path: root/arch
2017-01-06arm/xen: Use alloc_percpu rather than __alloc_percpuJulien Grall
commit 24d5373dda7c00a438d26016bce140299fae675e upstream. The function xen_guest_init is using __alloc_percpu with an alignment which are not power of two. However, the percpu allocator never supported alignments which are not power of two and has always behaved incorectly in thise case. Commit 3ca45a4 "percpu: ensure requested alignment is power of two" introduced a check which trigger a warning [1] when booting linux-next on Xen. But in reality this bug was always present. This can be fixed by replacing the call to __alloc_percpu with alloc_percpu. The latter will use an alignment which are a power of two. [1] [ 0.023921] illegal size (48) or align (48) for percpu allocation [ 0.024167] ------------[ cut here ]------------ [ 0.024344] WARNING: CPU: 0 PID: 1 at linux/mm/percpu.c:892 pcpu_alloc+0x88/0x6c0 [ 0.024584] Modules linked in: [ 0.024708] [ 0.024804] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.0-rc7-next-20161128 #473 [ 0.025012] Hardware name: Foundation-v8A (DT) [ 0.025162] task: ffff80003d870000 task.stack: ffff80003d844000 [ 0.025351] PC is at pcpu_alloc+0x88/0x6c0 [ 0.025490] LR is at pcpu_alloc+0x88/0x6c0 [ 0.025624] pc : [<ffff00000818e678>] lr : [<ffff00000818e678>] pstate: 60000045 [ 0.025830] sp : ffff80003d847cd0 [ 0.025946] x29: ffff80003d847cd0 x28: 0000000000000000 [ 0.026147] x27: 0000000000000000 x26: 0000000000000000 [ 0.026348] x25: 0000000000000000 x24: 0000000000000000 [ 0.026549] x23: 0000000000000000 x22: 00000000024000c0 [ 0.026752] x21: ffff000008e97000 x20: 0000000000000000 [ 0.026953] x19: 0000000000000030 x18: 0000000000000010 [ 0.027155] x17: 0000000000000a3f x16: 00000000deadbeef [ 0.027357] x15: 0000000000000006 x14: ffff000088f79c3f [ 0.027573] x13: ffff000008f79c4d x12: 0000000000000041 [ 0.027782] x11: 0000000000000006 x10: 0000000000000042 [ 0.027995] x9 : ffff80003d847a40 x8 : 6f697461636f6c6c [ 0.028208] x7 : 6120757063726570 x6 : ffff000008f79c84 [ 0.028419] x5 : 0000000000000005 x4 : 0000000000000000 [ 0.028628] x3 : 0000000000000000 x2 : 000000000000017f [ 0.028840] x1 : ffff80003d870000 x0 : 0000000000000035 [ 0.029056] [ 0.029152] ---[ end trace 0000000000000000 ]--- [ 0.029297] Call trace: [ 0.029403] Exception stack(0xffff80003d847b00 to 0xffff80003d847c30) [ 0.029621] 7b00: 0000000000000030 0001000000000000 ffff80003d847cd0 ffff00000818e678 [ 0.029901] 7b20: 0000000000000002 0000000000000004 ffff000008f7c060 0000000000000035 [ 0.030153] 7b40: ffff000008f79000 ffff000008c4cd88 ffff80003d847bf0 ffff000008101778 [ 0.030402] 7b60: 0000000000000030 0000000000000000 ffff000008e97000 00000000024000c0 [ 0.030647] 7b80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000 [ 0.030895] 7ba0: 0000000000000035 ffff80003d870000 000000000000017f 0000000000000000 [ 0.031144] 7bc0: 0000000000000000 0000000000000005 ffff000008f79c84 6120757063726570 [ 0.031394] 7be0: 6f697461636f6c6c ffff80003d847a40 0000000000000042 0000000000000006 [ 0.031643] 7c00: 0000000000000041 ffff000008f79c4d ffff000088f79c3f 0000000000000006 [ 0.031877] 7c20: 00000000deadbeef 0000000000000a3f [ 0.032051] [<ffff00000818e678>] pcpu_alloc+0x88/0x6c0 [ 0.032229] [<ffff00000818ece8>] __alloc_percpu+0x18/0x20 [ 0.032409] [<ffff000008d9606c>] xen_guest_init+0x174/0x2f4 [ 0.032591] [<ffff0000080830f8>] do_one_initcall+0x38/0x130 [ 0.032783] [<ffff000008d90c34>] kernel_init_freeable+0xe0/0x248 [ 0.032995] [<ffff00000899a890>] kernel_init+0x10/0x100 [ 0.033172] [<ffff000008082ec0>] ret_from_fork+0x10/0x50 Reported-by: Wei Chen <wei.chen@arm.com> Link: https://lkml.org/lkml/2016/11/28/669 Signed-off-by: Julien Grall <julien.grall@arm.com> Signed-off-by: Stefano Stabellini <sstabellini@kernel.org> Reviewed-by: Stefano Stabellini <sstabellini@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15m68k: Fix ndelay() macroBoris Brezillon
commit 7e251bb21ae08ca2e4fb28cc0981fac2685a8efa upstream. The current ndelay() macro definition has an extra semi-colon at the end of the line thus leading to a compilation error when ndelay is used in a conditional block without curly braces like this one: if (cond) ndelay(t); else ... which, after the preprocessor pass gives: if (cond) m68k_ndelay(t);; else ... thus leading to the following gcc error: error: 'else' without a previous 'if' Remove this extra semi-colon. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Fixes: c8ee038bd1488 ("m68k: Implement ndelay() based on the existing udelay() logic") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15arm64: futex.h: Add missing PAN togglingJames Morse
commit 811d61e384e24759372bb3f01772f3744b0a8327 upstream. futex.h's futex_atomic_cmpxchg_inatomic() does not use the __futex_atomic_op() macro and needs its own PAN toggling. This was missed when the feature was implemented. Fixes: 338d4f49d6f ("arm64: kernel: Add support for Privileged Access Never") Signed-off-by: James Morse <james.morse@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Mian Yousaf Kaukab <yousaf.kaukab@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15perf/x86: Fix full width counter, counter overflowPeter Zijlstra (Intel)
