path: root/arch
2010-07-07net: fix 64 bit counters on 32 bit archesEric Dumazet
There is a small possibility that a reader gets incorrect values on 32 bit arches. SNMP applications could catch incorrect counters when a 32bit high part is changed by another stats consumer/provider. One way to solve this is to add a rtnl_link_stats64 param to all ndo_get_stats64() methods, and also add such a parameter to dev_get_stats(). Rule is that we are not allowed to use dev->stats64 as a temporary storage for 64bit stats, but a caller provided area (usually on stack) Old drivers (only providing get_stats() method) need no changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-01x86: Drop CONFIG_MCORE2 check around setting of NET_IP_ALIGNAlexander Duyck
This patch removes the CONFIG_MCORE2 check from around NET_IP_ALIGN. It is based on a suggestion from Andi Kleen. The assumption is that there are not any x86 cores where unaligned access is really slow, and this change would allow for a performance improvement to still exist on configurations that are not necessarily optimized for Core 2. Cc: Andi Kleen <ak@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30x86: Align skb w/ start of cacheline on newer core 2/Xeon ArchAlexander Duyck
x86 architectures can handle unaligned accesses in hardware, and it has been shown that unaligned DMA accesses can be expensive on Nehalem architectures. As such we should overwrite NET_IP_ALIGN to resolve this issue. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15net: NET_SKB_PAD should depend on L1_CACHE_BYTESEric Dumazet
In old kernels, NET_SKB_PAD was defined to 16. Then commit d6301d3dd1c2 (net: Increase default NET_SKB_PAD to 32), and commit 18e8c134f4e9 (net: Increase NET_SKB_PAD to 64 bytes) increased it to 64. While first patch was governed by network stack needs, second was more driven by performance issues on current hardware. Real intent was to align data on a cache line boundary. So use max(32, L1_CACHE_BYTES) instead of 64, to be more generic. Remove microblaze and powerpc own NET_SKB_PAD definitions. Thanks to Alexander Duyck and David Miller for their comments. Suggested-by: David Miller <davem@davemloft.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-30ia64: revert __node_random additionLinus Torvalds
This partially reverts commit 4ec37de89d8c758ee8115e0e64b3f994910789ee ("[IA64] Fix build breakage"), since the commit that made it necessary got reverted earlier (see commit 35926ff5fba8, 'Revert "cpusets: randomize node rotor used in cpuset_mem_spread_node()"') Even if we ever re-introduce this, there is no reason to make __node_random be some architecture-specific function. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-30Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (47 commits) mfd: Rename twl5031 sih modules mfd: Storage class for timberdale should be before const qualifier mfd: Remove unneeded and dangerous clearing of clientdata mfd: New AB8500 driver gpio: Fix inverted rdc321x gpio data out registers mfd: Change rdc321x resources flags to IORESOURCE_IO mfd: Move pcf50633 irq related functions to its own file. mfd: Use threaded irq for pcf50633 mfd: pcf50633-adc: Fix potential race in pcf50633_adc_sync_read mfd: Fix pcf50633 bitfield logic in interrupt handler gpio: rdc321x needs to select MFD_CORE mfd: Use menuconfig for quicker config editing ARM: AB3550 board configuration and irq for U300 mfd: AB3550 core driver mfd: AB3100 register access change to abx500 API mfd: Renamed ab3100.h to abx500.h gpio: Add TC35892 GPIO driver mfd: Add Toshiba's TC35892 MFD core mfd: Delay to mask tsc irq in max8925 mfd: Remove incorrect wm8350 kfree ...
2010-05-30Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: DMAENGINE: DMA40 U8500 platform configuration DMA: PL330: Add dma api driver
2010-05-30Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, cpufeature: Unbreak compile with gcc 3.x x86, pat: Fix memory leak in free_memtype x86, k8: Fix section mismatch for powernowk8_exit() lib/atomic64_test: fix missing include of linux/kernel.h x86: remove last traces of quicklist usage x86, setup: Phoenix BIOS fixup is needed on Dell Inspiron Mini 1012 x86: "nosmp" command line option should force the system into UP mode arch/x86/pci: use kasprintf x86, apic: ack all pending irqs when crashed/on kexec
2010-05-30Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: Call pagefault_disable/pagefault_enable in kmap_atomic/kunmap_atomic parisc: Remove unnecessary macros from entry.S parisc: LWS fixes for syscall.S parisc: Delete unnecessary nop's in entry.S parisc: Avoid interruption in critical region in entry.S parisc: invoke oom-killer from page fault parisc: clear floating point exception flag on SIGFPE signal parisc: Use of align_frame provides stack frame.
