commit d974baa398f34393db76be45f7d4d04fbdbb4a0a upstream.
CR4 isn't constant; at least the TSD and PCE bits can vary.
TBH, treating CR0 and CR3 as constant scares me a bit, too, but it looks
like it's correct.
This adds a branch and a read from cr4 to each vm entry. Because it is
extremely likely that consecutive entries into the same vcpu will have
the same host cr4 value, this fixes up the vmcs instead of restoring cr4
after the fact. A subsequent patch will add a kernel-wide cr4 shadow,
reducing the overhead in the common case to just two memory reads and a
branch.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
[wangkai: Backport to 3.10: adjust context]
Signed-off-by: Wang Kai <morgan.wang@huawei.com>
commit 44b82b7700d05a52cd983799d3ecde1a976b3bed upstream.
Commit d7a49086f263164a (arm64: cpuinfo: print info for all CPUs)
attempted to clean up /proc/cpuinfo, but due to concerns regarding
further changes was reverted in commit 5e39977edf6500fd (Revert "arm64:
cpuinfo: print info for all CPUs").
There are two major issues with the arm64 /proc/cpuinfo format
currently:
* The "Features" line describes (only) the 64-bit hwcaps, which is
problematic for some 32-bit applications which attempt to parse it. As
the same names are used for analogous ISA features (e.g. aes) despite
these generally being architecturally unrelated, it is not possible to
simply append the 64-bit and 32-bit hwcaps in a manner that might not
be misleading to some applications.
Various potential solutions have appeared in vendor kernels. Typically
the format of the Features line varies depending on whether the task
is 32-bit.
* Information is only printed regarding a single CPU. This does not
match the ARM format, and does not provide sufficient information in
big.LITTLE systems where CPUs are heterogeneous. The CPU information
printed is queried from the current CPU's registers, which is racy
w.r.t. cross-cpu migration.
This patch attempts to solve these issues. The following changes are
made:
* When a task with a LINUX32 personality attempts to read /proc/cpuinfo,
the "Features" line contains the decoded 32-bit hwcaps, as with the
arm port. Otherwise, the decoded 64-bit hwcaps are shown. This aligns
with the behaviour of COMPAT_UTS_MACHINE and COMPAT_ELF_PLATFORM. In
the absense of compat support, the Features line is empty.
The set of hwcaps injected into a task's auxval are unaffected.
* Properties are printed per-cpu, as with the ARM port. The per-cpu
information is queried from pre-recorded cpu information (as used by
the sanity checks).
* As with the previous attempt at fixing up /proc/cpuinfo, the hardware
field is removed. The only users so far are 32-bit applications tied
to particular boards, so no portable applications should be affected,
and this should prevent future tying to particular boards.
The following differences remain:
* No model_name is printed, as this cannot be queried from the hardware
and cannot be provided in a stable fashion. Use of the CPU
{implementor,variant,part,revision} fields is sufficient to identify a
CPU and is portable across arm and arm64.
* The following system-wide properties are not provided, as they are not
possible to provide generally. Programs relying on these are already
tied to particular (32-bit only) boards:
- Hardware
- Revision
- Serial
No software has yet been identified for which these remaining
differences are problematic.
Cc: Greg Hackmann <ghackmann@google.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Serban Constantinescu <serban.constantinescu@arm.com>
Cc: cross-distro@lists.linaro.org
Cc: linux-api@vger.kernel.org
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
commit 8e64806672466392acf19e14427d1c29df3e58b9 upstream.
Commit e1a5848e3398 ("ARM: 7924/1: mm: don't bother with reserved ttbr0
when running with LPAE") removed the use of the reserved TTBR0 value
for LPAE systems, since the ASID is held in the TTBR and can be updated
atomicly with the pgd of the next mm.
Unfortunately, this patch forgot to update flush_context, which
deliberately avoids marking the local active ASID as allocated, since we
used to switch via ASID zero and didn't need to allocate the ASID of
the previous mm. The side-effect of this is that we can allocate the
same ASID to the next mm and, between flushing the local TLB and updating
TTBR0, we can perform speculative TLB fills for userspace nG mappings
using the page table of the previous mm.
The consequence of this is that the next mm can erroneously hit some
mappings of the previous mm. Note that this was made significantly
harder to hit by a391263cd84e ("ARM: 8203/1: mm: try to re-use old ASID
assignments following a rollover") but is still theoretically possible.
This patch fixes the problem by removing the code from flush_context
that forces the allocated ASID to zero for the local CPU. Many thanks
to the Broadcom guys for tracking this one down.
Fixes: e1a5848e3398 ("ARM: 7924/1: mm: don't bother with reserved ttbr0 when running with LPAE")
Reported-by: Raymond Ngun <rngun@broadcom.com>
Tested-by: Raymond Ngun <rngun@broadcom.com>
Reviewed-by: Gregory Fong <gregory.0xf0@gmail.com>
commit c7754e75100ed5e3068ac5085747f2bfc386c8d6 upstream.
As printk() invocation can cause e.g. a TLB miss, printk() cannot be
called before the exception handlers have been properly initialized.
This can happen e.g. when netconsole has been loaded as a kernel module
and the TLB table has been cleared when a CPU was offline.
Call cpu_report() in start_secondary() only after the exception handlers
have been initialized to fix this.
