commit 913050b91eb94f194392dd797b1ff3779f606ac0 upstream.
If oprofilefs_ulong_from_user() is called with count equals
zero, *val remains unchanged. Depending on the implementation it
might be uninitialized.
Change oprofilefs_ulong_from_user()'s interface to return count
on success. Thus, we are able to return early if count equals
zero which avoids using *val uninitialized. Fixing all users of
oprofilefs_ulong_ from_user().
This follows write syscall implementation when count is zero:
"If count is zero ... [and if] no errors are detected, 0 will be
returned without causing any other effect." (man 2 write)
Reported-By: Mike Waychison <mikew@google.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: oprofile-list <oprofile-list@lists.sourceforge.net>
Link: http://lkml.kernel.org/r/20111219153830.GH16765@erda.amd.com
commit c0d96aed8c6dd925afe9ea35491a0cd458642a86 upstream.
Signed-off-by: Jason Chen <jason.chen@linaro.org>
commit e5fe29c7198a1f6616286dfc8602a69da165cb3f upstream.
Commit 10299e2e4e3ed3b16503d4e04edd48b33083f4e2 (ARM: RX-51:
Enable isp1704 power on/off) added power management for isp1704.
However, the transceiver should be powered on by default,
otherwise USB doesn't work at all for networking during
boot.
All kernels after v3.0 are affected.
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com>
Reviewed-by: Sebastian Reichel <sre@debian.org>
[tony@atomide.com: updated comments]
commit d3db728125c4470a2d061ac10fa7395e18237263 upstream.
d312ae878b6a "xen: use maximum reservation to limit amount of usable RAM"
clamped the total amount of RAM to the current maximum reservation. This is
correct for dom0 but is not correct for guest domains. In order to boot a guest
"pre-ballooned" (e.g. with memory=1G but maxmem=2G) in order to allow for
future memory expansion the guest must derive max_pfn from the e820 provided by
the toolstack and not the current maximum reservation (which can reflect only
the current maximum, not the guest lifetime max). The existing algorithm
already behaves this correctly if we do not artificially limit the maximum
number of pages for the guest case.
For a guest booted with maxmem=512, memory=128 this results in:
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] Xen: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] Xen: 00000000000a0000 - 0000000000100000 (reserved)
-[ 0.000000] Xen: 0000000000100000 - 0000000008100000 (usable)
-[ 0.000000] Xen: 0000000008100000 - 0000000020800000 (unusable)
+[ 0.000000] Xen: 0000000000100000 - 0000000020800000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] DMI not present or invalid.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
-[ 0.000000] last_pfn = 0x8100 max_arch_pfn = 0x1000000
+[ 0.000000] last_pfn = 0x20800 max_arch_pfn = 0x1000000
[ 0.000000] initial memory mapped : 0 - 027ff000
[ 0.000000] Base memory trampoline at [c009f000] 9f000 size 4096
-[ 0.000000] init_memory_mapping: 0000000000000000-0000000008100000
-[ 0.000000] 0000000000 - 0008100000 page 4k
-[ 0.000000] kernel direct mapping tables up to 8100000 @ 27bb000-27ff000
+[ 0.000000] init_memory_mapping: 0000000000000000-0000000020800000
+[ 0.000000] 0000000000 - 0020800000 page 4k
+[ 0.000000] kernel direct mapping tables up to 20800000 @ 26f8000-27ff000
[ 0.000000] xen: setting RW the range 27e8000 - 27ff000
[ 0.000000] 0MB HIGHMEM available.
-[ 0.000000] 129MB LOWMEM available.
-[ 0.000000] mapped low ram: 0 - 08100000
-[ 0.000000] low ram: 0 - 08100000
+[ 0.000000] 520MB LOWMEM available.
+[ 0.000000] mapped low ram: 0 - 20800000
+[ 0.000000] low ram: 0 - 20800000
With this change "xl mem-set <domain> 512M" will successfully increase the
guest RAM (by reducing the balloon).
There is no change for dom0.
Reported-and-Tested-by: George Shuklin <george.shuklin@gmail.com>
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 2ded6e6a94c98ea453a156748cb7fabaf39a76b9 upstream.
When HPET is operating in RTC mode, the TN_ENABLE bit on timer1
controls whether the HPET or the RTC delivers interrupts to irq8. When
the system goes into suspend, the RTC driver sends a signal to the
HPET driver so that the HPET releases control of irq8, allowing the
RTC to wake the system from suspend. The switchover is accomplished by
a write to the HPET configuration registers which currently only
occurs while servicing the HPET interrupt.