commit 7f612a7f0bc13a2361a152862435b7941156b6af upstream. Lukasz reported that perf stat counters overflow handling is broken on KNL/SLM. Both these parts have full_width_write set, and that does indeed have a problem. In order to deal with counter wrap, we must sample the counter at at least half the counter period (see also the sampling theorem) such that we can unambiguously reconstruct the count. However commit: 069e0c3c4058 ("perf/x86/intel: Support full width counting") sets the sampling interval to the full period, not half. Fixing that exposes another issue, in that we must not sign extend the delta value when we shift it right; the counter cannot have decremented after all. With both these issues fixed, counter overflow functions correctly again. Reported-by: Lukasz Odzioba <lukasz.odzioba@intel.com> Tested-by: Liang, Kan <kan.liang@intel.com> Tested-by: Odzioba, Lukasz <lukasz.odzioba@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Fixes: 069e0c3c4058 ("perf/x86/intel: Support full width counting") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15parisc: Fix TLB related boot crash on SMP machinesHelge Deller
commit 24d0492b7d5d321a9c5846c8c974eba9823ffaa0 upstream. At bootup we run measurements to calculate the best threshold for when we should be using full TLB flushes instead of just flushing a specific amount of TLB entries. This performance test is run over the kernel text segment. But running this TLB performance test on the kernel text segment turned out to crash some SMP machines when the kernel text pages were mapped as huge pages. To avoid those crashes this patch simply skips this test on some SMP machines and calculates an optimal threshold based on the maximum number of available TLB entries and number of online CPUs. On a technical side, this seems to happen: The TLB measurement code uses flush_tlb_kernel_range() to flush specific TLB entries with a page size of 4k (pdtlb 0(sr1,addr)). On UP systems this purge instruction seems to work without problems even if the pages were mapped as huge pages. But on SMP systems the TLB purge instruction is broadcasted to other CPUs. Those CPUs then crash the machine because the page size is not as expected. C8000 machines with PA8800/PA8900 CPUs were not affected by this problem, because the required cache coherency prohibits to use huge pages at all. Sadly I didn't found any documentation about this behaviour, so this finding is purely based on testing with phyiscal SMP machines (A500-44 and J5000, both were 2-way boxes). Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15parisc: Remove unnecessary TLB purges from flush_dcache_page_asm and ↵John David Anglin
flush_icache_page_asm commit febe42964fe182281859b3d43d844bb25ca49367 upstream. We have four routines in pacache.S that use temporary alias pages: copy_user_page_asm(), clear_user_page_asm(), flush_dcache_page_asm() and flush_icache_page_asm(). copy_user_page_asm() and clear_user_page_asm() don't purge the TLB entry used for the operation. flush_dcache_page_asm() and flush_icache_page_asm do purge the entry. Presumably, this was thought to optimize TLB use. However, the operation is quite heavy weight on PA 1.X processors as we need to take the TLB lock and a TLB broadcast is sent to all processors. This patch removes the purges from flush_dcache_page_asm() and flush_icache_page_asm. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15parisc: Purge TLB before setting PTEJohn David Anglin
commit c78e710c1c9fbeff43dddc0aa3d0ff458e70b0cc upstream. The attached change interchanges the order of purging the TLB and setting the corresponding page table entry. TLB purges are strongly ordered. It occurred to me one night that setting the PTE first might have subtle ordering issues on SMP machines and cause random memory corruption. A TLB lock guards the insertion of user TLB entries. So after the TLB is purged, a new entry can't be inserted until the lock is released. This ensures that the new PTE value is used when the lock is released. Since making this change, no random segmentation faults have been observed on the Debian hppa buildd servers. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15powerpc/eeh: Fix deadlock when PE frozen state can't be clearedAndrew Donnellan
commit 409bf7f8a02ef88db5a0f2cdcf9489914f4b8508 upstream. In eeh_reset_device(), we take the pci_rescan_remove_lock immediately after after we call eeh_reset_pe() to reset the PCI controller. We then call eeh_clear_pe_frozen_state(), which can return an error. In this case, we bail out of eeh_reset_device() without calling pci_unlock_rescan_remove(). Add a call to pci_unlock_rescan_remove() in the eeh_clear_pe_frozen_state() error path so that we don't cause a deadlock later on. Reported-by: Pradipta Ghosh <pradghos@in.ibm.com> Fixes: 78954700631f ("powerpc/eeh: Avoid I/O access during PE reset") Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com> Acked-by: Russell Currey <ruscur@russell.cc> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-10sparc64: fix compile warning section mismatch in find_node()Thomas Tai
[ Upstream commit 87a349f9cc0908bc0cfac0c9ece3179f650ae95a ] A compile warning is introduced by a commit to fix the find_node(). This patch fix the compile warning by moving find_node() into __init section. Because find_node() is only used by memblock_nid_range() which is only used by a __init add_node_ranges(). find_node() and memblock_nid_range() should also be inside __init section. Signed-off-by: Thomas Tai <thomas.tai@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-10sparc64: Fix find_node warning if numa node cannot be foundThomas Tai
