path: root/arch
2011-09-12Merge branch 'upstream/bugfix' of git://github.com/jsgf/linux-xenLinus Torvalds
* 'upstream/bugfix' of git://github.com/jsgf/linux-xen: xen: use non-tracing preempt in xen_clocksource_read()
2011-09-12Merge branch 'fixes' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'fixes' of git://git.linaro.org/people/arnd/arm-soc: ARM: CSR: add missing sentinels to of_device_id tables ARM: cns3xxx: Fix newly introduced warnings in the PCIe code ARM: cns3xxx: Fix compile error caused by hardware.h removed ARM: davinci: fix cache flush build error ARM: davinci: correct MDSTAT_STATE_MASK ARM: davinci: da850 EVM: read mac address from SPI flash OMAP: omap_device: fix !CONFIG_SUSPEND case in _noirq handlers OMAP2430: hwmod: musb: add missing terminator to omap2430_usbhsotg_addrs[] OMAP3: clock: indicate that gpt12_fck and wdt1_fck are in the WKUP clockdomain OMAP4: clock: fix compile warning OMAP4: clock: re-enable previous clockdomain enable/disable sequence OMAP: clockdomain: Wait for powerdomain to be ON when using clockdomain force wakeup OMAP: powerdomains: Make all powerdomain target states as ON at init
2011-09-12Merge branch 'for_3.1/pm-fixes-2' of ↵Arnd Bergmann
git://gitorious.org/khilman/linux-omap-pm into fixes
2011-09-12Merge branch 'sirf/fixes' into fixesArnd Bergmann
2011-09-11Merge branch 'for-linus' of git://openrisc.net/~jonas/linuxLinus Torvalds
* 'for-linus' of git://openrisc.net/~jonas/linux: Add missing DMA ops openrisc: don't use pt_regs in struct sigcontext
2011-09-11Add missing DMA opsJonas Bonn
For the initial architecture submission, not all of the DMA ops were implemented. This patch adds the *map_page and *map_sg variants of the DMA mapping ops. This patch is currently of interest mainly to some drivers that haven't been submitted upstream yet. Signed-off-by: Jonas Bonn <jonas@southpole.se>
2011-09-11ARM: CSR: add missing sentinels to of_device_id tablesJamie Iles
The of_device_id tables used for matching should be terminated with empty sentinel values. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Barry Song <baohua.song@csr.com>
2011-09-10Merge branch 'fixes' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: ARM: 7088/1: entry: fix wrong parameter name used in do_thumb_abort ARM: 7080/1: l2x0: make sure I&D are not locked down on init ARM: 7081/1: mach-integrator: fix the clocksource NET: am79c961: fix race in link status code ARM: 7067/1: mm: keep significant bits in pfn_valid
2011-09-10ARM: 7088/1: entry: fix wrong parameter name used in do_thumb_abortJanusz Krzysztofik
Commit be020f8618ca, "ARM: entry: abort-macro: specify registers to be used for macros", while replacing register numbers with macro parameter names, mismatched the name used for r1. For me, this resulted in user space built for EABI with -march=armv4t -mtune=arm920t -mthumb-interwork -mthumb broken on my OMAP1510 based Amstrad Delta (old ABI and no thumb still worked for me though). Fix this by using correct parameter name fsr instead of mismatched psr, used by callers for another purpose. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-10Merge branches 'cns3xxx/fixes', 'omap/fixes' and 'davinci/fixes' into fixesArnd Bergmann
2011-09-09Fix pointer dereference before call to pcie_bus_configure_settingsShyam Iyer
Commit b03e7495a862 ("PCI: Set PCI-E Max Payload Size on fabric") introduced a potential NULL pointer dereference in calls to pcie_bus_configure_settings due to attempts to access pci_bus self variables when the self pointer is NULL. To correct this, verify that the self pointer in pci_bus is non-NULL before dereferencing it. Reported-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Shyam Iyer <shyam_iyer@dell.com> Signed-off-by: Jon Mason <mason@myri.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-09ARM: cns3xxx: Fix newly introduced warnings in the PCIe codeAnton Vorontsov
commit d5341942d784134f2997b3ff82cd63cf71d1f932 ("PCI: Make the struct pci_dev * argument of pci_fixup_irqs const") did not change argument of pdev_to_cnspci(), and thus introduced the following warnings: CHECK arch/arm/mach-cns3xxx/pcie.c pcie.c:177:60: warning: incorrect type in argument 1 (different modifiers) pcie.c:177:60: expected struct pci_dev *dev pcie.c:177:60: got struct pci_dev const *dev CC arch/arm/mach-cns3xxx/pcie.o pcie.c: In function 'cns3xxx_pcie_map_irq': pcie.c:177: warning: passing argument 1 of 'pdev_to_cnspci' discards qualifiers from pointer target type pcie.c:52: note: expected 'struct pci_dev *' but argument is of type 'const struct pci_dev *' This patch fixes the issue. Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-09-09ARM: cns3xxx: Fix compile error caused by hardware.h removedTommy Lin