On some systems, I have seen the system suspend before an HPET
interrupt occurs, preventing the write to the HPET configuration
register and leaving the HPET in control of the irq8. As the HPET is
not active during suspend, it does not generate a wake signal and RTC
alarms do not work.
This patch forces the HPET driver to immediately transfer control of
the irq8 channel to the RTC instead of waiting until the next
interrupt event.
Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com>
Link: http://lkml.kernel.org/r/20111118153306.GB16319@alberich.amd.com
Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
commit e5fd47bfab2df0c2184cc0bf4245d8e1bb7724fb upstream.
The idea behind commit d91ee5863b71 ("cpuidle: replace xen access to x86
pm_idle and default_idle") was to have one call - disable_cpuidle()
which would make pm_idle not be molested by other code. It disallows
cpuidle_idle_call to be set to pm_idle (which is excellent).
But in the select_idle_routine() and idle_setup(), the pm_idle can still
be set to either: amd_e400_idle, mwait_idle or default_idle. This
depends on some CPU flags (MWAIT) and in AMD case on the type of CPU.
In case of mwait_idle we can hit some instances where the hypervisor
(Amazon EC2 specifically) sets the MWAIT and we get:
Brought up 2 CPUs
invalid opcode: 0000 [#1] SMP
Pid: 0, comm: swapper Not tainted 3.1.0-0.rc6.git0.3.fc16.x86_64 #1
RIP: e030:[<ffffffff81015d1d>] [<ffffffff81015d1d>] mwait_idle+0x6f/0xb4
Call Trace:
[<ffffffff8100e2ed>] cpu_idle+0xae/0xe8
[<ffffffff8149ee78>] cpu_bringup_and_idle+0xe/0x10
RIP [<ffffffff81015d1d>] mwait_idle+0x6f/0xb4
RSP <ffff8801d28ddf10>
In the case of amd_e400_idle we don't get so spectacular crashes, but we
do end up making an MSR which is trapped in the hypervisor, and then
follow it up with a yield hypercall. Meaning we end up going to
hypervisor twice instead of just once.
The previous behavior before v3.0 was that pm_idle was set to
default_idle regardless of select_idle_routine/idle_setup.
We want to do that, but only for one specific case: Xen. This patch
does that.
Fixes RH BZ #739499 and Ubuntu #881076
Reported-by: Stefan Bader <stefan.bader@canonical.com>
commit 9811ccdfa94b4773c8030569bd8ec75eafa485ac upstream.
arm_dma_zone_size is used by arm_bootmem_free() which is called by
paging_init(). Thus it needs to be set before calling it.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
commit b6999b19120931ede364fa3b685e698a61fed31d upstream.
With the 3.2-rc kernel, IOMMU 2M pages in KVM works. But when I tried
to use IOMMU 1GB pages in KVM, I encountered an oops and the 1GB page
failed to be used.
The root cause is that 1GB page allocation calls gup_huge_pud() while 2M
page calls gup_huge_pmd. If compound pages are used and the page is a
tail page, gup_huge_pmd() increases _mapcount to record tail page are
mapped while gup_huge_pud does not do that.
So when the mapped page is relesed, it will result in kernel oops
because the page is not marked mapped.
This patch add tail process for compound page in 1GB huge page which
keeps the same process as 2M page.
Reproduce like:
1. Add grub boot option: hugepagesz=1G hugepages=8
2. mount -t hugetlbfs -o pagesize=1G hugetlbfs /dev/hugepages
3. qemu-kvm -m 2048 -hda os-kvm.img -cpu kvm64 -smp 4 -mem-path /dev/hugepages
-net none -device pci-assign,host=07:00.1
kernel BUG at mm/swap.c:114!
Call Trace:
put_page+0x15/0x37
kvm_release_pfn_clean+0x31/0x36
kvm_iommu_put_pages+0x94/0xb1
kvm_iommu_unmap_memslots+0x80/0xb6
kvm_assign_device+0xba/0x117
kvm_vm_ioctl_assigned_device+0x301/0xa47
kvm_vm_ioctl+0x36c/0x3a2
do_vfs_ioctl+0x49e/0x4e4
sys_ioctl+0x5a/0x7c
system_call_fastpath+0x16/0x1b
RIP put_compound_page+0xd4/0x168
Signed-off-by: Youquan Song <youquan.song@intel.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
commit 83713fc9373be2e943f82e9d36213708c6b0050e upstream.
