path: root/arch
2013-08-25Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "This round of fixes is smaller than previous: a couple more updates for the security fixes, and a one-liner kexec fix" * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7816/1: CONFIG_KUSER_HELPERS: fix help text ARM: 7815/1: kexec: offline non panic CPUs on Kdump panic ARM: 7819/1: fiq: Cast the first argument of flush_icache_range()
2013-08-24ARC: [lib] strchr breakage in Big-endian configurationJoern Rennecke
For a search buffer, 2 byte aligned, strchr() was returning pointer outside of buffer (buf - 1) ------------->8---------------- // Input buffer (default 4 byte aigned) char *buffer = "1AA_"; // actual search start (to mimick 2 byte alignment) char *current_line = &(buffer[2]); // Character to search for char c = 'A'; char *c_pos = strchr(current_line, c); printf("%s\n", c_pos) --> 'AA_' as oppose to 'A_' ------------->8---------------- Reported-by: Anton Kolesov <Anton.Kolesov@synopsys.com> Debugged-by: Anton Kolesov <Anton.Kolesov@synopsys.com> Cc: <stable@vger.kernel.org> # [3.9 and 3.10] Cc: Noam Camus <noamc@ezchip.com> Signed-off-by: Joern Rennecke <joern.rennecke@embecosm.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A handful of fixes for 3.11 are still trickling in. These are: - A couple of fixes for older OMAP platforms - Another few fixes for at91 (lateish due to European summer vacations) - A late-found problem with USB on Tegra, fix is to keep VBUS regulator on at all times - One fix for Exynos 5440 dealing with CPU detection - One MAINTAINERS update" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: tegra: always enable USB VBUS regulators ARM: davinci: nand: specify ecc strength ARM: OMAP: rx51: change musb mode to OTG ARM: OMAP2: fix musb usage for n8x0 MAINTAINERS: Update email address for Benoit Cousson ARM: at91/DT: fix at91sam9n12ek memory node ARM: at91: add missing uart clocks DT entries ARM: SAMSUNG: fix to support for missing cpu specific map_io ARM: at91/DT: at91sam9x5ek: fix USB host property to enable port C
2013-08-22x86 get_unmapped_area: Access mmap_legacy_base through mm_struct memberRadu Caragea
This is the updated version of df54d6fa5427 ("x86 get_unmapped_area(): use proper mmap base for bottom-up direction") that only randomizes the mmap base address once. Signed-off-by: Radu Caragea <sinaelgl@gmail.com> Reported-and-tested-by: Jeff Shorey <shoreyjeff@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Michel Lespinasse <walken@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Adrian Sendroiu <molecula2788@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-22Revert "x86 get_unmapped_area(): use proper mmap base for bottom-up direction"Linus Torvalds
This reverts commit df54d6fa54275ce59660453e29d1228c2b45a826. The commit isn't necessarily wrong, but because it recalculates the random mmap_base every time, it seems to confuse user memory allocators that expect contiguous mmap allocations even when the mmap address isn't specified. In particular, the MATLAB Java runtime seems to be unhappy. See https://bugzilla.kernel.org/show_bug.cgi?id=60774 So we'll want to apply the random offset only once, and Radu has a patch for that. Revert this older commit in order to apply the other one. Reported-by: Jeff Shorey <shoreyjeff@gmail.com> Cc: Radu Caragea <sinaelgl@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-21ARM: tegra: always enable USB VBUS regulatorsStephen Warren
This fixes a regression exposed during the merge window by commit 9f310de "ARM: tegra: fix VBUS regulator GPIO polarity in DT"; namely that USB VBUS doesn't get turned on, so USB devices are not detected. This affects the internal USB port on TrimSlice (i.e. the USB->SATA bridge, to which the SSD is connected) and the external port(s) on Seaboard/ Springbank and Whistler. The Tegra DT as written in v3.11 allows two paths to enable USB VBUS: 1) Via the legacy DT binding for the USB controller; it can directly acquire a VBUS GPIO and activate it. 2) Via a regulator for VBUS, which is referenced by the new DT binding for the USB controller. Those two methods both use the same GPIO, and hence whichever of the USB controller and regulator gets probed first ends up owning the GPIO. In practice, the USB driver only supports path (1) above, since the patches to support the new USB binding are not present until v3.12:-( In practice, the regulator ends up being probed first and owning the GPIO. Since nothing enables the regulator (the USB driver code is not yet present), the regulator ends up being turned off. This originally caused no problem, because the polarity in the regulator definition was incorrect, so attempting to turn off the regulator actually turned it on, and everything worked:-( However, when testing the new USB driver code in v3.12, I noticed the incorrect polarity and fixed it in commit 9f310de "ARM: tegra: fix VBUS regulator GPIO polarity in DT". In the context of v3.11, this patch then caused the USB VBUS to actually turn off, which broke USB ports with VBUS control. I got this patch included in v3.11-rc1 since it fixed a bug in device tree (incorrect polarity specification), and hence was suitable to be included early in the rc series. I evidently did not test the patch at all, or correctly, in the context of v3.11, and hence did not notice the issue that I have explained above:-( Fix this by making the USB VBUS regulators always enabled. This way, if the regulator owns the GPIO, it will always be turned on, even if there is no USB driver code to request the regulator be turned on. Even ignoring this bug, this is a reasonable way to configure the HW anyway. If this patch is applied to v3.11, it will cause a couple pretty trivial conflicts in tegra20-{trimslice,seaboard}.dts when creating v3.12, since the context right above the added lines changed in patches destined for v3.12. Reported-by: Kyle McMartin <kmcmarti@redhat.