path: root/arch
2018-09-09sys: don't hold uts_sem while accessing userspace memoryJann Horn
commit 42a0cc3478584d4d63f68f2f5af021ddbea771fa upstream. Holding uts_sem as a writer while accessing userspace memory allows a namespace admin to stall all processes that attempt to take uts_sem. Instead, move data through stack buffers and don't access userspace memory while uts_sem is held. Cc: stable@vger.kernel.org Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Jann Horn <jannh@google.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09osf_getdomainname(): use copy_to_user()Al Viro
commit 9ba3eb5103cf56f0daaf07de4507df76e7813ed7 upstream. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09Fix kexec forbidding kernels signed with keys in the secondary keyring to bootYannik Sembritzki
commit ea93102f32244e3f45c8b26260be77ed0cc1d16c upstream. The split of .system_keyring into .builtin_trusted_keys and .secondary_trusted_keys broke kexec, thereby preventing kernels signed by keys which are now in the secondary keyring from being kexec'd. Fix this by passing VERIFY_USE_SECONDARY_KEYRING to verify_pefile_signature(). Fixes: d3bfe84129f6 ("certs: Add a secondary system keyring that can be added to dynamically") Signed-off-by: Yannik Sembritzki <yannik@sembritzki.me> Signed-off-by: David Howells <dhowells@redhat.com> Cc: kexec@lists.infradead.org Cc: keyrings@vger.kernel.org Cc: linux-security-module@vger.kernel.org Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09ARM: tegra: Fix Tegra30 Cardhu PCA954x resetJon Hunter
commit 6e1811900b6fe6f2b4665dba6bd6ed32c6b98575 upstream. On all versions of Tegra30 Cardhu, the reset signal to the NXP PCA9546 I2C mux is connected to the Tegra GPIO BB0. Currently, this pin on the Tegra is not configured as a GPIO but as a special-function IO (SFIO) that is multiplexing the pin to an I2S controller. On exiting system suspend, I2C commands sent to the PCA9546 are failing because there is no ACK. Although it is not possible to see exactly what is happening to the reset during suspend, by ensuring it is configured as a GPIO and driven high, to de-assert the reset, the failures are no longer seen. Please note that this GPIO is also used to drive the reset signal going to the camera connector on the board. However, given that there is no camera support currently for Cardhu, this should not have any impact. Fixes: 40431d16ff11 ("ARM: tegra: enable PCA9546 on Cardhu") Cc: stable@vger.kernel.org Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09xtensa: increase ranges in ___invalidate_{i,d}cache_allMax Filippov
commit fec3259c9f747c039f90e99570540114c8d81a14 upstream. Cache invalidation macros use cache line size to iterate over invalidated cache lines, assuming that all cache ways are invalidated by single instruction, but xtensa ISA recommends to not assume that for future compatibility: In some implementations all ways at index Addry-1..z are invalidated regardless of the specified way, but for future compatibility this behavior should not be assumed. Iterate over all cache ways in ___invalidate_icache_all and ___invalidate_dcache_all. Cc: stable@vger.kernel.org Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09xtensa: limit offsets in __loop_cache_{all,page}Max Filippov
commit be75de25251f7cf3e399ca1f584716a95510d24a upstream. When building kernel for xtensa cores with big cache lines (e.g. 128 bytes or more) __loop_cache_all and __loop_cache_page may generate assembly instructions with immediate fields that are too big. This results in the following build errors: arch/xtensa/mm/misc.S: Assembler messages: arch/xtensa/mm/misc.S:464: Error: operand 2 of 'diwbi' has invalid value '256' arch/xtensa/mm/misc.S:464: Error: operand 2 of 'diwbi' has invalid value '384' arch/xtensa/kernel/head.S: Assembler messages: arch/xtensa/kernel/head.S:172: Error: operand 2 of 'diu' has invalid value '256' arch/xtensa/kernel/head.S:172: Error: operand 2 of 'diu' has invalid value '384' arch/xtensa/kernel/head.S:176: Error: operand 2 of 'iiu' has invalid value '256' arch/xtensa/kernel/head.S:176: Error: operand 2 of 'iiu' has invalid value '384' arch/xtensa/kernel/head.S:255: Error: operand 2 of 'diwb' has invalid value '256' arch/xtensa/kernel/head.S:255: Error: operand 2 of 'diwb' has invalid value '384' Add parameter max_immed to these macros and use it to limit values of immediate operands. Extract common code of these macros into the new macro __loop_cache_unroll. Cc: stable@vger.kernel.org Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09KVM: VMX: fixes for vmentry_l1d_flush module parameterPaolo Bonzini
commit 0027ff2a75f9dcf0537ac0a65c5840b0e21a4950 upstream. Two bug fixes: 1) missing entries in the l1d_param array; this can cause a host crash if an access attempts to reach the missing entry. Future-proof the get function against any overflows as well. However, the two entries VMENTER_L1D_FLUSH_EPT_DISABLED and VMENTER_L1D_FLUSH_NOT_REQUIRED must not be accepted by the parse function, so disable them there. 2) invalid values must be rejected even if the CPU does not have the bug, so test for them before checking boot_cpu_has(X86_BUG_L1TF) ... and a small refactoring, since the .cmd field is redundant with the index in the array. Reported-by: Bandan Das <bsd@redhat.com> Cc: stable@vger.kernel.org Fixes: a7b9020b06ec6d7c3f3b0d4ef1a9eba12654f4f7 Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09powerpc/powernv/pci: Work around races in PCI bridge enablingBenjamin Herrenschmidt
commit db2173198b9513f7add8009f225afa1f1c79bcc6 upstream. The generic code is racy when multiple children of a PCI bridge try to enable it simultaneously. This leads to drivers trying to access a device through a not-yet-enabled bridge, and this EEH errors under various circumstances when using parallel driver probing. There is work going on to fix that properly in the PCI core but it will take some time. x86 gets away with it because (outside of hotplug), the BIOS enables all the bridges at boot time. This patch does the same thing on powernv by enabling all bridges that have child devices at boot time, thus avoiding subsequent races. It's suitable for backporting to stable and distros, while the proper PCI fix will probably be significantly more invasive. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: stable@vger.kernel.org Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09powerpc/pseries: Fix endianness while restoring of r3 in MCE handler.Mahesh Salgaonkar
