commit 42a0cc3478584d4d63f68f2f5af021ddbea771fa upstream.
Holding uts_sem as a writer while accessing userspace memory allows a
namespace admin to stall all processes that attempt to take uts_sem.
Instead, move data through stack buffers and don't access userspace memory
while uts_sem is held.
Cc: stable@vger.kernel.org
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Jann Horn <jannh@google.com>
commit 9ba3eb5103cf56f0daaf07de4507df76e7813ed7 upstream.
commit ea93102f32244e3f45c8b26260be77ed0cc1d16c upstream.
The split of .system_keyring into .builtin_trusted_keys and
.secondary_trusted_keys broke kexec, thereby preventing kernels signed by
keys which are now in the secondary keyring from being kexec'd.
Fix this by passing VERIFY_USE_SECONDARY_KEYRING to
verify_pefile_signature().
Fixes: d3bfe84129f6 ("certs: Add a secondary system keyring that can be added to dynamically")
Signed-off-by: Yannik Sembritzki <yannik@sembritzki.me>
Cc: kexec@lists.infradead.org
Cc: keyrings@vger.kernel.org
Cc: linux-security-module@vger.kernel.org
Cc: stable@kernel.org
commit 6e1811900b6fe6f2b4665dba6bd6ed32c6b98575 upstream.
On all versions of Tegra30 Cardhu, the reset signal to the NXP PCA9546
I2C mux is connected to the Tegra GPIO BB0. Currently, this pin on the
Tegra is not configured as a GPIO but as a special-function IO (SFIO)
that is multiplexing the pin to an I2S controller. On exiting system
suspend, I2C commands sent to the PCA9546 are failing because there is
no ACK. Although it is not possible to see exactly what is happening
to the reset during suspend, by ensuring it is configured as a GPIO
and driven high, to de-assert the reset, the failures are no longer
seen.
Please note that this GPIO is also used to drive the reset signal
going to the camera connector on the board. However, given that there
is no camera support currently for Cardhu, this should not have any
impact.
Fixes: 40431d16ff11 ("ARM: tegra: enable PCA9546 on Cardhu")
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit fec3259c9f747c039f90e99570540114c8d81a14 upstream.
Cache invalidation macros use cache line size to iterate over
invalidated cache lines, assuming that all cache ways are invalidated by
single instruction, but xtensa ISA recommends to not assume that for
future compatibility:
In some implementations all ways at index Addry-1..z are invalidated
regardless of the specified way, but for future compatibility this
behavior should not be assumed.
Iterate over all cache ways in ___invalidate_icache_all and
___invalidate_dcache_all.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit be75de25251f7cf3e399ca1f584716a95510d24a upstream.
When building kernel for xtensa cores with big cache lines (e.g. 128
bytes or more) __loop_cache_all and __loop_cache_page may generate
assembly instructions with immediate fields that are too big. This
results in the following build errors:
arch/xtensa/mm/misc.S: Assembler messages:
arch/xtensa/mm/misc.S:464: Error: operand 2 of 'diwbi' has invalid value '256'
arch/xtensa/mm/misc.S:464: Error: operand 2 of 'diwbi' has invalid value '384'
arch/xtensa/kernel/head.S: Assembler messages:
arch/xtensa/kernel/head.S:172: Error: operand 2 of 'diu' has invalid value '256'
arch/xtensa/kernel/head.S:172: Error: operand 2 of 'diu' has invalid value '384'
arch/xtensa/kernel/head.S:176: Error: operand 2 of 'iiu' has invalid value '256'
arch/xtensa/kernel/head.S:176: Error: operand 2 of 'iiu' has invalid value '384'
arch/xtensa/kernel/head.S:255: Error: operand 2 of 'diwb' has invalid value '256'
arch/xtensa/kernel/head.S:255: Error: operand 2 of 'diwb' has invalid value '384'
Add parameter max_immed to these macros and use it to limit values of
immediate operands. Extract common code of these macros into the new
macro __loop_cache_unroll.
commit 0027ff2a75f9dcf0537ac0a65c5840b0e21a4950 upstream.