[ Upstream commit 74a5ed5c4f692df2ff0a2313ea71e81243525519 ] When booting up LDOM, find_node() warns that a physical address doesn't match a NUMA node. WARNING: CPU: 0 PID: 0 at arch/sparc/mm/init_64.c:835 find_node+0xf4/0x120 find_node: A physical address doesn't match a NUMA node rule. Some physical memory will be owned by node 0.Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 4.9.0-rc3 #4 Call Trace: [0000000000468ba0] __warn+0xc0/0xe0 [0000000000468c74] warn_slowpath_fmt+0x34/0x60 [00000000004592f4] find_node+0xf4/0x120 [0000000000dd0774] add_node_ranges+0x38/0xe4 [0000000000dd0b1c] numa_parse_mdesc+0x268/0x2e4 [0000000000dd0e9c] bootmem_init+0xb8/0x160 [0000000000dd174c] paging_init+0x808/0x8fc [0000000000dcb0d0] setup_arch+0x2c8/0x2f0 [0000000000dc68a0] start_kernel+0x48/0x424 [0000000000dcb374] start_early_boot+0x27c/0x28c [0000000000a32c08] tlb_fixup_done+0x4c/0x64 [0000000000027f08] 0x27f08 It is because linux use an internal structure node_masks[] to keep the best memory latency node only. However, LDOM mdesc can contain single latency-group with multiple memory latency nodes. If the address doesn't match the best latency node within node_masks[], it should check for an alternative via mdesc. The warning message should only be printed if the address doesn't match any node_masks[] nor within mdesc. To minimize the impact of searching mdesc every time, the last matched mask and index is stored in a variable. Signed-off-by: Thomas Tai <thomas.tai@oracle.com> Reviewed-by: Chris Hyser <chris.hyser@oracle.com> Reviewed-by: Liam Merwick <liam.merwick@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-10sparc32: Fix inverted invalid_frame_pointer checks on sigreturnsAndreas Larsson
[ Upstream commit 07b5ab3f71d318e52c18cc3b73c1d44c908aacfa ] Signed-off-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-08arm64: suspend: Reconfigure PSTATE after resume from idleJames Morse
commit d08544127d9fb4505635e3cb6871fd50a42947bd upstream. The suspend/resume path in kernel/sleep.S, as used by cpu-idle, does not save/restore PSTATE. As a result of this cpufeatures that were detected and have bits in PSTATE get lost when we resume from idle. UAO gets set appropriately on the next context switch. PAN will be re-enabled next time we return from user-space, but on a preemptible kernel we may run work accessing user space before this point. Add code to re-enable theses two features in __cpu_suspend_exit(). We re-use uao_thread_switch() passing current. Signed-off-by: James Morse <james.morse@arm.com> Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> [Removed UAO hooks and commit-message references: this feature is not present in v4.4] Signed-off-by: James Morse <james.morse@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-08arm64: mm: Set PSTATE.PAN from the cpu_enable_pan() callJames Morse
commit 7209c868600bd8926e37c10b9aae83124ccc1dd8 upstream. Commit 338d4f49d6f7 ("arm64: kernel: Add support for Privileged Access Never") enabled PAN by enabling the 'SPAN' feature-bit in SCTLR_EL1. This means the PSTATE.PAN bit won't be set until the next return to the kernel from userspace. On a preemptible kernel we may schedule work that accesses userspace on a CPU before it has done this. Now that cpufeature enable() calls are scheduled via stop_machine(), we can set PSTATE.PAN from the cpu_enable_pan() call. Add WARN_ON_ONCE(in_interrupt()) to check the PSTATE value we updated is not immediately discarded. Reported-by: Tony Thompson <anthony.thompson@arm.com> Reported-by: Vladimir Murzin <vladimir.murzin@arm.com> Signed-off-by: James Morse <james.morse@arm.com> [will: fixed typo in comment] Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-08arm64: cpufeature: Schedule enable() calls instead of calling them via IPIJames Morse
commit 2a6dcb2b5f3e21592ca8dfa198dcce7bec09b020 upstream. The enable() call for a cpufeature/errata is called using on_each_cpu(). This issues a cross-call IPI to get the work done. Implicitly, this stashes the running PSTATE in SPSR when the CPU receives the IPI, and restores it when we return. This means an enable() call can never modify PSTATE. To allow PAN to do this, change the on_each_cpu() call to use stop_machine(). This schedules the work on each CPU which allows us to modify PSTATE. This involves changing the protype of all the enable() functions. enable_cpu_capabilities() is called during boot and enables the feature on all online CPUs. This path now uses stop_machine(). CPU features for hotplug'd CPUs are enabled by verify_local_cpu_features() which only acts on the local CPU, and can already modify the running PSTATE as it is called from secondary_start_kernel(). Reported-by: Tony Thompson <anthony.thompson@arm.com> Reported-by: Vladimir Murzin <vladimir.murzin@arm.com> Signed-off-by: James Morse <james.morse@arm.com> Cc: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> [Removed enable() hunks for features/errata v4.4. doesn't have. Changed caps->enable arg in enable_cpu_capabilities()] Signed-off-by: James Morse <james.morse@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-08x86/traps: Ignore high word of regs->cs in early_fixup_exception()Andy Lutomirski
commit fc0e81b2bea0ebceb71889b61d2240856141c9ee upstream. On the 80486 DX, it seems that some exceptions may leave garbage in the high bits of CS. This causes sporadic failures in which early_fixup_exception() refuses to fix up an exception. As far as I can tell, this has been buggy for a long time, but the problem seems to have been exacerbated by commits: 1e02ce4cccdc ("x86: Store a per-cpu shadow copy of CR4") e1bfc11c5a6f ("x86/init: Fix cr4_init_shadow() on CR4-less machines") This appears to have broken for as long as we've had early exception handling. [ This backport should apply to kernels from 3.4 - 4.5. ] Fixes: 4c5023a3fa2e ("x86-32: Handle exception table entries during early boot") Cc: H. Peter Anvin <hpa@zytor.com> Reported-by: Matthew Whitehead <tedheadster@gmail.com> Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-08ARC: Don't use "+l" inline asm constraintVineet Gupta
commit 3c7c7a2fc8811bc7097479f69acf2527693d7562 upstream. Apparenty this is coming in the way of gcc fix which inhibits the usage of LP_COUNT as a gpr. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-02parisc: Also flush data TLB in flush_icache_page_asmJohn David Anglin
