commit 14be1f7454ea96ee614467a49cf018a1a383b189 upstream.
On UV systems, the TSC is not synchronized across blades. The
sched_clock_cpu() function is returning values that can go
backwards (I've seen as much as 8 seconds) when switching
between cpus.
As each cpu comes up, early_init_intel() will currently set the
sched_clock_stable flag true. When mark_tsc_unstable() runs, it
clears the flag, but this only occurs once (the first time a cpu
comes up whose TSC is not synchronized with cpu 0). After this,
early_init_intel() will set the flag again as the next cpu comes
up.
Only set sched_clock_stable if tsc has not been marked unstable.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <20100301174815.GC8224@sgi.com>
commit 319c2cc761505ee54a9536c5d0b9c2ee3fb33866 upstream.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit 035a02c1e1de31888e8b6adac0ff667971ac04db upstream.
Currently c1e_idle returns true for all CPUs greater than or equal to
family 0xf model 0x40. This covers too many CPUs.
Meanwhile a respective erratum for the underlying problem was filed
(#400). This patch adds the logic to check whether erratum #400
applies to a given CPU.
Especially for CPUs where SMI/HW triggered C1e is not supported,
c1e_idle() doesn't need to be used. We can check this by looking at
the respective OSVW bit for erratum #400.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
LKML-Reference: <20100319110922.GA19614@alberich.amd.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit ff30a0543e9a6cd732582063e7cae951cdb7acf2 upstream.
Ever for 32-bit with sufficiently high NR_CPUS, and starting
with commit 789d03f584484af85dbdc64935270c8e45f36ef7 also for
64-bit, the statically allocated early fixmap page tables were
not covering FIX_OHCI1394_BASE, leading to a boot time crash
when "ohci1394_dma=early" was used. Despite this entry not being
a permanently used one, it needs to be moved into the permanent
range since it has to be close to FIX_DBGP_BASE and
FIX_EARLYCON_MEM_BASE.
Reported-bisected-and-tested-by: Justin P. Mattock <justinmattock@gmail.com>
Fixes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=14487
Signed-off-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <4B9E15D30200007800034D23@vpn.id2.novell.com>
commit 1252f238db48ec419f40c1bdf30fda649860eed9 upstream.
05d43ed8a "x86: get rid of the insane TIF_ABI_PENDING bit" forgot about
force_personality32. Fix.
[ Upstream commit 8a4fd1e4922413cfdfa6c51a59efb720d904a5eb ]
If we do something like try to print to the OF console from an NMI
while we're already in OpenFirmware, we'll deadlock on the spinlock.
Use a raw spinlock and disable NMIs when we take it.
commit 681ee44d40d7c93b42118320e4620d07d8704fd6 upstream
We need to fall back from logical-flat APIC mode to physical-flat mode
when we have more than 8 CPUs. However, in the presence of CPU
hotplug(with bios listing not enabled but possible cpus as disabled cpus in
MADT), we have to consider the number of possible CPUs rather than
the number of current CPUs; otherwise we may cross the 8-CPU boundary
when CPUs are added later.
32bit apic code can use more cleanups (like the removal of vendor checks in
32bit default_setup_apic_routing()) and more unifications with 64bit code.
Yinghai has some patches in works already. This patch addresses the boot issue
that is reported in the virtualization guest context.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Shaohui Zheng <shaohui.zheng@intel.com>
Reviewed-by: Yinghai Lu <yinghai@kernel.org>
commit abbdc3d88aa2d5c937b21044c336bcd056c1732f upstream.
commit c8af165342e83a4eb078c9607d29a7c399d30a53 (lmo) rsp.
e0cc87f59490d7d62a8ab2a76498dc8a2b64927a (kernel.org) left
label_module_alloc unused. Remove it now.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Cc: linux-mips@linux-mips.org
Patchwork: http://patchwork.linux-mips.org/patch/752/
commit 98e12b5a6e05413420a7e3b3eca7fbfc2ff41b6d upstream.
Commit 2552fc2 changed the way the decompressor decides if it is safe
to decompress the kernel directly to its final location. Unfortunately,
it took the top of the compressed data as being the stack pointer,
which it is for ROM=n cases. However, for ROM=y, the stack pointer
is not relevant, and results in the wrong answer.
