path: root/arch
2009-04-07spi: pxa2xx_spi: introduce chipselect GPIO to simplify the common casesEric Miao
Most SPI peripherals use GPIOs as their chip selects, introduce .gpio_cs for this. Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Make mmc_spi driver work on BlackfinWolfgang Muees
1. Rewrite of the non-dma data transfer functions to use only ONE mode of TIMOD (TIMOD=0x1). With TIMOD=0, it was not possible to set the TX bit pattern. So the TDBR = 0xFFFF inside the read calls won't work. 2. Clear SPI_RDBR before reading and before duplex transfer. Otherwise the garbage data in RDBR will get read. Since mmc_spi uses a lot of duplex transfers, this is the main cause of mmc_spi failure. 3. Poll RXS for transfer completion. Polling SPIF or TXS cannot guarantee transfer completion. This may interrupt a transfer before it is finished. Also this may leave garbage data in buffer and affect next transfer. [Yi Li <yi.li@analog.com>: add a field "u16 idle_tx_val" in "struct bfin5xx_spi_chip" to specify the value to transmit if no TX value is supplied.] Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Add GPIO controlled SPI Slave Select supportMichael Hennerich
Add support for GPIO controlled SPI Chip Selects. To make use of this feature, set chip_select = 0 and add a proper cs_gpio to your controller_data. struct spi_board_info .chip_select = 0 struct bfin5xx_spi_chip .cs_gpio = GPIO_P### There are various SPI devices that require SPI MODE_0, and need to have the Chip Selects asserted during the entire transfer. Consider using SPI_MODE_3 (SPI_CPHA | SPI_CPOL) if your device allows it. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Fix erroneous SPI Clock divisor calculationMichael Hennerich
Fix erroneous SPI Clock divisor calculation. Make sure SPI_BAUD is always >= 2. Writing a value of 0 or 1 to the SPI_BAUD register disables the serial clock. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (28 commits) powerpc: Fix oops when loading modules powerpc: Wire up preadv and pwritev powerpc/ftrace: Fix printf format warning powerpc/ftrace: Fix #if that should be #ifdef powerpc: Fix ptrace compat wrapper for FPU register access powerpc: Print information about mapping hw irqs to virtual irqs powerpc: Correct dependency of KEXEC powerpc: Disable VSX or current process in giveup_fpu/altivec powerpc/pseries: Enable relay in pseries_defconfig powerpc/pseries: Fix ibm,client-architecture comment powerpc/pseries: Scan for all events in rtasd powerpc/pseries: Add dispatch dispersion statistics powerpc: Clean up some prom printouts powerpc: Print progress of ibm,client-architecture method powerpc: Remove duplicated #include's powerpc/pmac: Fix internal modem IRQ on Wallstreet PowerBook powerpc/wdrtas: Update wdrtas_get_interval to use rtas_data_buf fsl-diu-fb: Pass the proper device for dma mapping routines powerpc/pq2fads: Update device tree for use with device-tree-aware u-boot. cpm_uart: Disable CPM udbg when re-initing CPM uart, even if not the console. ...