Without the patch the kernel will randomly either lockup or crash
after a CPU is onlined and the console driver is a module.
Signed-off-by: Hemmo Nieminen <hemmo.nieminen@iki.fi>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/8953/
commit 63a87fe0d0de2ce126a8cec9a299a133cfd5658e upstream.
octeon_cpu_disable() will unconditionally enable interrupts when called.
We can assume that the routine is always called with interrupts disabled,
so just delete the incorrect local_irq_disable/enable().
The patch fixes the following crash when offlining a CPU:
[ 93.818785] ------------[ cut here ]------------
[ 93.823421] WARNING: CPU: 1 PID: 10 at kernel/smp.c:231 flush_smp_call_function_queue+0x1c4/0x1d0()
[ 93.836215] Modules linked in:
[ 93.839287] CPU: 1 PID: 10 Comm: migration/1 Not tainted 3.19.0-rc4-octeon-los_b5f0 #1
[ 93.847212] Stack : 0000000000000001 ffffffff81b2cf90 0000000000000004 ffffffff81630000
0000000000000000 0000000000000000 0000000000000000 000000000000004a
0000000000000006 ffffffff8117e550 0000000000000000 0000000000000000
ffffffff81b30000 ffffffff81b26808 8000000032c77748 ffffffff81627e07
ffffffff81595ec8 ffffffff81b26808 000000000000000a 0000000000000001
0000000000000001 0000000000000003 0000000010008ce1 ffffffff815030c8
8000000032cbbb38 ffffffff8113d42c 0000000010008ce1 ffffffff8117f36c
8000000032c77300 8000000032cbba50 0000000000000001 ffffffff81503984
0000000000000000 0000000000000000 0000000000000000 0000000000000000
0000000000000000 ffffffff81121668 0000000000000000 0000000000000000
[ 93.912819] Call Trace:
[ 93.915273] [<ffffffff81121668>] show_stack+0x68/0x80
[ 93.920335] [<ffffffff81503984>] dump_stack+0x6c/0x90
[ 93.925395] [<ffffffff8113d58c>] warn_slowpath_common+0x94/0xd8
[ 93.931324] [<ffffffff811a402c>] flush_smp_call_function_queue+0x1c4/0x1d0
[ 93.938208] [<ffffffff811a4128>] hotplug_cfd+0xf0/0x108
[ 93.943444] [<ffffffff8115bacc>] notifier_call_chain+0x5c/0xb8
[ 93.949286] [<ffffffff8113d704>] cpu_notify+0x24/0x60
[ 93.954348] [<ffffffff81501738>] take_cpu_down+0x38/0x58
[ 93.959670] [<ffffffff811b343c>] multi_cpu_stop+0x154/0x180
[ 93.965250] [<ffffffff811b3768>] cpu_stopper_thread+0xd8/0x160
[ 93.971093] [<ffffffff8115ea4c>] smpboot_thread_fn+0x1ec/0x1f8
[ 93.976936] [<ffffffff8115ab04>] kthread+0xd4/0xf0
[ 93.981735] [<ffffffff8111c4f0>] ret_from_kernel_thread+0x14/0x1c
[ 93.987835]
[ 93.989326] ---[ end trace c9e3815ee655bda9 ]---
[ 93.993951] Kernel bug detected[#1]:
[ 93.997533] CPU: 1 PID: 10 Comm: migration/1 Tainted: G W 3.19.0-rc4-octeon-los_b5f0 #1
[ 94.006591] task: 8000000032c77300 ti: 8000000032cb8000 task.ti: 8000000032cb8000
[ 94.014081] $ 0 : 0000000000000000 0000000010000ce1 0000000000000001 ffffffff81620000
[ 94.022146] $ 4 : 8000000002c72ac0 0000000000000000 00000000000001a7 ffffffff813b06f0
[ 94.030210] $ 8 : ffffffff813b20d8 0000000000000000 0000000000000000 ffffffff81630000
[ 94.038275] $12 : 0000000000000087 0000000000000000 0000000000000086 0000000000000000
[ 94.046339] $16 : ffffffff81623168 0000000000000001 0000000000000000 0000000000000008
[ 94.054405] $20 : 0000000000000001 0000000000000001 0000000000000001 0000000000000003
[ 94.062470] $24 : 0000000000000038 ffffffff813b7f10
[ 94.070536] $28 : 8000000032cb8000 8000000032cbbc20 0000000010008ce1 ffffffff811bcaf4
[ 94.078601] Hi : 0000000000f188e8
[ 94.082179] Lo : d4fdf3b646c09d55
[ 94.085760] epc : ffffffff811bc9d0 irq_work_run_list+0x8/0xf8
[ 94.091686] Tainted: G W
[ 94.095613] ra : ffffffff811bcaf4 irq_work_run+0x34/0x60
[ 94.101192] Status: 10000ce3 KX SX UX KERNEL EXL IE
[ 94.106235] Cause : 40808034
[ 94.109119] PrId : 000d9301 (Cavium Octeon II)
[ 94.113653] Modules linked in:
[ 94.116721] Process migration/1 (pid: 10, threadinfo=8000000032cb8000, task=8000000032c77300, tls=0000000000000000)
[ 94.127168] Stack : 8000000002c74c80 ffffffff811a4128 0000000000000001 ffffffff81635720
fffffffffffffff2 ffffffff8115bacc 80000000320fbce0 80000000320fbca4
80000000320fbc80 0000000000000002 0000000000000004 ffffffff8113d704
80000000320fbce0 ffffffff81501738 0000000000000003 ffffffff811b343c
8000000002c72aa0 8000000002c72aa8 ffffffff8159cae8 ffffffff8159caa0
ffffffff81650000 80000000320fbbf0 80000000320fbc80 ffffffff811b32e8
0000000000000000 ffffffff811b3768 ffffffff81622b80 ffffffff815148a8
8000000032c77300 8000000002c73e80 ffffffff815148a8 8000000032c77300