Two bug fixes:
1) missing entries in the l1d_param array; this can cause a host crash
if an access attempts to reach the missing entry. Future-proof the get
function against any overflows as well. However, the two entries
VMENTER_L1D_FLUSH_EPT_DISABLED and VMENTER_L1D_FLUSH_NOT_REQUIRED must
not be accepted by the parse function, so disable them there.
2) invalid values must be rejected even if the CPU does not have the
bug, so test for them before checking boot_cpu_has(X86_BUG_L1TF)
... and a small refactoring, since the .cmd field is redundant with
the index in the array.
Reported-by: Bandan Das <bsd@redhat.com>
Fixes: a7b9020b06ec6d7c3f3b0d4ef1a9eba12654f4f7
commit db2173198b9513f7add8009f225afa1f1c79bcc6 upstream.
The generic code is racy when multiple children of a PCI bridge try to
enable it simultaneously.
This leads to drivers trying to access a device through a
not-yet-enabled bridge, and this EEH errors under various
circumstances when using parallel driver probing.
There is work going on to fix that properly in the PCI core but it
will take some time.
x86 gets away with it because (outside of hotplug), the BIOS enables
all the bridges at boot time.
This patch does the same thing on powernv by enabling all bridges that
have child devices at boot time, thus avoiding subsequent races. It's
suitable for backporting to stable and distros, while the proper PCI
fix will probably be significantly more invasive.
commit cd813e1cd7122f2c261dce5b54d1e0c97f80e1a5 upstream.
During Machine Check interrupt on pseries platform, register r3 points
RTAS extended event log passed by hypervisor. Since hypervisor uses r3
to pass pointer to rtas log, it stores the original r3 value at the
start of the memory (first 8 bytes) pointed by r3. Since hypervisor
stores this info and rtas log is in BE format, linux should make
sure to restore r3 value in correct endian format.
Without this patch when MCE handler, after recovery, returns to code that
that caused the MCE may end up with Data SLB access interrupt for invalid
address followed by kernel panic or hang.
Severe Machine check interrupt [Recovered]
NIP [d00000000ca301b8]: init_module+0x1b8/0x338 [bork_kernel]
Initiator: CPU
Error type: SLB [Multihit]
Effective address: d00000000ca70000
cpu 0xa: Vector: 380 (Data SLB Access) at [c0000000fc7775b0]
pc: c0000000009694c0: vsnprintf+0x80/0x480
lr: c0000000009698e0: vscnprintf+0x20/0x60
sp: c0000000fc777830
msr: 8000000002009033
dar: a803a30c000000d0
current = 0xc00000000bc9ef00
paca = 0xc00000001eca5c00 softe: 3 irq_happened: 0x01
pid = 8860, comm = insmod
vprintk_emit+0xb4/0x4b0
vprintk_func+0x5c/0xd0
printk+0x38/0x4c
init_module+0x1c0/0x338 [bork_kernel]
do_one_initcall+0x54/0x230
do_init_module+0x8c/0x248
load_module+0x12b8/0x15b0
sys_finit_module+0xa8/0x110
system_call+0x58/0x6c
--- Exception: c00 (System Call) at 00007fff8bda0644
SP (7fffdfbfe980) is in userspace
This patch fixes this issue.
Fixes: a08a53ea4c97 ("powerpc/le: Enable RTAS events support")
Cc: stable@vger.kernel.org # v3.15+
Reviewed-by: Nicholas Piggin <npiggin@gmail.com>
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
commit 1bd6a1c4b80a28d975287630644e6b47d0f977a5 upstream.