commit cd813e1cd7122f2c261dce5b54d1e0c97f80e1a5 upstream. During Machine Check interrupt on pseries platform, register r3 points RTAS extended event log passed by hypervisor. Since hypervisor uses r3 to pass pointer to rtas log, it stores the original r3 value at the start of the memory (first 8 bytes) pointed by r3. Since hypervisor stores this info and rtas log is in BE format, linux should make sure to restore r3 value in correct endian format. Without this patch when MCE handler, after recovery, returns to code that that caused the MCE may end up with Data SLB access interrupt for invalid address followed by kernel panic or hang. Severe Machine check interrupt [Recovered] NIP [d00000000ca301b8]: init_module+0x1b8/0x338 [bork_kernel] Initiator: CPU Error type: SLB [Multihit] Effective address: d00000000ca70000 cpu 0xa: Vector: 380 (Data SLB Access) at [c0000000fc7775b0] pc: c0000000009694c0: vsnprintf+0x80/0x480 lr: c0000000009698e0: vscnprintf+0x20/0x60 sp: c0000000fc777830 msr: 8000000002009033 dar: a803a30c000000d0 current = 0xc00000000bc9ef00 paca = 0xc00000001eca5c00 softe: 3 irq_happened: 0x01 pid = 8860, comm = insmod vscnprintf+0x20/0x60 vprintk_emit+0xb4/0x4b0 vprintk_func+0x5c/0xd0 printk+0x38/0x4c init_module+0x1c0/0x338 [bork_kernel] do_one_initcall+0x54/0x230 do_init_module+0x8c/0x248 load_module+0x12b8/0x15b0 sys_finit_module+0xa8/0x110 system_call+0x58/0x6c --- Exception: c00 (System Call) at 00007fff8bda0644 SP (7fffdfbfe980) is in userspace This patch fixes this issue. Fixes: a08a53ea4c97 ("powerpc/le: Enable RTAS events support") Cc: stable@vger.kernel.org # v3.15+ Reviewed-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09powerpc/fadump: handle crash memory ranges array index overflowHari Bathini
commit 1bd6a1c4b80a28d975287630644e6b47d0f977a5 upstream. Crash memory ranges is an array of memory ranges of the crashing kernel to be exported as a dump via /proc/vmcore file. The size of the array is set based on INIT_MEMBLOCK_REGIONS, which works alright in most cases where memblock memory regions count is less than INIT_MEMBLOCK_REGIONS value. But this count can grow beyond INIT_MEMBLOCK_REGIONS value since commit 142b45a72e22 ("memblock: Add array resizing support"). On large memory systems with a few DLPAR operations, the memblock memory regions count could be larger than INIT_MEMBLOCK_REGIONS value. On such systems, registering fadump results in crash or other system failures like below: task: c00007f39a290010 ti: c00000000b738000 task.ti: c00000000b738000 NIP: c000000000047df4 LR: c0000000000f9e58 CTR: c00000000010f180 REGS: c00000000b73b570 TRAP: 0300 Tainted: G L X (4.4.140+) MSR: 8000000000009033 <SF,EE,ME,IR,DR,RI,LE> CR: 22004484 XER: 20000000 CFAR: c000000000008500 DAR: 000007a450000000 DSISR: 40000000 SOFTE: 0 ... NIP [c000000000047df4] smp_send_reschedule+0x24/0x80 LR [c0000000000f9e58] resched_curr+0x138/0x160 Call Trace: resched_curr+0x138/0x160 (unreliable) check_preempt_curr+0xc8/0xf0 ttwu_do_wakeup+0x38/0x150 try_to_wake_up+0x224/0x4d0 __wake_up_common+0x94/0x100 ep_poll_callback+0xac/0x1c0 __wake_up_common+0x94/0x100 __wake_up_sync_key+0x70/0xa0 sock_def_readable+0x58/0xa0 unix_stream_sendmsg+0x2dc/0x4c0 sock_sendmsg+0x68/0xa0 ___sys_sendmsg+0x2cc/0x2e0 __sys_sendmsg+0x5c/0xc0 SyS_socketcall+0x36c/0x3f0 system_call+0x3c/0x100 as array index overflow is not checked for while setting up crash memory ranges causing memory corruption. To resolve this issue, dynamically allocate memory for crash memory ranges and resize it incrementally, in units of pagesize, on hitting array size limit. Fixes: 2df173d9e85d ("fadump: Initialize elfcore header and add PT_LOAD program headers.") Cc: stable@vger.kernel.org # v3.4+ Signed-off-by: Hari Bathini <hbathini@linux.ibm.com> Reviewed-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> [mpe: Just use PAGE_SIZE directly, fixup variable placement] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05MIPS: lib: Provide MIPS64r6 __multi3() for GCC < 7Paul Burton
commit 690d9163bf4b8563a2682e619f938e6a0443947f upstream. Some versions of GCC suboptimally generate calls to the __multi3() intrinsic for MIPS64r6 builds, resulting in link failures due to the missing function: LD vmlinux.o MODPOST vmlinux.o kernel/bpf/verifier.o: In function `kmalloc_array': include/linux/slab.h:631: undefined reference to `__multi3' fs/select.o: In function `kmalloc_array': include/linux/slab.h:631: undefined reference to `__multi3' ... We already have a workaround for this in which we provide the instrinsic, but we do so selectively for GCC 7 only. Unfortunately the issue occurs with older GCC versions too - it has been observed with both GCC 5.4.0 & GCC 6.4.0. MIPSr6 support was introduced in GCC 5, so all major GCC versions prior to GCC 8 are affected and we extend our workaround accordingly to all MIPS64r6 builds using GCC versions older than GCC 8. Signed-off-by: Paul Burton <paul.burton@mips.com> Reported-by: Vladimir Kondratiev <vladimir.kondratiev@intel.com> Fixes: ebabcf17bcd7 ("MIPS: Implement __multi3 for GCC7 MIPS64r6 builds") Patchwork: https://patchwork.linux-mips.org/patch/20297/ Cc: James Hogan <jhogan@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org # 4.15+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05MIPS: Correct the 64-bit DSP accumulator register sizeMaciej W. Rozycki
