commit 86fd887b7fe350819dae5b55e7fef05b511c8656 upstream.
Commit 20cde694027e ("x86, ia64: Move EFI_FB vga_default_device()
initialization to pci_vga_fixup()") moved boot video device detection from
efifb to x86 and ia64 pci/fixup.c.
For dual-GPU Apple computers above change represents a regression as code
in efifb did forcefully override vga_default_device while the merge did not
(vgaarb happens prior to PCI fixup).
To improve on initial device selection by vgaarb (it cannot know if PCI
device not behind bridges see/decode legacy VGA I/O or not), move the
screen_info based check from pci_video_fixup() to vgaarb's init function and
use it to refine/override decision taken while adding the individual PCI
VGA devices. This way PCI fixup has no reason to adjust vga_default_device
anymore but can depend on its value for flagging shadowed VBIOS.
This has the nice benefit of removing duplicated code but does introduce a
#if defined() block in vgaarb. Not all architectures have screen_info and
would cause compile to fail without it.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=84461
Reported-and-Tested-By: Andreas Noever <andreas.noever@gmail.com>
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Matthew Garrett <matthew.garrett@nebula.com>
commit 20cde694027e7477cc532833e38ab9fcaa83fb64 upstream.
Commit b4aa0163056b ("efifb: Implement vga_default_device() (v2)") added
efifb vga_default_device() so EFI systems that do not load shadow VBIOS or
setup VGA get proper value for boot_vga PCI sysfs attribute on the
corresponding PCI device.
Xorg doesn't detect devices when boot_vga=0, e.g., on some EFI systems such
as MacBookAir2,1. Xorg detects the GPU and finds the DRI device but then
bails out with "no devices detected".
Note: When vga_default_device() is set boot_vga PCI sysfs attribute
reflects its state. When unset this attribute is 1 whenever
IORESOURCE_ROM_SHADOW flag is set.
With introduction of sysfb/simplefb/simpledrm efifb is getting obsolete
while having native drivers for the GPU also makes selecting sysfb/efifb
optional.
Remove the efifb implementation of vga_default_device() and initialize
vgaarb's vga_default_device() with the PCI GPU that matches boot
screen_info in pci_fixup_video().
[bhelgaas: remove unused "dev" in efifb_setup()]
Fixes: b4aa0163056b ("efifb: Implement vga_default_device() (v2)")
Tested-by: Anibal Francisco Martinez Cortina <linuxkid.zeuz@gmail.com>
Acked-by: Matthew Garrett <matthew.garrett@nebula.com>
commit af438fec6cb99fc2e2faf8b16b865af26ce722e6 upstream.
Use the corresponding compatibles to identify the devices.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
Tested-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
ref-cycles event is specially to Intel core, but can still used in arm
architecture with the wrong return value with 3.10 stable. this patch fix the
bug and make it return NOT SUPPORTED distinctly.
In upstream this bug has been fixed by other way, which changes more than one
file and more than 1000 lines. the primary commit is
6b7658ec8a100b608e59e3cde353434db51f5be0. besides we can not simply
cherry-pick.
Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com>
Cc: Mark Rutland <mark.rutland@arm.com
Cc: Christopher Covington <cov@codeaurora.org>
commit d26a7730b5874a5fa6779c62f4ad7c5065a94723 upstream.
In spite of what the GCC manual says, the -mfast-indirect-calls has
never been supported in the 64-bit parisc compiler. Indirect calls have
always been done using function descriptors irrespective of the
-mfast-indirect-calls option.
Recently, it was noticed that a function descriptor was always requested
when the -mfast-indirect-calls option was specified. This caused
problems when the option was used in application code and doesn't make
any sense because the whole point of the option is to avoid using a
function descriptor for indirect calls.
Fixing this broke 64-bit kernel builds.
I will fix GCC but for now we need the attached change. This results in
the same kernel code as before.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
commit 89206491201cbd1571009b36292af781cef74c1b upstream.
The current LWS cas only works correctly for 32bit. The new LWS allows
for CAS operations of variable size.
Signed-off-by: Guy Martin <gmsoft@tuxicoman.be>
commit 78e05b1421fa41ae8457701140933baa5e7d9479 upstream.
Similar to the previous commit which described why we need to add a
barrier to arch_spin_is_locked(), we have a similar problem with
spin_unlock_wait().
We need a barrier on entry to ensure any spinlock we have previously
taken is visibly locked prior to the load of lock->slock.
It's also not clear if spin_unlock_wait() is intended to have ACQUIRE
semantics. For now be conservative and add a barrier on exit to give it
ACQUIRE semantics.
commit 51d7d5205d3389a32859f9939f1093f267409929 upstream.
The kernel defines the function spin_is_locked(), which can be used to
check if a spinlock is currently locked.
Using spin_is_locked() on a lock you don't hold is obviously racy. That
is, even though you may observe that the lock is unlocked, it may become
locked at any time.
There is (at least) one exception to that, which is if two locks are
used as a pair, and the holder of each checks the status of the other
before doing any update.
Assuming *A and *B are two locks, and *COUNTER is a shared non-atomic
value:
The first CPU does:
spin_lock(*A)
if spin_is_locked(*B)
# nothing
else
smp_mb()
LOAD r = *COUNTER
r++
STORE *COUNTER = r
spin_unlock(*A)
And the second CPU does:
spin_lock(*B)
if spin_is_locked(*A)
# nothing
else
smp_mb()
LOAD r = *COUNTER
r++
STORE *COUNTER = r
spin_unlock(*B)
Although this is a strange locking construct, it should work.
It seems to be understood, but not documented, that spin_is_locked() is
not a memory barrier, so in the examples above and below the caller
inserts its own memory barrier before acting on the result of
spin_is_locked().
