path: root/arch
2011-05-16Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP3: set the core dpll clk rate in its set_rate function omap: iommu: Return IRQ_HANDLED in fault handler when no fault occured
2011-05-13alpha: Wire up syscalls new to 2.6.39Michael Cree
Wire up the syscalls: name_to_handle_at open_by_handle_at clock_adjtime syncfs and adjust some whitespace in the neighbourhood to align commments. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-05-13alpha: convert to clocksource_register_hzJohn Stultz
Converts alpha to use clocksource_register_hz. Signed-off-by: John Stultz <johnstul@us.ibm.com> CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-05-13OMAP3: set the core dpll clk rate in its set_rate functionAvinash H.M
The debug l3_ick/rate is not displaying the actual rate of the clock in hardware. This is because, the core dpll set_rate function doesn't update the clk.rate. After fixing, the l3_ick/rate is displaying proper values. Signed-off-by: Shweta Gulati <shweta.gulati@ti.com> Signed-off-by: Avinash.H.M <avinashhm@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Paul Wamsley <paul@pwsan.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-12Merge branch 'stable/bug-fixes-for-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug-fixes-for-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: x86/mm: Fix section mismatch derived from native_pagetable_reserve() x86,xen: introduce x86_init.mapping.pagetable_reserve Revert "xen/mmu: Add workaround "x86-64, mm: Put early page table high""
2011-05-12x86/mm: Fix section mismatch derived from native_pagetable_reserve()Sedat Dilek
With CONFIG_DEBUG_SECTION_MISMATCH=y I see these warnings in next-20110415: LD vmlinux.o MODPOST vmlinux.o WARNING: vmlinux.o(.text+0x1ba48): Section mismatch in reference from the function native_pagetable_reserve() to the function .init.text:memblock_x86_reserve_range() The function native_pagetable_reserve() references the function __init memblock_x86_reserve_range(). This is often because native_pagetable_reserve lacks a __init annotation or the annotation of memblock_x86_reserve_range is wrong. This patch fixes the issue. Thanks to pipacs from PaX project for help on IRC. Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12x86,xen: introduce x86_init.mapping.pagetable_reserveStefano Stabellini
Introduce a new x86_init hook called pagetable_reserve that at the end of init_memory_mapping is used to reserve a range of memory addresses for the kernel pagetable pages we used and free the other ones. On native it just calls memblock_x86_reserve_range while on xen it also takes care of setting the spare memory previously allocated for kernel pagetable pages from RO to RW, so that it can be used for other purposes. A detailed explanation of the reason why this hook is needed follows. As a consequence of the commit: commit 4b239f458c229de044d6905c2b0f9fe16ed9e01e Author: Yinghai Lu <yinghai@kernel.org> Date: Fri Dec 17 16:58:28 2010 -0800 x86-64, mm: Put early page table high at some point init_memory_mapping is going to reach the pagetable pages area and map those pages too (mapping them as normal memory that falls in the range of addresses passed to init_memory_mapping as argument). Some of those pages are already pagetable pages (they are in the range pgt_buf_start-pgt_buf_end) therefore they are going to be mapped RO and everything is fine. Some of these pages are not pagetable pages yet (they fall in the range pgt_buf_end-pgt_buf_top; for example the page at pgt_buf_end) so they are going to be mapped RW. When these pages become pagetable pages and are hooked into the pagetable, xen will find that the guest has already a RW mapping of them somewhere and fail the operation. The reason Xen requires pagetables to be RO is that the hypervisor needs to verify that the pagetables are valid before using them. The validation operations are called "pinning" (more details in arch/x86/xen/mmu.c). In order to fix the issue we mark all the pages in the entire range pgt_buf_start-pgt_buf_top as RO, however when the pagetable allocation is completed only the range pgt_buf_start-pgt_buf_end is reserved by init_memory_mapping. Hence the kernel is going to crash as soon as one of the pages in the range pgt_buf_end-pgt_buf_top is reused (b/c those ranges are RO). For this reason we need a hook to reserve the kernel pagetable pages we used and free the other ones so that they can be reused for other purposes. On native it just means calling memblock_x86_reserve_range, on Xen it also means marking RW the pagetable pages that we allocated before but that haven't been used before. Another way to fix this is without using the hook is by adding a 'if (xen_pv_domain)' in the 'init_memory_mapping' code and calling the Xen counterpart, but that is just nasty. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12Revert "xen/mmu: Add workaround "x86-64, mm: Put early page table high""Konrad Rzeszutek Wilk
