According to intel CPU manual, every time PGD entry is changed in i386 PAE
mode, we need do a full TLB flush. Current code follows this and there is
comment for this too in the code.
But current code misses the multi-threaded case. A changed page table
might be used by several CPUs, every such CPU should flush TLB. Usually
this isn't a problem, because we prepopulate all PGD entries at process
fork. But when the process does munmap and follows new mmap, this issue
will be triggered.
When it happens, some CPUs keep doing page faults:
http://marc.info/?l=linux-kernel&m=129915020508238&w=2
Reported-by: Yasunori Goto<y-goto@jp.fujitsu.com>
Tested-by: Yasunori Goto<y-goto@jp.fujitsu.com>
Signed-off-by: Shaohua Li<shaohua.li@intel.com>
Cc: Mallick Asit K <asit.k.mallick@intel.com>
Cc: linux-mm <linux-mm@kvack.org>
Cc: stable <stable@kernel.org>
LKML-Reference: <1300246649.2337.95.camel@sli10-conroe>
Current stack dump code scans entire stack and check each entry
contains a pointer to kernel code. If CONFIG_FRAME_POINTER=y it
could mark whether the pointer is valid or not based on value of
the frame pointer. Invalid entries could be preceded by '?' sign.
However this was not going to happen because scan start point
was always higher than the frame pointer so that they could not
meet.
Commit 9c0729dc8062 ("x86: Eliminate bp argument from the stack
tracing routines") delayed bp acquisition point, so the bp was
read in lower frame, thus all of the entries were marked
invalid.
This patch fixes this by reverting above commit while retaining
stack_frame() helper as suggested by Frederic Weisbecker.
End result looks like below:
before:
[ 3.508329] Call Trace:
[ 3.508551] [<ffffffff814f35c9>] ? panic+0x91/0x199
[ 3.508662] [<ffffffff814f3739>] ? printk+0x68/0x6a
[ 3.508770] [<ffffffff81a981b2>] ? mount_block_root+0x257/0x26e
[ 3.508876] [<ffffffff81a9821f>] ? mount_root+0x56/0x5a
[ 3.508975] [<ffffffff81a98393>] ? prepare_namespace+0x170/0x1a9
[ 3.509216] [<ffffffff81a9772b>] ? kernel_init+0x1d2/0x1e2
[ 3.509335] [<ffffffff81003894>] ? kernel_thread_helper+0x4/0x10
[ 3.509442] [<ffffffff814f6880>] ? restore_args+0x0/0x30
[ 3.509542] [<ffffffff81a97559>] ? kernel_init+0x0/0x1e2
[ 3.509641] [<ffffffff81003890>] ? kernel_thread_helper+0x0/0x10
after:
[ 3.522991] Call Trace:
[ 3.523351] [<ffffffff814f35b9>] panic+0x91/0x199
[ 3.523468] [<ffffffff814f3729>] ? printk+0x68/0x6a
[ 3.523576] [<ffffffff81a981b2>] mount_block_root+0x257/0x26e
[ 3.523681] [<ffffffff81a9821f>] mount_root+0x56/0x5a
[ 3.523780] [<ffffffff81a98393>] prepare_namespace+0x170/0x1a9
[ 3.523885] [<ffffffff81a9772b>] kernel_init+0x1d2/0x1e2
[ 3.523987] [<ffffffff81003894>] kernel_thread_helper+0x4/0x10
[ 3.524228] [<ffffffff814f6880>] ? restore_args+0x0/0x30
[ 3.524345] [<ffffffff81a97559>] ? kernel_init+0x0/0x1e2
[ 3.524445] [<ffffffff81003890>] ? kernel_thread_helper+0x0/0x10
-v5:
* fix build breakage with oprofile
-v4:
* use 0 instead of regs->bp
* separate out printk changes
-v3:
* apply comment from Frederic
* add a couple of printk fixes
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: Soren Sandmann <ssp@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Robert Richter <robert.richter@amd.com>
LKML-Reference: <1300416006-3163-1-git-send-email-namhyung@gmail.com>
The many stray whitespaces and other uncleanlinesses made this code
almost unreadable to me - so fix those.
No changes to the code.
They were generated by 'codespell' and then manually reviewed.
Cc: trivial@kernel.org
LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi>
Merge reason: Merge upstream commits to avoid conflicts in upcoming patches.
