path: root/arch
2010-01-06x86, msr: msrs_alloc/free for CONFIG_SMP=nBorislav Petkov
commit 6ede31e03084ee084bcee073ef3d1136f68d0906 upstream. Randy Dunlap reported the following build error: "When CONFIG_SMP=n, CONFIG_X86_MSR=m: ERROR: "msrs_free" [drivers/edac/amd64_edac_mod.ko] undefined! ERROR: "msrs_alloc" [drivers/edac/amd64_edac_mod.ko] undefined!" This is due to the fact that <arch/x86/lib/msr.c> is conditioned on CONFIG_SMP and in the UP case we have only the stubs in the header. Fork off SMP functionality into a new file (msr-smp.c) and build msrs_{alloc,free} unconditionally. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> LKML-Reference: <20091216231625.GD27228@liondog.tnic> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06x86, msr: Add support for non-contiguous cpumasksBorislav Petkov
commit 505422517d3f126bb939439e9d15dece94e11d2c upstream. The current rd/wrmsr_on_cpus helpers assume that the supplied cpumasks are contiguous. However, there are machines out there like some K8 multinode Opterons which have a non-contiguous core enumeration on each node (e.g. cores 0,2 on node 0 instead of 0,1), see http://www.gossamer-threads.com/lists/linux/kernel/1160268. This patch fixes out-of-bounds writes (see URL above) by adding per-CPU msr structs which are used on the respective cores. Additionally, two helpers, msrs_{alloc,free}, are provided for use by the callers of the MSR accessors. Cc: H. Peter Anvin <hpa@zytor.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Aristeu Rozanski <aris@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> LKML-Reference: <20091211171440.GD31998@aftab> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06x86, msr: Unify rdmsr_on_cpus/wrmsr_on_cpusBorislav Petkov
commit b8a4754147d61f5359a765a3afd3eb03012aa052 upstream. Since rdmsr_on_cpus and wrmsr_on_cpus are almost identical, unify them into a common __rwmsr_on_cpus helper thus avoiding code duplication. While at it, convert cpumask_t's to const struct cpumask *. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06x86/ptrace: make genregs[32]_get/set more robustLinus Torvalds
commit 04a1e62c2cec820501f93526ad1e46073b802dc4 upstream. The loop condition is fragile: we compare an unsigned value to zero, and then decrement it by something larger than one in the loop. All the callers should be passing in appropriately aligned buffer lengths, but it's better to just not rely on it, and have some appropriate defensive loop limits. Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06KVM: LAPIC: make sure IRR bitmap is scanned after vm loadMarcelo Tosatti
commit 6e24a6eff4571002cd48b99a2b92dc829ce39cb9 upstream. The vcpus are initialized with irr_pending set to false, but loading the LAPIC registers with pending IRR fails to reset the irr_pending variable. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06KVM: MMU: remove prefault from invlpg handlerMarcelo Tosatti
commit fb341f572d26e0786167cd96b90cc4febed830cf upstream. The invlpg prefault optimization breaks Windows 2008 R2 occasionally. The visible effect is that the invlpg handler instantiates a pte which is, microseconds later, written with a different gfn by another vcpu. The OS could have other mechanisms to prevent a present translation from being used, which the hypervisor is unaware of. While the documentation states that the cpu is at liberty to prefetch tlb entries, it looks like this is not heeded, so remove tlb prefetch from invlpg. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06x86/amd-iommu: Fix initialization failure panicJoerg Roedel
commit 0f764806438d5576ac58898332e5dcf30bb8a679 upstream. The assumption that acpi_table_parse passes the return value of the hanlder function to the caller proved wrong recently. The return value of the handler function is totally ignored. This makes the initialization code for AMD IOMMU buggy in a way that could cause a kernel panic on initialization. This patch fixes the issue in the AMD IOMMU driver. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06x86: SGI UV: Fix writes to led registers on remote uv hubsMike Travis