For now we assume spin_is_locked() is implemented as below, and we break
it out in our examples:
bool spin_is_locked(*LOCK) {
LOAD l = *LOCK
return l.locked
Our intuition is that there should be no problem even if the two code
sequences run simultaneously such as:
CPU 0 CPU 1
spin_lock(*A) spin_lock(*B)
LOAD b = *B LOAD a = *A
if b.locked # true if a.locked # true
# nothing # nothing
spin_unlock(*A) spin_unlock(*B)
If one CPU gets the lock before the other then it will do the update and
the other CPU will back off:
CPU 0 CPU 1
spin_lock(*A)
LOAD b = *B
spin_lock(*B)
if b.locked # false LOAD a = *A
else if a.locked # true
smp_mb() # nothing
LOAD r1 = *COUNTER spin_unlock(*B)
r1++
STORE *COUNTER = r1
spin_unlock(*A)
However in reality spin_lock() itself is not indivisible. On powerpc we
implement it as a load-and-reserve and store-conditional.
Ignoring the retry logic for the lost reservation case, it boils down to:
spin_lock(*LOCK) {
LOAD l = *LOCK
l.locked = true
STORE *LOCK = l
ACQUIRE_BARRIER
The ACQUIRE_BARRIER is required to give spin_lock() ACQUIRE semantics as
defined in memory-barriers.txt:
This acts as a one-way permeable barrier. It guarantees that all
memory operations after the ACQUIRE operation will appear to happen
after the ACQUIRE operation with respect to the other components of
the system.
On modern powerpc systems we use lwsync for ACQUIRE_BARRIER. lwsync is
also know as "lightweight sync", or "sync 1".
As described in Power ISA v2.07 section B.2.1.1, in this scenario the
lwsync is not the barrier itself. It instead causes the LOAD of *LOCK to
act as the barrier, preventing any loads or stores in the locked region
from occurring prior to the load of *LOCK.
Whether this behaviour is in accordance with the definition of ACQUIRE
semantics in memory-barriers.txt is open to discussion, we may switch to
a different barrier in future.
What this means in practice is that the following can occur:
CPU 0 CPU 1
LOAD a = *A LOAD b = *B
a.locked = true b.locked = true
STORE *A = a STORE *B = b
if b.locked # false if a.locked # false
else else
smp_mb() smp_mb()
LOAD r1 = *COUNTER LOAD r2 = *COUNTER
r1++ r2++
STORE *COUNTER = r1
STORE *COUNTER = r2 # Lost update
That is, the load of *B can occur prior to the store that makes *A
visibly locked. And similarly for CPU 1. The result is both CPUs hold
their lock and believe the other lock is unlocked.
The easiest fix for this is to add a full memory barrier to the start of
spin_is_locked(), so adding to our previous definition would give us:
smp_mb()
LOAD l = *LOCK
return l.locked
The new barrier orders the store to the lock we are locking vs the load
of the other lock:
CPU 0 CPU 1
smp_mb() smp_mb()
# nothing # nothing
Although the above example is theoretical, there is code similar to this
example in sem_lock() in ipc/sem.c. This commit in addition to the next
commit appears to be a fix for crashes we are seeing in that code where
we believe this race happens in practice.
commit 85101af13bb854a6572fa540df7c7201958624b9 upstream.
ABIv2 kernels are failing to backtrace through the kernel. An example:
39.30% readseek2_proce [kernel.kallsyms] [k] find_get_entry
--- find_get_entry
__GI___libc_read
The problem is in valid_next_sp() where we check that the new stack
pointer is at least STACK_FRAME_OVERHEAD below the previous one.
ABIv1 has a minimum stack frame size of 112 bytes consisting of 48 bytes
and 64 bytes of parameter save area. ABIv2 changes that to 32 bytes
with no paramter save area.
STACK_FRAME_OVERHEAD is in theory the minimum stack frame size,
but we over 240 uses of it, some of which assume that it includes
space for the parameter area.
We need to work through all our stack defines and rationalise them
but let's fix perf now by creating STACK_FRAME_MIN_SIZE and using
in valid_next_sp(). This fixes the issue:
30.64% readseek2_proce [kernel.kallsyms] [k] find_get_entry
--- find_get_entry
pagecache_get_page
generic_file_read_iter
new_sync_read
vfs_read
sys_read
syscall_exit
__GI___libc_read
Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 03bd4e1f7265548832a76e7919a81f3137c44fd1 upstream.
The following bug can be triggered by hot adding and removing a large number of
xen domain0's vcpus repeatedly:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [..] find_busiest_group
PGD 5a9d5067 PUD 13067 PMD 0
Oops: 0000 [#3] SMP
Call Trace:
load_balance
? _raw_spin_unlock_irqrestore
idle_balance
__schedule
schedule
schedule_timeout
? lock_timer_base
schedule_timeout_uninterruptible
msleep
lock_device_hotplug_sysfs
online_store
dev_attr_store
sysfs_write_file
vfs_write
SyS_write
system_call_fastpath
Last level cache shared mask is built during CPU up and the
build_sched_domain() routine takes advantage of it to setup
the sched domain CPU topology.
However, llc_shared_mask is not released during CPU disable,
which leads to an invalid sched domainCPU topology.
This patch fix it by releasing the llc_shared_mask correctly
during CPU disable.
Yasuaki also reported that this can happen on real hardware:
https://lkml.org/lkml/2014/7/22/1018
His case is here:
Here is an example on my system.
My system has 4 sockets and each socket has 15 cores and HT is
enabled. In this case, each core of sockes is numbered as
follows:
| CPU#
Socket#0 | 0-14 , 60-74
Socket#1 | 15-29, 75-89
Socket#2 | 30-44, 90-104
Socket#3 | 45-59, 105-119
Then llc_shared_mask of CPU#30 has 0x3fff80000001fffc0000000.
It means that last level cache of Socket#2 is shared with
CPU#30-44 and 90-104.
When hot-removing socket#2 and #3, each core of sockets is
numbered as follows:
| CPU#
But llc_shared_mask is not cleared. So llc_shared_mask of CPU#30
remains having 0x3fff80000001fffc0000000.