2010-05-30Revert "cpusets: randomize node rotor used in cpuset_mem_spread_node()"Linus Torvalds
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which caused cross-architecture build problems for all the wrong reasons. IA64 already added its own version of __node_random(), but the fact is, there is nothing architectural about the function, and the original commit was just badly done. Revert it, since no fix is forthcoming. Requested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-30parisc: Call pagefault_disable/pagefault_enable in kmap_atomic/kunmap_atomicJohn David Anglin
Based on the generic implementation of kmap_atomic and kunmap_atomic, we should call pagefault_disable and pagefault_enable in our PA8000 implementation. The define for kmap_atomic_prot was also missing, and I updated kmap_atomic_pfn to use the generic implementation because of the change to kmap_atomic. I believe that this change is needed to fix the fork copy-on-write bug. Signed-off-by: John David Anglin <dave.anglin@nrc-cnrc.gc.ca> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2010-05-30parisc: Remove unnecessary macros from entry.SJohn David Anglin
The EXTR, DEP and DEPI macros are unnecessary. There are PA 1.X pneumonics available with the same functionality, and the DEP and DEPI macros conflict with assembler pneumonics. Tested on a variety of 32 and 64-bit systems. Signed-off-by: John David Anglin <dave.anglin@nrc-cnrc.gc.ca> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2010-05-30parisc: LWS fixes for syscall.SJohn David Anglin
1) Gate immediately and save a branch. 2) Fix off by one error in checking entry number. 3) Use sr7 instead of sr3 in error return path as sr3 might not contain correct value. 4) Enable locking on UP systems to prevent incorrect operation of the cas_action critical region on page faults. Tested on several systems, including UP c3750 with 2.6.33.2 kernel. Signed-off-by: John David Anglin <dave.anglin@nrc-cnrc.gc.ca> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2010-05-30parisc: Delete unnecessary nop's in entry.SJohn David Anglin
2010-05-30parisc: Avoid interruption in critical region in entry.SJohn David Anglin
2010-05-30parisc: invoke oom-killer from page faultNick Piggin
As explained in commit 1c0fe6e3bd, we want to call the architecture independent oom killer when getting an unexplained OOM from handle_mm_fault, rather than simply killing current. Cc: linux-parisc@vger.kernel.org Cc: linux-arch@vger.kernel.org Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2010-05-30parisc: clear floating point exception flag on SIGFPE signalHelge Deller
Clear the floating point exception flag before returning to user space. This is needed, else the libc trampoline handler may hit the same SIGFPE again while building up a trampoline to a signal handler. Fixes debian bug #559406. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2010-05-30parisc: Use of align_frame provides stack frame.Carlos O'Donell
Any assembly constant generated with the use of align_frame includes size for a full stack frame. Signed-off-by: Carlos O'Donell <carlos@systemhalted.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2010-05-28Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: native hardware cpuidle driver for latest Intel processors ACPI: acpi_idle: touch TS_POLLING only in the non-MWAIT case acpi_pad: uses MONITOR/MWAIT, so it doesn't need to clear TS_POLLING sched: clarify commment for TS_POLLING ACPI: allow a native cpuidle driver to displace ACPI cpuidle: make cpuidle_curr_driver static cpuidle: add cpuidle_unregister_driver() error check cpuidle: fail to register if !CONFIG_CPU_IDLE
2010-05-28Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits) ACPI: Don't let acpi_pad needlessly mark TSC unstable drivers/acpi/sleep.h: Checkpatch cleanup ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversion ACPI: delete unused c-state promotion/demotion data strucutures ACPI: video: fix acpi_backlight=video ACPI: EC: Use kmemdup drivers/acpi: use kasprintf ACPI, APEI, EINJ injection parameters support Add x64 support to debugfs ACPI, APEI, Use ERST for persistent storage of MCE ACPI, APEI, Error Record Serialization Table (ERST) support ACPI, APEI, Generic Hardware Error Source memory error support ACPI, APEI, UEFI Common Platform Error Record (CPER) header Unified UUID/GUID definition ACPI Hardware Error Device (PNP0C33) support ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setup ACPI, APEI, Document for APEI ACPI, APEI, EINJ support ACPI, APEI, HEST table parsing ACPI, APEI, APEI supporting infrastructure ...
