path: root/arch
2011-03-30Merge branch 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix missing irq namespace conversion powerpc: qe_ic: Rename get_irq_desc_data and get_irq_desc_chip genirq: Remove the now obsolete config options and select statements arm: versatile : Fix typo introduced in irq namespace cleanup sound: Fixup the last user of the old irq functions genirq: Remove obsolete comment genirq: Remove now obsolete set_irq_wake() sh: Fix irq cleanup fallout x86: apb_timer: Fixup genirq fallout genirq: Fix misnamed label in handle_edge_eoi_irq Fix up crazy conflict in arch/powerpc/include/asm/qe_ic.h: - commit eead4d5c63ff ("powerpc: qe_ic: Rename get_irq_desc_data and get_irq_desc_chip") made the helper functions use irq_desc_get_handler_data() instead of the legacy (and no longer existing) get_irq_desc_data. - commit d4db35e8dc96 ("powerpc/qe_ic: Fix another breakage from the irq_data conversion") used irq_desc_get_chip_data() instead. According to Thomas, the former is the correct direct conversion, but it does look like both should work (arch/powerpc/sysdev/qe_lib/qe_ic.c seems to initialize both to the same thing), and the chip data in some ways is the more logical. Somebody should really decide on one of the other. This merge picks irq_desc_get_handler_data() as the straightforward pure conversion to new names, as per Thomas.
2011-03-30Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/qe_ic: Fix another breakage from the irq_data conversion powerpc/8xx: Fix another breakage from the irq_data conversion powerpc/cell: Use handle_edge_eoi_irq for real powerpc/pseries: Enable Chelsio network and iWARP drivers powerpc/mm: Move the STAB0 location to 0x8000 to make room in low memory powerpc: Fix accounting of softirq time when idle powerpc/pseries/smp: query-cpu-stopped-state support won't change powerpc/xics: Use hwirq for xics domain irq number powerpc/xics: Fix numberspace mismatch from irq_desc conversion powerpc: Wire up new syscalls powerpc/booke: Correct the SPRN_MAS5 definition. powerpc: ARCH_PFN_OFFSET should be unsigned long powerpc: Implement dma_mmap_coherent() powerpc/nvram: Don't overwrite oops/panic report on normal shutdown powerpc: Restore some misc devices to our configs
2011-03-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: Blackfin: bitops: fix include order after little endian inclusion Blackfin: defconfigs: update after misc devices defaulted to N Blackfin: use more standard pr_fmt in the module loader
2011-03-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits) ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support ARM: 6838/1: etm: fix section mismatch warning ARM: 6837/1: remove unused pci_fixup_prpmc1100 ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC Fix the broken build for Marvell Dove platform. ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency ARM: 6834/1: perf: reset counters on all CPUs during initialisation ARM: 6833/1: perf: add required isbs() to ARMv7 backend ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile arm: mach-mx3: pcm043: add write-protect and card-detect for SD1 eukrea_mbimxsd51: add SD Card detect eukrea_mbimxsd25-baseboard: add SD card detect mx3/eukrea_mbimxsd-baseboard: add SD card detect support mx3/eukrea_mbimxsd-baseboard: fix gpio request ARM: mxs/mx28evk: add mmc device ARM: mxs/mx23evk: add mmc device ARM: mxs: dynamically allocate mmc device ARM: mx51_efika: update platform data for new mfd changes mx2/iomux: Set direction for CSPI2 pins ...
