path: root/arch
2014-07-08media: vi driver on Colibri T20 is working againWojciech Bieganski
This commit resolves an issue of non-working vi camera driver on Colibri T20 occured after a l4t-r16-r4 merge.
2014-05-09colibri t20/t30: add spi controller platform data for hw csMarcel Ziswiler
Add SPI controller platform data required for use of hardware chip selects. While at it pull-up SPI chip select pin due to NVIDIA's designers taking the term chip select a little too personal: they indeed only select a chip otherwise all the chip select pins are just left floating!
2014-05-09colibri t20/t30: clarify mcp2515 resetMarcel Ziswiler
The MCP2515 on the Colibri EvalBoard V3.1a actually uses regular system reset aka RESET_OUT# on SODIMM 87 to reset the MCP2515. Therefore clean-up resp. remove any MECS Tellurium legacy in that respect. While at it adjust copyright year, re-order some include, clean-up some struct spacing, re-order clocks and improve some comments.
2014-05-08media: enabled CSI mode in AS0260 camera driverWojciech Bieganski
2014-04-22media: added camera settings per decoderWojciech Bieganski
This commit adds settings such as: - values of horizontal/vertical active start, - enabling/disabling internal sync, to the private data of decoders: MAX9526, ADV7180, TVP5150, OV7670 and AS0260. The feature is available through *_tegra_camera_platform_data struct initialised in board-*.c files.
2014-04-04media: fixes in board-*.c files for Colibri T20/T30 and Apalis T30Wojciech Bieganski
This commit fixes the crash that occures while loading tegra_v4l2_camera module caused by its new features (private data per sensor). updated files: arch/arm/mach-tegra/board-apalis_t30.c arch/arm/mach-tegra/board-colibri_t20.c arch/arm/mach-tegra/board-colibri_t30.c
2014-04-04media: symbol tegra_powergate_partition now exportsWojciech Bieganski
This commit fixes the kernel compilation error with the lack of the export of tegra_powergate_partition symbol in arch/arm/mach-tegra/powergate.c
2014-03-31apalis_t30: ieee 1588 ptp supportMarcel Ziswiler
Enable IEEE 1588 precision time protocol (PTP) support.
2014-03-13added Aptina AS0260SOC driverWojciech Bieganski
2014-03-13OV7670 and TVP5150 drivers added, updated configsWojciech Bieganski
2014-03-12PCI: Disable Gen2 for Tegra20 and Tegra30Eric Brower
Tegra20 and Tegra30 do not support gen2 PCIe, so correct the register setting to disable it. Signed-off-by: Eric Brower <ebrower@nvidia.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Thierry Reding <treding@nvidia.com>
2014-03-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: drivers/media/video/tegra_v4l2_camera.c reverted to current driver supporting ACM rather than CSI2 drivers/media/video/videobuf2-dma-nvmap.c drivers/video/tegra/host/Makefile
2014-02-04apalis_t30: add Fusion touchscreen driverStefan Agner
Activate Fusion touchscreen driver. Use GPIO 5/6 as pen down/reset GPIO and provide a helper function to free the GPIO before the driver requests them.
2014-01-29colibri_t20/colibri_t30: use new platform data for fusion touchscreenStefan Agner
Fusion touchscreen driver now uses platform data to do GPIO initialization by itself. Make use of this by providing GPIO numbers instead of doing initialization in the board initialization.
2014-01-29video: tegra: kernel parameters to change RGB clock polarityStefan Agner
Allow to change clock polarity for RGB display output using the keywords outputen/pixclockpol/vsync and hsync. Add them right after the driver specification, use 0/1 to specifiy high/low polarity, e.g. video=tegrafb0:pixclockpol:1,800x480
2014-01-29video: tegra: remove special clocks for Tegra 2Stefan Agner
Remove special clocks for Tegra 2, but use backup clock source instead. This allows to run all common used resolution within the drivers -1/+9% allowed band for pixelclock exactness.
2014-01-22colibri_t20/colibri_t30/apalis_t30: remove TEGRA_FB_VGA definesStefan Agner
Remove TEGRA_FB_VGA defines and use VGA as default. Since initial mode is now configureable through kernel cmd line parameter, we don't need those compile time helpers.
2014-01-13colibri_t20: video: use new modedb based settingsStefan Agner
Use modedb to set mode on framebuffer/display controller for Tegra 20 based module Colibri T20 too.
2014-01-09tegra: video: parse multiple modedbsStefan Agner
In order to find a viable resolution we not only parse VESA mode, we also parse CEA (multimedia) modes and our own small modedb (for specific touch screens).
2014-01-09tegra: video: use correct return value for callbackStefan Agner
2014-01-09tegra: video: use new modedb based settingsStefan Agner
Use new modedb based framebuffer settings by defining default_mode in the display controllers platform data. Also impelmented the fallback logic to this default_mode in case no kernel cmd line parameter was set.
