path: root/arch
2017-05-14bpf, arm64: fix jit branch offset related to ldimm64Daniel Borkmann
[ Upstream commit ddc665a4bb4b728b4e6ecec8db1b64efa9184b9c ] When the instruction right before the branch destination is a 64 bit load immediate, we currently calculate the wrong jump offset in the ctx->offset[] array as we only account one instruction slot for the 64 bit load immediate although it uses two BPF instructions. Fix it up by setting the offset into the right slot after we incremented the index. Before (ldimm64 test 1): [...] 00000020: 52800007 mov w7, #0x0 // #0 00000024: d2800060 mov x0, #0x3 // #3 00000028: d2800041 mov x1, #0x2 // #2 0000002c: eb01001f cmp x0, x1 00000030: 54ffff82 b.cs 0x00000020 00000034: d29fffe7 mov x7, #0xffff // #65535 00000038: f2bfffe7 movk x7, #0xffff, lsl #16 0000003c: f2dfffe7 movk x7, #0xffff, lsl #32 00000040: f2ffffe7 movk x7, #0xffff, lsl #48 00000044: d29dddc7 mov x7, #0xeeee // #61166 00000048: f2bdddc7 movk x7, #0xeeee, lsl #16 0000004c: f2ddddc7 movk x7, #0xeeee, lsl #32 00000050: f2fdddc7 movk x7, #0xeeee, lsl #48 [...] After (ldimm64 test 1): [...] 00000020: 52800007 mov w7, #0x0 // #0 00000024: d2800060 mov x0, #0x3 // #3 00000028: d2800041 mov x1, #0x2 // #2 0000002c: eb01001f cmp x0, x1 00000030: 540000a2 b.cs 0x00000044 00000034: d29fffe7 mov x7, #0xffff // #65535 00000038: f2bfffe7 movk x7, #0xffff, lsl #16 0000003c: f2dfffe7 movk x7, #0xffff, lsl #32 00000040: f2ffffe7 movk x7, #0xffff, lsl #48 00000044: d29dddc7 mov x7, #0xeeee // #61166 00000048: f2bdddc7 movk x7, #0xeeee, lsl #16 0000004c: f2ddddc7 movk x7, #0xeeee, lsl #32 00000050: f2fdddc7 movk x7, #0xeeee, lsl #48 [...] Also, add a couple of test cases to make sure JITs pass this test. Tested on Cavium ThunderX ARMv8. The added test cases all pass after the fix. Fixes: 8eee539ddea0 ("arm64: bpf: fix out-of-bounds read in bpf2a64_offset()") Reported-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Cc: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14MIPS: R2-on-R6 MULTU/MADDU/MSUBU emulation bugfixLeonid Yegoshin
commit d65e5677ad5b3a49c43f60ec07644dc1f87bbd2e upstream. MIPS instructions MULTU, MADDU and MSUBU emulation requires registers HI/LO to be converted to signed 32bits before 64bit sign extension on MIPS64. Bug was found on running MIPS32 R2 test application on MIPS64 R6 kernel. Fixes: b0a668fb2038 ("MIPS: kernel: mips-r2-to-r6-emul: Add R2 emulator for MIPS R6") Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com> Reported-by: Nikola.Veljkovic@imgtec.com Cc: paul.burton@imgtec.com Cc: yamada.masahiro@socionext.com Cc: akpm@linux-foundation.org Cc: andrea.gelmini@gelma.net Cc: macro@imgtec.com Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14043/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14KVM: nVMX: do not leak PML full vmexit to L1Ladi Prosek
commit ab007cc94ff9d82f5a8db8363b3becbd946e58cf upstream. The PML feature is not exposed to guests so we should not be forwarding the vmexit either. This commit fixes BSOD 0x20001 (HYPERVISOR_ERROR) when running Hyper-V enabled Windows Server 2016 in L1 on hardware that supports PML. Fixes: 843e4330573c ("KVM: VMX: Add PML support in VMX") Signed-off-by: Ladi Prosek <lprosek@redhat.com> Reviewed-by: David Hildenbrand <david@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14KVM: nVMX: initialize PML fields in vmcs02Ladi Prosek
commit 1fb883bb827ee8efc1cc9ea0154f953f8a219d38 upstream. L2 was running with uninitialized PML fields which led to incomplete dirty bitmap logging. This manifested as all kinds of subtle erratic behavior of the nested guest. Fixes: 843e4330573c ("KVM: VMX: Add PML support in VMX") Signed-off-by: Ladi Prosek <lprosek@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14Revert "KVM: nested VMX: disable perf cpuid reporting"Jim Mattson
commit 0b4c208d443ba2af82b4c70f99ca8df31e9a0020 upstream. This reverts commit bc6134942dbbf31c25e9bd7c876be5da81c9e1ce. A CPUID instruction executed in VMX non-root mode always causes a VM-exit, regardless of the leaf being queried. Fixes: bc6134942dbb ("KVM: nested VMX: disable perf cpuid reporting") Signed-off-by: Jim Mattson <jmattson@google.com> [The issue solved by bc6134942dbb has been resolved with ff651cb613b4 ("KVM: nVMX: Add nested msr load/restore algorithm").] Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14x86/platform/intel-mid: Correct MSI IRQ line for watchdog deviceAndy Shevchenko
commit 80354c29025833acd72ddac1ffa21c6cb50128cd upstream. The interrupt line used for the watchdog is 12, according to the official Intel Edison BSP code. And indeed after fixing it we start getting an interrupt and thus the watchdog starts working again: [ 191.699951] Kernel panic - not syncing: Kernel Watchdog Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: David Cohen <david.a.cohen@linux.intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 78a3bb9e408b ("x86: intel-mid: add watchdog platform code for Merrifield") Link: http://lkml.kernel.org/r/20170312150744.45493-1-andriy.shevchenko@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14kprobes/x86: Fix kernel panic when certain exception-handling addresses are ↵Masami Hiramatsu
probed commit 75013fb16f8484898eaa8d0b08fed942d790f029 upstream. Fix to the exception table entry check by using probed address instead of the address of copied instruction. This bug may cause unexpected kernel panic if user probe an address where an exception can happen which should be fixup by __ex_table (e.g. copy_from_user.) Unless user puts a kprobe on such address, this doesn't cause any problem. This bug has been introduced years ago, by commit: 464846888d9a ("x86/kprobes: Fix a bug which can modify kernel code permanently"). Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 464846888d9a ("x86/kprobes: Fix a bug which can modify kernel code permanently") Link: http://lkml.kernel.org/r/148829899399.28855.12581062400757221722.stgit@devbox Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14x86/pci-calgary: Fix iommu_free() comparison of unsigned expression >= 0Nikola Pajkovsky