commit 5035b230e7b67ac12691ed3b5495bbb617027b68 upstream. This is the second issue I noticed in reviewing the parisc TLB code. The fic instruction may use either the instruction or data TLB in flushing the instruction cache. Thus, on machines with a split TLB, we should also flush the data TLB after setting up the temporary alias registers. Although this has no functional impact, I changed the pdtlb and pitlb instructions to consistently use the index register %r0. These instructions do not support integer displacements. Tested on rp3440 and c8000. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-02parisc: Fix race in pci-dma.cJohn David Anglin
commit c0452fb9fb8f49c7d68ab9fa0ad092016be7b45f upstream. We are still troubled by occasional random segmentation faults and memory memory corruption on SMP machines. The causes quite a few package builds to fail on the Debian buildd machines for parisc. When gcc-6 failed to build three times in a row, I looked again at the TLB related code. I found a couple of issues. This is the first. In general, we need to ensure page table updates and corresponding TLB purges are atomic. The attached patch fixes an instance in pci-dma.c where the page table update was not guarded by the TLB lock. Tested on rp3440 and c8000. So far, no further random segmentation faults have been observed. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-02parisc: Fix races in parisc_setup_cache_timing()John David Anglin
commit 741dc7bf1c7c7d93b853bb55efe77baa27e1b0a9 upstream. Helge reported to me the following startup crash: [ 0.000000] Linux version 4.8.0-1-parisc64-smp (debian-kernel@lists.debian.org) (gcc version 5.4.1 20161019 (GCC) ) #1 SMP Debian 4.8.7-1 (2016-11-13) [ 0.000000] The 64-bit Kernel has started... [ 0.000000] Kernel default page size is 4 KB. Huge pages enabled with 1 MB physical and 2 MB virtual size. [ 0.000000] Determining PDC firmware type: System Map. [ 0.000000] model 9000/785/J5000 [ 0.000000] Total Memory: 2048 MB [ 0.000000] Memory: 2018528K/2097152K available (9272K kernel code, 3053K rwdata, 1319K rodata, 1024K init, 840K bss, 78624K reserved, 0K cma-reserved) [ 0.000000] virtual kernel memory layout: [ 0.000000] vmalloc : 0x0000000000008000 - 0x000000003f000000 (1007 MB) [ 0.000000] memory : 0x0000000040000000 - 0x00000000c0000000 (2048 MB) [ 0.000000] .init : 0x0000000040100000 - 0x0000000040200000 (1024 kB) [ 0.000000] .data : 0x0000000040b0e000 - 0x0000000040f533e0 (4372 kB) [ 0.000000] .text : 0x0000000040200000 - 0x0000000040b0e000 (9272 kB) [ 0.768910] Brought up 1 CPUs [ 0.992465] NET: Registered protocol family 16 [ 2.429981] Releasing cpu 1 now, hpa=fffffffffffa2000 [ 2.635751] CPU(s): 2 out of 2 PA8500 (PCX-W) at 440.000000 MHz online [ 2.726692] Setting cache flush threshold to 1024 kB [ 2.729932] Not-handled unaligned insn 0x43ffff80 [ 2.798114] Setting TLB flush threshold to 140 kB [ 2.928039] Unaligned handler failed, ret = -1 [ 3.000419] _______________________________ [ 3.000419] < Your System ate a SPARC! Gah! > [ 3.000419] ------------------------------- [ 3.000419] \ ^__^ [ 3.000419] (__)\ )\/\ [ 3.000419] U ||----w | [ 3.000419] || || [ 9.340055] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.8.0-1-parisc64-smp #1 Debian 4.8.7-1 [ 9.448082] task: 00000000bfd48060 task.stack: 00000000bfd50000 [ 9.528040] [ 10.760029] IASQ: 0000000000000000 0000000000000000 IAOQ: 000000004025d154 000000004025d158 [ 10.868052] IIR: 43ffff80 ISR: 0000000000340000 IOR: 000001ff54150960 [ 10.960029] CPU: 1 CR30: 00000000bfd50000 CR31: 0000000011111111 [ 11.052057] ORIG_R28: 000000004021e3b4 [ 11.100045] IAOQ[0]: irq_exit+0x94/0x120 [ 11.152062] IAOQ[1]: irq_exit+0x98/0x120 [ 11.208031] RP(r2): irq_exit+0xb8/0x120 [ 11.256074] Backtrace: [ 11.288067] [<00000000402cd944>] cpu_startup_entry+0x1e4/0x598 [ 11.368058] [<0000000040109528>] smp_callin+0x2c0/0x2f0 [ 11.436308] [<00000000402b53fc>] update_curr+0x18c/0x2d0 [ 11.508055] [<00000000402b73b8>] dequeue_entity+0x2c0/0x1030 [ 11.584040] [<00000000402b3cc0>] set_next_entity+0x80/0xd30 [ 11.660069] [<00000000402c1594>] pick_next_task_fair+0x614/0x720 [ 11.740085] [<000000004020dd34>] __schedule+0x394/0xa60 [ 11.808054] [<000000004020e488>] schedule+0x88/0x118 [ 11.876039] [<0000000040283d3c>] rescuer_thread+0x4d4/0x5b0 [ 11.948090] [<000000004028fc4c>] kthread+0x1ec/0x248 [ 12.016053] [<0000000040205020>] end_fault_vector+0x20/0xc0 [ 12.092239] [<00000000402050c0>] _switch_to_ret+0x0/0xf40 [ 12.164044] [ 12.184036] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.8.0-1-parisc64-smp #1 Debian 4.8.7-1 [ 12.244040] Backtrace: [ 12.244040] [<000000004021c480>] show_stack+0x68/0x80 [ 12.244040] [<00000000406f332c>] dump_stack+0xec/0x168 [ 12.244040] [<000000004021c74c>] die_if_kernel+0x25c/0x430 [ 12.244040] [<000000004022d320>] handle_unaligned+0xb48/0xb50 [ 12.244040] [ 12.632066] ---[ end trace 9ca05a7215c7bbb2 ]--- [ 12.692036] Kernel panic - not syncing: Attempted to kill the idle task! We have the insn 0x43ffff80 in IIR but from IAOQ we should have: 4025d150: 0f f3 20 df ldd,s r19(r31),r31 4025d154: 0f 9f 00 9c ldw r31(ret0),ret0 4025d158: bf 80 20 58 cmpb,*<> r0,ret0,4025d18c <irq_exit+0xcc> Cpu0 has just completed running parisc_setup_cache_timing: [ 2.429981] Releasing cpu 1 now, hpa=fffffffffffa2000 [ 2.635751] CPU(s): 2 out of 2 PA8500 (PCX-W) at 440.000000 MHz online [ 2.726692] Setting cache flush threshold to 1024 kB [ 2.729932] Not-handled unaligned insn 0x43ffff80 [ 2.798114] Setting TLB flush threshold to 140 kB [ 2.928039] Unaligned handler failed, ret = -1 From the backtrace, cpu1 is in smp_callin: void __init smp_callin(void) { int slave_id = cpu_now_booting; smp_cpu_init(slave_id); preempt_disable(); flush_cache_all_local(); /* start with known state */ flush_tlb_all_local(NULL); local_irq_enable(); /* Interrupts have been off until now */ cpu_startup_entry(CPUHP_AP_ONLINE_IDLE); So, it has just flushed its caches and the TLB. It would seem either the flushes in parisc_setup_cache_timing or smp_callin have corrupted kernel memory. The attached patch reworks parisc_setup_cache_timing to remove the races in setting the cache and TLB flush thresholds. It also corrects the number of bytes flushed in the TLB calculation. The patch flushes the cache and TLB on cpu0 before starting the secondary processors so that they are started from a known state. Tested with a few reboots on c8000. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-02tile: avoid using clocksource_cyc2ns with absolute cycle countChris Metcalf
