customer.
Also enhanced VGA@mode parsing to be more permissive in specification,
as well as fixed a string overflow bug in video mode processing.
CCWMX51JS carrier board.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: disable X86_PTRACE_BTS
there's a new ptrace arch level feature in .28:
config X86_PTRACE_BTS
bool "Branch Trace Store"
it has broken fork() handling: the old DS area gets copied over into
a new task without clearing it.
Fixes exist but they came too late:
c5dee61: x86, bts: memory accounting
bf53de9: x86, bts: add fork and exit handling
and are queued up for v2.6.29. This shows that the facility is still not
tested well enough to release into a stable kernel - disable it for now and
reactivate in .29. In .29 the hardware-branch-tracer will use the DS/BTS
facilities too - hopefully resulting in better code.
flush_tlb_mm's "optimized" uniprocessor case of allocating a new
context for userspace is exposing a race where we can suddely return
to a syscall with the protection id and space id out of sync, trapping
on the next userspace access.
Debugged-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Tested-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
The way the code is written it was assuming dshd has the function of a
hypothetical dshw instruction ...
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
x86: fix resume (S2R) broken by Intel microcode module, on A110L
x86 gart: don't complain if no AMD GART found
AMD IOMMU: panic if completion wait loop fails
AMD IOMMU: set cmd buffer pointers to zero manually
x86: re-enable MCE on secondary CPUS after suspend/resume
AMD IOMMU: allocate rlookup_table with __GFP_ZERO
Impact: fix deadlock
This is in response to the following bug report:
Bug-Entry : http://bugzilla.kernel.org/show_bug.cgi?id=12100
Subject : resume (S2R) broken by Intel microcode module, on A110L
Submitter : Andreas Mohr <andi@lisas.de>
Date : 2008-11-25 08:48 (19 days old)
Handled-By : Dmitry Adamushko <dmitry.adamushko@gmail.com>
[ The deadlock scenario has been discovered by Andreas Mohr ]
I think I might have a logical explanation why the system:
(http://bugzilla.kernel.org/show_bug.cgi?id=12100)
might hang upon resuming, OTOH it should have likely hanged each and every time.
(1) possible deadlock in microcode_resume_cpu() if either 'if' section is
taken;
(2) now, I don't see it in spec. and can't experimentally verify it (newer
ucodes don't seem to be available for my Core2duo)... but logically-wise, I'd
think that when read upon resuming, the 'microcode revision' (MSR 0x8B) should
be back to its original one (we need to reload ucode anyway so it doesn't seem
logical if a cpu doesn't drop the version)... if so, the comparison with
memcmp() for the full 'struct cpu_signature' is wrong... and that's how one of
the aforementioned 'if' sections might have been triggered - leading to a
deadlock.
Obviously, in my tests I simulated loading/resuming with the ucode of the same
version (just to see that the file is loaded/re-loaded upon resuming) so this
issue has never popped up.
I'd appreciate if someone with an appropriate system might give a try to the
2nd patch (titled "fix a comparison && deadlock...").
In any case, the deadlock situation is a must-have fix.
Reported-by: Andreas Mohr <andi@lisas.de>
Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
Tested-by: Andreas Mohr <andi@lisas.de>
Cc: <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6:
avr32: favr-32 build fix
ATSTK1006: Fix boot from NAND flash
avr32: remove .note.gnu.build-id section when making vmlinux.bin
avr32: Enable pullup on USART TX lines
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc: We need to implement arch_ptrace_stop().
The favr-32 board code still refers to the old asm/arch header files
which were moved to mach/ some time ago.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Enable JFFS2 write buffer support so that the kernel can access a root
filesystem in NAND flash.
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into x86/urgent
Impact: remove annoying bootup printk
It's perfectly normal for no AMD GART to be present, e.g., if you have
Intel CPUs. None of the other iommu_init() functions makes noise when
it finds nothing.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Acked-by: Joerg Roedel <joerg.roedel@amd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/galak/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/galak/powerpc:
powerpc: Fix corruption error in rh_alloc_fixed()
powerpc/fsl-booke: Fix the miss interrupt restore
There is an error in rh_alloc_fixed() of the Remote Heap code:
If there is at least one free block blk won't be NULL at the end of the
search loop, so -ENOMEM won't be returned and the else branch of
"if (bs == s || be == e)" will be taken, corrupting the management
structures.