Commit c9d95fbe59e426eed7f16e7cac812e46ac4772d0 "ARM: convert PCI defines to variables" deleted cns3xxx' hardware.h, but didn't remove references for it, so do it now. This patch removes lines that refer to hardware.h. Signed-off-by: Tommy Lin <tommy.lin.1101@gmail.com> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-09-07Merge branch 'perf-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tipLinus Torvalds
* 'perf-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip: x86, perf: Check that current->mm is alive before getting user callchain perf_event: Fix broken calc_timer_values() perf events: Fix slow and broken cgroup context switch code
2011-09-07Merge branch 'stable/bug.fixes' of git://oss.oracle.com/git/kwilk/xenLinus Torvalds
* 'stable/bug.fixes' of git://oss.oracle.com/git/kwilk/xen: xen/smp: Warn user why they keel over - nosmp or noapic and what to use instead. xen: x86_32: do not enable iterrupts when returning from exception in interrupt context xen: use maximum reservation to limit amount of usable RAM
2011-09-07Merge branch 'kvm-updates/3.1' of git://github.com/avikivity/kvmLinus Torvalds
* 'kvm-updates/3.1' of git://github.com/avikivity/kvm: KVM: Fix instruction size issue in pvclock scaling
2011-09-07ARM: davinci: fix cache flush build errorLinus Walleij
The TNET variant of DaVinci compiles some code that it shares with other DaVinci variants, however it has a V6 CPU rather than an ARM926T, thus the hardcoded call to arm926_flush_kern_cache_all() in sleep.S will obviously fail, and we need to build with the v6_flush_kern_cache_all() call instead. This was triggered by manually altering the DaVinci config to build the TNET version. Cc: Dave Martin <dave.martin@linaro.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Cc: stable@kernel.org
2011-09-07ARM: davinci: correct MDSTAT_STATE_MASKSergei Shtylyov
MDSTAT.STATE occupies bits 0..5 according to all available documentation, so fix the #define MDSTAT_STATE_MASK at last. Using the wrong value seems to have been harmless though... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2011-09-07ARM: davinci: da850 EVM: read mac address from SPI flashRajashekhara, Sudhakar
DA850/OMAP-L138 EMAC driver uses random mac address instead of a fixed one because the mac address is not stuffed into EMAC platform data. This patch provides a function which reads the mac address stored in SPI flash (registered as MTD device) and populates the EMAC platform data. The function which reads the mac address is registered as a callback which gets called upon addition of MTD device. NOTE: In case the MAC address stored in SPI flash is erased, follow the instructions at [1] to restore it. [1] http://processors.wiki.ti.com/index.php/GSG:_OMAP-L138_DVEVM_Additional_Procedures#Restoring_MAC_address_on_SPI_Flash Modifications in v2: Guarded registering the mtd_notifier only when MTD is enabled. Earlier this was handled using mtd_has_partitions() call, but this has been removed in Linux v3.0. Modifications in v3: a. Guarded da850_evm_m25p80_notify_add() function and da850evm_spi_notifier structure with CONFIG_MTD macros. b. Renamed da850_evm_register_mtd_user() function to da850_evm_setup_mac_addr() and removed the struct mtd_notifier argument to this function. c. Passed the da850evm_spi_notifier structure to register_mtd_user() function. Modifications in v4: Moved the da850_evm_setup_mac_addr() function within the first CONFIG_MTD ifdef construct. Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Cc: stable@kernel.org
2011-09-07ARM: 7080/1: l2x0: make sure I&D are not locked down on initLinus Walleij
Fighting unfixed U-Boots and other beasts that may the cache in a locked-down state when starting the kernel, we make sure to disable all cache lock-down when initializing the l2x0 so we are in a known state. Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Rabin Vincent <rabin.vincent@stericsson.com> Cc: Adrian Bunk <adrian.bunk@movial.com> Cc: Rob Herring <robherring2@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reported-by: Jan Rinze <janrinze@gmail.com> Tested-by: Robert Marklund <robert.marklund@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-07ARM: 7081/1: mach-integrator: fix the clocksourceLinus Walleij