commit 68dee8e2f2cacc54d038394e70d22411dee89da2 upstream. commit 8fd524b355da ("x86: Kill bad_dma_address variable") has killed bad_dma_address variable and used instead of macro DMA_ERROR_CODE which is always zero. Since dma_addr is unsigned, the statement dma_addr >= DMA_ERROR_CODE is always true, and not needed. arch/x86/kernel/pci-calgary_64.c: In function ‘iommu_free’: arch/x86/kernel/pci-calgary_64.c:299:2: warning: comparison of unsigned expression >= 0 is always true [-Wtype-limits] if (unlikely((dma_addr >= DMA_ERROR_CODE) && (dma_addr < badend))) { Fixes: 8fd524b355da ("x86: Kill bad_dma_address variable") Signed-off-by: Nikola Pajkovsky <npajkovsky@suse.cz> Cc: iommu@lists.linux-foundation.org Cc: Jon Mason <jdmason@kudzu.us> Cc: Muli Ben-Yehuda <mulix@mulix.org> Link: http://lkml.kernel.org/r/7612c0f9dd7c1290407dbf8e809def922006920b.1479161177.git.npajkovsky@suse.cz Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14x86/ioapic: Restore IO-APIC irq_chip retrigger callbackRuslan Ruslichenko
commit a9b4f08770b415f30f2fb0f8329a370c8f554aa3 upstream. commit d32932d02e18 removed the irq_retrigger callback from the IO-APIC chip and did not add it to the new IO-APIC-IR irq chip. There is no harm because the interrupts are resent in software when the retrigger callback is NULL, but it's less efficient. So restore them. [ tglx: Massaged changelog ] Fixes: d32932d02e18 ("x86/irq: Convert IOAPIC to use hierarchical irqdomain interfaces") Signed-off-by: Ruslan Ruslichenko <rruslich@cisco.com> Cc: xe-linux-external@cisco.com Link: http://lkml.kernel.org/r/1484662432-13580-1-git-send-email-rruslich@cisco.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14ARM: OMAP5 / DRA7: Fix HYP mode boot for thumb2 buildMatthijs van Duin
commit 448c077eeb02240c430db2a2c3bf5285a4c65d66 upstream. 'adr' yields a data-pointer, not a function-pointer. Fixes: 999f934de195 ("ARM: omap5/dra7xx: Enable booting secondary CPU in HYP mode") Signed-off-by: Matthijs van Duin <matthijsvanduin@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14powerpc/powernv: Fix opal_exit tracepoint opcodeMichael Ellerman
commit a7e0fb6c2029a780444d09560f739e020d54fe4d upstream. Currently the opal_exit tracepoint usually shows the opcode as 0: <idle>-0 [047] d.h. 635.654292: opal_entry: opcode=63 <idle>-0 [047] d.h. 635.654296: opal_exit: opcode=0 retval=0 kopald-1209 [019] d... 636.420943: opal_entry: opcode=10 kopald-1209 [019] d... 636.420959: opal_exit: opcode=0 retval=0 This is because we incorrectly load the opcode into r0 before calling __trace_opal_exit(), whereas it expects the opcode in r3 (first function parameter). In fact we are leaving the retval in r3, so opcode and retval will always show the same value. Instead load the opcode into r3, resulting in: <idle>-0 [040] d.h. 636.618625: opal_entry: opcode=63 <idle>-0 [040] d.h. 636.618627: opal_exit: opcode=63 retval=0 Fixes: c49f63530bb6 ("powernv: Add OPAL tracepoints") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14ARM: 8452/3: PJ4: make coprocessor access sequences buildable in Thumb2 modeArd Biesheuvel
commit 5008efc83bf85b647aa1cbc44718b1675bbb7444 upstream. The PJ4 inline asm sequence to write to cp15 cannot be built in Thumb-2 mode, due to the way it performs arithmetic on the program counter, so it is built in ARM mode instead. However, building C files in ARM mode under CONFIG_THUMB2_KERNEL is problematic, since the instrumentation performed by subsystems like ftrace does not expect having to deal with interworking branches. Since the sequence in question is simply a poor man's ISB instruction, let's use a straight 'isb' instead when building in Thumb2 mode. Thumb2 implies V7, so 'isb' should always be supported in that case. Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02ftrace/x86: Fix triple fault with graph tracing and suspend-to-ramJosh Poimboeuf
commit 34a477e5297cbaa6ecc6e17c042a866e1cbe80d6 upstream. On x86-32, with CONFIG_FIRMWARE and multiple CPUs, if you enable function graph tracing and then suspend to RAM, it will triple fault and reboot when it resumes. The first fault happens when booting a secondary CPU: startup_32_smp() load_ucode_ap() prepare_ftrace_return() ftrace_graph_is_dead() (accesses 'kill_ftrace_graph') The early head_32.S code calls into load_ucode_ap(), which has an an ftrace hook, so it calls prepare_ftrace_return(), which calls ftrace_graph_is_dead(), which tries to access the global 'kill_ftrace_graph' variable with a virtual address, causing a fault because the CPU is still in real mode. The fix is to add a check in prepare_ftrace_return() to make sure it's running in protected mode before continuing. The check makes sure the stack pointer is a virtual kernel address. It's a bit of a hack, but it's not very intrusive and it works well enough. For reference, here are a few other (more difficult) ways this could have potentially been fixed: - Move startup_32_smp()'s call to load_ucode_ap() down to *after* paging is enabled. (No idea what that would break.) - Track down load_ucode_ap()'s entire callee tree and mark all the functions 'notrace'. (Probably not realistic.) - Pause graph tracing in ftrace_suspend_notifier_call() or bringup_cpu() or __cpu_up(), and ensure that the pause facility can be queried from real mode. Reported-by: Paul Menzel <pmenzel@molgen.mpg.de> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Tested-by: Paul Menzel <pmenzel@molgen.mpg.de> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: "Rafael J . Wysocki" <rjw@rjwysocki.net> Cc: linux-acpi@vger.kernel.org Cc: Borislav Petkov <bp@alien8.de> Cc: Len Brown <lenb@kernel.org> Link: http://lkml.kernel.org/r/5c1272269a580660703ed2eccf44308e790c7a98.1492123841.git.jpoimboe@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02ARCv2: save r30 on kernel entry as gcc uses it for code-genVineet Gupta