The function setup_vpif_input_channel_mode() used the VSCLKDIS register
instead of VIDCLKCTL. This meant that when in HD mode videoport channel 0
used a different clock from channel 1.
Clearly a copy-and-paste error.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Manjunath Hadli <manjunath.hadli@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
commit 0e934e22f3fabb98c41737e2e30bd9db2668e935 upstream.
Since 193ab2a6070039e7ee2b9b9bebea754a7c52fd1b, various AT91 boards don't
register at91_udc anymore due to depending on a now non-existing symbol.
Fix the symbol name.
Signed-off-by: Anders Darander <anders@chargestorm.se>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 1808958d27b1250295f01dff4997d8a8814adaab upstream.
The conid is supposed to be t0/t1/t2_clk.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 11357be9246c7d1acf9b37ad54a18b29bbb734be upstream.
Adding the machine_is_* line was forgotten when converting mach-stmp378x to
mach-mxs.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
commit f1b21c525693b0159aed83b5871f2d0f077f208e upstream.
On OMAP-L138 platform, EDMA event queue 0 should be used for audio
transfers so that they are not starved by video data moving on event queue 1.
Commit 48519f0ae03bc7e86b3dc93e56f1334d53803770 (ASoC: davinci: let platform
data define edma queue numbers) had a side-effect of changing this behavior
by making the driver actually honor the platform data passed.
Fix this now by passing event queue 0 as the queue to be used for audio
transfers.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
commit b934069c991355d27a053a932591c77960f4e414 upstream.
The last breaking event address is a read-only value, the regset misses the
.set function. If a PTRACE_SETREGSET is done for NT_S390_LAST_BREAK we
get an oops due to a branch to zero:
Kernel BUG at 0000000000000002 verbose debug info unavailable
illegal operation: 0001 #1 SMP
Call Trace:
(<0000000000158294> ptrace_regset+0x184/0x188)
<00000000001595b6> ptrace_request+0x37a/0x4fc
<0000000000109a78> arch_ptrace+0x108/0x1fc
<00000000001590d6> SyS_ptrace+0xaa/0x12c
<00000000005c7a42> sysc_noemu+0x16/0x1c
<000003fffd5ec10c> 0x3fffd5ec10c
Last Breaking-Event-Address:
<0000000000158242> ptrace_regset+0x132/0x188
Add a nop .set function to prevent the branch to zero.
commit 97f7f8189fe54e3cfe324ef9ad35064f3d2d3bff upstream.
If oprofile uses the nmi timer interrupt there is a crash while
unloading the module. The bug can be triggered with oprofile build as
module and kernel parameter nolapic set. This patch fixes this.
oprofile: using NMI timer interrupt.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
PGD 42dbca067 PUD 41da6a067 PMD 0
Oops: 0002 [#1] PREEMPT SMP
CPU 5
Modules linked in: oprofile(-) [last unloaded: oprofile]
Pid: 2518, comm: modprobe Not tainted 3.1.0-rc7-00019-gb2fb49d #19 Advanced Micro Device Anaheim/Anaheim
RIP: 0010:[<ffffffff8123c226>] [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP: 0018:ffff88041ef71e98 EFLAGS: 00010296
RAX: 0000000000000000 RBX: ffffffffa0017100 RCX: dead000000200200
RDX: 0000000000000000 RSI: dead000000100100 RDI: ffffffff8178c620
RBP: ffff88041ef71ea8 R08: 0000000000000001 R09: 0000000000000082
R10: 0000000000000000 R11: ffff88041ef71de8 R12: 0000000000000080
R13: fffffffffffffff5 R14: 0000000000000001 R15: 0000000000610210
FS: 00007fc902f20700(0000) GS:ffff88042fd40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000008 CR3: 000000041cdb6000 CR4: 00000000000006e0
Process modprobe (pid: 2518, threadinfo ffff88041ef70000, task ffff88041d348040)
Stack:
ffff88041ef71eb8 ffffffffa0017790 ffff88041ef71eb8 ffffffffa0013532
ffff88041ef71ec8 ffffffffa00132d6 ffff88041ef71ed8 ffffffffa00159b2
ffff88041ef71f78 ffffffff81073115 656c69666f72706f 0000000000610200
Call Trace:
[<ffffffffa0013532>] op_nmi_exit+0x15/0x17 [oprofile]
[<ffffffffa00132d6>] oprofile_arch_exit+0xe/0x10 [oprofile]
[<ffffffffa00159b2>] oprofile_exit+0x1e/0x20 [oprofile]
[<ffffffff81073115>] sys_delete_module+0x1c3/0x22f
[<ffffffff811bf09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff8148070b>] system_call_fastpath+0x16/0x1b
Code: 20 c6 78 81 e8 c5 cc 23 00 48 8b 13 48 8b 43 08 48 be 00 01 10 00 00 00 ad de 48 b9 00 02 20 00 00 00 ad de 48 c7 c7 20 c6 78 81
89 42 08 48 89 10 48 89 33 48 89 4b 08 e8 a6 c0 23 00 5a 5b
RIP [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP <ffff88041ef71e98>
---[ end trace 43a541a52956b7b0 ]---
commit 57d1c0c03c6b48b2b96870d831b9ce6b917f53ac upstream.
