path: root/arch
2009-05-08Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: MCE: make cmci_discover_lock irq-safe x86: xen, i386: reserve Xen pagetables x86, kexec: fix crashdump panic with CONFIG_KEXEC_JUMP x86-64: finish cleanup_highmaps()'s job wrt. _brk_end x86: fix boot hang in early_reserve_e820() x86: Fix a typo in a printk message x86, srat: do not register nodes beyond e820 map
2009-05-08Merge branch 'fixes-for-linus' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'fixes-for-linus' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Fix return value for sys_ipc microblaze: Storage class should be before const qualifier
2009-05-08x86: MCE: make cmci_discover_lock irq-safeHidetoshi Seto
Lockdep reports the warning below when Li tries to offline one cpu: [ 110.835487] ================================= [ 110.835616] [ INFO: inconsistent lock state ] [ 110.835688] 2.6.30-rc4-00336-g8c9ed89 #52 [ 110.835757] --------------------------------- [ 110.835828] inconsistent {HARDIRQ-ON-W} -> {IN-HARDIRQ-W} usage. [ 110.835908] swapper/0 [HC1[1]:SC0[0]:HE0:SE1] takes: [ 110.835982] (cmci_discover_lock){?.+...}, at: [<ffffffff80236dc0>] cmci_clear+0x30/0x9b cmci_clear() can be called via smp_call_function_single(). It is better to disable interrupt while holding cmci_discover_lock, to turn it into an irq-safe lock - we can deadlock otherwise. [ Impact: fix possible deadlock in the MCE code ] Reported-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <4A03ED38.8000700@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Reported-by: Shaohua Li<shaohua.li@intel.com>
2009-05-08x86: xen, i386: reserve Xen pagetablesJeremy Fitzhardinge
The Xen pagetables are no longer implicitly reserved as part of the other i386_start_kernel reservations, so make sure we explicitly reserve them. This prevents them from being released into the general kernel free page pool and reused. [ Impact: fix Xen guest crash ] Also-Bisected-by: Bryan Donlan <bdonlan@gmail.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Xen-devel <xen-devel@lists.xensource.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4A032EEC.30509@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-07x86, kexec: fix crashdump panic with CONFIG_KEXEC_JUMPHuang Ying
Tim Starling reported that crashdump will panic with kernel compiled with CONFIG_KEXEC_JUMP due to null pointer deference in machine_kexec_32.c: machine_kexec(), when deferencing kexec_image. Refering to: http://bugzilla.kernel.org/show_bug.cgi?id=13265 This patch fixes the BUG via replacing global variable reference: kexec_image in machine_kexec() with local variable reference: image, which is more appropriate, and will not be null. Same BUG is in machine_kexec_64.c too, so fixed too in the same way. [ Impact: fix crash on kexec ] Reported-by: Tim Starling <tstarling@wikimedia.org> Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1241751101.6259.85.camel@yhuang-dev.sh.intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-05-07x86-64: finish cleanup_highmaps()'s job wrt. _brk_endJan Beulich
With the introduction of the .brk section, special care must be taken that no unused page table entries remain if _brk_end and _end are separated by a 2M page boundary. cleanup_highmap() runs very early and hence cannot take care of that, hence potential entries needing to be removed past _brk_end must be cleared once the brk allocator has done its job. [ Impact: avoids undesirable TLB aliases ] Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-05-07x86: fix boot hang in early_reserve_e820()Jan Beulich
If the first non-reserved (sub-)range doesn't fit the size requested, an endless loop will be entered. If a range returned from find_e820_area_size() turns out insufficient in size, the range must be skipped before calling the function again. [ Impact: fixes boot hang on some platforms ] Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-05-07Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 5507/1: support R_ARM_MOVW_ABS_NC and MOVT_ABS relocation types [ARM] 5506/1: davinci: DMA_32BIT_MASK --> DMA_BIT_MASK(32) i.MX31: Disable CPU_32v6K in mx3_defconfig. mx3fb: Fix compilation with CONFIG_PM mx27ads: move PBC mapping out of vmalloc space MXC: remove BUG_ON in interrupt handler mx31: remove mx31moboard_defconfig ARM: ARCH_MXC should select HAVE_CLK mxc : BUG in imx_dma_request mxc : Clean up properly when imx_dma_free() used without imx_dma_disable() [ARM] mv78xx0: update defconfig [ARM] orion5x: update defconfig [ARM] Kirkwood: update defconfig [ARM] Kconfig typo fix: "PXA930" -> "CPU_PXA930". [ARM] S3C2412: Add missing cache flush in suspend code [ARM] S3C: Add UDIVSLOT support for newer UARTS [ARM] S3C64XX: Add S3C64XX_PA_IIS{0,1} to <mach/map.h>