commit f5958b4cf4fc38ed4583ab83fb7c4cd1ab05f47b upstream. Use the `unsigned long' rather than `__u32' type for DSP accumulator registers, like with the regular MIPS multiply/divide accumulator and general-purpose registers, as all are 64-bit in 64-bit implementations and using a 32-bit data type leads to contents truncation on context saving. Update `arch_ptrace' and `compat_arch_ptrace' accordingly, removing casts that are similarly not used with multiply/divide accumulator or general-purpose register accesses. Signed-off-by: Maciej W. Rozycki <macro@mips.com> Signed-off-by: Paul Burton <paul.burton@mips.com> Fixes: e50c0a8fa60d ("Support the MIPS32 / MIPS64 DSP ASE.") Patchwork: https://patchwork.linux-mips.org/patch/19329/ Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: James Hogan <jhogan@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-fsdevel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org # 2.6.15+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05s390/pci: fix out of bounds access during irq setupSebastian Ott
commit 866f3576a72b2233a76dffb80290f8086dc49e17 upstream. During interrupt setup we allocate interrupt vectors, walk the list of msi descriptors, and fill in the message data. Requesting more interrupts than supported on s390 can lead to an out of bounds access. When we restrict the number of interrupts we should also stop walking the msi list after all supported interrupts are handled. Cc: stable@vger.kernel.org Signed-off-by: Sebastian Ott <sebott@linux.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05s390/numa: move initial setup of node_to_cpumask_mapMartin Schwidefsky
commit fb7d7518b0d65955f91c7b875c36eae7694c69bd upstream. The numa_init_early initcall sets the node_to_cpumask_map[0] to the full cpu_possible_mask. Unfortunately this early_initcall is too late, the NUMA setup for numa=emu is done even earlier. The order of calls is numa_setup() -> emu_update_cpu_topology(), then the early_initcalls(), followed by sched_init_domains(). Starting with git commit 051f3ca02e46432c0965e8948f00c07d8a2f09c0 "sched/topology: Introduce NUMA identity node sched domain" the incorrect node_to_cpumask_map[0] really screws up the domain setup and the kernel panics with the follow oops: Cc: <stable@vger.kernel.org> # v4.15+ Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05s390/qdio: reset old sbal_state flagsJulian Wiedmann
commit 64e03ff72623b8c2ea89ca3cb660094e019ed4ae upstream. When allocating a new AOB fails, handle_outbound() is still capable of transmitting the selected buffer (just without async completion). But if a previous transfer on this queue slot used async completion, its sbal_state flags field is still set to QDIO_OUTBUF_STATE_FLAG_PENDING. So when the upper layer driver sees this stale flag, it expects an async completion that never happens. Fix this by unconditionally clearing the flags field. Fixes: 104ea556ee7f ("qdio: support asynchronous delivery of storage blocks") Cc: <stable@vger.kernel.org> #v3.2+ Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05s390: fix br_r1_trampoline for machines without exrlMartin Schwidefsky
commit 26f843848bae973817b3587780ce6b7b0200d3e4 upstream. For machines without the exrl instruction the BFP jit generates code that uses an "br %r1" instruction located in the lowcore page. Unfortunately there is a cut & paste error that puts an additional "larl %r1,.+14" instruction in the code that clobbers the branch target address in %r1. Remove the larl instruction. Cc: <stable@vger.kernel.org> # v4.17+ Fixes: de5cb6eb51 ("s390: use expoline thunks in the BPF JIT") Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/entry/64: Wipe KASAN stack shadow before rewind_stack_do_exit()Jann Horn
commit f12d11c5c184626b4befdee3d573ec8237405a33 upstream. Reset the KASAN shadow state of the task stack before rewinding RSP. Without this, a kernel oops will leave parts of the stack poisoned, and code running under do_exit() can trip over such poisoned regions and cause nonsensical false-positive KASAN reports about stack-out-of-bounds bugs. This does not wipe the exception stacks; if an oops happens on an exception stack, it might result in random KASAN false-positives from other tasks afterwards. This is probably relatively uninteresting, since if the kernel oopses on an exception stack, there are most likely bigger things to worry about. It'd be more interesting if vmapped stacks and KASAN were compatible, since then handle_stack_overflow() would oops from exception stack context. Fixes: 2deb4be28077 ("x86/dumpstack: When OOPSing, rewind the stack before do_exit()") Signed-off-by: Jann Horn <jannh@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Alexander Potapenko <glider@google.com> Cc: Kees Cook <keescook@chromium.org> Cc: kasan-dev@googlegroups.com Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180828184033.93712-1-jannh@google.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/speculation/l1tf: Increase l1tf memory limit for Nehalem+Andi Kleen
commit cc51e5428ea54f575d49cfcede1d4cb3a72b4ec4 upstream. On Nehalem and newer core CPUs the CPU cache internally uses 44 bits physical address space. The L1TF workaround is limited by this internal cache address width, and needs to have one bit free there for the mitigation to work. Older client systems report only 36bit physical address space so the range check decides that L1TF is not mitigated for a 36bit phys/32GB system with some memory holes. But since these actually have the larger internal cache width this warning is bogus because it would only really be needed if the system had more than 43bits of memory. Add a new internal x86_cache_bits field. Normally it is the same as the physical bits field reported by CPUID, but for Nehalem and newerforce it to be at least 44bits. Change the L1TF memory size warning to use the new cache_bits field to avoid bogus warnings and remove the bogus comment about memory size. Fixes: 17dbca119312 ("x86/speculation/l1tf: Add sysfs reporting for l1tf") Reported-by: George Anchev <studio@anchev.net> Reported-by: Christopher Snowhill <kode54@gmail.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: x86@kernel.org Cc: linux-kernel@vger.kernel.org Cc: Michael Hocko <mhocko@suse.com> Cc: vbabka@suse.cz Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180824170351.34874-1-andi@firstfloor.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/spectre: Add missing family 6 check to microcode checkAndi Kleen