2009-04-07powerpc: Fix oops when loading modulesPaul Mackerras
This fixes a problem reported by Sean MacLennan where loading any module would cause an oops. We weren't marking the pages containing the module text as having hardware execute permission, due to a bug introduced in commit 8d1cf34e ("powerpc/mm: Tweak PTE bit combination definitions"), hence trying to execute the module text caused an exception on processors that support hardware execute permission. This adds _PAGE_HWEXEC to the definitions of PAGE_KERNEL_X and PAGE_KERNEL_ROX to fix this problem. Reported-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Wire up preadv and pwritevStephen Rothwell
[paulus@samba.org: changed to use syscall numbers 320 and 321 since perf_counters is currently using 319.] Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc/ftrace: Fix printf format warningMichael Ellerman
'tramp' is an unsigned long, so print it with %lx. Fixes the following build warning: arch/powerpc/kernel/ftrace.c:291: error: format ‘%x’ expects type ‘unsigned int’, but argument 2 has type ‘long unsigned int’ Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc/ftrace: Fix #if that should be #ifdefMichael Ellerman
Commit bb7253403f7a4670a128e4c080fd8ea1bd4d5029 ("powerpc64, ftrace: save toc only on modules for function graph"), added an #if CONFIG_PPC64. This changes it to #ifdef. Fixes the following warning on 32-bit builds: arch/powerpc/kernel/ftrace.c:562:5: error: "CONFIG_PPC64" is not defined Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Fix ptrace compat wrapper for FPU register accessMichael Neuling
The ptrace compat wrapper mishandles access to the fpu registers. The PTRACE_PEEKUSR and PTRACE_POKEUSR requests miscalculate the index into the fpr array due to the broken FPINDEX macro. The PPC_PTRACE_PEEKUSR_3264 request needs to use the same formula that the native ptrace interface uses when operating on the register number (as opposed to the 4-byte offset). The PPC_PTRACE_POKEUSR_3264 request didn't take TS_FPRWIDTH into account. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Print information about mapping hw irqs to virtual irqsMichael Ellerman
The irq remapping layer seems to cause some confusion when people see a different irq number in /proc/interrupts vs the one they request in their driver or DTS. So have the irq remapping layer print out a message when we map an irq. The message is only printed the first time the irq is mapped, and it's KERN_DEBUG so most people won't see it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Correct dependency of KEXECGeert Uytterhoeven
commit 28794d34ecb6815a3fa0a4256027c9b081a17c5f ("powerpc/kconfig: Kill PPC_MULTIPLATFORM") broke KEXEC, by making it dependent on BOOK3S, while it should be PPC_BOOK3S. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Disable VSX or current process in giveup_fpu/altivecMichael Neuling
When we call giveup_fpu, we need to need to turn off VSX for the current process. If we don't, on return to userspace it may execute a VSX instruction before the next FP instruction, and not have its register state refreshed correctly from the thread_struct. Ditto for altivec. This caused a bug where an unaligned lfs or stfs results in fix_alignment calling giveup_fpu so it can use the FPRs (in order to do a single <-> double conversion), and then returning to userspace with FP off but VSX on. Then if a VSX instruction is executed, before another FP instruction, it will proceed without another exception and hence have the incorrect register state for VSX registers 0-31. lfs unaligned <- alignment exception turns FP off but leaves VSX on VSX instruction <- no exception since VSX on, hence we get the wrong VSX register values for VSX registers 0-31, which overlap the FPRs. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc/pseries: Enable relay in pseries_defconfigAnton Blanchard
Enable relay in pseries config, ppc64_defconfig had it enabled but pseries did not. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc/pseries: Fix ibm,client-architecture commentAnton Blanchard
We specify a 64MB RMO, but the comment says 128MB. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc/pseries: Scan for all events in rtasdAnton Blanchard
Instead of checking for known events, pass in all 1s so we handle future event types. We were currently missing the IO event type. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc/pseries: Add dispatch dispersion statisticsAnton Blanchard
