commit cf592bf768c4fa40282b8fce58a80820065de2cb upstream.
powerpc didn't return 0 in that case, if it's rolling back the *nr pointer
it should also return zero to avoid adding pages to the array at the wrong
offset.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Acked-by: David Gibson <david@gibson.dropbear.id.au>
commit 3526741f0964c88bc2ce511e1078359052bf225b upstream.
Up to this point the code assumed old refcounting for hugepages (pre-thp).
This updates the code directly to the thp mapcount tail page refcounting.
Cc: David Gibson <david@gibson.dropbear.id.au>
commit 8596468487e2062cae2aad56e973784e03959245 upstream.
We only taken "refs" pins on the head page not "*nr" pins.
commit 405e44f2e312dd5dd63e5a9f459bffcbcd4368ef upstream.
"page" may have changed to point to the next hugepage after the loop
completed, The references have been taken on the head page, so the
put_page must happen there too.
This is a longstanding issue pre-thp inclusion.
It's totally unclear how these page_cache_add_speculative and
pte_val(pte) != pte_val(*ptep) checks are necessary across all the
powerpc gup_fast code, when x86 doesn't need any of that: there's no way
the page can be freed with irq disabled so we're guaranteed the
atomic_inc will happen on a page with page_count > 0 (so not needing the
speculative check).
The pte check is also meaningless on x86: no need to rollback on x86 if
the pte changed, because the pte can still change a CPU tick after the
check succeeded and it won't be rolled back in that case. The important
thing is we got a reference on a valid page that was mapped there a CPU
tick ago. So not knowing the soft tlb refill code of ppc64 in great
detail I'm not removing the "speculative" page_count increase and the
pte checks across all the code, but unless there's a strong reason for
it they should be later cleaned up too.
If a pte can change from huge to non-huge (like it could happen with
THP) passing a pte_t *ptep to gup_hugepte() would also require to repeat
the is_hugepd in gup_hugepte(), but that shouldn't happen with hugetlbfs
only so I'm not altering that.
commit 2839bdc1bfc0af76a2f0f11eca011590520a04fa upstream.
This part of gup_fast doesn't seem capable of handling hugetlbfs ptes,
those should be handled by gup_hugepd only, so these checks are
superfluous.
Plus if this wasn't a noop, it would have oopsed because, the insistence
of using the speculative refcounting would trigger a VM_BUG_ON if a tail
page was encountered in the page_cache_get_speculative().
commit 70b50f94f1644e2aa7cb374819cfd93f3c28d725 upstream.
Michel while working on the working set estimation code, noticed that
calling get_page_unless_zero() on a random pfn_to_page(random_pfn)
wasn't safe, if the pfn ended up being a tail page of a transparent
hugepage under splitting by __split_huge_page_refcount().
He then found the problem could also theoretically materialize with
page_cache_get_speculative() during the speculative radix tree lookups
that uses get_page_unless_zero() in SMP if the radix tree page is freed
and reallocated and get_user_pages is called on it before
page_cache_get_speculative has a chance to call get_page_unless_zero().
So the best way to fix the problem is to keep page_tail->_count zero at
all times. This will guarantee that get_page_unless_zero() can never
succeed on any tail page. page_tail->_mapcount is guaranteed zero and
is unused for all tail pages of a compound page, so we can simply
account the tail page references there and transfer them to
tail_page->_count in __split_huge_page_refcount() (in addition to the
head_page->_mapcount).
While debugging this s/_count/_mapcount/ change I also noticed get_page is
called by direct-io.c on pages returned by get_user_pages. That wasn't
entirely safe because the two atomic_inc in get_page weren't atomic. As
opposed to other get_user_page users like secondary-MMU page fault to
establish the shadow pagetables would never call any superflous get_page
after get_user_page returns. It's safer to make get_page universally safe
for tail pages and to use get_page_foll() within follow_page (inside
get_user_pages()). get_page_foll() is safe to do the refcounting for tail
pages without taking any locks because it is run within PT lock protected
critical sections (PT lock for pte and page_table_lock for
pmd_trans_huge).