Fix this by explicitly storing the end of the biggybacked data in the
decompressor, and use that to calculate the compressed image size.
commit 14315592009c17035cac81f4954d5a1f4d71e489 upstream.
Distros generally (I looked at Debian, RHEL5 and SLES11) seem to
enable CONFIG_HIGHPTE for any x86 configuration which has highmem
enabled. This means that the overhead applies even to machines which
have a fairly modest amount of high memory and which therefore do not
really benefit from allocating PTEs in high memory but still pay the
price of the additional mapping operations.
Running kernbench on a 4G box I found that with CONFIG_HIGHPTE=y but
no actual highptes being allocated there was a reduction in system
time used from 59.737s to 55.9s.
With CONFIG_HIGHPTE=y and highmem PTEs being allocated:
Average Optimal load -j 4 Run (std deviation):
Elapsed Time 175.396 (0.238914)
User Time 515.983 (5.85019)
System Time 59.737 (1.26727)
Percent CPU 263.8 (71.6796)
Context Switches 39989.7 (4672.64)
Sleeps 42617.7 (246.307)
With CONFIG_HIGHPTE=y but with no highmem PTEs being allocated:
Elapsed Time 174.278 (0.831968)
User Time 515.659 (6.07012)
System Time 55.9 (1.07799)
Percent CPU 263.8 (71.266)
Context Switches 39929.6 (4485.13)
Sleeps 42583.7 (373.039)
This patch allows the user to control the allocation of PTEs in
highmem from the command line ("userpte=nohigh") but retains the
status-quo as the default.
It is possible that some simple heuristic could be developed which
allows auto-tuning of this option however I don't have a sufficiently
large machine available to me to perform any particularly meaningful
experiments. We could probably handwave up an argument for a threshold
at 16G of total RAM.
Assuming 768M of lowmem we have 196608 potential lowmem PTE
pages. Each page can map 2M of RAM in a PAE-enabled configuration,
meaning a maximum of 384G of RAM could potentially be mapped using
lowmem PTEs.
Even allowing generous factor of 10 to account for other required
lowmem allocations, generous slop to account for page sharing (which
reduces the total amount of RAM mappable by a given number of PT
pages) and other innacuracies in the estimations it would seem that
even a 32G machine would not have a particularly pressing need for
highmem PTEs. I think 32G could be considered to be at the upper bound
of what might be sensible on a 32 bit machine (although I think in
practice 64G is still supported).
It's seems questionable if HIGHPTE is even a win for any amount of RAM
you would sensibly run a 32 bit kernel on rather than going 64 bit.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
LKML-Reference: <1266403090-20162-1-git-send-email-ian.campbell@citrix.com>
commit e92805ac1228626c59c865f2f4e9059b9fb8c97b upstream.
Add CPL checking in case emulator is tricked into emulating
privilege instruction from userspace.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 60a29d4ea4e7b6b95d9391ebc8625b0426f3a363 upstream.
Use groups mechanism to decode 0F C7 instructions.
commit 8b9f44140bc4afd2698413cd9960c3912168ee91 upstream.
Inject #UD if guest attempts to do so. This is in accordance to Intel
SDM.
commit 2db2c2eb6226e30f8059b82512a1364db98da8e3 upstream.
Use groups mechanism to decode 0F BA instructions.
commit 18dce6ba5c8c6bd0f3ab4efa4cbdd698dab5c40a upstream.
Thomas Renninger <trenn@suse.de> reported on IBM x3330
booting a latest kernel on this machine results in:
PCI: PCI BIOS revision 2.10 entry at 0xfd61c, last bus=1
PCI: Using configuration type 1 for base access bio: create slab <bio-0> at 0
ACPI: SCI (IRQ30) allocation failed
ACPI Exception: AE_NOT_ACQUIRED, Unable to install System Control Interrupt handler (20090903/evevent-161)
ACPI: Unable to start the ACPI Interpreter
Later all kind of devices fail...
and bisect it down to this commit:
commit b9c61b70075c87a8612624736faf4a2de5b1ed30
x86/pci: update pirq_enable_irq() to setup io apic routing
it turns out we need to set irq routing for the sci on ioapic1 early.
-v2: make it work without sparseirq too.
