This gives the DDR3L memory settings for 400MHz/800MHz.
The boot memory speed must be 400MHz for this to work, i.e.
the 400MHz BCT must be used.
If the boot console is RS232 and RX is left floating this leads
to arbitrary sys requests including reboots...
(RX is left floating on the evaluation boards if USB to serial is
jumpered but USB is not connected)
Up to now only the LVDS transceiver controlling GPIOs were exported.
This patch adds the generic Apalis GPIOs to the list of via sysfs to
userspace exported ones as well.
Initialisation of the framebuffer console on DVI-D aka HDMI sometimes
failed. This was particularly bad on Apalis T30 where this is activated
by default. On Colibri T30 this was observed when enabling it using the
fbcon=map:1 boot argument.
This fix curtsey of Bibek Basu from NVIDIA explicitly enables PLLA
during early clock initialisation which avoids a later race with the
display driver on DC1.
In preparation for the new Apalis resp. Colibri T30 production lots
with either T30IQS-P-A3 or T30MQS-P-A3 chips that due to some bug were
locked at 312 MHz force a speedo ID of 2 for now which allows regular
operation of up to 1.4 GHz (single core only).
Allow for jumper-less ACM operation by defaulting to 0x20 I2C address.
Enable the modular camera configuration for ACM which allows switching
not only decoders but also their inputs at run-time.
This is the only correct order to load the modules:
modprobe videobuf2-memops
modprobe videobuf2-dma-nvmap
modprobe max9526
# or modprobe adv7180
modprobe tegra_v4l2_camera
To change the decoder on the fly:
rmmod tegra_v4l2_camera
rmmod max9526
# or rmmod adv7180
modprobe adv7180
# or modprobe max9526
To get a pre-view window through gstreamer:
gst-launch v4l2src ! deinterlace tff=1 method=4 ! nv_omx_videomixer !
nv_gl_eglimagesink
To switch inputs (0-5 resp. 0-4 for ADV7180 and 0-2 for MAX9526 where 2
means auto selection):
v4l2-ctl -i 0
v4l2-ctl -i 1
v4l2-ctl -i 2
v4l2-ctl -i 3
v4l2-ctl -i 4
v4l2-ctl -i 5
To check what input is active:
v4l2-ctl -I
While at it enable NVIDIA confirmed ARM errata 716044 and 720789 as
well.
This patch fixes building without CONFIG_SATA_AHCI_TEGRA aka SATA
support which previously failed as follows:
CC arch/arm/mach-tegra/board-apalis_t30.o
~/linux-toradex/arch/arm/mach-tegra/board-apalis_t30.c:571:31: error:
'apalis_led_gpio_device' defined but not used [-Werror=unused-variable]
cc1: all warnings being treated as errors
make[2]: *** [arch/arm/mach-tegra/board-apalis_t30.o] Error 1
make[1]: *** [arch/arm/mach-tegra] Error 2
make[1]: *** Waiting for unfinished jobs....
make: *** [sub-make] Error 2
If the local critical temperature is reached the power is
unconditionally switched off. At 70°C ambient the default of 85°C
can be reached. So increase the limit in the hwmon chip to 95°C.
Enable PCI quirk support resp. don't explicitly disable it in order for
the following fix to take effect.
The Apalis evaluation board needs to set the link speed to 2.5 GT/s
(GEN1). The default link speed setting is 5 GT/s (GEN2). 0x98 is the
Link Control 2 PCIe Capability Register of the PEX8605 PCIe switch. The
switch supports link speed auto negotiation, but falsely sets the link
speed to 5 GT/s.
Integrate ADV7180 and MAX9526 video decoder support and prepare for
drivers as modules.
The following gstreamer pipeline shows a preview window:
nv_gl_eglimagesink
drivers as modules.
Remove tegra_aes_device from the platform device list as it was listed
twice.
Integrate ADV7180 video decoder support.
While at it prepare for ADV7180 as well as MAX9526 drivers as module.
Avoid AXI response decoding errors of the following form by properly
setting the root bus number:
[ 3.377991] PCIE: AXI response decoding error, signature: ff01003d
[ 3.384174] PCIE: AXI response decoding error, signature: ff01003c
Implement workaround for PLX PEX 8605 errata 5 (PEX_REFCLK_OUTpx/nx
Clock Outputs is not Guaranteed Until 900 us After PEX_PERST#
De-assertion) by releasing RESET_MOCI_N 1 ms after releasing
PEX_PERST_N.