commit 39d30770992895d55789de64bad2349510af68d0 upstream. The wrong address was being used to write the SCIR led regs on remote hubs. Also, there was an inconsistency between how BIOS and the kernel indexed these regs. Standardize on using the lower 6 bits of the APIC ID as the index. This patch fixes the problem of writing to an errant address to a cpu # >= 64. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4B3922F9.3060905@sgi.com> [ v2: fix a number of annoying checkpatch artifacts and whitespace noise ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06powerpc: Handle VSX alignment faults correctly in little-endian modeNeil Campbell
commit bb7f20b1c639606def3b91f4e4aca6daeee5d80a upstream. This patch fixes the handling of VSX alignment faults in little-endian mode (the current code assumes the processor is in big-endian mode). The patch also makes the handlers clear the top 8 bytes of the register when handling an 8 byte VSX load. This is based on 2.6.32. Signed-off-by: Neil Campbell <neilc@linux.vnet.ibm.com> Acked-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06x86, cpuid: Add "volatile" to asm in native_cpuid()Suresh Siddha
commit 45a94d7cd45ed991914011919e7d40eb6d2546d1 upstream. xsave_cntxt_init() does something like: cpuid(0xd, ..); // find out what features FP/SSE/.. etc are supported xsetbv(); // enable the features known to OS cpuid(0xd, ..); // find out the size of the context for features enabled Depending on what features get enabled in xsetbv(), value of the cpuid.eax=0xd.ecx=0.ebx changes correspondingly (representing the size of the context that is enabled). As we don't have volatile keyword for native_cpuid(), gcc 4.1.2 optimizes away the second cpuid and the kernel continues to use the cpuid information obtained before xsetbv(), ultimately leading to kernel crash on processors supporting more state than the legacy FP/SSE. Add "volatile" for native_cpuid(). Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1261009542.2745.55.camel@sbs-t61.sc.intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18implement early_io{re,un}map for ia64Luck, Tony
commit cd7bcf32d42b15891620b3f1387a00178b54291a upstream. Needed for commit 2c992208 ("intel-iommu: Detect DMAR in hyperspace at probe time.) to build on IA64. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: Under BIOS control, restore AP's APIC_LVTTHMR to the BSP valueYong Wang
Upstream commit a2202aa29289db64ca7988b12343158b67b27f10. On platforms where bios handles the thermal monitor interrupt, APIC_LVTTHMR on each logical CPU is programmed to generate a SMI and OS can't touch it. Unfortunately AP bringup sequence using INIT-SIPI-SIPI clear all the LVT entries except the mask bit. Essentially this results in all LVT entries including the thermal monitoring interrupt set to masked (clearing the bios programmed value for APIC_LVTTHMR). And this leads to kernel take over the thermal monitoring interrupt on AP's but not on BSP (leaving the bios programmed value only on BSP). As a result of this, we have seen system hangs when the thermal monitoring interrupt is generated. Fix this by reading the initial value of thermal LVT entry on BSP and if bios has taken over the control, then program the same value on all AP's and leave the thermal monitoring interrupt control on all the logical cpu's to the bios. Signed-off-by: Yong Wang <yong.y.wang@intel.com> Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Arjan van de Ven <arjan@infradead.org> LKML-Reference: <20091110013824.GA24940@ywang-moblin2.bj.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18ACPI: Use the ARB_DISABLE for the CPU which model id is less than 0x0f.Zhao Yakui
commit 03a05ed1152944000151d57b71000de287a1eb02 upstream. Currently, ARB_DISABLE is a NOP on all of the recent Intel platforms. For such platforms, reduce contention on c3_lock by skipping the fake ARB_DISABLE. The cpu model id on one laptop is 14. If we disable ARB_DISABLE on this box, the box can't be booted correctly. But if we still enable ARB_DISABLE on this box, the box can be booted correctly. So we still use the ARB_DISABLE for the cpu which mode id is less than 0x0f. http://bugzilla.kernel.org/show_bug.cgi?id=14700 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18sparc: Set UTS_MACHINE correctly.David S. Miller