The standard get_page() as invoked by direct-io instead will now take
the compound_lock but still only for tail pages. The direct-io paths
are usually I/O bound and the compound_lock is per THP so very
finegrined, so there's no risk of scalability issues with it. A simple
direct-io benchmarks with all lockdep prove locking and spinlock
debugging infrastructure enabled shows identical performance and no
overhead. So it's worth it. Ideally direct-io should stop calling
get_page() on pages returned by get_user_pages(). The spinlock in
get_page() is already optimized away for no-THP builds but doing
get_page() on tail pages returned by GUP is generally a rare operation
and usually only run in I/O paths.
This new refcounting on page_tail->_mapcount in addition to avoiding new
RCU critical sections will also allow the working set estimation code to
work without any further complexity associated to the tail page
refcounting with THP.
Reported-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
commit 0d65ede0a605d6252acc5c8a9c536c4cd0211f3c upstream.
kmalloc size is 1st arg, not second.
Signed-off-by: Dave Jones <davej@redhat.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 8535639810e578960233ad39def3ac2157b0c3ec upstream.
ubd_file_size() cannot use ubd_dev->cow.file because at this time
ubd_dev->cow.file is not initialized.
Therefore, ubd_file_size() will always report a wrong disk size when
COW files are used.
Reading from /dev/ubd* would crash the kernel.
We have to read the correct disk size from the COW file's backing
file.
commit 1bf6d2c1bb23533af6930581cc39b74685bc29de upstream.
Apparently U8500 U-Boot versions may leave the l2x0 locked down
before executing the kernel. Make sure we unlock it before we
initialize the l2x0. This fixes a performance problem reported
by Jan Rinze.
The l2x0 core has been modified to unlock the l2x0 by default,
but it will not touch the locking registers if the l2x0 was
already enabled, as on the ux500, so we need this quirk to
make sure it is properly turned off.
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
Cc: Adrian Bunk <adrian.bunk@movial.com>
Reported-by: Jan Rinze <janrinze@gmail.com>
Tested-by: Robert Marklund <robert.marklund@stericsson.com>
commit 1a64200ec5e93be03e27c3b2fc332e04ae443eb2 upstream.
Fix below build warning and properly set bt_reset pin.
CC arch/arm/mach-pxa/cm-x300.o
arch/arm/mach-pxa/cm-x300.c: In function 'cm_x300_init_wi2wi':
arch/arm/mach-pxa/cm-x300.c:779: warning: unused variable 'wlan_en'
arch/arm/mach-pxa/cm-x300.c:795: warning: 'bt_reset' may be used uninitialized in this function
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
commit 6571534b600b8ca1936ff5630b9e0947f21faf16 upstream.
To configure pads during the initialisation a set of special constants
is used, e.g.
#define MX25_PAD_FEC_MDIO__FEC_MDIO IOMUX_PAD(0x3c4, 0x1cc, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_22K_UP)
The problem is that no pull-up/down is getting activated unless both
PAD_CTL_PUE (pull-up enable) and PAD_CTL_PKE (pull/keeper module
enable) set. This is clearly stated in the i.MX25 datasheet and is
confirmed by the measurements on hardware. This leads to some rather
hard to understand bugs such as misdetecting an absent ethernet PHY (a
real bug i had), unstable data transfer etc. This might affect mx25,
mx35, mx50, mx51 and mx53 SoCs.
It's reasonable to expect that if the pullup value is specified, the
intention was to have it actually active, so we implicitly add the
needed bits.
Signed-off-by: Paul Fertser <fercerpav@gmail.com>
commit e73b7fffe487c315fd1a4fa22282e3362b440a06 upstream.
The rcu page table free code uses a couple of bits in the page table
pointer passed to tlb_remove_table to discern the different page table
types. __tlb_remove_table extracts the type with an incorrect mask which
leads to memory leaks. The correct mask is ((FRAG_MASK << 4) | FRAG_MASK).
commit a45aff5285871bf7be1781d9462d3fdbb6c913f9 upstream.
git commit 5e9a2692 "[S390] ptrace cleanup" introduced a regression
for the case when both a user PER set (e.g. a storage alteration trace) and
PTRACE_SINGLESTEP are active. The new code will overrule the user PER set
with a instruction-fetch PER set over the whole address space for ptrace
single stepping. The inferior process will be stopped after each instruction
with an instruction fetch event. Any other events that may have occurred
concurrently are not reported (e.g. storage alteration event) because the
control bits for them are not set. The solution is to merge the PER control
bits of the user PER set with the PER_EVENT_IFETCH control bit for
PTRACE_SINGLESTEP.
commit 4d47555a80495657161a7e71ec3014ff2021e450 upstream.