ffffffff81622b80 ffffffff815148a8 8000000032c77300 ffffffff81503f48
ffffffff8115ea0c ffffffff81620000 0000000000000000 ffffffff81174d64
[ 94.192771] Call Trace:
[ 94.195222] [<ffffffff811bc9d0>] irq_work_run_list+0x8/0xf8
[ 94.200802] [<ffffffff811bcaf4>] irq_work_run+0x34/0x60
[ 94.206036] [<ffffffff811a4128>] hotplug_cfd+0xf0/0x108
[ 94.211269] [<ffffffff8115bacc>] notifier_call_chain+0x5c/0xb8
[ 94.217111] [<ffffffff8113d704>] cpu_notify+0x24/0x60
[ 94.222171] [<ffffffff81501738>] take_cpu_down+0x38/0x58
[ 94.227491] [<ffffffff811b343c>] multi_cpu_stop+0x154/0x180
[ 94.233072] [<ffffffff811b3768>] cpu_stopper_thread+0xd8/0x160
[ 94.238914] [<ffffffff8115ea4c>] smpboot_thread_fn+0x1ec/0x1f8
[ 94.244757] [<ffffffff8115ab04>] kthread+0xd4/0xf0
[ 94.249555] [<ffffffff8111c4f0>] ret_from_kernel_thread+0x14/0x1c
[ 94.255654]
[ 94.257146]
Code: a2423c40 40026000 30420001 <00020336> dc820000 10400037 00000000 0000010f 0000010f
[ 94.267183] ---[ end trace c9e3815ee655bdaa ]---
[ 94.271804] Fatal exception: panic in 5 seconds
Reported-by: Hemmo Nieminen <hemmo.nieminen@iki.fi>
Acked-by: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/8952/
commit a3e6c1eff54878506b2dddcc202df9cc8180facb upstream.
If the irq_chip does not define .irq_disable, any call to disable_irq
will defer disabling the IRQ until it fires while marked as disabled.
This assumes that the handler function checks for this condition, which
handle_percpu_irq does not. In this case, calling disable_irq leads to
an IRQ storm, if the interrupt fires while disabled.
This optimization is only useful when disabling the IRQ is slow, which
is not true for the MIPS CPU IRQ.
Disable this optimization by implementing .irq_disable and .irq_enable
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/8949/
commit 51ac3d2f0c505ca36ffc9715ffd518d756589ef8 upstream.
NEC OEMs the same platforms as Stratus does, which have multiple devices on
some PCIe buses under downstream ports.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=51331
Fixes: 1278998f8ff6 ("PCI: Work around Stratus ftServer broken PCIe hierarchy (fix DMI check)")
Signed-off-by: Charlotte Richardson <charlotte.richardson@stratus.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Myron Stowe <myron.stowe@redhat.com>
commit 6b076991dca9817e75c37e2f0db6d52611ea42fa upstream.
When setting up the CMA region, we must ensure that the old section
mappings are flushed from the TLB before replacing them with page
tables, otherwise we can suffer from mismatched aliases if the CPU
speculatively prefetches from these mappings at an inopportune time.
A mismatched alias can occur when the TLB contains a section mapping,
but a subsequent prefetch causes it to load a page table mapping,
resulting in the possibility of the TLB containing two matching
mappings for the same virtual address region.
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Hou Pengyang <houpengyang@huawei.com>
commit e6eb2eba494d6f99e69ca3c3748cd37a2544ab38 upstream.
The commit 3b8a3c010969 ("powerpc/pseries: Fix endiannes issue in RTAS
call from xmon") was fixing an endianness issue in the call made from
xmon to RTAS.
However, as Michael Ellerman noticed, this fix was not complete, the
token value was not byte swapped. This lead to call an unexpected and
most of the time unexisting RTAS function, which is silently ignored by
RTAS.
This fix addresses this hole.
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
commit d69911a68c865b152a067feaa45e98e6bb0f655b upstream.
Commit e6023367d779 ("x86, kaslr: Prevent .bss from overlaping initrd")
added Perl to the required build environment. This reimplements in
shell the Perl script used to find the size of the kernel with bss and
brk added.
Reported-by: Rob Landley <rob@landley.net>
Acked-by: Rob Landley <rob@landley.net>
Cc: Anca Emanuel <anca.emanuel@gmail.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Junjie Mao <eternal.n08@gmail.com>
Cc: <stable@vger.kernel.org>
commit b745bc85f21ea707e4ea1a91948055fa3e72c77b upstream.
cold is a bool, make it one. Make the likely case the "if" part of the
block instead of the else as according to the optimisation manual this is
preferred.
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit ba25915fb2cd18152cb14b144dbe8bf2f2bd8e45 upstream.