Masami spotted that we always try to decode the instruction stream as
64bit instructions when running a 64bit kernel, this doesn't work for
ia32-compat proglets.
Use TIF_IA32 to detect if we need to use the 32bit instruction
decoder.
Reported-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
regardless of lazy_mmu mode
commit 2cd1c8d4dc7ecca9e9431e2dabe41ae9c7d89e51 upstream.
Fix an outstanding issue that has been reported since 2.6.37.
Under a heavy loaded machine processing "fork()" calls could
crash with:
BUG: unable to handle kernel paging request at f573fc8c
IP: [<c01abc54>] swap_count_continued+0x104/0x180
*pdpt = 000000002a3b9027 *pde = 0000000001bed067 *pte = 0000000000000000 Oops: 0000 [#1] SMP
Modules linked in:
Pid: 1638, comm: apache2 Not tainted 3.0.4-linode37 #1
EIP: 0061:[<c01abc54>] EFLAGS: 00210246 CPU: 3
EIP is at swap_count_continued+0x104/0x180
.. snip..
Call Trace:
[<c01ac222>] ? __swap_duplicate+0xc2/0x160
[<c01040f7>] ? pte_mfn_to_pfn+0x87/0xe0
[<c01ac2e4>] ? swap_duplicate+0x14/0x40
[<c01a0a6b>] ? copy_pte_range+0x45b/0x500
[<c01a0ca5>] ? copy_page_range+0x195/0x200
[<c01328c6>] ? dup_mmap+0x1c6/0x2c0
[<c0132cf8>] ? dup_mm+0xa8/0x130
[<c013376a>] ? copy_process+0x98a/0xb30
[<c013395f>] ? do_fork+0x4f/0x280
[<c01573b3>] ? getnstimeofday+0x43/0x100
[<c010f770>] ? sys_clone+0x30/0x40
[<c06c048d>] ? ptregs_clone+0x15/0x48
[<c06bfb71>] ? syscall_call+0x7/0xb
The problem is that in copy_page_range() we turn lazy mode on,
and then in swap_entry_free() we call swap_count_continued()
which ends up in:
map = kmap_atomic(page, KM_USER0) + offset;
and then later we touch *map.
Since we are running in batched mode (lazy) we don't actually
set up the PTE mappings and the kmap_atomic is not done
synchronously and ends up trying to dereference a page that has
not been set.
Looking at kmap_atomic_prot_pfn(), it uses
'arch_flush_lazy_mmu_mode' and doing the same in
kmap_atomic_prot() and __kunmap_atomic() makes the problem go
away.
Interestingly, commit b8bcfe997e4615 ("x86/paravirt: remove lazy
mode in interrupts") removed part of this to fix an interrupt
issue - but it went to far and did not consider this scenario.
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
commit 1ef03890969932e9359b9a4c658f7f87771910ac upstream.
Looks like on some Acer Aspire 1s with older bioses, reboot via bios
fails. It works on my machine, (with BIOS version 0.3310) but
not on some others (BIOS version 0.3309).
There's a log of problems at:
https://bbs.archlinux.org/viewtopic.php?id=124136
This patch adds a different callback to the reboot quirk table,
to allow rebooting via keybaord controller.
Reported-by: Uroš Vampl <mobile.leecher@gmail.com>
Tested-by: Vasily Khoruzhick <anarsoul@gmail.com>
Signed-off-by: Peter Chubb <peter.chubb@nicta.com.au>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/r/1323093233-9481-1-git-send-email-anarsoul@gmail.com
commit 9e6866686bdf2dcf3aeb0838076237ede532dcc8 upstream.
In commit f8924e770e04 ("x86: unify mp_bus_info"), the 32-bit
and 64-bit versions of MP_bus_info were rearranged to match each
other better. Unfortunately it introduced a regression: prior
to that change we used to always set the mp_bus_not_pci bit,
then clear it if we found a PCI bus. After it, we set
mp_bus_not_pci for ISA buses, clear it for PCI buses, and leave
it alone otherwise.