Testing on the OLPC XO-1.5 (VIA C7-M 1000MHz CPU) shows a partial_csum()
speed increase by a factor of 1.5 when we switch to the Pentium-optimized
version.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Cc: dilinger@queued.net
Merge reason: This is one followup commit that was not in x86/mm - merge it via the urgent path
[AV: on architectures where default conflicts with existing
flags, that is]
Support for Always Running APIC timer (ARAT) was introduced in
commit db954b5898dd3ef3ef93f4144158ea8f97deb058. This feature
allows us to avoid switching timers from LAPIC to something else
(e.g. HPET) and go into timer broadcasts when entering deep
C-states.
AMD processors don't provide a CPUID bit for that feature but
they also keep APIC timers running in deep C-states (except for
cases when the processor is affected by erratum 400). Therefore
we should set ARAT feature bit on AMD CPUs.
Tested-by: Borislav Petkov <borislav.petkov@amd.com>
Acked-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Acked-by: Mark Langsdorf <mark.langsdorf@amd.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
LKML-Reference: <1300205624-4813-1-git-send-email-ostr@amd64.org>
Commit 7f74f8f28a2bd9db9404f7d364e2097a0c42cc12
(x86 quirk: Fix polarity for IRQ0 pin2 override on SB800
systems) introduced a regression. It removed some SB600 specific
code to determine the revision ID without adapting a
corresponding revision ID check for SB600.
See this mail thread:
http://marc.info/?l=linux-kernel&m=129980296006380&w=2
This patch adapts the corresponding check to cover all SB600
revisions.
Tested-by: Wang Lei <f3d27b@gmail.com>
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: stable@kernel.org # 38.x, 37.x, 32.x
LKML-Reference: <20110315143137.GD29499@alberich.amd.com>
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits)
x86: Clean up apic.c and apic.h
x86: Remove superflous goal definition of tsc_sync
x86: dt: Correct local apic documentation in device tree bindings
x86: dt: Cleanup local apic setup
x86: dt: Fix OLPC=y/INTEL_CE=n build
rtc: cmos: Add OF bindings
x86: ce4100: Use OF to setup devices
x86: ioapic: Add OF bindings for IO_APIC
x86: dtb: Add generic bus probe
x86: dtb: Add support for PCI devices backed by dtb nodes
x86: dtb: Add device tree support for HPET
x86: dtb: Add early parsing of IO_APIC
x86: dtb: Add irq domain abstraction
x86: dtb: Add a device tree for CE4100
x86: Add device tree support
x86: e820: Remove conditional early mapping in parse_e820_ext
x86: OLPC: Make OLPC=n build again
x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection
x86: OLPC: Cleanup config maze completely
x86: OLPC: Hide OLPC_OPENFIRMWARE config switch
Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (93 commits)
x86, tlb, UV: Do small micro-optimization for native_flush_tlb_others()
x86-64, NUMA: Don't call numa_set_distanc() for all possible node combinations during emulation
x86-64, NUMA: Don't assume phys node 0 is always online in numa_emulation()
x86-64, NUMA: Clean up initmem_init()
x86-64, NUMA: Fix numa_emulation code with node0 without RAM
x86-64, NUMA: Revert NUMA affine page table allocation
x86: Work around old gas bug
x86-64, NUMA: Better explain numa_distance handling
x86-64, NUMA: Fix distance table handling
mm: Move early_node_map[] reverse scan helpers under HAVE_MEMBLOCK
x86-64, NUMA: Fix size of numa_distance array
x86: Rename e820_table_* to pgt_buf_*
bootmem: Move __alloc_memory_core_early() to nobootmem.c
bootmem: Move contig_page_data definition to bootmem.c/nobootmem.c
bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.c
x86-64, NUMA: Seperate out numa_alloc_distance() from numa_set_distance()
x86-64, NUMA: Add proper function comments to global functions
x86-64, NUMA: Move NUMA emulation into numa_emulation.c
x86-64, NUMA: Prepare numa_emulation() for moving NUMA emulation into a separate file
x86-64, NUMA: Do not scan two times for setup_node_bootmem()
Fix up conflicts in arch/x86/kernel/smpboot.c
* 'x86-mem-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-64, mem: Convert memmove() to assembly file and fix return value bug
* 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, microcode, AMD: Fix signedness bug in generic_load_microcode()
x86, microcode, AMD: Extend ucode size verification
x86, microcode, AMD: Cleanup dmesg output
x86, microcode, AMD: Remove unneeded memset call