-v3: fix checkpatch.pl warning, and cc to stable
Reported-by: Thomas Renninger <trenn@suse.de>
Bisected-by: Thomas Renninger <trenn@suse.de>
Tested-by: Thomas Renninger <trenn@suse.de>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <1265793639-15071-2-git-send-email-yinghai@kernel.org>
commit ced5b697a76d325e7a7ac7d382dbbb632c765093 upstream.
Keep chip_data in create_irq_nr and destroy_irq.
When two drivers are setting up MSI-X at the same time via
pci_enable_msix() there is a race. See this dmesg excerpt:
[ 85.170610] ixgbe 0000:02:00.1: irq 97 for MSI/MSI-X
[ 85.170611] alloc irq_desc for 99 on node -1
[ 85.170613] igb 0000:08:00.1: irq 98 for MSI/MSI-X
[ 85.170614] alloc kstat_irqs on node -1
[ 85.170616] alloc irq_2_iommu on node -1
[ 85.170617] alloc irq_desc for 100 on node -1
[ 85.170619] alloc kstat_irqs on node -1
[ 85.170621] alloc irq_2_iommu on node -1
[ 85.170625] ixgbe 0000:02:00.1: irq 99 for MSI/MSI-X
[ 85.170626] alloc irq_desc for 101 on node -1
[ 85.170628] igb 0000:08:00.1: irq 100 for MSI/MSI-X
[ 85.170630] alloc kstat_irqs on node -1
[ 85.170631] alloc irq_2_iommu on node -1
[ 85.170635] alloc irq_desc for 102 on node -1
[ 85.170636] alloc kstat_irqs on node -1
[ 85.170639] alloc irq_2_iommu on node -1
[ 85.170646] BUG: unable to handle kernel NULL pointer dereference
at 0000000000000088
As you can see igb and ixgbe are both alternating on create_irq_nr()
via pci_enable_msix() in their probe function.
ixgbe: While looping through irq_desc_ptrs[] via create_irq_nr() ixgbe
choses irq_desc_ptrs[102] and exits the loop, drops vector_lock and
calls dynamic_irq_init. Then it sets irq_desc_ptrs[102]->chip_data =
NULL via dynamic_irq_init().
igb: Grabs the vector_lock now and starts looping over irq_desc_ptrs[]
via create_irq_nr(). It gets to irq_desc_ptrs[102] and does this:
cfg_new = irq_desc_ptrs[102]->chip_data;
if (cfg_new->vector != 0)
continue;
This hits the NULL deref.
Another possible race exists via pci_disable_msix() in a driver or in
the number of error paths that call free_msi_irqs():
destroy_irq()
dynamic_irq_cleanup() which sets desc->chip_data = NULL
...race window...
desc->chip_data = cfg;
Remove the save and restore code for cfg in create_irq_nr() and
destroy_irq() and take the desc->lock when checking the irq_cfg.
Reported-and-analyzed-by: Brandon Philips <bphilips@suse.de>
LKML-Reference: <1265793639-15071-3-git-send-email-yinghai@kernel.org>
Signed-off-by: Brandon Phililps <bphilips@suse.de>
commit 817a824b75b1475f1b067c8cee318c7b4d66fcde upstream.
There's a path in the pagefault code where the kernel deliberately
breaks its own locking rules by kmapping a high pte page without
holding the pagetable lock (in at least page_check_address). This
breaks Xen's ability to track the pinned/unpinned state of the
page. There does not appear to be a viable workaround for this
behaviour so simply disable HIGHPTE for all Xen guests.
LKML-Reference: <1267204562-11844-1-git-send-email-ian.campbell@citrix.com>
Cc: Pasi Kärkkäinen <pasik@iki.fi>
Cc: <xen-devel@lists.xensource.com>
commit 0a832320f1bae6a4169bf683e201378f2437cfc1 upstream.
On the iMac9,1 /sbin/reboot results in a black mangled screen. Adding
this DMI entry gets the machine to reboot cleanly as it should.
LKML-Reference: <1266362249-3337-1-git-send-email-justinmattock@gmail.com>
commit 318f6b228ba88a394ef560efc1bfe028ad5ae6b6 upstream.
Do not set current->mm->mmap to NULL in 32-bit emulation on 64-bit
load_aout_binary after flush_old_exec as it would destroy already
set brpm mapping with arguments.
Introduced by b6a2fea39318e43fee84fa7b0b90d68bed92d2ba
mm: variable length argument support
where the argument mapping in bprm was added.