In the cases of ISA and PCI, there's not much difference. But
ISA is not the only non-PCI bus, so it's better to always set
mp_bus_not_pci and clear it only for PCI.
Without this change, Dan's Dell PowerEdge 4200 panics on boot
with a log indicating interrupt routing trouble unless the
"noapic" option is supplied. With this change, the machine
boots reliably without "noapic".
Fixes http://bugs.debian.org/586494
Reported-bisected-and-tested-by: Dan McGrath <troubledaemon@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Dan McGrath <troubledaemon@gmail.com>
Cc: Alexey Starikovskiy <aystarik@gmail.com>
[jrnieder@gmail.com: clarified commit message]
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Link: http://lkml.kernel.org/r/20111122215000.GA9151@elie.hsd1.il.comcast.net
commit 4cecf6d401a01d054afc1e5f605bcbfe553cb9b9 upstream.
(Added the missing signed-off-by line)
In hundreds of days, the __cycles_2_ns calculation in sched_clock
has an overflow. cyc * per_cpu(cyc2ns, cpu) exceeds 64 bits, causing
the final value to become zero. We can solve this without losing
any precision.
We can decompose TSC into quotient and remainder of division by the
scale factor, and then use this to convert TSC into nanoseconds.
Signed-off-by: Salman Qazi <sqazi@google.com>
Acked-by: John Stultz <johnstul@us.ibm.com>
Reviewed-by: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20111115221121.7262.88871.stgit@dungbeetle.mtv.corp.google.com
commit 11ed0ba1754841316d4095478944300acf19acc3 upstream.
This patch implements a workaround for PL310 erratum 769419. On
revisions of the PL310 prior to r3p2, the Store Buffer does not
automatically drain. This can cause normal, non-cacheable writes to be
retained when the memory system is idle, leading to suboptimal I/O
performance for drivers using coherent DMA.
This patch adds an optional wmb() call to the cpu_idle loop. On systems
with an outer cache, this causes an explicit flush of the store buffer.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
commit 46232a3622c6e33605906ee6690dfef372925f53 upstream.
Current code registers voltage layer details for TWL PMIC even when a TWL
has not been registered. Fix this to only register the TWL with voltage
layer when the TWL PMIC is initialized by board-level code.
Signed-off-by: Kevin Hilman <khilman@ti.com>
commit a8a6565c7615cab3608d75af95b5c8a3522cd7c4 upstream.
This patch selects ARM_AMBA if OMAP3_EMU is defined because
OC_ETM depends on ARM_AMBA, so fix the link failure[1].
[1],
arch/arm/kernel/built-in.o: In function `etm_remove':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:609: undefined
reference to `amba_release_regions'
arch/arm/kernel/built-in.o: In function `etb_remove':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:409: undefined
arch/arm/kernel/built-in.o: In function `etm_init':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:640: undefined
reference to `amba_driver_register'
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:646: undefined
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:648: undefined
reference to `amba_driver_unregister'
arch/arm/kernel/built-in.o: In function `etm_probe':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:545: undefined
reference to `amba_request_regions'
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:595: undefined
arch/arm/kernel/built-in.o: In function `etb_probe':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:347: undefined
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:392: undefined
arch/arm/mach-omap2/built-in.o: In function `emu_init':
/home/tom/git/omap/linux-2.6-omap/arch/arm/mach-omap2/emu.c:62:
undefined reference to `amba_device_register'
/home/tom/git/omap/linux-2.6-omap/arch/arm/mach-omap2/emu.c:63:
make: *** [.tmp_vmlinux1] Error 1
making modules
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit cc1b0765da6078b906772b79ff211b88cc0ae958 upstream.
The address spaces, irqs and dma reqs count APIs return the
number of corresponding entries in a hwmod including a additional
null value or a -1 terminator in the structure introduced recently.
More information here:
- 212738a4: omap_hwmod: use a terminator record with omap_hwmod_mpu_irqs
arrays
- 78183f3f: omap_hwmod: use a null structure record to terminate
omap_hwmod_addr_space arrays
- bc614958: omap_hwmod: use a terminator record with omap_hwmod_dma_info
arrays
The issue with irqs and dma info was originally reported by Benoit Cousson.
The devices which have multiple hwmods and use device_build_ss are
broken with this, as their resources are populated with a extra null
value, subsequently the probe fails. So fix the API not to include
the array terminator in the count.