commit ecd43afdbe72017aefe48080631eb625e177ef4d upstream. This is not exposed to userspace debugers yet, which can be done independently as a seperate patch ! Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02MIPS: Avoid BUG warning in arch_check_elfJames Cowgill
commit c46f59e90226fa5bfcc83650edebe84ae47d454b upstream. arch_check_elf contains a usage of current_cpu_data that will call smp_processor_id() with preemption enabled and therefore triggers a "BUG: using smp_processor_id() in preemptible" warning when an fpxx executable is loaded. As a follow-up to commit b244614a60ab ("MIPS: Avoid a BUG warning during prctl(PR_SET_FP_MODE, ...)"), apply the same fix to arch_check_elf by using raw_current_cpu_data instead. The rationale quoted from the previous commit: "It is assumed throughout the kernel that if any CPU has an FPU, then all CPUs would have an FPU as well, so it is safe to perform the check with preemption enabled - change the code to use raw_ variant of the check to avoid the warning." Fixes: 46490b572544 ("MIPS: kernel: elf: Improve the overall ABI and FPU mode checks") Signed-off-by: James Cowgill <James.Cowgill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15951/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02MIPS: KGDB: Use kernel context for sleeping threadsJames Hogan
commit 162b270c664dca2e0944308e92f9fcc887151a72 upstream. KGDB is a kernel debug stub and it can't be used to debug userland as it can only safely access kernel memory. On MIPS however KGDB has always got the register state of sleeping processes from the userland register context at the beginning of the kernel stack. This is meaningless for kernel threads (which never enter userland), and for user threads it prevents the user seeing what it is doing while in the kernel: (gdb) info threads Id Target Id Frame ... 3 Thread 2 (kthreadd) 0x0000000000000000 in ?? () 2 Thread 1 (init) 0x000000007705c4b4 in ?? () 1 Thread -2 (shadowCPU0) 0xffffffff8012524c in arch_kgdb_breakpoint () at arch/mips/kernel/kgdb.c:201 Get the register state instead from the (partial) kernel register context stored in the task's thread_struct for resume() to restore. All threads now correctly appear to be in context_switch(): (gdb) info threads Id Target Id Frame ... 3 Thread 2 (kthreadd) context_switch (rq=<optimized out>, cookie=..., next=<optimized out>, prev=0x0) at kernel/sched/core.c:2903 2 Thread 1 (init) context_switch (rq=<optimized out>, cookie=..., next=<optimized out>, prev=0x0) at kernel/sched/core.c:2903 1 Thread -2 (shadowCPU0) 0xffffffff8012524c in arch_kgdb_breakpoint () at arch/mips/kernel/kgdb.c:201 Call clobbered registers which aren't saved and exception registers (BadVAddr & Cause) which can't be easily determined without stack unwinding are reported as 0. The PC is taken from the return address, such that the state presented matches that found immediately after returning from resume(). Fixes: 8854700115ec ("[MIPS] kgdb: add arch support for the kernel's kgdb core") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15829/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02sparc64: Fix kernel panic due to erroneous #ifdef surrounding pmd_write()Tom Hromatka
[ Upstream commit 9ae34dbd8afd790cb5f52467e4f816434379eafa ] This commit moves sparc64's prototype of pmd_write() outside of the CONFIG_TRANSPARENT_HUGEPAGE ifdef. In 2013, commit a7b9403f0e6d ("sparc64: Encode huge PMDs using PTE encoding.") exposed a path where pmd_write() could be called without CONFIG_TRANSPARENT_HUGEPAGE defined. This can result in the panic below. The diff is awkward to read, but the changes are straightforward. pmd_write() was moved outside of #ifdef CONFIG_TRANSPARENT_HUGEPAGE. Also, __HAVE_ARCH_PMD_WRITE was defined. kernel BUG at include/asm-generic/pgtable.h:576! \|/ ____ \|/ "@'/ .. \`@" /_| \__/ |_\ \__U_/ oracle_8114_cdb(8114): Kernel bad sw trap 5 [#1] CPU: 120 PID: 8114 Comm: oracle_8114_cdb Not tainted 4.1.12-61.7.1.el6uek.rc1.sparc64 #1 task: fff8400700a24d60 ti: fff8400700bc4000 task.ti: fff8400700bc4000 TSTATE: 0000004411e01607 TPC: 00000000004609f8 TNPC: 00000000004609fc Y: 00000005 Not tainted TPC: <gup_huge_pmd+0x198/0x1e0> g0: 000000000001c000 g1: 0000000000ef3954 g2: 0000000000000000 g3: 0000000000000001 g4: fff8400700a24d60 g5: fff8001fa5c10000 g6: fff8400700bc4000 g7: 0000000000000720 o0: 0000000000bc5058 o1: 0000000000000240 o2: 0000000000006000 o3: 0000000000001c00 o4: 0000000000000000 o5: 0000048000080000 sp: fff8400700bc6ab1 ret_pc: 00000000004609f0 RPC: <gup_huge_pmd+0x190/0x1e0> l0: fff8400700bc74fc l1: 0000000000020000 l2: 0000000000002000 l3: 0000000000000000 l4: fff8001f93250950 l5: 000000000113f800 l6: 0000000000000004 l7: 0000000000000000 i0: fff8400700ca46a0 i1: bd0000085e800453 i2: 000000026a0c4000 i3: 000000026a0c6000 i4: 0000000000000001 i5: fff800070c958de8 i6: fff8400700bc6b61 i7: 0000000000460dd0 I7: <gup_pud_range+0x170/0x1a0> Call Trace: [0000000000460dd0] gup_pud_range+0x170/0x1a0 [0000000000460e84] get_user_pages_fast+0x84/0x120 [00000000006f5a18] iov_iter_get_pages+0x98/0x240 [00000000005fa744] do_direct_IO+0xf64/0x1e00 [00000000005fbbc0] __blockdev_direct_IO+0x360/0x15a0 [00000000101f74fc] ext4_ind_direct_IO+0xdc/0x400 [ext4] [00000000101af690] ext4_ext_direct_IO+0x1d0/0x2c0 [ext4] [00000000101af86c] ext4_direct_IO+0xec/0x220 [ext4] [0000000000553bd4] generic_file_read_iter+0x114/0x140 [00000000005bdc2c] __vfs_read+0xac/0x100 [00000000005bf254] vfs_read+0x54/0x100 [00000000005bf368] SyS_pread64+0x68/0x80 Signed-off-by: Tom Hromatka <tom.hromatka@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02sparc64: kern_addr_valid regressionbob picco