Crash memory ranges is an array of memory ranges of the crashing kernel
to be exported as a dump via /proc/vmcore file. The size of the array
is set based on INIT_MEMBLOCK_REGIONS, which works alright in most cases
where memblock memory regions count is less than INIT_MEMBLOCK_REGIONS
value. But this count can grow beyond INIT_MEMBLOCK_REGIONS value since
commit 142b45a72e22 ("memblock: Add array resizing support").
On large memory systems with a few DLPAR operations, the memblock memory
regions count could be larger than INIT_MEMBLOCK_REGIONS value. On such
systems, registering fadump results in crash or other system failures
like below:
task: c00007f39a290010 ti: c00000000b738000 task.ti: c00000000b738000
NIP: c000000000047df4 LR: c0000000000f9e58 CTR: c00000000010f180
REGS: c00000000b73b570 TRAP: 0300 Tainted: G L X (4.4.140+)
MSR: 8000000000009033 <SF,EE,ME,IR,DR,RI,LE> CR: 22004484 XER: 20000000
CFAR: c000000000008500 DAR: 000007a450000000 DSISR: 40000000 SOFTE: 0
NIP [c000000000047df4] smp_send_reschedule+0x24/0x80
LR [c0000000000f9e58] resched_curr+0x138/0x160
Call Trace:
resched_curr+0x138/0x160 (unreliable)
check_preempt_curr+0xc8/0xf0
ttwu_do_wakeup+0x38/0x150
try_to_wake_up+0x224/0x4d0
__wake_up_common+0x94/0x100
ep_poll_callback+0xac/0x1c0
__wake_up_sync_key+0x70/0xa0
sock_def_readable+0x58/0xa0
unix_stream_sendmsg+0x2dc/0x4c0
sock_sendmsg+0x68/0xa0
___sys_sendmsg+0x2cc/0x2e0
__sys_sendmsg+0x5c/0xc0
SyS_socketcall+0x36c/0x3f0
system_call+0x3c/0x100
as array index overflow is not checked for while setting up crash memory
ranges causing memory corruption. To resolve this issue, dynamically
allocate memory for crash memory ranges and resize it incrementally,
in units of pagesize, on hitting array size limit.
Fixes: 2df173d9e85d ("fadump: Initialize elfcore header and add PT_LOAD program headers.")
Cc: stable@vger.kernel.org # v3.4+
Signed-off-by: Hari Bathini <hbathini@linux.ibm.com>
Reviewed-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
[mpe: Just use PAGE_SIZE directly, fixup variable placement]
commit 690d9163bf4b8563a2682e619f938e6a0443947f upstream.
Some versions of GCC suboptimally generate calls to the __multi3()
intrinsic for MIPS64r6 builds, resulting in link failures due to the
missing function:
LD vmlinux.o
MODPOST vmlinux.o
kernel/bpf/verifier.o: In function `kmalloc_array':
include/linux/slab.h:631: undefined reference to `__multi3'
fs/select.o: In function `kmalloc_array':
We already have a workaround for this in which we provide the
instrinsic, but we do so selectively for GCC 7 only. Unfortunately the
issue occurs with older GCC versions too - it has been observed with
both GCC 5.4.0 & GCC 6.4.0.
MIPSr6 support was introduced in GCC 5, so all major GCC versions prior
to GCC 8 are affected and we extend our workaround accordingly to all
MIPS64r6 builds using GCC versions older than GCC 8.
Signed-off-by: Paul Burton <paul.burton@mips.com>
Reported-by: Vladimir Kondratiev <vladimir.kondratiev@intel.com>
Fixes: ebabcf17bcd7 ("MIPS: Implement __multi3 for GCC7 MIPS64r6 builds")
Patchwork: https://patchwork.linux-mips.org/patch/20297/
Cc: James Hogan <jhogan@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: stable@vger.kernel.org # 4.15+
commit f5958b4cf4fc38ed4583ab83fb7c4cd1ab05f47b upstream.
Use the `unsigned long' rather than `__u32' type for DSP accumulator
registers, like with the regular MIPS multiply/divide accumulator and
general-purpose registers, as all are 64-bit in 64-bit implementations
and using a 32-bit data type leads to contents truncation on context
saving.