Reported-by: Benoit Cousson <b-cousson@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimar@ti.com>
Signed-off-by: sricharan <r.sricharan@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
commit 5a4f1844c2ba21f804d7729306d9b16eaeb724a8 upstream.
Fix a bug which has been on this driver since
it was added by the original commit 984aa6db
which would never clear IRQSTATUS bits.
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit c2735391fbc68feae10d6d14e60956c8106e725f upstream.
reg | (1 << clk->enable_shift) always evaluates to true. Switch it
to & which makes much more sense. Same fix as 13be9f00 (ARM i.MX28: fix
bit operation) at a different location.
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Shawn Guo <shawn.guo@freescale.com>
commit c0a39151a4055332897cba615623d3de2f3896df upstream.
Since CONFIG_USB_GADGET_PXA27X and other macros are renamed to
CONFIG_USB_PXA27X. Update them in arch/arm/mach-pxa and arch/arm/configs
to keep consistent.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
commit 8428e84d42179c2a00f5f6450866e70d802d1d05 upstream.
Recent gcc versions generate unaligned accesses by default on ARMv6 and
later processors. This patch ensures that the SCTLR.A bit is always
cleared on such processors to avoid kernel traping before
alignment_init() is called.
Tested-by: John Linn <John.Linn@xilinx.com>
commit 9e6dabeffd1d0ec2aa19aa076c4886067238d442 upstream.
CPUSTAT_RUNNING was implemented signifying that a vcpu is not stopped.
This is not, however, what the architecture says: RUNNING should be
set when the host is acting on the behalf of the guest operating
system.
CPUSTAT_RUNNING has been changed to be set in kvm_arch_vcpu_load()
and to be unset in kvm_arch_vcpu_put().
For signifying stopped state of a vcpu, a host-controlled bit has
been used and is set/unset basically on the reverse as the old
CPUSTAT_RUNNING bit (including pushing it down into stop handling
proper in handle_stop()).
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit d715e433b7ad19c02fc4becf0d5e9a59f97925de upstream.
kdump fails because we try to execute an HV only instruction. Feature
fixups are being applied after we copy the exception vectors down to 0
so they miss out on any updates.
We have always had this issue but it only became critical in v3.0
when we added CFAR support (breaks POWER5) and v3.1 when we added
POWERNV (breaks everyone).
commit de1d9248eadd27539eba449b4d09428252e80c04 upstream.
If you build with KVM and UP it fails with the following due to a
missing include.
/arch/powerpc/kvm/book3s_hv.c: In function 'do_h_register_vpa':
arch/powerpc/kvm/book3s_hv.c:156:10: error: 'H_PARAMETER' undeclared (first use in this function)
arch/powerpc/kvm/book3s_hv.c:156:10: note: each undeclared identifier is reported only once for each function it appears in
arch/powerpc/kvm/book3s_hv.c:192:12: error: 'H_RESOURCE' undeclared (first use in this function)
arch/powerpc/kvm/book3s_hv.c:222:9: error: 'H_SUCCESS' undeclared (first use in this function)
arch/powerpc/kvm/book3s_hv.c: In function 'kvmppc_pseries_do_hcall':
arch/powerpc/kvm/book3s_hv.c:228:30: error: 'H_SUCCESS' undeclared (first use in this function)
arch/powerpc/kvm/book3s_hv.c:232:7: error: 'H_CEDE' undeclared (first use in this function)
arch/powerpc/kvm/book3s_hv.c:234:7: error: 'H_PROD' undeclared (first use in this function)
arch/powerpc/kvm/book3s_hv.c:238:10: error: 'H_PARAMETER' undeclared (first use in this function)
arch/powerpc/kvm/book3s_hv.c:250:7: error: 'H_CONFER' undeclared (first use in this function)
arch/powerpc/kvm/book3s_hv.c:252:7: error: 'H_REGISTER_VPA' undeclared (first use in this function)
make[2]: *** [arch/powerpc/kvm/book3s_hv.o] Error 1
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit 72f3bea075287785ed32b777b6dd2636aa7002e8 upstream.
Fixes the PS3 bootup hang introduced in 3.0-rc1 by:
commit 317f394160e9beb97d19a84c39b7e5eb3d7815a
sched: Move the second half of ttwu() to the remote cpu
Move the PS3's LV1 EOI call lv1_end_of_interrupt_ext() from ps3_chip_eoi()
to ps3_get_irq() for IPI messages.