x86, microcode, AMD: Simplify get_next_ucode
x86, microcode, AMD: Simplify install_equiv_cpu_table
x86, microcode, AMD: Release firmware on error
x86, microcode: Correct sysdev_add error path
* 'um-irq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
um: Select GENERIC_HARDIRQS_NO_DEPRECATED
um: Use proper accessors in show_interrupts()
um: Convert irq_chips to new functions
um: Remove stale irq_chip.end
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (116 commits)
x86: Enable forced interrupt threading support
x86: Mark low level interrupts IRQF_NO_THREAD
x86: Use generic show_interrupts
x86: ioapic: Avoid redundant lookup of irq_cfg
x86: ioapic: Use new move_irq functions
x86: Use the proper accessors in fixup_irqs()
x86: ioapic: Use irq_data->state
x86: ioapic: Simplify irq chip and handler setup
x86: Cleanup the genirq name space
genirq: Add chip flag to force mask on suspend
genirq: Add desc->irq_data accessor
genirq: Add comments to Kconfig switches
genirq: Fixup fasteoi handler for oneshot mode
genirq: Provide forced interrupt threading
sched: Switch wait_task_inactive to schedule_hrtimeout()
genirq: Add IRQF_NO_THREAD
genirq: Allow shared oneshot interrupts
genirq: Prepare the handling of shared oneshot interrupts
genirq: Make warning in handle_percpu_event useful
x86: ioapic: Move trigger defines to io_apic.h
Fix up trivial(?) conflicts in arch/x86/pci/xen.c due to genirq name
space changes clashing with the Xen cleanups. The set_irq_msi() had
moved to xen_bind_pirq_msi_to_irq().
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Combine printk()s in show_regs_common()
x86: Don't call dump_stack() from arch_trigger_all_cpu_backtrace_handler()
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix and clean up generic_processor_info()
x86: Don't copy per_cpu cpuinfo for BSP two times
x86: Move llc_shared_map out of cpu_info
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, binutils, xen: Fix another wrong size directive
x86: Remove dead config option X86_CPU
x86: Really print supported CPUs if PROCESSOR_SELECT=y
x86: Fix a bogus unwind annotation in lib/semaphore_32.S
um, x86-64: Fix UML build after adding CFI annotations to lib/rwsem_64.S
x86: Remove unused bits from lib/thunk_*.S
x86: Use {push,pop}_cfi in more places
x86-64: Add CFI annotations to lib/rwsem_64.S
x86, asm: Cleanup unnecssary macros in asm-offsets.c
x86, system.h: Drop unused __SAVE/__RESTORE macros
x86: Use bitmap library functions
x86: Partly unify asm-offsets_{32,64}.c
x86: Reduce back the alignment of the per-CPU data section
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits)
posix-clocks: Check write permissions in posix syscalls
hrtimer: Remove empty hrtimer_init_hres_timer()
hrtimer: Update hrtimer->state documentation
hrtimer: Update base[CLOCK_BOOTTIME].offset correctly
timers: Export CLOCK_BOOTTIME via the posix timers interface
timers: Add CLOCK_BOOTTIME hrtimer base
time: Extend get_xtime_and_monotonic_offset() to also return sleep
time: Introduce get_monotonic_boottime and ktime_get_boottime
hrtimers: extend hrtimer base code to handle more then 2 clockids
ntp: Remove redundant and incorrect parameter check
mn10300: Switch do_timer() to xtimer_update()
posix clocks: Introduce dynamic clocks
posix-timers: Cleanup namespace
posix-timers: Add support for fd based clocks
x86: Add clock_adjtime for x86
posix-timers: Introduce a syscall for clock tuning.
time: Splitout compat timex accessors
ntp: Add ADJ_SETOFFSET mode bit
time: Introduce timekeeping_inject_offset
posix-timer: Update comment
Fix up new system-call-related conflicts in
arch/x86/ia32/ia32entry.S
arch/x86/include/asm/unistd_32.h
arch/x86/include/asm/unistd_64.h
arch/x86/kernel/syscall_table_32.S
(name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some
due to movement of get_jiffies_64() in:
kernel/time.c
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (184 commits)
perf probe: Clean up probe_point_lazy_walker() return value
tracing: Fix irqoff selftest expanding max buffer
tracing: Align 4 byte ints together in struct tracer
tracing: Export trace_set_clr_event()
tracing: Explain about unstable clock on resume with ring buffer warning
ftrace/graph: Trace function entry before updating index
ftrace: Add .ref.text as one of the safe areas to trace
tracing: Adjust conditional expression latency formatting.
