path: root/arch
2012-11-21staging: drm/imx: Remove duplicate inclusion of linux/videodev2.hSachin Kamat
linux/videodev2.h was included twice. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-16Merge 3.7-rc6 into staging-nextGreg Kroah-Hartman
2012-11-16Merge git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fix from Marcelo Tosatti: "A correction for oops on module init with older Intel hosts." * git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: Fix invalid secondary exec controls in vmx_cpuid_update()
2012-11-16Merge branch 'akpm' (Fixes from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (12 patches) revert "mm: fix-up zone present pages" tmpfs: change final i_blocks BUG to WARNING tmpfs: fix shmem_getpage_gfp() VM_BUG_ON mm: highmem: don't treat PKMAP_ADDR(LAST_PKMAP) as a highmem address mm: revert "mm: vmscan: scale number of pages reclaimed by reclaim/compaction based on failures" rapidio: fix kernel-doc warnings swapfile: fix name leak in swapoff memcg: fix hotplugged memory zone oops mips, arc: fix build failure memcg: oom: fix totalpages calculation for memory.swappiness==0 mm: fix build warning for uninitialized value mm: add anon_vma_lock to validate_mm()
2012-11-16revert "mm: fix-up zone present pages"Andrew Morton
Revert commit 7f1290f2f2a4 ("mm: fix-up zone present pages") That patch tried to fix a issue when calculating zone->present_pages, but it caused a regression on 32bit systems with HIGHMEM. With that change, reset_zone_present_pages() resets all zone->present_pages to zero, and fixup_zone_present_pages() is called to recalculate zone->present_pages when the boot allocator frees core memory pages into buddy allocator. Because highmem pages are not freed by bootmem allocator, all highmem zones' present_pages becomes zero. Various options for improving the situation are being discussed but for now, let's return to the 3.6 code. Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: David Rientjes <rientjes@google.com> Tested-by: Chris Clayton <chris2553@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-16mips, arc: fix build failureDavid Rientjes
Using a cross-compiler to fix another issue, the following build error occurred for mips defconfig: arch/mips/fw/arc/misc.c: In function 'ArcHalt': arch/mips/fw/arc/misc.c:25:2: error: implicit declaration of function 'local_irq_disable' Fix it up by including irqflags.h. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-16KVM: x86: Fix invalid secondary exec controls in vmx_cpuid_update()Takashi Iwai
The commit [ad756a16: KVM: VMX: Implement PCID/INVPCID for guests with EPT] introduced the unconditional access to SECONDARY_VM_EXEC_CONTROL, and this triggers kernel warnings like below on old CPUs: vmwrite error: reg 401e value a0568000 (err 12) Pid: 13649, comm: qemu-kvm Not tainted 3.7.0-rc4-test2+ #154 Call Trace: [<ffffffffa0558d86>] vmwrite_error+0x27/0x29 [kvm_intel] [<ffffffffa054e8cb>] vmcs_writel+0x1b/0x20 [kvm_intel] [<ffffffffa054f114>] vmx_cpuid_update+0x74/0x170 [kvm_intel] [<ffffffffa03629b6>] kvm_vcpu_ioctl_set_cpuid2+0x76/0x90 [kvm] [<ffffffffa0341c67>] kvm_arch_vcpu_ioctl+0xc37/0xed0 [kvm] [<ffffffff81143f7c>] ? __vunmap+0x9c/0x110 [<ffffffffa0551489>] ? vmx_vcpu_load+0x39/0x1a0 [kvm_intel] [<ffffffffa0340ee2>] ? kvm_arch_vcpu_load+0x52/0x1a0 [kvm] [<ffffffffa032dcd4>] ? vcpu_load+0x74/0xd0 [kvm] [<ffffffffa032deb0>] kvm_vcpu_ioctl+0x110/0x5e0 [kvm] [<ffffffffa032e93d>] ? kvm_dev_ioctl+0x4d/0x4a0 [kvm] [<ffffffff8117dc6f>] do_vfs_ioctl+0x8f/0x530 [<ffffffff81139d76>] ? remove_vma+0x56/0x60 [<ffffffff8113b708>] ? do_munmap+0x328/0x400 [<ffffffff81187c8c>] ? fget_light+0x4c/0x100 [<ffffffff8117e1a1>] sys_ioctl+0x91/0xb0 [<ffffffff815a942d>] system_call_fastpath+0x1a/0x1f This patch adds a check for the availability of secondary exec control to avoid these warnings. Cc: <stable@vger.kernel.org> [v3.6+] Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-11-16Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "We've been sitting on this longer than we meant to due to travel and other activities, but the number of patches is luckily not that high. Biggest changes are from a batch of OMAP bugfixes, but there are a few for the broader set of SoCs too (bcm2835, pxa, highbank, tegra, at91 and i.MX). The OMAP patches contain some fixes for MUSB/PHY on omap4 which ends up being a bit on the large side but needed for legacy (non-DT) platforms. Beyond that there are a handful of hwmod/pm changes. So, fairly noncontroversial stuff all in all, and as usual around this time the fixes are well targeted at specific problems." