commit fd120dc2e205d2318a8b47d6d8098b789e3af67d upstream.
It seems that forward declaration couldn't work well with typedef, use
struct spinlock directly to avoiding following build errors:
In file included from include/linux/spinlock.h:81,
from include/linux/seqlock.h:35,
from include/linux/time.h:5,
from include/uapi/linux/timex.h:56,
from include/linux/timex.h:56,
from include/linux/sched.h:17,
from arch/powerpc/kernel/asm-offsets.c:17:
include/linux/spinlock_types.h:76: error: redefinition of typedef 'spinlock_t'
/root/linux-next/arch/powerpc/include/asm/pgtable-ppc64.h:563: note: previous declaration of 'spinlock_t' was here
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit b3084f4db3aeb991c507ca774337c7e7893ed04f upstream.
This patch fix the below crash
NIP [c00000000004cee4] .__hash_page_thp+0x2a4/0x440
LR [c0000000000439ac] .hash_page+0x18c/0x5e0
Call Trace:
[c000000736103c40] [00001ffffb000000] 0x1ffffb000000(unreliable)
[437908.479693] [c000000736103d50] [c0000000000439ac] .hash_page+0x18c/0x5e0
[437908.479699] [c000000736103e30] [c00000000000924c] .do_hash_page+0x4c/0x58
On ppc64 we use the pgtable for storing the hpte slot information and
store address to the pgtable at a constant offset (PTRS_PER_PMD) from
pmd. On mremap, when we switch the pmd, we need to withdraw and deposit
the pgtable again, so that we find the pgtable at PTRS_PER_PMD offset
from new pmd.
We also want to move the withdraw and deposit before the set_pmd so
that, when page fault find the pmd as trans huge we can be sure that
pgtable can be located at the offset.
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit a558d99263936b8a67d4eff8918745a77bfd8c31 upstream.
Remove __initdata attribute, as the devices may be used after init
sections are freed.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 5a5e75f4714a592f31e57f248b8f5c866f278b8d upstream.
With commit d8d14bd09cdd ("fs/compat: fix lookup_dcookie() parameter
handling") I changed the type of the len parameter of the
lookup_dcookie() syscall.
However I missed that there was still a stale declaration in
arch/tile/.. which now causes a compile error on tile:
In file included from fs/dcookies.c:28:0:
include/linux/compat.h:425:17: error: conflicting types for 'compat_sys_lookup_dcookie'
fs/dcookies.c:207:1: error: conflicting types for 'compat_sys_lookup_dcookie'
Simply remove the declaration in the tile architecture, which is only a
leftover from before the different compat lookup_dcookie() versions have
been merged. The correct declaration is now in include/linux/compat.h
The build error was reported by Fenguang's build bot.
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
commit dc4910d9e93f8cc56b190dd8fc9e789135978216 upstream.
When pci_base is accessed whereas it has not been properly mapped by
of_iomap() the kernel hang. The check of this pointer made an improper
use of IS_ERR() instead of comparing to NULL. This patch fix this
issue.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Reported-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Fixes: 930ab3d403ae (i2c: mv64xxx: Add I2C Transaction Generator support)
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit f28d7de6bd4d41774744e011141945affa127da4 upstream.
DT-enabled Marvell Kirkwood and Dove SoCs make use of an irqchip
driver. As expected for irqchip drivers, it uses a C-style
interrupt handler and therefore selects MULTI_IRQ_HANDLER.
Now, compiling a kernel with both non-DT and DT support enabled,
selecting MULTI_IRQ_HANDLER will break ASM irq handler used by
non-DT boards.
Therefore, we provide a C-style irq handler even for non-DT boards,
if MULTI_IRQ_HANDLER is set. By installing the C-style irq handler
in orion_irq_init this is transparent to all non-DT board files.
While the regression report was filed on Marvell Kirkwood, also
Marvell Dove non-DT boards are affected and fixed by this patch.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-by: Ian Campbell <ijc@hellion.org.uk>
Reported-by: Ian Campbell <ijc@hellion.org.uk>
Fixes: 2326f04321a9 ("ARM: kirkwood: convert to DT irqchip and clocksource")
Fixes: f07d73e33d0e ("ARM: dove: convert to DT irqchip and clocksource")
Acked-by: Andrew Lunn <andrew@lunn.ch>
commit 24f91eba18bbfdb27e71a1aae5b3a61b67fcd091 upstream.