I was intrigued by the fact that the clock stood still on the Integrator, but it wasn't strange at all, because the timer was set up all wrong and probably has been for a while. With this patch the clock starts ticking again: make the timer periodic (reload), |= on the divisor bit and load the timer before starting it. Cc: stable@kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-06OMAP: omap_device: fix !CONFIG_SUSPEND case in _noirq handlersKevin Hilman
The suspend/resume _noirq handlers were #ifdef'd out in the !CONFIG_SUSPEND case, but were still assigned to the dev_pm_ops struct. Fix by defining them to NULL in the !CONFIG_SUSPEND case. Reported-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-05openrisc: don't use pt_regs in struct sigcontextJonas Bonn
As it was decided not to export struct pt_regs to userspace, struct sigcontext shouldn't be using it either. The pt_regs struct for OpenRISC is kernel internal and the layout of the registers may change in the future. The struct user_regs_struct is what is guaranteed to remain stable, so struct sigcontext may use that instead. This patch removes the usage of struct pt_regs in struct sigcontext and makes according changes in signal.c to get the register layout right. The usp field is removed from the sigcontext structure as this information is already contained in the user_regs_struct. Signed-off-by: Jonas Bonn <jonas@southpole.se> Reviewed-by: Emilio Cota <cota@braap.org>
2011-09-04Merge branches 'non_hwmod_compliant_fix_3.1rc', 'omap3_clock_fixes_3.1rc', ↵Paul Walmsley
'omap4_clock_fixes_3.1rc', 'missing_2430_musb_adds_terminator_fix_3.1rc' and 'pwrdm_clkdm_fixes_3.1rc' into prcm-fixes-a-3.1rc
2011-09-04OMAP2430: hwmod: musb: add missing terminator to omap2430_usbhsotg_addrs[]Paul Walmsley
Add a missing array terminator to omap2430_usbhsotg_addrs[]. Without this terminator, the omap_hwmod resource building code runs off the end of the array, resulting in at least this error -- if not worse behavior: [ 0.578002] musb-omap2430: failed to claim resource 4 [ 0.583465] omap_device: musb-omap2430: build failed (-16) [ 0.589294] Could not build omap_device for musb-omap2430 usb_otg_hs This should have been part of commit 78183f3fdf76f422431a81852468be01b36db325 ("omap_hwmod: use a null structure record to terminate omap_hwmod_addr_space arrays") but was evidently missed. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2011-09-04ARM: 7067/1: mm: keep significant bits in pfn_validMark Rutland
When ARCH_HAS_HOLES_MEMORYMODEL is selected, pfn_valid calls memblock_is_memory to test validity of a pfn: > memblock_is_memory(pfn << PAGE_SHIFT); On LPAE systems this cuts off the top bits, as the shift occurs before the value is promoted to a phys_addr_t. This patch replaces the shift with a call to __pfn_to_phys (which casts pfn to phys_addr_t before shifting), preventing the loss of significant bits. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-01xen/smp: Warn user why they keel over - nosmp or noapic and what to use instead.Konrad Rzeszutek Wilk
We have hit a couple of customer bugs where they would like to use those parameters to run an UP kernel - but both of those options turn of important sources of interrupt information so we end up not being able to boot. The correct way is to pass in 'dom0_max_vcpus=1' on the Xen hypervisor line and the kernel will patch itself to be a UP kernel. Fixes bug: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=637308 CC: stable@kernel.org Acked-by: Ian Campbell <Ian.Campbell@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-09-01xen: x86_32: do not enable iterrupts when returning from exception in ↵Igor Mammedov