Fixes: ec7ac6afd07b (ARC: switch to generic ENTRY/END assembler annotations)
Reported-by: Anton Kolesov <akolesov@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 64ee9f32c33cbd53545284742e73c17fedf9d429 upstream.
Commit 93ea02bb8435 ("arch: Clean up asm/barrier.h implementations")
wired generic barrier.h for ARC, but failed to delete the existing file.
In 3.15, due to rcupdate.h updates, this causes a build breakage on ARC:
CC arch/arc/kernel/asm-offsets.s
In file included from include/linux/sched.h:45:0,
from arch/arc/kernel/asm-offsets.c:9:
include/linux/rculist.h: In function __list_add_rcu:
include/linux/rculist.h:54:2: error: implicit declaration of function smp_store_release [-Werror=implicit-function-declaration]
rcu_assign_pointer(list_next_rcu(prev), new);
commit 3e14dcf7cb80b34a1f38b55bc96f02d23fdaaaaf upstream.
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
changed the automatic module loading when requesting crypto algorithms
to prefix all module requests with "crypto-". This requires all crypto
modules to have a crypto specific module alias even if their file name
would otherwise match the requested crypto algorithm.
Even though commit 5d26a105b5a7 added those aliases for a vast amount of
modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO
annotations to those files to make them get loaded automatically, again.
This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work
with kernels v3.18 and below.
Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former
won't work for crypto modules any more.
Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 4943ba16bbc2db05115707b3ff7b4874e9e3c560 upstream.
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 7ddc6a2199f1da405a2fb68c40db8899b1a8cd87 upstream.
These functions can be executed on the int3 stack, so kprobes
are dangerous. Tracing is probably a bad idea, too.
Fixes: b645af2d5905 ("x86_64, traps: Rework bad_iret")
Link: http://lkml.kernel.org/r/50e33d26adca60816f3ba968875801652507d0c4.1416870125.git.luto@amacapital.net
[bwh: Backported to 3.10:
- Use __kprobes instead of NOKPROBE_SYMBOL()
- Adjust context]
commit 38a1dfda8e77d7ba74c94d06d8bc41ba98a4bc8c upstream.
Commit 0dbc6078c06bc0 ('x86, build, pci: Fix PCI_MSI build on !SMP')
introduced the dependency that X86_UP_APIC is only available when
PCI_MSI is false. This effectively prevents PCI_MSI support on 32bit
UP systems because it disables both APIC and IO-APIC. But APIC support
is architecturally required for PCI_MSI.
The intention of the patch was to enforce APIC support when PCI_MSI is
enabled, but failed to do so.
Remove the !PCI_MSI dependency from X86_UP_APIC and enforce
X86_UP_APIC when PCI_MSI support is enabled on 32bit UP systems.
[ tglx: Massaged changelog ]
Fixes 0dbc6078c06bc0 'x86, build, pci: Fix PCI_MSI build on !SMP'
Signed-off-by: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: http://lkml.kernel.org/r/1421967529-9037-1-git-send-email-pure.logic@nexus-software.ie
commit 3669ef9fa7d35f573ec9c0e0341b29251c2734a7 upstream.
The Witcher 2 did something like this to allocate a TLS segment index:
struct user_desc u_info;
bzero(&u_info, sizeof(u_info));
u_info.entry_number = (uint32_t)-1;
syscall(SYS_set_thread_area, &u_info);
Strictly speaking, this code was never correct. It should have set
read_exec_only and seg_not_present to 1 to indicate that it wanted
to find a free slot without putting anything there, or it should
have put something sensible in the TLS slot if it wanted to allocate
a TLS entry for real. The actual effect of this code was to
allocate a bogus segment that could be used to exploit espfix.
The set_thread_area hardening patches changed the behavior, causing
set_thread_area to return -EINVAL and crashing the game.
This changes set_thread_area to interpret this as a request to find
a free slot and to leave it empty, which isn't *quite* what the game
expects but should be close enough to keep it working. In
particular, using the code above to allocate two segments will
allocate the same segment both times.
According to FrostbittenKing on Github, this fixes The Witcher 2.
If this somehow still causes problems, we could instead allocate
a limit==0 32-bit data segment, but that seems rather ugly to me.
Fixes: 41bdc78544b8 x86/tls: Validate TLS entries to protect espfix
Cc: torvalds@linux-foundation.org
Link: http://lkml.kernel.org/r/0cb251abe1ff0958b8e468a9a9a905b80ae3a746.1421954363.git.luto@amacapital.net
commit e30ab185c490e9a9381385529e0fd32f0a399495 upstream.
32-bit programs don't have an lm bit in their ABI, so they can't
reliably cause LDT_empty to return true without resorting to memset.
They shouldn't need to do this.
This should fix a longstanding, if minor, issue in all 64-bit kernels
as well as a potential regression in the TLS hardening code.
Link: http://lkml.kernel.org/r/72a059de55e86ad5e2935c80aa91880ddf19d07c.1421954363.git.luto@amacapital.net
commit f285f4a21c3253887caceed493089ece17579d59 upstream.
On 64-bit, relocation is not required unless the load address gets
changed. Without this, relocations do unexpected things when the kernel
is above 4G.