Update `arch_ptrace' and `compat_arch_ptrace' accordingly, removing
casts that are similarly not used with multiply/divide accumulator or
general-purpose register accesses.
Signed-off-by: Maciej W. Rozycki <macro@mips.com>
Fixes: e50c0a8fa60d ("Support the MIPS32 / MIPS64 DSP ASE.")
Patchwork: https://patchwork.linux-mips.org/patch/19329/
Cc: linux-fsdevel@vger.kernel.org
Cc: stable@vger.kernel.org # 2.6.15+
commit 866f3576a72b2233a76dffb80290f8086dc49e17 upstream.
During interrupt setup we allocate interrupt vectors, walk the list of msi
descriptors, and fill in the message data. Requesting more interrupts than
supported on s390 can lead to an out of bounds access.
When we restrict the number of interrupts we should also stop walking the
msi list after all supported interrupts are handled.
Signed-off-by: Sebastian Ott <sebott@linux.ibm.com>
commit fb7d7518b0d65955f91c7b875c36eae7694c69bd upstream.
The numa_init_early initcall sets the node_to_cpumask_map[0] to the
full cpu_possible_mask. Unfortunately this early_initcall is too late,
the NUMA setup for numa=emu is done even earlier. The order of calls
is numa_setup() -> emu_update_cpu_topology(), then the early_initcalls(),
followed by sched_init_domains().
Starting with git commit 051f3ca02e46432c0965e8948f00c07d8a2f09c0
"sched/topology: Introduce NUMA identity node sched domain"
the incorrect node_to_cpumask_map[0] really screws up the domain
setup and the kernel panics with the follow oops:
Cc: <stable@vger.kernel.org> # v4.15+
commit 64e03ff72623b8c2ea89ca3cb660094e019ed4ae upstream.
When allocating a new AOB fails, handle_outbound() is still capable of
transmitting the selected buffer (just without async completion).
But if a previous transfer on this queue slot used async completion, its
sbal_state flags field is still set to QDIO_OUTBUF_STATE_FLAG_PENDING.
So when the upper layer driver sees this stale flag, it expects an async
completion that never happens.
Fix this by unconditionally clearing the flags field.
Fixes: 104ea556ee7f ("qdio: support asynchronous delivery of storage blocks")
Cc: <stable@vger.kernel.org> #v3.2+
Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com>
commit 26f843848bae973817b3587780ce6b7b0200d3e4 upstream.
For machines without the exrl instruction the BFP jit generates
code that uses an "br %r1" instruction located in the lowcore page.
Unfortunately there is a cut & paste error that puts an additional
"larl %r1,.+14" instruction in the code that clobbers the branch
target address in %r1. Remove the larl instruction.
Cc: <stable@vger.kernel.org> # v4.17+
Fixes: de5cb6eb51 ("s390: use expoline thunks in the BPF JIT")
commit f12d11c5c184626b4befdee3d573ec8237405a33 upstream.
Reset the KASAN shadow state of the task stack before rewinding RSP.
Without this, a kernel oops will leave parts of the stack poisoned, and
code running under do_exit() can trip over such poisoned regions and cause
nonsensical false-positive KASAN reports about stack-out-of-bounds bugs.
This does not wipe the exception stacks; if an oops happens on an exception
stack, it might result in random KASAN false-positives from other tasks
afterwards. This is probably relatively uninteresting, since if the kernel
oopses on an exception stack, there are most likely bigger things to worry
about. It'd be more interesting if vmapped stacks and KASAN were
compatible, since then handle_stack_overflow() would oops from exception
stack context.
Fixes: 2deb4be28077 ("x86/dumpstack: When OOPSing, rewind the stack before do_exit()")
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: kasan-dev@googlegroups.com
Link: https://lkml.kernel.org/r/20180828184033.93712-1-jannh@google.com
commit cc51e5428ea54f575d49cfcede1d4cb3a72b4ec4 upstream.