interrupt context If vmalloc page_fault happens inside of interrupt handler with interrupts disabled then on exit path from exception handler when there is no pending interrupts, the following code (arch/x86/xen/xen-asm_32.S:112): cmpw $0x0001, XEN_vcpu_info_pending(%eax) sete XEN_vcpu_info_mask(%eax) will enable interrupts even if they has been previously disabled according to eflags from the bounce frame (arch/x86/xen/xen-asm_32.S:99) testb $X86_EFLAGS_IF>>8, 8+1+ESP_OFFSET(%esp) setz XEN_vcpu_info_mask(%eax) Solution is in setting XEN_vcpu_info_mask only when it should be set according to cmpw $0x0001, XEN_vcpu_info_pending(%eax) but not clearing it if there isn't any pending events. Reproducer for bug is attached to RHBZ 707552 CC: stable@kernel.org Signed-off-by: Igor Mammedov <imammedo@redhat.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-09-01xen: use maximum reservation to limit amount of usable RAMDavid Vrabel
Use the domain's maximum reservation to limit the amount of extra RAM for the memory balloon. This reduces the size of the pages tables and the amount of reserved low memory (which defaults to about 1/32 of the total RAM). On a system with 8 GiB of RAM with the domain limited to 1 GiB the kernel reports: Before: Memory: 627792k/4472000k available After: Memory: 549740k/11132224k available A increase of about 76 MiB (~1.5% of the unused 7 GiB). The reserved low memory is also reduced from 253 MiB to 32 MiB. The total additional usable RAM is 329 MiB. For dom0, this requires at patch to Xen ('x86: use 'dom0_mem' to limit the number of pages for dom0') (c/s 23790) CC: stable@kernel.org Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-31Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/p1023rds: Fix the error of bank-width of nor flash powerpc/85xx: enable caam crypto driver by default powerpc/85xx: enable the audio drivers in the defconfigs
2011-08-31x86, perf: Check that current->mm is alive before getting user callchainAndrey Vagin
An event may occur when an mm is already released. I added an event in dequeue_entity() and caught a panic with the following backtrace: [ 434.421110] BUG: unable to handle kernel NULL pointer dereference at 0000000000000050 [ 434.421258] IP: [<ffffffff810464ac>] __get_user_pages_fast+0x9c/0x120 ... [ 434.421258] Call Trace: [ 434.421258] [<ffffffff8101ae81>] copy_from_user_nmi+0x51/0xf0 [ 434.421258] [<ffffffff8109a0d5>] ? sched_clock_local+0x25/0x90 [ 434.421258] [<ffffffff8101b048>] perf_callchain_user+0x128/0x170 [ 434.421258] [<ffffffff811154cd>] ? __perf_event_header__init_id+0xed/0x100 [ 434.421258] [<ffffffff81116690>] perf_prepare_sample+0x200/0x280 [ 434.421258] [<ffffffff81118da8>] __perf_event_overflow+0x1b8/0x290 [ 434.421258] [<ffffffff81065240>] ? tg_shares_up+0x0/0x670 [ 434.421258] [<ffffffff8104fe1a>] ? walk_tg_tree+0x6a/0xb0 [ 434.421258] [<ffffffff81118f44>] perf_swevent_overflow+0xc4/0xf0 [ 434.421258] [<ffffffff81119150>] do_perf_sw_event+0x1e0/0x250 [ 434.421258] [<ffffffff81119204>] perf_tp_event+0x44/0x70 [ 434.421258] [<ffffffff8105701f>] ftrace_profile_sched_block+0xdf/0x110 [ 434.421258] [<ffffffff8106121d>] dequeue_entity+0x2ad/0x2d0 [ 434.421258] [<ffffffff810614ec>] dequeue_task_fair+0x1c/0x60 [ 434.421258] [<ffffffff8105818a>] dequeue_task+0x9a/0xb0 [ 434.421258] [<ffffffff810581e2>] deactivate_task+0x42/0xe0 [ 434.421258] [<ffffffff814bc019>] thread_return+0x191/0x808 [ 434.421258] [<ffffffff81098a44>] ? switch_task_namespaces+0x24/0x60 [ 434.421258] [<ffffffff8106f4c4>] do_exit+0x464/0x910 [ 434.421258] [<ffffffff8106f9c8>] do_group_exit+0x58/0xd0 [ 434.421258] [<ffffffff8106fa57>] sys_exit_group+0x17/0x20 [ 434.421258] [<ffffffff8100b202>] system_call_fastpath+0x16/0x1b Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/1314693156-24131-1-git-send-email-avagin@openvz.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-30powerpc/p1023rds: Fix the error of bank-width of nor flashChunhe Lan
In the p1023rds, a physical bus of nor flash is 16 bits width. The bank-width is width (in bytes) of the bus width. So, the value of bank-width of nor flash is not one, and it should be two. Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-08-30powerpc/85xx: enable caam crypto driver by defaultKim Phillips
corenet based SoCs have SEC4 h/w, so enable the SEC4 driver, caam, and the algorithms it supports, and disable the SEC2/3 driver, talitos. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-08-30powerpc/85xx: enable the audio drivers in the defconfigsTimur Tabi
Enable the audio drivers in the non-corenet 85xx defconfigs so that audio is enabled on the Freescale P1022DS reference board. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-08-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Only Panther cheetah+ chips have POPC.