After that, when hot-adding socket#2 and #3, each core of
sockets is numbered as follows:
| CPU#
Socket#2 | 30-59
Socket#3 | 90-119
Then llc_shared_mask of CPU#30 becomes
0x3fff8000fffffffc0000000. It means that last level cache of
Socket#2 is shared with CPU#30-59 and 90-104. So the mask has
the wrong value.
Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com>
Tested-by: Linn Crosetto <linn@hp.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Link: http://lkml.kernel.org/r/1411547885-48165-1-git-send-email-wanpeng.li@linux.intel.com
commit 0cacbfbeb5077b63d5d3cf6df88b14ac12ad584b upstream.
The KASLR location-choosing logic needs to avoid the setup_data
list memory areas as well. Without this, it would be possible to
have the ASLR position stomp on the memory, ultimately causing
the boot to fail.
Tested-by: Baoquan He <bhe@redhat.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: Pavel Machek <pavel@ucw.cz>
Link: http://lkml.kernel.org/r/20140911161931.GA12001@www.outflux.net
commit 3eddc69ffeba092d288c386646bfa5ec0fce25fd upstream.
3.16 kernel boot fail with earlyprintk=efi, it keeps scrolling at the
bottom line of screen.
Bisected, the first bad commit is below:
commit 86dfc6f339886559d80ee0d4bd20fe5ee90450f0
Author: Lv Zheng <lv.zheng@intel.com>
Date: Fri Apr 4 12:38:57 2014 +0800
ACPICA: Tables: Fix table checksums verification before installation.
I did some debugging by enabling both serial and efi earlyprintk, below is
some debug dmesg, seems early_ioremap fails in scroll up function due to
no free slot, see below dmesg output:
WARNING: CPU: 0 PID: 0 at mm/early_ioremap.c:116 __early_ioremap+0x90/0x1c4()
__early_ioremap(ed00c800, 00000c80) not found slot
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.17.0-rc1+ #204
Hardware name: Hewlett-Packard HP Z420 Workstation/1589, BIOS J61 v03.15 05/09/2013
Call Trace:
dump_stack+0x4e/0x7a
warn_slowpath_common+0x75/0x8e
? __early_ioremap+0x90/0x1c4
warn_slowpath_fmt+0x47/0x49
? sprintf+0x46/0x48
early_ioremap+0x13/0x15
early_efi_map+0x24/0x26
early_efi_scroll_up+0x6d/0xc0
early_efi_write+0x1b0/0x214
call_console_drivers.constprop.21+0x73/0x7e
console_unlock+0x151/0x3b2
? vprintk_emit+0x49f/0x532
vprintk_emit+0x521/0x532
? console_unlock+0x383/0x3b2
printk+0x4f/0x51
acpi_os_vprintf+0x2b/0x2d
acpi_os_printf+0x43/0x45
acpi_info+0x5c/0x63
? __acpi_map_table+0x13/0x18
? acpi_os_map_iomem+0x21/0x147
acpi_tb_print_table_header+0x177/0x186
acpi_tb_install_table_with_override+0x4b/0x62
acpi_tb_install_standard_table+0xd9/0x215
? early_ioremap+0x13/0x15
acpi_tb_parse_root_table+0x16e/0x1b4
acpi_initialize_tables+0x57/0x59
acpi_table_init+0x50/0xce
acpi_boot_table_init+0x1e/0x85
setup_arch+0x9b7/0xcc4
start_kernel+0x94/0x42d
? early_idt_handlers+0x120/0x120
x86_64_start_reservations+0x2a/0x2c
x86_64_start_kernel+0xf3/0x100
Quote reply from Lv.zheng about the early ioremap slot usage in this case:
In early_efi_scroll_up(), 2 mapping entries will be used for the src/dst screen buffer.
In drivers/acpi/acpica/tbutils.c, we've improved the early table loading code in acpi_tb_parse_root_table().
We now need 2 mapping entries:
1. One mapping entry is used for RSDT table mapping. Each RSDT entry contains an address for another ACPI table.
2. For each entry in RSDP, we need another mapping entry to map the table to perform necessary check/override before installing it.
When acpi_tb_parse_root_table() prints something through EFI earlyprintk console, we'll have 4 mapping entries used.
The current 4 slots setting of early_ioremap() seems to be too small for such a use case.
Thus increase the slot to 8 in this patch to fix this issue.
boot-time mappings become 512 page with this patch.
Signed-off-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit 0b5a50635fc916cf46e3de0b819a61fc3f17e7ee upstream.
When RANDOMIZE_BASE (KASLR) is enabled; or the sum of all loaded
modules exceeds 512 MiB, then loading modules fails with a warning
(and hence a vmalloc allocation failure) because the PTEs for the
newly-allocated vmalloc address space are not zero.
WARNING: CPU: 0 PID: 494 at linux/mm/vmalloc.c:128
vmap_page_range_noflush+0x2a1/0x360()
This is caused by xen_setup_kernel_pagetables() copying
level2_kernel_pgt into level2_fixmap_pgt, overwriting many non-present
entries.
Without KASLR, the normal kernel image size only covers the first half
of level2_kernel_pgt and module space starts after that.
L4[511]->level3_kernel_pgt[510]->level2_kernel_pgt[ 0..255]->kernel
[256..511]->module
[511]->level2_fixmap_pgt[ 0..505]->module
This allows 512 MiB of of module vmalloc space to be used before
having to use the corrupted level2_fixmap_pgt entries.
With KASLR enabled, the kernel image uses the full PUD range of 1G and
module space starts in the level2_fixmap_pgt. So basically:
L4[511]->level3_kernel_pgt[510]->level2_kernel_pgt[0..511]->kernel
[511]->level2_fixmap_pgt[0..505]->module
And now no module vmalloc space can be used without using the corrupt
Fix this by properly converting the level2_fixmap_pgt entries to MFNs,
and setting level1_fixmap_pgt as read-only.
A number of comments were also using the the wrong L3 offset for
level2_kernel_pgt. These have been corrected.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit 1951497d90d6754201af3e65241a06f9ef6755cd upstream.
commit 0944fe3f4a32 ("s390/mm: implement software referenced bits")
triggered another paging/storage key corruption. There is an
unhandled invalid->valid pte change where we have to set the real
storage key from the pgste.