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-21Merge tag 'stable/for-linus-3.11-rc6-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bug-fixes from Konrad Rzeszutek Wilk: - On ARM did not have balanced calls to get/put_cpu. - Fix to make tboot + Xen + Linux correctly. - Fix events VCPU binding issues. - Fix a vCPU online race where IPIs are sent to not-yet-online vCPU. * tag 'stable/for-linus-3.11-rc6-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/smp: initialize IPI vectors before marking CPU online xen/events: mask events when changing their VCPU binding xen/events: initialize local per-cpu mask for all possible events x86/xen: do not identity map UNUSABLE regions in the machine E820 xen/arm: missing put_cpu in xen_percpu_init
2013-08-21Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fix from Ralf Baechle: "Just a single patch which fixes a special case in the MIPS FPU emulator which is always required, even on CPUs with FPU. There is the rare special case that an FPU (or certain other instructions) in a branch delay slot is causing an exception and then the branch instruction will need to be emulated by the kernel before resuming execution. This is working great except if the branch instruction is an Octeon BBIT instruction. The boring disclaimer - all MIPS defconfigs build tested and no regressions and runtime tested on Octeon, no known issues" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: Handle OCTEON BBIT instructions in FPU emulator.
2013-08-21Merge tag 'arm64-stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull arm64 perf fixes from Catalin Marinas: "Perf backend fixes for arm64 where the user can cause kernel panic (discovered with Vince's fuzzing tool)" * tag 'arm64-stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: arm64: perf: fix event validation for software group leaders arm64: perf: fix array out of bounds access in armpmu_map_hw_event()
2013-08-21Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "Fixes for ARM and aarch64. This pull request is coming a bit later than I would have preferred, because I and Gleb happened to have holidays around the same weeks of August... sorry about that" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: ARM: Squash len warning arm64: KVM: use 'int' instead of 'u32' for variable 'target' in kvm_host.h. arm64: KVM: add missing dsb before invalidating Stage-2 TLBs arm64: KVM: perform save/restore of PAR_EL1 arm64: KVM: fix 2-level page tables unmapping ARM: KVM: Fix unaligned unmap_range leak ARM: KVM: Fix 64-bit coprocessor handling
2013-08-20MIPS: Handle OCTEON BBIT instructions in FPU emulator.David Daney
The branch emulation needs to handle the OCTEON BBIT instructions, otherwise we get SIGILL instead of emulation. Signed-off-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5726/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-08-20xen/smp: initialize IPI vectors before marking CPU onlineChuck Anderson
An older PVHVM guest (v3.0 based) crashed during vCPU hot-plug with: kernel BUG at drivers/xen/events.c:1328! RCU has detected that a CPU has not entered a quiescent state within the grace period. It needs to send the CPU a reschedule IPI if it is not offline. rcu_implicit_offline_qs() does this check: /* * If the CPU is offline, it is in a quiescent state. We can * trust its state not to change because interrupts are disabled. */ if (cpu_is_offline(rdp->cpu)) { rdp->offline_fqs++; return 1; } Else the CPU is online. Send it a reschedule IPI. The CPU is in the middle of being hot-plugged and has been marked online (!cpu_is_offline()). See start_secondary(): set_cpu_online(smp_processor_id(), true); ... per_cpu(cpu_state, smp_processor_id()) = CPU_ONLINE; start_secondary() then waits for the CPU bringing up the hot-plugged CPU to mark it as active: /* * Wait until the cpu which brought this one up marked it * online before enabling interrupts. If we don't do that then * we can end up waking up the softirq thread before this cpu * reached the active state, which makes the scheduler unhappy * and schedule the softirq thread on the wrong cpu. This is * only observable with forced threaded interrupts, but in * theory it could also happen w/o them. It's just way harder * to achieve. */ while (!cpumask_test_cpu(smp_processor_id(), cpu_active_mask)) cpu_relax(); /* enable local interrupts */ local_irq_enable(); The CPU being hot-plugged will be marked active after it has been fully initialized by the CPU managing the hot-plug. In the Xen PVHVM case xen_smp_intr_init() is called to set up the hot-plugged vCPU's XEN_RESCHEDULE_VECTOR. The