tracing: Fix event alignment: skb:kfree_skb
tracing: Fix event alignment: mce:mce_record
tracing: Fix event alignment: kvm:kvm_hv_hypercall
tracing: Fix event alignment: module:module_request
tracing: Fix event alignment: ftrace:context_switch and ftrace:wakeup
tracing: Remove lock_depth from event entry
perf header: Stop using 'self'
perf session: Use evlist/evsel for managing perf.data attributes
perf top: Don't let events to eat up whole header line
perf top: Fix events overflow in top command
ring-buffer: Remove unused #include <linux/trace_irq.h>
tracing: Add an 'overwrite' trace_option.
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rtmutex: tester: Remove the remaining BKL leftovers
lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause
rtmutex: Simplify PI algorithm and make highest prio task get lock
rwsem: Remove redundant asmregparm annotation
rwsem: Move duplicate function prototypes to linux/rwsem.h
rwsem: Unify the duplicate rwsem_is_locked() inlines
rwsem: Move duplicate init macros and functions to linux/rwsem.h
rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h
x86: Cleanup rwsem_count_t typedef
rwsem: Cleanup includes
locking: Remove deprecated lock initializers
cred: Replace deprecated spinlock initialization
kthread: Replace deprecated spinlock initialization
xtensa: Replace deprecated spinlock initialization
um: Replace deprecated spinlock initialization
sparc: Replace deprecated spinlock initialization
mips: Replace deprecated spinlock initialization
cris: Replace deprecated spinlock initialization
alpha: Replace deprecated spinlock initialization
rtmutex-tester: Remove BKL tests
* 'core-futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
arm: Remove bogus comment in futex_atomic_cmpxchg_inatomic()
futex: Deobfuscate handle_futex_death()
plist: Add priority list test
plist: Shrink struct plist_head
futex,plist: Remove debug lock assignment from plist_node
futex,plist: Pass the real head of the priority list to plist_del()
futex: Sanitize futex ops argument types
futex: Sanitize cmpxchg_futex_value_locked API
futex: Remove redundant pagefault_disable in futex_atomic_cmpxchg_inatomic()
futex: Avoid redudant evaluation of task_pid_vnr()
futex: Update futex_wait_setup comments about locking
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (57 commits)
tidy the trailing symlinks traversal up
Turn resolution of trailing symlinks iterative everywhere
simplify link_path_walk() tail
Make trailing symlink resolution in path_lookupat() iterative
update nd->inode in __do_follow_link() instead of after do_follow_link()
pull handling of one pathname component into a helper
fs: allow AT_EMPTY_PATH in linkat(), limit that to CAP_DAC_READ_SEARCH
Allow passing O_PATH descriptors via SCM_RIGHTS datagrams
readlinkat(), fchownat() and fstatat() with empty relative pathnames
Allow O_PATH for symlinks
New kind of open files - "location only".
ext4: Copy fs UUID to superblock
ext3: Copy fs UUID to superblock.
vfs: Export file system uuid via /proc/<pid>/mountinfo
unistd.h: Add new syscalls numbers to asm-generic
x86: Add new syscalls for x86_64
x86: Add new syscalls for x86_32
fs: Remove i_nlink check from file system link callback
fs: Don't allow to create hardlink for deleted file
vfs: Add open by file handle support
* 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm:
xen: suspend: remove xen_hvm_suspend
xen: suspend: pull pre/post suspend hooks out into suspend_info
xen: suspend: move arch specific pre/post suspend hooks into generic hooks
xen: suspend: refactor non-arch specific pre/post suspend hooks
xen: suspend: add "arch" to pre/post suspend hooks
xen: suspend: pass extra hypercall argument via suspend_info struct
xen: suspend: refactor cancellation flag into a structure
xen: suspend: use HYPERVISOR_suspend for PVHVM case instead of open coding
xen: switch to new schedop hypercall by default.
xen: use new schedop interface for suspend
xen: do not respond to unknown xenstore control requests
xen: fix compile issue if XEN is enabled but XEN_PVHVM is disabled
xen: PV on HVM: support PV spinlocks and IPIs
xen: make the ballon driver work for hvm domains
xen-blkfront: handle Xen major numbers other than XENVBD
xen: do not use xen_info on HVM, set pv_info name to "Xen HVM"
xen: no need to delay xen_setup_shutdown_event for hvm guests anymore
of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/ia64' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: ia64 build broken due to "xen: switch to new schedop hypercall by default."