2011-03-30avr32: Fix missing irq namespace conversionThomas Gleixner
2011-03-30powerpc: qe_ic: Rename get_irq_desc_data and get_irq_desc_chipRichard Cochran
These two functions disappeared in commit 0c6f8a8b917ad361319c8ace3e9f28e69bfdb4c1 "genirq: Remove compat code" but they still exist in qe_ic.h. This patch renames the function to their new names. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Cc: linuxppc-dev@lists.ozlabs.org Cc: Lennert Buytenhek <buytenh@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> LKML-Reference: <20110330132504.GA31832@riccoc20.at.omicron.at> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-30arm: versatile : Fix typo introduced in irq namespace cleanupGrant Likely
Commit 6845664(arm: Cleanup the irq namespace) introduces a typo causing a build failure for the versatile platform. [ tglx: Sorry, my bad. Have no idea how I fatfingered that ] Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org LKML-Reference: <20110330060229.27397.7628.stgit@ponder> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-30powerpc/qe_ic: Fix another breakage from the irq_data conversionBenjamin Herrenschmidt
2011-03-30powerpc/8xx: Fix another breakage from the irq_data conversionBenjamin Herrenschmidt
2011-03-29powerpc/cell: fixup for removal of handle_iic_irqStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-30powerpc/cell: Use handle_edge_eoi_irq for realThomas Gleixner
Missed one instance when moving that to the core code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linuxppc-dev@lists.ozlabs.org Cc: michael@ellerman.id.au Cc: mingo@elte.hu Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/pseries: Enable Chelsio network and iWARP driversAnton Blanchard
Ensure the Chelsio T3/T4 network drivers and iWARP drivers are enabled in the pseries config. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/mm: Move the STAB0 location to 0x8000 to make room in low memoryBenjamin Herrenschmidt
Recent upstream builds with allmodconfig fail due to lack of space between 0x3000 and 0x6000. We have a hard block at 0x7000 but we can spare a page by moving the STAB0 from 0x6000 to 0x8000. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc: Fix accounting of softirq time when idleAnton Blanchard
commit cf9efce0ce31 (powerpc: Account time using timebase rather than PURR) used in_irq() to detect if the time was spent in interrupt processing. This only catches hardirq context so if we are in softirq context and in the idle loop we end up accounting it as idle time. If we instead use in_interrupt() we catch both softirq and hardirq time. The issue was found when running a network intensive workload. top showed the following: 0.0%us, 1.1%sy, 0.0%ni, 85.7%id, 0.0%wa, 9.9%hi, 3.3%si, 0.0%st 85.7% idle. But this was wildly different to the perf events data. To confirm the suspicion I ran something to keep the core busy: # yes > /dev/null & 8.2%us, 0.0%sy, 0.0%ni, 0.0%id, 0.0%wa, 10.3%hi, 81.4%si, 0.0%st We only got 8.2% of the CPU for the userspace task and softirq has shot up to 81.4%. With the patch below top shows the correct stats: 0.0%us, 0.0%sy, 0.0%ni, 5.3%id, 0.0%wa, 13.3%hi, 81.3%si, 0.0%st Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable@kernel.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/pseries/smp: query-cpu-stopped-state support won't changeMilton Miller
If a given firmware doesn't have a token to support query-cpu-stopped-state, its not likely to change during the lifetime of the kernel. Only print this information once, not once per secondary thread. While here, make the line wrap grep friendly. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/xics: Use hwirq for xics domain irq numberMilton Miller
To try to avoid future confusion, rename irq to hwirq when it refers to a xics domain number instead of a linux irq number. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/xics: Fix numberspace mismatch from irq_desc conversionMilton Miller
commit 79f26c268ebad29bd75d078cfc09d3d82b30ccbd (powerpc: platforms/pseries irq_data conversion) pushed irq_desc down into many functions, dererencing the descriptor irq field as late as possible. But it incorrectly passed a linix virtural irq number to RTAS, resulting in the interrupt not being disabled and possibly other bad things, such as another interrupt being disabled and/or a checkstop. In addition this missed the point of xics_mask_unknown_vec and the seperation of xics_mask_real_irq from xics_mask_irq. When xics_mask_unknown_vec is called it's because the hardware delivered an irq source for which we have no linux irq allocated, and thefore we can not have an irq_desc allocated. Revert xics_mask_real_irq to its prior version, naming the argument hwirq to highlight the difference. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc: Wire up new syscallsStephen Rothwell