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: imx: ehci: fix host power mask bit ARM i.MX: fix error-valued pointer dereference in clk_register_gate2() ARM: at91/usbh: fix overcurrent gpio setup ARM: at91/AT91SAM9G45: fix crypto peripherals irq issue due to sparse irq support ARM: boot: Fix usage of kecho ARM: OMAP: ocp2scp: create omap device for ocp2scp ARM: OMAP4: add _dev_attr_ to ocp2scp for representing usb_phy drivers: bus: ocp2scp: add pdata support irqchip: irq-bcm2835: Add terminating entry for of_device_id table ARM: highbank: retry wfi on reset request ARM: OMAP4: PM: fix regulator name for VDD_MPU ARM: OMAP4: hwmod data: do not enable or reset the McPDM during kernel init ARM: OMAP2+: hwmod: add flag to prevent hwmod code from touching IP block during init ARM: dt: tegra: fix length of pad control and mux registers ARM: OMAP: hwmod: wait for sysreset complete after enabling hwmod ARM: OMAP2+: clockdomain: Fix OMAP4 ISS clk domain to support only SWSUP ARM: pxa/spitz_pm: Fix hang when resuming from STR ARM: pxa: hx4700: Fix backlight PWM device number ARM: OMAP2+: PM: add missing newline to VC warning message
2012-11-16Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull arm64 bugfix from Catalin Marinas: "Arm64 page permission bug fix. Without this fix, the CPU speculatively accesses the interrupt controller memory causing random IRQ acknowledge." * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: arm64: Distinguish between user and kernel XN bits
2012-11-16arm64: Distinguish between user and kernel XN bitsCatalin Marinas
On AArch64, the meaning of the XN bit has changed to UXN (user). The PXN (privileged) bit must be set to prevent kernel execution. Without the PXN bit set, the CPU may speculatively access device memory. This patch ensures that all the mappings that the kernel must not execute from (including user mappings) have the PXN bit set. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2012-11-16Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesArnd Bergmann
From Nicolas Ferre <nicolas.ferre@atmel.com>: Two little fixes, one related to the move to sparse irq and another one fixing the check of a GPIO for USB host overcurrent. * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: ARM: at91/usbh: fix overcurrent gpio setup ARM: at91/AT91SAM9G45: fix crypto peripherals irq issue due to sparse irq support Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-16Merge tag 'imx-fixes-rc' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Arnd Bergmann
fixes From Sascha Hauer <s.hauer@pengutronix.de>: ARM i.MX fixes for 3.7-rc * tag 'imx-fixes-rc' of git://git.pengutronix.de/git/imx/linux-2.6: ARM: imx: ehci: fix host power mask bit ARM i.MX: fix error-valued pointer dereference in clk_register_gate2() Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 patches from Martin Schwidefsky: "Some more bug fixes and a config change. The signal bug is nasty, if the clock_gettime vdso function is interrupted by a signal while in access-register-mode we end up with an endless signal loop until the signal stack is full. The config change is for aligned struct pages, gives us 8% improvement with hackbench." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/3215: fix tty close handling s390/mm: have 16 byte aligned struct pages s390/gup: fix access_ok() usage in __get_user_pages_fast() s390/gup: add missing TASK_SIZE check to get_user_pages_fast() s390/topology: fix core id vs physical package id mix-up s390/signal: set correct address space control
2012-11-16ARM: imx: ehci: fix host power mask bitChristoph Fritz
This patch sets HPM (Host power mask bit) to bit 16 according to i.MX Reference Manual. Falsely it was set to bit 8, but this controls pull-up Impedance. Reported-by: Michael Burkey <mdburkey@gmail.com> Cc: Stable <stable@vger.kernel.org> Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Acked-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-11-16ARM i.MX: fix error-valued pointer dereference in clk_register_gate2()Wei Yongjun
The error-valued pointer clk is used for the arg of kfree, it should be kfree(gate) if clk_register() return ERR_PTR(). dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-11-16ARM: at91/usbh: fix overcurrent gpio setupJohan Hovold