When doing paging a guest page might be swapcache or swap and when
faulted in it might be read-only and due to a parallel scan old.
An do_wp_page will make it writeable and young. Due to software
reference tracking this page was invalid and now becomes valid.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 3e03d4c46daa849880837d802e41c14132a03ef9 upstream.
Since 3.12 or more precisely commit 0944fe3f4a32 ("s390/mm:
implement software referenced bits") guest storage keys get
corrupted during paging. This commit added another valid->invalid
translation for page tables - namely ptep_test_and_clear_young.
We have to transfer the storage key into the pgste in that case.
commit ab3f285f227fec62868037e9b1b1fd18294a83b8 upstream.
The PFMF instruction handler blindly wrote the storage key even if
the page was mapped R/O in the host. Lets try a COW before continuing
and bail out in case of errors.
Reviewed-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
commit 614a80e474b227cace52fd6e3c790554db8a396e upstream.
In the early days, we had some special handling for the
KVM_EXIT_S390_SIEIC exit, but this was gone in 2009 with commit
d7b0b5eb3000 (KVM: s390: Make psw available on all exits, not
just a subset).
Now this switch statement is just a sanity check for userspace
not messing with the kvm_run structure. Unfortunately, this
allows userspace to trigger a kernel BUG. Let's just remove
this switch statement.
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
commit 2520d039728b2a3c5ae7f79fe2a0e9d182855b12 upstream.
Commit 5f888a1d33 (ARM64: perf: support dwarf unwinding in compat mode)
changes user_stack_pointer() to return the compat SP for 32-bit tasks
but without brackets around the whole definition, with possible issues
on the call sites (noticed with a subsequent fix for KSTK_ESP).
Fixes: 5f888a1d33c4 (ARM64: perf: support dwarf unwinding in compat mode)
Reported-by: Sudeep Holla <sudeep.holla@arm.com>
commit 8a574cfa2652545eb95595d38ac2a0bb501af0ae upstream.
Every mcount() call in the MIPS 32-bit kernel is done as follows:
move at, ra
jal _mcount
addiu sp, sp, -8
but upon returning from the mcount() function, the stack pointer
is not adjusted properly. This is explained in details in 58b69401c797
(MIPS: Function tracer: Fix broken function tracing).
Commit ad8c396936e3 ("MIPS: Unbreak function tracer for 64-bit kernel.)
fixed the stack manipulation for 64-bit but it didn't fix it completely
for MIPS32.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/7792/
commit c8c0da6bdf0f0d6f59fc23aab6ee373a131df82d upstream.
Commit bbd426f542cb "MIPS: Simplify FP context access" modified the
SIFROMREG & SIFROMHREG macros such that they return unsigned rather
than signed 32b integers. I had believed that to be fine, but
inadvertently missed the MFC1 & MFHC1 cases which write to a struct
pt_regs regs element. On MIPS32 this is fine, but on 64 bit those
saved regs' fields are 64 bit wide. Using unsigned values caused the
32 bit value from the FP register to be zero rather than sign extended
as the architecture specifies, causing incorrect emulation of the
MFC1 & MFHc1 instructions. Fix by reintroducing the casts to signed
integers, and therefore the sign extension.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/7848/
commit 29593fd5a8149462ed6fad0d522234facdaee6c8 upstream.
Commit dc4d7b37 (MIPS: ZBOOT: gather string functions into string.c)
moved the string related functions into a separate file, which might
cause the following build error, depending on the configuration:
| CC arch/mips/boot/compressed/decompress.o
| In file included from linux/arch/mips/boot/compressed/../../../../lib/decompress_unxz.c:234:0,
| from linux/arch/mips/boot/compressed/decompress.c:67:
| linux/arch/mips/boot/compressed/../../../../lib/xz/xz_dec_stream.c: In function 'fill_temp':
| linux/arch/mips/boot/compressed/../../../../lib/xz/xz_dec_stream.c:162:2: error: implicit declaration of function 'memcpy' [-Werror=implicit-function-declaration]
| cc1: some warnings being treated as errors
| linux/scripts/Makefile.build:308: recipe for target 'arch/mips/boot/compressed/decompress.o' failed
| make[6]: *** [arch/mips/boot/compressed/decompress.o] Error 1
| linux/arch/mips/Makefile:308: recipe for target 'vmlinuz' failed
It does not fail with the standard configuration, as when
CONFIG_DYNAMIC_DEBUG is not enabled <linux/string.h> gets included in
include/linux/dynamic_debug.h. There might be other ways for it to
get indirectly included.
We can't add the include directly in xz_dec_stream.c as some
architectures might want to use a different version for the boot/
directory (see for example arch/x86/boot/string.h).
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Patchwork: https://patchwork.linux-mips.org/patch/7420/
commit 9cc6d9e5daaa147a9a3e31557efcb331989e77be upstream.
Joachim Eastwood reports that commit fbfb872f5f41 "ARM: 8148/1: flush
TLS and thumbee register state during exec" causes a boot-time crash
on a Cortex-M4 nommu system:
Freeing unused kernel memory: 68K (281e5000 - 281f6000)
Unhandled exception: IPSR = 00000005 LR = fffffff1
CPU: 0 PID: 1 Comm: swapper Not tainted 3.17.0-rc6-00313-gd2205fa30aa7 #191
task: 29834000 ti: 29832000 task.ti: 29832000
PC is at flush_thread+0x2e/0x40
LR is at flush_thread+0x21/0x40
pc : [<2800954a>] lr : [<2800953d>] psr: 4100000b
sp : 29833d60 ip : 00000000 fp : 00000001
r10: 00003cf8 r9 : 29b1f000 r8 : 00000000
r7 : 29b0bc00 r6 : 29834000 r5 : 29832000 r4 : 29832000
r3 : ffff0ff0 r2 : 29832000 r1 : 00000000 r0 : 282121f0
xPSR: 4100000b
[<2800afa5>] (unwind_backtrace) from [<2800a327>] (show_stack+0xb/0xc)
[<2800a327>] (show_stack) from [<2800a963>] (__invalid_entry+0x4b/0x4c)
The problem is that set_tls is attempting to clear the TLS location in
the kernel-user helper page, which isn't set up on V7M.