2009-05-07[ARM] 5507/1: support R_ARM_MOVW_ABS_NC and MOVT_ABS relocation typesPaul Gortmaker
From: Bruce Ashfield <bruce.ashfield@windriver.com> To fully support the armv7-a instruction set/optimizations, support for the R_ARM_MOVW_ABS_NC and R_ARM_MOVT_ABS relocation types is required. The MOVW and MOVT are both load-immediate instructions, MOVW loads 16 bits into the bottom half of a register, and MOVT loads 16 bits into the top half of a register. The relocation information for these instructions has a full 32 bit value, plus an addend which is stored in the 16 immediate bits in the instruction itself. The immediate bits in the instruction are not contiguous (the register # splits it into a 4 bit and 12 bit value), so the addend has to be extracted accordingly and added to the value. The value is then split and put into the instruction; a MOVW uses the bottom 16 bits of the value, and a MOVT uses the top 16 bits. Signed-off-by: David Borman <david.borman@windriver.com> Signed-off-by: Bruce Ashfield <bruce.ashfield@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-07[ARM] 5506/1: davinci: DMA_32BIT_MASK --> DMA_BIT_MASK(32)Kevin Hilman
As per commit 284901a90a9e0b812ca3f5f852cbbfb60d10249d, use DMA_BIT_MASK(n) Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-06x86: Fix a typo in a printk messageNikanth Karthikesan
[ Impact: printk message cleanup ] Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> LKML-Reference: <200905040908.27299.knikanth@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-06x86, srat: do not register nodes beyond e820 mapDavid Rientjes
The mem= option will truncate the memory map at a specified address so it's not possible to register nodes with memory beyond the e820 upper bound. unparse_node() is only called when then node had memory associated with it, although with the mem= option it is no longer addressable. [ Impact: fix boot hang on certain (large) systems ] Reported-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <alpine.DEB.2.00.0905051248150.20021@chino.kir.corp.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-05Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] xen_domu_defconfig: fix build issues/warnings
2009-05-05Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: x86, mmiotrace: fix range test tracing: fix ref count in splice pages
2009-05-05Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: show number of core_siblings instead of thread_siblings in /proc/cpuinfo amd-iommu: fix iommu flag masks x86: initialize io_bitmap_base on 32bit x86: gettimeofday() vDSO: fix segfault when tv == NULL
2009-05-05[IA64] xen_domu_defconfig: fix build issues/warningsJan Beulich
- drivers/xen/events.c did not compile - xen_setup_hook caused a modpost section warning - the use of u64 (instead of unsigned long long) together with a %llu in drivers/xen/balloon.c caused a compiler warning Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-05-05Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Fix setting of oprofile cpu type powerpc: Update MPC5xxx and Xilinx Virtex maintainer entries powerpc adjust oprofile_cpu_type version 3
2009-05-05Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6Russell King
2009-05-05Merge branch 'for-rmk' of git://git.marvell.com/orionRussell King
2009-05-05i.MX31: Disable CPU_32v6K in mx3_defconfig.Magnus Lilja
The i.MX31 ARM11 core is not a v6K core. Disable this option as it is incompatible with non v6K cores. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-05-05mx27ads: move PBC mapping out of vmalloc spaceUwe Kleine-König
Before this patch I got the following line in my dmesg: [ 0.000000] BUG: mapping for 0xd4000000 at 0xeb000000 overlaps vmalloc space VMALLOC_END is 0xf4000000 and there are the following other mappings defined for mx27ads: (0xa0500000,+0x00001000) maps to 0xffff0000 (0x10000000,+0x00100000) maps to 0xf4000000 (0x80000000,+0x00100000) maps to 0xf4100000 (0xd8000000,+0x00100000) maps to 0xf4200000 So map PBC to 0xf4300000. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-05-05MXC: remove BUG_ON in interrupt handlerSascha Hauer
On i.MX31 I sometimes get spurious interrupts. There is no need to crash the whole system when this happens. Instead, silently ignore it. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-05-05mx31: remove mx31moboard_defconfigValentin Longchamp