If lv1_send_event_locally() is called between a previous call to
lv1_send_event_locally() and the coresponding call to
lv1_end_of_interrupt_ext() the second event will not be delivered to the
target cpu.
The PS3's SMP IPIs are implemented using lv1_send_event_locally(), so if two
IPI messages of the same type are sent to the same target in a relatively
short period of time the second IPI event can become lost when
lv1_end_of_interrupt_ext() is called from ps3_chip_eoi().
Signed-off-by: Geoff Levand <geoff@infradead.org>
commit 90d4f5534d14815bd94c10e8ceccc57287657ecc upstream.
PVHVM running with more than 32 vcpus and pv_irq/pv_time enabled
need VCPU placement to work, or else it will softlockup.
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com>
commit dfd3b596fbbfa48b8e7966ef996d587157554b69 upstream.
In the case of 29bit mode, CAC/UNCAC_ADDR does not return a right address.
This revises this problem by using P1SEGADDR and P2SEGADDR in 29bit mode.
Reported-by: Yutaro Ebihara <ebiharaml@si-linux.co.jp>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Tested-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit dd0b3825495a2e7a8cd6cf0ec077618c008ac7c4 upstream.
register USBA adapters anymore due to depending on a now non-existing
symbol. Fix the symbol name.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
commit 8bdafa39a47265bc029838b35cc6585f69224afa upstream.
The icswx code introduced an A-B B-A deadlock:
CPU0 CPU1
lock(&anon_vma->mutex);
lock(&mm->mmap_sem);
Instead of using the mmap_sem to keep mm_users constant, take the
page table spinlock.
commit 8feaa43494cee5e938fd5a57b9e9bf1c827e6ccd upstream.
Since commit 188917e183cf9ad0374b571006d0fc6d48a7f447, /proc/ppc64 is a
symlink to /proc/powerpc/. That means that creating /proc/ppc64/eeh will
end up with a unaccessible file, that is not listed under /proc/powerpc/
and, then, not listed under /proc/ppc64/.
Creating /proc/powerpc/eeh fixes that problem and maintain the
compatibility intended with the ppc64 symlink.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
commit 9c740025c51a26ab00192cfc464064d4ccbfe3fc upstream.
During hotplug CPU add we get the following error:
Unexpected Error (0) returned from configure-connector
ibm,configure-connector returns 0 for configuration complete, so
catch this and avoid the error.
commit a11940978bd598e65996b4f807cf4904793f7025 upstream.
If we echo an address the hypervisor doesn't like to
/sys/devices/system/memory/probe we oops the box:
# echo 0x10000000000 > /sys/devices/system/memory/probe
kernel BUG at arch/powerpc/mm/hash_utils_64.c:541!
The backtrace is:
create_section_mapping
arch_add_memory
add_memory
memory_probe_store
sysdev_class_store
sysfs_write_file
vfs_write
SyS_write
In create_section_mapping we BUG if htab_bolt_mapping returned
an error. A better approach is to return an error which will
propagate back to userspace.
Rerunning the test with this patch applied:
-bash: echo: write error: Invalid argument
commit 6083184269fd723affca4f6340e491950267622a upstream.
During memory hotplug testing, I got the following warning:
ERROR: Bad of_node_put() on /memory@0
of_node_release
kref_put
of_node_put
of_find_node_by_type
hot_add_node_scn_to_nid
hot_add_scn_to_nid
memory_add_physaddr_to_nid
of_find_node_by_type() loop does the of_node_put for us so we only
need the handle the case where we terminate the loop early.
As suggested by Stephen Rothwell we can do the of_node_put
unconditionally outside of the loop since of_node_put handles a
NULL argument fine.
commit b35a35b556f5e6b7993ad0baf20173e75c09ce8c upstream.
This avoids duplicating the function in every arch gup_fast.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
commit e0d85a366c2300efd230ef82a9b22110b0658331 upstream.
Up to this point the code assumed old refcounting for hugepages (pre-thp).
This updates the code directly to the thp mapcount tail page refcounting.
Acked-by: David Miller <davem@davemloft.net>
commit 0693bc9ce2cc4f6a1b9c3c05790fc149a74c0b87 upstream.
s390 didn't return 0 in that case, if it's rolling back the *nr pointer it
should also return zero to avoid adding pages to the array at the wrong
offset.
commit 220a2eb228d032acde60e9fd044ca802706ff583 upstream.
commit cf592bf768c4fa40282b8fce58a80820065de2cb upstream.
powerpc didn't return 0 in that case, if it's rolling back the *nr pointer
it should also return zero to avoid adding pages to the array at the wrong
offset.