Use gpio_is_valid also for overcurrent pins (which are currently negative in many board files). Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-11-16ARM: at91/AT91SAM9G45: fix crypto peripherals irq issue due to sparse irq ↵Nicolas Royer
support Spare irq support introduced by commit 8fe82a5 (ARM: at91: sparse irq support) involves to add the NR_IRQS_LEGACY offset to irq number. Signed-off-by: Nicolas Royer <nicolas@eukrea.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Eric Bénard <eric@eukrea.com> Tested-by: Eric Bénard <eric@eukrea.com> Cc: stable@vger.kernel.org # 3.6
2012-11-15Merge tag 'for-linus' of git://github.com/gxt/linuxLinus Torvalds
Pull unicore32 update from Guan Xuetao. * tag 'for-linus' of git://github.com/gxt/linux: arch/unicore32: remove CONFIG_EXPERIMENTAL unicore32: switch to generic sys_execve() unicore32: switch to generic kernel_thread()/kernel_execve() unicore32: Use Kbuild infrastructure for kvm_para.h UAPI: (Scripted) Disintegrate arch/unicore32/include/asm UniCore32-bugfix: Remove definitions in asm/bug.h to solve difference between native and cross compiler UniCore32-bugfix: fix mismatch return value of __xchg_bad_pointer UniCore32 bugfix: add missed CONFIG_ZONE_DMA unicore32/mm/fault.c: Port OOM changes to do_pf
2012-11-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS update from Ralf Baechle: "To avoid unnecessary risk and work the preemption fixes are combined with some preparatory work that isn't strictly required. So it's really just 3 fixes: - Get is_compat_task() to do the right thing while simplifying it. The unnecessary complexity hid a rarely striking bug which could be triggered by ext3/ext4 under certain circumstances. - Resolve a preemption issue in the irqflags.h functions for kernels built to support pre-MIPS32 / pre-MIPS64 Release 2 processors. - Fix the interrupt number of the MIPS Malta's CBUS UART." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: Malta: Fix interupt number of CBUS UART. MIPS: Make irqflags.h functions preempt-safe for non-mipsr2 cpus MIPS: Remove irqflags.h dependency from bitops.h MIPS: bitops.h: Change use of 'unsigned short' to 'int' MIPS: compat: Delete now unused TIF_32BIT. MIPS: compat: Implement is_compat_task() by testing for 32-bit address space. MIPS: compat: Fix use of TIF_32BIT_ADDR vs _TIF_32BIT_ADDR
2012-11-13MIPS: Malta: Fix interupt number of CBUS UART.Ralf Baechle
The CBUS UART's interrupt number was wrong conflicting with the interrupt being tied to the Intel PIIX4. Since the PIIX4's interrupt is registered before the CBUS UART which is not being used on most systems this would not be noticed. Attempts to open the ttyS2 CBUS UART would result in: genirq: Flags mismatch irq 18. 00000000 (serial) vs. 00010000 (XT-PIC cascade) serial_link_irq_chain: request failed: -16 for irq: 18 Qemu was written to match the kernel so will need to be fixed also. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-13s390/mm: have 16 byte aligned struct pagesHeiko Carstens
Select HAVE_ALIGNED_STRUCT_PAGE on s390, so that the slub allocator can make use of compare and swap double for lockless updates. This increases the size of struct page to 64 bytes (instead of 56 bytes), however the performance gain justifies the increased size: - now excactly four struct pages fit into a single cache line; the case that accessing a struct page causes two cache line loads does not exist anymore. - calculating the offset of a struct page within the memmap array is only a simple shift instead of a more expensive multiplication. A "hackbench 200 process 200" run on a 32 cpu system did show an 8% runtime improvement. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-13s390/gup: fix access_ok() usage in __get_user_pages_fast()Heiko Carstens
access_ok() returns always "true" on s390. Therefore all access_ok() invocations are rather pointless. However when walking page tables we need to make sure that everything is within bounds of the ASCE limit of the task's address space. So remove the access_ok() call and add the same check we have in get_user_pages_fast(). Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-13s390/gup: add missing TASK_SIZE check to get_user_pages_fast()Heiko Carstens