Fix this by guarding the write to the kuser helper page with
a CONFIG_KUSER_HELPERS ifdef.
Fixes: fbfb872f5f41 ARM: 8148/1: flush TLS and thumbee register state during exec
Reported-by: Joachim Eastwood <manabian@gmail.com>
Tested-by: Joachim Eastwood <manabian@gmail.com>
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
commit 5ca918e5e3f9df4634077c06585c42bc6a8d699a upstream.
The alignment fixup incorrectly decodes faulting ARM VLDn/VSTn
instructions (where the optional alignment hint is given but incorrect)
as LDR/STR, leading to register corruption. Detect these and correctly
treat them as unhandled, so that userspace gets the fault it expects.
Reported-by: Simon Hosie <simon.hosie@arm.com>
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
commit 9e1ac462b982f496ed3b491f02c417dcc8e40347 upstream.
Commit 63288b721a80 ("ARM: imx: fix shared gate clock") attempted to fix
an issue with particular enable/disable sequence from two shared gate
clocks. But unfortunately, while it partially fixed the issue, it also
did something wrong in .is_enabled() function hook. In case of shared
gate, the function shouldn't really query the hardware state via
share_count, because the function is trying to query the enabling state
of the clock in question, not the hardware state which is shared by
multiple clocks.
Fix the issue by returning the enable_count of the clock itself which is
maintained by clock core, in case it's a clock sharing hardware gate
with others. As the result, the initialization of share_count per
hardware state is not needed now. So remove it.
Reported-by: Fabio Estevam <fabio.estevam@freescale.com>
Fixes: 63288b721a80 ("ARM: imx: fix shared gate clock")
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
commit 1b134c9c4b555342be667f144ee714af1c3f6a9f upstream.
using LVDS channel 1 on an i.MX53 leads to following error:
imx-ldb 53fa8008.ldb: unable to set di0 parent clock to ldb_di1
This comes from imx_ldb_set_clock with mux = 0. Mux parameter must be "1" for
reparenting di1 clock to ldb_di1. The value of the mux param comes from device
tree port settings.
On i.MX5, the internal two-input-multiplexer is used. Due to hardware limitations,
only one port (port@[0,1]) can be used for each channel (lvds-channel@[0,1],
respectively)
Documentation update suggested by Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
Fixes: e05c8c9a790a ("ARM: dts: imx53: Add IPU DI ports and endpoints, move imx-drm node to dtsi")
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
commit 5990047cef0c6a36eefcb166bd32d99a8f95c75b upstream.
The nand timings were scaled down by 2 to account for
the 2x rate returned by clk_get_rate(gpmc_fclk).
As the clock data got fixed by [1], revert back to actual
timings (i.e. scale them up by 2).
Without this NAND doesn't work on dra7-evm.
[1] - commit dd94324b983afe114ba9e7ee3649313b451f63ce
ARM: dts: dra7xx-clocks: Fix the l3 and l4 clock rates
Fixes: ff66a3c86e00 ("ARM: dts: dra7: add support for parallel NAND flash")
Signed-off-by: Roger Quadros <rogerq@ti.com>
commit 505013bc9065391f09a51d51cd3bf0b06dfb570a upstream.
Rob Clark reports a sleeping while atomic bug when using perf.
BUG: sleeping function called from invalid context at ../kernel/locking/mutex.c:583
in_atomic(): 1, irqs_disabled(): 128, pid: 0, name: swapper/0
WARNING: CPU: 2 PID: 4828 at ../kernel/locking/mutex.c:479 mutex_lock_nested+0x3a0/0x3e8()
DEBUG_LOCKS_WARN_ON(in_interrupt())
Modules linked in:
CPU: 2 PID: 4828 Comm: Xorg.bin Tainted: G W 3.17.0-rc3-00234-gd535c45-dirty #819
[<c0216690>] (unwind_backtrace) from [<c0212174>] (show_stack+0x10/0x14)
[<c0212174>] (show_stack) from [<c0867cc0>] (dump_stack+0x98/0xb8)
[<c0867cc0>] (dump_stack) from [<c02492a4>] (warn_slowpath_common+0x70/0x8c)
[<c02492a4>] (warn_slowpath_common) from [<c02492f0>] (warn_slowpath_fmt+0x30/0x40)
[<c02492f0>] (warn_slowpath_fmt) from [<c086a3f8>] (mutex_lock_nested+0x3a0/0x3e8)
[<c086a3f8>] (mutex_lock_nested) from [<c0294d08>] (irq_find_host+0x20/0x9c)
[<c0294d08>] (irq_find_host) from [<c0769d50>] (of_irq_get+0x28/0x48)
[<c0769d50>] (of_irq_get) from [<c057d104>] (platform_get_irq+0x1c/0x8c)
[<c057d104>] (platform_get_irq) from [<c021a06c>] (cpu_pmu_enable_percpu_irq+0x14/0x38)
[<c021a06c>] (cpu_pmu_enable_percpu_irq) from [<c02b1634>] (flush_smp_call_function_queue+0x88/0x178)
[<c02b1634>] (flush_smp_call_function_queue) from [<c0214dc0>] (handle_IPI+0x88/0x160)
[<c0214dc0>] (handle_IPI) from [<c0208930>] (gic_handle_irq+0x64/0x68)
[<c0208930>] (gic_handle_irq) from [<c0212d04>] (__irq_svc+0x44/0x5c)
Exception stack(0xe63ddea0 to 0xe63ddee8)
dea0: 00000001 00000001 00000000 c2f3b200 c16db380 c032d4a0 e63ddf40 60010013
dec0: 00000000 001fbfd4 00000100 00000000 00000001 e63ddee8 c0284770 c02a2e30
dee0: 20010013 ffffffff
[<c0212d04>] (__irq_svc) from [<c02a2e30>] (ktime_get_ts64+0x1c8/0x200)
[<c02a2e30>] (ktime_get_ts64) from [<c032d4a0>] (poll_select_set_timeout+0x60/0xa8)
[<c032d4a0>] (poll_select_set_timeout) from [<c032df64>] (SyS_select+0xa8/0x118)
[<c032df64>] (SyS_select) from [<c020e8e0>] (ret_fast_syscall+0x0/0x48)
---[ end trace 0bb583b46342da6f ]---
INFO: lockdep is turned off.