2010-05-28Merge branch 'ht-delete-2.6.35' into releaseLen Brown
2010-05-28Merge branch 'acpi_enable' into releaseLen Brown
2010-05-28Merge branch 'bjorn-pci-root-v4-2.6.35' into releaseLen Brown
2010-05-28tracing: fix for tracepoint API changeStephen Rothwell
Commit 38516ab59fbc5b3bb278cf5e1fe2867c70cff32e ("tracing: Let tracepoints have data passed to tracepoint callbacks") requires this fixup to the powerpc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-28Merge branch 'for-linus/2635-updates' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2635-updates' of git://git.fluff.org/bjdooks/linux: ARM: S5PV210: serial: Fix section mismatch warning ARM: s3c2410_defconfig: Add new machines ARM: s3c6400_defconfig: Add framebuffer and basic LCD ARM: s3c6400_defconfig: Add RTC driver support ARM: s3c6400_defconfig: Enable USB host side ARM: s3c6400_defconfig: Add SPI driver ARM: s3c6400_defconfig: Update compiled machines ARM: S5P: Regoster clk_xusbxti clock for hsotg driver ARM: S3C64XX: Add USB OTG HCLK to the list of clocks ARM: SAMSUNG: gpio-cfg.h: update documentation ARM: SAMSUNG: Documentation: add documentation on GPIO code ARM: SAMSUNG: Fix documentation for s3c_gpio_cfgpin() ARM: S3C24XX: Documentation: add section on gpiolib changes ARM: S3C24XX: Documentation: update GPIO documentation ARM: S3C24XX: Documentation: update documentation overview ARM: SAMSUNG: Documentation: update directory layout ARM: SAMSUNG: Documentation: update the list of SoCs supported
2010-05-28FRV: ARCH_KMALLOC_MINALIGN was already definedDavid Howells
ARCH_KMALLOC_MINALIGN was already defined in asm/mem-layout.h and so shouldn't have been added to asm/cache.h as well, but rather altered in place. The commit that added it to asm/cache.h was: commit 69dcf3db03626c4f18de624e8632454ea12ff260 Author: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Date: Mon May 24 14:32:54 2010 -0700 frv: set ARCH_KMALLOC_MINALIGN Architectures that handle DMA-non-coherent memory need to set ARCH_KMALLOC_MINALIGN to make sure that kmalloc'ed buffer is DMA-safe: the buffer doesn't share a cache with the others. Signed-off-by: David Howells <dhowells@redhat.com> cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-28ARM: Merge for-2635/defconfig3Ben Dooks
Merge branch 'for-2635/defconfig3' into for-linus/2635-updates
2010-05-28ARM: s3c2410_defconfig: Add new machinesBen Dooks
Add the SMDK2416, and the GTA02 to the list of machines that are included in the s3c2410_defconfig. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: s3c6400_defconfig: Add framebuffer and basic LCDBen Dooks
Add the framebuffer driver and some basic LCD configurations that should be suitable for the SMDK boards. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: s3c6400_defconfig: Add RTC driver supportBen Dooks
Now that the RTC driver supports the S3C64XX, enable it in the build. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: s3c6400_defconfig: Enable USB host sideBen Dooks
Enable the USB Host side by adding the USB OHCI and some basic USB driver modules. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: s3c6400_defconfig: Add SPI driverBen Dooks
The SPI driver was added last kernel round, so enable the core SPI and add the 64XX and bitbang driver as modules. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: s3c6400_defconfig: Update compiled machinesBen Dooks
Add the machines that have been added in the last round to the list of builds. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: S5P: Regoster clk_xusbxti clock for hsotg driverThomas Abraham
The clk_xusbxti clock is added to the list of clocks to be registred during boot time clock registration. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> [ben-linux@fluff.org: edited title] Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: S3C64XX: Add USB OTG HCLK to the list of clocksThomas Abraham
Add the USB OTG HCLK clock to the list of clocks to be registered during initialization. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: SAMSUNG: gpio-cfg.h: update documentationBen Dooks
Update the documentation on the gpio configuration calls to add more references to useful information and also to document the values that are passed. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: SAMSUNG: Fix documentation for s3c_gpio_cfgpin()Ben Dooks
Fix typo in s3c_gpio_cfgpin() documentation, the second argument is @to not @pin again. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-27sched: clarify commment for TS_POLLINGLen Brown
TS_POLLING set tells the scheduler an idle_task will poll need_resched() to look for work. TS_POLLING clear tells resched_task() and wake_up_idle_cpu() that the remote CPU's idle_task is now sleeping in idle, and thus requires a reschedule interrupt notice work. Update the description of TS_POLLING to reflect how it works. "idle task polling need_resched, skip sending interrupt" Wordsmithing-by: Milton Miller <miltonm@bga.com> Signed-off-by: Len Brown <len.brown@intel.com> Acked-by: Peter Zijlstra <peterz@infradead.org>
