path: root/arch
2011-05-23Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools: Fix sample size bit operations perf tools: Fix ommitted mmap data update on remap watchdog: Change the default timeout and configure nmi watchdog period based on watchdog_thresh watchdog: Disable watchdog when thresh is zero watchdog: Only disable/enable watchdog if neccessary watchdog: Fix rounding bug in get_sample_period() perf tools: Propagate event parse error handling perf tools: Robustify dynamic sample content fetch perf tools: Pre-check sample size before parsing perf tools: Move evlist sample helpers to evlist area perf tools: Remove junk code in mmap size handling perf tools: Check we are able to read the event size on mmap
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits) ASoC: core: Don't set "(null)" as a driver name ALSA: hda - Use LPIB for ATI/AMD chipsets as default Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets" ASoC: Tegra: Fix compile when debugfs not enabled ASoC: spdif-dit: Add missing MODULE_* SOUND: OSS: Remove Au1550 driver. ALSA: hda - add Intel Panther Point HDMI codec id ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live! ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek ALSA: hda - Fix input-src parse in patch_analog.c ASoC: davinci-mcasp: enable ping-pong SRAM buffers ASoC: add iPAQ hx4700 machine driver ASoC: Asahi Kasei AK4641 codec driver ALSA: hda - Enable Realtek ALC269 codec input layer beep ALSA: intel8x0m: enable AMD8111 modem ALSA: HDA: Add jack detection for HDMI ALSA: sound, core, pcm_lib: fix xrun_log ASoC: Max98095: Move existing NULL check before pointer dereference. ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt ALSA: usb-audio - Add support for USB X-Fi S51 Pro ...
2011-05-23Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Eliminate various 'set but not used' warnings x86, SMEP: Fix section mismatch warnings x86, amd: Use _safe() msr access for GartTlbWlk disable code
2011-05-23Merge branch 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (131 commits) KVM: MMU: Use ptep_user for cmpxchg_gpte() KVM: Fix kvm mmu_notifier initialization order KVM: Add documentation for KVM_CAP_NR_VCPUS KVM: make guest mode entry to be rcu quiescent state KVM: x86 emulator: Make jmp far emulation into a separate function KVM: x86 emulator: Rename emulate_grpX() to em_grpX() KVM: x86 emulator: Remove unused arg from emulate_pop() KVM: x86 emulator: Remove unused arg from writeback() KVM: x86 emulator: Remove unused arg from read_descriptor() KVM: x86 emulator: Remove unused arg from seg_override() KVM: Validate userspace_addr of memslot when registered KVM: MMU: Clean up gpte reading with copy_from_user() KVM: PPC: booke: add sregs support KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0) KVM: PPC: use ticks, not usecs, for exit timing KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsx KVM: PPC: e500: emulate SVR KVM: VMX: Cache vmcs segment fields KVM: x86 emulator: consolidate segment accessors KVM: VMX: Avoid reading %rip unnecessarily when handling exceptions ...