Reported-by: Baoquan He <bhe@redhat.com>
Tested-by: Thomas D. <whissi@whissi.de>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Jan Beulich <JBeulich@suse.com>
Link: http://lkml.kernel.org/r/20150116005146.GA4212@www.outflux.net
commit 520452172e6b318f3a8bd9d4fe1e25066393de25 upstream.
Many users see this message when booting without knowning that it is
of no importance and that TSC calibration may have succeeded by
another way.
As explained by Paul Bolle in
http://lkml.kernel.org/r/1348488259.1436.22.camel@x61.thuisdomein
"Fast TSC calibration failed" should not be considered as an error
since other calibration methods are being tried afterward. At most,
those send a warning if they fail (not an error). So let's change
the message from error to warning.
[ tglx: Make if pr_info. It's really not important at all ]
Fixes: c767a54ba065 x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>
Signed-off-by: Alexandre Demers <alexandre.f.demers@gmail.com>
Link: http://lkml.kernel.org/r/1418106470-6906-1-git-send-email-alexandre.f.demers@gmail.com
commit 32c6590d126836a062b3140ed52d898507987017 upstream.
The Hyper-V clocksource is continuous; mark it accordingly.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Acked-by: jasowang@redhat.com
Cc: gregkh@linuxfoundation.org
Cc: devel@linuxdriverproject.org
Cc: olaf@aepfle.de
Cc: apw@canonical.com
Link: http://lkml.kernel.org/r/1421108762-3331-1-git-send-email-kys@microsoft.com
commit 7ecd0bde5bfea524a843ad8fa8cb66ccbce68779 upstream.
Currently PWM functionality is broken on mx25 due to the wrong assignment of the
PWM "per" clock.
According to Documentation/devicetree/bindings/clock/imx25-clock.txt:
pwm_ipg_per 52
,so update the pwm "per" to use 'pwm_ipg_per' instead of 'per10' clock.
With this change PWM can work fine on mx25.
Reported-by: Carlos Soto <csotoalonso@gmail.com>
commit 78051e3b7e35722ad3f31dd611f1b34770bddab8 upstream.
If L0 has disabled EPT, don't advertise unrestricted
mode at all since it depends on EPT to run real mode code.
Fixes: 92fbc7b195b824e201d9f06f2b93105f72384d65
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Bandan Das <bsd@redhat.com>
commit b485342bd79af363c77ef1a421c4a0aef2de9812 upstream.
Commit a074335a370e ("x86, um: Mark system call tables readonly") was
supposed to mark the sys_call_table in UML as RO by adding the const,
but it doesn't have the desired effect as it's nevertheless being placed
into the data section since __cacheline_aligned enforces sys_call_table
being placed into .data..cacheline_aligned instead. We need to use
the ____cacheline_aligned version instead to fix this issue.
Before:
$ nm -v arch/x86/um/sys_call_table_64.o | grep -1 "sys_call_table"
U sys_writev
0000000000000000 D sys_call_table
0000000000000000 D syscall_table_size
After:
U sys_writev
0000000000000000 R sys_call_table
Fixes: a074335a370e ("x86, um: Mark system call tables readonly")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit f911d731054ab3d82ee72a16b889e17ca3a2332a upstream.
futex_atomic_cmpxchg_inatomic() does not work on UML because
it triggers a copy_from_user() in kernel context.
On UML copy_from_user() can only be used if the kernel was called
by a real user space process such that UML can use ptrace()
to fetch the value.
Reported-by: Miklos Szeredi <miklos@szeredi.hu>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Daniel Walter <d.walter@0x90.at>
commit b0ddb319db3d7a1943445f0de0a45c07a7f3457a upstream.
The sh73a0 INTC can't mask interrupts properly most likely due to a
hardware bug. Set the .control_parent flag to delegate masking to the
parent interrupt controller, like was already done for irqpin1.
Without this, accessing the three-axis digital accelerometer ADXL345
on kzm9g through /dev/input/event1 causes an interrupt storm, which
requires a power-cycle to recover from.
This was inspired by a patch for arch/arm/boot/dts/sh73a0.dtsi from
Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Fixes: 341eb5465f67437a ("ARM: shmobile: INTC External IRQ pin driver on sh73a0")
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit 572b24e6d85d98cdc552f07e9fb9870d9460d81b upstream.
The switch statement of the possible list of SYSCLK1 frequencies is
missing a 0 in 4 out of the 7 frequencies.
Fixes: fa6d79d27614 ("ARM: OMAP: Add initialisation for the real-time counter")
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
commit 81ef447950bf0955aca46f4a7617d8ce435cf0ce upstream.
The post dividers do not work on i.MX6Q rev T0 1.0 so they must be fixed
to 1. As the table index was wrong, a divider a of 4 could still be
requested which implied the clock not to be set properly. This is the
root cause of the HDMI not working at high resolution on rev T0 1.0 of
the SoC.
Signed-off-by: Gary Bisson <bisson.gary@gmail.com>
commit d2a10a1727b3948019128e83162f22c65859f1fd upstream.
Drop unnecessary semicolon after closing curly bracket.
Signed-off-by: Dmitry Voytik <voytikd@gmail.com>
commit 7a87e9cbc3a2f0ff0955815335e08c9862359130 upstream.
From Documentation/devicetree/bindings/clock/imx25-clock.txt:
cspi1_ipg 78
cspi2_ipg 79
cspi3_ipg 80
, so fix the SPI1 clocks accordingly to avoid a kernel hang when trying to
access SPI1.
commit 237d28db036e411f22c03cfd5b0f6dc2aa9bf3bc upstream.