PHYP tells us how often a shared processor dispatch changed physical cpus. This can highlight performance problems caused by the hypervisor. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Clean up some prom printoutsAnton Blanchard
Make all messages consistent, some have spaces before the "...", some do not. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Print progress of ibm,client-architecture methodAnton Blanchard
The ibm,client-architecture method will often cause a reconfiguration reboot. When this happens the last thing we see is: Hypertas detected, assuming LPAR ! Which doesn't explain what just happened. Wrap the ibm,client-architecture so it's clear what is going on: Calling ibm,client-architecture... done In order to maintain the law of conservation of screen real estate, downgrade two other messages to debug. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Remove duplicated #include'sHuang Weiyi
Remove duplicated #include's in - arch/powerpc/include/asm/ps3fb.h - arch/powerpc/kernel/setup-common.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07Merge branch 'next' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into merge
2009-04-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (120 commits) cx231xx: Convert to snd_card_create() V4L/DVB (11440): PWC: fix build error when CONFIG_INPUT=m V4L/DVB (11439): UVC: uvc_status_cleanup(): undefined reference to `input_unregister_device' V4L/DVB (11438): au0828: fix Kconfig dependance V4L/DVB (11437): pvrusb2: Drop client_register/unregister stubs V4L/DVB (11436): radio-mr800: convert to to v4l2_device V4L/DVB (11435): dsbr100 radio: convert to to v4l2_device V4L/DVB: zr364xx: remove unused #include <version.h> V4L/DVB: usbvision: remove unused #include <version.h> V4L/DVB (11427): gspca - m5602: Minor cleanups V4L/DVB (11426): gspca - m5602: Don't touch hflip/vflip register on Read/Modify/Write V4L/DVB (11425): gspca - m5602: Move the vflip quirk to probe stage. V4L/DVB (11424): gspca - m5602-ov9650: Use the local ctrl cache. Adjust image on vflip. V4L/DVB (11423): gspca - m5602-ov9650: Add a disconnect hook, setup a ctrl cache ctrl. V4L/DVB (11422): gspca - m5602-ov9650: Replace a magic constant with a define V4L/DVB (11421): gspca - m5602-ov9650: Synthesize modesetting. V4L/DVB (11420): gspca - m5602: Improve error handling in the ov9650 driver V4L/DVB (11419): gspca - m5602-ov9650: Don't read exposure data from COM1. V4L/DVB (11418): gspca - m5602-ov9650: Auto white balancing is on by default V4L/DVB (11417): gspca - m5602-ov9650: Autogain is on by default ...
2009-04-06V4L/DVB (11350): Add camera (CSI) driver for MX1Paulius Zaleckas
Add support for CMOS Sensor Interface on i.MX1 and i.MXL SoCs. create mode 100644 arch/arm/mach-mx1/ksym_mx1.c create mode 100644 arch/arm/mach-mx1/mx1_camera_fiq.S create mode 100644 arch/arm/plat-mxc/include/mach/mx1_camera.h create mode 100644 drivers/media/video/mx1_camera.c Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: Darius Augulis <augulis.darius@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11349): mx3-camera: adapt the clock definition and the driver to ↵Guennadi Liakhovetski
the new clock naming With the i.MX31 transition to clkdev clock names have changed, but mistakenly the "mx3-camera.0" has been registered with a non-NULL connection ID, which is not necessary, since this is the only clock, used by the capture interface driver. Fix the clock definition and the driver to use NULL as a connection ID. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (53 commits) [MTD] struct device - replace bus_id with dev_name(), dev_set_name() [MTD] [NOR] Fixup for Numonyx M29W128 chips [MTD] mtdpart: Make ecc_stats more realistic. powerpc/85xx: TQM8548: Update DTS file for multi-chip support powerpc: NAND: FSL UPM: document new bindings [MTD] [NAND] FSL-UPM: Add wait flags to support board/chip specific delays [MTD] [NAND] FSL-UPM: add multi chip support [MTD] [NOR] Add device parent info to physmap_of [MTD] [NAND] Add support for NAND on the Socrates board [MTD] [NAND] Add support for 4KiB pages. [MTD] sysfs support should not depend on CONFIG_PROC_FS [MTD] [NAND] Add parent info for CAFÉ controller [MTD] support driver model updates [MTD] driver model updates (part 2) [MTD] driver model updates [MTD] [NAND] move gen_nand's probe function to .devinit.text [MTD] [MAPS] move sa1100 flash's probe function to .devinit.text [MTD] fix use after free in register_mtd_blktrans [MTD] [MAPS] Drop now unused sharpsl-flash map [MTD] ofpart: Check name property to determine partition nodes. ... Manually fix trivial conflict in drivers/mtd/maps/Makefile