We want to have a mx31_defconfig file that builds a kernel that is able to boot on all support mx31 systems and thus also can be better tested by automatic build scripts. For these reasons, this config file is not needed anymore. Signed-off-by: Valentin Longchamp <valentin.longchamp@epfl.ch> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-05-05ARM: ARCH_MXC should select HAVE_CLKGuennadi Liakhovetski
All i.MX platforms support <linux/clk.h> calls and should select HAVE_CLK. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-05-05mxc : BUG in imx_dma_requestMartin Fuzzey
On MX2 platforms imx_dma_request() calls request_irq() which may sleep with interrupts disabled. Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-05-05mxc : Clean up properly when imx_dma_free() used without imx_dma_disable()Martin Fuzzey
The sequence imx_dma_request() imx_dma_enable() imx_dma_free() left the dma channel in_use mode and did not release the timer. Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-05-04[ARM] mv78xx0: update defconfigNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-05-04[ARM] orion5x: update defconfigNicolas Pitre
2009-05-04[ARM] Kirkwood: update defconfigNicolas Pitre
2009-05-04x86: show number of core_siblings instead of thread_siblings in /proc/cpuinfoAndreas Herrmann
Commit 7ad728f98162cb1af06a85b2a5fc422dddd4fb78 (cpumask: x86: convert cpu_sibling_map/cpu_core_map to cpumask_var_t) changed the output of /proc/cpuinfo for siblings: Example on an AMD Phenom: physical id : 0 siblings : 1 core id : 3 cpu cores : 4 Before that commit it was: physical id : 0 siblings : 4 core id : 3 cpu cores : 4 Instead of cpu_core_mask it now uses cpu_sibling_mask to count siblings. This is due to the following hunk of above commit: | --- a/arch/x86/kernel/cpu/proc.c | +++ b/arch/x86/kernel/cpu/proc.c | @@ -14,7 +14,7 @@ static void show_cpuinfo_core(struct seq_file *m, struct cpuinf | if (c->x86_max_cores * smp_num_siblings > 1) { | seq_printf(m, "physical id\t: %d\n", c->phys_proc_id); | seq_printf(m, "siblings\t: %d\n", | - cpus_weight(per_cpu(cpu_core_map, cpu))); | + cpumask_weight(cpu_sibling_mask(cpu))); | seq_printf(m, "core id\t\t: %d\n", c->cpu_core_id); | seq_printf(m, "cpu cores\t: %d\n", c->booted_cores); | seq_printf(m, "apicid\t\t: %d\n", c->apicid); This was a mistake, because the impact line shows that this side-effect was not anticipated: Impact: reduce per-cpu size for CONFIG_CPUMASK_OFFSTACK=y So revert the respective hunk to restore the old behavior. [ Impact: fix sibling-info regression in /proc/cpuinfo ] Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <20090504182859.GA29045@alberich.amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-04amd-iommu: fix iommu flag masksJoerg Roedel
The feature bits should be set via bitmasks, not via feature IDs. [ Impact: fix feature enabling in newer IOMMU versions ] Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> LKML-Reference: <20090504102028.GA30307@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-03[ARM] Kconfig typo fix: "PXA930" -> "CPU_PXA930".Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-03Merge branch 'v2630-rc3-fixes' of git://aeryn.fluff.org.uk/bjdooks/linuxRussell King
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (45 commits) [ARM] 5489/1: ARM errata: Data written to the L2 cache can be overwritten with stale data [ARM] 5490/1: ARM errata: Processor deadlock when a false hazard is created [ARM] 5487/1: ARM errata: Stale prediction on replaced interworking branch [ARM] 5488/1: ARM errata: Invalidation of the Instruction Cache operation can fail davinci: DM644x: NAND: update partitioning davinci: update DM644x support in preparation for more SoCs davinci: DM644x: rename board file davinci: update pin-multiplexing support davinci: serial: generalize for more SoCs davinci: DM355 IRQ Definitions davinci: DM646x: add interrupt number and priorities davinci: PSC: Clear bits in MDCTL reg before setting new bits davinci: gpio bugfixes davinci: add EDMA driver davinci: timers: use clk_get_rate() [ARM] pxa/littleton: add missing da9034 touchscreen support [ARM] pxa/zylonite: configure GPIO18/19 correctly, used by 2 GPIO expanders [ARM] pxa/zylonite: fix the issue of unused SDATA_IN_1 pin get AC97 not working [ARM] pxa: make ads7846 on corgi and spitz to sync on HSYNC [ARM] pxa: remove unused CPU_FREQ_PXA Kconfig symbol ...