These syscalls have been added recently: name_to_handle_at open_by_handle_at clock_adjtime syncfs Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/booke: Correct the SPRN_MAS5 definition.Varun Sethi
339 is the SPR number for MAS5 documented by Power ISA 2.06, and implemented by e500mc. It is not yet used anywhere in the kernel, so nothing should be relying on the wrong number. Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc: ARCH_PFN_OFFSET should be unsigned longScott Wood
pfns are unsigned long, but MEMORY_START is phys_addr_t. This leads to page_to_pfn() returning phys_addr_t, and thus type mismatches in a few print statements. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc: Implement dma_mmap_coherent()Benjamin Herrenschmidt
This is used by Alsa to mmap buffers allocated with dma_alloc_coherent() into userspace. We need a special variant to handle machines with non-coherent DMAs as those buffers have "special" virt addresses and require non-cachable mappings Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/nvram: Don't overwrite oops/panic report on normal shutdownJim Keniston
For normal halt, reboot, and poweroff events, refrain from overwriting the lnx,oops-log partition. Also, don't save the dmesg buffer on an emergency-restart event if we've already saved it earlier in panic(). Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc: Restore some misc devices to our configsStephen Rothwell
Uwe Kleine-König reported: while working on an defconfig (arm/mx27) I noticed that just updating it[1] results in removing CONFIG_EEPROM_AT24=y. The reason is that since commit v2.6.36-5965-g5f2365d (misc devices: do not enable by default) MISC_DEVICES isn't enabled anymore by default. So all defconfigs that have CONFIG_SOME_SYMBOL=y (or =m) (with SOME_SYMBOL depending on MISC_DEVICES) but not CONFIG_MISC_DEVICES=y suffer from the same problem. This restores those misc devices to the powerpc defconfigs. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Uwe Kleine-König Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30x86: apb_timer: Fixup genirq falloutThomas Gleixner
The lonely user of the internal interface was not in the coccinelle script. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29Merge branches 'fixes' and 'devel-stable' into for-linusRussell King
2011-03-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (26 commits) mmc: SDHI should depend on SUPERH || ARCH_SHMOBILE mmc: tmio_mmc: Move some defines into a shared header mmc: tmio: support aggressive clock gating mmc: tmio: fix power-mode interpretation mmc: tmio: remove work-around for unmasked SDIO interrupts sh: fix SDHI IO address-range ARM: mach-shmobile: fix SDHI IO address-range mmc: tmio: only access registers above 0xff, if available mfd: remove now redundant sh_mobile_sdhi.h header sh: convert boards to use linux/mmc/sh_mobile_sdhi.h ARM: mach-shmobile: convert boards to use linux/mmc/sh_mobile_sdhi.h mmc: tmio: convert the SDHI MMC driver from MFD to a platform driver sh: ecovec: use the CONFIG_MMC_TMIO symbols instead of MFD mmc: tmio: split core functionality, DMA and MFD glue mmc: tmio: use PIO for short transfers mmc: tmio-mmc: Improve DMA stability on sh-mobile mmc: fix mmc_app_send_scr() for dma transfer mmc: sdhci-esdhc: enable esdhc on imx53 mmc: sdhci-esdhc: use writel/readl as general APIs mmc: sdhci: add the abort CMDTYPE bits definition ...
2011-03-29Merge branch 'frv' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-frv * 'frv' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-frv: FRV: Use generic show_interrupts() FRV: Convert genirq namespace frv: Select GENERIC_HARDIRQS_NO_DEPRECATED frv: Convert cpu irq_chip to new functions frv: Convert mb93493 irq_chip to new functions frv: Convert mb93093 irq_chip to new function frv: Convert mb93091 irq_chip to new functions frv: Fix typo from __do_IRQ overhaul frv: Remove stale irq_chip.end FRV: Do some cleanups FRV: Missing node arg in alloc_thread_info_node() macro NOMMU: implement access_remote_vm NOMMU: support SMP dynamic percpu_alloc NOMMU: percpu should use is_vmalloc_addr().