2009-04-06FRV: Fix compile breakageAdrian Bunk
This patch fixes the follwing build error caused by commit 7ca43e7564679604d86e9ed834e7bbcffd8a4a3f (mm: use debug_kmap_atomic): ... AS arch/frv/mm/tlb-miss.o In file included from arch/frv/mm/tlb-miss.S:13: ... Assembler messages: include/asm-generic/ioctl.h:73: Error: unrecognized instruction `extern unsigned int __invalid_size_argument_for_IO...' ... Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: drivers/pci/intr_remapping.c: include acpi.h intel-iommu: Fix oops in device_to_iommu() when devices not found. intel-iommu: Handle PCI domains appropriately. intel-iommu: Fix device-to-iommu mapping for PCI-PCI bridges. x2apic/intr-remap: decouple interrupt remapping from x2apic x86, dmar: check if it's initialized before disable queue invalidation intel-iommu: set compatibility format interrupt Intel IOMMU Suspend/Resume Support - Interrupt Remapping Intel IOMMU Suspend/Resume Support - Queued Invalidation Intel IOMMU Suspend/Resume Support - DMAR intel-iommu: Add for_each_iommu() and for_each_active_iommu() macros
2009-04-06powerpc/85xx: TQM8548: Update DTS file for multi-chip supportWolfgang Grandegger
This patch adds multi-chip support for the Micron MT29F8G08FAB NAND flash memory on the TQM8548 modules. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06[MTD] [NAND] FSL-UPM: add multi chip supportWolfgang Grandegger
This patch adds support for multi-chip NAND devices to the FSL-UPM driver. This requires support for multiple GPIOs for the RNB pins. The NAND chips are selected through address lines defined by the FDT property "fsl,upm-addr-line-cs-offsets". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06powerpc/pq2fads: Update device tree for use with device-tree-aware u-boot.Scott Wood
Add aliases, and correct CS0 offset to match how u-boot programs it (this was not a problem with cuImage because the wrapper would reprogram the localbus to match the device tree). Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-06powerpc: Add support for CoreInt delivery of interrupts on MPICKumar Gala
CoreInt provides a mechansim to deliver the IRQ vector directly into the core on an interrupt (via the SPR EPR) rather than having to go IACK on the PIC. This is suppose to provide an improvment in interrupt latency by reducing the time to get the IRQ vector. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-05Merge branch 'for-next' of git://git.o-hand.com/linux-mfdLinus Torvalds
* 'for-next' of git://git.o-hand.com/linux-mfd: mfd: fix da903x warning mfd: fix MAINTAINERS entry mfd: Use the value of the final spin when reading the AUXADC mfd: Storage class should be before const qualifier mfd: PASIC3: supply clock_rate to DS1WM via driver_data mfd: remove DS1WM clock handling mfd: remove unused PASIC3 bus_shift field pxa/magician: remove deprecated .bus_shift from PASIC3 platform_data mfd: convert PASIC3 to use MFD core mfd: convert DS1WM to use MFD core mfd: Support active high IRQs on WM835x mfd: Use bulk read to fill WM8350 register cache mfd: remove duplicated #include from pcf50633
2009-04-05Merge branch 'for-linus' of git://repo.or.cz/cris-mirrorLinus Torvalds
* 'for-linus' of git://repo.or.cz/cris-mirror: CRISv32: Remove extraneous space between -I and the path. cris: convert obsolete hw_interrupt_type to struct irq_chip BUG to BUG_ON changes cpumask: use mm_cpumask() wrapper: cris cpumask: Use accessors code.: cris cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.: cris
2009-04-05Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (140 commits) ACPI: processor: use .notify method instead of installing handler directly ACPI: button: use .notify method instead of installing handler directly ACPI: support acpi_device_ops .notify methods toshiba-acpi: remove MAINTAINERS entry ACPI: battery: asynchronous init acer-wmi: Update copyright notice & documentation acer-wmi: Cleanup the failure cleanup handling acer-wmi: Blacklist Acer Aspire One video: build fix thinkpad-acpi: rework brightness support thinkpad-acpi: enhanced debugging messages for the fan subdriver thinkpad-acpi: enhanced debugging messages for the hotkey subdriver thinkpad-acpi: enhanced debugging messages for rfkill subdrivers thinkpad-acpi: restrict access to some firmware LEDs thinkpad-acpi: remove HKEY disable functionality thinkpad-acpi: add new debug helpers and warn of deprecated atts thinkpad-acpi: add missing log levels thinkpad-acpi: cleanup debug helpers thinkpad-acpi: documentation cleanup thinkpad-acpi: drop ibm-acpi alias ...
