling CONFIG_TEGRA_CAMERA resp. not explicitly disabling
it will make L4T's nv_omx_vip Gstreamer plug-in work with analogue video
decoders like the ADV7180 or MAX9526.
Booting with a bare USB hub (e.g. EvalBoard V3.1A) and later plugging
in a USB device completely hang the system. This fixes it.
Shorten GPL license header.
Get rid of obsolete includes.
Get rid of spurious comments.
Fix indentation.
Add some clarifying comments.
Commit 39ca35e4610f1307247815ec5268b5072172d24a mixed up the SCL/SDA
GPIOs. This fixes it again.
Fix indentation.
Rename board level init_machine and reserve functions.
As our hardware only allows triggering an interrupt on over-temperature
shutdown we setup a workqueue to catch leaving it again.
For Tegra 3 NVIDIA relies on the regular Linux thermal subsystem.
As follows some output during a thermal throttling run:
root@colibri-t30:~# cat /sys/bus/i2c/devices/4-004c/temp2_os
45000
RAM 400/980MB (lfb 135x4MB) IRAM 0/255kB(lfb 255kB)
cpu [12%,2%,3%,6%]@475 EMC 533 AVP 81 VDE 400 EDP limit 1300000
Temperatures CPU 42.4 Board 36.4
60000
cpu [14%,5%,4%,4%]@1300 EMC 533 AVP 81 VDE 400 EDP limit 1300000
Temperatures CPU 54.2 Board 47.8
cpu [100%,100%,100%,100%]@1200 EMC 533 AVP 81 VDE 400 EDP limit 1200000
Temperatures CPU 70.4 Board 56.6
75000
cpu [54%,49%,48%,48%]@1200 EMC 533 AVP 81 VDE 400 EDP limit 1200000
Temperatures CPU 70.9 Board 57.1
cpu [100%,100%,100%,100%]@1100 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 75.3 Board 60.5
85000
RAM 401/980MB (lfb 135x4MB) IRAM 0/255kB(lfb 255kB)
cpu [65%,61%,61%,61%]@1100 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 75.2 Board 61.0
cpu [100%,100%,100%,100%]@1000 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 85.1 Board 69.8
cpu [100%,100%,100%,100%]@760 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 85.1 Board 69.9
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/cur_state
0
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/max_state
10
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/type
balanced
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/cdev0_trip_point
0
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/temp
84531
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/trip_point_0_temp
85000
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/trip_point_0_type
passive
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/type
lm95245_remote
Adjust thermal throttling to latest lm95245 evolution and wait with the
interrupt registration until we get the LM95245 drivers probe callback.
While at it add some clarifying comments and wrap RTC stuff with a
define.
Our platform data erroneously used the forth (bus number 3) rather than
the first (bus number 0) controller instance.
Get rid of obsolete NAND aka Colibri T30 v1.0a prototype handling.
shutdown we first use it to catch entering throttle limit and only then
set it up to catch an actual over-temperature shutdown.
While throttling we setup a workqueue to catch leaving it again.
We support the same sysfs interface as on NVIDIA Ventana:
root@colibri-t20:~# cat /sys/kernel/debug/thermal/shutdown
115000
root@colibri-t20:~# cat /sys/kernel/debug/thermal/throttle
90000
As follows some output of before and during a throttling run:
root@colibri-t20:~# tegrastats
RAM 159/345MB (lfb 36x4MB) Carveout 11/128MB (lfb 116MB) GART 0/32MB
(lfb 32MB) IRAM 4/255kB(lfb 248kB) cpu [51%,23%]@216 EMC 666 AVP 72 VDE
240 EDP limit -1 Temperatures CPU 48.7 Board 43.2
root@colibri-t20:~# cat /sys/devices/system/cpu/cpu0/cpufreq/throttle
0
root@colibri-t20:~# cat /sys/bus/i2c/devices/4-004c/temp2_os
90000
115000
90000
RAM 66/345MB (lfb 5x32kB) Carveout 75/128MB (lfb 53MB) GART 8/32MB
(lfb 24MB) IRAM 20/255kB(lfb 232kB) cpu [85%,83%]@912 EMC 666 AVP 216
VDE 240 EDP limit -1 Temperatures CPU 90.1 Board 77.9
1
115000
Integrate remote over-temperature shutdown ROS pin handling.
Clean-up I2C platform data and bring it more in line with Colibri T30.