* 'stable/blkfront-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: Union the blkif_request request specific fields
* 'stable/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: annotate functions which only call into __init at start of day
xen p2m: annotate variable which appears unused
xen: events: mark cpu_evtchn_mask_p as __refdata
* 'stable/irq.cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: events: remove dom0 specific xen_create_msi_irq
xen: events: use xen_bind_pirq_msi_to_irq from xen_create_msi_irq
xen: events: push set_irq_msi down into xen_create_msi_irq
xen: events: update pirq_to_irq in xen_create_msi_irq
xen: events: refactor xen_create_msi_irq slightly
xen: events: separate MSI PIRQ allocation from PIRQ binding to IRQ
xen: events: assume PHYSDEVOP_get_free_pirq exists
xen: pci: collapse apic_register_gsi_xen_hvm and xen_hvm_register_pirq
xen: events: return irq from xen_allocate_pirq_msi
xen: events: drop XEN_ALLOC_IRQ flag to xen_allocate_pirq_msi
xen: events: do not leak IRQ from xen_allocate_pirq_msi when no pirq available.
xen: pci: only define xen_initdom_setup_msi_irqs if CONFIG_XEN_DOM0
* 'stable/irq.rework' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/irq: Cleanup up the pirq_to_irq for DomU PV PCI passthrough guests as well.
xen: Use IRQF_FORCE_RESUME
xen/timer: Missing IRQF_NO_SUSPEND in timer code broke suspend.
xen: Fix compile error introduced by "switch to new irq_chip functions"
xen: Switch to new irq_chip functions
xen: Remove stale irq_chip.end
xen: events: do not free legacy IRQs
xen: events: allocate GSIs and dynamic IRQs from separate IRQ ranges.
xen: events: add xen_allocate_irq_{dynamic, gsi} and xen_free_irq
xen:events: move find_unbound_irq inside CONFIG_PCI_MSI
xen: handled remapped IRQs when enabling a pcifront PCI device.
genirq: Add IRQF_FORCE_RESUME
* 'stable/pcifront-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
pci/xen: When free-ing MSI-X/MSI irq->desc also use generic code.
pci/xen: Cleanup: convert int** to int[]
pci/xen: Use xen_allocate_pirq_msi instead of xen_allocate_pirq
xen-pcifront: Sanity check the MSI/MSI-X values
xen-pcifront: don't use flush_scheduled_work()
* 'stable/p2m-identity.v4.9.1' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/m2p: Check whether the MFN has IDENTITY_FRAME bit set..
xen/m2p: No need to catch exceptions when we know that there is no RAM
xen/debug: WARN_ON when identity PFN has no _PAGE_IOMAP flag set.
xen/debugfs: Add 'p2m' file for printing out the P2M layout.
xen/setup: Set identity mapping for non-RAM E820 and E820 gaps.
xen/mmu: WARN_ON when racing to swap middle leaf.
xen/mmu: Set _PAGE_IOMAP if PFN is an identity PFN.
xen/mmu: Add the notion of identity (1-1) mapping.
xen: Mark all initial reserved pages for the balloon as INVALID_P2M_ENTRY.
* 'stable/e820' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/e820: Don't mark balloon memory as E820_UNUSABLE when running as guest and fix overflow.
xen/setup: Inhibit resource API from using System RAM E820 gaps as PCI mem gaps.
Intel Archiecture Software Developer's Manual section 7.1.3 specifies that a
core serializing instruction such as "cpuid" should be executed on _each_ core
before the new instruction is made visible.
Failure to do so can lead to unspecified behavior (Intel XMC erratas include
General Protection Fault in the list), so we should avoid this at all cost.
This problem can affect modified code executed by interrupt handlers after
interrupt are re-enabled at the end of stop_machine, because no core serializing
instruction is executed between the code modification and the moment interrupts
are reenabled.
Because stop_machine_text_poke performs the text modification from the first CPU
decrementing stop_machine_first, modified code executed in thread context is
also affected by this problem. To explain why, we have to split the CPUs in two
categories: the CPU that initiates the text modification (calls text_poke_smp)
and all the others. The scheduler, executed on all other CPUs after
stop_machine, issues an "iret" core serializing instruction, and therefore
handles core serialization for all these CPUs. However, the text modification
initiator can continue its execution on the same thread and access the modified
text without any scheduler call. Given that the CPU that initiates the code
modification is not guaranteed to be the one actually performing the code
modification, it falls into the XMC errata.