2009-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (23 commits) sh: sh7785lcr: Map whole PCI address space. sh: Fix up DSP context save/restore. sh: Fix up number of on-chip DMA channels on SH7091. sh: update defconfigs. sh: Kill off broken direct-mapped cache mode. sh: Wire up ARCH_HAS_DEFAULT_IDLE for cpuidle. sh: Add a command line option for disabling I/O trapping. sh: Select ARCH_HIBERNATION_POSSIBLE. sh: migor: Fix up CEU use flags. input: migor_ts: add wakeup support rtc: rtc-sh: use set_irq_wake() input: sh_keysc: use enable/disable_irq_wake() sh: intc: set_irq_wake() support sh: intc: install enable, disable and shutdown callbacks clocksource: sh_cmt: use remove_irq() and remove clockevent workaround sh: ap325 and Migo-R use new sh_mobile_ceu_info flags sh: Fix up -Wformat-security whining. sh: ap325rxa: Add ov772x support, again. sh: Sanitize asm/mmu.h for assembly use. sh: Tidy up sh7786 pinmux table. ...
2009-04-05Merge branch 'avr32-arch' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6 * 'avr32-arch' of git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: avr32: add hardware handshake support to atmel_serial avr32: add RTS/CTS/CLK pin selection for the USARTs Add RTC support for Merisc boards avr32: at32ap700x: setup DMA for AC97C in the machine code avr32: at32ap700x: setup DMA for ABDAC in the machine code Add Merisc board support avr32: use gpio_is_valid() to check USBA vbus_pin I/O line atmel-usba-udc: use gpio_is_valid() to check vbus_pin I/O line avr32: fix timing LCD parameters for EVKLCD10X boards avr32: use GPIO line PB15 on EVKLCD10x boards for backlight avr32: configure MCI detect and write protect pins for EVKLCD10x boards avr32: set pin mask to alternative 18 bpp for EVKLCD10x boards avr32: add pin mask for 18-bit color on the LCD controller avr32: fix 15-bit LCDC pin mask to use MSB lines
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: (36 commits) cpumask: remove cpumask allocation from idle_balance, fix numa, cpumask: move numa_node_id default implementation to topology.h, fix cpumask: remove cpumask allocation from idle_balance x86: cpumask: x86 mmio-mod.c use cpumask_var_t for downed_cpus x86: cpumask: update 32-bit APM not to mug current->cpus_allowed x86: microcode: cleanup x86: cpumask: use work_on_cpu in arch/x86/kernel/microcode_core.c cpumask: fix CONFIG_CPUMASK_OFFSTACK=y cpu hotunplug crash numa, cpumask: move numa_node_id default implementation to topology.h cpumask: convert node_to_cpumask_map[] to cpumask_var_t cpumask: remove x86 cpumask_t uses. cpumask: use cpumask_var_t in uv_flush_tlb_others. cpumask: remove cpumask_t assignment from vector_allocation_domain() cpumask: make Xen use the new operators. cpumask: clean up summit's send_IPI functions cpumask: use new cpumask functions throughout x86 x86: unify cpu_callin_mask/cpu_callout_mask/cpu_initialized_mask/cpu_sibling_setup_mask cpumask: convert struct cpuinfo_x86's llc_shared_map to cpumask_var_t cpumask: convert node_to_cpumask_map[] to cpumask_var_t x86: unify 32 and 64-bit node_to_cpumask_map ...
2009-04-05Merge ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param * git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param: module: use strstarts() strstarts: helper function for !strncmp(str, prefix, strlen(prefix)) arm: allow usage of string functions in linux/string.h module: don't use stop_machine on module load module: create a request_module_nowait() module: include other structures in module version check module: remove the SHF_ALLOC flag on the __versions section. module: clarify the force-loading taint message. module: Export symbols needed for Ksplice Ksplice: Add functions for walking kallsyms symbols module: remove module_text_address() module: __module_address module: Make find_symbol return a struct kernel_symbol kernel/module.c: fix an unused goto label param: fix charp parameters set via sysfs Fix trivial conflicts in kernel/extable.c manually.