The SOFT_DIRTY bit shows that the content of memory was changed after a
defined point in the past. mprotect() doesn't change the content of
memory, so it must not change the SOFT_DIRTY bit.
This bug causes a malfunction: on the first iteration all pages are
dumped. On other iterations only pages with the SOFT_DIRTY bit are
dumped. So if the SOFT_DIRTY bit is cleared from a page by mistake, the
page is not dumped and its content will be restored incorrectly.
This patch does nothing with _PAGE_SWP_SOFT_DIRTY, becase pte_modify()
is called only for present pages.
Fixes commit 0f8975ec4db2 ("mm: soft-dirty bits for user memory changes
tracking").
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Wen Congyang <wency@cn.fujitsu.com>
commit 51c71a3bbaca868043cc45b3ad3786dd48a90235 upstream.
The user has the option of disabling the platform driver:
00:02.0 Unassigned class [ff80]: XenSource, Inc. Xen Platform Device (rev 01)
which is used to unplug the emulated drivers (IDE, Realtek 8169, etc)
and allow the PV drivers to take over. If the user wishes
to disable that they can set:
xen_platform_pci=0
(in the guest config file)
or
xen_emul_unplug=never
(on the Linux command line)
except it does not work properly. The PV drivers still try to
load and since the Xen platform driver is not run - and it
has not initialized the grant tables, most of the PV drivers
stumble upon:
input: Xen Virtual Keyboard as /devices/virtual/input/input5
input: Xen Virtual Pointer as /devices/virtual/input/input6M
kernel BUG at /home/konrad/ssd/konrad/linux/drivers/xen/grant-table.c:1206!
invalid opcode: 0000 [#1] SMP
Modules linked in: xen_kbdfront(+) xenfs xen_privcmd
CPU: 6 PID: 1389 Comm: modprobe Not tainted 3.13.0-rc1upstream-00021-ga6c892b-dirty #1
Hardware name: Xen HVM domU, BIOS 4.4-unstable 11/26/2013
RIP: 0010:[<ffffffff813ddc40>] [<ffffffff813ddc40>] get_free_entries+0x2e0/0x300
Call Trace:
[<ffffffff8150d9a3>] ? evdev_connect+0x1e3/0x240
[<ffffffff813ddd0e>] gnttab_grant_foreign_access+0x2e/0x70
[<ffffffffa0010081>] xenkbd_connect_backend+0x41/0x290 [xen_kbdfront]
[<ffffffffa0010a12>] xenkbd_probe+0x2f2/0x324 [xen_kbdfront]
[<ffffffff813e5757>] xenbus_dev_probe+0x77/0x130
[<ffffffff813e7217>] xenbus_frontend_dev_probe+0x47/0x50
[<ffffffff8145e9a9>] driver_probe_device+0x89/0x230
[<ffffffff8145ebeb>] __driver_attach+0x9b/0xa0
[<ffffffff8145eb50>] ? driver_probe_device+0x230/0x230
[<ffffffff8145cf1c>] bus_for_each_dev+0x8c/0xb0
[<ffffffff8145e7d9>] driver_attach+0x19/0x20
[<ffffffff8145e260>] bus_add_driver+0x1a0/0x220
[<ffffffff8145f1ff>] driver_register+0x5f/0xf0
[<ffffffff813e55c5>] xenbus_register_driver_common+0x15/0x20
[<ffffffff813e76b3>] xenbus_register_frontend+0x23/0x40
[<ffffffffa0015000>] ? 0xffffffffa0014fff
[<ffffffffa001502b>] xenkbd_init+0x2b/0x1000 [xen_kbdfront]
[<ffffffff81002049>] do_one_initcall+0x49/0x170
.. snip..
which is hardly nice. This patch fixes this by having each
PV driver check for:
- if running in PV, then it is fine to execute (as that is their
native environment).
- if running in HVM, check if user wanted 'xen_emul_unplug=never',
in which case bail out and don't load any PV drivers.