We don't really need to get the platform irq again when we're
enabling or disabling the per-cpu irq. Furthermore, we don't
really need to set and clear bits in the active_irqs bitmask
because that's only used in the non-percpu irq case to figure out
when the last CPU PMU has been disabled. Just pass the irq
directly to the enable/disable functions to clean all this up.
This should be slightly more efficient and also fix the
scheduling while atomic bug.
Fixes: bbd64559376f "ARM: perf: support percpu irqs for the CPU PMU"
Reported-by: Rob Clark <robdclark@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit fbfb872f5f417cea48760c535e0ff027c88b507a upstream.
The TPIDRURO and TPIDRURW registers need to be flushed during exec;
otherwise TLS information is potentially leaked. TPIDRURO in
particular needs careful treatment. Since flush_thread basically
needs the same code used to set the TLS in arm_syscall, pull that into
a common set_tls helper in tls.h and use it in both places.
Similarly, TEEHBR needs to be cleared during exec as well. Clearing
its save slot in thread_info isn't right as there is no guarantee
that a thread switch will occur before the new program runs. Just
setting the register directly is sufficient.
commit a040803a9d6b8c1876d3487a5cb69602ebcbb82c upstream.
Since commit 1dbfa187dad ("ARM: irq migration: force migration off CPU
going down") the ARM interrupt migration code on cpu offline calls
irqchip.irq_set_affinity() with the argument force=true. At the point
of this change the argument had no effect because it was not used by
any interrupt chip driver and there was no semantics defined.
This changed with commit 01f8fa4f01d8 ("genirq: Allow forcing cpu
affinity of interrupts") which made the force argument useful to route
interrupts to not yet online cpus without checking the target cpu
against the cpu online mask. The following commit ffde1de64012
("irqchip: gic: Support forced affinity setting") implemented this for
the GIC interrupt controller.
As a consequence the ARM cpu offline irq migration fails if CPU0 is
offlined, because CPU0 is still set in the affinity mask and the
validataion against cpu online mask is skipped to the force argument
being true. The following first_cpu(mask) selection always selects
CPU0 as the target.
Solve the issue by calling irq_set_affinity() with force=false from
the CPU offline irq migration code so the GIC driver validates the
affinity mask against CPU online mask and therefore removes CPU0 from
the possible target candidates.
Tested on TC2 hotpluging CPU0 in and out. Without this patch the system
locks up as the IRQs are not migrated away from CPU0.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
commit 68e4d9e58dbae2fb178e8b74806f521adb16f0d3 upstream.
While auditing the various pin ctrl configurations using the following
command:
grep PIN_ arch/arm/boot/dts/dra7-evm.dts|(while read line;
do
v=`echo "$line" | sed -e "s/\s\s*/|/g" | cut -d '|' -f1 |
cut -d 'x' -f2|tr [a-z] [A-Z]`;
HEX=`echo "obase=16;ibase=16;4A003400+$v"| bc`;
echo "$HEX ===> $line";
done)
against DRA75x/74x NDA TRM revision S(SPRUHI2S August 2014),
documentation errors were found for spi1 pinctrl. Fix the same.
Fixes: 6e58b8f1daaf1af ("ARM: dts: DRA7: Add the dts files for dra7 SoC and dra7-evm board")
Signed-off-by: Nishanth Menon <nm@ti.com>
commit 929a015b1809a30748d487f9d25b16a41434b61a upstream.
The edma_setup_from_hw() should know about the CC number when parsing the
CCCFG register - when it reads the register to be precise. The base
addresses for CCs stored in an array and we need to provide the correct id
to edma_read() in order to read the correct register.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
commit e49d519c456f4fb6f4a0473bc04ba30bb805fce5 upstream.
GPIO modules are also interrupt sources. However, they require both the
GPIO number and IRQ type to function properly.
By declaring that GPIO uses interrupt-cells=<1>, we essentially do not
allow users of the nodes to use the interrupt property appropritely.
With this change, the following now works:
interrupt-parent = <&gpio6>;
interrupts = <5 IRQ_TYPE_LEVEL_LOW>;
Fixes: 6e58b8f1daaf ('ARM: dts: DRA7: Add the dts files for dra7 SoC and dra7-evm board')
commit f7f7a29bf0cf25af23f37e5b5bf1368b85705286 upstream.
To deal with IPs which are specific to dra74x and dra72x, maintain seperate
ocp interface lists, while keeping the common list for all common IPs.
Move USB OTG SS4 to dra74x only list since its unavailable in
dra72x and is giving an abort during boot. The dra72x only list
is empty for now and a placeholder for future hwmod additions which
are specific to dra72x.
Fixes: d904b38df0db13 ("ARM: DRA7: hwmod: Add SYSCONFIG for usb_otg_ss")
Reported-by: Keerthy <j-keerthy@ti.com>
[paul@pwsan.com: fixed comment style to conform with CodingStyle]
commit 090727b880ff3c56e333f267cc24ab076f3bc096 upstream.
The following error is seen after a suspend/resume cycle on a mx53qsb with a
MC34708 PMIC:
root@freescale /$ echo mem > /sys/power/state
[ 32.630592] PM: Syncing filesystems ... done.
[ 32.643924] Freezing user space processes ... (elapsed 0.001 seconds) done.