hot-plugging CPU is marked online, not marked active and does not have its IPI vectors set up. rcu_implicit_offline_qs() sees the hot-plugging cpu is !cpu_is_offline() and tries to send it a reschedule IPI: This will lead to: kernel BUG at drivers/xen/events.c:1328! xen_send_IPI_one() xen_smp_send_reschedule() rcu_implicit_offline_qs() rcu_implicit_dynticks_qs() force_qs_rnp() force_quiescent_state() __rcu_process_callbacks() rcu_process_callbacks() __do_softirq() call_softirq() do_softirq() irq_exit() xen_evtchn_do_upcall() because xen_send_IPI_one() will attempt to use an uninitialized IRQ for the XEN_RESCHEDULE_VECTOR. There is at least one other place that has caused the same crash: xen_smp_send_reschedule() wake_up_idle_cpu() add_timer_on() clocksource_watchdog() call_timer_fn() run_timer_softirq() __do_softirq() call_softirq() do_softirq() irq_exit() xen_evtchn_do_upcall() xen_hvm_callback_vector() clocksource_watchdog() uses cpu_online_mask to pick the next CPU to handle a watchdog timer: /* * Cycle through CPUs to check if the CPUs stay synchronized * to each other. */ next_cpu = cpumask_next(raw_smp_processor_id(), cpu_online_mask); if (next_cpu >= nr_cpu_ids) next_cpu = cpumask_first(cpu_online_mask); watchdog_timer.expires += WATCHDOG_INTERVAL; add_timer_on(&watchdog_timer, next_cpu); This resulted in an attempt to send an IPI to a hot-plugging CPU that had not initialized its reschedule vector. One option would be to make the RCU code check to not check for CPU offline but for CPU active. As becoming active is done after a CPU is online (in older kernels). But Srivatsa pointed out that "the cpu_active vs cpu_online ordering has been completely reworked - in the online path, cpu_active is set *before* cpu_online, and also, in the cpu offline path, the cpu_active bit is reset in the CPU_DYING notification instead of CPU_DOWN_PREPARE." Drilling in this the bring-up path: "[brought up CPU].. send out a CPU_STARTING notification, and in response to that, the scheduler sets the CPU in the cpu_active_mask. Again, this mask is better left to the scheduler alone, since it has the intelligence to use it judiciously." The conclusion was that: " 1. At the IPI sender side: It is incorrect to send an IPI to an offline CPU (cpu not present in the cpu_online_mask). There are numerous places where we check this and warn/complain. 2. At the IPI receiver side: It is incorrect to let the world know of our presence (by setting ourselves in global bitmasks) until our initialization steps are complete to such an extent that we can handle the consequences (such as receiving interrupts without crashing the sender etc.) " (from Srivatsa) As the native code enables the interrupts at some point we need to be able to service them. In other words a CPU must have valid IPI vectors if it has been marked online. It doesn't need to handle the IPI (interrupts may be disabled) but needs to have valid IPI vectors because another CPU may find it in cpu_online_mask and attempt to send it an IPI. This patch will change the order of the Xen vCPU bring-up functions so that Xen vectors have been set up before start_secondary() is called. It also will not continue to bring up a Xen vCPU if xen_smp_intr_init() fails to initialize it. Orabug 13823853 Signed-off-by Chuck Anderson <chuck.anderson@oracle.com> Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-08-20x86/xen: do not identity map UNUSABLE regions in the machine E820David Vrabel
If there are UNUSABLE regions in the machine memory map, dom0 will attempt to map them 1:1 which is not permitted by Xen and the kernel will crash. There isn't anything interesting in the UNUSABLE region that the dom0 kernel needs access to so we can avoid making the 1:1 mapping and treat it as RAM. We only do this for dom0, as that is where tboot case shows up. A PV domU could have an UNUSABLE region in its pseudo-physical map and would need to be handled in another patch. This fixes a boot failure on hosts with tboot. tboot marks a region in the e820 map as unusable and the dom0 kernel would attempt to map this region and Xen does not permit unusable regions to be mapped by guests. (XEN) 0000000000000000 - 0000000000060000 (usable) (XEN) 0000000000060000 - 0000000000068000 (reserved) (XEN) 0000000000068000 - 000000000009e000 (usable) (XEN) 0000000000100000 - 0000000000800000 (usable) (XEN) 0000000000800000 - 0000000000972000 (unusable) tboot marked this region as unusable. (XEN) 0000000000972000 - 00000000cf200000 (usable) (XEN) 00000000cf200000 - 00000000cf38f000 (reserved) (XEN) 00000000cf38f000 - 00000000cf3ce000 (ACPI data) (XEN) 00000000cf3ce000 - 00000000d0000000 (reserved) (XEN) 00000000e0000000 - 00000000f0000000 (reserved) (XEN) 00000000fe000000 - 0000000100000000 (reserved) (XEN) 0000000100000000 - 0000000630000000 (usable) Signed-off-by: David Vrabel <david.vrabel@citrix.com> [v1: Altered the patch and description with domU's with UNUSABLE regions] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-08-20arm64: perf: fix event validation for software group leadersWill Deacon
This is a port of c95eb3184ea1 ("ARM: 7809/1: perf: fix event validation for software group leaders") to arm64, which fixes a panic in the arm64 perf backend found as a result of Vince's fuzzing tool. Cc: <stable@vger.kernel.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-08-20arm64: perf: fix array out of bounds access in armpmu_map_hw_event()Will Deacon