- if running in HVM, and if PCI device 5853:0001 (xen_platform_pci)
does not exist, then bail out and not load PV drivers.
- (v2) if running in HVM, and if the user wanted 'xen_emul_unplug=ide-disks',
then bail out for all PV devices _except_ the block one.
Ditto for the network one ('nics').
- (v2) if running in HVM, and if the user wanted 'xen_emul_unplug=unnecessary'
then load block PV driver, and also setup the legacy IDE paths.
In (v3) make it actually load PV drivers.
Reported-by: Sander Eikelenboom <linux@eikelenboom.it
Reported-by: Anthony PERARD <anthony.perard@citrix.com>
Reported-and-Tested-by: Fabio Fantoni <fabio.fantoni@m2r.biz>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[v2: Add extra logic to handle the myrid ways 'xen_emul_unplug'
can be used per Ian and Stefano suggestion]
[v3: Make the unnecessary case work properly]
[v4: s/disks/ide-disks/ spotted by Fabio]
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com> [for PCI parts]
commit 53a52f17d96c8d47c79a7dafa81426317e89c7c1 upstream.
arch/sh/kernel/kgdb.c: In function 'sleeping_thread_to_gdb_regs':
arch/sh/kernel/kgdb.c:225:32: error: implicit declaration of function 'task_stack_page' [-Werror=implicit-function-declaration]
arch/sh/kernel/kgdb.c:242:23: error: dereferencing pointer to incomplete type
arch/sh/kernel/kgdb.c:243:22: error: dereferencing pointer to incomplete type
arch/sh/kernel/kgdb.c: In function 'singlestep_trap_handler':
arch/sh/kernel/kgdb.c:310:27: error: 'SIGTRAP' undeclared (first use in this function)
arch/sh/kernel/kgdb.c:310:27: note: each undeclared identifier is reported only once for each function it appears in
This was introduced by commit 16559ae48c76 ("kgdb: remove #include
<linux/serial_8250.h> from kgdb.h").
[geert@linux-m68k.org: reworded and reformatted]
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 3b56496865f9f7d9bcb2f93b44c63f274f08e3b6 upstream.
This adds the workaround for erratum 793 as a precaution in case not
every BIOS implements it. This addresses CVE-2013-6885.
Erratum text:
[Revision Guide for AMD Family 16h Models 00h-0Fh Processors,
document 51810 Rev. 3.04 November 2013]
793 Specific Combination of Writes to Write Combined Memory Types and
Locked Instructions May Cause Core Hang
Description
Under a highly specific and detailed set of internal timing
conditions, a locked instruction may trigger a timing sequence whereby
the write to a write combined memory type is not flushed, causing the
locked instruction to stall indefinitely.
Potential Effect on System
Processor core hang.
Suggested Workaround
BIOS should set MSR
C001_1020[15] = 1b.
Fix Planned
No fix planned
[ hpa: updated description, fixed typo in MSR name ]
Link: http://lkml.kernel.org/r/20140114230711.GS29865@pd.tnic
Tested-by: Aravind Gopalakrishnan <aravind.gopalakrishnan@amd.com>
commit 91b973f90c1220d71923e7efe1e61f5329806380 upstream.
The code in remove_cache_dir() is supposed to remove the "cache"
subdirectory from the sysfs directory for a CPU when that CPU is
being offlined. It tries to do this by calling kobject_put() on
the kobject for the subdirectory. However, the subdirectory only
gets removed once the last reference goes away, and the reference
being put here may well not be the last reference. That means
that the "cache" subdirectory may still exist when the offlining
operation has finished. If the same CPU subsequently gets onlined,
the code tries to add a new "cache" subdirectory. If the old
subdirectory has not yet been removed, we get a WARN_ON in the
sysfs code, with stack trace, and an error message printed on the
console. Further, we ultimately end up with an online cpu with no
This fixes it by doing an explicit kobject_del() at the point where
we want the subdirectory to go away. kobject_del() removes the sysfs
directory even though the object still exists in memory. The object
will get freed at some point in the future. A subsequent onlining
operation can create a new sysfs directory, even if the old object
still exists in memory, without causing any problems.
commit d4edc5b6c480a0917e61d93d55531d7efa6230be upstream.