When walking page tables we need to make sure that everything is within bounds of the ASCE limit of the task's address space. Otherwise we might calculate e.g. a pud pointer which is not within a pud and dereference it. So check against TASK_SIZE (which is the ASCE limit) before walking page tables. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: stable@vger.kernel.org Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-12Merge git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fix from Marcelo Tosatti: "A correction for user triggerable oops" * git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: invalid opcode oops on SET_SREGS with OSXSAVE bit set (CVE-2012-4461)
2012-11-12KVM: x86: invalid opcode oops on SET_SREGS with OSXSAVE bit set (CVE-2012-4461)Petr Matousek
On hosts without the XSAVE support unprivileged local user can trigger oops similar to the one below by setting X86_CR4_OSXSAVE bit in guest cr4 register using KVM_SET_SREGS ioctl and later issuing KVM_RUN ioctl. invalid opcode: 0000 [#2] SMP Modules linked in: tun ip6table_filter ip6_tables ebtable_nat ebtables ... Pid: 24935, comm: zoog_kvm_monito Tainted: G D 3.2.0-3-686-pae EIP: 0060:[<f8b9550c>] EFLAGS: 00210246 CPU: 0 EIP is at kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] EAX: 00000001 EBX: 000f387e ECX: 00000000 EDX: 00000000 ESI: 00000000 EDI: 00000000 EBP: ef5a0060 ESP: d7c63e70 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process zoog_kvm_monito (pid: 24935, ti=d7c62000 task=ed84a0c0 task.ti=d7c62000) Stack: 00000001 f70a1200 f8b940a9 ef5a0060 00000000 00200202 f8769009 00000000 ef5a0060 000f387e eda5c020 8722f9c8 00015bae 00000000 ed84a0c0 ed84a0c0 c12bf02d 0000ae80 ef7f8740 fffffffb f359b740 ef5a0060 f8b85dc1 0000ae80 Call Trace: [<f8b940a9>] ? kvm_arch_vcpu_ioctl_set_sregs+0x2fe/0x308 [kvm] ... [<c12bfb44>] ? syscall_call+0x7/0xb Code: 89 e8 e8 14 ee ff ff ba 00 00 04 00 89 e8 e8 98 48 ff ff 85 c0 74 1e 83 7d 48 00 75 18 8b 85 08 07 00 00 31 c9 8b 95 0c 07 00 00 <0f> 01 d1 c7 45 48 01 00 00 00 c7 45 1c 01 00 00 00 0f ae f0 89 EIP: [<f8b9550c>] kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] SS:ESP 0068:d7c63e70 QEMU first retrieves the supported features via KVM_GET_SUPPORTED_CPUID and then sets them later. So guest's X86_FEATURE_XSAVE should be masked out on hosts without X86_FEATURE_XSAVE, making kvm_set_cr4 with X86_CR4_OSXSAVE fail. Userspaces that allow specifying guest cpuid with X86_FEATURE_XSAVE even on hosts that do not support it, might be susceptible to this attack from inside the guest as well. Allow setting X86_CR4_OSXSAVE bit only if host has XSAVE support. Signed-off-by: Petr Matousek <pmatouse@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-11-12ARM: boot: Fix usage of kechoFabio Estevam
Since commit edc88ceb0 (ARM: be really quiet when building with 'make -s') the following output is generated when building a kernel for ARM: echo ' Kernel: arch/arm/boot/Image is ready' Kernel: arch/arm/boot/Image is ready Building modules, stage 2. echo ' Kernel: arch/arm/boot/zImage is ready' Kernel: arch/arm/boot/zImage is ready As per Documentation/kbuild/makefiles.txt the correct way of using kecho is '@$(kecho)'. Make this change so no more unwanted 'echo' messages are displayed. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-12Merge tag 'omap-for-v3.7-rc4/fixes-signed' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes From Tony Lindgren <tony@atomide.com>: Minor OMAP PM and hwmod fixes for v3.7-rc series via Kevin Hilman and Paul Walmsley. * tag 'omap-for-v3.7-rc4/fixes-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP4: PM: fix regulator name for VDD_MPU ARM: OMAP4: hwmod data: do not enable or reset the McPDM during kernel init ARM: OMAP2+: hwmod: add flag to prevent hwmod code from touching IP block during init ARM: OMAP: hwmod: wait for sysreset complete after enabling hwmod ARM: OMAP2+: clockdomain: Fix OMAP4 ISS clk domain to support only SWSUP ARM: OMAP2+: PM: add missing newline to VC warning message Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-12Merge tag 'omap-for-v3.7-rc4/musb-regression-signed' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes From Tony Lindgren <tony@atomide.com>: This series fixes an annoying regression to make MUSB working on omap4 again. Although it's getting rather late for these changes for the -rc cycle, it is important as many devices are using MUSB for charging and