commit 1ab534e85c93945f7862378d8c8adcf408205b19 upstream. The check for Spectre microcodes does not check for family 6, only the model numbers. Add a family 6 check to avoid ambiguity with other families. Fixes: a5b296636453 ("x86/cpufeature: Blacklist SPEC_CTRL/PRED_CMD on early Spectre v2 microcodes") Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: x86@kernel.org Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180824170351.34874-2-andi@firstfloor.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/irqflags: Mark native_restore_fl extern inlineNick Desaulniers
commit 1f59a4581b5ecfe9b4f049a7a2cf904d8352842d upstream. This should have been marked extern inline in order to pick up the out of line definition in arch/x86/kernel/irqflags.S. Fixes: 208cbb325589 ("x86/irqflags: Provide a declaration for native_save_fl") Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Juergen Gross <jgross@suse.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180827214011.55428-1-ndesaulniers@google.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/kvm/vmx: Remove duplicate l1d flush definitionsJosh Poimboeuf
commit 94d7a86c21a3d6046bf4616272313cb7d525075a upstream. These are already defined higher up in the file. Fixes: 7db92e165ac8 ("x86/kvm: Move l1tf setup function") Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/d7ca03ae210d07173452aeed85ffe344301219a5.1534253536.git.jpoimboe@redhat.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05KVM: x86: SVM: Call x86_spec_ctrl_set_guest/host() with interrupts disabledThomas Gleixner
commit 024d83cadc6b2af027e473720f3c3da97496c318 upstream. Mikhail reported the following lockdep splat: WARNING: possible irq lock inversion dependency detected CPU 0/KVM/10284 just changed the state of lock: 000000000d538a88 (&st->lock){+...}, at: speculative_store_bypass_update+0x10b/0x170 but this lock was taken by another, HARDIRQ-safe lock in the past: (&(&sighand->siglock)->rlock){-.-.} and interrupts could create inverse lock ordering between them. Possible interrupt unsafe locking scenario: CPU0 CPU1 ---- ---- lock(&st->lock); local_irq_disable(); lock(&(&sighand->siglock)->rlock); lock(&st->lock); <Interrupt> lock(&(&sighand->siglock)->rlock); *** DEADLOCK *** The code path which connects those locks is: speculative_store_bypass_update() ssb_prctl_set() do_seccomp() do_syscall_64() In svm_vcpu_run() speculative_store_bypass_update() is called with interupts enabled via x86_virt_spec_ctrl_set_guest/host(). This is actually a false positive, because GIF=0 so interrupts are disabled even if IF=1; however, we can easily move the invocations of x86_virt_spec_ctrl_set_guest/host() into the interrupt disabled region to cure it, and it's a good idea to keep the GIF=0/IF=1 area as small and self-contained as possible. Fixes: 1f50ddb4f418 ("x86/speculation: Handle HT correctly on AMD") Reported-by: Mikhail Gavrilov <mikhail.v.gavrilov@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Mikhail Gavrilov <mikhail.v.gavrilov@gmail.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Borislav Petkov <bp@suse.de> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tom Lendacky <thomas.lendacky@amd.com> Cc: kvm@vger.kernel.org Cc: x86@kernel.org Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/process: Re-export start_thread()Rian Hunter
commit dc76803e57cc86589c4efcb5362918f9b0c0436f upstream. The consolidation of the start_thread() functions removed the export unintentionally. This breaks binfmt handlers built as a module. Add it back. Fixes: e634d8fc792c ("x86-64: merge the standard and compat start_thread() functions") Signed-off-by: Rian Hunter <rian@alum.mit.edu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Dmitry Safonov <dima@arista.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180819230854.7275-1-rian@alum.mit.edu Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/speculation/l1tf: Suggest what to do on systems with too much RAMVlastimil Babka
commit 6a012288d6906fee1dbc244050ade1dafe4a9c8d upstream. Two users have reported [1] that they have an "extremely unlikely" system with more than MAX_PA/2 memory and L1TF mitigation is not effective. Make the warning more helpful by suggesting the proper mem=X kernel boot parameter to make it effective and a link to the L1TF document to help decide if the mitigation is worth the unusable RAM. [1] https://bugzilla.suse.com/show_bug.cgi?id=1105536 Suggested-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/966571f0-9d7f-43dc-92c6-a10eec7a1254@suse.cz Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/speculation/l1tf: Fix off-by-one error when warning that system has too ↵Vlastimil Babka
much RAM commit b0a182f875689647b014bc01d36b340217792852 upstream. Two users have reported [1] that they have an "extremely unlikely" system with more than MAX_PA/2 memory and L1TF mitigation is not effective. In fact it's a CPU with 36bits phys limit (64GB) and 32GB memory, but due to holes in the e820 map, the main region is almost 500MB over the 32GB limit: [ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000081effffff] usable Suggestions to use 'mem=32G' to enable the L1TF mitigation while losing the 500MB revealed, that there's an off-by-one error in the check in l1tf_select_mitigation(). l1tf_pfn_limit() returns the last usable pfn (inclusive) and the range check in the mitigation path does not take this into account. Instead of amending the range check, make l1tf_pfn_limit() return the first PFN which is over the limit which is less error prone. Adjust the other users accordingly. [1] https://bugzilla.suse.com/show_bug.cgi?id=1105536 Fixes: 17dbca119312 ("x86/speculation/l1tf: Add sysfs reporting for l1tf") Reported-by: George Anchev <studio@anchev.net> Reported-by: Christopher Snowhill <kode54@gmail.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180823134418.17008-1-vbabka@suse.cz Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/speculation/l1tf: Fix overflow in l1tf_pfn_limit() on 32bitVlastimil Babka