[ Upstream commit adfae8a5d833fa2b46577a8081f350e408851f5b ] I encountered this bug when using /proc/kcore to examine the kernel. Plus a coworker inquired about debugging tools. We computed pa but did not use it during the maximum physical address bits test. Instead we used the identity mapped virtual address which will always fail this test. I believe the defect came in here: [bpicco@zareason linus.git]$ git describe --contains bb4e6e85daa52 v3.18-rc1~87^2~4 . Signed-off-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02xen/x86: don't lose event interruptsStefano Stabellini
commit c06b6d70feb32d28f04ba37aa3df17973fd37b6b upstream. On slow platforms with unreliable TSC, such as QEMU emulated machines, it is possible for the kernel to request the next event in the past. In that case, in the current implementation of xen_vcpuop_clockevent, we simply return -ETIME. To be precise the Xen returns -ETIME and we pass it on. However the result of this is a missed event, which simply causes the kernel to hang. Instead it is better to always ask the hypervisor for a timer event, even if the timeout is in the past. That way there are no lost interrupts and the kernel survives. To do that, remove the VCPU_SSHOTTMR_future flag. Signed-off-by: Stefano Stabellini <sstabellini@kernel.org> Acked-by: Juergen Gross <jgross@suse.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02MIPS: Fix crash registers on non-crashing CPUsCorey Minyard
commit c80e1b62ffca52e2d1d865ee58bc79c4c0c55005 upstream. As part of handling a crash on an SMP system, an IPI is send to all other CPUs to save their current registers and stop. It was using task_pt_regs(current) to get the registers, but that will only be accurate if the CPU was interrupted running in userland. Instead allow the architecture to pass in the registers (all pass NULL now, but allow for the future) and then use get_irq_regs() which should be accurate as we are in an interrupt. Fall back to task_pt_regs(current) if nothing else is available. Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/13050/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02ARM: OMAP2+: timer: add probe for clocksourcesTero Kristo
commit 970f9091d25df14e9540ec7ff48a2f709e284cd1 upstream. A few platforms are currently missing clocksource_probe() completely in their time_init functionality. On OMAP3430 for example, this is causing cpuidle to be pretty much dead, as the counter32k is not going to be registered and instead a gptimer is used as a clocksource. This will tick in periodic mode, preventing any deeper idle states. While here, also drop one unnecessary check for populated DT before existing clocksource_probe() call. Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27x86, pmem: fix broken __copy_user_nocache cache-bypass assumptionsDan Williams
commit 11e63f6d920d6f2dfd3cd421e939a4aec9a58dcd upstream. Before we rework the "pmem api" to stop abusing __copy_user_nocache() for memcpy_to_pmem() we need to fix cases where we may strand dirty data in the cpu cache. The problem occurs when copy_from_iter_pmem() is used for arbitrary data transfers from userspace. There is no guarantee that these transfers, performed by dax_iomap_actor(), will have aligned destinations or aligned transfer lengths. Backstop the usage __copy_user_nocache() with explicit cache management in these unaligned cases. Yes, copy_from_iter_pmem() is now too big for an inline, but addressing that is saved for a later patch that moves the entirety of the "pmem api" into the pmem driver directly. Fixes: 5de490daec8b ("pmem: add copy_from_iter_pmem() and clear_pmem()") Cc: <x86@kernel.org> Cc: Jan Kara <jack@suse.cz> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Matthew Wilcox <mawilcox@microsoft.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27kvm: arm/arm64: Fix locking for kvm_free_stage2_pgdSuzuki K Poulose
commit 8b3405e345b5a098101b0c31b264c812bba045d9 upstream. In kvm_free_stage2_pgd() we don't hold the kvm->mmu_lock while calling unmap_stage2_range() on the entire memory range for the guest. This could cause problems with other callers (e.g, munmap on a memslot) trying to unmap a range. And since we have to unmap the entire Guest memory range holding a spinlock, make sure we yield the lock if necessary, after we unmap each PUD range. Fixes: commit d5d8184d35c9 ("KVM: ARM: Memory virtualization setup") Cc: Paolo Bonzini <pbonzin@redhat.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> [ Avoid vCPU starvation and lockup detector warnings ] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27x86/mce/AMD: Give a name to MCA bank 3 when accessed with legacy MSRsYazen Ghannam