This reverts commit a38647837a411f7df79623128421eef2118b5884. It does not work with certain AMD machines. last_pfn = 0x100000 max_arch_pfn = 0x400000000 initial memory mapped : 0 - 02c3a000 Base memory trampoline at [ffff88000009b000] 9b000 size 20480 init_memory_mapping: 0000000000000000-0000000100000000 0000000000 - 0100000000 page 4k kernel direct mapping tables up to 100000000 @ ff7fb000-100000000 init_memory_mapping: 0000000100000000-00000001e0800000 0100000000 - 01e0800000 page 4k kernel direct mapping tables up to 1e0800000 @ 1df0f3000-1e0000000 xen: setting RW the range fffdc000 - 100000000 RAMDISK: 0203b000 - 02c3a000 No NUMA configuration found Faking a node at 0000000000000000-00000001e0800000 NUMA: Using 63 for the hash shift. Initmem setup node 0 0000000000000000-00000001e0800000 NODE_DATA [00000001dfffb000 - 00000001dfffffff] BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea PGD 0 Oops: 0003 [#1] SMP last sysfs file: CPU 0 Modules linked in: Pid: 0, comm: swapper Not tainted 2.6.39-0-virtual #6~smb1 RIP: e030:[<ffffffff81cf6a75>] [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea RSP: e02b:ffffffff81c01e38 EFLAGS: 00010046 RAX: 0000000000000000 RBX: 00000001e0800000 RCX: 0000000000001040 RDX: 0000000000004100 RSI: 0000000000000000 RDI: ffff8801dfffb000 RBP: ffffffff81c01e58 R08: 0000000000000020 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000bfe400 FS: 0000000000000000(0000) GS:ffffffff81cca000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 0000000001c03000 CR4: 0000000000000660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 0, threadinfo ffffffff81c00000, task ffffffff81c0b020) Stack: 0000000000000040 0000000000000001 0000000000000000 ffffffffffffffff ffffffff81c01e88 ffffffff81cf6c25 0000000000000000 0000000000000000 ffffffff81cf687f 0000000000000000 ffffffff81c01ea8 ffffffff81cf6e45 Call Trace: [<ffffffff81cf6c25>] numa_register_memblks.constprop.3+0x150/0x181 [<ffffffff81cf687f>] ? numa_add_memblk+0x7c/0x7c [<ffffffff81cf6e45>] numa_init.part.2+0x1c/0x7c [<ffffffff81cf687f>] ? numa_add_memblk+0x7c/0x7c [<ffffffff81cf6f67>] numa_init+0x6c/0x70 [<ffffffff81cf7057>] initmem_init+0x39/0x3b [<ffffffff81ce5865>] setup_arch+0x64e/0x769 [<ffffffff815e43c1>] ? printk+0x51/0x53 [<ffffffff81cdf92b>] start_kernel+0xd4/0x3f3 [<ffffffff81cdf388>] x86_64_start_reservations+0x132/0x136 [<ffffffff81ce2ed4>] xen_start_kernel+0x588/0x58f Code: 41 00 00 48 8b 3c c5 a0 24 cc 81 31 c0 40 f6 c7 01 74 05 aa 66 ba ff 40 40 f6 c7 02 74 05 66 ab 83 ea 02 89 d1 c1 e9 02 f6 c2 02 <f3> ab 74 02 66 ab 80 e2 01 74 01 aa 49 63 c4 48 c1 eb 0c 44 89 RIP [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea RSP <ffffffff81c01e38> CR2: 0000000000000000 ---[ end trace a7919e7f17c0a725 ]--- Kernel panic - not syncing: Attempted to kill the idle task! Pid: 0, comm: swapper Tainted: G D 2.6.39-0-virtual #6~smb1 Reported-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc32: Fixed unaligned memory copying in function __csum_partial_copy_sparc_generic sparc32: fix sparcstation 5 boot sparc32: fix section mismatch warnings in apc, pmc and time_32
2011-05-12Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6870/1: The mandatory barrier rmb() must be a dsb() in for device accesses ARM: 6892/1: handle ptrace requests to change PC during interrupted system calls ARM: 6890/1: memmap: only free allocated memmap entries when using SPARSEMEM ARM: zImage: the page table memory must be considered before relocation ARM: zImage: make sure not to relocate on top of the relocation code ARM: zImage: Fix bad SP address after relocating kernel ARM: zImage: make sure the stack is 64-bit aligned ARM: RiscPC: acornfb: fix section mismatches ARM: RiscPC: etherh: fix section mismatches
2011-05-12ARM: 6870/1: The mandatory barrier rmb() must be a dsb() in for device accessesCatalin Marinas