2014-01-07tegra: video: use modedb to specify framebuffer resolutionStefan Agner
Allow to specify framebufffer videomode using kernel command line parameters. NVIDIAs binary X driver later on picks up those settings and start X with current mode settings, if no EDID data are available.
2013-12-13colibri_t20: android: disable hw stat monMarcel Ziswiler
Disable hardware statistics monitor for AVP due to it completely hanging upon boot on certain Colibri T20 V1.2a modules.
2013-12-09colibri_t30/apalis_t30: enable STMPE ADC driverStefan Agner
Make use of the new STMPE ADC driver to expose the four free ADC channels on the STMPE811 to userspace.
2013-12-09tegra: pcie: use integer for root_bus_nrStefan Agner
The drivers internal root_bus_nr used to be u8 which lead to a wrong error detection in bus_to_port. Bus number can be -1 in case bus is not scanned yet. Thanks to James pointing that out.
2013-12-02colibri_t20/colibri_t30: don't register KEY_BACK for wakeupStefan Agner
The port used for KEY_BACK does not support wakeup (no wake PIN). Remove the wake flag, this prevents unbalanced irq warning messages.
2013-11-26apalis_t30: add gpio keyboard configurationStefan Agner
Add GPIO keyboard platform device configuration. Currently only the power key is defined which is registred as wake key as well in order to wake the SoC when in sleep mode (MXM3 37/WAKE1_MICO).
2013-11-22ARM: tegra: make SKU 0x81 same as 0xB1 for tegra3tegra-l4t-r16-16.4Shreshtha Sahu
SKU 0x81 is identical to 0xB1 so same can be used for sku to speedo ID conversion. Bug 1313434 Change-Id: I63f08522878524a05c2a6fb0a82fee90a59a99bd Signed-off-by: Shreshtha Sahu <ssahu@nvidia.com> Reviewed-on: http://git-master/r/334396 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-11-20colibri_t30/apalis_t30: remove vdd_hdmi_con regulatorStefan Agner
Remove vdd_hdmi_con regulator from dc1 since we don't have a dedicated regulator for this connector on our baseboards.
2013-11-19apalis_t30: use TPS6591X specific IRQ base for RTCStefan Agner
Use TPS6591X IRQ base define to calculate correct IRQ number.
2013-11-19colibri_t30: use TPS6591X specific IRQ baseStefan Agner
Use TPS6591X base defines to make sure the chip gets its own irq range rather than interfer with the STMPE chip.
2013-11-18Revert "media: camera config changes"Vikram Fugro
This reverts commit dd9a841da571a41d43f1eeaac1785b2adb1d80f3. The config changes (for V4L2) can be done manually as per need basis for V4L2, followed by compiling the kernel. Change-Id: I9174bce0f3da2974ab703b238dfb8fb3bbf607c5 Signed-off-by: Vikram Fugro <vfugro@nvidia.com> Reviewed-on: http://git-master/r/327607 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-10-30media: camera config changesVikram Fugro
- Disables TEGRA_CAMERA - Enables SOC_CAMERA and OV5640 sensor support Bug 1369083 Change-Id: I073c226e9f04a6f4f4699051f624a755dceb36cb Signed-off-by: Vikram Fugro <vfugro@nvidia.com> Reviewed-on: http://git-master/r/309491 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-10-22apalis_t30: clean-up gpio definitions and namesColibri_T30_LinuxImageV2.1Beta1_20131022Colibri_T20_LinuxImageV2.1Beta1_20131022Apalis_T30_LinuxImageV2.1Beta1_20131022Marcel Ziswiler
Clean-up GPIO definitions and names (e.g. use LVDS_ defines, BKL1_ON rather than BL_ON and HDMI1_HPD rather than hdmi_hpd).
2013-10-21colibri_t30: add DDR speed definition for 400MHz/800MHzMax Krummenacher
This gives the DDR3L memory settings for 400MHz/800MHz. The boot memory speed must be 400MHz for this to work, i.e. the 400MHz BCT must be used.
2013-10-21toradex defconfigs: don't set CONFIG_MAGIC_SYSRQMax Krummenacher
If the boot console is RS232 and RX is left floating this leads to arbitrary sys requests including reboots... (RX is left floating on the evaluation boards if USB to serial is jumpered but USB is not connected)
2013-10-16ARM: tegra: cardhu: enable OV5650/OV5640 sensorBryan Wu
Enable OV5650 and OV5640 sensor in Cardhu board file with the help of Tegra V4L2 SoC camera interface. To use V4L2 driver, we need to disable old camera HAL driver. Bug 1240806 Bug 1369083 Change-Id: I0dc529d44fba4d80b45690e384e8bf81b29f69e5 Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/246266 (cherry picked from commit 6b2f7cc4117208dc992478f27d5873ea38071fdc) Reviewed-on: http://git-master/r/279988 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Tested-by: Matthew Pedro <mapedro@nvidia.com>
2013-09-16ARM: tegra3: initialize pll_a during bootBibek Basu
Configure pll_a during boot so that locking to pll_a does not fail Bug 1330751 Change-Id: I188f0be211379f43770b24c5b382dec2788aefda Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/269469 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Kiran Adduri <kadduri@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Jong Kim <jongk@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2013-09-12ARM: tegra: beaver: updated DVFS tableBibek Basu
DVFS entry is fixed for Hynix_2GB_H5TC4G83MFR-PBA to support all emc frequencies. Bug 1218885 Change-Id: Id9d578499e495f43db1a072cbcee25a353fa78f5 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/210653 (cherry picked from commit 688bf04ff67e2c1ff22762f4f578b925ff3b9f3c) Reviewed-on: http://git-master/r/273530 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Kiran Adduri <kadduri@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Tested-by: Matthew Pedro <mapedro@nvidia.com>
2013-08-30apalis_t30: export Apalis GPIOs to userspace via sysfsMarcel Ziswiler
Up to now only the LVDS transceiver controlling GPIOs were exported. This patch adds the generic Apalis GPIOs to the list of via sysfs to userspace exported ones as well.