2011-05-23watchdog: Change the default timeout and configure nmi watchdog period based ↵Mandeep Singh Baines
on watchdog_thresh Before the conversion of the NMI watchdog to perf event, the watchdog timeout was 5 seconds. Now it is 60 seconds. For my particular application, netbooks, 5 seconds was a better timeout. With a short timeout, we catch faults earlier and are able to send back a panic. With a 60 second timeout, the user is unlikely to wait and will instead hit the power button, causing us to lose the panic info. This change configures the NMI period to watchdog_thresh and sets the softlockup_thresh to watchdog_thresh * 2. In addition, watchdog_thresh was reduced to 10 seconds as suggested by Ingo Molnar. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/1306127423-3347-4-git-send-email-msb@chromium.org Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <20110517071642.GF22305@elte.hu>
2011-05-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6: (28 commits) sparc32: fix build, fix missing cpu_relax declaration SCHED_TTWU_QUEUE is not longer needed since sparc32 now implements IPI sparc32,leon: Remove unnecessary page_address calls in LEON DMA API. sparc: convert old cpumask API into new one sparc32, sun4d: Implemented SMP IPIs support for SUN4D machines sparc32, sun4m: Implemented SMP IPIs support for SUN4M machines sparc32,leon: Implemented SMP IPIs for LEON CPU sparc32: implement SMP IPIs using the generic functions sparc32,leon: SMP power down implementation sparc32,leon: added some SMP comments sparc: add {read,write}*_be routines sparc32,leon: don't rely on bootloader to mask IRQs sparc32,leon: operate on boot-cpu IRQ controller registers sparc32: always define boot_cpu_id sparc32: removed unused code, implemented by generic code sparc32: avoid build warning at mm/percpu.c:1647 sparc32: always register a PROM based early console sparc32: probe for cpu info only during startup sparc: consolidate show_cpuinfo in cpu.c sparc32,leon: implement genirq CPU affinity ...
2011-05-22x86: setup_smep needs to be __cpuinitLinus Torvalds
The setup_smep function gets calle at resume time too, and is thus not a pure __init function. When marked as __init, it gets thrown out after the kernel has initialized, and when the kernel is suspended and resumed, the code will no longer be around, and we'll get a nice "kernel tried to execute NX-protected page" oops because the page is no longer marked executable. Reported-and-tested-by: Parag Warudkar <parag.lkml@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-22sparc32: fix build, fix missing cpu_relax declarationSam Ravnborg
Fix following sparc (32 bit) build error: CC arch/sparc/kernel/asm-offsets.s In file included from include/linux/seqlock.h:29:0, from include/linux/time.h:8, from include/linux/timex.h:56, from include/linux/sched.h:57, from arch/sparc/kernel/asm-offsets.c:13: include/linux/spinlock.h: In function 'spin_unlock_wait': include/linux/spinlock.h:360:2: error: implicit declaration of function 'cpu_relax' Most likely caused by commit e66eed651fd1 ("list: remove prefetching from regular list iterators") due to include changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] wire up syncfs syscall [PARISC] wire up the fhandle syscalls [PARISC] wire up clock_adjtime syscall [PARISC] wire up fanotify syscalls [PARISC] prevent speculative re-read on cache flush [PARISC] only make executable areas executable [PARISC] fix pacache .size with new binutils
2011-05-22KVM: MMU: Use ptep_user for cmpxchg_gpte()Takuya Yoshikawa
The address of the gpte was already calculated and stored in ptep_user before entering cmpxchg_gpte(). This patch makes cmpxchg_gpte() to use that to make it clear that we are using the same address during walk_addr_generic(). Note that the unlikely annotations are used to show that the conditions are something unusual rather than for performance. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-05-22KVM: x86 emulator: Make jmp far emulation into a separate functionTakuya Yoshikawa
We introduce em_jmp_far(). We also call this from em_grp45() to stop treating modrm_reg == 5 case separately in the group 5 emulation. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Rename emulate_grpX() to em_grpX()Takuya Yoshikawa
The prototypes are changed appropriately. We also replaces "goto grp45;" with simple em_grp45() call. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Remove unused arg from emulate_pop()Takuya Yoshikawa
The opt of emulate_grp1a() is also removed. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Remove unused arg from writeback()Takuya Yoshikawa