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'misc' into releaseLen Brown
2009-04-05Merge branch 'x2apic' into releaseLen Brown
2009-04-05pxa/magician: remove deprecated .bus_shift from PASIC3 platform_dataPhilipp Zabel
The PASIC3 driver now calculates its register spacing from the resource size. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-04-04sh: sh7785lcr: Map whole PCI address space.Takashi Yoshii
PCI still doesn't work on sh7785lcr 29bit 256M map mode. On SH7785, PCI -> SHwy address translation is not base+offset but somewhat like base|offset (See HW Manual (rej09b0261) Fig. 13.11). So, you can't export CS2,3,4,5 by 256M at CS2 (results CS0,1,2,3 exported, I guess). There are two candidates. a) 128M@CS2 + 128M@CS4 b) 512M@CS0 Attached patch is B. It maps 512M Byte at 0 independently of memory size. It results CS0 to CS6 and perhaps some more being accessible from PCI. Tested on 7785lcr 29bit 128M map 7785lcr 29bit 256M map (NOT tested on 32bit) Signed-off-by: Takashi YOSHII <yoshii.takashi@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-04sh: Fix up DSP context save/restore.Michael Trimarchi
There were a number of issues with the DSP context save/restore code, mostly left-over relics from when it was introduced on SH3-DSP with little follow-up testing, resulting in things like task_pt_dspregs() referencing incorrect state on the stack. This follows the MIPS convention of tracking the DSP state in the thread_struct and handling the state save/restore in switch_to() and finish_arch_switch() respectively. The regset interface is also updated, which allows us to finally be rid of task_pt_dspregs() and the special cased task_pt_regs(). Signed-off-by: Michael Trimarchi <michael@evidence.eu.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-04sh: Fix up number of on-chip DMA channels on SH7091.Paul Mundt
This accidentally regressed when the multi-IRQ changes went in, switching SH7091 from 4 to 6 channels. Add SH7091 back in to the 4-channel dependency list. Reported-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-04x2apic/intr-remap: decouple interrupt remapping from x2apicHan, Weidong
interrupt remapping must be enabled before enabling x2apic, but interrupt remapping doesn't depend on x2apic, it can be used separately. Enable interrupt remapping in init_dmars even x2apic is not supported. [dwmw2: Update Kconfig accordingly, fix build with INTR_REMAP && !X2APIC] Signed-off-by: Weidong Han <weidong.han@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-03Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, mtrr: remove debug message x86: disable stack-protector for __restore_processor_state() x86: fix is_io_mapping_possible() build warning on i386 allnoconfig x86, setup: compile with -DDISABLE_BRANCH_PROFILING x86/dma: unify definition of pci_unmap_addr* and pci_unmap_len macros x86, mm: fix misuse of debug_kmap_atomic x86: remove duplicated code with pcpu_need_numa() x86,percpu: fix inverted NUMA test in setup_pcpu_remap() x86: signal: check sas_ss_size instead of sas_ss_flags()
2009-04-03Merge branch 'ipi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: s390: remove arch specific smp_send_stop() panic: clean up kernel/panic.c panic, smp: provide smp_send_stop() wrapper on UP too panic: decrease oops_in_progress only after having done the panic generic-ipi: eliminate WARN_ON()s during oops/panic generic-ipi: cleanups generic-ipi: remove CSD_FLAG_WAIT generic-ipi: remove kmalloc() generic IPI: simplify barriers and locking
2009-04-03x86, ACPI: add support for x2apic ACPI extensionsSuresh Siddha
All logical processors with APIC ID values of 255 and greater will have their APIC reported through Processor X2APIC structure (type-9 entry type) and all logical processors with APIC ID less than 255 will have their APIC reported through legacy Processor Local APIC (type-0 entry type) only. This is the same case even for NMI structure reporting. The Processor X2APIC Affinity structure provides the association between the X2APIC ID of a logical processor and the proximity domain to which the logical processor belongs. For OSPM, Procssor IDs outside the 0-254 range are to be declared as Device() objects in the ACPI namespace. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