On Nehalem and newer core CPUs the CPU cache internally uses 44 bits
physical address space. The L1TF workaround is limited by this internal
cache address width, and needs to have one bit free there for the
mitigation to work.
Older client systems report only 36bit physical address space so the range
check decides that L1TF is not mitigated for a 36bit phys/32GB system with
some memory holes.
But since these actually have the larger internal cache width this warning
is bogus because it would only really be needed if the system had more than
43bits of memory.
Add a new internal x86_cache_bits field. Normally it is the same as the
physical bits field reported by CPUID, but for Nehalem and newerforce it to
be at least 44bits.
Change the L1TF memory size warning to use the new cache_bits field to
avoid bogus warnings and remove the bogus comment about memory size.
Fixes: 17dbca119312 ("x86/speculation/l1tf: Add sysfs reporting for l1tf")
Reported-by: George Anchev <studio@anchev.net>
Reported-by: Christopher Snowhill <kode54@gmail.com>
Cc: x86@kernel.org
Cc: Michael Hocko <mhocko@suse.com>
Cc: vbabka@suse.cz
Link: https://lkml.kernel.org/r/20180824170351.34874-1-andi@firstfloor.org
commit 1ab534e85c93945f7862378d8c8adcf408205b19 upstream.
The check for Spectre microcodes does not check for family 6, only the
model numbers.
Add a family 6 check to avoid ambiguity with other families.
Fixes: a5b296636453 ("x86/cpufeature: Blacklist SPEC_CTRL/PRED_CMD on early Spectre v2 microcodes")
Cc: x86@kernel.org
Link: https://lkml.kernel.org/r/20180824170351.34874-2-andi@firstfloor.org
commit 1f59a4581b5ecfe9b4f049a7a2cf904d8352842d upstream.
This should have been marked extern inline in order to pick up the out
of line definition in arch/x86/kernel/irqflags.S.
Fixes: 208cbb325589 ("x86/irqflags: Provide a declaration for native_save_fl")
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: https://lkml.kernel.org/r/20180827214011.55428-1-ndesaulniers@google.com
commit 94d7a86c21a3d6046bf4616272313cb7d525075a upstream.
These are already defined higher up in the file.
Fixes: 7db92e165ac8 ("x86/kvm: Move l1tf setup function")
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/d7ca03ae210d07173452aeed85ffe344301219a5.1534253536.git.jpoimboe@redhat.com
commit 024d83cadc6b2af027e473720f3c3da97496c318 upstream.
Mikhail reported the following lockdep splat:
WARNING: possible irq lock inversion dependency detected
CPU 0/KVM/10284 just changed the state of lock:
000000000d538a88 (&st->lock){+...}, at:
speculative_store_bypass_update+0x10b/0x170
but this lock was taken by another, HARDIRQ-safe lock
in the past:
(&(&sighand->siglock)->rlock){-.-.}
and interrupts could create inverse lock ordering between them.
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(&st->lock);
local_irq_disable();
lock(&(&sighand->siglock)->rlock);
lock(&st->lock);
<Interrupt>
*** DEADLOCK ***
The code path which connects those locks is:
speculative_store_bypass_update()
ssb_prctl_set()
do_seccomp()
do_syscall_64()
In svm_vcpu_run() speculative_store_bypass_update() is called with
interupts enabled via x86_virt_spec_ctrl_set_guest/host().
This is actually a false positive, because GIF=0 so interrupts are
disabled even if IF=1; however, we can easily move the invocations of
x86_virt_spec_ctrl_set_guest/host() into the interrupt disabled region to
cure it, and it's a good idea to keep the GIF=0/IF=1 area as small
and self-contained as possible.