[ Upstream commit 7f5620a5fcd658f219e85831d3691908f1eccbde ] "ARCH" can be just about anything, so we shouldn't end up with UTS_MACHINE of "sparc" in a 64-bit kernel build just because someone set the personality using 'sparc32' or similar. CONFIG_SPARC64 drives the compilation and therefore provides the definitive value, not "ARCH". This mirrors commit 8c6531f7a99f29ba8817ffb12cc9ecf190049bd6 (x86: correctly set UTS_MACHINE for "make ARCH=x86") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18sparc64: Fix stack debugging IRQ stack regression.David S. Miller
[ Upstream commit 166e553a575f09485f6d0df8a1ef3c5991f7d953 ] Commit 4f70f7a91bffdcc39f088748dc678953eb9a3fbd (sparc64: Implement IRQ stacks.) has two bugs. First, the softirq range check forgets to subtract STACK_BIAS before comparing with %sp. Next, on failure the wrong label is jumped to, resulting in a bogus stack being loaded. Reported-by: Igor Kovalenko <igor.v.kovalenko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18sparc64: Fix overly strict range type matching for PCI devices.David S. Miller
[ Upstream commit 4230fa3b89ea1c413766bd411a8315a3d05aa6c7 ] When we are trying to see if a range property entry applies to a given address, we are overly strict about the type. We should only allow I/O ranges for I/O addresses, and only allow CONFIG space ranges for CONFIG space address. However for MEM ranges, they come in 32-bit and 64-bit flavors. And a lack of an exact match is OK if the range is 32-bit and the address is 64-bit. We can assign a 64-bit address properly into a 32-bit parent range just fine. So allow it. Reported-by: Patrick Finnegan <pat@computer-refuge.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18sparc64: Don't specify IRQF_SHARED for LDC interrupts.David S. Miller
[ Upstream commit 08a036d583409e3517e3d15b7478d029b25f2cf2 ] IRQF_SHARED and IRQF_DISABLED don't mix. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18xen: use iret for return from 64b kernel to 32b usermodeJeremy Fitzhardinge
commit 6aaf5d633bb6cead81b396d861d7bae4b9a0ba7e upstream. If Xen wants to return to a 32b usermode with sysret it must use the right form. When using VCGF_in_syscall to trigger this, it looks at the code segment and does a 32b sysret if it is FLAT_USER_CS32. However, this is different from __USER32_CS, so it fails to return properly if we use the normal Linux segment. So avoid the whole mess by dropping VCGF_in_syscall and simply use plain iret to return to usermode. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18xen: call clock resume notifier on all CPUsIan Campbell
commit f6eafe3665bcc374c66775d58312d1c06c55303f upstream. tick_resume() is never called on secondary processors. Presumably this is because they are offlined for suspend on native and so this is normally taken care of in the CPU onlining path. Under Xen we keep all CPUs online over a suspend. This patch papers over the issue for me but I will investigate a more generic, less hacky, way of doing to the same. tick_suspend is also only called on the boot CPU which I presume should be fixed too. Signed-off-by: Ian Campbell <Ian.Campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18xen: register runstate info for boot CPU earlyJeremy Fitzhardinge
commit 499d19b82b586aef18727b9ae1437f8f37b66e91 upstream. printk timestamping uses sched_clock, which in turn relies on runstate info under Xen. So make sure we set it up before any printks can be called. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18xen: register runstate on secondary CPUsIan Campbell
commit 028896721ac04f6fa0697f3ecac3f98761746363 upstream. The commit "xen: re-register runstate area earlier on resume" caused us to never try and setup the runstate area for secondary CPUs. Ensure that we do this... Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18xen: register timer interrupt with IRQF_TIMERIan Campbell
commit f350c7922faad3397c98c81a9e5658f5a1ef0214 upstream. Otherwise the timer is disabled by dpm_suspend_noirq() which in turn prevents correct operation of stop_machine on multi-processor systems and breaks suspend. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18xen: correctly restore pfn_to_mfn_list_list after resumeIan Campbell