connectivity. With the USB PHY changes, MUSB started using the newly added drivers/usb/phy/omap-usb2.c driver introduced by commit 657b306a (usb: phy: add a new driver for omap usb2 phy) that is using the newly introduced drivers/bus/omap-ocp2scp.c introduced by commit 26a84b3e (drivers: bus: add a new driver for omap-ocp2scp). These changes allowed dropping a lot of PHY related code from arch/arm/mach-omap2/omap_phy_internal.c and have it live in the device driver like it should with commit c9e4412a (arm: omap: phy: remove unused functions from omap-phy-internal.c). However, MUSB on omap4 broke with these changes for legacy platform data boot, and now only works with device tree for omap4. Unfortunately we are still few critical bindings away from being able to make omap4 usbale with device tree. Fix the regression properly by adding platform data support to the ocp2scp driver so we can avoid adding back the driver code to arch/arm/mach-omap2. * tag 'omap-for-v3.7-rc4/musb-regression-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP: ocp2scp: create omap device for ocp2scp ARM: OMAP4: add _dev_attr_ to ocp2scp for representing usb_phy drivers: bus: ocp2scp: add pdata support Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-12s390/topology: fix core id vs physical package id mix-upHeiko Carstens
The current topology code confuses core id vs physical package id. In other words /sys/devices/system/cpu/cpuX/topology/core_id displays the physical_package_id (aka socket id) instead of the core id. The physical_package_id sysfs attribute always displays "-1" instead of the socket id. Fix this mix-up with a small patch which defines and initializes topology_physical_package_id correctly and fixes the broken core id handling. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-12s390/signal: set correct address space controlMartin Schwidefsky
If user space is running in primary mode it can switch to secondary or access register mode, this is used e.g. in the clock_gettime code of the vdso. If a signal is delivered to the user space process while it has been running in access register mode the signal handler is executed in access register mode as well which will result in a crash most of the time. Set the address space control bits in the PSW to the default for the execution of the signal handler and make sure that the previous address space control is restored on signal return. Take care that user space can not switch to the kernel address space by modifying the registers in the signal frame. Cc: stable@vger.kernel.org Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-11Merge 3.7-rc5 into staging-nextGreg Kroah-Hartman
2012-11-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: "Several build/bug fixes for sparc, including: 1) Configuring a mix of static vs. modular sparc64 crypto modules didn't work, remove an ill-conceived attempt to only have to build the device match table for these drivers once to fix the problem. Reported by Meelis Roos. 2) Make the montgomery multiple/square and mpmul instructions actually usable in 32-bit tasks. Essentially this involves providing 32-bit userspace with a way to use a 64-bit stack when it needs to. 3) Our sparc64 atomic backoffs don't yield cpu strands properly on Niagara chips. Use pause instruction when available to achieve this, otherwise use a benign instruction we know blocks the strand for some time. 4) Wire up kcmp 5) Fix the build of various drivers by removing the unnecessary blocking of OF_GPIO when SPARC. 6) Fix unintended regression wherein of_address_to_resource stopped being provided. Fix from Andreas Larsson. 7) Fix NULL dereference in leon_handle_ext_irq(), also from Andreas Larsson." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Fix build with mix of modular vs. non-modular crypto drivers. sparc: Support atomic64_dec_if_positive properly. of/address: sparc: Declare of_address_to_resource() as an extern function for sparc again sparc32, leon: Check for existent irq_map entry in leon_handle_ext_irq sparc: Add sparc support for platform_get_irq() sparc: Allow OF_GPIO on sparc. qlogicpti: Fix build warning. sparc: Wire up sys_kcmp. sparc64: Improvde documentation and readability of atomic backoff code. sparc64: Use pause instruction when available. sparc64: Fix cpu strand yielding. sparc64: Make montmul/montsqr/mpmul usable in 32-bit threads.