2011-08-30KVM: Fix instruction size issue in pvclock scalingDuncan Sands
Commit de2d1a524e94 ("KVM: Fix register corruption in pvclock_scale_delta") introduced a mul instruction that may have only a memory operand; the assembler therefore cannot select the correct size: pvclock.s:229: Error: no instruction mnemonic suffix given and no register operands; can't size instruction In this example the assembler is: #APP mul -48(%rbp) ; shrd $32, %rdx, %rax #NO_APP A simple solution is to use mulq. Signed-off-by: Duncan Sands <baldrick@free.fr> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-08-29sparc64: Only Panther cheetah+ chips have POPC.David S. Miller
2011-08-29Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: pm: avoid writing the auxillary control register for ARMv7 ARM: pm: some ARMv7 requires a dsb in resume to ensure correctness ARM: pm: arm920/926: fix number of registers saved ARM: pm: CPU specific code should not overwrite r1 (v:p offset) ARM: 7066/1: proc-v7: disable SCTLR.TE when disabling MMU ARM: 7065/1: kexec: ensure new kernel is entered in ARM state ARM: 7003/1: vexpress: Add clock definition for the SP805. ARM: 7051/1: cpuimx* boards: fix mach-types errors ARM: 7019/1: Footbridge: select CLKEVT_I8253 for ARCH_NETWINDER ARM: 7015/1: ARM errata: Possible cache data corruption with hit-under-miss enabled ARM: 7014/1: cache-l2x0: Fix L2 Cache size calculation. ARM: 6967/1: ep93xx: ts72xx: fix board model detection ARM: 6965/1: ep93xx: add model detection for ts-7300 and ts-7400 boards ARM: cache: detect VIPT aliasing I-cache on ARMv6 ARM: twd: register clockevents device before enabling PPI ARM: realview: ensure visibility of writes during reset ARM: perf: make name of arm_pmu_type consistent ARM: perf: fix prototype of release_pmu ARM: fix perf build with uclibc toolchains
2011-08-29Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: mach-footbridge: add missing header file <video/vga.h> ARM: mach-orion5x: add missing header file <linux/vga.h> arm: fix compile failure in orion5x/dns323-setup.c at91: at91sam9261.c: fix typo in t2_clk alias for atmel_tcb.0 ARM: S5P: fix bug in spdif_clk_get_rate ARM: EXYNOS4: Add restart hook for proper reboot ARM: EXYNOS4: Increase reset delay for USB HOST PHY ARM: S5P: add required chained_irq_enter/exit to gpio-int code ARM: EXYNOS4: add required chained_irq_enter/exit to eint code ARM: SAMSUNG: Add chained enrty/exit call to timer interrupt handler ARM: S3C64XX: Fix build break in PM debug ARM: S5PV210: Fix build warning ARM: EXYNOS4: Fix the IRQ definitions for MIPI CSIS device ARM: EXYNOS4: remove duplicated inclusion ARM: EXYNOS4: Fix wrong devname to support clkdev ARM: EXYNOS4: Use the correct regulator names on universal_c210 ARM: SAMSUNG: Fix Section mismatch in samsung_bl_set() ARM: S5P64X0: Replace irq_gc_ack() with irq_gc_ack_set_bit()
2011-08-29remove remaining references to nfsservctlStephen Rothwell
These were missed in commit f5b940997397 "All Arch: remove linkage for sys_nfsservctl system call" due to them having no sys_ prefix (presumably). Cc: NeilBrown <neilb@suse.de> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-parisc@vger.kernel.org Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: James Bottomley <James.Bottomley@hansenpartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc32,sun4d: Change IPI IRQ level to prevent collision between IPI and timer interrupt sparc: Remove another reference to nfsservctl
2011-08-29Merge branch 'rmobile-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x * 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x: ARM: mach-shmobile: sh7372 CMT3 and CMT4 clock support ARM: mach-shmobile: sh7372 MSIOF clock support ARM: mach-shmobile: clock-sh7372: fixup USB-DMAC1 settings ARM: mach-shmobile: clock-sh73a0: tidyup CKSCR main clock selecter ARM: mach-shmobile: Remove 3DG/SGX from sh7372 INTCS ARM: mach-shmobile: mackerel: Add USB-DMA ID mmc: sdhi, mmcif: zboot: Correct clock disable logic ARM: mach-shmobile: ag5evm: SDHI requires waiting for idle ARM: static should be at beginning of declaration ARM: mach-shmobile: Use CMT2 for timer on sh7372 ARM: mach-shmobile: sh7372: Add USB-DMAC support