commit fa24ba62ea2869308ffc9f0b286ac9650b4ca6cb upstream. pvops kernels >= 2.6.30 can currently only be saved and restored once. The second attempt to save results in: ERROR Internal error: Frame# in pfn-to-mfn frame list is not in pseudophys ERROR Internal error: entry 0: p2m_frame_list[0] is 0xf2c2c2c2, max 0x120000 ERROR Internal error: Failed to map/save the p2m frame list I finally narrowed it down to: commit cdaead6b4e657f960d6d6f9f380e7dfeedc6a09b Author: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Date: Fri Feb 27 15:34:59 2009 -0800 xen: split construction of p2m mfn tables from registration Build the p2m_mfn_list_list early with the rest of the p2m table, but register it later when the real shared_info structure is in place. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> The unforeseen side-effect of this change was to cause the mfn list list to not be rebuilt on resume. Prior to this change it would have been rebuilt via xen_post_suspend() -> xen_setup_shared_info() -> xen_setup_mfn_list_list(). Fix by explicitly calling xen_build_mfn_list_list() from xen_post_suspend(). Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18xen: restore runstate_info even if !have_vcpu_info_placementJeremy Fitzhardinge
commit 3905bb2aa7bb801b31946b37a4635ebac4009051 upstream. Even if have_vcpu_info_placement is not set, we still need to set up the runstate area on each resumed vcpu. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18xen: re-register runstate area earlier on resume.Ian Campbell
commit be012920ecba161ad20303a3f6d9e96c58cf97c7 upstream. This is necessary to ensure the runstate area is available to xen_sched_clock before any calls to printk which will require it in order to provide a timestamp. I chose to pull the xen_setup_runstate_info out of xen_time_init into the caller in order to maintain parity with calling xen_setup_runstate_info separately from calling xen_time_resume. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18powerpc: Fix usage of 64-bit instruction in 32-bit altivec codeBenjamin Herrenschmidt
commit e090aa80321b64c3b793f3b047e31ecf1af9538d upstream. e821ea70f3b4873b50056a1e0f74befed1014c09 introduced a bug by copying some 64-bit originated code as-is to be used by both 32 and 64-bit but this code contains a 64-bit ony "cmpdi" instruction. This changes it to cmpwi, which is fine since VRSAVE can only contains a 32-bit value anyway. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: Fix bogus warning in apic_noop.apic_write()Thomas Gleixner
commit a946d8f11f0da9cfc714248036fcfd3a794d1e27 upstream. apic_noop is used to provide dummy apic functions. It's installed when the CPU has no APIC or when the APIC is disabled on the kernel command line. The apic_noop implementation of apic_write() warns when the CPU has an APIC or when the APIC is not disabled. That's bogus. The warning should only happen when the CPU has an APIC _AND_ the APIC is not disabled. apic_noop.apic_read() has the correct check. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Cyrill Gorcunov <gorcunov@openvz.org> LKML-Reference: <alpine.LFD.2.00.0912071255420.3089@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18pxa/em-x270: fix usb hub power up/reset sequenceIgor Grinberg
commit 1b82e4c32fba96d8805b1e2126ba5382e56fac32 upstream. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18s390: clear high-order bits of registers after sam64Hendrik Brueckner
commit cf87b7439ec81b9374e7772e44e9cb2eb9e57160 upstream. When the kernel is IPLed without the CLEAR option and switches to 64-bit, the high-order half of the registers might contain random values. This can cause addressing exceptions and the kernel enters an interrupt loop. Initialize the high-order half of the general purpose registers with zeros after switching to 64-bit mode. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: Fix typo in Intel CPU cache size descriptorDave Jones
commit e02e0e1a130b9ca37c5186d38ad4b3aaf58bb149 upstream. I double-checked the datasheet. One of the existing descriptors has a typo: it should be 2MB not 2038 KB. Signed-off-by: Dave Jones <davej@redhat.com> LKML-Reference: <20091110200120.GA27090@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: Add new Intel CPU cache size descriptorsDave Jones
commit 85160b92fbd35321104819283c91bfed2b553e3c upstream. The latest rev of Intel doc AP-485 details new cache descriptors that we don't yet support. 12MB, 18MB and 24MB 24-way assoc L3 caches. Signed-off-by: Dave Jones <davej@redhat.com> LKML-Reference: <20091110184924.GA20337@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: Fix duplicated UV BAU interrupt vectorCliff Wickman