Q: Isn't this executed from an IPI handler, which will return with IRET (a
serializing instruction) anyway?
A: No, now stop_machine uses per-cpu workqueue, so that handler will be
executed from worker threads. There is no iret anymore.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
LKML-Reference: <20110303160137.GB1590@Krystal>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: <stable@kernel.org>
Cc: Arjan van de Ven <arjan@infradead.org>
native_flush_tlb_others() is called from:
flush_tlb_current_task()
flush_tlb_mm()
flush_tlb_page()
All these functions disable preemption explicitly, so we can use
smp_processor_id() instead of get_cpu() and put_cpu().
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Cc: Cliff Wickman <cpw@sgi.com>
LKML-Reference: <4D7EC791.4040003@cn.fujitsu.com>
arch/x86/mm/numa_64.c
Merge reason: Resolve the conflict, update the branch to .38.
This patch add new syscalls to x86_64
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch adds new syscalls to x86_32
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300:
MN10300: atomic_read() should ensure it emits a load
MN10300: The SMP_ICACHE_INV_FLUSH_RANGE IPI command does not exist
MN10300: Proper use of macros get_user() in the case of incremented pointers
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (26 commits)
MIPS: Alchemy: Fix reset for MTX-1 and XXS1500
MIPS: MTX-1: Make au1000_eth probe all PHY addresses
MIPS: Jz4740: Add HAVE_CLK
MIPS: Move idle task creation to work queue
MIPS, Perf-events: Use unsigned delta for right shift in event update
MIPS, Perf-events: Work with the new callchain interface
MIPS, Perf-events: Fix event check in validate_event()
MIPS, Perf-events: Work with the new PMU interface
MIPS, Perf-events: Work with irq_work
MIPS: Fix always CONFIG_LOONGSON_UART_BASE=y
MIPS: Loongson: Fix potentially wrong string handling
MIPS: Fix GCC-4.6 'set but not used' warning in arch/mips/mm/init.c
MIPS: Fix GCC-4.6 'set but not used' warning in ieee754int.h
MIPS: Remove unused code from arch/mips/kernel/syscall.c
MIPS: Fix GCC-4.6 'set but not used' warning in signal*.c
MIPS: MSP: Fix MSP71xx bpci interrupt handler return value
MIPS: Select R4K timer lib for all MSP platforms
MIPS: Loongson: Remove ad-hoc cmdline default
MIPS: Clear the correct flag in sysmips(MIPS_FIXADE, ...).
MIPS: Add an unreachable return statement to satisfy buggy GCCs.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: ce4100: Set pci ops via callback instead of module init
x86/mm: Fix pgd_lock deadlock
x86/mm: Handle mm_fault_error() in kernel space
x86: Don't check for BIOS corruption in first 64K when there's no need to
commit 522d7dec(futex: Remove redundant pagefault_disable in
futex_atomic_cmpxchg_inatomic()) added a bogus comment.
/* Note that preemption is disabled by futex_atomic_cmpxchg_inatomic
* call sites. */
Bogus in two aspects:
1) pagefault_disable != preempt_disable even if the mechanism we use
is the same
2) we have a call site which deliberately does not disable pagefaults
as it wants the possible fault to be handled - though that has been
changed for consistency reasons now.
Sigh. I really should have seen that when committing the above. :(
Catched-by-and-rightfully-ranted-at-by: Linus Torvalds <torvalds@linux-foundation.org>
LKML-Reference: <alpine.LFD.2.00.1103141126590.2787@localhost6.localdomain6>
Cc: Michel Lespinasse <walken@google.com>
Cc: Darren Hart <darren@dvhart.com>
Since commit 32fd6901 (MIPS: Alchemy: get rid of common/reset.c)
Alchemy-based boards use their own reset function. For MTX-1 and XXS1500,
the reset function pokes at the BCSR.SYSTEM_RESET register, but this does
not work. According to Bruno Randolf, this was not tested when written.
Previously, the generic au1000_restart() routine called the board specific
reset function, which for MTX-1 and XXS1500 did not work, but finally made
a jump to the reset vector, which really triggers a system restart. Fix
reboot for both targets by jumping to the reset vector.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2093/
Acked-by: Bruno Randolf <br1@einfach.org>
When au1000_eth probes the MII bus for PHY address, if we do not set
au1000_eth platform data's phy_search_highest_address, the MII probing
logic will exit early and will assume a valid PHY is found at address 0.