Fixes: 1f50ddb4f418 ("x86/speculation: Handle HT correctly on AMD")
Reported-by: Mikhail Gavrilov <mikhail.v.gavrilov@gmail.com>
Tested-by: Mikhail Gavrilov <mikhail.v.gavrilov@gmail.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: kvm@vger.kernel.org
Cc: x86@kernel.org
commit dc76803e57cc86589c4efcb5362918f9b0c0436f upstream.
The consolidation of the start_thread() functions removed the export
unintentionally. This breaks binfmt handlers built as a module.
Add it back.
Fixes: e634d8fc792c ("x86-64: merge the standard and compat start_thread() functions")
Signed-off-by: Rian Hunter <rian@alum.mit.edu>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Dmitry Safonov <dima@arista.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/20180819230854.7275-1-rian@alum.mit.edu
commit 6a012288d6906fee1dbc244050ade1dafe4a9c8d upstream.
Two users have reported [1] that they have an "extremely unlikely" system
with more than MAX_PA/2 memory and L1TF mitigation is not effective.
Make the warning more helpful by suggesting the proper mem=X kernel boot
parameter to make it effective and a link to the L1TF document to help
decide if the mitigation is worth the unusable RAM.
[1] https://bugzilla.suse.com/show_bug.cgi?id=1105536
Suggested-by: Michal Hocko <mhocko@suse.com>
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Cc: "H . Peter Anvin" <hpa@zytor.com>
Link: https://lkml.kernel.org/r/966571f0-9d7f-43dc-92c6-a10eec7a1254@suse.cz
much RAM
commit b0a182f875689647b014bc01d36b340217792852 upstream.
with more than MAX_PA/2 memory and L1TF mitigation is not effective. In
fact it's a CPU with 36bits phys limit (64GB) and 32GB memory, but due to
holes in the e820 map, the main region is almost 500MB over the 32GB limit:
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000081effffff] usable
Suggestions to use 'mem=32G' to enable the L1TF mitigation while losing the
500MB revealed, that there's an off-by-one error in the check in
l1tf_select_mitigation().
l1tf_pfn_limit() returns the last usable pfn (inclusive) and the range
check in the mitigation path does not take this into account.
Instead of amending the range check, make l1tf_pfn_limit() return the first
PFN which is over the limit which is less error prone. Adjust the other
users accordingly.
Cc: Michal Hocko <mhocko@kernel.org>
Link: https://lkml.kernel.org/r/20180823134418.17008-1-vbabka@suse.cz
commit 9df9516940a61d29aedf4d91b483ca6597e7d480 upstream.
On 32bit PAE kernels on 64bit hardware with enough physical bits,
l1tf_pfn_limit() will overflow unsigned long. This in turn affects
max_swapfile_size() and can lead to swapon returning -EINVAL. This has been
observed in a 32bit guest with 42 bits physical address size, where
max_swapfile_size() overflows exactly to 1 << 32, thus zero, and produces
the following warning to dmesg:
[ 6.396845] Truncating oversized swap area, only using 0k out of 2047996k
Fix this by using unsigned long long instead.
Fixes: 377eeaa8e11f ("x86/speculation/l1tf: Limit swap file size to MAX_PA/2")
Reported-by: Dominique Leuenberger <dimstar@suse.de>
Reported-by: Adrian Schroeter <adrian@suse.de>
Acked-by: Andi Kleen <ak@linux.intel.com>
Link: https://lkml.kernel.org/r/20180820095835.5298-1-vbabka@suse.cz
commit 2dc77533f1e495788d73ffa4bee4323b2646d2bb upstream.
When building the kernel for Sparc using gcc 7.x, the build fails
with:
arch/sparc/kernel/pcic.c: In function ‘pcibios_fixup_bus’:
arch/sparc/kernel/pcic.c:647:8: error: ‘cmd’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
cmd |= PCI_COMMAND_IO;
The simplified code looks like this:
unsigned int cmd;
pcic_read_config(dev->bus, dev->devfn, PCI_COMMAND, 2, &cmd);
I.e, the code assumes that pcic_read_config() will always initialize
cmd. But it's not the case. Looking at pcic_read_config(), if
bus->number is != 0 or if the size is not one of 1, 2 or 4, *val will
not be initialized.