We use the cpu id provided by userspace as array index here. Thus we
clearly need to check it first. Ooops.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 838312be46f3abfbdc175f81c3e54a857994476d upstream.
These warnings (generally one per CPU) are a result of
initializing x86_cpu_to_logical_apicid while apic_default is
still in use, but the check in setup_local_APIC() being done
when apic_bigsmp was already used as an override in
default_setup_apic_routing():
Overriding APIC driver with bigsmp
Enabling APIC mode: Physflat. Using 5 I/O APICs
WARNING: at .../arch/x86/kernel/apic/apic.c:1239
CPU 1 irqstacks, hard=f1c9a000 soft=f1c9c000
Booting Node 0, Processors #1
smpboot cpu 1: start_ip = 9e000
Initializing CPU#1
setup_local_APIC+0x137/0x46b() Hardware name: ...
CPU1 logical APIC ID: 2 != 8
Fix this (for the time being, i.e. until
x86_32_early_logical_apicid() will get removed again, as Tejun
says ought to be possible) by overriding the previously stored
values at the point where the APIC driver gets overridden.
v2: Move this and the pre-existing override logic into
arch/x86/kernel/apic/bigsmp_32.c.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Acked-by: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/4E835D16020000780005844C@nat28.tlf.novell.com
commit a06f916b7a9b57447ceb875eb0a89f1a66b31bca upstream.
Rather than clipping the number of CPUs using the compile-time NR_CPUS
constant, use the runtime nr_cpu_ids value instead. This allows the
nr_cpus command line option to work as expected.
Reported-by: Mark Salter <msalter@redhat.com>
commit 315eb8a2a1b7f335d40ceeeb11b9e067475eb881 upstream.
When compiling an i386_defconfig kernel with gcc-4.6.1-9.fc15.i686, I
noticed a warning about the asm operand for test_bit in kprobes'
can_boost. I discovered that this caused only the first long of
twobyte_is_boostable[] to be output.
Jakub filed and fixed gcc PR50571 to correct the warning and this output
issue. But to solve it for less current gcc, we can make kprobes'
twobyte_is_boostable[] non-const, and it won't be optimized out.
Before:
CC arch/x86/kernel/kprobes.o
In file included from include/linux/bitops.h:22:0,
from include/linux/kernel.h:17,
from [...]/arch/x86/include/asm/percpu.h:44,
from [...]/arch/x86/include/asm/current.h:5,
from [...]/arch/x86/include/asm/processor.h:15,
from [...]/arch/x86/include/asm/atomic.h:6,
from include/linux/atomic.h:4,
from include/linux/mutex.h:18,
from include/linux/notifier.h:13,
from include/linux/kprobes.h:34,
from arch/x86/kernel/kprobes.c:43:
[...]/arch/x86/include/asm/bitops.h: In function ‘can_boost.part.1’:
[...]/arch/x86/include/asm/bitops.h:319:2: warning: use of memory input
without lvalue in asm operand 1 is deprecated [enabled by default]
$ objdump -rd arch/x86/kernel/kprobes.o | grep -A1 -w bt
551: 0f a3 05 00 00 00 00 bt %eax,0x0
554: R_386_32 .rodata.cst4
$ objdump -s -j .rodata.cst4 -j .data arch/x86/kernel/kprobes.o
arch/x86/kernel/kprobes.o: file format elf32-i386
Contents of section .data:
0000 48000000 00000000 00000000 00000000 H...............
Contents of section .rodata.cst4:
0000 4c030000 L...
Only a single long of twobyte_is_boostable[] is in the object file.
After, without the const on twobyte_is_boostable:
551: 0f a3 05 20 00 00 00 bt %eax,0x20
554: R_386_32 .data
0010 00000000 00000000 00000000 00000000 ................
0020 4c030000 0f000200 ffff0000 ffcff0c0 L...............