2012-11-10Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull arm64 fixes from Catalin Marinas: - correct argument type (pgprot_t) when calling __ioremap() - PCI_IOBASE virtual address change - use architected event for CPU cycle counter - fix ELF core dumping - select CONFIG_ARCH_WANT_COMPAT_IPC_PARSE_VERSION - missing completion for secondary CPU boot - booting on systems with all memory beyond 4GB * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: arm64: mm: fix booting on systems with no memory below 4GB arm64: smp: add missing completion for secondary boot arm64: compat: select CONFIG_ARCH_WANT_COMPAT_IPC_PARSE_VERSION arm64: elf: fix core dumping definitions for GP and FP registers arm64: perf: use architected event for CPU cycle counter arm64: Move PCI_IOBASE closer to MODULES_VADDR arm64: Use pgprot_t as the last argument when invoking __ioremap()
2012-11-10Merge tag 'stable/for-linus-3.7-rc5-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen fixes from Konrad Rzeszutek Wilk: "There are three ARM compile fixes (we forgot to export certain functions and if the drivers are built as an module - we go belly-up). There is also an mismatch of irq_enter() / exit_idle() calls sequence which were fixed some time ago in other piece of codes, but failed to appear in the Xen code. Lastly a fix for to help in the field with troubleshooting in case we cannot get the appropriate parameter and also fallback code when working with very old hypervisors." Bug-fixes: - Fix compile issues on ARM. - Fix hypercall fallback code for old hypervisors. - Print out which HVM parameter failed if it fails. - Fix idle notifier call after irq_enter. * tag 'stable/for-linus-3.7-rc5-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/arm: Fix compile errors when drivers are compiled as modules (export more). xen/arm: Fix compile errors when drivers are compiled as modules. xen/generic: Disable fallback build on ARM. xen/events: fix RCU warning, or Call idle notifier after irq_enter() xen/hvm: If we fail to fetch an HVM parameter print out which flag it is. xen/hypercall: fix hypercall fallback code for very old hypervisors
2012-11-09sparc64: Fix build with mix of modular vs. non-modular crypto drivers.David S. Miller
We tried linking in a single built object to hold the device table, but only works if all of the sparc64 crypto modules get built the same way (modular vs. non-modular). Just include the device ID stub into each driver source file so that the table gets compiled into the correct result in all cases. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09sparc: Support atomic64_dec_if_positive properly.David S. Miller
Sparc32 already supported it, as a consequence of using the generic atomic64 implementation. And the sparc64 implementation is rather trivial. This allows us to set ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE for all of sparc, and avoid the annoying warning from lib/atomic64_test.c Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09of/address: sparc: Declare of_address_to_resource() as an extern function ↵Andreas Larsson
for sparc again This bug-fix makes sure that of_address_to_resource is defined extern for sparc so that the sparc-specific implementation of of_address_to_resource() is once again used when including include/linux/of_address.h in a sparc context. A number of drivers in mainline relies on this function working for sparc. The bug was introduced in a850a7554442f08d3e910c6eeb4ee216868dda1e, "of/address: add empty static inlines for !CONFIG_OF". Contrary to that commit title, the static inlines are added for !CONFIG_OF_ADDRESS, and CONFIG_OF_ADDRESS is never defined for sparc. This is good behavior for the other functions in include/linux/of_address.h, as the extern functions defined in drivers/of/address.c only gets linked when OF_ADDRESS is configured. However, for of_address_to_resource there exists a sparc-specific implementation in arch/sparc/arch/sparc/kernel/of_device_common.c Solution suggested by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andreas Larsson <andreas@gaisler.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09sparc32, leon: Check for existent irq_map entry in leon_handle_ext_irqAndreas Larsson