commit 9df9516940a61d29aedf4d91b483ca6597e7d480 upstream. On 32bit PAE kernels on 64bit hardware with enough physical bits, l1tf_pfn_limit() will overflow unsigned long. This in turn affects max_swapfile_size() and can lead to swapon returning -EINVAL. This has been observed in a 32bit guest with 42 bits physical address size, where max_swapfile_size() overflows exactly to 1 << 32, thus zero, and produces the following warning to dmesg: [ 6.396845] Truncating oversized swap area, only using 0k out of 2047996k Fix this by using unsigned long long instead. Fixes: 17dbca119312 ("x86/speculation/l1tf: Add sysfs reporting for l1tf") Fixes: 377eeaa8e11f ("x86/speculation/l1tf: Limit swap file size to MAX_PA/2") Reported-by: Dominique Leuenberger <dimstar@suse.de> Reported-by: Adrian Schroeter <adrian@suse.de> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180820095835.5298-1-vbabka@suse.cz Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05sparc: kernel/pcic: silence gcc 7.x warning in pcibios_fixup_bus()Thomas Petazzoni
commit 2dc77533f1e495788d73ffa4bee4323b2646d2bb upstream. When building the kernel for Sparc using gcc 7.x, the build fails with: arch/sparc/kernel/pcic.c: In function ‘pcibios_fixup_bus’: arch/sparc/kernel/pcic.c:647:8: error: ‘cmd’ may be used uninitialized in this function [-Werror=maybe-uninitialized] cmd |= PCI_COMMAND_IO; ^~ The simplified code looks like this: unsigned int cmd; [...] pcic_read_config(dev->bus, dev->devfn, PCI_COMMAND, 2, &cmd); [...] cmd |= PCI_COMMAND_IO; I.e, the code assumes that pcic_read_config() will always initialize cmd. But it's not the case. Looking at pcic_read_config(), if bus->number is != 0 or if the size is not one of 1, 2 or 4, *val will not be initialized. As a simple fix, we initialize cmd to zero at the beginning of pcibios_fixup_bus. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05KVM: arm/arm64: Skip updating PMD entry if no changePunit Agrawal
commit 86658b819cd0a9aa584cd84453ed268a6f013770 upstream. Contention on updating a PMD entry by a large number of vcpus can lead to duplicate work when handling stage 2 page faults. As the page table update follows the break-before-make requirement of the architecture, it can lead to repeated refaults due to clearing the entry and flushing the tlbs. This problem is more likely when - * there are large number of vcpus * the mapping is large block mapping such as when using PMD hugepages (512MB) with 64k pages. Fix this by skipping the page table update if there is no change in the entry being updated. Cc: stable@vger.kernel.org Fixes: ad361f093c1e ("KVM: ARM: Support hugetlbfs backed huge pages") Reviewed-by: Suzuki Poulose <suzuki.poulose@arm.com> Acked-by: Christoffer Dall <christoffer.dall@arm.com> Signed-off-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05KVM: arm/arm64: Skip updating PTE entry if no changePunit Agrawal
commit 976d34e2dab10ece5ea8fe7090b7692913f89084 upstream. When there is contention on faulting in a particular page table entry at stage 2, the break-before-make requirement of the architecture can lead to additional refaulting due to TLB invalidation. Avoid this by skipping a page table update if the new value of the PTE matches the previous value. Cc: stable@vger.kernel.org Fixes: d5d8184d35c9 ("KVM: ARM: Memory virtualization setup") Reviewed-by: Suzuki Poulose <suzuki.poulose@arm.com> Acked-by: Christoffer Dall <christoffer.dall@arm.com> Signed-off-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05s390/kvm: fix deadlock when killed by oomClaudio Imbrenda
commit 306d6c49ac9ded11114cb53b0925da52f2c2ada1 upstream. When the oom killer kills a userspace process in the page fault handler while in guest context, the fault handler fails to release the mm_sem if the FAULT_FLAG_RETRY_NOWAIT option is set. This leads to a deadlock when tearing down the mm when the process terminates. This bug can only happen when pfault is enabled, so only KVM clients are affected. The problem arises in the rare cases in which handle_mm_fault does not release the mm_sem. This patch fixes the issue by manually releasing the mm_sem when needed. Fixes: 24eb3a824c4f3 ("KVM: s390: Add FAULT_FLAG_RETRY_NOWAIT for guest fault") Cc: <stable@vger.kernel.org> # 3.15+ Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05arm64: mm: check for upper PAGE_SHIFT bits in pfn_valid()Greg Hackmann
commit 5ad356eabc47d26a92140a0c4b20eba471c10de3 upstream. ARM64's pfn_valid() shifts away the upper PAGE_SHIFT bits of the input before seeing if the PFN is valid. This leads to false positives when some of the upper bits are set, but the lower bits match a valid PFN. For example, the following userspace code looks up a bogus entry in /proc/kpageflags: int pagemap = open("/proc/self/pagemap", O_RDONLY); int pageflags = open("/proc/kpageflags", O_RDONLY); uint64_t pfn, val; lseek64(pagemap, [...], SEEK_SET); read(pagemap, &pfn, sizeof(pfn)); if (pfn & (1UL << 63)) { /* valid PFN */ pfn &= ((1UL << 55) - 1); /* clear flag bits */ pfn |= (1UL << 55); lseek64(pageflags, pfn * sizeof(uint64_t), SEEK_SET); read(pageflags, &val, sizeof(val)); } On ARM64 this causes the userspace process to crash with SIGSEGV rather than reading (1 << KPF_NOPAGE). kpageflags_read() treats the offset as valid, and stable_page_flags() will try to access an address between the user and kernel address ranges. Fixes: c1cc1552616d ("arm64: MMU initialisation") Cc: stable@vger.kernel.org Signed-off-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05kprobes/arm64: Fix %p uses in error messagesMasami Hiramatsu
commit 0722867dcbc28cc9b269b57acd847c7c1aa638d6 upstream. Fix %p uses in error messages by removing it because those are redundant or meaningless. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David Howells <dhowells@redhat.com> Cc: David S . Miller <davem@davemloft.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Jon Medhurst <tixy@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Richter <tmricht@linux.ibm.com> Cc: Tobin C . Harding <me@tobin.cc> Cc: acme@kernel.org Cc: akpm@linux-foundation.org Cc: brueckner@linux.vnet.ibm.com Cc: linux-arch@vger.kernel.org Cc: rostedt@goodmis.org Cc: schwidefsky@de.ibm.com Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/lkml/152491908405.9916.12425053035317241111.stgit@devbox Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05arc: fix type warnings in arc/mm/cache.cRandy Dunlap