[ hpa: this is a regression from 2.6.22... time to kill a.out? ]
LKML-Reference: <1265831716-7668-1-git-send-email-jslaby@suse.cz>
Cc: Ollie Wild <aaw@google.com>
Cc: x86@kernel.org
commit cfc9c0b450176a077205ef39092f0dc1a04e020a upstream.
During switching virtual counters there is access to perfctr msrs. If
the counter is not available this fails due to an invalid
address. This patch fixes this.
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit c17c8fbf349482e89b57d1b800e83e9f4cf40c47 upstream.
commit 89baaaa98a10cad5cc8516c7208b02d9fc711890 upstream.
Standard AMD systems have the same number of nodes as there are
northbridge devices. However, there may kernel configurations
(especially for 32 bit) or system setups exist, where the node number
is different or it can not be detected properly. Thus the check is not
reliable and may fail though IBS setup was fine. For this reason it is
better to remove the check.
commit 18b4a4d59e97e7ff13ee84b5bec79f3fc70a9f0a upstream.
The commit
1155de4 ring-buffer: Make it generally available
already made ring-buffer available without the TRACING option
enabled. This patch removes the TRACING dependency from oprofile.
Fixes also oprofile configuration on ia64.
The patch also applies to the 2.6.32-stable kernel.
Reported-by: Tony Jones <tonyj@suse.de>
commit 68dc819ce829f7e7977a56524e710473bdb55115 upstream.
Multiple virtual counters share one physical counter. The reservation
of virtual counters fails due to duplicate allocation of the same
counter. The counters are already reserved. Thus, virtual counter
reservation may removed at all. This also makes the code easier.
[ Upstream commit 1f474646fdc36b457606bbcd6a3592e6cbd31ac4 ]
Thanks to testcase and report from Brad Spengler:
#include <stdio.h>
typedef int (* _wee)(void);
int main(void)
char buf[8] = { '\x81', '\xc7', '\xe0', '\x08', '\x81', '\xe8',
'\x00', '\x00' };
_wee wee;
printf("%p\n", &buf);
wee = (_wee)&buf;
wee();
return 0;
TSB I-tlb load code tries to use andcc to check the _PAGE_EXEC_4U bit,
but that's bit 12 so it gets sign extended all the way up to bit 63
and the test nearly always passes as a result.
Use sethi to fix the bug.
[ Upstream commit 093171465235a8482fbf08a9a2e365247e1f7dd5 ]
It should be a 1 byte region.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
[ Upstream commit 2531be413b3f2f64c0282073de89fe52bbcbbab5 ]
Commit 085219f79cad89291699bd2bfb21c9fdabafe65f
("sparc32: use proper types in struct stat")
Accidently changed the struct stat uid/gid members
to uid_t and gid_t, but those get set to
__kernel_uid32_t and __kernel_gid32_t respectively.
Those are of type 'int' but the structure is meant
to have 'short'. So use uid16_t and gid16_t to
correct this.
Reported-by: Rob Landley <rob@landley.net>
[ Upstream commit 8654164f54bd02787ae91db8526dcae8e7e34eeb ]
It doesn't account for phys_base like it should, fix by using
page_to_pfn().
While we're here, make virt_to_page() use pfn_to_page() as well, so we
consistently use the asm/memory-model.h abstractions instead of
open-coding memory model assumptions.
Tested-by: Kristoffer Glembo <kristoffer@gaisler.com>
[ Upstream commits f036d9f3985a529a81e582f68aa984eb7b20d54d
and 440ab7ac2d6b735fb278a1ff1674f6716314c6bb ]
This is mandatory for 64-bit processes, and doing it also for 32-bit
processes saves a conditional in the compat case.
This fixes the glibc/nptl/tst-stdio1 test case, as well
as many others, on 64-bit.
commit 49bf83a45fc677db1ed44d0e072e6aaeabe4e124 upstream.
We broke "acpi=ht" in 2.6.32 by disabling MADT parsing
for acpi=disabled. e5b8fc6ac158f65598f58dba2c0d52ba3b412f52
This also broke systems which invoked acpi=ht via DMI blacklist.
acpi=ht is a really ugly hack,
but restore it for those that still use it.
http://bugzilla.kernel.org/show_bug.cgi?id=14886
Signed-off-by: Len Brown <len.brown@intel.com>
commit 97c169d39b6846a564dc8d883832e7fef9bdb77d upstream.