Remove inline at this chance. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Remove unused arg from read_descriptor()Takuya Yoshikawa
2011-05-22KVM: x86 emulator: Remove unused arg from seg_override()Takuya Yoshikawa
In addition, one comma at the end of a statement is replaced with a semicolon. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: Validate userspace_addr of memslot when registeredTakuya Yoshikawa
This way, we can avoid checking the user space address many times when we read the guest memory. Although we can do the same for write if we check which slots are writable, we do not care write now: reading the guest memory happens more often than writing. [avi: change VERIFY_READ to VERIFY_WRITE] Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: MMU: Clean up gpte reading with copy_from_user()Takuya Yoshikawa
When we optimized walk_addr_generic() by not using the generic guest memory reader, we replaced copy_from_user() with get_user(): commit e30d2a170506830d5eef5e9d7990c5aedf1b0a51 KVM: MMU: Optimize guest page table walk commit 15e2ac9a43d4d7d08088e404fddf2533a8e7d52e KVM: MMU: Fix 64-bit paging breakage on x86_32 But as Andi pointed out later, copy_from_user() does the same as get_user() as long as we give a constant size to it. So we use copy_from_user() to clean up the code. The only, noticeable, regression introduced by this is 64-bit gpte reading on x86_32 hosts needed for PAE guests. But this can be mitigated by implementing 8-byte get_user() for x86_32, if needed. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: PPC: booke: add sregs supportScott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-05-22KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0)Scott Wood
Linux doesn't use USPRG0 (now renamed VRSAVE in the architecture, even when Altivec isn't involved), but a guest might. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-05-22KVM: PPC: use ticks, not usecs, for exit timingStuart Yoder
Convert to microseconds when displaying (with fix from Bharat Bhushan <Bharat.Bhushan@freescale.com>). This reduces rounding error with large quantities of short exits. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-05-22KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsxScott Wood
The exit type setting for mfspr/mtspr is moved from 44x to toplevel SPR emulation. This enables it on e500, and makes sure that all SPRs are covered. Exit accounting for tlbwe and tlbsx is added to e500. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-05-22KVM: PPC: e500: emulate SVRScott Wood
Return the actual host SVR for now, as we already do for PVR. Eventually we may support Qemu overriding PVR/SVR if the situation is appropriate, once we implement KVM_SET_SREGS on e500. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-05-22KVM: VMX: Cache vmcs segment fieldsAvi Kivity
Since the emulator now checks segment limits and access rights, it generates a lot more accesses to the vmcs segment fields. Undo some of the performance hit by cacheing those fields in a read-only cache (the entire cache is invalidated on any write, or on guest exit). Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: consolidate segment accessorsAvi Kivity
Instead of separate accessors for the segment selector and cached descriptor, use one accessor for both. This simplifies the code somewhat. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: VMX: Avoid reading %rip unnecessarily when handling exceptionsAvi Kivity
Avoids a VMREAD. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: SVM: Make dump_vmcb static, reduce textJoe Perches
dump_vmcb isn't used outside this module, make it static. Shrink text and object by ~1% by standardizing formats. $ size arch/x86/kvm/svm.o* text data bss dec hex filename 52910 580 10072 63562 f84a arch/x86/kvm/svm.o.new 53563 580 10072 64215 fad7 arch/x86/kvm/svm.o.old Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: MMU: Fix 64-bit paging breakage on x86_32Takuya Yoshikawa
Fix regression introduced by commit e30d2a170506830d5eef5e9d7990c5aedf1b0a51 KVM: MMU: Optimize guest page table walk On x86_32, get_user() does not support 64-bit values and we fail to build KVM at the point of 64-bit paging. This patch fixes this by using get_user() twice for that condition. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Reported-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: ia64: fix sparse warningsJeff Mahoney
This patch fixes some sparse warning about "dubious one-bit signed bitfield." Signed-off-by: Jeff Mahoney <jeffm@suse.com> Originally-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: Add CPUID support for VIA CPUBrillyWu@viatech.com.cn