This is a port of d9f966357b14 ("ARM: 7810/1: perf: Fix array out of bounds access in armpmu_map_hw_event()") to arm64, which fixes an oops in the arm64 perf backend found as a result of Vince's fuzzing tool. Cc: <stable@vger.kernel.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-08-20Merge branch 'security-fixes' into fixesRussell King
2013-08-20ARM: 7816/1: CONFIG_KUSER_HELPERS: fix help textNicolas Pitre
Commit f6f91b0d9fd9 ("ARM: allow kuser helpers to be removed from the vector page") introduced some help text for the CONFIG_KUSER_HELPERS option which is rather contradictory. Let's fix that, and improve it a little. Cc: <stable@vger.kernel.org> Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-20ARM: 7815/1: kexec: offline non panic CPUs on Kdump panicVijaya Kumar K
In case of normal kexec kernel load, all cpu's are offlined before calling machine_kexec().But in case crash panic cpus are relaxed in machine_crash_nonpanic_core() SMP function but not offlined. When crash kernel is loaded with kexec and on panic trigger machine_kexec() checks for number of cpus online. If more than one cpu is online machine_kexec() fails to load with below error kexec: error: multiple CPUs still online In machine_crash_nonpanic_core() SMP function, offline CPU before cpu_relax Signed-off-by: Vijaya Kumar K <Vijaya.Kumar@caviumnetworks.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-20ARM: 7819/1: fiq: Cast the first argument of flush_icache_range()Fabio Estevam
Commit 2ba85e7af4 (ARM: Fix FIQ code on VIVT CPUs) causes the following build warning: arch/arm/kernel/fiq.c:92:3: warning: passing argument 1 of 'cpu_cache.coherent_kern_range' makes integer from pointer without a cast [enabled by default] Cast it as '(unsigned long)base' to avoid the warning. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-19ARM: davinci: nand: specify ecc strengthSekhar Nori
Starting with kernel v3.5, it is mandatory to specify ECC strength when using hardware ECC. Without this, kernel panics with a warning of the sort: Driver must set ecc.strength when using hardware ECC ------------[ cut here ]------------ kernel BUG at drivers/mtd/nand/nand_base.c:3519! Fix this by specifying ECC strength for the boards which were missing this. Reported-by: Holger Freyther <holger@freyther.de> Cc: <stable@vger.kernel.org> #v3.5+ Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-08-19Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Two AMD microcode loader fixes and an OLPC firmware support fix" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode, AMD: Fix early microcode loading x86, microcode, AMD: Make cpu_has_amd_erratum() use the correct struct cpuinfo_x86 x86: Don't clear olpc_ofw_header when sentinel is detected
2013-08-16s390: Fix broken buildGuenter Roeck
Fix this build error: In file included from fs/exec.c:61:0: arch/s390/include/asm/tlb.h:35:23: error: expected identifier or '(' before 'unsigned' arch/s390/include/asm/tlb.h:36:1: warning: no semicolon at end of struct or union [enabled by default] arch/s390/include/asm/tlb.h: In function 'tlb_gather_mmu': arch/s390/include/asm/tlb.h:57:5: error: 'struct mmu_gather' has no member named 'end' Broken due to commit 2b047252d0 ("Fix TLB gather virtual address range invalidation corner cases"). Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: stable@vger.kernel.org Signed-off-by: Guenter Roeck <linux@roeck-us.net> [ Oh well. We had build testing for ppc amd um, but no s390 - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-16Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "The usual collection of random fixes. Also some further fixes to the last set of security fixes, and some more from Will (which you may already have in a slightly different form)" * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7807/1: kexec: validate CPU hotplug support ARM: 7812/1: rwlocks: retry trylock operation if strex fails on free lock ARM: 7811/1: locks: use early clobber in arch_spin_trylock ARM: 7810/1: perf: Fix array out of bounds access in armpmu_map_hw_event() ARM: 7809/1: perf: fix event validation for software group leaders ARM: Fix FIQ code on VIVT CPUs ARM: Fix !kuser helpers case ARM: Fix the world famous typo with is_gate_vma()
2013-08-16Merge branch 'for-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k fixes from Geert Uytterhoeven: "These are two critical fixes, needed by distro kernels, and thus also destined for stable: - The do_div() commit fixes a crash in mounting btrfs volumes, which was a regression from 3.2, - The ARAnyM fix allows to have NatFeat drivers as loadable modules, which is needed for initrds" * 'for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Truncate base in do_div() m68k/atari: ARAnyM - Fix NatFeat module support
2013-08-16ARM: OMAP: rx51: change musb mode to OTGAaro Koskinen
Peripheral-only mode got broken in v3.11-rc1 because of unknown reasons. Change the mode to OTG, in practice that should work equally well even when/if the regression gets fixed. Note that the peripheral-only regression is a separate patch, this change is still correct as the role is handled by hardware. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-16ARM: OMAP2: fix musb usage for n8x0Daniel Mack