As a simple fix, we initialize cmd to zero at the beginning of
pcibios_fixup_bus.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
commit 86658b819cd0a9aa584cd84453ed268a6f013770 upstream.
Contention on updating a PMD entry by a large number of vcpus can lead
to duplicate work when handling stage 2 page faults. As the page table
update follows the break-before-make requirement of the architecture,
it can lead to repeated refaults due to clearing the entry and
flushing the tlbs.
This problem is more likely when -
* there are large number of vcpus
* the mapping is large block mapping
such as when using PMD hugepages (512MB) with 64k pages.
Fix this by skipping the page table update if there is no change in
the entry being updated.
Fixes: ad361f093c1e ("KVM: ARM: Support hugetlbfs backed huge pages")
Reviewed-by: Suzuki Poulose <suzuki.poulose@arm.com>
Acked-by: Christoffer Dall <christoffer.dall@arm.com>
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
commit 976d34e2dab10ece5ea8fe7090b7692913f89084 upstream.
When there is contention on faulting in a particular page table entry
at stage 2, the break-before-make requirement of the architecture can
lead to additional refaulting due to TLB invalidation.
Avoid this by skipping a page table update if the new value of the PTE
matches the previous value.
Fixes: d5d8184d35c9 ("KVM: ARM: Memory virtualization setup")
commit 306d6c49ac9ded11114cb53b0925da52f2c2ada1 upstream.
When the oom killer kills a userspace process in the page fault handler
while in guest context, the fault handler fails to release the mm_sem
if the FAULT_FLAG_RETRY_NOWAIT option is set. This leads to a deadlock
when tearing down the mm when the process terminates. This bug can only
happen when pfault is enabled, so only KVM clients are affected.
The problem arises in the rare cases in which handle_mm_fault does not
release the mm_sem. This patch fixes the issue by manually releasing
the mm_sem when needed.
Fixes: 24eb3a824c4f3 ("KVM: s390: Add FAULT_FLAG_RETRY_NOWAIT for guest fault")
Cc: <stable@vger.kernel.org> # 3.15+
Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
commit 5ad356eabc47d26a92140a0c4b20eba471c10de3 upstream.
ARM64's pfn_valid() shifts away the upper PAGE_SHIFT bits of the input
before seeing if the PFN is valid. This leads to false positives when
some of the upper bits are set, but the lower bits match a valid PFN.
For example, the following userspace code looks up a bogus entry in
/proc/kpageflags:
int pagemap = open("/proc/self/pagemap", O_RDONLY);
int pageflags = open("/proc/kpageflags", O_RDONLY);
uint64_t pfn, val;
lseek64(pagemap, [...], SEEK_SET);
read(pagemap, &pfn, sizeof(pfn));
if (pfn & (1UL << 63)) { /* valid PFN */
pfn &= ((1UL << 55) - 1); /* clear flag bits */
pfn |= (1UL << 55);
lseek64(pageflags, pfn * sizeof(uint64_t), SEEK_SET);
read(pageflags, &val, sizeof(val));
On ARM64 this causes the userspace process to crash with SIGSEGV rather
than reading (1 << KPF_NOPAGE). kpageflags_read() treats the offset as
valid, and stable_page_flags() will try to access an address between the
user and kernel address ranges.
Fixes: c1cc1552616d ("arm64: MMU initialisation")
Signed-off-by: Greg Hackmann <ghackmann@google.com>
commit 0722867dcbc28cc9b269b57acd847c7c1aa638d6 upstream.