2011-03-29Merge branch 'stable/bug-fixes-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug-fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: Use new irq_move functions xen: Convert genirq namespace xen: fix p2m section mismatches xen/p2m: Allocate p2m tracking pages on override xen-gntdev: unlock on error path in gntdev_mmap() xen-gntdev: return -EFAULT on copy_to_user failure
2011-03-29xen: fix p2m section mismatchesRandy Dunlap
Fix section mismatch warnings: set_phys_range_identity() is called by __init xen_set_identity(), so also mark set_phys_range_identity() as __init. then: __early_alloc_p2m() is called set_phys_range_identity(), so also mark __early_alloc_p2m() as __init. WARNING: arch/x86/built-in.o(.text+0x7856): Section mismatch in reference from the function __early_alloc_p2m() to the function .init.text:extend_brk() The function __early_alloc_p2m() references the function __init extend_brk(). This is often because __early_alloc_p2m lacks a __init annotation or the annotation of extend_brk is wrong. WARNING: arch/x86/built-in.o(.text+0x7967): Section mismatch in reference from the function set_phys_range_identity() to the function .init.text:extend_brk() The function set_phys_range_identity() references the function __init extend_brk(). This is often because set_phys_range_identity lacks a __init annotation or the annotation of extend_brk is wrong. [v2: Per Stephen Hemming recommonedation made __early_alloc_p2m static] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-29FRV: Use generic show_interrupts()Thomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-29FRV: Convert genirq namespaceThomas Gleixner
Convert to new function names. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-29frv: Select GENERIC_HARDIRQS_NO_DEPRECATEDThomas Gleixner
All chips converted Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-29frv: Convert cpu irq_chip to new functionsThomas Gleixner
2011-03-29frv: Convert mb93493 irq_chip to new functionsThomas Gleixner
2011-03-29frv: Convert mb93093 irq_chip to new functionThomas Gleixner
2011-03-29frv: Convert mb93091 irq_chip to new functionsThomas Gleixner
2011-03-29frv: Fix typo from __do_IRQ overhaulThomas Gleixner
Compiles way better. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-29frv: Remove stale irq_chip.endThomas Gleixner
irq_chip.end got obsolete with the removal of __do_IRQ(). irq-mb93093.c even lacks an implementation, but nobody noticed that it's broken since commit 88d6e1 in 2006. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-29FRV: Do some cleanupsAmerigo Wang
1. frv doesn't support SMP, remove the useless SMP bits. 2. frv has its own alloc_task_struct, so define __HAVE_ARCH_TASK_STRUCT_ALLOCATOR (I am not sure if frv should use generic alloc_task_struct().) Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-29FRV: Missing node arg in alloc_thread_info_node() macroDavid Howells
There are two alloc_thread_info_node() macros defined (one for debugging and one for normal). The commit that changed them most recently: commit b6a84016bd2598e35ead635147fa53619982648d Author: Eric Dumazet <eric.dumazet@gmail.com> Date: Tue Mar 22 16:30:42 2011 -0700 Subject: mm: NUMA aware alloc_thread_info_node() didn't add the node argument into the macro argument list for the normal macro. This results in the following error: kernel/fork.c:267:39: error: macro "alloc_thread_info_node" passed 2 arguments, but takes just 1 kernel/fork.c: In function 'dup_task_struct': kernel/fork.c:267: error: 'alloc_thread_info_node' undeclared (first use in this function) kernel/fork.c:267: error: (Each undeclared identifier is reported only once kernel/fork.c:267: error: for each function it appears in.) Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-29mn10300: Use generic show_interrupts()Thomas Gleixner
2011-03-29mn10300: Cleanup irq_desc accessThomas Gleixner
The migration needs only access to irq_data. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29mn10300: Convert genirq namespaceThomas Gleixner
2011-03-29frv: Use generic show_interrupts()Thomas Gleixner
2011-03-29frv: Convert genirq namespaceThomas Gleixner
All chips converted Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Howells <dhowells@redhat.com> LKML-Reference: <20110206192106.601290592@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Howells <dhowells@redhat.com> LKML-Reference: <20110206192106.501651128@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Howells <dhowells@redhat.com> LKML-Reference: <20110206192106.401266547@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