[ Upstream commit ec837d620c750c0d4996a907c8c4f7febe1bbeee ] Fix type warnings in arch/arc/mm/cache.c. ../arch/arc/mm/cache.c: In function 'flush_anon_page': ../arch/arc/mm/cache.c:1062:55: warning: passing argument 2 of '__flush_dcache_page' makes integer from pointer without a cast [-Wint-conversion] __flush_dcache_page((phys_addr_t)page_address(page), page_address(page)); ^~~~~~~~~~~~~~~~~~ ../arch/arc/mm/cache.c:1013:59: note: expected 'long unsigned int' but argument is of type 'void *' void __flush_dcache_page(phys_addr_t paddr, unsigned long vaddr) ~~~~~~~~~~~~~~^~~~~ Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: linux-snps-arc@lists.infradead.org Cc: Elad Kanfi <eladkan@mellanox.com> Cc: Leon Romanovsky <leonro@mellanox.com> Cc: Ofer Levi <oferle@mellanox.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05arc: fix build errors in arc/include/asm/delay.hRandy Dunlap
[ Upstream commit 2423665ec53f2a29191b35382075e9834288a975 ] Fix build errors in arch/arc/'s delay.h: - add "extern unsigned long loops_per_jiffy;" - add <asm-generic/types.h> for "u64" In file included from ../drivers/infiniband/hw/cxgb3/cxio_hal.c:32: ../arch/arc/include/asm/delay.h: In function '__udelay': ../arch/arc/include/asm/delay.h:61:12: error: 'u64' undeclared (first use in this function) loops = ((u64) usecs * 4295 * HZ * loops_per_jiffy) >> 32; ^~~ In file included from ../drivers/infiniband/hw/cxgb3/cxio_hal.c:32: ../arch/arc/include/asm/delay.h: In function '__udelay': ../arch/arc/include/asm/delay.h:63:37: error: 'loops_per_jiffy' undeclared (first use in this function) loops = ((u64) usecs * 4295 * HZ * loops_per_jiffy) >> 32; ^~~~~~~~~~~~~~~ Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: linux-snps-arc@lists.infradead.org Cc: Elad Kanfi <eladkan@mellanox.com> Cc: Leon Romanovsky <leonro@mellanox.com> Cc: Ofer Levi <oferle@mellanox.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05arc: [plat-eznps] fix data type errors in platform headersRandy Dunlap
[ Upstream commit b1f32ce1c3d2c11959b7e6a2c58dc5197c581966 ] Add <linux/types.h> to fix build errors. Both ctop.h and <soc/nps/common.h> use u32 types and cause many errors. Examples: ../include/soc/nps/common.h:71:4: error: unknown type name 'u32' u32 __reserved:20, cluster:4, core:4, thread:4; ../include/soc/nps/common.h:76:3: error: unknown type name 'u32' u32 value; ../include/soc/nps/common.h:124:4: error: unknown type name 'u32' u32 base:8, cl_x:4, cl_y:4, ../include/soc/nps/common.h:127:3: error: unknown type name 'u32' u32 value; ../arch/arc/plat-eznps/include/plat/ctop.h:83:4: error: unknown type name 'u32' u32 gen:1, gdis:1, clk_gate_dis:1, asb:1, ../arch/arc/plat-eznps/include/plat/ctop.h:86:3: error: unknown type name 'u32' u32 value; ../arch/arc/plat-eznps/include/plat/ctop.h:93:4: error: unknown type name 'u32' u32 csa:22, dmsid:6, __reserved:3, cs:1; ../arch/arc/plat-eznps/include/plat/ctop.h:95:3: error: unknown type name 'u32' u32 value; Cc: linux-snps-arc@lists.infradead.org Cc: Ofer Levi <oferle@mellanox.com> Reviewed-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05Revert "MIPS: BCM47XX: Enable 74K Core ExternalSync for PCIe erratum"Rafał Miłecki
[ Upstream commit d5ea019f8a381f88545bb26993b62ec24a2796b7 ] This reverts commit 2a027b47dba6 ("MIPS: BCM47XX: Enable 74K Core ExternalSync for PCIe erratum"). Enabling ExternalSync caused a regression for BCM4718A1 (used e.g. in Netgear E3000 and ASUS RT-N16): it simply hangs during PCIe initialization. It's likely that BCM4717A1 is also affected. I didn't notice that earlier as the only BCM47XX devices with PCIe I own are: 1) BCM4706 with 2 x 14e4:4331 2) BCM4706 with 14e4:4360 and 14e4:4331 it appears that BCM4706 is unaffected. While BCM5300X-ES300-RDS.pdf seems to document that erratum and its workarounds (according to quotes provided by Tokunori) it seems not even Broadcom follows them. According to the provided info Broadcom should define CONF7_ES in their SDK's mipsinc.h and implement workaround in the si_mips_init(). Checking both didn't reveal such code. It *could* mean Broadcom also had some problems with the given workaround. Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Signed-off-by: Paul Burton <paul.burton@mips.com> Reported-by: Michael Marley <michael@michaelmarley.com> Patchwork: https://patchwork.linux-mips.org/patch/20032/ URL: https://bugs.openwrt.org/index.php?do=details&task_id=1688 Cc: Tokunori Ikegami <ikegami@allied-telesis.co.jp> Cc: Hauke Mehrtens <hauke@hauke-m.de> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: James Hogan <jhogan@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05x86/boot: Fix if_changed build flip/flop bugKees Cook
[ Upstream commit 92a4728608a8fd228c572bc8ff50dd98aa0ddf2a ] Dirk Gouders reported that two consecutive "make" invocations on an already compiled tree will show alternating behaviors: $ make CALL scripts/checksyscalls.sh DESCEND objtool CHK include/generated/compile.h DATAREL arch/x86/boot/compressed/vmlinux Kernel: arch/x86/boot/bzImage is ready (#48) Building modules, stage 2. MODPOST 165 modules $ make CALL scripts/checksyscalls.sh DESCEND objtool CHK include/generated/compile.h LD arch/x86/boot/compressed/vmlinux ZOFFSET arch/x86/boot/zoffset.h AS arch/x86/boot/header.o LD arch/x86/boot/setup.elf OBJCOPY arch/x86/boot/setup.bin OBJCOPY arch/x86/boot/vmlinux.bin BUILD arch/x86/boot/bzImage Setup is 15644 bytes (padded to 15872 bytes). System is 6663 kB CRC 3eb90f40 Kernel: arch/x86/boot/bzImage is ready (#48) Building modules, stage 2. MODPOST 165 modules He bisected it back to: commit 98f78525371b ("x86/boot: Refuse to build with data relocations") The root cause was the use of the "if_changed" kbuild function multiple times for the same target. It was designed to only be used once per target, otherwise it will effectively always trigger, flipping back and forth between the two commands getting recorded by "if_changed". Instead, this patch merges the two commands into a single function to get stable build artifacts (i.e. .vmlinux.cmd), and a single build behavior. Bisected-and-Reported-by: Dirk Gouders <dirk@gouders.net> Fix-Suggested-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20180724230827.GA37823@beast Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05perf/x86/amd/ibs: Don't access non-started eventThomas Gleixner