On POWER platforms, the hypervisor can notify the guest kernel about dynamic
changes in the cpu-numa associativity (VPHN topology update). Hence the
cpu-to-node mappings that we got from the firmware during boot, may no longer
be valid after such updates. This is handled using the arch_update_cpu_topology()
hook in the scheduler, and the sched-domains are rebuilt according to the new
mappings.
But unfortunately, at the moment, CPU hotplug ignores these updated mappings
and instead queries the firmware for the cpu-to-numa relationships and uses
them during CPU online. So the kernel can end up assigning wrong NUMA nodes
to CPUs during subsequent CPU hotplug online operations (after booting).
Further, a particularly problematic scenario can result from this bug:
On POWER platforms, the SMT mode can be switched between 1, 2, 4 (and even 8)
threads per core. The switch to Single-Threaded (ST) mode is performed by
offlining all except the first CPU thread in each core. Switching back to
SMT mode involves onlining those other threads back, in each core.
Now consider this scenario:
1. During boot, the kernel gets the cpu-to-node mappings from the firmware
and assigns the CPUs to NUMA nodes appropriately, during CPU online.
2. Later on, the hypervisor updates the cpu-to-node mappings dynamically and
communicates this update to the kernel. The kernel in turn updates its
cpu-to-node associations and rebuilds its sched domains. Everything is
fine so far.
3. Now, the user switches the machine from SMT to ST mode (say, by running
ppc64_cpu --smt=1). This involves offlining all except 1 thread in each
core.
4. The user then tries to switch back from ST to SMT mode (say, by running
ppc64_cpu --smt=4), and this involves onlining those threads back. Since
CPU hotplug ignores the new mappings, it queries the firmware and tries to
associate the newly onlined sibling threads to the old NUMA nodes. This
results in sibling threads within the same core getting associated with
different NUMA nodes, which is incorrect.
The scheduler's build-sched-domains code gets thoroughly confused with this
and enters an infinite loop and causes soft-lockups, as explained in detail
in commit 3be7db6ab (powerpc: VPHN topology change updates all siblings).
So to fix this, use the numa_cpu_lookup_table to remember the updated
cpu-to-node mappings, and use them during CPU hotplug online operations.
Further, we also need to ensure that all threads in a core are assigned to a
common NUMA node, irrespective of whether all those threads were online during
the topology update. To achieve this, we take care not to use cpu_sibling_mask()
since it is not hotplug invariant. Instead, we use cpu_first_sibling_thread()
and set up the mappings manually using the 'threads_per_core' value for that
particular platform. This helps us ensure that we don't hit this bug with any
combination of CPU hotplug and SMT mode switching.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 70713fe315ed14cd1bb07d1a7f33e973d136ae3d upstream.
Use gva_t instead of unsigned int for eaddr in deliver_tlb_miss().
Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com>
commit 48eaef0518a565d3852e301c860e1af6a6db5a84 upstream.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit 57737c49dd72c96cfbcd4f66559f3ffc399aeb4f upstream.
This commit:
f8dae00684d678afa13041ef170cecfd1297ed40: parisc: Ensure full cache coherency for kmap/kunmap
caused negative caching side-effects, e.g. hanging processes with expect and
too many inequivalent alias messages from flush_dcache_page() on Debian 5 systems.
This patch now partly reverts it and has been in production use on our debian buildd
makeservers since a week without any major problems.
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: John David Anglin <dave.anglin@bell.net>
commit 0ef38d70d4118b2ce1a538d14357be5ff9dc2bbd upstream.
The patch 3ddc5b46a8e90f3c9251338b60191d0a804b0d92 breaks networking on
alpha (there is a follow-up fix 5cfe8f1ba5eebe6f4b6e5858cdb1a5be4f3272a6,
but networking is still broken even with the second patch).
The patch 3ddc5b46a8e90f3c9251338b60191d0a804b0d92 makes
csum_partial_copy_from_user check the pointer with access_ok. However,
csum_partial_copy_from_user is called also from csum_partial_copy_nocheck
and csum_partial_copy_nocheck is called on kernel pointers and it is
supposed not to check pointer validity.