If the function graph tracer traces a jprobe callback, the system will
crash. This can easily be demonstrated by compiling the jprobe
sample module that is in the kernel tree, loading it and running the
function graph tracer.
# modprobe jprobe_example.ko
# echo function_graph > /sys/kernel/debug/tracing/current_tracer
# ls
The first two commands end up in a nice crash after the first fork.
(do_fork has a jprobe attached to it, so "ls" just triggers that fork)
The problem is caused by the jprobe_return() that all jprobe callbacks
must end with. The way jprobes works is that the function a jprobe
is attached to has a breakpoint placed at the start of it (or it uses
ftrace if fentry is supported). The breakpoint handler (or ftrace callback)
will copy the stack frame and change the ip address to return to the
jprobe handler instead of the function. The jprobe handler must end
with jprobe_return() which swaps the stack and does an int3 (breakpoint).
This breakpoint handler will then put back the saved stack frame,
simulate the instruction at the beginning of the function it added
a breakpoint to, and then continue on.
For function tracing to work, it hijakes the return address from the
stack frame, and replaces it with a hook function that will trace
the end of the call. This hook function will restore the return
address of the function call.
If the function tracer traces the jprobe handler, the hook function
for that handler will not be called, and its saved return address
will be used for the next function. This will result in a kernel crash.
To solve this, pause function tracing before the jprobe handler is called
and unpause it before it returns back to the function it probed.
Some other updates:
Used a variable "saved_sp" to hold kcb->jprobe_saved_sp. This makes the
code look a bit cleaner and easier to understand (various tries to fix
this bug required this change).
Note, if fentry is being used, jprobes will change the ip address before
the function graph tracer runs and it will not be able to trace the
function that the jprobe is probing.
Link: http://lkml.kernel.org/r/20150114154329.552437962@goodmis.org
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit 45db07382a5c78b0c43b3b0002b63757fb60e873 upstream.
The __ldcw macro has a problem when its argument needs to be reloaded from
memory. The output memory operand and the input register operand both need to
be reloaded using a register in class R1_REGS when generating 64-bit code.
This fails because there's only a single register in the class. Instead, use a
memory clobber. This also makes the __ldcw macro a compiler memory barrier.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
commit ec7ac6afd07b2d958aab9dfc0a686300b856922a upstream.
With commit 9df62f054406 "arch: use ASM_NL instead of ';'" the generic
macros can handle the arch specific newline quirk. Hence we can get rid
of ARC asm macros and use the "C" style macros.
commit e8ef060b37c2d3cc5fd0c0edbe4e42ec1cb9768b upstream.
This allows the sdplite/Zebu images to run on OSCI simulation platform
commit af91568e762d04931dcbdd6bef4655433d8b9418 upstream.
The uncore_collect_events functions assumes that event group
might contain only uncore events which is wrong, because it
might contain any type of events.
This bug leads to uncore framework touching 'not' uncore events,
which could end up all sorts of bugs.
One was triggered by Vince's perf fuzzer, when the uncore code
touched breakpoint event private event space as if it was uncore
event and caused BUG:
BUG: unable to handle kernel paging request at ffffffff82822068
IP: [<ffffffff81020338>] uncore_assign_events+0x188/0x250
The code in uncore_assign_events() function was looking for
event->hw.idx data while the event was initialized as a
breakpoint with different members in event->hw union.
This patch forces uncore_collect_events() to collect only uncore
events.
Reported-by: Vince Weaver <vince@deater.net>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Link: http://lkml.kernel.org/r/1418243031-20367-2-git-send-email-jolsa@kernel.org
commit f43c27188a49111b58e9611afa2f0365b0b55625 upstream.
On arm64 the TTBR0_EL1 register is set to either the reserved TTBR0
page tables on boot or to the active_mm mappings belonging to user space
processes, it must never be set to swapper_pg_dir page tables mappings.
When a CPU is booted its active_mm is set to init_mm even though its
TTBR0_EL1 points at the reserved TTBR0 page mappings. This implies
that when __cpu_suspend is triggered the active_mm can point at
init_mm even if the current TTBR0_EL1 register contains the reserved
TTBR0_EL1 mappings.
Therefore, the mm save and restore executed in __cpu_suspend might
turn out to be erroneous in that, if the current->active_mm corresponds
to init_mm, on resume from low power it ends up restoring in the
TTBR0_EL1 the init_mm mappings that are global and can cause speculation
of TLB entries which end up being propagated to user space.
This patch fixes the issue by checking the active_mm pointer before
restoring the TTBR0 mappings. If the current active_mm == &init_mm,
the code sets the TTBR0_EL1 to the reserved TTBR0 mapping instead of
switching back to the active_mm, which is the expected behaviour
corresponding to the TTBR0_EL1 settings when __cpu_suspend was entered.
Fixes: 95322526ef62 ("arm64: kernel: cpu_{suspend/resume} implementation")
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
commit c3684fbb446501b48dec6677a6a9f61c215053de upstream.
The function cpu_resume currently lives in the .data section.
There's no reason for it to be there since we can use relative
instructions without a problem. Move a few cpu_resume data
structures out of the assembly file so the .data annotation
can be dropped completely and cpu_resume ends up in the read
only text section.