commit 29f72ce3e4d18066ec75c79c857bee0618a3504b upstream. MCA bank 3 is reserved on systems pre-Fam17h, so it didn't have a name. However, MCA bank 3 is defined on Fam17h systems and can be accessed using legacy MSRs. Without a name we get a stack trace on Fam17h systems when trying to register sysfs files for bank 3 on kernels that don't recognize Scalable MCA. Call MCA bank 3 "decode_unit" since this is what it represents on Fam17h. This will allow kernels without SMCA support to see this bank on Fam17h+ and prevent the stack trace. This will not affect older systems since this bank is reserved on them, i.e. it'll be ignored. Tested on AMD Fam15h and Fam17h systems. WARNING: CPU: 26 PID: 1 at lib/kobject.c:210 kobject_add_internal kobject: (ffff88085bb256c0): attempted to be registered with empty name! ... Call Trace: kobject_add_internal kobject_add kobject_create_and_add threshold_create_device threshold_init_device Signed-off-by: Yazen Ghannam <yazen.ghannam@amd.com> Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/1490102285-3659-1-git-send-email-Yazen.Ghannam@amd.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27powerpc/kprobe: Fix oops when kprobed on 'stdu' instructionRavi Bangoria
commit 9e1ba4f27f018742a1aa95d11e35106feba08ec1 upstream. If we set a kprobe on a 'stdu' instruction on powerpc64, we see a kernel OOPS: Bad kernel stack pointer cd93c840 at c000000000009868 Oops: Bad kernel stack pointer, sig: 6 [#1] ... GPR00: c000001fcd93cb30 00000000cd93c840 c0000000015c5e00 00000000cd93c840 ... NIP [c000000000009868] resume_kernel+0x2c/0x58 LR [c000000000006208] program_check_common+0x108/0x180 On a 64-bit system when the user probes on a 'stdu' instruction, the kernel does not emulate actual store in emulate_step() because it may corrupt the exception frame. So the kernel does the actual store operation in exception return code i.e. resume_kernel(). resume_kernel() loads the saved stack pointer from memory using lwz, which only loads the low 32-bits of the address, causing the kernel crash. Fix this by loading the 64-bit value instead. Fixes: be96f63375a1 ("powerpc: Split out instruction analysis part of emulate_step()") Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com> Reviewed-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Reviewed-by: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> [mpe: Change log massage, add stable tag] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27s390/mm: fix CMMA vs KSM vs othersChristian Borntraeger
commit a8f60d1fadf7b8b54449fcc9d6b15248917478ba upstream. On heavy paging with KSM I see guest data corruption. Turns out that KSM will add pages to its tree, where the mapping return true for pte_unused (or might become as such later). KSM will unmap such pages and reinstantiate with different attributes (e.g. write protected or special, e.g. in replace_page or write_protect_page)). This uncovered a bug in our pagetable handling: We must remove the unused flag as soon as an entry becomes present again. Signed-of-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21MIPS: fix Select HAVE_IRQ_EXIT_ON_IRQ_STACK patch.Greg Kroah-Hartman
Commit f017e58da4aba293e4a6ab62ca5d4801f79cc929 which was commit 3cc3434fd6307d06b53b98ce83e76bf9807689b9 upstream, was misapplied to the 4.4 stable kernel. This patch fixes this and moves the chunk to the proper Kconfig area. Reported-by: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Jason A. Donenfeld <jason@zx2c4.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21mm: Tighten x86 /dev/mem with zeroing readsKees Cook
commit a4866aa812518ed1a37d8ea0c881dc946409de94 upstream. Under CONFIG_STRICT_DEVMEM, reading System RAM through /dev/mem is disallowed. However, on x86, the first 1MB was always allowed for BIOS and similar things, regardless of it actually being System RAM. It was possible for heap to end up getting allocated in low 1MB RAM, and then read by things like x86info or dd, which would trip hardened usercopy: usercopy: kernel memory exposure attempt detected from ffff880000090000 (dma-kmalloc-256) (4096 bytes) This changes the x86 exception for the low 1MB by reading back zeros for System RAM areas instead of blindly allowing them. More work is needed to extend this to mmap, but currently mmap doesn't go through usercopy, so hardened usercopy won't Oops the kernel. Reported-by: Tommi Rantala <tommi.t.rantala@nokia.com> Tested-by: Tommi Rantala <tommi.t.rantala@nokia.com> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Brad Spengler <spender@grsecurity.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21powerpc: Disable HFSCR[TM] if TM is not supportedBenjamin Herrenschmidt
commit 7ed23e1bae8bf7e37fd555066550a00b95a3a98b upstream. On Power8 & Power9 the early CPU inititialisation in __init_HFSCR() turns on HFSCR[TM] (Hypervisor Facility Status and Control Register [Transactional Memory]), but that doesn't take into account that TM might be disabled by CPU features, or disabled by the kernel being built with CONFIG_PPC_TRANSACTIONAL_MEM=n. So later in boot, when we have setup the CPU features, clear HSCR[TM] if the TM CPU feature has been disabled. We use CPU_FTR_TM_COMP to account for the CONFIG_PPC_TRANSACTIONAL_MEM=n case. Without this a KVM guest might try use TM, even if told not to, and cause an oops in the host kernel. Typically the oops is seen in __kvmppc_vcore_entry() and may or may not be fatal to the host, but is always bad news. In practice all shipping CPU revisions do support TM, and all host kernels we are aware of build with TM support enabled, so no one should actually be able to hit this in the wild. Fixes: 2a3563b023e5 ("powerpc: Setup in HFSCR for POWER8") Cc: stable@vger.kernel.org # v3.10+ Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Sam Bobroff <sam.bobroff@au1.ibm.com> [mpe: Rewrite change log with input from Sam, add Fixes/stable] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> [sb: Backported to linux-4.4.y: adjusted context] Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21kvm: fix page struct leak in handle_vmonPaolo Bonzini