commit e658a6f14d7c0243205f035979d0ecf6c12a036f upstream. For large values of "mult" and long uptimes, the intermediate result of "cycles * mult" can overflow 64 bits. For example, the tile platform calls clocksource_cyc2ns with a 1.2 GHz clock; we have mult = 853, and after 208.5 days, we overflow 64 bits. Since clocksource_cyc2ns() is intended to be used for relative cycle counts, not absolute cycle counts, performance is more importance than accepting a wider range of cycle values. So, just use mult_frac() directly in tile's sched_clock(). Commit 4cecf6d401a0 ("sched, x86: Avoid unnecessary overflow in sched_clock") by Salman Qazi results in essentially the same generated code for x86 as this change does for tile. In fact, a follow-on change by Salman introduced mult_frac() and switched to using it, so the C code was largely identical at that point too. Peter Zijlstra then added mul_u64_u32_shr() and switched x86 to use it. This is, in principle, better; by optimizing the 64x64->64 multiplies to be 32x32->64 multiplies we can potentially save some time. However, the compiler piplines the 64x64->64 multiplies pretty well, and the conditional branch in the generic mul_u64_u32_shr() causes some bubbles in execution, with the result that it's pretty much a wash. If tilegx provided its own implementation of mul_u64_u32_shr() without the conditional branch, we could potentially save 3 cycles, but that seems like small gain for a fair amount of additional build scaffolding; no other platform currently provides a mul_u64_u32_shr() override, and tile doesn't currently have an <asm/div64.h> header to put the override in. Additionally, gcc currently has an optimization bug that prevents it from recognizing the opportunity to use a 32x32->64 multiply, and so the result would be no better than the existing mult_frac() until such time as the compiler is fixed. For now, just using mult_frac() seems like the right answer. Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-02KVM: x86: check for pic and ioapic presence before useRadim Krčmář
commit df492896e6dfb44fd1154f5402428d8e52705081 upstream. Split irqchip allows pic and ioapic routes to be used without them being created, which results in NULL access. Check for NULL and avoid it. (The setup is too racy for a nicer solutions.) Found by syzkaller: general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC KASAN Dumping ftrace buffer: (ftrace buffer empty) Modules linked in: CPU: 3 PID: 11923 Comm: kworker/3:2 Not tainted 4.9.0-rc5+ #27 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Workqueue: events irqfd_inject task: ffff88006a06c7c0 task.stack: ffff880068638000 RIP: 0010:[...] [...] __lock_acquire+0xb35/0x3380 kernel/locking/lockdep.c:3221 RSP: 0000:ffff88006863ea20 EFLAGS: 00010006 RAX: dffffc0000000000 RBX: dffffc0000000000 RCX: 0000000000000000 RDX: 0000000000000039 RSI: 0000000000000000 RDI: 1ffff1000d0c7d9e RBP: ffff88006863ef58 R08: 0000000000000001 R09: 0000000000000000 R10: 00000000000001c8 R11: 0000000000000000 R12: ffff88006a06c7c0 R13: 0000000000000001 R14: ffffffff8baab1a0 R15: 0000000000000001 FS: 0000000000000000(0000) GS:ffff88006d100000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000004abdd0 CR3: 000000003e2f2000 CR4: 00000000000026e0 Stack: ffffffff894d0098 1ffff1000d0c7d56 ffff88006863ecd0 dffffc0000000000 ffff88006a06c7c0 0000000000000000 ffff88006863ecf8 0000000000000082 0000000000000000 ffffffff815dd7c1 ffffffff00000000 ffffffff00000000 Call Trace: [...] lock_acquire+0x2a2/0x790 kernel/locking/lockdep.c:3746 [...] __raw_spin_lock include/linux/spinlock_api_smp.h:144 [...] _raw_spin_lock+0x38/0x50 kernel/locking/spinlock.c:151 [...] spin_lock include/linux/spinlock.h:302 [...] kvm_ioapic_set_irq+0x4c/0x100 arch/x86/kvm/ioapic.c:379 [...] kvm_set_ioapic_irq+0x8f/0xc0 arch/x86/kvm/irq_comm.c:52 [...] kvm_set_irq+0x239/0x640 arch/x86/kvm/../../../virt/kvm/irqchip.c:101 [...] irqfd_inject+0xb4/0x150 arch/x86/kvm/../../../virt/kvm/eventfd.c:60 [...] process_one_work+0xb40/0x1ba0 kernel/workqueue.c:2096 [...] worker_thread+0x214/0x18a0 kernel/workqueue.c:2230 [...] kthread+0x328/0x3e0 kernel/kthread.c:209 [...] ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:433 Reported-by: Dmitry Vyukov <dvyukov@google.com> Fixes: 49df6397edfc ("KVM: x86: Split the APIC from the rest of IRQCHIP.") Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-02KVM: x86: drop error recovery in em_jmp_far and em_ret_farRadim Krčmář