Add a comment about conflicting use of SODIMM pin 150 as GPIO K0 resp.
GMI_ADV_N used for multiplexed address/data bus courtesy of Stéphane
Gonnella from Multitel ASBL.
Revert the following commit:
4bb48c289cdfddf02673b5b3dd1a735dfd5d972e
Added skeleton code to define userspace accessable gpio.
Export gpios which are unlikely to be used for other functions.
Enable the back key as a wake-up source as well.
Use 32 rather than 16 bits per pixel as otherwise it looks so ugly.
Add initial Android kernel configuration adopted from
tegra_android_defconfig.
Due to 720p not working well with most regular analogue screens and as
customers rather might want to evaluate using our 7 inch EDT
ET070080DH6 panel revert to 800x480 if not default VGA TFTLCD
resolution is chosen.
This reverts commit 0fc41ea361c79175f2076a349a0ba0dcc7e71131.
As customers might want to evaluate using a regular VGA screen or our
5.7 inch EDT ET057090DHU panel revert to default VGA TFTLCD resolution.
This is a partial revert of the following commit:
106ac0436290a98ecc5e3dfc75d0d7f104ef0ff4
Due to a strong pull-down on the menu-key multiplexed ACC1_DETECT pin
Android unintentionally entered safe-mode. Fix this by making the
menu-key active-high as well.
By default configure for LG LP156WF1 15.6 inch full HD dual channel
LVDS panel.
Integrate support for the Realtek ALC898 as found on the Apalis
Evaluation Board V1.0a.
Please note that the following HDA rewiring needs to be done:
remove jumpers X6-5 and 7 to 9
rewire as follows:
X5 X7
5 9
7 8
8 5
9 7
Please further note that currently only noise is heard during playback.
SODIMM-59, SODIMM-67 is no longer a GPIO and thus the PWM are usable again.
PWM<D>
Fix null pointer during USB OTG host to peripheral transition caused by
freeing the platform data twice. See the following Tegra OTG driver
commit for reference:
8acf989d5896b152cc88f8b29afd11d522f903e3
Integrate CAN support for the Colibri Evaluation Board V3.1a with built-in
MCP2515 SPI CAN controller resp. the Colibri Evaluation Board V2.1c with its
built-in SJA1000 CAN controller connected to the GMI bus.
The following kernel configuration needs to be enabled as well:
CONFIG_CAN
CONFIG_CAN_RAW
CONFIG_CAN_BCM
CONFIG_CAN_DEV
Plus depending on the Evaluation Board revision:
CONFIG_CAN_MCP251X
or
CONFIG_CAN_SJA1000
CONFIG_CAN_SJA1000_PLATFORM
Optional support for 32-bit GMI as well as xPOD CAN on MECS Tellurium for
Colibri T20 is provided via commented defines in
arch/arm/mach-tegra/board-colibri_t20.h.
tegra3_android_defconfig.
Unless HDA driver is enabled device enters safe mode upon start-up.
NVIDIA's Android for their Cardhu developer tablet is looking for the
machine name in order to initialise certain things. For now just hack
it to be able to use their regular initrd.
Android uses 32 bits per pixel and fails otherwise.
While at it increase the default DVI-D aka HDMI resolution to full HD.
Integrate MAX9526 video decoder support as found on our analogous
camera module (ACM) connected to a Colibri Evaluation carrier board.
The following kernel configuration options are required to be enabled:
CONFIG_VIDEO_V4L2=y
CONFIG_SOC_CAMERA=y
CONFIG_SOC_CAMERA_MAX9526=y
CONFIG_VIDEO_TEGRA=y
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Move GPIO defines to header file.
While at it get rid of spurious AVDD_DSI_CSI_ENB_GPIO define.
Re-arrange defines in header file.
Get rid of spurious AC_PRESENT_GPIO/INT defines.
Explicitly configure MMC/SD card as 4-bit only by default.
Rename UARTs to be consistent with Colibri FF/BT/STDUART naming.
Rename PWM LEDs to be consistent with Colibri PWM<X> naming.
Migrate from static TEGRA_GPIO_TO_IRQ macro to run-time gpio_to_irq
function.
While at it clean-up some comments and fix some long lines in order to
adhere to Linux kernel coding style.
Clean-up clocks. HDA clocks are of course required on Apalis T30.
Fix naming of fixed regulator initialisation function.
Fix naming of CAN initialisation function.