[ 32.652384] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 32.679156] PM: suspend of devices complete after 13.113 msecs
[ 32.685128] PM: suspend devices took 0.030 seconds
[ 32.696109] PM: late suspend of devices complete after 6.133 msecs
[ 33.313032] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 33.322009] PM: noirq suspend of devices complete after 619.667 msecs
[ 33.328544] Disabling non-boot CPUs ...
[ 33.335031] PM: noirq resume of devices complete after 2.352 msecs
[ 33.842940] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 33.976095] [sched_delayed] sched: RT throttling activated
[ 33.984804] PM: early resume of devices complete after 642.642 msecs
[ 34.352954] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 34.862910] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 34.996595] PM: resume of devices complete after 1005.367 msecs
[ 35.372925] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 35.882911] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 35.955707] PM: resume devices took 1.970 seconds
[ 35.960445] Restarting tasks ... done.
[ 35.993386] fec 63fec000.ethernet eth0: Link is Down
[ 36.392980] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 36.902908] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 36.953036] ata1: SATA link down (SStatus 0 SControl 300)
[ 37.412922] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 37.922906] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 37.993379] fec 63fec000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 38.432938] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 38.942920] mc13xxx 0-0008: Failed to read IRQ status: -110
[ 39.452933] mc13xxx 0-0008: Failed to read IRQ status: -110
(flood of this error message continues forever)
Commit 5169df8be0a432ee ("ARM: dts: i.MX53: add support for MCIMX53-START-R")
missed to configure the IOMUX for the PMIC IRQ pin.
Configure the PMIC IRQ pin so that the suspend/resume sequence behaves cleanly
as expected.
commit 2c32c65e3726c773760038910be30cce1b4d4149 upstream.
On revisions of Cortex-A15 prior to r3p3, a CLREX instruction at PL1 may
falsely trigger a watchpoint exception, leading to potential data aborts
during exception return and/or livelock.
This patch resolves the issue in the following ways:
- Replacing our uses of CLREX with a dummy STREX sequence instead (as
we did for v6 CPUs).
- Removing the clrex code from v7_exit_coherency_flush and derivatives,
since this only exists as a minor performance improvement when
non-cached exclusives are in use (Linux doesn't use these).
Benchmarking on a variety of ARM cores revealed no measurable
performance difference with this change applied, so the change is
performed unconditionally and no new Kconfig entry is added.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
commit 85868313177700d20644263a782351262d2aff84 upstream.
The ARMv6 and ARMv7 early abort handlers clear the exclusive monitors
upon entry to the kernel, but this is redundant:
- We clear the monitors on every exception return since commit
200b812d0084 ("Clear the exclusive monitor when returning from an
exception"), so this is not necessary to ensure the monitors are
cleared before returning from a fault handler.
- Any dummy STREX will target a temporary scratch area in memory, and
may succeed or fail without corrupting useful data. Its status value
will not be used.
- Any other STREX in the kernel must be preceded by an LDREX, which
will initialise the monitors consistently and will not depend on the
earlier state of the monitors.
Therefore we have no reason to care about the initial state of the
exclusive monitors when a data abort is taken, and clearing the monitors
prior to exception return (as we already do) is sufficient.
This patch removes the redundant clearing of the exclusive monitors from
the early abort handlers.
commit d1b6ba82a50cecf94be540a3a153aa89d97511a0 upstream.
Remove restoring a6 on some return paths and instead modify and restore
it in a single place, using symbolic name.
Correctly restore a7 from PT_AREG7 in case of illegal a6 value.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 7128039fe2dd3d59da9e4ffa036f3aaa3ba87b9f upstream.
Current definition of TLBTEMP_BASE_2 is always 32K above the
TLBTEMP_BASE_1, whereas fast_second_level_miss handler for the TLBTEMP
region analyzes virtual address bit (PAGE_SHIFT + DCACHE_ALIAS_ORDER)
to determine TLBTEMP region where the fault happened. The size of the
TLBTEMP region is also checked incorrectly: not 64K, but twice data
cache way size (whicht may as well be less than the instruction cache
way size).
Fix TLBTEMP_BASE_2 to be TLBTEMP_BASE_1 + data cache way size.
Provide TLBTEMP_SIZE that is a greater of doubled data cache way size or
the instruction cache way size, and use it to determine if the second
level TLB miss occured in the TLBTEMP region.
Practical occurence of page faults in the TLBTEMP area is extremely
rare, this code can be tested by deletion of all w[di]tlb instructions
in the tlbtemp_mapping region.
commit 52247123749cc3cbc30168b33ad8c69515c96d23 upstream.
With SMP and a lot of debug options enabled task_struct::thread gets out
of reach of s32i/l32i instructions with base pointing at task_struct,
breaking build with the following messages:
arch/xtensa/kernel/entry.S: Assembler messages:
arch/xtensa/kernel/entry.S:1002: Error: operand 3 of 'l32i.n' has invalid value '1048'
arch/xtensa/kernel/entry.S:1831: Error: operand 3 of 's32i.n' has invalid value '1040'
arch/xtensa/kernel/entry.S:1832: Error: operand 3 of 's32i.n' has invalid value '1044'
Change base to point to task_struct::thread in such cases.
Don't use a10 in _switch_to to save/restore prev pointer as a2 is not
clobbered.
commit 1ca49463c44c970b1ab1d71b0f268bfdf8427a7e upstream.
Virtual address is translated to the XCHAL_KSEG_CACHED region in the
dma_free_coherent, but is checked to be in the 0...XCHAL_KSEG_SIZE
range.
Change check for end of the range from 'addr >= X' to 'addr > X - 1' to
handle the case of X == 0.
Replace 'if (C) BUG();' construct with 'BUG_ON(C);'.
Signed-off-by: Alan Douglas <adouglas@cadence.com>
commit f61bf8e7d19e0a3456a7a9ed97c399e4353698dc upstream.