Since mandatory barriers may be used (explicitly or implicitly via readl etc.) to ensure the ordering between Device and Normal memory accesses, a DMB is not enough. This patch converts it to a DSB. Cc: Colin Cross <ccross@android.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: 6892/1: handle ptrace requests to change PC during interrupted system callsArnd Bergmann
GDB's interrupt.exp test cases currenly fail on ARM. The problem is how do_signal handled restarting interrupted system calls: The entry.S assembler code determines that we come from a system call; and that information is passed as "syscall" parameter to do_signal. That routine then calls get_signal_to_deliver [*] and if a signal is to be delivered, calls into handle_signal. If a system call is to be restarted either after the signal handler returns, or if no handler is to be called in the first place, the PC is updated after the get_signal_to_deliver call, either in handle_signal (if we have a handler) or at the end of do_signal (otherwise). Now the problem is that during [*], the call to get_signal_to_deliver, a ptrace intercept may happen. During this intercept, the debugger may change registers, including the PC. This is done by GDB if it wants to execute an "inferior call", i.e. the execution of some code in the debugged program triggered by GDB. To this purpose, GDB will save all registers, allocate a stack frame, set up PC and arguments as appropriate for the call, and point the link register to a dummy breakpoint instruction. Once the process is restarted, it will execute the call and then trap back to the debugger, at which point GDB will restore all registers and continue original execution. This generally works fine. However, now consider what happens when GDB attempts to do exactly that while the process was interrupted during execution of a to-be- restarted system call: do_signal is called with the syscall flag set; it calls get_signal_to_deliver, at which point the debugger takes over and changes the PC to point to a completely different place. Now get_signal_to_deliver returns without a signal to deliver; but now do_signal decides it should be restarting a system call, and decrements the PC by 2 or 4 -- so it now points to 2 or 4 bytes before the function GDB wants to call -- which leads to a subsequent crash. To fix this problem, two things need to be supported: - do_signal must be able to recognize that get_signal_to_deliver changed the PC to a different location, and skip the restart-syscall sequence - once the debugger has restored all registers at the end of the inferior call sequence, do_signal must recognize that *now* it needs to restart the pending system call, even though it was now entered from a breakpoint instead of an actual svc instruction This set of issues is solved on other platforms, usually by one of two mechanisms: - The status information "do_signal is handling a system call that may need restarting" is itself carried in some register that can be accessed via ptrace. This is e.g. on Intel the "orig_eax" register; on Sparc the kernel defines a magic extra bit in the flags register for this purpose. This allows GDB to manage that state: reset it when doing an inferior call, and restore it after the call is finished. - On s390, do_signal transparently handles this problem without requiring GDB interaction, by performing system call restarting in the following way: first, adjust the PC as necessary for restarting the call. Then, call get_signal_to_deliver; and finally just continue execution at the PC. This way, if GDB does not change the PC, everything is as before. If GDB *does* change the PC, execution will simply continue there -- and once GDB restores the PC it saved at that point, it will automatically point to the *restarted* system call. (There is the minor twist how to handle system calls that do *not* need restarting -- do_signal will undo the PC change in this case, after get_signal_to_deliver has returned, and only if ptrace did not change the PC during that call.) Because there does not appear to be any obvious register to carry the syscall-restart information on ARM, we'd either have to introduce a new artificial ptrace register just for that purpose, or else handle the issue transparently like on s390. The patch below implements the second option; using this patch makes the interrupt.exp test cases pass on ARM, with no regression in the GDB test suite otherwise. Cc: patches@linaro.org Signed-off-by: Ulrich Weigand <ulrich.weigand@linaro.org> Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: 6890/1: memmap: only free allocated memmap entries when using SPARSEMEMWill Deacon