Commit b7e2e75a8c ("usb: gadget: drop unused USB_GADGET_MUSB_HDRC") dropped a config symbol that was unused by the musb core, but it turns out that board support code still had references to it. As the core now handles both dual role and host-only modes, we can just pass MUSB_OTG as mode from board files. Signed-off-by: Daniel Mack <zonque@gmail.com> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-16Fix TLB gather virtual address range invalidation corner casesLinus Torvalds
Ben Tebulin reported: "Since v3.7.2 on two independent machines a very specific Git repository fails in 9/10 cases on git-fsck due to an SHA1/memory failures. This only occurs on a very specific repository and can be reproduced stably on two independent laptops. Git mailing list ran out of ideas and for me this looks like some very exotic kernel issue" and bisected the failure to the backport of commit 53a59fc67f97 ("mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT"). That commit itself is not actually buggy, but what it does is to make it much more likely to hit the partial TLB invalidation case, since it introduces a new case in tlb_next_batch() that previously only ever happened when running out of memory. The real bug is that the TLB gather virtual memory range setup is subtly buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather: enable tlb flush range in generic mmu_gather"), and the range handling was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB range flushed when __tlb_remove_page() runs out of slots"), but that fix was not complete. The problem with the TLB gather virtual address range is that it isn't set up by the initial tlb_gather_mmu() initialization (which didn't get the TLB range information), but it is set up ad-hoc later by the functions that actually flush the TLB. And so any such case that forgot to update the TLB range entries would potentially miss TLB invalidates. Rather than try to figure out exactly which particular ad-hoc range setup was missing (I personally suspect it's the hugetlb case in zap_huge_pmd(), which didn't have the same logic as zap_pte_range() did), this patch just gets rid of the problem at the source: make the TLB range information available to tlb_gather_mmu(), and initialize it when initializing all the other tlb gather fields. This makes the patch larger, but conceptually much simpler. And the end result is much more understandable; even if you want to play games with partial ranges when invalidating the TLB contents in chunks, now the range information is always there, and anybody who doesn't want to bother with it won't introduce subtle bugs. Ben verified that this fixes his problem. Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com> Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au> Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-15Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesOlof Johansson
From Nicolas Ferre: Device tree related fixes: - USB host numbering for 9x5 which was preventing from using all ports - a missing UART (not USART) clock lookup table was preventing from using them on 9x5 - too large amount of memory was specified for 9n12ek * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: ARM: at91/DT: fix at91sam9n12ek memory node ARM: at91: add missing uart clocks DT entries ARM: at91/DT: at91sam9x5ek: fix USB host property to enable port C Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-14Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge a bunch of fixes from Andrew Morton. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: fs/proc/task_mmu.c: fix buffer overflow in add_page_map() arch: *: Kconfig: add "kernel/Kconfig.freezer" to "arch/*/Kconfig" ocfs2: fix null pointer dereference in ocfs2_dir_foreach_blk_id() x86 get_unmapped_area(): use proper mmap base for bottom-up direction ocfs2: fix NULL pointer dereference in ocfs2_duplicate_clusters_by_page ocfs2: Revert 40bd62e to avoid regression in extended allocation drivers/rtc/rtc-stmp3xxx.c: provide timeout for potentially endless loop polling a HW bit hugetlb: fix lockdep splat caused by pmd sharing aoe: adjust ref of head for compound page tails microblaze: fix clone syscall mm: save soft-dirty bits on file pages mm: save soft-dirty bits on swapped pages memcg: don't initialize kmem-cache destroying work for root caches
2013-08-14Merge tag 'amd_ucode_fixes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp into x86/urgent Pull AMD microcode fixes from Borislav Petkov: " Those are basically two fixes which correct the AMD early ucode loader from accessing cpu_data too early, i.e. before smp_store_cpu_info() has copied the boot_cpu_data ontop and overwritten an already empty structure (which we shouldn't access that early in the first place anyway). The second patch is kinda largish for that late in the game but it shouldn't be problematic because we're simply switching from using cpu_data to use the CPU family number directly and thus again, not use uninitialized cpu_data structure. " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-14m68k: Truncate base in do_div()Andreas Schwab