If an irq is being unlinked concurrently with leon_handle_ext_irq, irq_map[eirq] might be null in leon_handle_ext_irq. Make sure that this is not dereferenced. Signed-off-by: Andreas Larsson <andreas@gaisler.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09xen/arm: Fix compile errors when drivers are compiled as modules (export more).Stefano Stabellini
The commit 911dec0db4de6ccc544178a8ddaf9cec0a11d533 "xen/arm: Fix compile errors when drivers are compiled as modules." exports the neccessary functions. But to guard ourselves against out-of-tree modules and future drivers hitting this, lets export all of the relevant hypercalls. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-11-09MIPS: Make irqflags.h functions preempt-safe for non-mipsr2 cpusJim Quinlan
For non MIPSr2 processors, such as the BMIPS 5000, calls to arch_local_irq_disable() and others may be preempted, and in doing so a stale value may be restored to c0_status. This fix disables preemption for such processors prior to the call and enables it after the call. Those functions that needed this fix have been "outlined" to mips-atomic.c, as they are no longer good candidates for inlining. This bug was observed in a BMIPS 5000, occuring once every few hours in a continuous reboot test. It was traced to the write_lock_irq() function which was being invoked in release_task() in exit.c. By placing a number of "nops" inbetween the mfc0/mtc0 pair in arch_local_irq_disable(), which is called by write_lock_irq(), we were able to greatly increase the occurance of this bug. Similarly, the application of this commit silenced the bug. Signed-off-by: Jim Quinlan <jim2101024@gmail.com> Cc: linux-mips@linux-mips.org Cc: David Daney <ddaney.cavm@gmail.com> Cc: Kevin Cernekee cernekee@gmail.com Cc: Jim Quinlan <jim2101024@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/4321/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-09MIPS: Remove irqflags.h dependency from bitops.hJim Quinlan
The "else clause" of most functions in bitops.h invoked raw_local_irq_{save,restore}() and in doing so had a dependency on irqflags.h. This fix moves said code to bitops.c, removing the dependency. Signed-off-by: Jim Quinlan <jim2101024@gmail.com> Cc: linux-mips@linux-mips.org Cc: David Daney <ddaney.cavm@gmail.com> Cc: Kevin Cernekee cernekee@gmail.com Cc: Jim Quinlan <jim2101024@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/4320/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-09MIPS: bitops.h: Change use of 'unsigned short' to 'int'Jim Quinlan
[ralf@linux-mips.org: No functional change but it's consistent with how use types elsewhere in the code.] Signed-off-by: Jim Quinlan <jim2101024@gmail.com> Cc: linux-mips@linux-mips.org Cc: David Daney <ddaney.cavm@gmail.com> Cc: Kevin Cernekee cernekee@gmail.com Cc: Jim Quinlan <jim2101024@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/4319/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-09MIPS: compat: Delete now unused TIF_32BIT.Ralf Baechle
2012-11-09MIPS: compat: Implement is_compat_task() by testing for 32-bit address space.Ralf Baechle
So far is_compat_task() was testing for 32-bit registers if O32 support was enabled and if O32 support was disabled but N32 enabled it was testing for 32-bit address space. So if both O32 and N32 were enabled a N32 task was not considered a compat task, whops. This still leaves potential cases where O32 and N32 need different treatment unsolved. But that's another commit. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-09MIPS: compat: Fix use of TIF_32BIT_ADDR vs _TIF_32BIT_ADDRRalf Baechle
2012-11-09arch/unicore32: remove CONFIG_EXPERIMENTALKees Cook
This config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it. CC: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
2012-11-09unicore32: switch to generic sys_execve()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-and-Tested-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
2012-11-09unicore32: switch to generic kernel_thread()/kernel_execve()Al Viro
2012-11-09unicore32: Use Kbuild infrastructure for kvm_para.hGuan Xuetao
All the headers but kvm_para.h use the Kbuild infrastructure to get to the asm-generic headers. Cc: linux-kbuild@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
2012-11-09UAPI: (Scripted) Disintegrate arch/unicore32/include/asmDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