The SPARSEMEM code allocates memmap entries only for sections which are present (i.e. those which contain some valid memory). The membank checks in free_unused_memmap do not take this into account and can incorrectly attempt to free memory which is not allocated, resulting in a BUG() in the bootmem code. However, if memory is configured as follows: |<----section---->|<----hole---->|<----section---->| +--------+--------+--------------+--------+--------+ | bank 0 | unused | | bank 1 | unused | +--------+--------+--------------+--------+--------+ where a bank only occupies part of a section, the memmap allocated for the remainder of the section *can* be freed. This patch modifies the checks in free_unused_memmap so that only valid memmap entries are considered for removal. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-11sparc32: Fixed unaligned memory copying in function ↵Tkhai Kirill
__csum_partial_copy_sparc_generic When we are in the label cc_dword_align, registers %o0 and %o1 have the same last 2 bits, but it's not guaranteed one of them is zero. So we can get unaligned memory access in label ccte. Example of parameters which lead to this: %o0=0x7ff183e9, %o1=0x8e709e7d, %g1=3 With the parameters I had a memory corruption, when the additional 5 bytes were rewritten. This patch corrects the error. One comment to the patch. We don't care about the third bit in %o1, because cc_end_cruft stores word or less. Signed-off-by: Tkhai Kirill <tkhai@yandex.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] fix alloc_pgste check in init_new_context [S390] oprofile: fix min/max interval query checks [S390] replace diag10() with diag10_range() function [S390] disassembler: handle b280/spp instruction [S390] kernel: Initialize register 14 when starting new CPU [S390] dasd: prevent IO error during reserve/release loop [S390] sclp/memory hotplug: fix initial usecount of increments
2011-05-11omap: iommu: Return IRQ_HANDLED in fault handler when no fault occuredLaurent Pinchart
Commit d594f1f31afe13edd8c02f3854a65cc58cfb3b74 (omap: IOMMU: add support to callback during fault handling) broke interrupt line sharing between the OMAP3 ISP and its IOMMU. Because of this, every interrupt generated by the OMAP3 ISP is handled by the IOMMU driver instead of being passed to the OMAP3 ISP driver. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-10MIPS: Alchemy: fix xxs1500 build errorManuel Lauss
This fixes: alchemy/xxs1500/init.c: In function 'prom_init': alchemy/xxs1500/init.c:57:17: error: ignoring return value of 'kstrtoul', declared with attribute warn_unused_result Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2340/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Invalidate old TLB mappings when updating huge page PTEs.David Daney
Without this, stale Icache or TLB entries may be used. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org https://patchwork.linux-mips.org/patch/2318/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Hibernation: Fixes for PAGE_SIZE >= 64kbWu Zhangjin
PAGE_SIZE >= 64kb (1 << 16) is too big to be the immediate of the addiu/daddiu instruction, so, use addu/daddu instruction instead. The following compiling error is fixed: AS arch/mips/power/hibernate.o arch/mips/power/hibernate.S: Assembler messages: arch/mips/power/hibernate.S:38: Error: expression out of range make[2]: *** [arch/mips/power/hibernate.o] Error 1 make[1]: *** [arch/mips/power] Error 2 Reported-by: Roman Mamedov <rm@romanrm.ru> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2313/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: JZ4740: Set one-shot feature flag for the clockeventLars-Peter Clausen
The code for supporting one-shot mode for the clockevent is already there, only the feature flag was not set. Setting the one-shot flag allows the kernel to run in tickless mode. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2261/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: JZ4740: Export symbols to the watchdog driver moduleRalf Baechle
MODPOST 356 modules ERROR: "jz4740_timer_disable_watchdog" [drivers/watchdog/jz4740_wdt.ko] undefine d! ERROR: "jz4740_timer_enable_watchdog" [drivers/watchdog/jz4740_wdt.ko] undefined ! make[1]: *** [__modpost] Error 1 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: JZ4740: Fix GCC 4.6.0 build error.Ralf Baechle