For MTX-1, the PHY is at address 31, and without this patch, the link
detection/speed/duplex would not work correctly.
CC: stable@kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/2111/
Jz4740 supports the clock framework but doesn't have HAVE_CLK defined,
so define it!
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
To: linux-kernel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/2112/
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
To avoid forking usermode thread when creating an idle task, move fork_idle
to a work queue.
If kernel starts with maxcpus= option which does not bring all available
cpus online at boot time, idle tasks for offline cpus are not created. If
later offline cpus are hotplugged through sysfs, __cpu_up is called in
the context of the user task, and fork_idle copies its non-zero mm
pointer. This causes BUG() in per_cpu_trap_init.
This also avoids issues with resource limits of the CPU writing to sysfs,
containers, maybe others.
Signed-off-by: Maksim Rayskiy <mrayskiy@broadcom.com>
Patchwork: https://patchwork.linux-mips.org/patch/2070/
Leverage the commit for ARM by Will Deacon:
- 446a5a8b1eb91a6990e5c8fe29f14e7a95b69132
ARM: 6205/1: perf: ensure counter delta is treated as unsigned
Hardware performance counters on ARM are 32-bits wide but atomic64_t
variables are used to represent counter data in the hw_perf_event structure.
The armpmu_event_update function right-shifts a signed 64-bit delta variable
and adds the result to the event count. This can lead to shifting in sign-bits
if the MSB of the 32-bit counter value is set. This results in perf output
such as:
Performance counter stats for 'sleep 20':
18446744073460670464 cycles <-- 0xFFFFFFFFF12A6000
7783773 instructions # 0.000 IPC
465 context-switches
161 page-faults
1172393 branches
20.154242147 seconds time elapsed
This patch ensures that the delta value is treated as unsigned so that the
right shift sets the upper bits to zero.
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: David Daney <ddaney@caviumnetworks.com>
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
To: a.p.zijlstra@chello.nl
To: fweisbec@gmail.com
To: will.deacon@arm.com
Cc: linux-mips@linux-mips.org
Cc: wuzhangjin@gmail.com
Cc: paulus@samba.org
Cc: mingo@elte.hu
Cc: acme@redhat.com
Cc: matt@console-pimps.org
Cc: sshtylyov@mvista.com
Patchwork: http://patchwork.linux-mips.org/patch/2015/
This is the MIPS part of the following commits by Frederic Weisbecker:
- f72c1a931e311bb7780fee19e41a89ac42cab50e
perf: Factorize callchain context handling
Store the kernel and user contexts from the generic layer instead
of archs, this gathers some repetitive code.
- 56962b4449af34070bb1994621ef4f0265eed4d8
perf: Generalize some arch callchain code
- Most archs use one callchain buffer per cpu, except x86 that needs
to deal with NMIs. Provide a default perf_callchain_buffer()
implementation that x86 overrides.
- Centralize all the kernel/user regs handling and invoke new arch
handlers from there: perf_callchain_user() / perf_callchain_kernel()
That avoid all the user_mode(), current->mm checks and so...
- Invert some parameters in perf_callchain_*() helpers: entry to the
left, regs to the right, following the traditional (dst, src).
- 70791ce9ba68a5921c9905ef05d23f62a90bc10c
perf: Generalize callchain_store()
callchain_store() is the same on every archs, inline it in
perf_event.h and rename it to perf_callchain_store() to avoid
any collision.
This removes repetitive code.
- c1a65932fd7216fdc9a0db8bbffe1d47842f862c
perf: Drop unappropriate tests on arch callchains
Drop the TASK_RUNNING test on user tasks for callchains as
this check doesn't seem to make any sense.
Also remove the tests for !current that is not supposed to
happen and current->pid as this should be handled at the
generic level, with exclude_idle attribute.
Reported-by: Wu Zhangjin <wuzhangjin@gmail.com>
Cc: mingo@elte.hu
Cc: acme@redhat.com
Cc: dengcheng.zhu@gmail.com
Patchwork: http://patchwork.linux-mips.org/patch/2014/
Ignore events that are in off/error state or belong to a different PMU.