[ Upstream commit d2753e6b4882a637a0e8fb3b9c2e15f33265300e ] Paul Menzel reported the following bug: > Enabling the undefined behavior sanitizer and building GNU/Linux 4.18-rc5+ > (with some unrelated commits) with GCC 8.1.0 from Debian Sid/unstable, the > warning below is shown. > > > [ 2.111913] > > ================================================================================ > > [ 2.111917] UBSAN: Undefined behaviour in arch/x86/events/amd/ibs.c:582:24 > > [ 2.111919] member access within null pointer of type 'struct perf_event' > > [ 2.111926] CPU: 0 PID: 144 Comm: udevadm Not tainted 4.18.0-rc5-00316-g4864b68cedf2 #104 > > [ 2.111928] Hardware name: ASROCK E350M1/E350M1, BIOS TIMELESS 01/01/1970 > > [ 2.111930] Call Trace: > > [ 2.111943] dump_stack+0x55/0x89 > > [ 2.111949] ubsan_epilogue+0xb/0x33 > > [ 2.111953] handle_null_ptr_deref+0x7f/0x90 > > [ 2.111958] __ubsan_handle_type_mismatch_v1+0x55/0x60 > > [ 2.111964] perf_ibs_handle_irq+0x596/0x620 The code dereferences event before checking the STARTED bit. Patch below should cure the issue. The warning should not trigger, if I analyzed the thing correctly. (And Paul's testing confirms this.) Reported-by: Paul Menzel <pmenzel@molgen.mpg.de> Tested-by: Paul Menzel <pmenzel@molgen.mpg.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Menzel <pmenzel+linux-x86@molgen.mpg.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Vince Weaver <vincent.weaver@maine.edu> Link: http://lkml.kernel.org/r/alpine.DEB.2.21.1807200958390.1580@nanos.tec.linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05bpf, ppc64: fix unexpected r0=0 exit path inside bpf_xaddDaniel Borkmann
[ Upstream commit b9c1e60e7bf4e64ac1b4f4d6d593f0bb57886973 ] None of the JITs is allowed to implement exit paths from the BPF insn mappings other than BPF_JMP | BPF_EXIT. In the BPF core code we have a couple of rewrites in eBPF (e.g. LD_ABS / LD_IND) and in eBPF to cBPF translation to retain old existing behavior where exceptions may occur; they are also tightly controlled by the verifier where it disallows some of the features such as BPF to BPF calls when legacy LD_ABS / LD_IND ops are present in the BPF program. During recent review of all BPF_XADD JIT implementations I noticed that the ppc64 one is buggy in that it contains two jumps to exit paths. This is problematic as this can bypass verifier expectations e.g. pointed out in commit f6b1b3bf0d5f ("bpf: fix subprog verifier bypass by div/mod by 0 exception"). The first exit path is obsoleted by the fix in ca36960211eb ("bpf: allow xadd only on aligned memory") anyway, and for the second one we need to do a fetch, add and store loop if the reservation from lwarx/ldarx was lost in the meantime. Fixes: 156d0e290e96 ("powerpc/ebpf/jit: Implement JIT compiler for extended BPF") Reviewed-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Reviewed-by: Sandipan Das <sandipan@linux.vnet.ibm.com> Tested-by: Sandipan Das <sandipan@linux.vnet.ibm.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24parisc: Remove unnecessary barriers from spinlock.hJohn David Anglin
commit 3b885ac1dc35b87a39ee176a6c7e2af9c789d8b8 upstream. Now that mb() is an instruction barrier, it will slow performance if we issue unnecessary barriers. The spinlock defines have a number of unnecessary barriers.  The __ldcw() define is both a hardware and compiler barrier.  The mb() barriers in the routines using __ldcw() serve no purpose. The only barrier needed is the one in arch_spin_unlock().  We need to ensure all accesses are complete prior to releasing the lock. Signed-off-by: John David Anglin <dave.anglin@bell.net> Cc: stable@vger.kernel.org # 4.0+ Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24parisc: Remove ordered stores from syscall.SJohn David Anglin
commit 7797167ffde1f00446301cb22b37b7c03194cfaf upstream. Now that we use a sync prior to releasing the locks in syscall.S, we don't need the PA 2.0 ordered stores used to release some locks.  Using an ordered store, potentially slows the release and subsequent code. There are a number of other ordered stores and loads that serve no purpose.  I have converted these to normal stores. Signed-off-by: John David Anglin <dave.anglin@bell.net> Cc: stable@vger.kernel.org # 4.0+ Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24ARM: dts: am3517.dtsi: Disable reference to OMAP3 OTG controllerAdam Ford
[ Upstream commit 923847413f7316b5ced3491769b3fefa6c56a79a ] The AM3517 has a different OTG controller location than the OMAP3, which is included from omap3.dtsi. This results in a hwmod error. Since the AM3517 has a different OTG controller address, this patch disabes one that is isn't available. Signed-off-by: Adam Ford <aford173@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24ARM: DRA7/OMAP5: Enable ACTLR[0] (Enable invalidates of BTB) for secondary coresNishanth Menon
[ Upstream commit 2f8b5b21830aea95989a6e67d8a971297272a086 ] Call secure services to enable ACTLR[0] (Enable invalidates of BTB with ICIALLU) when branch hardening is enabled for kernel. On GP devices OMAP5/DRA7, there is no possibility to update secure side since "secure world" is ROM and there are no override mechanisms possible. On HS devices, appropriate PPA should do the workarounds as well. However, the configuration is only done for secondary core, since it is expected that firmware/bootloader will have enabled the required configuration for the primary boot core (note: bootloaders typically will NOT enable secondary processors, since it has no need to do so). Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24ARM: 8780/1: ftrace: Only set kernel memory back to read-only after bootSteven Rostedt (VMware)