Signed-off-by: Guillaume Knispel <gknispel@proformatique.com>
Acked-by: Timur Tabi <timur@freescale.com>
The commit e5e774d8833de1a0037be2384efccadf16935675
powerpc/fsl-booke: Fix problem with _tlbil_va being interrupted
introduce one issue. that casue the problem like this:
Kernel BUG at c00b19fc [verbose debug info unavailable]
Oops: Exception in kernel mode, sig: 5 [#1]
MPC8572 DS
Modules linked in:
NIP: c00b19fc LR: c00b1c34 CTR: c0064e88
REGS: ef02b7b0 TRAP: 0700 Not tainted (2.6.28-rc8-00057-g1bda712)
MSR: 00021000 <ME> CR: 44048028 XER: 20000000
TASK = ef02c000[1] 'init' THREAD: ef02a000
GPR00: 00000001 ef02b860 ef02c000 eec201a0 c0dec2c0 00000000 000078a1 00000400
GPR08: c00b4e40 000078a1 c048ec00 a1780000 44048028 ecd26917 00000001 ef02b948
GPR16: ffffffea 0000020c 00000000 00000000 00000003 0000000a 00000000 000078a1
GPR24: eec201a0 00000000 ed849000 00000400 ef02b95c 00000001 ef02b978 ef02b984
NIP [c00b19fc] __find_get_block+0x24/0x238
LR [c00b1c34] __getblk+0x24/0x2a0
Call Trace:
[ef02b860] [c017b768] generic_make_request+0x290/0x328 (unreliable)
[ef02b8b0] [c00b1c34] __getblk+0x24/0x2a0
[ef02b910] [c00b4ae4] __bread+0x14/0xf8
[ef02b920] [c00fc228] ext2_get_branch+0xf0/0x138
[ef02b940] [c00fcc88] ext2_get_block+0xb8/0x828
[ef02ba00] [c00bbdc8] do_mpage_readpage+0x188/0x808
[ef02bac0] [c00bc5b4] mpage_readpages+0xec/0x144
[ef02bb50] [c00fba38] ext2_readpages+0x24/0x34
[ef02bb60] [c006ade0] __do_page_cache_readahead+0x150/0x230
[ef02bbb0] [c0064bdc] filemap_fault+0x31c/0x3e0
[ef02bbf0] [c00728b8] __do_fault+0x60/0x5b0
[ef02bc50] [c0011e0c] do_page_fault+0x2d8/0x4c4
[ef02bd10] [c000ed90] handle_page_fault+0xc/0x80
[ef02bdd0] [c00c7adc] set_brk+0x74/0x9c
[ef02bdf0] [c00c9274] load_elf_binary+0x70c/0x1180
[ef02be70] [c00945f0] search_binary_handler+0xa8/0x274
[ef02bea0] [c0095818] do_execve+0x19c/0x1d4
[ef02bed0] [c000766c] sys_execve+0x58/0x84
[ef02bef0] [c000e950] ret_from_syscall+0x0/0x3c
[ef02bfb0] [c009c6fc] sys_dup+0x24/0x6c
[ef02bfc0] [c0001e04] init_post+0xb0/0xf0
[ef02bfd0] [c046c1ac] kernel_init+0xcc/0xf4
[ef02bff0] [c000e6d0] kernel_thread+0x4c/0x68
Instruction dump:
4bffffa4 813f000c 4bffffac 9421ffb0 7c0802a6 7d800026 90010054 bf210034
91810030 7c0000a6 68008000 54008ffe <0f000000> 3d20c04e 3b29ffb8 38000008
The issue was the beqlr returns early but we haven't reenabled interrupts.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Impact: prevents data corruption after a failed completion wait loop
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Impact: set cmd buffer head and tail pointers to zero in case nobody else did
This patch will remove the section .note.gnu.build-id added in binutils
2.18 from the vmlinux.bin binary. Not removing this section results in a
huge multiple gigabyte binary and likewize large uImage.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
In order to always provide fully synchronized state to the debugger,
we might need to do a synchronize_user_stack().
A pair of hooks, arch_ptrace_stop_needed() and arch_ptrace_stop(),
exist to handle this kind of situation. It was created for
the sake of IA64.
Use them, to flush the kernel side cached register windows
to the user stack, when necessary.
Impact: fix disabled MCE after resume
Don't prevent multiple initialization of MCEs.