We realized when we broke acpi=ht
that acpi=ht is not needed on this box
and folks have been using acpi=force on it anyway.
commit 37ef2a3029fde884808ff1b369677abc7dd9a79a upstream.
When irq_desc is moved, we need to make sure to use the right cfg_new.
LKML-Reference: <4B07A739.3030104@kernel.org>
commit d3ad9373b7c29b63d5e8460a69453718d200cc3b upstream.
Deassigning a device from the passthrough domain does not
work and breaks device assignment to kvm guests. This patch
fixes the issue.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit f5325094379158e6b876ea0010c807bf7890ec8f upstream
This patch moves the initialization of the iommu-api out of
the dma-ops initialization code. This ensures that the
iommu-api is initialized even with iommu=pt.
commit fcb4ebd678858850e8b029909064175cb627868d upstream.
pte_write() should check whether the permissions include either the user
or kernel write permission bits. Likewise, pte_wrprotect() needs to
remove both the kernel and user write bits.
Without this patch handle_tlbmiss() doesn't handle faulting in pages
from the P3 area (our vmalloc space) because of a write. Mappings of the
P3 space have the _PAGE_EXT_KERN_WRITE bit but not _PAGE_EXT_USER_WRITE.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
commit ee73f656a604d5aa9df86a97102e4e462dd79924 upstream.
PIT control word (address 0x43) is write-only, reads are undefined.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 923de3cf5bf12049628019010e36623fca5ef6d1 upstream.
Current kvm wallclock does not consider the total_sleep_time which could cause
wrong wallclock in guest after host suspend/resume. This patch solve
this issue by counting total_sleep_time to get the correct host boot time.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Glauber Costa <glommer@redhat.com>
commit 557a701c16553b0b691dbb64ef30361115a80f64 upstream.
Easy fix for a regression introduced in 2.6.31.
On managed CPUs the cpufreq.c core will call driver->exit(cpu) on the
managed cpus and powernow_k8 will free the core's data.
Later driver->get(cpu) function might get called trying to read out the
current freq of a managed cpu and the NULL pointer check does not work on
the freed object -> better set it to NULL.
->get() is unsigned and must return 0 as invalid frequency.
Reference:
http://bugzilla.kernel.org/show_bug.cgi?id=14391
Signed-off-by: Thomas Renninger <trenn@suse.de>
Tested-by: Michal Schmidt <mschmidt@redhat.com>
Signed-off-by: Dave Jones <davej@redhat.com>
commit 94f28da8409c6059135e89ac64a0839993124155 upstream.
Here are the powerpc bits to remove TIF_ABI_PENDING now that
set_personality() is called at the appropriate place in exec.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit d8cc108f4fab42b380c6b3f3356f99e8dd5372e2 upstream.
With multiplexing enabled oprofile crashs when profiling more than 28
events. This patch fixes this.
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
commit e83e452b0692c9c13372540deb88a77d4ae2553d upstream.
Add Xeon 7500 series support to oprofile.
Straight forward: it's the same as Core i7, so just detect
the model number. No user space changes needed.
(cherry picked from afbcf7ab8d1bc8c2d04792f6d9e786e0adeb328d)
When we migrate a kvm guest that uses pvclock between two hosts, we may
suffer a large skew. This is because there can be significant differences
between the monotonic clock of the hosts involved. When a new host with
a much larger monotonic time starts running the guest, the view of time
will be significantly impacted.
Situation is much worse when we do the opposite, and migrate to a host with
a smaller monotonic clock.
This proposed ioctl will allow userspace to inform us what is the monotonic
clock value in the source host, so we can keep the time skew short, and
more importantly, never goes backwards. Userspace may also need to trigger
the current data, since from the first migration onwards, it won't be
reflected by a simple call to clock_gettime() anymore.
[marcelo: future-proof abi with a flags field]
[jan: fix KVM_GET_CLOCK by clearing flags field instead of checking it]
Signed-off-by: Glauber Costa <glommer@redhat.com>
commit d91afd15b041f27d34859c79afa9e172018a86f4 upstream.