commit 06ce521af9558814b8606c0476c54497cf83a653 upstream. handle_vmon gets a reference on VMXON region page, but does not release it. Release the reference. Found by syzkaller; based on a patch by Dmitry. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> [bwh: Backported to 3.16: use skip_emulated_instruction()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21Revert "MIPS: Lantiq: Fix cascaded IRQ setup"Greg Kroah-Hartman
This reverts commit 6280ac931a23d3fa40cd26057576abcf90a4f22d which is commit 6c356eda225e3ee134ed4176b9ae3a76f793f4dd upstream. It shouldn't have been included in a stable release. Reported-by: Amit Pundir <amit.pundir@linaro.org> Cc: Felix Fietkau <nbd@nbd.name> Cc: John Crispin <john@phrozen.org> Cc: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21x86/vdso: Plug race between mapping and ELF header setupThomas Gleixner
commit 6fdc6dd90272ce7e75d744f71535cfbd8d77da81 upstream. The vsyscall32 sysctl can racy against a concurrent fork when it switches from disabled to enabled: arch_setup_additional_pages() if (vdso32_enabled) --> No mapping sysctl.vsysscall32() --> vdso32_enabled = true create_elf_tables() ARCH_DLINFO_IA32 if (vdso32_enabled) { --> Add VDSO entry with NULL pointer Make ARCH_DLINFO_IA32 check whether the VDSO mapping has been set up for the newly forked process or not. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mathias Krause <minipli@googlemail.com> Link: http://lkml.kernel.org/r/20170410151723.602367196@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21x86/vdso: Ensure vdso32_enabled gets set to valid values onlyMathias Krause
commit c06989da39cdb10604d572c8c7ea8c8c97f3c483 upstream. vdso_enabled can be set to arbitrary integer values via the kernel command line 'vdso32=' parameter or via 'sysctl abi.vsyscall32'. load_vdso32() only maps VDSO if vdso_enabled == 1, but ARCH_DLINFO_IA32 merily checks for vdso_enabled != 0. As a consequence the AT_SYSINFO_EHDR auxiliary vector for the VDSO_ENTRY is emitted with a NULL pointer which causes a segfault when the application tries to use the VDSO. Restrict the valid arguments on the command line and the sysctl to 0 and 1. Fixes: b0b49f2673f0 ("x86, vdso: Remove compat vdso support") Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roland McGrath <roland@redhat.com> Link: http://lkml.kernel.org/r/1491424561-7187-1-git-send-email-minipli@googlemail.com Link: http://lkml.kernel.org/r/20170410151723.518412863@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21perf/x86: Avoid exposing wrong/stale data in intel_pmu_lbr_read_32()Peter Zijlstra
commit f2200ac311302fcdca6556fd0c5127eab6c65a3e upstream. When the perf_branch_entry::{in_tx,abort,cycles} fields were added, intel_pmu_lbr_read_32() wasn't updated to initialize them. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Fixes: 135c5612c460 ("perf/x86/intel: Support Haswell/v4 LBR format") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18MIPS: IRQ Stack: Fix erroneous jal to plat_irq_dispatchMatt Redfearn
commit c25f8064c1d5731a2ce5664def890140dcdd3e5c upstream. Commit dda45f701c9d ("MIPS: Switch to the irq_stack in interrupts") changed both the normal and vectored interrupt handlers. Unfortunately the vectored version, "except_vec_vi_handler", was incorrectly modified to unconditionally jal to plat_irq_dispatch, rather than doing a jalr to the vectored handler that has been set up. This is ok for many platforms which set the vectored handler to plat_irq_dispatch anyway, but will cause problems with platforms that use other handlers. Fixes: dda45f701c9d ("MIPS: Switch to the irq_stack in interrupts") Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15110/ Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18MIPS: Select HAVE_IRQ_EXIT_ON_IRQ_STACKMatt Redfearn
commit 3cc3434fd6307d06b53b98ce83e76bf9807689b9 upstream. Since do_IRQ is now invoked on a separate IRQ stack, we select HAVE_IRQ_EXIT_ON_IRQ_STACK so that softirq's may be invoked directly from irq_exit(), rather than requiring do_softirq_own_stack. Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Acked-by: Jason A. Donenfeld <jason@zx2c4.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14744/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18MIPS: Switch to the irq_stack in interruptsMatt Redfearn
commit dda45f701c9d7ad4ac0bb446e3a96f6df9a468d9 upstream. When enterring interrupt context via handle_int or except_vec_vi, switch to the irq_stack of the current CPU if it is not already in use. The current stack pointer is masked with the thread size and compared to the base or the irq stack. If it does not match then the stack pointer is set to the top of that stack, otherwise this is a nested irq being handled on the irq stack so the stack pointer should be left as it was. The in-use stack pointer is placed in the callee saved register s1. It will be saved to the stack when plat_irq_dispatch is invoked and can be restored once control returns here. Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Acked-by: Jason A. Donenfeld <jason@zx2c4.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14743/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18MIPS: Only change $28 to thread_info if coming from user modeMatt Redfearn
commit 510d86362a27577f5ee23f46cfb354ad49731e61 upstream. The SAVE_SOME macro is used to save the execution context on all exceptions. If an exception occurs while executing user code, the stack is switched to the kernel's stack for the current task, and register $28 is switched to point to the current_thread_info, which is at the bottom of the stack region. If the exception occurs while executing kernel code, the stack is left, and this change ensures that register $28 is not updated. This is the correct behaviour when the kernel can be executing on the separate irq stack, because the thread_info will not be at the base of it. With this change, register $28 is only switched to it's kernel conventional usage of the currrent thread info pointer at the point at which execution enters kernel space. Doing it on every exception was redundant, but OK without an IRQ stack, but will be erroneous once that is introduced. Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Acked-by: Jason A. Donenfeld <jason@zx2c4.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14742/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18MIPS: Stack unwinding while on IRQ stackMatt Redfearn