This fixes userspace code that builds on other architectures but fails
on xtensa due to references to structures that other architectures don't
refer to. E.g. this fixes the following issue with python-2.7.8:
python-2.7.8/Modules/termios.c:861:25: error: invalid application
of 'sizeof' to incomplete type 'struct serial_multiport_struct'
{"TIOCSERGETMULTI", TIOCSERGETMULTI},
python-2.7.8/Modules/termios.c:870:25: error: invalid application
{"TIOCSERSETMULTI", TIOCSERSETMULTI},
python-2.7.8/Modules/termios.c:900:24: error: invalid application
of 'sizeof' to incomplete type 'struct tty_struct'
{"TIOCTTYGSTRUCT", TIOCTTYGSTRUCT},
commit 27d7ff273c2aad37b28f6ff0cab2cfa35b51e648 upstream.
I'm not sure what I was on when I wrote this, but when iterating over
the hardware watchpoint array (hbp_watch_array), our index is off by
ARM_MAX_BRP, so we walk off the end of our thread_struct...
... except, a dodgy condition in the loop means that it never executes
at all (bp cannot be NULL).
This patch fixes the code so that we remove the bp check and use the
correct index for accessing the watchpoint structures.
commit f6edbbf36da3a27b298b66c7955fc84e1dcca305 upstream.
X-Gene u-boot runs in EL2 mode with MMU enabled hence we might
have stale EL2 tlb enteris when we enable EL2 MMU on each host CPU.
This can happen on any ARM/ARM64 board running bootloader in
Hyp-mode (or EL2-mode) with MMU enabled.
This patch ensures that we flush all Hyp-mode (or EL2-mode) TLBs
on each host CPU before enabling Hyp-mode (or EL2-mode) MMU.
Tested-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Pranavkumar Sawargaonkar <pranavkumar@linaro.org>
Signed-off-by: Anup Patel <anup.patel@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 05e0127f9e362b36aa35f17b1a3d52bca9322a3a upstream.
The architecture specifies that when the processor wakes up from a WFE
or WFI instruction, the instruction is considered complete, however we
currrently return to EL1 (or EL0) at the WFI/WFE instruction itself.
While most guests may not be affected by this because their local
exception handler performs an exception returning setting the event bit
or with an interrupt pending, some guests like UEFI will get wedged due
this little mishap.
Simply skip the instruction when we have completed the emulation.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 3d8afe3099ebc602848aa7f09235cce3a9a023ce upstream.
The arm64 interrupt migration code on cpu offline calls
irqchip.irq_set_affinity() with the argument force=true. Originally
this argument had no effect because it was not used by any interrupt
As a consequence the cpu offline irq migration fails if CPU0 is
validation against cpu online mask is skipped to the force argument
CPU0 as the target.
Commit 601c942176d8("arm64: use cpu_online_mask when using forced
irq_set_affinity") intended to fix the above mentioned issue but
introduced another issue where affinity can be migrated to a wrong
CPU due to unconditional copy of cpu_online_mask.
As with for arm, solve the issue by calling irq_set_affinity() with
force=false from the CPU offline irq migration code so the GIC driver
validates the affinity mask against CPU online mask and therefore
removes CPU0 from the possible target candidates. Also revert the
changes done in the commit 601c942176d8 as it's no longer needed.
Tested on Juno platform.
Fixes: 601c942176d8("arm64: use cpu_online_mask when using forced
irq_set_affinity")
commit eb35bdd7bca29a13c8ecd44e6fd747a84ce675db upstream.
Nathan reports that we leak TLS information from the parent context
during an exec, as we don't clear the TLS registers when flushing the
thread state.
This patch updates the flushing code so that we:
(1) Unconditionally zero the tpidr_el0 register (since this is fully
context switched for native tasks and zeroed for compat tasks)
(2) Zero the tp_value state in thread_info before clearing the
tpidrr0_el0 register for compat tasks (since this is only writable
by the set_tls compat syscall and therefore not fully switched).
A missing compiler barrier is also added to the compat set_tls syscall.
Acked-by: Nathan Lynch <Nathan_Lynch@mentor.com>
Reported-by: Nathan Lynch <Nathan_Lynch@mentor.com>
commit fa97d2f7448a2f998bca0f4d4e40d6ad49026554 upstream.
The VPU on i.MX53 has two distinct clocks for register access and
internal function.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Fixes: fbf970f61eb9 ("ARM: dts: mx53qsb: Enable VPU support")
commit 0aa4dcb5b730f5da2540926b94d98636fe7d1cbc upstream.
Previous version had an extra 'fsl' which made the pins not match
any entry. The console message,
vf610-pinctrl 40048000.iomuxc: no fsl,pins property in node \
/soc/aips-bus@40000000/iomuxc@40048000/vf610-twr/esdhc1grp
is displayed without the fix. The prior version would generally
work as u-boot sets the pins properly for sdhc. This change allows
Linux sdhc use even if u-boot is built without sdhc support.
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Fixes: 0517fe6aa880 ("ARM: dts: vf610-twr: Add support for sdhc1")
commit 59d05b518321618177b898a6801503e31b15b25b upstream.
After the suspend routine running in OCRAM puts DDR into self-refresh,
it will access IOMUXC block to float DDR IO for power saving. A TLB
missing of IOMUXC base address may happen in this case, and triggers an
access to DDR, and thus hangs the system.
The failure is discovered by running suspend/resume on a Cubox-i board.
Though the issue is not Cubox-i specific, it can be hit the on the board
quite easily with the 3.15 or 3.16 kernel.
Fix the issue with a dummy access to IOMUXC block at the beginning of
suspend routine, so that the address translation can be filled into TLB
before DDR is put into self-refresh.
Acked-by: Anson Huang <Anson.Huang@freescale.com>
commit 6521d9a436a62e83ce57d6be6e5484e1098c1380 upstream.
The CPS code is doing several memory loads when configuring the VPEs
from secondary cores, so the segmentation control registers must be
initialized in time otherwise the kernel will crash with strange
TLB exceptions.
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: http://patchwork.linux-mips.org/patch/7424/
Signed-off-by: James Hogan <james.hogan@imgtec.com>