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Kees Cook <keescook@chromium.org>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
commit 714f59925595b9c2ea9c22b107b340d38e3b3bc9 upstream.
CPU suspend is the standard kernel interface to be used to enter
low-power states on ARM64 systems. Current cpu_suspend implementation
by default assumes that all low power states are losing the CPU context,
so the CPU registers must be saved and cleaned to DRAM upon state
entry. Furthermore, the current cpu_suspend() implementation assumes
that if the CPU suspend back-end method returns when called, this has
to be considered an error regardless of the return code (which can be
successful) since the CPU was not expected to return from a code path that
is different from cpu_resume code path - eg returning from the reset vector.
All in all this means that the current API does not cope well with low-power
states that preserve the CPU context when entered (ie retention states),
since first of all the context is saved for nothing on state entry for
those states and a successful state entry can return as a normal function
return, which is considered an error by the current CPU suspend
implementation.
This patch refactors the cpu_suspend() API so that it can be split in
two separate functionalities. The arm64 cpu_suspend API just provides
a wrapper around CPU suspend operation hook. A new function is
introduced (for architecture code use only) for states that require
context saving upon entry:
__cpu_suspend(unsigned long arg, int (*fn)(unsigned long))
__cpu_suspend() saves the context on function entry and calls the
so called suspend finisher (ie fn) to complete the suspend operation.
The finisher is not expected to return, unless it fails in which case
the error is propagated back to the __cpu_suspend caller.
The API refactoring results in the following pseudo code call sequence for a
suspending CPU, when triggered from a kernel subsystem:
* int cpu_suspend(unsigned long idx)
* @idx: idle state index
-> cpu_suspend(idx)
|---> CPU operations suspend hook called, if present
|--> if (retention_state)
|--> direct suspend back-end call (eg PSCI suspend)
else
|--> __cpu_suspend(idx, &back_end_finisher);
By refactoring the cpu_suspend API this way, the CPU operations back-end
has a chance to detect whether idle states require state saving or not
and can call the required suspend operations accordingly either through
simple function call or indirectly through __cpu_suspend() which carries out
state saving and suspend finisher dispatching to complete idle state entry.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
commit 18ab7db6b749ac27aac08d572afbbd2f4d937934 upstream.
Suspend init function must be marked as __init, since it is not needed
after the kernel has booted. This patch moves the cpu_suspend_init()
function to the __init section.
commit e55355453600a33bb5ca4f71f2d7214875f3b061 upstream.
Enabling the hardware I/O coherency on Armada 370, Armada 375, Armada
38x and Armada XP requires a certain number of conditions:
- On Armada 370, the cache policy must be set to write-allocate.
- On Armada 375, 38x and XP, the cache policy must be set to
write-allocate, the pages must be mapped with the shareable
attribute, and the SMP bit must be set
Currently, on Armada XP, when CONFIG_SMP is enabled, those conditions
are met. However, when Armada XP is used in a !CONFIG_SMP kernel, none
of these conditions are met. With Armada 370, the situation is worse:
since the processor is single core, regardless of whether CONFIG_SMP
or !CONFIG_SMP is used, the cache policy will be set to write-back by
the kernel and not write-allocate.
Since solving this problem turns out to be quite complicated, and we
don't want to let users with a mainline kernel known to have
infrequent but existing data corruptions, this commit proposes to
simply disable hardware I/O coherency in situations where it is known
not to work.
And basically, the is_smp() function of the kernel tells us whether it
is OK to enable hardware I/O coherency or not, so this commit slightly
refactors the coherency_type() function to return
COHERENCY_FABRIC_TYPE_NONE when is_smp() is false, or the appropriate
type of the coherency fabric in the other case.
Thanks to this, the I/O coherency fabric will no longer be used at all
in !CONFIG_SMP configurations. It will continue to be used in
CONFIG_SMP configurations on Armada XP, Armada 375 and Armada 38x
(which are multiple cores processors), but will no longer be used on
Armada 370 (which is a single core processor).
In the process, it simplifies the implementation of the
coherency_type() function, and adds a missing call to of_node_put().
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Fixes: e60304f8cb7bb545e79fe62d9b9762460c254ec2 ("arm: mvebu: Add hardware I/O Coherency support")
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1415871540-20302-3-git-send-email-thomas.petazzoni@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit 4bf9636c39ac70da091d5a2e28d3448eaa7f115c upstream.
Commit 9fc2105aeaaf ("ARM: 7830/1: delay: don't bother reporting
bogomips in /proc/cpuinfo") breaks audio in python, and probably
elsewhere, with message
FATAL: cannot locate cpu MHz in /proc/cpuinfo
I'm not the first one to hit it, see for example
https://theredblacktree.wordpress.com/2014/08/10/fatal-cannot-locate-cpu-mhz-in-proccpuinfo/
https://devtalk.nvidia.com/default/topic/765800/workaround-for-fatal-cannot-locate-cpu-mhz-in-proc-cpuinf/?offset=1
Reading original changelog, I have to say "Stop breaking working setups.
You know who you are!".
Signed-off-by: Pavel Machek <pavel@ucw.cz>
omap4_init_static_deps
commit 9008d83fe9dc2e0f19b8ba17a423b3759d8e0fd7 upstream.
