The use of signed instead of unsigned here broke the calculations on
negative numbers that are involved in calculating wall_to_monotonic.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Fix the calculation of the end address when flushing iotlb entries to
ram. This bug has been a cause of esp dma errors, and it affects
HyperSPARC systems much worse than SuperSPARC systems.
Signed-off-by: Bob Breuer <breuerr@mc.net>
The page size encoding passed to tlbie is incorrect for new-style
large pages. This fixes it. This doesn't affect anything on older
machines because mmu_psize_defs[psize].penc (the page size encoding)
is 0 for 4k and 16M pages (the two are distinguished by a separate "is
a large page" bit).
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
According to include/asm-alpha/bitops.h, only ALPHA_EV67 has hardware
hweight support, so ALPHA_EV6 needs to use GENERIC_HWEIGHT.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ernst Herzberg <earny@net4u.de>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC64]: Do not double-export sys_close() when CONFIG_SOLARIS_EMUL_MODULE
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] Fix Integrator and Versatile interrupt initialisation
[ARM] 3546/1: PATCH: subtle lost interrupts bug on i.MX
[ARM] 3547/1: PXA-OHCI: Allow platforms to specify a power budget
[ARM] Fix Neponset IRQ handling
It is already exported by fs/open.c
Noticed by Ben Collins.
This patch sets the max_cache_size value required to tune up
scheduler in SMP systems. Otherwise, the calculated
migration_cost is too high and task scheduling may lock up.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
[SPARC64]: Avoid JBUS errors on some Niagara systems.
[FUSION]: Fix mptspi.c build with CONFIG_PM not set.
[TG3]: Handle Sun onboard tg3 chips more correctly.
[SPARC64]: Dump local cpu registers in sun4v_log_error()
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[PATCH] powerpc: Fix cell blade detection
[PATCH] powerpc: Fix call to ibm,client-architecture-support
powerpc: Fix machine check problem on 32-bit kernels
Both Integrator and Versatile were using set_irq_handler() and
enable_irq(), and working around the initialisation of the
chained interrupt, instead of the more correct
set_irq_chained_handler() function. Fix Integrator and
Versatile to use the right function, and remove these work-arounds.
Doing PCI config space accesses to non-present PCI slots
can result in fatal JBUS errors if the PCI config access
hypervisor call is performed on cpus other than the boot
cpu.
PCI config space accesses to present PCI slots works just
fine.
Recursively traverse the OBP device tree under the PCI
controller node and record all present device IDs into
a small hash table.
Avoid the hypervisor call for any PCI config space access
attempt for a device not recorded in the hash table.
This makes the debugging information more usable.
The IBM Cell blade firmware might confuse the kernel to think it's a
pSeries machine. This fixes it for now. With a bit of luck, the firmware
will be updated to avoid that in the future but currently that patch is
needed.
The code in prom_init.c calling the firmware
ibm,client-architecture-support method on pSeries has a bug where it
fails to properly pass the instance handle of the firmware object when
trying to call a method. Result ranges from the call doing nothing to
the firmware crashing. (Found by Segher, thanks !)
Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org>
This fixes a bug found by Dave Jones that means that it is possible
for userspace to provoke a machine check on 32-bit kernels. This
also fixes a couple of other places where I found similar problems
by inspection.
The recent renaming of m48t86's ->readb() and ->writeb() platform driver
methods (2d7b20c1884777e66009be1a533641c19c4705f6) to ->readbyte() and
->writebyte() to fix the ia64 build broke the build of the cirrus ep93xx
ARM platform. This patch fixes it up.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
This patch fixes a kernel panic during boot that occurs on NVIDIA platforms
that have HPET enabled.
When HPET is enabled, the standard timer IRQ is routed to IOAPIC pin 2 and is
advertised as such in the ACPI APIC table - but an earlier workaround in the
kernel was ignoring this override. The fix is to honor timer IRQ overrides
from ACPI when HPET is detected on an NVIDIA platform.
Signed-off-by: Andy Currid <acurrid@nvidia.com>
Cc: "Brown, Len" <len.brown@intel.com>
Cc: "Yu, Luming" <luming.yu@intel.com>
Cc: Andi Kleen <ak@muc.de>
Patch from Matt Reimer
There is a subtle bug in the GPIO interrupt status register
handling in arch/arm/mach-imx/irq.c:imx_gpio_ack_irq(). The
documentation states that a 1 should be written to the relevant bit to
acknowledge a GPIO interrupt, but that is not what the code does.
The problem is that the |= writes back 1s for all the *other*
interrupts represented in the register, so interrupts could get lost.
For example, if interrupts are pending for GPIO B10 and B12, ISR_B
would have the value 0x00001400. Then when the interrupt code handles
GPIO B10, it eventually calls imx_gpio_ack_irq(IRQ_GPIOB(10)), which
effectively does this:
ISR_B |= 1 << 10;
with the result that (0x00001400 | 0x00000400) is written, clearing
the interrupt status bits for *both* GPIO B10 and B12.
The fix is to write 1s only for the interrupts we want to clear.
The same problem seems to be occurring in the DMA code; this patch
does not address those issues.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Signed-off-by: Matt Reimer <mreimer@vpop.net>
Patch from Richard Purdie
Add a power budget variable to the PXA OHCI platform data and add a
default value for the spitz platform(s) which prevents known failures
with certain USB devices.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
While testing the genirq code on ARM, a condition was found whereby
the Neponset IRQ handler was being re-entered, causing the system
to deadlock.