This bug results in ssh session hangs if the system is loaded and bulk
data are printed to ssh terminal.
This patch fixes csum_partial_copy_nocheck to call set_fs(KERNEL_DS), so
that access_ok in csum_partial_copy_from_user accepts kernel-space
addresses.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Matt Turner <mattst88@gmail.com>
commit 85e618a1be2b2092318178d1d66bdad49cbbeeeb upstream.
The first variants of Armada XP SoCs (A0 stepping) have issues related
to the i2c controller which prevent to use the offload mechanism and
lead to a kernel hang during boot.
This commit add quirk in the mvebu platform code to check the SoC
version and then update the compatible string for the i2c controller
according to the revision of the SoC. Currently only some OpenBlocks
AX3-4 boards are known to use an A0 revision so the check is done only
for these boards.
commit af8d1c63afcbf36eea06789c92e22d4af118d2fb upstream.
All the mvebu SoCs have information related to their variant and
revision that can be read from the PCI control register.
This patch adds support for Armada XP and Armada 370. This reading of
the revision and the ID are done before the PCI initialization to
avoid any conflicts. Once these data are retrieved, the resources are
freed to let the PCI subsystem use it.
commit a96cc303e42ad7830dde929aad0046e448a05505 upstream.
This patch updates the Armada 370/XP SATA node with the new compatible
string "marvell,armada-370-sata".
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Lior Amsalem <alior@marvell.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
commit 4e078146dff728f4865270a47710d57797e81eb6 upstream.
With b8668fd0a7e1b59f "s390/uapi: change struct statfs[64] member types
to unsigned values" the size of a couple of struct statfs64 member got
incorrectly changed from 64 to 32 bit for 32 bit builds.
Fix this by changing the type of couple of struct statfs64 members from
unsigned long to unsigned long long.
The definition of struct compat_statfs64 was correct however.
commit ff1f3cb4b3ac5d039f02679f34cb1498d110d241 upstream.
The diagnose 500 subcode 3 contains the 32 bit subchannel id in bits 32-63
(counting from the left). As for other I/O instructions, bits 0-31 should be
ignored and thus not be passed to kvm_io_bus_write_cookie().
This fixes a bug where the guest passed non-zero bits 0-31 which the
host tried to interpret, leading to ioeventfd notification failures.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
commit 743db27c526e0f31cc507959d662e97e2048a86f upstream.
The diagnose code to be used is the contents of the base register (if not
zero), plus the displacement. The current code ignores the base register
contents. So let's fix that...
Cc: stable@vger.kernel.org
commit e879892c725217a4af1012f31ae56be762473216 upstream.
The SIGP order STOP_AND_STORE_STATUS is defined to stop a CPU and store
its status. However, we only stored the status if the CPU was still
running, so make sure that the status is now also stored if the CPU was
already stopped. This fixes the problem that the CPU information was
not stored correctly in kdump files, rendering them unreadable.
Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 075dfd82102d2048e43e1cbf48d558d915c50072 upstream.
PSW32_USER_BITS should define the primary address space for user space
instead of the home address space.
Symptom of this bug is that gdb doesn't work in compat mode.
The bug was introduced with e258d719ff28 "s390/uaccess: always run the kernel
in home space" and f26946d7ecad "s390/compat: make psw32_user_bits a constant
value again".
Reported-by: Andreas Arnez <arnez@linux.vnet.ibm.com>
commit 1588c51cf6d782e63a8719681d905ef0ac22ee62 upstream.
There was a copy/paste error when reading the nwe_pulse value.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@traphandler.com>
Acked-by: Boris BREZILLON <b.brezillon@overkiz.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
commit 0645b93f6c223b594c0dca348e2ae0a23bccf6e3 upstream.
pinctrl-names property was missing from mmc nodes.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
commit 77f01bdfa5e55dc19d3eb747181d2730a9bb3ca8 upstream.
When Hyper-V hypervisor leaves are present, KVM must relocate
its own leaves at 0x40000100, because Windows does not look for
Hyper-V leaves at indices other than 0x40000000. In this case,
the KVM features are at 0x40000101, but the old code would always
look at 0x40000001.