Commit 705814b5ea6f ("ARM: OMAP4+: PM: Consolidate OMAP4 PM code to
re-use it for OMAP5")
Moved logic generic for OMAP5+ as part of the init routine by
introducing omap4_pm_init. However, the patch left the powerdomain
initial setup, an unused omap4430 es1.0 check and a spurious log
"Power Management for TI OMAP4." in the original code.
Remove the duplicate code which is already present in omap4_pm_init from
omap4_init_static_deps.
As part of this change, also move the u-boot version print out of the
static dependency function to the omap4_pm_init function.
Fixes: 705814b5ea6f ("ARM: OMAP4+: PM: Consolidate OMAP4 PM code to re-use it for OMAP5")
Signed-off-by: Nishanth Menon <nm@ti.com>
commit 5e794de514f56de1e78e979ca09c56a91aa2e9f1 upstream.
The PWM block is required for system clock source so it must be always
enabled. This patch fixes boot issues on SMDK6410 which did not have
the node enabled explicitly for other purposes.
Fixes: eeb93d02 ("clocksource: of: Respect device tree node status")
Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
commit be6688350a4470e417aaeca54d162652aab40ac5 upstream.
OMAP wdt driver supports only ti,omap3-wdt compatible. In DRA7 dt
wdt compatible property is defined as ti,omap4-wdt by mistake instead of
ti,omap3-wdt. Correcting the typo.
Fixes: 6e58b8f1daaf1a ("ARM: dts: DRA7: Add the dts files for dra7 SoC and dra7-evm board")
commit 007487f1fd43d84f26cda926081ca219a24ecbc4 upstream.
Currently we enable Exynos devices in the multi v7 defconfig, however, when
testing on my ODROID-U3, I noticed that USB was not working. Enabling this
option causes USB to work, which enables networking support as well since the
ODROID-U3 has networking on the USB bus.
[arnd] Support for odroid-u3 was added in 3.10, so it would be nice to
backport this fix at least that far.
Signed-off-by: Steev Klimaszewski <steev@gentoo.org>
commit 1ddf0b1b11aa8a90cef6706e935fc31c75c406ba upstream.
In Linux 3.18 and below, GCC hoists the lsl instructions in the
pvclock code all the way to the beginning of __vdso_clock_gettime,
slowing the non-paravirt case significantly. For unknown reasons,
presumably related to the removal of a branch, the performance issue
is gone as of
e76b027e6408 x86,vdso: Use LSL unconditionally for vgetcpu
but I don't trust GCC enough to expect the problem to stay fixed.
There should be no correctness issue, because the __getcpu calls in
__vdso_vlock_gettime were never necessary in the first place.
Note to stable maintainers: In 3.18 and below, depending on
configuration, gcc 4.9.2 generates code like this:
9c3: 44 0f 03 e8 lsl %ax,%r13d
9c7: 45 89 eb mov %r13d,%r11d
9ca: 0f 03 d8 lsl %ax,%ebx
This patch won't apply as is to any released kernel, but I'll send a
trivial backported version if needed.
Backported by Andy Lutomirski. Should apply to all affected
versions. This fixes a functionality bug as well as a performance
bug: buggy kernels can infinite loop in __vdso_clock_gettime on
affected compilers. See, for exammple:
https://bugzilla.redhat.com/show_bug.cgi?id=1178975
Fixes: 51c19b4f5927 x86: vdso: pvclock gettime support
Cc: Marcelo Tosatti <mtosatti@redhat.com>
commit 394f56fe480140877304d342dec46d50dc823d46 upstream.
The theory behind vdso randomization is that it's mapped at a random
offset above the top of the stack. To avoid wasting a page of
memory for an extra page table, the vdso isn't supposed to extend
past the lowest PMD into which it can fit. Other than that, the
address should be a uniformly distributed address that meets all of
the alignment requirements.
The current algorithm is buggy: the vdso has about a 50% probability
of being at the very end of a PMD. The current algorithm also has a
decent chance of failing outright due to incorrect handling of the
case where the top of the stack is near the top of its PMD.
This fixes the implementation. The paxtest estimate of vdso
"randomisation" improves from 11 bits to 18 bits. (Disclaimer: I
don't know what the paxtest code is actually calculating.)
It's worth noting that this algorithm is inherently biased: the vdso
is more likely to end up near the end of its PMD than near the
beginning. Ideally we would either nix the PMD sharing requirement
or jointly randomize the vdso and the stack to reduce the bias.
In the mean time, this is a considerable improvement with basically
no risk of compatibility issues, since the allowed outputs of the
algorithm are unchanged.
As an easy test, doing this:
for i in `seq 10000`
do grep -P vdso /proc/self/maps |cut -d- -f1
done |sort |uniq -d
used to produce lots of output (1445 lines on my most recent run).
A tiny subset looks like this:
7fffdfffe000
7fffe01fe000
7fffe05fe000
7fffe07fe000
7fffe09fe000
7fffe0bfe000
7fffe0dfe000
Note the suspicious fe000 endings. With the fix, I get a much more
palatable 76 repeated addresses.
commit a629df7eadffb03e6ce4a8616e62ea29fdf69b6b upstream.
Since most virtual machines raise this message once, it is a bit annoying.
Make it KERN_DEBUG severity.
Fixes: 7a2e8aaf0f6873b47bc2347f216ea5b0e4c258ab