Under the ARM IRQ code, this would not have been a visible problem
because the "simple" IRQ handling had no re-entrancy protection.
Resolve this by acknowledging the parent interrupt after we mask it
when we are going to handle one of our "special" level-based sources
(from ethernet or USAR chip.)
* master.kernel.org:/home/rmk/linux-2.6-serial:
[SERIAL] typo: buad -> baud
[ARM] 3543/1: [Fwd: PXA270 bootparams address not set]
[ARM] Trivial typo fixes
Move memory_present() in arch/mips/kernel/setup.c. When using sparsemem
extreme, this function does an allocate for bootmem. This would always
fail since init_bootmem hasn't been called yet.
Move memory_present after free_bootmem. This only marks actual memory
ranges as present instead of the entire address space.
Signed-off-by: Chad Reese <creese@caviumnetworks.com>
Fix following warnings:
linux/arch/mips/kernel/setup.c:432: warning: field width is not type int (arg 2)
linux/arch/mips/kernel/setup.c:432: warning: field width is not type int (arg 4)
linux/arch/mips/kernel/syscall.c:279: warning: unused variable `len'
linux/arch/mips/kernel/syscall.c:280: warning: unused variable `name'
linux/arch/mips/math-emu/dp_fint.c:32: warning: unused variable `xc'
linux/arch/mips/math-emu/dp_flong.c:32: warning: unused variable `xc'
linux/arch/mips/math-emu/sp_fint.c:32: warning: unused variable `xc'
linux/arch/mips/math-emu/sp_flong.c:32: warning: unused variable `xc'
(original patch by Atsushi, slight changes to the setup.c part by me.)
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
linux/arch/mips/kernel/setup.c:249:12: warning: constant 0xffffffff00000000 is so big it is unsigned long
linux/arch/mips/kernel/cpu-bugs64.c:209:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long
linux/arch/mips/kernel/cpu-bugs64.c:227:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long
linux/arch/mips/kernel/cpu-bugs64.c:283:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long
linux/arch/mips/kernel/cpu-bugs64.c:299:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long
The expressions are volatile; no need for temporary variables.
The wrong revision number in the check was forcing a fallback to FPU
emulation for all SB1 cores in 2.6.
open() always sets the O_LARGEFILE flag for the o32 ABI implementation
of a 64bit kernel. The appended patch fixes it.
Signed-off-by: Thiemo Seufer <ths@networkno.de>
Alchemy boards use YAMON which passes the environment variables as the
tuples of strings (the name followed by the value) unlike PMON which
passes "name=<val>" strings.
Save the Config.OD bit from being clobbered by coherency_setup(). This
bit, when set, fixes various errata in the early steppings of Au1x00
SOCs. Unfortunately, the bit was write-only on the most early of them.
In addition, also restore the bit after a wakeup from sleep.
The modpost uses a whitelist for commonly used suffix on checking the
section mismatch. Adding "_ops" suffix to op_modex_xxx get rid of
this modpost warning.
WARNING: arch/mips/oprofile/oprofile.o - Section mismatch: reference to .init.text: from .data after 'op_model_mipsxx' (at offset 0x528)
This fixes the undefined reference to strcpy seen when building modules on
i386. Tracked down by Al Viro.
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
uml __user annotations
fix uml/amd64 prctl()
put_user() there should go to (long __user *)addr, not &addr
We had a spurious semicolon somehow.
Initialize wall_to_monotonic correctly. This fixes a problem where sleeps
lasted about one secone less than they should. This also called for a bit of
code restructuring, following a patch which Blaisorblade had been keeping.
From: Benjamin Herrenschmidt <benh@kernel.crashing.org>
This fixes request_irq() potentially called from atomic context.
After removal of fixup_cpu_present_map() function Alpha ended up with an empty
cpu_present_map, so secondary CPUs on SMP systems are not being started.
Worse, on some platforms we route interrupts to secondary CPUs using
cpu_possible_map which is still populated properly. As a result, these
interrupts go nowhere so the machines like DP264 aren't able to boot even with
a primary CPU.
Fixed basically by s/cpu_present_mask/cpu_present_map/.
Thanks to Ernst Herzberg for reporting the bug and testing the fix.
Cc: Ernst Herzberg <list-lkml@net4u.de>
Patch from Steve Yang
MACHINE_START struct doesn't have any bootargs location for the
mainstone. Result is no kernel command args get passed; no serial driver
is selected for console and results in a silent boot failure.
Signed-off-by: Steve Yang <steve.yang@windriver.com>
Replacing mistyped "buad" with "baud" where applicable.
Signed-off-by: Horst Schirmeier <horst@schirmeier.com>
Both csum_partial() and the csum_partial_copy*() family of routines
forget to do a final fold on the computed checksum value on sparc64.
So do the standard Sparc "add + set condition codes, add carry"
sequence, then make sure the high 32-bits of the return value are
clear.
Based upon some excellent detective work and debugging done by
Richard Braun and Samuel Thibault.
Trivial typo fixes in Kconfig files (ARM).
Signed-off-by: Egry Gabor <gaboregry@t-online.hu>
[ARM] 3540/1: ixp23xx: deal with gap in interrupt bitmasks
[ARM] 3539/1: ixp23xx: fix __arch_ixp23xx_is_coherent() for A1 stepping
[SPARC64]: Fix D-cache corruption in mremap
[SPARC64]: Make smp_processor_id() functional before start_kernel()