CC arch/mips/jz4740/dma.o arch/mips/jz4740/dma.c: In function 'jz4740_dma_chan_irq': arch/mips/jz4740/dma.c:245:11: error: variable 'status' set but not used [-Werro r=unused-but-set-variable] Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Audit: Fix success success argument pass to audit_syscall_exitRalf Baechle
2011-05-10MIPS: Fix calc_vmlinuz_load_addr build warnings.Ralf Baechle
HOSTCC arch/mips/boot/compressed/calc_vmlinuz_load_addr arch/mips/boot/compressed/calc_vmlinuz_load_addr.c: In function 'main': arch/mips/boot/compressed/calc_vmlinuz_load_addr.c:35:2: warning: format '%llx' expects type 'long long unsigned int *', but argument 3 has type 'uint64_t *' arch/mips/boot/compressed/calc_vmlinuz_load_addr.c:54:2: warning: format '%llx' expects type 'long long unsigned int', but argument 2 has type 'uint64_t' Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Alchemy: Fix GCC 4.6.0 build error.Ralf Baechle
CC arch/mips/alchemy/devboards/db1x00/board_setup.o arch/mips/alchemy/devboards/db1x00/board_setup.c: In function 'board_setup': arch/mips/alchemy/devboards/db1x00/board_setup.c:130:6: error: variable 'pin_func' set but not used [-Werror=unused-but-set-variable] Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Document former use of timerfd(2) syscall number.Ralf Baechle
2011-05-10MIPS: IP27: Fix GCC 4.6.0 build error.Ralf Baechle
CC arch/mips/sgi-ip27/ip27-hubio.o arch/mips/sgi-ip27/ip27-hubio.c: In function 'hub_pio_map': arch/mips/sgi-ip27/ip27-hubio.c:32:20: error: variable 'junk' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: bcm63xx: Fix header_crc comment in bcm963xx_tag.hJonas Gorski
The CRC32 actually includes the tag_version. Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2275/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Octeon: Guard the Kconfig body with CPU_CAVIUM_OCTEONDavid Daney
Instead of making each Octeon specific option depend on CPU_CAVIUM_OCTEON, gate the body of the entire file with CPU_CAVIUM_OCTEON. With this change, CAVIUM_OCTEON_SPECIFIC_OPTIONS becomes useless, so get rid of it as well. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2091/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Octeon: Cleanup Kconfig IRQ_CPU* symbols.David Daney
Octeon doesn't use IRQ_CPU, so don't select it. IRQ_CPU_OCTEON is a completely unused symbol, remove it completely. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2086/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Rename .data..mostly and properly handle it in linker scriptCatalin Marinas
2011-05-10MIPS: MSP: Fix build errorRalf Baechle
Reported and original patch by Yoichi Yuasa <yuasa@linux-mips.org>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: MSP71xx: Fix typo in msp_per_irq_controllerYoichi Yuasa
CC arch/mips/pmc-sierra/msp71xx/msp_irq_per.o arch/mips/pmc-sierra/msp71xx/msp_irq_per.c:101:2: error: expected identifier before '.' token make[2]: *** [arch/mips/pmc-sierra/msp71xx/msp_irq_per.o] Error 1 Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2246/ Cc: linux-mips <linux-mips@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Loongson: Fix GCC 2.6.0 build error.Ralf Baechle
CC arch/mips/loongson/common/env.o arch/mips/loongson/common/env.c: In function 'prom_init_env': arch/mips/loongson/common/env.c:50:12: error: variable 'ret' set but not used [-Werror=unused-but-set-variable] arch/mips/loongson/common/env.c:51:12: error: variable 'ret' set but not used [-Werror=unused-but-set-variable] arch/mips/loongson/common/env.c:52:12: error: variable 'ret' set but not used [-Werror=unused-but-set-variable] arch/mips/loongson/common/env.c:53:12: error: variable 'ret' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Jazz: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/jazz/jazzdma.o arch/mips/jazz/jazzdma.c: In function 'vdma_remap': arch/mips/jazz/jazzdma.c:214:20: error: variable 'npages' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: SNI: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/sni/time.o arch/mips/sni/time.c: In function 'dosample': arch/mips/sni/time.c:98:19: error: variable 'lsb' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Malta: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/mti-malta/malta-int.o arch/mips/mti-malta/malta-int.c: In function 'mips_pcibios_iack': arch/mips/mti-malta/malta-int.c:59:6: error: variable 'dummy' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