Fix by using kvm_cpuid_base(). This also requires making the
function non-inline, since kvm_cpuid_base() is static.
Fixes: 1085ba7f552d84aa8ac0ae903fa8d0cc2ff9f79d
Cc: mtosatti@redhat.com
commit 1c300a40772dae829b91dad634999a6a522c0829 upstream.
It is unnecessary to go through hypervisor_cpuid_base every time
a leaf is found (which will be every time a feature is requested
after the next patch).
commit 9ed96e87c5748de4c2807ef17e81287c7304186c upstream.
Limit PIT timer frequency similarly to the limit applied by
LAPIC timer.
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit a7f84f03f660d93574ac88835d056c0d6468aebe upstream.
Current code check boot service region with kernel text region by:
start+size >= __pa_symbol(_text)
The end of the above region should be start + size - 1 instead.
I see this problem in ovmf + Fedora 19 grub boot:
text start: 1000000 md start: 800000 md size: 800000
Signed-off-by: Dave Young <dyoung@redhat.com>
Acked-by: Borislav Petkov <bp@suse.de>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Tested-by: Toshi Kani <toshi.kani@hp.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Pull perf fixes from Ingo Molnar:
- an s2ram related fix on AMD systems
- a perf fault handling bug that is relatively old but which has become
much easier to trigger in v3.13 after commit e00b12e64be9 ("perf/x86:
Further optimize copy_from_user_nmi()")
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/amd/ibs: Fix waking up from S3 for AMD family 10h
x86, mm, perf: Allow recursive faults from interrupts
Pull networking fixes from David Miller:
1) The value choosen for the new SO_MAX_PACING_RATE socket option on
parisc was very poorly choosen, let's fix it while we still can.
From Eric Dumazet.
2) Our generic reciprocal divide was found to handle some edge cases
incorrectly, part of this is encoded into the BPF as deep as the JIT
engines themselves. Just use a real divide throughout for now.
From Eric Dumazet.
3) Because the initial lookup is lockless, the TCP metrics engine can
end up creating two entries for the same lookup key. Fix this by
doing a second lookup under the lock before we actually create the
new entry. From Christoph Paasch.
4) Fix scatter-gather list init in usbnet driver, from Bjørn Mork.
5) Fix unintended 32-bit truncation in cxgb4 driver's bit shifting.
From Dan Carpenter.
6) Netlink socket dumping uses the wrong socket state for timewait
sockets. Fix from Neal Cardwell.
7) Fix netlink memory leak in ieee802154_add_iface(), from Christian
Engelmayer.
8) Multicast forwarding in ipv4 can overflow the per-rule reference
counts, causing all multicast traffic to cease. Fix from Hannes
Frederic Sowa.
9) via-rhine needs to stop all TX queues when it resets the device,
from Richard Weinberger.
10) Fix RDS per-cpu accesses broken by the this_cpu_* conversions. From
Gerald Schaefer.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
s390/bpf,jit: fix 32 bit divisions, use unsigned divide instructions
parisc: fix SO_MAX_PACING_RATE typo
ipv6: simplify detection of first operational link-local address on interface
tcp: metrics: Avoid duplicate entries with the same destination-IP
net: rds: fix per-cpu helper usage
e1000e: Fix compilation warning when !CONFIG_PM_SLEEP
bpf: do not use reciprocal divide
be2net: add dma_mapping_error() check for dma_map_page()
bnx2x: Don't release PCI bars on shutdown
net,via-rhine: Fix tx_timeout handling
batman-adv: fix batman-adv header overhead calculation
qlge: Fix vlan netdev features.
net: avoid reference counter overflows on fib_rules in multicast forwarding
dm9601: add USB IDs for new dm96xx variants
MAINTAINERS: add virtio-dev ML for virtio
ieee802154: Fix memory leak in ieee802154_add_iface()
net: usbnet: fix SG initialisation
inet_diag: fix inet_diag_dump_icsk() to use correct state for timewait sockets
cxgb4: silence shift wrapping static checker warning
The s390 bpf jit compiler emits the signed divide instructions "dr" and "d"
for unsigned divisions.