commit 2117d5398c81554fbf803f5fd1dc55eb78216c0c upstream. em_jmp_far and em_ret_far assumed that setting IP can only fail in 64 bit mode, but syzkaller proved otherwise (and SDM agrees). Code segment was restored upon failure, but it was left uninitialized outside of long mode, which could lead to a leak of host kernel stack. We could have fixed that by always saving and restoring the CS, but we take a simpler approach and just break any guest that manages to fail as the error recovery is error-prone and modern CPUs don't need emulator for this. Found by syzkaller: WARNING: CPU: 2 PID: 3668 at arch/x86/kvm/emulate.c:2217 em_ret_far+0x428/0x480 Kernel panic - not syncing: panic_on_warn set ... CPU: 2 PID: 3668 Comm: syz-executor Not tainted 4.9.0-rc4+ #49 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 [...] Call Trace: [...] __dump_stack lib/dump_stack.c:15 [...] dump_stack+0xb3/0x118 lib/dump_stack.c:51 [...] panic+0x1b7/0x3a3 kernel/panic.c:179 [...] __warn+0x1c4/0x1e0 kernel/panic.c:542 [...] warn_slowpath_null+0x2c/0x40 kernel/panic.c:585 [...] em_ret_far+0x428/0x480 arch/x86/kvm/emulate.c:2217 [...] em_ret_far_imm+0x17/0x70 arch/x86/kvm/emulate.c:2227 [...] x86_emulate_insn+0x87a/0x3730 arch/x86/kvm/emulate.c:5294 [...] x86_emulate_instruction+0x520/0x1ba0 arch/x86/kvm/x86.c:5545 [...] emulate_instruction arch/x86/include/asm/kvm_host.h:1116 [...] complete_emulated_io arch/x86/kvm/x86.c:6870 [...] complete_emulated_mmio+0x4e9/0x710 arch/x86/kvm/x86.c:6934 [...] kvm_arch_vcpu_ioctl_run+0x3b7a/0x5a90 arch/x86/kvm/x86.c:6978 [...] kvm_vcpu_ioctl+0x61e/0xdd0 arch/x86/kvm/../../../virt/kvm/kvm_main.c:2557 [...] vfs_ioctl fs/ioctl.c:43 [...] do_vfs_ioctl+0x18c/0x1040 fs/ioctl.c:679 [...] SYSC_ioctl fs/ioctl.c:694 [...] SyS_ioctl+0x8f/0xc0 fs/ioctl.c:685 [...] entry_SYSCALL_64_fastpath+0x1f/0xc2 Reported-by: Dmitry Vyukov <dvyukov@google.com> Fixes: d1442d85cc30 ("KVM: x86: Handle errors when RIP is set during far jumps") Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26x86/kexec: add -fno-PIESebastian Andrzej Siewior
commit 90944e40ba1838de4b2a9290cf273f9d76bd3bdd upstream. If the gcc is configured to do -fPIE by default then the build aborts later with: | Unsupported relocation type: unknown type rel type name (29) Tagging it stable so it is possible to compile recent stable kernels as well. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26KVM: Disable irq while unregistering user notifierIgnacio Alvarado
commit 1650b4ebc99da4c137bfbfc531be4a2405f951dd upstream. Function user_notifier_unregister should be called only once for each registered user notifier. Function kvm_arch_hardware_disable can be executed from an IPI context which could cause a race condition with a VCPU returning to user mode and attempting to unregister the notifier. Signed-off-by: Ignacio Alvarado <ikalvarado@google.com> Fixes: 18863bdd60f8 ("KVM: x86 shared msr infrastructure") Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26KVM: x86: fix missed SRCU usage in kvm_lapic_set_vapic_addrPaolo Bonzini
commit 7301d6abaea926d685832f7e1f0c37dd206b01f4 upstream. Reported by syzkaller: [ INFO: suspicious RCU usage. ] 4.9.0-rc4+ #47 Not tainted ------------------------------- ./include/linux/kvm_host.h:536 suspicious rcu_dereference_check() usage! stack backtrace: CPU: 1 PID: 6679 Comm: syz-executor Not tainted 4.9.0-rc4+ #47 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 ffff880039e2f6d0 ffffffff81c2e46b ffff88003e3a5b40 0000000000000000 0000000000000001 ffffffff83215600 ffff880039e2f700 ffffffff81334ea9 ffffc9000730b000 0000000000000004 ffff88003c4f8420 ffff88003d3f8000 Call Trace: [< inline >] __dump_stack lib/dump_stack.c:15 [<ffffffff81c2e46b>] dump_stack+0xb3/0x118 lib/dump_stack.c:51 [<ffffffff81334ea9>] lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4445 [< inline >] __kvm_memslots include/linux/kvm_host.h:534 [< inline >] kvm_memslots include/linux/kvm_host.h:541 [<ffffffff8105d6ae>] kvm_gfn_to_hva_cache_init+0xa1e/0xce0 virt/kvm/kvm_main.c:1941 [<ffffffff8112685d>] kvm_lapic_set_vapic_addr+0xed/0x140 arch/x86/kvm/lapic.c:2217 Reported-by: Dmitry Vyukov <dvyukov@google.com> Fixes: fda4e2e85589191b123d31cdc21fd33ee70f50fd Cc: Andrew Honig <ahonig@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Reviewed-by: David Hildenbrand <david@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26x86/cpu/AMD: Fix cpu_llc_id for AMD Fam17h systemsYazen Ghannam
commit b0b6e86846093c5f8820386bc01515f857dd8faa upstream. cpu_llc_id (Last Level Cache ID) derivation on AMD Fam17h has an underflow bug when extracting the socket_id value. It starts from 0 so subtracting 1 from it will result in an invalid value. This breaks scheduling topology later on since the cpu_llc_id will be incorrect. For example, the the cpu_llc_id of the *other* CPU in the loops in set_cpu_sibling_map() underflows and we're generating the funniest thread_siblings masks and then when I run 8 threads of nbench, they get spread around the LLC domains in a very strange pattern which doesn't give you the normal scheduling spread one would expect for performance. Other things like EDAC use cpu_llc_id so they will be b0rked too. So, the APIC ID is preset in APICx020 for bits 3 and above: they contain the core complex, node and socket IDs. The LLC is at the core complex level so we can find a unique cpu_llc_id by right shifting the APICID by 3 because then the least significant bit will be the Core Complex ID. Tested-by: Borislav Petkov <bp@suse.de> Signed-off-by: Yazen Ghannam <Yazen.Ghannam@amd.com> [ Cleaned up and extended the commit message. ] Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Aravind Gopalakrishnan <aravindksg.lkml@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Fixes: 3849e91f571d ("x86/AMD: Fix last level cache topology for AMD Fam17h systems") Link: http://lkml.kernel.org/r/20161108083506.rvqb5h4chrcptj7d@pd.tnic Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Delete now unused user copy fixup functions.David S. Miller