2010-05-27Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix build breakage
2010-05-28mfd: New AB8500 driverRabin Vincent
Add a new driver to support the AB8500 Power Management chip, replacing the current AB4500. The new driver replaces the old one, instead of an incremental modification, because this is a substantial overhaul including: - Split of the driver into -core and -spi portions, to allow another interface layer to be added - Addition of interrupt support - Switch to MFD core API for handling subdevices - Simplification of the APIs to remove a redundant block parameter - Rename of the APIs and macros from ab4500_* to ab8500_* - Rename of the files from ab4500* to ab8500* - Change of the driver name from ab4500 to ab8500 Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28ARM: AB3550 board configuration and irq for U300Mattias Wallin
This patch adds the i2c board configuration needed for the Mixed Signal chip AB3550. It also adds the irq numbers needed for the irq_chip implementation. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Renamed ab3100.h to abx500.hLinus Walleij
The goal here is to make way for a more general interface for the analog baseband chips ab3100 ab3550 ab550 and future chips. This patch have been divided into two parts since both changing name and content of a file is not recommended in git. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28davinci: da850 TPS6507x touch screen driver board dataTodd Fischer
The touch screen controller in the TPS6507x chip needs values that are dependent on the characteristics of the touch screen hardware being used in the board design. In addition, the board provides version information that is exposed via the kernel input sub-system. Signed-off-by: Todd Fischer <todd.fischer@ridgerun.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Add tps6507x board data structureTodd Fischer
Add mfd structure which refrences sub-driver initialization data. For example, for a giving hardware implementation, the voltage regulator sub-driver initialization data provides the mapping betten a voltage regulator and what the output voltage is being used for. Signed-off-by: Todd Fischer <todd.fischer@ridgerun.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28x86: remove rdc321x_defs.hFlorian Fainelli
This file is replaced by a cleaner version with the adding of a MFD driver for the southbridge. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-27[IA64] Fix build breakageTony Luck
In commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b cpusets: randomize node rotor used in cpuset_mem_spread_node() Jack Steiner fixed a problem with too many small tasks being assigned to node 0. Copy his code to ia64 to avoid build error. arch/ia64/kernel/smpboot.c:641: error: ‘cpu_to_node_map’ undeclared (first use in this function) In commit 3bccd996276b108c138e8176793a26ecef54d573 numa: ia64: use generic percpu var numa_node_id() implementation Lee Schermerhorn added some set_numa_node() calls - but these only work on CONFIG_NUMA=y configurations. Surround the calls with #ifdef CONFIG_NUMA Signed-off-by: Tony Luck <tony.luck@intel.com>
2010-05-27Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (61 commits) tracing: Add __used annotation to event variable perf, trace: Fix !x86 build bug perf report: Support multiple events on the TUI perf annotate: Fix up usage of the build id cache x86/mmiotrace: Remove redundant instruction prefix checks perf annotate: Add TUI interface perf tui: Remove annotate from popup menu after failure perf report: Don't start the TUI if -D is used perf: Fix getline undeclared perf: Optimize perf_tp_event_match() perf: Remove more code from the fastpath perf: Optimize the !vmalloc backed buffer perf: Optimize perf_output_copy() perf: Fix wakeup storm for RO mmap()s perf-record: Share per-cpu buffers perf-record: Remove -M perf: Ensure that IOC_OUTPUT isn't used to create multi-writer buffers perf, trace: Optimize tracepoints by using per-tracepoint-per-cpu hlist to track events perf, trace: Optimize tracepoints by removing IRQ-disable from perf/tracepoint interaction perf tui: Allow disabling the TUI on a per command basis in ~/.perfconfig ...
2010-05-27DMAENGINE: DMA40 U8500 platform configurationLinus Walleij
This completes the DMA40 support with the platform-specific configuration for U8500/DB8500. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Reviewed-by: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson_nomadik_linux@list.st.com Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> [fixed up dma40_{tx|rx}_map declaration/initialization] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