Explicitly truncate the second operand of do_div() to 32 bits to guard against bogus code calling it with a 64-bit divisor. [Thorsten] After upgrading from 3.2 to 3.10, mounting a btrfs volume fails with: btrfs: setting nodatacow, compression disabled btrfs: enabling auto recovery btrfs: disk space caching is enabled *** ZERO DIVIDE *** FORMAT=2 Current process id is 722 BAD KERNEL TRAP: 00000000 Modules linked in: evdev mac_hid ext4 crc16 jbd2 mbcache btrfs xor lzo_compress zlib_deflate raid6_pq crc32c libcrc32c PC: [<319535b2>] __btrfs_map_block+0x11c/0x119a [btrfs] SR: 2000 SP: 30c1fab4 a2: 30f0faf0 d0: 00000000 d1: 00001000 d2: 00000000 d3: 00000000 d4: 00010000 d5: 00000000 a0: 3085c72c a1: 3085c72c Process mount (pid: 722, task=30f0faf0) Frame format=2 instr addr=319535ae Stack from 30c1faec: 00000000 00000020 00000000 00001000 00000000 01401000 30253928 300ffc00 00a843ac 3026f640 00000000 00010000 0009e250 00d106c0 00011220 00000000 00001000 301c6830 0009e32a 000000ff 00000009 3085c72c 00000000 00000000 30c1fd14 00000000 00000020 00000000 30c1fd14 0009e26c 00000020 00000003 00000000 0009dd8a 300b0b6c 30253928 00a843ac 00001000 00000000 00000000 0000a008 3194e76a 30253928 00a843ac 00001000 00000000 00000000 00000002 Call Trace: [<00001000>] kernel_pg_dir+0x0/0x1000 [...] Code: 222e ff74 2a2e ff5c 2c2e ff60 4c45 1402 <2d40> ff64 2d41 ff68 2205 4c2e 1800 ff68 4c04 0800 2041 d1c0 2206 4c2e 1400 ff68 [Geert] As diagnosed by Andreas, fs/btrfs/volumes.c:__btrfs_map_block() calls do_div(stripe_nr, stripe_len); with stripe_len u64, while do_div() assumes the divisor is a 32-bit number. Due to the lack of truncation in the m68k-specific implementation of do_div(), the division is performed using the upper 32-bit word of stripe_len, which is zero. This was introduced by commit 53b381b3abeb86f12787a6c40fee9b2f71edc23b ("Btrfs: RAID5 and RAID6"), which changed the divisor from map->stripe_len (struct map_lookup.stripe_len is int) to a 64-bit temporary. Reported-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Tested-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: stable@vger.kernel.org
2013-08-14m68k/atari: ARAnyM - Fix NatFeat module supportGeert Uytterhoeven
As pointed out by Andreas Schwab, pointers passed to ARAnyM NatFeat calls should be physical addresses, not virtual addresses. Fortunately on Atari, physical and virtual kernel addresses are the same, as long as normal kernel memory is concerned, so this usually worked fine without conversion. But for modules, pointers to literal strings are located in vmalloc()ed memory. Depending on the version of ARAnyM, this causes the nf_get_id() call to just fail, or worse, crash ARAnyM itself with e.g. Gotcha! Illegal memory access. Atari PC = $968c This is a big issue for distro kernels, who want to have all drivers as loadable modules in an initrd. Add a wrapper for nf_get_id() that copies the literal to the stack to work around this issue. Reported-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: stable@vger.kernel.org
2013-08-14ARM: at91/DT: fix at91sam9n12ek memory nodeNicolas Ferre
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: stable <stable@vger.kernel.org> # 3.5+
2013-08-14ARM: at91: add missing uart clocks DT entriesBoris BREZILLON
Add clocks to clock lookup table for uart DT entries. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Tested-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-08-13arch: *: Kconfig: add "kernel/Kconfig.freezer" to "arch/*/Kconfig"Chen Gang
All architectures include "kernel/Kconfig.freezer" except three left, so let them include it too, or 'allmodconfig' will report error. The related errors: (with allmodconfig for openrisc): CC kernel/cgroup_freezer.o kernel/cgroup_freezer.c: In function 'freezer_css_online': kernel/cgroup_freezer.c:133:15: error: 'system_freezing_cnt' undeclared (first use in this function) kernel/cgroup_freezer.c:133:15: note: each undeclared identifier is reported only once for each function it appears in kernel/cgroup_freezer.c: In function 'freezer_css_offline': kernel/cgroup_freezer.c:157:15: error: 'system_freezing_cnt' undeclared (first use in this function) kernel/cgroup_freezer.c: In function 'freezer_attach': kernel/cgroup_freezer.c:200:4: error: implicit declaration of function 'freeze_task' kernel/cgroup_freezer.c: In function 'freezer_apply_state': kernel/cgroup_freezer.c:371:16: error: 'system_freezing_cnt' undeclared (first use in this function) Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13x86 get_unmapped_area(): use proper mmap base for bottom-up directionRadu Caragea
When the stack is set to unlimited, the bottomup direction is used for mmap-ings but the mmap_base is not used and thus effectively renders ASLR for mmapings along with PIE useless. Cc: Michel Lespinasse <walken@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Sendroiu <molecula2788@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13microblaze: fix clone syscallMichal Simek