[ Upstream commit 0fd0ff01d4c3c01e7fe69b762ee1a13236639acc ] Now that all of the user copy routines are converted to return accurate residual lengths when an exception occurs, we no longer need the broken fixup routines. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Delete now unused user copy assembler helpers.David S. Miller
[ Upstream commit 614da3d9685b67917cab48c8452fd8bf93de0867 ] All of __ret{,l}_mone{_asi,_fp,_asi_fpu} are now unused. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert U3copy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit ee841d0aff649164080e445e84885015958d8ff4 ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert NG2copy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit e93704e4464fdc191f73fce35129c18de2ebf95d ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert NGcopy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit 7ae3aaf53f1695877ccd5ebbc49ea65991e41f1e ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert NG4copy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit 95707704800988093a9b9a27e0f2f67f5b4bf2fa ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert U1copy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit cb736fdbb208eb3420f1a2eb2bfc024a6e9dcada ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert GENcopy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit d0796b555ba60c22eb41ae39a8362156cb08eee9 ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert copy_in_user to accurate exception reporting.David S. Miller
[ Upstream commit 0096ac9f47b1a2e851b3165d44065d18e5f13d58 ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Prepare to move to more saner user copy exception handling.David S. Miller
[ Upstream commit 83a17d2661674d8c198adc0e183418f72aabab79 ] The fixup helper function mechanism for handling user copy fault handling is not %100 accurrate, and can never be made so. We are going to transition the code to return the running return return length, which is always kept track in one or more registers of each of these routines. In order to convert them one by one, we have to allow the existing behavior to continue functioning. Therefore make all the copy code that wants the fixup helper to be used return negative one. After all of the user copy routines have been converted, this logic and the fixup helpers themselves can be removed completely. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Delete __ret_efault.David S. Miller
[ Upstream commit aa95ce361ed95c72ac42dcb315166bce5cf1a014 ] It is completely unused. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Handle extremely large kernel TLB range flushes more gracefully.David S. Miller
[ Upstream commit a74ad5e660a9ee1d071665e7e8ad822784a2dc7f ] When the vmalloc area gets fragmented, and because the firmware mapping area sits between where modules live and the vmalloc area, we can sometimes receive requests for enormous kernel TLB range flushes. When this happens the cpu just spins flushing billions of pages and this triggers the NMI watchdog and other problems. We took care of this on the TSB side by doing a linear scan of the table once we pass a certain threshold. Do something similar for the TLB flush, however we are limited by the TLB flush facilities provided by the different chip variants. First of all we use an (mostly arbitrary) cut-off of 256K which is about 32 pages. This can be tuned in the future. The huge range code path for each chip works as follows: 1) On spitfire we flush all non-locked TLB entries using diagnostic acceses. 2) On cheetah we use the "flush all" TLB flush. 3) On sun4v/hypervisor we do a TLB context flush on context 0, which unlike previous chips does not remove "permanent" or locked entries. We could probably do something better on spitfire, such as limiting the flush to kernel TLB entries or even doing range comparisons. However that probably isn't worth it since those chips are old and the TLB only had 64 entries. Reported-by: James Clarke <jrtc27@jrtc27.com> Tested-by: James Clarke <jrtc27@jrtc27.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Fix illegal relative branches in hypervisor patched TLB cross-call ↵David S. Miller
code. [ Upstream commit a236441bb69723032db94128761a469030c3fe6d ] Just like the non-cross-call TLB flush handlers, the cross-call ones need to avoid doing PC-relative branches outside of their code blocks. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Fix instruction count in comment for __hypervisor_flush_tlb_pending.David S. Miller
[ Upstream commit 830cda3f9855ff092b0e9610346d110846fc497c ] Noticed by James Clarke. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Fix illegal relative branches in hypervisor patched TLB code.David S. Miller
[ Upstream commit b429ae4d5b565a71dfffd759dfcd4f6c093ced94 ] When we copy code over to patch another piece of code, we can only use PC-relative branches that target code within that piece of code. Such PC-relative branches cannot be made to external symbols because the patch moves the location of the code and thus modifies the relative address of external symbols. Use an absolute jmpl to fix this problem. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Handle extremely large kernel TSB range flushes sanely.David S. Miller
[ Upstream commit 849c498766060a16aad5b0e0d03206726e7d2fa4 ] If the number of pages we are flushing is more than twice the number of entries in the TSB, just scan the TSB table for matches rather than probing each and every page in the range. Based upon a patch and report by James Clarke. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc: Handle negative offsets in arch_jump_label_transformJames Clarke