[ Upstream commit b4c7e2bd2eb4764afe3af9409ff3b1b87116fa30 ] Dynamic ftrace requires modifying the code segments that are usually set to read-only. To do this, a per arch function is called both before and after the ftrace modifications are performed. The "before" function will set kernel code text to read-write to allow for ftrace to make the modifications, and the "after" function will set the kernel code text back to "read-only" to keep the kernel code text protected. The issue happens when dynamic ftrace is tested at boot up. The test is done before the kernel code text has been set to read-only. But the "before" and "after" calls are still performed. The "after" call will change the kernel code text to read-only prematurely, and other boot code that expects this code to be read-write will fail. The solution is to add a variable that is set when the kernel code text is expected to be converted to read-only, and make the ftrace "before" and "after" calls do nothing if that variable is not yet set. This is similar to the x86 solution from commit 162396309745 ("ftrace, x86: make kernel text writable only for conversions"). Link: http://lkml.kernel.org/r/20180620212906.24b7b66e@vmware.local.home Reported-by: Stefan Agner <stefan@agner.ch> Tested-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24ARC: Improve cmpxchg syscall implementationPeter Zijlstra
[ Upstream commit e8708786d4fe21c043d38d760f768949a3d71185 ] This is used in configs lacking hardware atomics to emulate atomic r-m-w for user space, implemented by disabling preemption in kernel. However there are issues in current implementation: 1. Process not terminated if invalid user pointer passed: i.e. __get_user() failed. 2. The reason for this patch was __put_user() failure not being handled either, specifically for the COW break scenario. The zero page is initially wired up and read from __get_user() succeeds. A subsequent write by __put_user() induces a Protection Violation, but COW can't finish as Linux page fault handler is disabled due to preempt disable. And what's worse is we silently return the stale value to user space. Fix this specific case by re-enabling preemption and explicitly fixing up the fault and retrying the whole sequence over. Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: linux-arch@vger.kernel.org Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> [vgupta: rewrote the changelog] Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24ARM: pxa: irq: fix handling of ICMR registers in suspend/resumeDaniel Mack
[ Upstream commit 0c1049dcb4ceec640d8bd797335bcbebdcab44d2 ] PXA3xx platforms have 56 interrupts that are stored in two ICMR registers. The code in pxa_irq_suspend() and pxa_irq_resume() however does a simple division by 32 which only leads to one register being saved at suspend and restored at resume time. The NAND interrupt setting, for instance, is lost. Fix this by using DIV_ROUND_UP() instead. Signed-off-by: Daniel Mack <daniel@zonque.org> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24ARM: imx_v4_v5_defconfig: Select ULPI supportFabio Estevam
[ Upstream commit 2ceb2780b790b74bc408a949f6aedbad8afa693e ] Select CONFIG_USB_CHIPIDEA_ULPI and CONFIG_USB_ULPI_BUS so that USB ULPI can be functional on some boards like that use ULPI interface. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24ARM: imx_v6_v7_defconfig: Select ULPI supportFabio Estevam
[ Upstream commit 157bcc06094c3c5800d3f4676527047b79b618e7 ] Select CONFIG_USB_CHIPIDEA_ULPI and CONFIG_USB_ULPI_BUS so that USB ULPI can be functional on some boards like imx51-babbge. This fixes a kernel hang in 4.18-rc1 on i.mx51-babbage, caused by commit 03e6275ae381 ("usb: chipidea: Fix ULPI on imx51"). Suggested-by: Andrey Smirnov <andrew.smirnov@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24m68k: fix "bad page state" oops on ColdFire bootGreg Ungerer
[ Upstream commit ecd60532e060e45c63c57ecf1c8549b1d656d34d ] Booting a ColdFire m68k core with MMU enabled causes a "bad page state" oops since commit 1d40a5ea01d5 ("mm: mark pages in use for page tables"): BUG: Bad page state in process sh pfn:01ce2 page:004fefc8 count:0 mapcount:-1024 mapping:00000000 index:0x0 flags: 0x0() raw: 00000000 00000000 00000000 fffffbff 00000000 00000100 00000200 00000000 raw: 039c4000 page dumped because: nonzero mapcount Modules linked in: CPU: 0 PID: 22 Comm: sh Not tainted 4.17.0-07461-g1d40a5ea01d5 #13 Fix by calling pgtable_page_dtor() in our __pte_free_tlb() code path, so that the PG_table flag is cleared before we free the pte page. Note that I had to change the type of pte_free() to be static from extern. Otherwise you get a lot of warnings like this: ./arch/m68k/include/asm/mcf_pgalloc.h:80:2: warning: ‘pgtable_page_dtor’ is static but used in inline function ‘pte_free’ which is not static pgtable_page_dtor(page); ^ And making it static is consistent with our use of this in the other m68k pgalloc definitions of pte_free(). Signed-off-by: Greg Ungerer <gerg@linux-m68k.org> CC: Matthew Wilcox <willy@infradead.org> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24bpf, s390: fix potential memleak when later bpf_jit_prog failsDaniel Borkmann
[ Upstream commit f605ce5eb26ac934fb8106d75d46a2c875a2bf23 ] If we would ever fail in the bpf_jit_prog() pass that writes the actual insns to the image after we got header via bpf_jit_binary_alloc() then we also need to make sure to free it through bpf_jit_binary_free() again when bailing out. Given we had prior bpf_jit_prog() passes to initially probe for clobbered registers, program size and to fill in addrs arrray for jump targets, this is more of a theoretical one, but at least make sure this doesn't break with future changes. Fixes: 054623105728 ("s390/bpf: Add s390x eBPF JIT compiler backend") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