Fix inadvertent breakage in the clone syscall ABI for Microblaze that was introduced in commit f3268edbe6fe ("microblaze: switch to generic fork/vfork/clone"). The Microblaze syscall ABI for clone takes the parent tid address in the 4th argument; the third argument slot is used for the stack size. The incorrectly-used CLONE_BACKWARDS type assigned parent tid to the 3rd slot. This commit restores the original ABI so that existing userspace libc code will work correctly. All kernel versions from v3.8-rc1 were affected. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13mm: save soft-dirty bits on file pagesCyrill Gorcunov
Andy reported that if file page get reclaimed we lose the soft-dirty bit if it was there, so save _PAGE_BIT_SOFT_DIRTY bit when page address get encoded into pte entry. Thus when #pf happens on such non-present pte we can restore it back. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13mm: save soft-dirty bits on swapped pagesCyrill Gorcunov
Andy Lutomirski reported that if a page with _PAGE_SOFT_DIRTY bit set get swapped out, the bit is getting lost and no longer available when pte read back. To resolve this we introduce _PTE_SWP_SOFT_DIRTY bit which is saved in pte entry for the page being swapped out. When such page is to be read back from a swap cache we check for bit presence and if it's there we clear it and restore the former _PAGE_SOFT_DIRTY bit back. One of the problem was to find a place in pte entry where we can save the _PTE_SWP_SOFT_DIRTY bit while page is in swap. The _PAGE_PSE was chosen for that, it doesn't intersect with swap entry format stored in pte. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Two small fixlets" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Add Haswell ULT model number used in Macbook Air and other systems perf/x86: Fix intel QPI uncore event definitions
2013-08-13perf/arm: Fix armpmu_map_hw_event()Stephen Boyd
Fix constraint check in armpmu_map_hw_event(). Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13Merge branch 'security-fixes' into fixesRussell King
2013-08-13ARM: 7807/1: kexec: validate CPU hotplug supportStephen Warren
Architectures should fully validate whether kexec is possible as part of machine_kexec_prepare(), so that user-space's kexec_load() operation can report any problems. Performing validation in machine_kexec() itself is too late, since it is not allowed to return. Prior to this patch, ARM's machine_kexec() was testing after-the-fact whether machine_kexec_prepare() was able to disable all but one CPU. Instead, modify machine_kexec_prepare() to validate all conditions necessary for machine_kexec_prepare()'s to succeed. BUG if the validation succeeded, yet disabling the CPUs didn't actually work. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-13ARM: 7812/1: rwlocks: retry trylock operation if strex fails on free lockWill Deacon
Commit 15e7e5c1ebf5 ("ARM: 7749/1: spinlock: retry trylock operation if strex fails on free lock") modifying our arch_spin_trylock to retry the acquisition if the lock appeared uncontended, but the strex failed. This patch does the same for rwlocks, which were missed by the original patch. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-13ARM: 7811/1: locks: use early clobber in arch_spin_trylockWill Deacon
The res variable is written before we've finished with the input operands (namely the lock address), so ensure that we mark it as `early clobber' to avoid unintended register sharing. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-13ARM: 7810/1: perf: Fix array out of bounds access in armpmu_map_hw_event()Stephen Boyd
Vince Weaver reports an oops in the ARM perf event code while running his perf_fuzzer tool on a pandaboard running v3.11-rc4. Unable to handle kernel paging request at virtual address 73fd14cc pgd = eca6c000 [73fd14cc] *pgd=00000000 Internal error: Oops: 5 [#1] SMP ARM Modules linked in: snd_soc_omap_hdmi omapdss snd_soc_omap_abe_twl6040 snd_soc_twl6040 snd_soc_omap snd_soc_omap_hdmi_card snd_soc_omap_mcpdm snd_soc_omap_mcbsp snd_soc_core snd_compress regmap_spi snd_pcm snd_page_alloc snd_timer snd soundcore CPU: 1 PID: 2790 Comm: perf_fuzzer Not tainted 3.11.0-rc4 #6 task: eddcab80 ti: ed892000 task.ti: ed892000 PC is at armpmu_map_event+0x20/0x88 LR is at armpmu_event_init+0x38/0x280 pc : [<c001c3e4>] lr : [<c001c17c>] psr: 60000013 sp : ed893e40 ip : ecececec fp : edfaec00 r10: 00000000 r9 : 00000000 r8 : ed8c3ac0 r7 : ed8c3b5c r6 : edfaec00 r5 : 00000000 r4 : 00000000 r3 : 000000ff r2 : c0496144 r1 : c049611c r0 : edfaec00 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user Control: 10c5387d Table: aca6c04a DAC: 00000015 Process perf_fuzzer (pid: 2790, stack limit = 0xed892240) Stack: (0xed893e40 to 0xed894000) 3e40: 00000800 c001c17c 00000002 c008a748 00000001 00000000 00000000 c00bf078 3e60: 00000000 edfaee50 00000000 00000000 00000000 edfaec00 ed8c3ac0 edfaec00 3e80: 00000000 c073ffac ed893f20 c00bf180 00000001 00000000 c00bf078 ed893f20 3ea0: 00000000 ed8c3ac0 00000000 00000000 00000000 c0cb0818 eddcab80 c00bf440 3ec0: ed893f20 00000000 eddcab80 eca76800 00000000 eca76800 00000000 00000000 3ee0: 00000000 ec984c80 eddcab80 c00bfe68 00000000 00000000 00000000 00000080 3f00: 00000000 ed892000 00000000 ed892030 00000004 ecc7e3c8 ecc7e3c8 00000000 3f20: 00000000 00000048 ecececec 00000000 00000000 00000000 00000000 00000000 3f40: 00000000 00000000 00297810 00000000 00000000 00000000 00000000 00000000 3f60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 3f80: 00000002 00000002 000103a4 00000002 0000016c c00128e8 