commit 1d865fb728bd6bbcdfbd6ec1e2b8ade3b4805641 upstream. Interrupt vector 0xec has been doubly defined in irq_vectors.h It seems arbitrary whether LOCAL_PENDING_VECTOR or UV_BAU_MESSAGE is the higher number. As long as they are unique. If they are not unique we'll hit a BUG in alloc_system_vector(). Signed-off-by: Cliff Wickman <cpw@sgi.com> LKML-Reference: <E1NJ9Pe-0004P7-0Q@eag09.americas.sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: SGI UV: Fix BAU initializationCliff Wickman
commit e38e2af1c57c3eb5211331a5b4fcaae0c4a2a918 upstream. A memory mapped register that affects the SGI UV Broadcast Assist Unit's interrupt handling may sometimes be unintialized. Remove the condition on its initialization, as that condition can be randomly satisfied by a hardware reset. Signed-off-by: Cliff Wickman <cpw@sgi.com> LKML-Reference: <E1NBGB9-0005nU-Dp@eag09.americas.sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86/mce: Set up timer unconditionallyJan Beulich
commit bc09effabf0c5c6c7021e5ef9af15a23579b32a8 upstream. mce_timer must be passed to setup_timer() in all cases, no matter whether it is going to be actually used. Otherwise, when the CPU gets brought down, its call to del_timer_sync() will never return, as the timer won't have a base associated, and hence lock_timer_base() will loop infinitely. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> LKML-Reference: <4B1DB831.2030801@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86, mce: don't restart timer if disabledHidetoshi Seto
commit fe5ed91ddce85a0ed0e4f92c10b099873ef62167 upstream. Even it is in error path unlikely taken, add_timer_on() at CPU_DOWN_FAILED* needs to be skipped if mce_timer is disabled. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: Use -maccumulate-outgoing-args for sane mcount prologuesThomas Gleixner
commit b8b7d791a8ff01d2380089279a69afa99115fb23 upstream. commit 746357d (x86: Prevent GCC 4.4.x (pentium-mmx et al) function prologue wreckage) uses -mtune=generic to work around the function prologue problem with mcount on -march=pentium-mmx and others. Jakub pointed out that we can use -maccumulate-outgoing-args instead which is selected by -mtune=generic and prevents the problem without losing the -march specific optimizations. Pointed-out-by: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: Prevent GCC 4.4.x (pentium-mmx et al) function prologue wreckageThomas Gleixner
commit 746357d6a526d6da9d89a2ec645b28406e959c2e upstream. When the kernel is compiled with -pg for tracing GCC 4.4.x inserts stack alignment of a function _before_ the mcount prologue if the -march=pentium-mmx is set and -mtune=generic is not set. This breaks the assumption of the function graph tracer which expects that the mcount prologue push %ebp mov %esp, %ebp is the first stack operation in a function because it needs to modify the function return address on the stack to trap into the tracer before returning to the real caller. The generated code is: push %edi lea 0x8(%esp),%edi and $0xfffffff0,%esp pushl -0x4(%edi) push %ebp mov %esp,%ebp so the tracer modifies the copy of the return address which is stored after the stack alignment and therefor does not trap the return which in turn breaks the call chain logic of the tracer and leads to a kernel panic. Aside of the fact that the generated code is horrible for no good reason other -march -mtune options generate the expected: push %ebp mov %esp,%ebp and $0xfffffff0,%esp which does the same and keeps everything intact. After some experimenting we found out that this problem is restricted to gcc4.4.x and to the following -march settings: i586, pentium, pentium-mmx, k6, k6-2, k6-3, winchip-c6, winchip2, c3, geode By adding -mtune=generic the code generator produces always the expected code. So forcing -mtune=generic when CONFIG_FUNCTION_GRAPH_TRACER=y is not pretty, but at the moment the only way to prevent that the kernel trips over gcc-shrooms induced code madness. Most distro kernels have CONFIG_X86_GENERIC=y anyway which forces -mtune=generic as well so it will not impact those. References: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=42109 http://lkml.org/lkml/2009/11/19/17 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <alpine.LFD.2.00.0911200206570.24119@localhost.localdomain> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com>, Cc: Jeff Law <law@redhat.com> Cc: gcc@gcc.gnu.org Cc: David Daney <ddaney@caviumnetworks.com> Cc: Andrew Haley <aph@redhat.com> Cc: Richard Guenther <richard.guenther@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18KVM: x86: include pvclock MSRs in msrs_to_saveGlauber Costa