The CPUIDs for Centaur are added, and then the features of PadLock hardware engine on VIA CPU, such as "ace", "ace_en" and so on, can be passed into the kvm guest. Signed-off-by: Brilly Wu <brillywu@viatech.com.cn> Signed-off-by: Kary Jin <karyjin@viatech.com.cn> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: call cache_all_regs() only once during instruction emulationGleb Natapov
Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: Fix compound mmioGleb Natapov
mmio_index should be taken into account when copying data from userspace. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: emulator: Propagate fault in far jump emulationGleb Natapov
2011-05-22KVM: mmio_fault_cr2 is not usedGleb Natapov
Remove unused variable mmio_fault_cr2. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: consolidate group handlingAvi Kivity
Move all groups into a single field and handle them in a single place. This saves bits when we add more group types (3 bits -> 7 groups types). Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: MMU: Add unlikely() annotations to walk_addr_generic()Avi Kivity
walk_addr_generic() is a hot path and is also hard for the cpu to predict - some of the parameters (fetch_fault in particular) vary wildly from invocation to invocation. Add unlikely() annotations where appropriate; all walk failures are considered unlikely, as are cases where we have to mark the accessed or dirty bit, as they are slow paths both in kvm and on real processors. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Use opcode::execute for PUSHF/POPF (9C/9D)Takuya Yoshikawa
For this, em_pushf/popf() are introduced. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Use opcode::execute for PUSHA/POPA (60/61)Takuya Yoshikawa
For this, emulate_pusha/popa() are converted to em_pusha/popa(). Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Use opcode::execute for POP reg (58-5F)Takuya Yoshikawa
In addition, the RET emulation is changed to call em_pop() to remove the pop_instruction label. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Use opcode::execute for Group 1, CMPS and SCASTakuya Yoshikawa
The following instructions are changed to use opcode::execute. Group 1 (80-83) ADD (00-05), OR (08-0D), ADC (10-15), SBB (18-1D), AND (20-25), SUB (28-2D), XOR (30-35), CMP (38-3D) CMPS (A6-A7), SCAS (AE-AF) The last two do the same as CMP in the emulator, so em_cmp() is used. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: MMU: Optimize guest page table walkTakuya Yoshikawa
This patch optimizes the guest page table walk by using get_user() instead of copy_from_user(). With this patch applied, paging64_walk_addr_generic() has become about 0.5us to 1.0us faster on my Phenom II machine with NPT on. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: SVM: Get rid of x86_intercept_map::validAvi Kivity
By reserving 0 as an invalid x86_intercept_stage, we no longer need to store a valid flag in x86_intercept_map. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: Use opcode::execute for 0F 01 opcodeAvi Kivity
2011-05-22KVM: x86 emulator: Don't force #UD for 0F 01 /5Avi Kivity
While it isn't defined, no need to force a #UD. If it becomes defined in the future this can cause wierd problems for the guest. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: move 0F 01 sub-opcodes into their own functionsAvi Kivity
2011-05-22KVM: x86 emulator: fix const value warning on i386 in svm insn RAX checkRandy Dunlap
arch/x86/kvm/emulate.c:2598: warning: integer constant is too large for 'long' type Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: avoid calling wbinvd() macroClemens Noss
Commit 0b56652e33c72092956c651ab6ceb9f0ad081153 fails to build: CC [M] arch/x86/kvm/emulate.o arch/x86/kvm/emulate.c: In function 'x86_emulate_insn': arch/x86/kvm/emulate.c:4095:25: error: macro "wbinvd" passed 1 arguments, but takes just 0 arch/x86/kvm/emulate.c:4095:3: warning: statement with no effect make[2]: *** [arch/x86/kvm/emulate.o] Error 1 make[1]: *** [arch/x86/kvm] Error 2 make: *** [arch/x86] Error 2 Work around this for now. Signed-off-by: Clemens Noss <cnoss@gmx.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: MMU: Make cmpxchg_gpte aware of nesting tooRoedel, Joerg
This patch makes the cmpxchg_gpte() function aware of the difference between l1-gfns and l2-gfns when nested virtualization is in use. This fixes a potential data-corruption problem in the l1-guest and makes the code work correct (at least as correct as the hardware which is emulated in this code) again. Cc: stable@kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: x86 emulator: drop x86_emulate_ctxt::vcpuAvi Kivity
No longer used. Signed-off-by: Avi Kivity <avi@redhat.com>