0030 0000ffff 3bbbfff8 03ff2ebb 26bb2e77 ....;.......&..w
Now all 32 bytes are output into .data instead.
Signed-off-by: Josh Stone <jistone@redhat.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Jakub Jelinek <jakub@redhat.com>
commit 6a469e4665bc158599de55d64388861d0a9f10f4 upstream.
This is a workaround for a UV2 hub bug that affects the format of system
global addresses.
The GRU API for UV2 was inadvertently broken by a hardware change. The
format of the physical address used for TLB dropins and for addresses used
with instructions running in unmapped mode has changed. This change was
not documented and became apparent only when diags failed running on
system simulators.
For UV1, TLB and GRU instruction physical addresses are identical to
socket physical addresses (although high NASID bits must be OR'ed into the
address).
For UV2, socket physical addresses need to be converted. The NODE portion
of the physical address needs to be shifted so that the low bit is in bit
39 or bit 40, depending on an MMR value.
It is not yet clear if this bug will be fixed in a silicon respin. If it
is fixed, the hub revision will be incremented & the workaround disabled.
Signed-off-by: Jack Steiner <steiner@sgi.com>
Commit 4b239f458 ("x86-64, mm: Put early page table high") causes a S4
regression since 2.6.39, namely the machine reboots occasionally at S4
resume. It doesn't happen always, overall rate is about 1/20. But,
like other bugs, once when this happens, it continues to happen.
This patch fixes the problem by essentially reverting the memory
assignment in the older way.
Cc: <stable@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Yinghai Lu <yinghai.lu@oracle.com>
[ We'll hopefully find the real fix, but that's too late for 3.1 now ]
* 'samsung-fixes-4' of git://github.com/kgene/linux-samsung:
ARM: S3C24XX: Fix s3c24xx build errors if !CONFIG_PM
ARM: S5P: fix offset calculation on gpio-interrupt
v2:
- register_syscore_ops(&s3c24xx_irq_syscore_ops) does not need to be
conditionally compiled out, it is already optimized out on !CONFIG_PM
- fix also s3c2412 and s3c2416 affected by the same build issue
v1:
s3c2440.c fails to build if !CONFIG_PM because in such case
s3c2410_pm_syscore_ops is not defined. Same error should happen also
in s3c2410.c and s3c2442.c
Signed-off-by: Domenico Andreoli <cavokz@gmail.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Offsets of the irq controller registers were calculated
correctly only for first GPIO bank. This patch fixes
calculation of the register offsets for all GPIO banks.
Reported-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc: Add alignment flag to PCI expansion resources
sparc: Avoid calling sigprocmask()
sparc: Use set_current_blocked()
sparc32,leon: SRMMU MMU Table probe fix
Currently no type of alignment is specified for PCI expansion roms while
parsing the openfirmware tree. This causes calls to pci_map_rom() to fail.
IORESOURCE_SIZEALIGN is the default alignment used for rom resouces in
pci/probe.c, and has been verified to work with various cards on a ultra 10.
Signed-off-By: Kjetil Oftedal <oftedal@gmail.com>
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm:
ARM: 7128/1: vic: Don't write to the read-only register VIC_IRQ_STATUS
ARM: 7122/1: localtimer: add header linux/errno.h explicitly
ARM: 7117/1: perf: fix HW_CACHE_* events on Cortex-A9
ARM: 7113/1: mm: Align bank start to MAX_ORDER_NR_PAGES
This is unneeded and causes an abort on the SPMP8000 platform.
Signed-off-by: Zoltan Devai <zoss@devai.org>
Per the text in Documentation/SubmitChecklist as below, we should
explicitly have header linux/errno.h in localtimer.h for ENXIO
reference.
1: If you use a facility then #include the file that defines/declares
that facility. Don't depend on other header files pulling in ones
that you use.
Otherwise, we may run into some compiling error like the following one,
if any file includes localtimer.h without CONFIG_LOCAL_TIMERS defined.
arch/arm/include/asm/localtimer.h: In function ‘local_timer_setup’:
arch/arm/include/asm/localtimer.h:53:10: error: ‘ENXIO’ undeclared (first use in this function)
Using COHERENT_LINE_{MISS,HIT} for cache misses and references
respectively is completely wrong. Instead, use the L1D events which
are a better and more useful approximation despite ignoring instruction
traffic.