[ Upstream commit 9d9fa230206a3aea6ef451646c97122f04777983 ] Additionally, if the offset will overflow the immediate for a ba,pt instruction, fall back on a standard ba to get an extra 3 bits. Signed-off-by: James Clarke <jrtc27@jrtc27.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64 mm: Fix base TSB sizing when hugetlb pages are usedMike Kravetz
[ Upstream commit af1b1a9b36b8f9d583d4b4f90dd8946ed0cd4bd0 ] do_sparc64_fault() calculates both the base and huge page RSS sizes and uses this information in calls to tsb_grow(). The calculation for base page TSB size is not correct if the task uses hugetlb pages. hugetlb pages are not accounted for in RSS, therefore the call to get_mm_rss(mm) does not include hugetlb pages. However, the number of pages based on huge_pte_count (which does include hugetlb pages) is subtracted from this value. This will result in an artificially small and often negative RSS calculation. The base TSB size is then often set to max_tsb_size as the passed RSS is unsigned, so a negative value looks really big. THP pages are also accounted for in huge_pte_count, and THP pages are accounted for in RSS so the calculation in do_sparc64_fault() is correct if a task only uses THP pages. A single huge_pte_count is not sufficient for TSB sizing if both hugetlb and THP pages can be used. Instead of a single counter, use two: one for hugetlb and one for THP. Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc: Don't leak context bits into thread->fault_addressDavid S. Miller
[ Upstream commit 4f6deb8cbab532a8d7250bc09234c1795ecb5e2c ] On pre-Niagara systems, we fetch the fault address on data TLB exceptions from the TLB_TAG_ACCESS register. But this register also contains the context ID assosciated with the fault in the low 13 bits of the register value. This propagates into current_thread_info()->fault_address and can cause trouble later on. So clear the low 13-bits out of the TLB_TAG_ACCESS value in the cases where it matters. Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18KVM: MIPS: Precalculate MMIO load resume PCJames Hogan
commit e1e575f6b026734be3b1f075e780e91ab08ca541 upstream. The advancing of the PC when completing an MMIO load is done before re-entering the guest, i.e. before restoring the guest ASID. However if the load is in a branch delay slot it may need to access guest code to read the prior branch instruction. This isn't safe in TLB mapped code at the moment, nor in the future when we'll access unmapped guest segments using direct user accessors too, as it could read the branch from host user memory instead. Therefore calculate the resume PC in advance while we're still in the right context and save it in the new vcpu->arch.io_pc (replacing the no longer needed vcpu->arch.pending_load_cause), and restore it on MMIO completion. Fixes: e685c689f3a8 ("KVM/MIPS32: Privileged instruction/target branch emulation.") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Radim Krčmář" <rkrcmar@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: kvm@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> [james.hogan@imgtec.com: Backport to 3.18..4.4] Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ARC: timer: rtc: implement read loop in "C" vs. inline asmVineet Gupta
commit 922cc171998ac3dbe74d57011ef7ed57e9b0d7df upstream. The current code doesn't even compile as somehow the inline assembly can't see the register names defined as ARC_RTC_* I'm pretty sure It worked when I first got it merged, but the tools were definitely different then. So better to write this in "C" anyways. Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18s390/hypfs: Use get_free_page() instead of kmalloc to ensure page alignmentMichael Holzheu
commit 237d6e6884136923b6bd26d5141ebe1d065960c9 upstream. Since commit d86bd1bece6f ("mm/slub: support left redzone") it is no longer guaranteed that kmalloc(PAGE_SIZE) returns page aligned memory. After the above commit we get an error for diag224 because aligned memory is required. This leads to the following user visible error: # mount none -t s390_hypfs /sys/hypervisor/ mount: unknown filesystem type 's390_hypfs' # dmesg | grep hypfs hypfs.cccfb8: The hardware system does not provide all functions required by hypfs hypfs.7a79f0: Initialization of hypfs failed with rc=-61 Fix this problem and use get_free_page() instead of kmalloc() to get correctly aligned memory. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-15KVM: MIPS: Drop other CPU ASIDs on guest MMU changesJames Hogan
commit 91e4f1b6073dd680d86cdb7e42d7cccca9db39d8 upstream. When a guest TLB entry is replaced by TLBWI or TLBWR, we only invalidate TLB entries on the local CPU. This doesn't work correctly on an SMP host when the guest is migrated to a different physical CPU, as it could pick up stale TLB mappings from the last time the vCPU ran on that physical CPU. Therefore invalidate both user and kernel host ASIDs on other CPUs, which will cause new ASIDs to be generated when it next runs on those CPUs. We're careful only to do this if the TLB entry was already valid, and only for the kernel ASID where the virtual address it mapped is outside of the guest user address range. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Radim Krčmář" <rkrcmar@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: kvm@vger.kernel.org Cc: <stable@vger.kernel.org> # 3.17.x- [james.hogan@imgtec.com: Backport to 3.17..4.4] Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-15Revert KVM: MIPS: Drop other CPU ASIDs on guest MMU changesGreg Kroah-Hartman
This reverts commit d450527ad04ad180636679aeb3161ec58079f1ba which was commit 91e4f1b6073dd680d86cdb7e42d7cccca9db39d8 upstream as it was incorrect. A fixed version will be forthcoming. Reported-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Radim Krčmář" <rkrcmar@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