Back from early prehistory mcheck_init() has a reentry check. Presumably
that was needed in very old kernels to prevent it entering twice.
But as Andreas points out this prevents CPU hotplug (and therefore resume)
to correctly reinitialize MCEs when a AP boots again after being
offlined.
Just drop the check.
Reported-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Impact: fix bug which can lead to panic in prealloc_protection_domains()
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh/for-2.6.28' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: Disable GENERIC_HARDIRQS_NO__DO_IRQ for unconverted platforms.
sh: maple: Do not pass SLAB_POISON to kmem_cache_create()
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
powerpc/cell/axon-msi: Fix MSI after kexec
powerpc: Fix bootmem reservation on uninitialized node
powerpc: Check for valid hugepage size in hugetlb_get_unmapped_area
Presently limited to Cayman, Dreamcast, Microdev, and SystemH 7751.
Re-enable it for everyone once these have been fixed up.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Commit d015fe995 'powerpc/cell/axon-msi: Retry on missing interrupt'
has turned a rare failure to kexec on QS22 into a reproducible
error, which we have now analysed.
The problem is that after a kexec, the MSIC hardware still points
into the middle of the old ring buffer. We set up the ring buffer
during reboot, but not the offset into it. On older kernels, this
would cause a storm of thousands of spurious interrupts after a
kexec, which would most of the time get dropped silently.
With the new code, we time out on each interrupt, waiting for
it to become valid. If more interrupts come in that we time
out on, this goes on indefinitely, which eventually leads to
a hard crash.
The solution in this commit is to read the current offset from
the MSIC when reinitializing it. This now works correctly, as
expected.
Reported-by: Dirk Herrendoerfer <d.herrendoerfer@de.ibm.com>
Acked-by: Michael Ellerman <michael@ellerman.id.au>
careful_allocation() was calling into the bootmem allocator for
nodes which had not been fully initialized and caused a previous
bug: http://patchwork.ozlabs.org/patch/10528/ So, I merged a
few broken out loops in do_init_bootmem() to fix it. That changed
the code ordering.
I think this bug is triggered by having reserved areas for a node
which are spanned by another node's contents. In the
mark_reserved_regions_for_nid() code, we attempt to reserve the
area for a node before we have allocated the NODE_DATA() for that
nid. We do this since I reordered that loop. I suck.
This is causing crashes at bootup on some systems, as reported
by Jon Tollefson.
This may only present on some systems that have 16GB pages
reserved. But, it can probably happen on any system that is
trying to reserve large swaths of memory that happen to span other
nodes' contents.
This commit ensures that we do not touch bootmem for any node which
has not been initialized, and also removes a compile warning about
an unused variable.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
It looks like most of the hugetlb code is doing the correct thing if
hugepages are not supported, but the mmap code is not. If we get into
the mmap code when hugepages are not supported, such as in an LPAR
which is running Active Memory Sharing, we can oops the kernel. This
fixes the oops being seen in this path.
oops: Kernel access of bad area, sig: 11 [#1]
SMP NR_CPUS=1024 NUMA pSeries
Modules linked in: nfs(N) lockd(N) nfs_acl(N) sunrpc(N) ipv6(N) fuse(N) loop(N)
dm_mod(N) sg(N) ibmveth(N) sd_mod(N) crc_t10dif(N) ibmvscsic(N)
scsi_transport_srp(N) scsi_tgt(N) scsi_mod(N)
Supported: No
NIP: c000000000038d60 LR: c00000000003945c CTR: c0000000000393f0
REGS: c000000077e7b830 TRAP: 0300 Tainted: G
(2.6.27.5-bz50170-2-ppc64)
MSR: 8000000000009032 <EE,ME,IR,DR> CR: 44000448 XER: 20000001
DAR: c000002000af90a8, DSISR: 0000000040000000
TASK = c00000007c1b8600[4019] 'hugemmap01' THREAD: c000000077e78000 CPU: 6
GPR00: 0000001fffffffe0 c000000077e7bab0 c0000000009a4e78 0000000000000000
GPR04: 0000000000010000 0000000000000001 00000000ffffffff 0000000000000001
GPR08: 0000000000000000 c000000000af90c8 0000000000000001 0000000000000000
GPR12: 000000000000003f c000000000a73880 0000000000000000 0000000000000000
GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000010000
GPR20: 0000000000000000 0000000000000003 0000000000010000 0000000000000001
GPR24: 0000000000000003 0000000000000000 0000000000000001 ffffffffffffffb5
GPR28: c000000077ca2e80 0000000000000000 c00000000092af78 0000000000010000
NIP [c000000000038d60] .slice_get_unmapped_area+0x6c/0x4e0
LR [c00000000003945c] .hugetlb_get_unmapped_area+0x6c/0x80
Call Trace:
[c000000077e7bbc0] [c00000000003945c] .hugetlb_get_unmapped_area+0x6c/0x80
[c000000077e7bc30] [c000000000107e30] .get_unmapped_area+0x64/0xd8
[c000000077e7bcb0] [c00000000010b140] .do_mmap_pgoff+0x140/0x420
[c000000077e7bd80] [c00000000000bf5c] .sys_mmap+0xc4/0x140
[c000000077e7be30] [c0000000000086b4] syscall_exit+0x0/0x40
Instruction dump:
fac1ffb0 fae1ffb8 fb01ffc0 fb21ffc8 fb41ffd0 fb61ffd8 fb81ffe0 fbc1fff0
fbe1fff8 f821fef1 f8c10158 f8e10160 <7d49002e> f9010168 e92d01b0 eb4902b0
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 5348/1: fix documentation wrt location of the alignment trap interface
[ARM] Ensure linux/hardirqs.h is included where required
[ARM] fix kernel-doc syntax
[ARM] arch/arm/common/sa1111.c: Correct error handling code
[ARM] 5341/2: there is no copy_page on nommu ARM
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
Phonet: keep TX queue disabled when the device is off
SCHED: netem: Correct documentation comment in code.
netfilter: update rwlock initialization for nat_table
netlabel: Compiler warning and NULL pointer dereference fix
e1000e: fix double release of mutex
IA64: HP_SIMETH needs to depend upon NET
netpoll: fix race on poll_list resulting in garbage entry
ipv6: silence log messages for locally generated multicast
sungem: improve ethtool output with internal pcs and serdes
tcp: tcp_vegas cong avoid fix
sungem: Make PCS PHY support partially work again.
... for the removal of it from asm-generic/local.h
VMI initialiation can relocate the fixmap, causing early_ioremap to
malfunction if it is initialized before the relocation. To fix this,
VMI activation is split into two phases; the detection, which must
happen before setting up ioremap, and the activation, which must happen
after parsing early boot parameters.
This fixes a crash on boot when VMI is enabled under VMware.
Signed-off-by: Zachary Amsden <zach@vmware.com>
Fix kernel-doc notation to use correct syntax. Even though this should be
moved to where the function is actually implemented...
If it is reasonable to apply PTR_ERR to the result of calling clk_get, then
that result should first be tested with IS_ERR, not with !.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression E,E1;
if (
- E == NULL
+ IS_ERR(E)
) { <+... when != E = E1
PTR_ERR(E)
// </smpl>
An example calling sequence which we did see:
copy_user_highpage -> kmap_atomic -> flush_tlb_page -> _tlbil_va
We got interrupted after setting up the MAS registers before the
tlbwe and the interrupt handler that caused the interrupt also did
a kmap_atomic (ide code) and thus on returning from the interrupt
the MAS registers no longer contained the proper values.
Since we dont save/restore MAS registers for normal interrupts we
need to disable interrupts in _tlbil_va to ensure atomicity.
git://git.kernel.org/pub/scm/linux/kernel/git/jwboyer/powerpc-4xx
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jwboyer/powerpc-4xx:
powerpc/40x: Add proper BOOTCFLAGS for cuboot-acadia
dma_free_noncoherent() and dma_free_coherent() are missing calls to
plat_unmap_dma_mem(). This patch adds them.
The header path in the help text for the RUNTIME_DEBUG config option is
obsolete and needs to be updated to match the new location of
architecture-specific header files. While at it, fix the spelling mistake.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi>
For MIPS R2, use the EI and DI instructions to enable and disable
interrupts.
Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com>
The cuboot-acadia.c wrapper can cause assembler errors on some
toolchains due to the lack of the proper BOOTCFLAGS. This adds
the proper flags for the file.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
... as it is defined with memcpy, therefore no copy_page symbol to
export.
Signed-off-by: Nicolas Pitre <nico@cam.org>