commit e3267cbbbfbcbe9c18833e89b10beabb1117cb55 upstream. For a while now, we are issuing a rdmsr instruction to find out which msrs in our save list are really supported by the underlying machine. However, it fails to account for kvm-specific msrs, such as the pvclock ones. This patch moves then to the beginning of the list, and skip testing them. Signed-off-by: Glauber Costa <glommer@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18KVM: s390: Make psw available on all exits, not just a subsetCarsten Otte
commit d7b0b5eb3000c6fb902f08c619fcd673a23d8fab upstream. This patch moves s390 processor status word into the base kvm_run struct and keeps it up-to date on all userspace exits. The userspace ABI is broken by this, however there are no applications in the wild using this. A capability check is provided so users can verify the updated API exists. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18KVM: s390: Fix prefix register checking in arch/s390/kvm/sigp.cCarsten Otte
commit f50146bd7bdb75435638e60d4960edd9bcdf88b8 upstream. This patch corrects the checking of the new address for the prefix register. On s390, the prefix register is used to address the cpu's lowcore (address 0...8k). This check is supposed to verify that the memory is readable and present. copy_from_guest is a helper function, that can be used to read from guest memory. It applies prefixing, adds the start address of the guest memory in user, and then calls copy_from_user. Previous code was obviously broken for two reasons: - prefixing should not be applied here. The current prefix register is going to be updated soon, and the address we're looking for will be 0..8k after we've updated the register - we're adding the guest origin (gmsor) twice: once in subject code and once in copy_from_guest With kuli, we did not hit this problem because (a) we were lucky with previous prefix register content, and (b) our guest memory was mmaped very low into user address space. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Reported-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18KVM: x86 emulator: limit instructions to 15 bytesAvi Kivity
commit eb3c79e64a70fb8f7473e30fa07e89c1ecc2c9bb upstream. While we are never normally passed an instruction that exceeds 15 bytes, smp games can cause us to attempt to interpret one, which will cause large latencies in non-preempt hosts. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86, apic: Enable lapic nmi watchdog on AMD Family 11hMikael Pettersson
commit 7d1849aff6687a135a8da3a75e32a00e3137a5e2 upstream. The x86 lapic nmi watchdog does not recognize AMD Family 11h, resulting in: NMI watchdog: CPU not supported As far as I can see from available documentation (the BKDM), family 11h looks identical to family 10h as far as the PMU is concerned. Extending the check to accept family 11h results in: Testing NMI watchdog ... OK. I've been running with this change on a Turion X2 Ultra ZM-82 laptop for a couple of weeks now without problems. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Joerg Roedel <joerg.roedel@amd.com> LKML-Reference: <19223.53436.931768.278021@pilspetsen.it.uu.se> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: ASUS P4S800 reboot=bios quirkLeann Ogasawara