The variable i in this function could be increased to over
2**32 which would result in an integer overflow when using
int. Fix it by changing i to unsigned long.
commit 7c099ce1575126395f186ecf58b51a60d5c3be7d upstream.
Commit 6aa542a694dc9ea4344a8a590d2628c33d1b9431 added a quirk for the
Intel DG45ID board due to low memory corruption. The Intel DG45FC
shares the same BIOS (and the same bug) as noted in:
http://bugzilla.kernel.org/show_bug.cgi?id=13736
Signed-off-by: David Härdeman <david@hardeman.nu>
LKML-Reference: <20100128200254.GA9134@hardeman.nu>
Cc: Alexey Fisher <bug-track@fisher-privat.net>
Cc: ykzhao <yakui.zhao@intel.com>
Cc: Tony Bones <aabonesml@gmail.com>
commit 35ea63d70f827a26c150993b4b940925bb02b03f upstream.
Dell OptiPlex 760 hangs on reboot unless reboot=bios is used. Add quirk
to reboot through the BIOS.
BugLink: https://bugs.launchpad.net/bugs/488319
Signed-off-by: Leann Ogasawara <leann.ogasawara@canonical.com>
LKML-Reference: <1264634958.27335.1091.camel@emiko>
commit 73472a46b5b28116b145fb5fc05242c1aa8e1461 upstream
HPET MSI on platforms with ATI SB700/SB800 as they seem to have some
side-effects on floppy DMA. Do not use HPET MSI on such platforms.
Original problem report from Mark Hounschell
http://lkml.indiana.edu/hypermail/linux/kernel/0912.2/01118.html
Tested-by: Mark Hounschell <markh@compro.net>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: <stable@kernel.org>
LKML-Reference: <20100121190952.GA32523@linux-os.sc.intel.com>
commit 05d43ed8a89c159ff641d472f970e3f1baa66318 upstream.
Now that the previous commit made it possible to do the personality
setting at the point of no return, we do just that for ELF binaries.
And suddenly all the reasons for that insane TIF_ABI_PENDING bit go
away, and we can just make SET_PERSONALITY() just do the obvious thing
for a 32-bit compat process.
Everything becomes much more straightforward this way.
commit 94673e968cbcce07fa78dac4b0ae05d24b5816e1 upstream.
Here are the sparc bits to remove TIF_ABI_PENDING now that
commit 221af7f87b97431e3ee21ce4b0e77d5411cf1549 upstream.
'flush_old_exec()' is the point of no return when doing an execve(), and
it is pretty badly misnamed. It doesn't just flush the old executable
environment, it also starts up the new one.
Which is very inconvenient for things like setting up the new
personality, because we want the new personality to affect the starting
of the new environment, but at the same time we do _not_ want the new
personality to take effect if flushing the old one fails.
As a result, the x86-64 '32-bit' personality is actually done using this
insane "I'm going to change the ABI, but I haven't done it yet" bit
(TIF_ABI_PENDING), with SET_PERSONALITY() not actually setting the
personality, but just the "pending" bit, so that "flush_thread()" can do
the actual personality magic.
This patch in no way changes any of that insanity, but it does split the
'flush_old_exec()' function up into a preparatory part that can fail
(still called flush_old_exec()), and a new part that will actually set
up the new exec environment (setup_new_exec()). All callers are changed
to trivially comply with the new world order.
commit 04e4f2b18c8de1389d1e00fef0f42a8099910daf upstream.
The current code will load the stack size and protection markings, but
then only use the markings in the MMU code path. The NOMMU code path
always passes PROT_EXEC to the mmap() call. While this doesn't matter
to most people whilst the code is running, it will cause a pointless
icache flush when starting every FDPIC application. Typically this
icache flush will be of a region on the order of 128KB in size, or may
be the entire icache, depending on the facilities available on the CPU.
In the case where the arch default behaviour seems to be desired
(EXSTACK_DEFAULT), we probe VM_STACK_FLAGS for VM_EXEC to determine
whether we should be setting PROT_EXEC or not.
For arches that support an MPU (Memory Protection Unit - an MMU without
the virtual mapping capability), setting PROT_EXEC or not will make an
important difference.
It should be noted that this change also affects the executability of
the brk region, since ELF-FDPIC has that share with the stack. However,
this is probably irrelevant as NOMMU programs aren't likely to use the
brk region, preferring instead allocation via mmap().