commit d42d8d106b0275b027c1e8992c42aecf933436ea upstream. Within unwind stack, check if the stack pointer being unwound is within the CPU's irq_stack and if so use that page rather than the task's stack page. Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Acked-by: Jason A. Donenfeld <jason@zx2c4.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Adam Buchbinder <adam.buchbinder@gmail.com> Cc: Maciej W. Rozycki <macro@imgtec.com> Cc: Marcin Nowakowski <marcin.nowakowski@imgtec.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14741/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18MIPS: Introduce irq_stackMatt Redfearn
commit fe8bd18ffea5327344d4ec2bf11f47951212abd0 upstream. Allocate a per-cpu irq stack for use within interrupt handlers. Also add a utility function on_irq_stack to determine if a given stack pointer is within the irq stack for that cpu. Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Acked-by: Jason A. Donenfeld <jason@zx2c4.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Petr Mladek <pmladek@suse.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14740/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12MIPS: Flush wrong invalid FTLB entry for huge pageHuacai Chen
commit 0115f6cbf26663c86496bc56eeea293f85b77897 upstream. On VTLB+FTLB platforms (such as Loongson-3A R2), FTLB's pagesize is usually configured the same as PAGE_SIZE. In such a case, Huge page entry is not suitable to write in FTLB. Unfortunately, when a huge page is created, its page table entries haven't created immediately. Then the TLB refill handler will fetch an invalid page table entry which has no "HUGE" bit, and this entry may be written to FTLB. Since it is invalid, TLB load/store handler will then use tlbwi to write the valid entry at the same place. However, the valid entry is a huge page entry which isn't suitable for FTLB. Our solution is to modify build_huge_handler_tail. Flush the invalid old entry (whether it is in FTLB or VTLB, this is in order to reduce branches) and use tlbwr to write the valid new entry. Signed-off-by: Rui Wang <wangr@lemote.com> Signed-off-by: Huacai Chen <chenhc@lemote.com> Cc: John Crispin <john@phrozen.org> Cc: Steven J . Hill <Steven.Hill@caviumnetworks.com> Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Cc: Huacai Chen <chenhc@lemote.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15754/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12MIPS: Lantiq: fix missing xbar kernel panicHauke Mehrtens
commit 6ef90877eee63a0d03e83183bb44b64229b624e6 upstream. Commit 08b3c894e565 ("MIPS: lantiq: Disable xbar fpi burst mode") accidentally requested the resources from the pmu address region instead of the xbar registers region, but the check for the return value of request_mem_region() was wrong. Commit 98ea51cb0c8c ("MIPS: Lantiq: Fix another request_mem_region() return code check") fixed the check of the return value of request_mem_region() which made the kernel panics. This patch now makes use of the correct memory region for the cross bar. Fixes: 08b3c894e565 ("MIPS: lantiq: Disable xbar fpi burst mode") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: John Crispin <john@phrozen.org> Cc: james.hogan@imgtec.com Cc: arnd@arndb.de Cc: sergei.shtylyov@cogentembedded.com Cc: john@phrozen.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15751 Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12MIPS: End spinlocks with .insnPaul Burton
commit 4b5347a24a0f2d3272032c120664b484478455de upstream. When building for microMIPS we need to ensure that the assembler always knows that there is code at the target of a branch or jump. Recent toolchains will fail to link a microMIPS kernel when this isn't the case due to what it thinks is a branch to non-microMIPS code. mips-mti-linux-gnu-ld kernel/built-in.o: .spinlock.text+0x2fc: Unsupported branch between ISA modes. mips-mti-linux-gnu-ld final link failed: Bad value This is due to inline assembly labels in spinlock.h not being followed by an instruction mnemonic, either due to a .subsection pseudo-op or the end of the inline asm block. Fix this with a .insn direction after such labels. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: James Hogan <james.hogan@imgtec.com> Reviewed-by: Maciej W. Rozycki <macro@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/15325/ Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12MIPS: ralink: Fix typos in rt3883 pinctrlJohn Crispin
commit 7c5a3d813050ee235817b0220dd8c42359a9efd8 upstream. There are two copy & paste errors in the definition of the 5GHz LNA and second ethernet pinmux. Fixes: f576fb6a0700 ("MIPS: ralink: cleanup the soc specific pinmux data") Signed-off-by: John Crispin <john@phrozen.org> Signed-off-by: Daniel Golle <daniel@makrotopia.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15328/ Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12MIPS: Force o32 fp64 support on 32bit MIPS64r6 kernelsJames Hogan