Acked-by: David Gibson <david@gibson.dropbear.id.au>
commit 3526741f0964c88bc2ce511e1078359052bf225b upstream.
commit 8596468487e2062cae2aad56e973784e03959245 upstream.
We only taken "refs" pins on the head page not "*nr" pins.
commit 405e44f2e312dd5dd63e5a9f459bffcbcd4368ef upstream.
"page" may have changed to point to the next hugepage after the loop
completed, The references have been taken on the head page, so the
put_page must happen there too.
This is a longstanding issue pre-thp inclusion.
It's totally unclear how these page_cache_add_speculative and
pte_val(pte) != pte_val(*ptep) checks are necessary across all the
powerpc gup_fast code, when x86 doesn't need any of that: there's no way
the page can be freed with irq disabled so we're guaranteed the
atomic_inc will happen on a page with page_count > 0 (so not needing the
speculative check).
The pte check is also meaningless on x86: no need to rollback on x86 if
the pte changed, because the pte can still change a CPU tick after the
check succeeded and it won't be rolled back in that case. The important
thing is we got a reference on a valid page that was mapped there a CPU
tick ago. So not knowing the soft tlb refill code of ppc64 in great
detail I'm not removing the "speculative" page_count increase and the
pte checks across all the code, but unless there's a strong reason for
it they should be later cleaned up too.
If a pte can change from huge to non-huge (like it could happen with
THP) passing a pte_t *ptep to gup_hugepte() would also require to repeat
the is_hugepd in gup_hugepte(), but that shouldn't happen with hugetlbfs
only so I'm not altering that.
commit 2839bdc1bfc0af76a2f0f11eca011590520a04fa upstream.
This part of gup_fast doesn't seem capable of handling hugetlbfs ptes,
those should be handled by gup_hugepd only, so these checks are
superfluous.
Plus if this wasn't a noop, it would have oopsed because, the insistence
of using the speculative refcounting would trigger a VM_BUG_ON if a tail
page was encountered in the page_cache_get_speculative().
commit 70b50f94f1644e2aa7cb374819cfd93f3c28d725 upstream.
Michel while working on the working set estimation code, noticed that
calling get_page_unless_zero() on a random pfn_to_page(random_pfn)
wasn't safe, if the pfn ended up being a tail page of a transparent
hugepage under splitting by __split_huge_page_refcount().
He then found the problem could also theoretically materialize with
page_cache_get_speculative() during the speculative radix tree lookups
that uses get_page_unless_zero() in SMP if the radix tree page is freed
and reallocated and get_user_pages is called on it before
page_cache_get_speculative has a chance to call get_page_unless_zero().
So the best way to fix the problem is to keep page_tail->_count zero at
all times. This will guarantee that get_page_unless_zero() can never
succeed on any tail page. page_tail->_mapcount is guaranteed zero and
is unused for all tail pages of a compound page, so we can simply
account the tail page references there and transfer them to
tail_page->_count in __split_huge_page_refcount() (in addition to the
head_page->_mapcount).
While debugging this s/_count/_mapcount/ change I also noticed get_page is
called by direct-io.c on pages returned by get_user_pages. That wasn't
entirely safe because the two atomic_inc in get_page weren't atomic. As
opposed to other get_user_page users like secondary-MMU page fault to
establish the shadow pagetables would never call any superflous get_page
after get_user_page returns. It's safer to make get_page universally safe
for tail pages and to use get_page_foll() within follow_page (inside
get_user_pages()). get_page_foll() is safe to do the refcounting for tail
pages without taking any locks because it is run within PT lock protected
critical sections (PT lock for pte and page_table_lock for
pmd_trans_huge).
The standard get_page() as invoked by direct-io instead will now take
the compound_lock but still only for tail pages. The direct-io paths
are usually I/O bound and the compound_lock is per THP so very
finegrined, so there's no risk of scalability issues with it. A simple
direct-io benchmarks with all lockdep prove locking and spinlock
debugging infrastructure enabled shows identical performance and no
overhead. So it's worth it. Ideally direct-io should stop calling
get_page() on pages returned by get_user_pages(). The spinlock in
get_page() is already optimized away for no-THP builds but doing
get_page() on tail pages returned by GUP is generally a rare operation
and usually only run in I/O paths.
This new refcounting on page_tail->_mapcount in addition to avoiding new
RCU critical sections will also allow the working set estimation code to
work without any further complexity associated to the tail page
refcounting with THP.
Reported-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