commit 4832ddda2ec4df96ea1eed334ae2dbd65fc1f541 upstream. Bug reporter noted their system with an ASUS P4S800 motherboard would hang when rebooting unless reboot=b was specified. Their dmidecode didn't contain descriptive System Information for Manufacturer or Product Name, so I used their Base Board Information to create a reboot quirk patch. The bug reporter confirmed this patch resolves the reboot hang. Handle 0x0001, DMI type 1, 25 bytes System Information Manufacturer: System Manufacturer Product Name: System Name Version: System Version Serial Number: SYS-1234567890 UUID: E0BFCD8B-7948-D911-A953-E486B4EEB67F Wake-up Type: Power Switch Handle 0x0002, DMI type 2, 8 bytes Base Board Information Manufacturer: ASUSTeK Computer INC. Product Name: P4S800 Version: REV 1.xx Serial Number: xxxxxxxxxxx BugLink: http://bugs.launchpad.net/bugs/366682 ASUS P4S800 will hang when rebooting unless reboot=b is specified. Add a quirk to reboot through the bios. Signed-off-by: Leann Ogasawara <leann.ogasawara@canonical.com> LKML-Reference: <1259972107.4629.275.camel@emiko> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: GART: pci-gart_64.c: Use correct length in strncmpJoe Perches
commit 41855b77547fa18d90ed6a5d322983d3fdab1959 upstream. Signed-off-by: Joe Perches <joe@perches.com> LKML-Reference: <1257818330.12852.72.camel@Joe-Laptop.home> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86: Fix iommu=nodac parameter handlingTejun Heo
commit 2ae8bb75db1f3de422eb5898f2a063c46c36dba8 upstream. iommu=nodac should forbid dac instead of enabling it. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Matteo Frigo <athena@fftw.org> LKML-Reference: <4AE5B52A.4050408@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86, Calgary IOMMU quirk: Find nearest matching Calgary while walking up the ↵Darrick J. Wong
PCI tree commit 4528752f49c1f4025473d12bc5fa9181085c3f22 upstream. On a multi-node x3950M2 system, there's a slight oddity in the PCI device tree for all secondary nodes: 30:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) \-33:00.0 PCI bridge: IBM CalIOC2 PCI-E Root Port (rev 01) \-34:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 1078 (rev 04) ...as compared to the primary node: 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) \-01:00.0 VGA compatible controller: ATI Technologies Inc ES1000 (rev 02) 03:00.0 PCI bridge: IBM CalIOC2 PCI-E Root Port (rev 01) \-04:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 1078 (rev 04) In both nodes, the LSI RAID controller hangs off a CalIOC2 device, but on the secondary nodes, the BIOS hides the VGA device and substitutes the device tree ending with the disk controller. It would seem that Calgary devices don't necessarily appear at the top of the PCI tree, which means that the current code to find the Calgary IOMMU that goes with a particular device is buggy. Rather than walk all the way to the top of the PCI device tree and try to match bus number with Calgary descriptor, the code needs to examine each parent of the particular device; if it encounters a Calgary with a matching bus number, simply use that. Otherwise, we BUG() when the bus number of the Calgary doesn't match the bus number of whatever's at the top of the device tree. Extra note: This patch appears to work correctly for the x3950 that came before the x3950 M2. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Jon D. Mason <jdmason@kudzu.us> Cc: Corinna Schultz <coschult@us.ibm.com> LKML-Reference: <20091202230556.GG10295@tux1.beaverton.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86/amd-iommu: un__init iommu_setup_msiJoerg Roedel
commit 9f800de38b05d84809e89f16671d636a140eede7 upstream. This function may be called on the resume path and can not be dropped after booting. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18x86/amd-iommu: attach devices to pre-allocated domains earlyJoerg Roedel
commit be831297716036de5b24308447ecb69f1706a846 upstream. For some devices the ACPI table may define unity map requirements which must me met when the IOMMU is enabled. So we need to attach devices to their domains as early as possible so that these mappings are in place when needed. This patch assigns the domains right after they are allocated. Otherwise this can result in I/O page faults before a driver binds to a device and BIOS is still using it. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-02MIPS: RB532: Fix devices.c compilation.Florian Fainelli
We should now use dev_set_drvdata to set the driver driver_data field. Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/747/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-02MIPS: Fix MIPS I build.Ralf Baechle
Broken by d63c63e889bbeeaa461a8addf1245f89f3ce4ece (lmo) rsp. f1e39a4a616cd9981a9decfd5332fd07a01abb8b (kernel.org). Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/746/