2011-08-29Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x: sh: fix the compile error in setup-sh7757.c serial: sh-sci: report CTS as active for get_mctrl sh: Add unaligned memory access for PC relative intructions sh: Fix unaligned memory access for branches without delay slots sh: Fix up fallout from cpuidle changes. serial: sh-sci: console Runtime PM support sh: Fix conflicting definitions of ptrace_triggered serial: sh-sci: fix DMA build by including dma-mapping.h serial: sh-sci: Fix up default regtype probing. sh: intc: enable both edges GPIO interrupts on sh7372 shwdt: fix usage of mod_timer clocksource: sh_cmt: wait for CMCNT on init V2
2011-08-29sparc32,sun4d: Change IPI IRQ level to prevent collision between IPI and ↵Kjetil Oftedal
timer interrupt On Sun4d systems running in SMP mode, IRQ 14 is used for timer interrupts and has a specialized interrupt handler. IPI is currently set to use IRQ 14 as well, which causes it to trigger the timer interrupt handler, and not the IPI interrupt handler. The IPI interrupt is therefore changed to IRQ 13, which is the highest normally handled interrupt. This IRQ is also used for SBUS interrupts, however there is nothing in the IPI/SBUS interrupt handlers that indicate that they will not handle sharing the interrupt. (IRQ 13 is indicated as audio interrupt, which is unlikely to be found in a sun4d system) Signed-off-by: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-29sparc: Remove another reference to nfsservctlStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-29ARM: mach-shmobile: sh7372 CMT3 and CMT4 clock supportMagnus Damm
Add clock control support for sh7372 CMT hardware blocks. No upstream sh7372 boards are making use of CMT3 + CMT4, but the sh7372 hardware happens to come out of reset with all CMT MSTP clocks _enabled_, so to save power we need to implement a fix in software to shut down unused clocks. This patch relies on the recently merged 794d78f drivers: sh: late disabling of clocks V2 to make sure the unused clocks get disabled as expected. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: sh7372 MSIOF clock supportMagnus Damm
Add clock control support for sh7372 MSIOF hardware blocks. No upstream sh7372 boards are making use of MSIOF0->2, but the sh7372 hardware happens to come out of reset with all MSIOF MSTP clocks _enabled_, so to save power we need to implement a fix in software to shut down unused clocks. This patch relies on the recently merged 794d78f drivers: sh: late disabling of clocks V2 to make sure the unused clocks get disabled as expected. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: clock-sh7372: fixup USB-DMAC1 settingsKuninori Morimoto
USB-DMAC1 needs SMSTPCR4/MSTP407 controls, not MSTP214 this patch tested on mackerel board Reported-by: Magnus Damm <damm@opensource.se> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: clock-sh73a0: tidyup CKSCR main clock selecterKuninori Morimoto
MAINCKSEL is [29:28], not [27:24] Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: Remove 3DG/SGX from sh7372 INTCSMagnus Damm
This patch removes support for the SGX interrupt source in the sh7372 INTCS controller. The SGX hardware block included in sh7372 is already hooked up to the ARM Cortex-A8 core using the INTCA controller, so SGX users are encouraged to make use of that interrupt source instead. Removing support for the SGX interrupt source in INTCS simplifies the sh7372 power management code by allowing us to assume that only INTCA needs to be powered on to operate the SGX hardware. If the INTCS interrupt source would be kept then the kernel would be forced to deal with additional dependencies that does not follow the regular power domain hiearachy. With this patch in place we can safely power down INTCS while the SGX is operating. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