Avoid the following issue on both /dev/ttyHS1 as well as /dev/ttyHS3:
[ 4419.708332] tegra_uart tegra_uart.1: Setting clk_src pll_m
[ 4419.714361] Failed to set parent pll_m for uartb (violates clock
limit 600000000)
[ 4427.469124] tegra_uart tegra_uart.3: Setting clk_src pll_m
[ 4427.476177] Failed to set parent pll_m for uartd (violates clock
limit 600000000)
Integrate spidev support straight from Colibri T20.
Instead of copying the boot loader frame buffer which currently neither
displays anything worth preserving nor even what it has in the right
resolution make sure both LVDS as well as HDMI frame buffers get
cleared during initialisation to avoid displaying random garbled stuff.
Add the following tested (e.g. framebuffer console and X) video modes:
- 1280x1024@60
- 1600x1200@60
- 1680x1050@60
- 1920x1080p
- 1920x1200
And the following portrait modes:
- 480x640
- 540x960
- 720x1280
The define TEGRA_FB_VGA in board-colibri_t20.h can be used to switch
between VGA and 800x480.
While at it clean-up some defines and includes.
Clean-up I2C platform data.
Validate pin-muxing for latest Colibri T30 v1.1a and v1.1b module
hardware.
Clean-up kernel configuration and bring it more in line with Colibri T20.
- 1280x1024@60
- 1600x1200@60
- 1680x1050@60
- 1920x1080p
- 1920x1200
- 480x640
- 540x960
- 720x1280
While at it fix rename of CAMERA_INTERFACE to COLIBRI_T20_VI as well.
As the new Colibri Evaluation carrier board v3.1a uses SODIMM pin 45 as
IrDA transceiver SD with a 100 K pull-down we revert to using the power
key as high active.
GPIO keys configured as active-low either require pull-ups on the
carrier board or via pin-muxing. We enable the later for now.
Use GPIO inputs for function tri-stating rather than pin group
tri-stating to avoid influencing neighbouring pins.
While at it get rid of most pull-up/downs and a lot of commented out
stuff.
Rename CAMERA_INTERFACE to COLIBRI_T20_VI which stands for video input
to be more in-line with Colibri T30.
Get rid of optional CAM/GEN3_I2C on SODIMM pin 127/133.
Verify standard GPIO usage for latest v1.2a modules.
The Iris carrier board by default uses SODIMM pin 73 as DAC power save.
Note: This conflicts with the CAN interrupt on the new EvalBoard v3.1a.
VESA VGA mode defines hsync/vsync to be of polarity low rather than
high.
The HDMI power rail configuration used to be done within the LVDS aka
TFTLCD panel enable function. Now moving it to the platform power
initialisation where it really belongs. This avoids any
duplicate/spurious regulator configuration.
As the deep-sleep LP0 suspend mode is currently anyway not supported
default to the LP1 suspend mode for now.
The full PMIC power off decreases power consumption but doing a
subsequent reset won't force a re-boot any more.
Clean-up the following unused regulator supplies in the platform power
stuff:
p_cam_avdd, avdd_lvds, vddio_sys (panjit_touch), vmmc (sdhci-tegra.3)
and avdd_2v85.
While at it add some more comments concerning specific consumers/rails.
The boot logo and framebuffer console where displayed with a wrong
stride caused by a colour depth mismatch. Fix this by initially
configuring the display controllers to 16 bpp.
There are some classes of devices that are controlled entirely from
user space. Userspace consumer driver provides ability to control power
supplies for such devices. Enable this configuration option to be more
in line with the T30.
If the console is locked while the system is rebooted, the messages in
the temporary log buffer would not have propagated to all the console
drivers. This option forces the console lock to be released if it
failed to be acquired, which will cause all the pending messages to be
flushed. Enable this configuration option to be more in line with the
T30.
Get rid of the 2G/2G user/kernel memory split configuration in order to
use the default 3G/1G user/kernel memory split. This is more in line
with the T30 and avoids issues trying to run Android.
Fix two issues concerning SDMMC4B pinmux (e.g. using a regular SD card
as the boot device instead of the on-module eMMC). First according to
the TRM it is illegal to mux a certain function to two sets of balls
(e.g. the regular SDMMC4 as well as the SDMMC4B muxing). Second make
absolutely sure all unused balls are not only tri-stating their outputs
but also disable their inputs to prevent any illegal internal states.