This can cause problems: the dividend will be zero extended to a 64 bit value
and the divisor is the 32 bit signed value as specified A or X accumulator,
even though A and X are supposed to be treated as unsigned values.
The divide instrunctions will generate an exception if the result cannot be
expressed with a 32 bit signed value.
This is the case if e.g. the dividend is 0xffffffff and the divisor either 1
or also 0xffffffff (signed: -1).
To avoid all these issues simply use unsigned divide instructions.
SO_MAX_PACING_RATE definition on parisc got a typo.
Its not too late to fix it, before 3.13 is official.
Fixes: 62748f32d501 ("net: introduce SO_MAX_PACING_RATE")
Pull KVM fix from Paolo Bonzini:
"Fix for a brown paper bag bug. Thanks to Drew Jones for noticing"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
kvm: x86: fix apic_base enable check
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fix from Catalin Marinas:
"Revert "arm64: Fix memory shareability attribute for ioremap_wc/cache"
We noticed that it breaks ioremap (and earlyprintk) with 64K page
configuration"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
This reverts commit 2f7dc6027522499582a520807cb9ffda589de47e.
The above commit breaks the mapping type for Device memory because
pgprot_default already contains a Normal memory type. pgprot_default is
also not initialised early enough for earlyprintk resulting in an
inconsistent memory mapping with 64K PAGE_SIZE configuration.
Reported-by: Will Deacon <will.deacon@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
On AMD family 10h we see following error messages while waking up from
S3 for all non-boot CPUs leading to a failed IBS initialization:
Enabling non-boot CPUs ...
smpboot: Booting Node 0 Processor 1 APIC 0x1
[Firmware Bug]: cpu 1, try to use APIC500 (LVT offset 0) for vector 0x400, but the register is already in use for vector 0xf9 on another cpu
perf: IBS APIC setup failed on cpu #1
process: Switch to broadcast mode on CPU1
CPU1 is up
ACPI: Waking up from system sleep state S3
Reason for this is that during suspend the LVT offset for the IBS
vector gets lost and needs to be reinialized while resuming.
The offset is read from the IBSCTL msr. On family 10h the offset needs
to be 1 as offset 0 is used for the MCE threshold interrupt, but
firmware assings it for IBS to 0 too. The kernel needs to reprogram
the vector. The msr is a readonly node msr, but a new value can be
written via pci config space access. The reinitialization is
implemented for family 10h in setup_ibs_ctl() which is forced during
IBS setup.
This patch fixes IBS setup after waking up from S3 by adding
resume/supend hooks for the boot cpu which does the offset
reinitialization.
Marking it as stable to let distros pick up this fix.
Signed-off-by: Robert Richter <rric@kernel.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: <stable@vger.kernel.org> v3.2..
Link: http://lkml.kernel.org/r/1389797849-5565-1-git-send-email-rric.net@gmail.com
Waiman managed to trigger a PMI while in a emulate_vsyscall() fault,
the PMI in turn managed to trigger a fault while obtaining a stack
trace. This triggered the sig_on_uaccess_error recursive fault logic
and killed the process dead.
Fix this by explicitly excluding interrupts from the recursive fault
logic.
Reported-and-Tested-by: Waiman Long <waiman.long@hp.com>
Fixes: e00b12e64be9 ("perf/x86: Further optimize copy_from_user_nmi()")
Cc: Aswin Chandramouleeswaran <aswin@hp.com>
Cc: Scott J Norton <scott.norton@hp.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20140110200603.GJ7572@laptop.programming.kicks-ass.net
Pull locking fixes from Ingo Molnar:
"Two fixes from lockdep coverage of seqlocks, which fix deadlocks on
lockdep-enabled ARM systems"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched_clock: Disable seqlock lockdep usage in sched_clock()
seqlock: Use raw_ prefix instead of _no_lockdep
Pull ARM fixes from Russell King:
"Another few fixes for ARM, nothing major here"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 7938/1: OMAP4/highbank: Flush L2 cache before disabling
ARM: 7939/1: traps: fix opcode endianness when read from user memory
ARM: 7937/1: perf_event: Silence sparse warning
ARM: 7934/1: DT/kernel: fix arch_match_cpu_phys_id to avoid erroneous match
Revert "ARM: 7908/1: mm: Fix the arm_dma_limit calculation"
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
Commit e66d2ae7c67bd moved the assignment
vcpu->arch.apic_base = value above a condition with
(vcpu->arch.apic_base ^ value), causing that check
to always fail. Use old_value, vcpu->arch.apic_base's
old value, in the condition instead.