This patch originates from the following commit for ARM by Will Deacon:
- 65b4711ff513767341aa1915c822de6ec0de65cb
ARM: 6352/1: perf: fix event validation
The validate_event function in the ARM perf events backend has the
following problems:
1.) Events that are disabled count towards the cost.
2.) Events associated with other PMUs [for example, software events or
breakpoints] do not count towards the cost, but do fail validation,
causing the group to fail.
This patch changes validate_event so that it ignores events in the
PERF_EVENT_STATE_OFF state or that are scheduled for other PMUs.
Cc: mingo@elte.hu
Cc: acme@redhat.com
Cc: ddaney@caviumnetworks.com
Patchwork: http://patchwork.linux-mips.org/patch/2013/
This is the MIPS part of the following commits by Peter Zijlstra:
- a4eaf7f14675cb512d69f0c928055e73d0c6d252
perf: Rework the PMU methods
Replace pmu::{enable,disable,start,stop,unthrottle} with
pmu::{add,del,start,stop}, all of which take a flags argument.
The new interface extends the capability to stop a counter while
keeping it scheduled on the PMU. We replace the throttled state with
the generic stopped state.
This also allows us to efficiently stop/start counters over certain
code paths (like IRQ handlers).
It also allows scheduling a counter without it starting, allowing for
a generic frozen state (useful for rotating stopped counters).
The stopped state is implemented in two different ways, depending on
how the architecture implemented the throttled state:
1) We disable the counter:
a) the pmu has per-counter enable bits, we flip that
b) we program a NOP event, preserving the counter state
2) We store the counter state and ignore all read/overflow events
For MIPSXX, the stopped state is implemented in the way of 1.b as above.
- 33696fc0d141bbbcb12f75b69608ea83282e3117
perf: Per PMU disable
Changes perf_disable() into perf_pmu_disable().
- 24cd7f54a0d47e1d5b3de29e2456bfbd2d8447b7
perf: Reduce perf_disable() usage
Since the current perf_disable() usage is only an optimization,
remove it for now. This eases the removal of the __weak
hw_perf_enable() interface.
- b0a873ebbf87bf38bf70b5e39a7cadc96099fa13
perf: Register PMU implementations
Simple registration interface for struct pmu, this provides the
infrastructure for removing all the weak functions.
- 51b0fe39549a04858001922919ab355dee9bdfcf
perf: Deconstify struct pmu
sed -ie 's/const struct pmu\>/struct pmu/g' `git grep -l "const struct pmu\>"`
Cc: mingo@elte.hu
Cc: acme@redhat.com
Patchwork: http://patchwork.linux-mips.org/patch/2012/
This is the MIPS part of the following commit by Peter Zijlstra:
- e360adbe29241a0194e10e20595360dd7b98a2b3
irq_work: Add generic hardirq context callbacks
Provide a mechanism that allows running code in IRQ context. It is
most useful for NMI code that needs to interact with the rest of the
system -- like wakeup a task to drain buffers.
Perf currently has such a mechanism, so extract that and provide it as
a generic feature, independent of perf so that others may also
benefit.
The IRQ context callback is generated through self-IPIs where
possible, or on architectures like powerpc the decrementer (the
built-in timer facility) is set to generate an interrupt immediately.
Architectures that don't have anything like this get to do with a
callback from the timer tick. These architectures can call
irq_work_run() at the tail of any IRQ handlers that might enqueue such
work (like the perf IRQ handler) to avoid undue latencies in
processing the work.
For MIPSXX, we need to call irq_work_run() at the tail of the perf IRQ
handler as described above.
Cc: mingo@elte.hu
Cc: acme@redhat.com
Cc: sshtylyov@mvista.com,
Patchwork: http://patchwork.linux-mips.org/patch/2011/
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
Cc: linux-mips <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/2055/
This error was reported by cppcheck:
arch/mips/loongson/common/machtype.c:56: error: Dangerous usage of 'str' (strncpy doesn't always 0-terminate it)
If strncpy copied MACHTYPE_LEN bytes, the destination string str
was not terminated.
The patch adds one more byte to str and makes sure that this byte is
always 0.
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
Cc: Wu Zhangjin <wuzhangjin@gmail.com>
Cc: Arnaud Patard <apatard@mandriva.com>
Patchwork: https://patchwork.linux-mips.org/patch/2053/
Under some combinations of CONFIG_*, lastpfn in page_is_ram is 'set
but not used'. Mark it as __maybe_unused to quiet the warning/error.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/2033/