Reported-by: Alasdair Grant <alasdair.grant@arm.com>
Reported-by: Matt Horsnell <matt.horsnell@arm.com>
Reported-by: Michael Williams <michael.williams@arm.com>
Cc: stable@kernel.org
Cc: Jean Pihet <j-pihet@ti.com>
* 'stable' of git://github.com/cmetcalf-tilera/linux-tile:
tile: revert change from <asm/atomic.h> to <linux/atomic.h> in asm files
* 'x86-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
x86: Default to vsyscall=native for now
SFI tables reside in RAM and should not be modified once they are
written. Current code went to set pentry->irq to zero which causes
subsequent reads to fail with invalid SFI table checksum. This will
break kexec as the second kernel fails to validate SFI tables.
To fix this we use temporary variable for irq number.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
The 32-bit TILEPro support uses some #defines in <asm/atomic_32.h>
for atomic support routines in assembly. To make this more explicit,
I've turned those includes into includes of <asm/atomic_32.h>, which
should hopefully make it clear that they shouldn't be bombed into
<linux/atomic.h> in any cleanups.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Use set_current_blocked() instead.
As described in e6fa16ab ("signal: sigprocmask() should do
retarget_shared_pending()") the modification of current->blocked is
incorrect as we need to check whether the signal we're about to block
is pending in the shared queue.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
This UML breakage:
linux-2.6.30.1[3800] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb9c498 ax:ffffffffff600000 si:0 di:606790
linux-2.6.30.1[3856] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb13168 ax:ffffffffff600000 si:0 di:606790
Is caused by commit 3ae36655 ("x86-64: Rework vsyscall emulation and add
vsyscall= parameter") - the vsyscall emulation code is not fully cooked
yet as UML relies on some rather fragile SIGSEGV semantics.
Linus suggested in https://lkml.org/lkml/2011/8/9/376 to default
to vsyscall=native for now, this patch implements that.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Andrew Lutomirski <luto@mit.edu>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Link: http://lkml.kernel.org/r/20111005214047.GE14406@localhost.pp.htv.fi
* 'fixes' of git://git.linaro.org/people/arnd/arm-soc:
ARM: mach-ux500: enable fix for ARM errata 754322
ARM: OMAP: musb: Remove a redundant omap4430_phy_init call in usb_musb_init
ARM: OMAP: Fix i2c init for twl4030
ARM: OMAP4: MMC: fix power and audio issue, decouple USBC1 from MMC1
This fixes a compilation error in cpu-tegra.c which was introduced in
dc8d966bccde ("ARM: convert PCI defines to variables") which removed the
now obsolete mach/hardware.h from the mach-tegra subtree.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (29 commits)
MIPS: Call oops_enter, oops_exit in die
staging/octeon: Software should check the checksum of no tcp/udp packets
MIPS: Octeon: Enable C0_UserLocal probing.
MIPS: No branches in delay slots for huge pages in handle_tlbl
MIPS: Don't clobber CP0_STATUS value for CONFIG_MIPS_MT_SMTC
MIPS: Octeon: Select CONFIG_HOLES_IN_ZONE
MIPS: PM: Use struct syscore_ops instead of sysdevs for PM (v2)
MIPS: Compat: Use 32-bit wrapper for compat_sys_futex.
MIPS: Do not use EXTRA_CFLAGS
MIPS: Alchemy: DB1200: Disable cascade IRQ in handler
SERIAL: Lantiq: Set timeout in uart_port
MIPS: Lantiq: Fix setting the PCI bus speed on AR9
MIPS: Lantiq: Fix external interrupt sources
MIPS: tlbex: Fix build error in R3000 code.
MIPS: Alchemy: Include Au1100 in PM code.
MIPS: Alchemy: Fix typo in MAC0 registration
MIPS: MSP71xx: Fix build error.
MIPS: Handle __put_user() sleeping.
MIPS: Allow forced irq threading
MIPS: i8259: Mark cascade interrupt non-threaded
The LEON MMU Model (SRMMU) does not implement MMu Table probing
in hardware, instead it is implemented in software. However the
software implementation does not return the PTE as it should which
always results in INVALID entires and the PROM mappings are not
inherited as they should during startup. The following patch
removes the masking of the PTE.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
This applies ARM errata fix 754322 for all ux500 platforms.
Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com>
In summary, this DMI quirk uses the _CRS info by default for the ASUS
M2V-MX SE by turning on `pci=use_crs` and is similar to the quirk
added by commit 2491762cfb47 ("x86/PCI: use host bridge _CRS info on
ASRock ALiveSATA2-GLAN") whose commit message should be read for further
information.
Since commit 3e3da00c01d0 ("x86/pci: AMD one chain system to use pci
read out res") Linux gives the following oops:
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
HDA Intel 0000:20:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
HDA Intel 0000:20:01.0: setting latency timer to 64
BUG: unable to handle kernel paging request at ffffc90011c08000
IP: [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel]
PGD 13781a067 PUD 13781b067 PMD 1300ba067 PTE 800000fd00000173
Oops: 0009 [#1] SMP
last sysfs file: /sys/module/snd_pcm/initstate
CPU 0
Modules linked in: snd_hda_intel(+) snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event tpm_tis tpm snd_seq tpm_bios psmouse parport_pc snd_timer snd_seq_device parport processor evdev snd i2c_viapro thermal_sys amd64_edac_mod k8temp i2c_core soundcore shpchp pcspkr serio_raw asus_atk0110 pci_hotplug edac_core button snd_page_alloc edac_mce_amd ext3 jbd mbcache sha256_generic cryptd aes_x86_64 aes_generic cbc dm_crypt dm_mod raid1 md_mod usbhid hid sg sd_mod crc_t10dif sr_mod cdrom ata_generic uhci_hcd sata_via pata_via libata ehci_hcd usbcore scsi_mod via_rhine mii nls_base [last unloaded: scsi_wait_scan]
Pid: 1153, comm: work_for_cpu Not tainted 2.6.37-1-amd64 #1 M2V-MX SE/System Product Name
RIP: 0010:[<ffffffffa0578402>] [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel]
RSP: 0018:ffff88013153fe50 EFLAGS: 00010286
RAX: ffffc90011c08000 RBX: ffff88013029ec00 RCX: 0000000000000006
RDX: 0000000000000000 RSI: 0000000000000246 RDI: 0000000000000246
RBP: ffff88013341d000 R08: 0000000000000000 R09: 0000000000000040
R10: 0000000000000286 R11: 0000000000003731 R12: ffff88013029c400
R13: 0000000000000000 R14: 0000000000000000 R15: ffff88013341d090
FS: 0000000000000000(0000) GS:ffff8800bfc00000(0000) knlGS:00000000f7610ab0
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffffc90011c08000 CR3: 0000000132f57000 CR4: 00000000000006f0
Process work_for_cpu (pid: 1153, threadinfo ffff88013153e000, task ffff8801303c86c0)
Stack:
0000000000000005 ffffffff8123ad65 00000000000136c0 ffff88013029c400
ffff8801303c8998 ffff88013341d000 ffff88013341d090 ffff8801322d9dc8
ffff88013341d208 0000000000000000 0000000000000000 ffffffff811ad232
Call Trace:
[<ffffffff8123ad65>] ? __pm_runtime_set_status+0x162/0x186
[<ffffffff811ad232>] ? local_pci_probe+0x49/0x92
[<ffffffff8105afc5>] ? do_work_for_cpu+0x0/0x1b
[<ffffffff8105afd0>] ? do_work_for_cpu+0xb/0x1b
[<ffffffff8105fd3f>] ? kthread+0x7a/0x82
[<ffffffff8100a824>] ? kernel_thread_helper+0x4/0x10
[<ffffffff8105fcc5>] ? kthread+0x0/0x82
[<ffffffff8100a820>] ? kernel_thread_helper+0x0/0x10
Code: f4 01 00 00 ef 31 f6 48 89 df e8 29 dd ff ff 85 c0 0f 88 2b 03 00 00 48 89 ef e8 b4 39 c3 e0 8b 7b 40 e8 fc 9d b1 e0 48 8b 43 38 <66> 8b 10 66 89 14 24 8b 43 14 83 e8 03 83 f8 01 77 32 31 d2 be
RIP [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel]
RSP <ffff88013153fe50>
---[ end trace 8d1f3ebc136437fd ]---
Trusting the ACPI _CRS information (`pci=use_crs`) fixes this problem.