commit 2e6c7747730296a6d4fd700894286db1132598c4 upstream. When a 32-bit kernel is configured to support MIPS64r6 (CPU_MIPS64_R6), MIPS_O32_FP64_SUPPORT won't be selected as it should be because MIPS32_O32 is disabled (o32 is already the default ABI available on 32-bit kernels). This results in userland FP breakage as CP0_Status.FR is read-only 1 since r6 (when an FPU is present) so __enable_fpu() will fail to clear FR. This causes the FPU emulator to get used which will incorrectly emulate 32-bit FPU registers. Force o32 fp64 support in this case by also selecting MIPS_O32_FP64_SUPPORT from CPU_MIPS64_R6 if 32BIT. Fixes: 4e9d324d4288 ("MIPS: Require O32 FP64 support for MIPS64 with O32 compat") Signed-off-by: James Hogan <james.hogan@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15310/ Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12s390/uaccess: get_user() should zero on failure (again)Heiko Carstens
commit d09c5373e8e4eaaa09233552cbf75dc4c4f21203 upstream. Commit fd2d2b191fe7 ("s390: get_user() should zero on failure") intended to fix s390's get_user() implementation which did not zero the target operand if the read from user space faulted. Unfortunately the patch has no effect: the corresponding inline assembly specifies that the operand is only written to ("=") and the previous value is discarded. Therefore the compiler is free to and actually does omit the zero initialization. To fix this simply change the contraint modifier to "+", so the compiler cannot omit the initialization anymore. Fixes: c9ca78415ac1 ("s390/uaccess: provide inline variants of get_user/put_user") Fixes: fd2d2b191fe7 ("s390: get_user() should zero on failure") Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12s390/decompressor: fix initrd corruption caused by bss clearMarcelo Henrique Cerri
commit d82c0d12c92705ef468683c9b7a8298dd61ed191 upstream. Reorder the operations in decompress_kernel() to ensure initrd is moved to a safe location before the bss section is zeroed. During decompression bss can overlap with the initrd and this can corrupt the initrd contents depending on the size of the compressed kernel (which affects where the initrd is placed by the bootloader) and the size of the bss section of the decompressor. Also use the correct initrd size when checking for overlaps with parmblock. Fixes: 06c0dd72aea3 ([S390] fix boot failures with compressed kernels) Reviewed-by: Joy Latten <joy.latten@canonical.com> Reviewed-by: Vineetha HariPai <vineetha.hari.pai@canonical.com> Signed-off-by: Marcelo Henrique Cerri <marcelo.cerri@canonical.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12nios2: reserve boot memory for device treeTobias Klauser
commit 921d701e6f31e1ffaca3560416af1aa04edb4c4f upstream. Make sure to reserve the boot memory for the flattened device tree. Otherwise it might get overwritten, e.g. when initial_boot_params is copied, leading to a corrupted FDT and a boot hang/crash: bootconsole [early0] enabled Early console on uart16650 initialized at 0xf8001600 OF: fdt: Error -11 processing FDT Kernel panic - not syncing: setup_cpuinfo: No CPU found in devicetree! ---[ end Kernel panic - not syncing: setup_cpuinfo: No CPU found in devicetree! Guenter Roeck says: > I think I found the problem. In unflatten_and_copy_device_tree(), with added > debug information: > > OF: fdt: initial_boot_params=c861e400, dt=c861f000 size=28874 (0x70ca) > > ... and then initial_boot_params is copied to dt, which results in corrupted > fdt since the memory overlaps. Looks like the initial_boot_params memory > is not reserved and (re-)allocated by early_init_dt_alloc_memory_arch(). Reported-by: Guenter Roeck <linux@roeck-us.net> Reference: http://lkml.kernel.org/r/20170226210338.GA19476@roeck-us.net Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Ley Foon Tan <ley.foon.tan@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12powerpc: Don't try to fix up misaligned load-with-reservation instructionsPaul Mackerras
commit 48fe9e9488743eec9b7c1addd3c93f12f2123d54 upstream. In the past, there was only one load-with-reservation instruction, lwarx, and if a program attempted a lwarx on a misaligned address, it would take an alignment interrupt and the kernel handler would emulate it as though it was lwzx, which was not really correct, but benign since it is loading the right amount of data, and the lwarx should be paired with a stwcx. to the same address, which would also cause an alignment interrupt which would result in a SIGBUS being delivered to the process. We now have 5 different sizes of load-with-reservation instruction. Of those, lharx and ldarx cause an immediate SIGBUS by luck since their entries in aligninfo[] overlap instructions which were not fixed up, but lqarx overlaps with lhz and will be emulated as such. lbarx can never generate an alignment interrupt since it only operates on 1 byte. To straighten this out and fix the lqarx case, this adds code to detect the l[hwdq]arx instructions and return without fixing them up, resulting in a SIGBUS being delivered to the process. Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12powerpc/mm: Add missing global TLB invalidate if cxl is activeFrederic Barrat
commit 88b1bf7268f56887ca88eb09c6fb0f4fc970121a upstream. Commit 4c6d9acce1f4 ("powerpc/mm: Add hooks for cxl") converted local TLB invalidates to global if the cxl driver is active. This is necessary because the CAPP snoops invalidations to forward them to the PSL on the cxl adapter. However one path was forgotten. native_flush_hash_range() still does local TLB invalidates, as found out the hard way recently. This patch fixes it by following the same logic as previously: if the cxl driver is active, the local TLB invalidates are 'upgraded' to global. Fixes: 4c6d9acce1f4 ("powerpc/mm: Add hooks for cxl") Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