2009-05-02Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip: x86, mce: fix boot logging logic x86, mce: make polling timer interval per CPU
2009-05-02Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild, modpost: Check the section flags, to catch missing "ax"/"aw" kbuild: fix comment in modpost.c kbuild: fix scripts/setlocalversion with git kbuild: fix Module.markers permission error under cygwin docs: also clean index.html kbuild: remove a tag file before it is regenerated kbuild: "make prepare" should be "make modules_prepare" kbuild: clean Module.markers and modules.order for out-of-tree modules avr32: drop unused CLEAN_FILES
2009-05-02Merge branch 'for-linus' of git://www.linux-m32r.org/git/takata/linux-2.6_devLinus Torvalds
* 'for-linus' of git://www.linux-m32r.org/git/takata/linux-2.6_dev: m32r: use __stringify() macro in assembler.h m32r: build fix for __stringify macro
2009-05-02of: make of_(un)register_platform_driver common codeGrant Likely
Some drivers using of_register_platform_driver() wrapper break on sparc because the wrapper isn't in the header file. This patch moves it from Microblaze and PowerPC implementations and makes it common code. Fixes this sparc64 allmodconfig build error (at least): drivers/leds/leds-gpio.c: In function `gpio_led_init': drivers/leds/leds-gpio.c:295: error: implicit declaration of function `of_register_platform_driver' drivers/leds/leds-gpio.c: In function `gpio_led_exit': drivers/leds/leds-gpio.c:311: error: implicit declaration of function `of_unregister_platform_driver' Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Cc: Michal Simek <monstr@monstr.eu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02alpha: binfmt_aout fixIvan Kokshaysky
This fixes the problem introduced by commit 3bfacef412 (get rid of special-casing the /sbin/loader on alpha): osf/1 ecoff binary segfaults when binfmt_aout built as module. That happens because aout binary handler gets on the top of the binfmt list due to late registration, and kernel attempts to execute the binary without preparatory work that must be done by binfmt_loader. Fixed by changing the registration order of the default binfmt handlers using list_add_tail() and introducing insert_binfmt() function which places new handler on the top of the binfmt list. This might be generally useful for installing arch-specific frontends for default handlers or just for overriding them. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Richard Henderson <rth@twiddle.net Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02alpha: futex implementationIvan Kokshaysky
2009-05-02alpha: exception table sortingIvan Kokshaysky
Exception fixups for sections other than .text (like one in futex_init()) break the natural ordering of fixup entries, so sorting is required. Without that the result of the exception table search depends on phase of the moon. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Richard Henderson <rth@twiddle.net Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02alpha: titan and marvel build fixesIvan Kokshaysky
These platforms got broken after u64 => 'long long' conversion. Apparently that change was compile-tested with 'make allmodconfig', but it doesn't include systems that depend on !ALPHA_LEGACY_START_ADDRESS. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Richard Henderson <rth@twiddle.net Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02m32r: use __stringify() macro in assembler.hHirokazu Takata
Replace #x with __stringify(x). Also, #ifndef __STR is removed and undefine __STR macro at the beginning. The __STR() macro is still remained, because the assembler.h might be included from assembly codes as well as C codes. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-05-02m32r: build fix for __stringify macroHirokazu Takata
This patch fixes the following build error of 2.6.30-rc3-git2: AS arch/m32r/kernel/head.o In file included from /include/linux/init.h:7, from /arch/m32r/kernel/head.S:11: /include/linux/stringify.h:9: error: syntax error in macro parameter list /include/linux/stringify.h:10: error: syntax error in macro parameter list This build error was caused at __HEAD macro in arch/m32r/kernel/head.S, which uses __stringify() macro. Remove -traditional option from EXTRA_AFLAGS for the m32r, because the __stringify() macro depends on the gcc's variadic macro extension function, due to commit: Make __stringify support variable argument macros too commit: 8f7c2c37319a81ef4c2bfdec67b1ccd5744d97e4 Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-05-01x86: initialize io_bitmap_base on 32bitThomas Gleixner
commit db949bba3c7cf2e664ac12e237c6d4c914f0c69d (x86-32: use non-lazy io bitmap context switching) broke ioperm for 32bit because it removed the lazy initialization of io_bitmap_base and did not set it to the real bitmap offset. [ Impact: fix non-working sys_ioperm() on 32-bit kernels ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-05-01microblaze: Fix return value for sys_ipcMichal Simek
Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-05-01microblaze: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-05-01[ARM] S3C2412: Add missing cache flush in suspend codeBen Dooks
The alterations to the suspend code missed adding a call to the cache flushing routines during the suspend path of the S3C2412. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-01[ARM] S3C64XX: Add S3C64XX_PA_IIS{0,1} to <mach/map.h>Ben Dooks
Add the physical address of the two I2S channel register blocks. Signed-off-by: Ben Dooks <ben@simtec.co.uk>