$ dmesg | grep -i crs # with the quirk
PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
The match has to be against the DMI board entries though since the vendor entries are not populated.
DMI: System manufacturer System Product Name/M2V-MX SE, BIOS 0304 10/30/2007
This quirk should be removed when `pci=use_crs` is enabled for machines
from 2006 or earlier or some other solution is implemented.
Using coreboot [1] with this board the problem does not exist but this
quirk also does not affect it either. To be safe though the check is
tightened to only take effect when the BIOS from American Megatrends is
used.
15:13 < ruik> but coreboot does not need that
15:13 < ruik> because i have there only one root bus
15:13 < ruik> the audio is behind a bridge
$ sudo dmidecode
BIOS Information
Vendor: American Megatrends Inc.
Version: 0304
Release Date: 10/30/2007
[1] http://www.coreboot.org/
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=30552
Cc: stable@kernel.org (2.6.34)
Cc: x86@kernel.org
Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This allows pause_on_oops and mtdoops to work.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2810/
The VM subsystem assumes that there are valid memmap entries from
the bank start aligned to MAX_ORDER_NR_PAGES.
On the Ux500 we have a lot of mem=N arguments on the commandline
triggering this bug several times over and causing kernel
oops messages.
Cc: Michael Bohan <mbohan@codeaurora.org>
Cc: Nicolas Pitre <nico@fluxnic.net>
Signed-off-by: Johan Palsson <johan.palsson@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
'sched-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip
* 'irq-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
irq: Fix check for already initialized irq_domain in irq_domain_add
irq: Add declaration of irq_domain_simple_ops to irqdomain.h
x86/rtc: Don't recursively acquire rtc_lock
* 'sched-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
posix-cpu-timers: Cure SMP wobbles
sched: Fix up wchan borkage
sched/rt: Migrate equal priority tasks to available CPUs
Current code calls omap4430_phy_init() twice in usb_musb_init().
Calling omap4430_phy_init() once is enough.
This patch removes the first omap4430_phy_init() call, which using an
uninitialized pointer as parameter.
This patch elimates below build warning:
arch/arm/mach-omap2/usb-musb.c: In function 'usb_musb_init':
arch/arm/mach-omap2/usb-musb.c:141: warning: 'dev' may be used uninitialized in this function
Bjarne Steinsbo <bsteinsbo@gmail.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Looks like 2600 kHz rate does not work reliably on 2430,
so just use the 100 kHz rate.
Otherwise the system often fails to boot properly with:
omap_i2c omap_i2c.2: timeout waiting for bus ready
twl: i2c_write failed to transfer all messages
twl: clock init err [-110]
TWL4030 Unable to unlock IDCODE registers --110
Remove OMAP4_USBC1_ICUSB_PWRDNZ_MASK during enable/disable PWRDNZ mode for
MMC1_PBIAS and associated extended-drain MMC1 I/O cell. This is in accordance
with the control module programming guide. This fixes a bug where if trying to
use gpio_98 or gpio_99 and MMC1 at the same time the GPIO signal will be
affected by a changing SDMMC1_VDDS.
Software must keep MMC1_PBIAS cell and MMC1_IO cell PWRDNZ signals low whenever
SDMMC1_VDDS ramps up/down or changes for cell protection purposes.
MMC1 is based on SDMMC1_VDDS whereas USBC1 is based on SIM_VDDS therefore
they can operate independently.
Signed-off-by: Bryan Buckley <bryan.buckley@ti.com>
Acked-by: Kishore Kadiyala <kishore.kadiyala@ti.com>
Tested-by: Balaji T K <balajitk@ti.com>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6:
[S390] cio: fix cio_tpi ignoring adapter interrupts
[S390] gmap: always up mmap_sem properly
[S390] Do not clobber personality flags on exec
* git://github.com/davem330/sparc:
sparc64: Force the execute bit in OpenFirmware's translation entries.
sparc: Make '-p' boot option meaningful again.
sparc, exec: remove redundant addr_limit assignment
sparc64: Future proof Niagara cpu detection.