2013-08-30apalis/colibri_t30: fix HDMI hang issueMarcel Ziswiler
Initialisation of the framebuffer console on DVI-D aka HDMI sometimes failed. This was particularly bad on Apalis T30 where this is activated by default. On Colibri T30 this was observed when enabling it using the fbcon=map:1 boot argument. This fix curtsey of Bibek Basu from NVIDIA explicitly enables PLLA during early clock initialisation which avoids a later race with the display driver on DC1.
2013-08-12apalis/colibri_t30: hack to force speedo id of 2 for nowMarcel Ziswiler
In preparation for the new Apalis resp. Colibri T30 production lots with either T30IQS-P-A3 or T30MQS-P-A3 chips that due to some bug were locked at 312 MHz force a speedo ID of 2 for now which allows regular operation of up to 1.4 GHz (single core only).
2013-08-06config: tegra3: Turn off R8169 firmware loadingMursalin Akon
The firmware is not being in use currently. So, turn the loading code off. Bug 1236060 Bug 991551 Change-Id: Id41cf762b59502d0ece470e315ac75d93e3b6b39 Signed-off-by: Mursalin Akon <makon@nvidia.com> Reviewed-on: http://git-master/r/218613 (cherry picked from commit f15976bdfb32d6c5e20057f6d4d57646c15a5591) Reviewed-on: http://git-master/r/258354 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-07-31apalis_t30: allow for jumper-less ACM operationMarcel Ziswiler
Allow for jumper-less ACM operation by defaulting to 0x20 I2C address.
2013-07-31apalis_t30: enable modular camera configurationMarcel Ziswiler
Enable the modular camera configuration for ACM which allows switching not only decoders but also their inputs at run-time. This is the only correct order to load the modules: modprobe videobuf2-memops modprobe videobuf2-dma-nvmap modprobe max9526 # or modprobe adv7180 modprobe tegra_v4l2_camera To change the decoder on the fly: rmmod tegra_v4l2_camera rmmod max9526 # or rmmod adv7180 modprobe adv7180 # or modprobe max9526 modprobe tegra_v4l2_camera To get a pre-view window through gstreamer: gst-launch v4l2src ! deinterlace tff=1 method=4 ! nv_omx_videomixer ! nv_gl_eglimagesink To switch inputs (0-5 resp. 0-4 for ADV7180 and 0-2 for MAX9526 where 2 means auto selection): v4l2-ctl -i 0 v4l2-ctl -i 1 v4l2-ctl -i 2 v4l2-ctl -i 3 v4l2-ctl -i 4 v4l2-ctl -i 5 To check what input is active: v4l2-ctl -I While at it enable NVIDIA confirmed ARM errata 716044 and 720789 as well.
2013-07-31colibri_t20: also define COLIBRI_T20_VI when VIDEO_TEGRA is a kernel modulePeter Gielda
2013-07-31colibri_t30: also define COLIBRI_T30_VI when VIDEO_TEGRA is a kernel module.Peter Gielda
2013-07-16apalis_t30: fix build without SATA supportMarcel Ziswiler
This patch fixes building without CONFIG_SATA_AHCI_TEGRA aka SATA support which previously failed as follows: ... CC arch/arm/mach-tegra/board-apalis_t30.o ~/linux-toradex/arch/arm/mach-tegra/board-apalis_t30.c:571:31: error: 'apalis_led_gpio_device' defined but not used [-Werror=unused-variable] cc1: all warnings being treated as errors make[2]: *** [arch/arm/mach-tegra/board-apalis_t30.o] Error 1 make[1]: *** [arch/arm/mach-tegra] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [sub-make] Error 2
2013-06-24colibri_t30: set local critical temperatur to 95°CMax Krummenacher
If the local critical temperature is reached the power is unconditionally switched off. At 70°C ambient the default of 85°C can be reached. So increase the limit in the hwmon chip to 95°C.
2013-06-24apalis_t30: set local critical temperatur to 95°CMax Krummenacher