ed892000 00000000 3fa0: 00090998 c0012700 00000002 000103a4 00090ab8 00000000 00000000 0000000f 3fc0: 00000002 000103a4 00000002 0000016c 00090ab0 00090ab8 000107a0 00090998 3fe0: bed92be0 bed92bd0 0000b785 b6e8f6d0 40000010 00090ab8 00000000 00000000 [<c001c3e4>] (armpmu_map_event+0x20/0x88) from [<c001c17c>] (armpmu_event_init+0x38/0x280) [<c001c17c>] (armpmu_event_init+0x38/0x280) from [<c00bf180>] (perf_init_event+0x108/0x180) [<c00bf180>] (perf_init_event+0x108/0x180) from [<c00bf440>] (perf_event_alloc+0x248/0x40c) [<c00bf440>] (perf_event_alloc+0x248/0x40c) from [<c00bfe68>] (SyS_perf_event_open+0x4f4/0x8fc) [<c00bfe68>] (SyS_perf_event_open+0x4f4/0x8fc) from [<c0012700>] (ret_fast_syscall+0x0/0x48) Code: 0a000005 e3540004 0a000016 e3540000 (0791010c) This is because event->attr.config in armpmu_event_init() contains a very large number copied directly from userspace and is never checked against the size of the array indexed in armpmu_map_hw_event(). Fix the problem by checking the value of config before indexing the array and rejecting invalid config values. Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-13ARM: 7809/1: perf: fix event validation for software group leadersWill Deacon
It is possible to construct an event group with a software event as a group leader and then subsequently add a hardware event to the group. This results in the event group being validated by adding all members of the group to a fake PMU and attempting to allocate each event on their respective PMU. Unfortunately, for software events wthout a corresponding arm_pmu, this results in a kernel crash attempting to dereference the ->get_event_idx function pointer. This patch fixes the problem by checking explicitly for software events and ignoring those in event validation (since they can always be scheduled). We will probably want to revisit this for 3.12, since the validation checks don't appear to work correctly when dealing with multiple hardware PMUs anyway. Cc: <stable@vger.kernel.org> Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-13sched: fix the theoretical signal_wake_up() vs schedule() raceOleg Nesterov
This is only theoretical, but after try_to_wake_up(p) was changed to check p->state under p->pi_lock the code like __set_current_state(TASK_INTERRUPTIBLE); schedule(); can miss a signal. This is the special case of wait-for-condition, it relies on try_to_wake_up/schedule interaction and thus it does not need mb() between __set_current_state() and if(signal_pending). However, this __set_current_state() can move into the critical section protected by rq->lock, now that try_to_wake_up() takes another lock we need to ensure that it can't be reordered with "if (signal_pending(current))" check inside that section. The patch is actually one-liner, it simply adds smp_wmb() before spin_lock_irq(rq->lock). This is what try_to_wake_up() already does by the same reason. We turn this wmb() into the new helper, smp_mb__before_spinlock(), for better documentation and to allow the architectures to change the default implementation. While at it, kill smp_mb__after_lock(), it has no callers. Perhaps we can also add smp_mb__before/after_spinunlock() for prepare_to_wait(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-12x86, microcode, AMD: Fix early microcode loadingTorsten Kaiser
load_microcode_amd() (and the helper it is using) should not have an cpu parameter. The microcode loading does not depend on the CPU wrt the patches loaded since they will end up in a global list for all CPUs anyway. The change from cpu to x86family in load_microcode_amd() now allows to drop the code messing with cpu_data(cpu) from collect_cpu_info_amd_early(), which is wrong anyway because at that point the per-cpu cpu_info is not yet setup (These values would later be overwritten by smp_store_boot_cpu_info() / smp_store_cpu_info()). Fold the rest of collect_cpu_info_amd_early() into load_ucode_amd_ap(), because its only used at one place and without the cpuinfo_x86 accesses it was not much left. Signed-off-by: Torsten Kaiser <just.for.lkml@googlemail.com> [ Fengguang: build fix ] Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> [ Boris: adapt it to current tree. ] Signed-off-by: Borislav Petkov <bp@suse.de>
2013-08-12x86, microcode, AMD: Make cpu_has_amd_erratum() use the correct struct ↵Torsten Kaiser
cpuinfo_x86 cpu_has_amd_erratum() is buggy, because it uses the per-cpu cpu_info before it is filled by smp_store_boot_cpu_info() / smp_store_cpu_info(). If early microcode loading is enabled its collect_cpu_info_amd_early() will fill ->x86 and so the fallback to boot_cpu_data is not used. But ->x86_vendor was not filled and is still X86_VENDOR_INTEL resulting in no errata fixes getting applied and my system hangs on boot. Using cpu_info in cpu_has_amd_erratum() is wrong anyway: its only caller init_amd() will have a struct cpuinfo_x86 as parameter and the set_cpu_bug() that is controlled by cpu_has_amd_erratum() also only uses that struct. So pass the struct cpuinfo_x86 from init_amd() to cpu_has_amd_erratum() and the broken fallback can be dropped. [ Boris: Drop WARN_ON() since we're called only from init_amd() ] Signed-off-by: Torsten Kaiser <just.for.lkml@googlemail.com> Signed-off-by: Borislav Petkov <bp@suse.de>