Signed-off-by: Andrew Jones <drjones@redhat.com>
Commit 14bd8c082016 ("MIPS: Loongson: Get rid of Loongson 2 #ifdefery
all over arch/mips") failed to add Loongson2 specific blast_icache32
functions. Fix that.
The patch fixes the following crash seen with 3.13-rc1:
Reserved instruction in kernel code[#1]:
Call Trace:
blast_icache32_page+0x8/0xb0
r4k_flush_cache_page+0x19c/0x200
do_wp_page.isra.97+0x47c/0xe08
handle_mm_fault+0x938/0x1118
__do_page_fault+0x140/0x540
resume_userspace_check+0x0/0x10
Code: 00200825 64834000 00200825 <bc900000> bc900020 bc900040 bc900060 bc900080 bc9000a0
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Reviewed-by: Aurelien Jarno <aurelien@aurel32.net>
Acked-by: John Crispin <blogic@openwrt.org>
Currently, Loongson-2 call protected_blast_icache_range() and others
call protected_loongson23_blast_icache_range(), but I think the correct
behavior should be the opposite. BTW, Loongson-3's cache-ops is
compatible with MIPS64, but not compatible with Loongson-2. So, rename
xxx_loongson23_yyy things to xxx_loongson2_yyy.
The patch fixes early boot hang with 3.13-rc1, introduced in commit
14bd8c082016 ("MIPS: Loongson: Get rid of Loongson 2 #ifdefery all over
arch/mips").
Signed-off-by: Huacai Chen <chenhc@lemote.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc fix from Ben Herrenschmidt:
"Here's one regression fix for 3.13 that I would appreciate if you
could still pull in. It was an "interesting" one to debug, basically
it's an old bug that got somewhat "exposed" by new code breaking the
boot on PA Semi boards (yes, it does appear that some people are still
using these!)"
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: Check return value of instance-to-package OF call
Pull x86 fixes from Peter Anvin:
"Sorry, meant to push out this batch earlier this weekend"
* 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, fpu, amd: Clear exceptions in AMD FXSAVE workaround
ftrace/x86: Load ftrace_ops in parameter not the variable holding it
On PA-Semi firmware, the instance-to-package callback doesn't seem
to be implemented. We didn't check for error, however, thus
subsequently passed the -1 value returned into stdout_node to
thins like prom_getprop etc...
Thus caused the firmware to load values around 0 (physical) internally
as node structures. It somewhat "worked" as long as we had a NULL in the
right place (address 8) at the beginning of the kernel, we didn't "see"
the bug. But commit 5c0484e25ec03243d4c2f2d4416d4a13efc77f6a
"powerpc: Endian safe trampoline" changed the kernel entry point causing
that old bug to now cause a crash early during boot.
This fixes booting on PA-Semi board by properly checking the return
value from instance-to-package.
Tested-by: Olof Johansson <olof@lixom.net>
Kexec disables outer cache before jumping to reboot code, but it doesn't
flush it explicitly. Flush is done implicitly inside of l2x0_disable().
But some SoC's override default .disable handler and don't flush cache.
This may lead to a corrupted memory during Kexec reboot on these
platforms.
This patch adds cache flush inside of OMAP4 and Highbank outer_cache.disable()
handlers to make it consistent with default l2x0_disable().
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Linus disliked the _no_lockdep() naming, so instead
use the more-consistent raw_* prefix to the non-lockdep
enabled seqcount methods.
This also adds raw_ methods for the write operations
as well, which will be utilized in a following patch.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Krzysztof Hałasa <khalasa@piap.pl>
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Cc: Willy Tarreau <w@1wt.eu>
Link: http://lkml.kernel.org/r/1388704274-5278-1-git-send-email-john.stultz@linaro.org