CC arch/mips/mti-malta/malta-init.o arch/mips/mti-malta/malta-init.c: In function 'prom_init': arch/mips/mti-malta/malta-init.c:196:6: error: variable 'result' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: IP22: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/sgi-ip22/ip22-platform.o arch/mips/sgi-ip22/ip22-platform.c: In function 'sgiseeq_devinit': arch/mips/sgi-ip22/ip22-platform.c:135:15: error: variable 'tmp' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors While at it rename the variable to pbdma for readability; there is a local variable tmp of different type being used in two nested blocks. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
CC arch/mips/sgi-ip22/ip22-time.o arch/mips/sgi-ip22/ip22-time.c: In function 'dosample': arch/mips/sgi-ip22/ip22-time.c:35:10: error: variable 'lsb' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: tlbex: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/mm/tlbex.o arch/mips/mm/tlbex.c: In function 'build_r4000_tlb_refill_handler': arch/mips/mm/tlbex.c:1155:22: error: variable 'vmalloc_mode' set but not used [-Werror=unused-but-set-variable] arch/mips/mm/tlbex.c:1154:28: error: variable 'htlb_info' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: c-r4k: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/mm/c-r4k.o arch/mips/mm/c-r4k.c: In function 'probe_scache': arch/mips/mm/c-r4k.c:1078:6: error: variable 'tmp' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Older GCC versions didn't warn about the unused variable tmp because it was getting initialized. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Mask jump target in ftrace_dyn_arch_init_insns().David Daney
The current code is abusing the uasm interface by passing jump target addresses with high bits set. Mask the addresses to avoid annoying messages at boot time. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/1922/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10[S390] fix alloc_pgste check in init_new_contextMartin Schwidefsky
Processes started with kernel_execve from a kernel thread will have current->mm==NULL. Reading current->mm->context.alloc_pgste will read a more or less random bit from lowcore in this case. If the bit turns out to be set the whole process tree started this way will allocate page table extensions although they have no need for it. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-10[S390] oprofile: fix min/max interval query checksMartin Schwidefsky
oprofile_min_interval and oprofile_max_interval are unsigned, checking for negative values doesn't work. Change hwsampler_query_min_interval and hwsampler_query_max_interval to return an unsigned long and check for a zero value instead. Reported-by: Nicolas Kaiser <nikai@nikai.net> Acked-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-10[S390] replace diag10() with diag10_range() functionMichael Holzheu
Currently the diag10() function can only release one page. For exploiters that have to call diag10 on a contiguous memory region this is suboptimal. This patch replaces the diag10() function with diag10_range() that is able to release multiple pages. In addition to that the new function now allows to release memory with addresses higher than 2047 MiB. This was due to a restriction of the diagnose implementation under z/VM prior to release 5.2. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-10[S390] disassembler: handle b280/spp instructionChristian Borntraeger
arch/s390/kvm/sie64a.S uses the b280 instruction. Tell the builtin disassembler to handle that code. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-10[S390] kernel: Initialize register 14 when starting new CPUMichael Holzheu
When starting a new CPU we currently jump to start_secondary() without setting register 14 (the return address) correctly. Therefore on the stack frame for start_secondary an invalid return address is stored. This leads to wrong stack back traces in kernel dumps. Example: #00 [1f33fe48] cpu_idle at 10614a #01 [1f33fe90] start_secondary at 54fa88 #02 [1f33feb8] (null) at 0 <--- invalid To fix this start_secondary() is called now with basr/brasl that sets register 14 correctly. The output of the stack backtrace looks then like the following: #00 [1f33fe48] cpu_idle at 10614a #01 [1f33fe90] start_secondary at 54fa88 #02 [1f33feb8] restart_base at 54f41e <--- correct Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-07Merge first four commits of 'zImage_fixes' of ↵Russell King
git://git.linaro.org/people/nico/linux into fixes