Fix %p uses in error messages by removing it because
those are redundant or meaningless.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Jon Medhurst <tixy@linaro.org>
Cc: Thomas Richter <tmricht@linux.ibm.com>
Cc: Tobin C . Harding <me@tobin.cc>
Cc: acme@kernel.org
Cc: akpm@linux-foundation.org
Cc: brueckner@linux.vnet.ibm.com
Cc: rostedt@goodmis.org
Cc: schwidefsky@de.ibm.com
Link: https://lkml.kernel.org/lkml/152491908405.9916.12425053035317241111.stgit@devbox
[ Upstream commit ec837d620c750c0d4996a907c8c4f7febe1bbeee ]
Fix type warnings in arch/arc/mm/cache.c.
../arch/arc/mm/cache.c: In function 'flush_anon_page':
../arch/arc/mm/cache.c:1062:55: warning: passing argument 2 of '__flush_dcache_page' makes integer from pointer without a cast [-Wint-conversion]
__flush_dcache_page((phys_addr_t)page_address(page), page_address(page));
../arch/arc/mm/cache.c:1013:59: note: expected 'long unsigned int' but argument is of type 'void *'
void __flush_dcache_page(phys_addr_t paddr, unsigned long vaddr)
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: Elad Kanfi <eladkan@mellanox.com>
Cc: Leon Romanovsky <leonro@mellanox.com>
Cc: Ofer Levi <oferle@mellanox.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
[ Upstream commit 2423665ec53f2a29191b35382075e9834288a975 ]
Fix build errors in arch/arc/'s delay.h:
- add "extern unsigned long loops_per_jiffy;"
- add <asm-generic/types.h> for "u64"
In file included from ../drivers/infiniband/hw/cxgb3/cxio_hal.c:32:
../arch/arc/include/asm/delay.h: In function '__udelay':
../arch/arc/include/asm/delay.h:61:12: error: 'u64' undeclared (first use in this function)
loops = ((u64) usecs * 4295 * HZ * loops_per_jiffy) >> 32;
../arch/arc/include/asm/delay.h:63:37: error: 'loops_per_jiffy' undeclared (first use in this function)
[ Upstream commit b1f32ce1c3d2c11959b7e6a2c58dc5197c581966 ]
Add <linux/types.h> to fix build errors.
Both ctop.h and <soc/nps/common.h> use u32 types and cause many
errors.
Examples:
../include/soc/nps/common.h:71:4: error: unknown type name 'u32'
u32 __reserved:20, cluster:4, core:4, thread:4;
../include/soc/nps/common.h:76:3: error: unknown type name 'u32'
u32 value;
../include/soc/nps/common.h:124:4: error: unknown type name 'u32'
u32 base:8, cl_x:4, cl_y:4,
../include/soc/nps/common.h:127:3: error: unknown type name 'u32'
u32 value;
../arch/arc/plat-eznps/include/plat/ctop.h:83:4: error: unknown type name 'u32'
u32 gen:1, gdis:1, clk_gate_dis:1, asb:1,
../arch/arc/plat-eznps/include/plat/ctop.h:86:3: error: unknown type name 'u32'
u32 value;
../arch/arc/plat-eznps/include/plat/ctop.h:93:4: error: unknown type name 'u32'
u32 csa:22, dmsid:6, __reserved:3, cs:1;
../arch/arc/plat-eznps/include/plat/ctop.h:95:3: error: unknown type name 'u32'
u32 value;
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
[ Upstream commit d5ea019f8a381f88545bb26993b62ec24a2796b7 ]
This reverts commit 2a027b47dba6 ("MIPS: BCM47XX: Enable 74K Core
ExternalSync for PCIe erratum").
Enabling ExternalSync caused a regression for BCM4718A1 (used e.g. in
Netgear E3000 and ASUS RT-N16): it simply hangs during PCIe
initialization. It's likely that BCM4717A1 is also affected.
I didn't notice that earlier as the only BCM47XX devices with PCIe I
own are:
1) BCM4706 with 2 x 14e4:4331
2) BCM4706 with 14e4:4360 and 14e4:4331
it appears that BCM4706 is unaffected.
While BCM5300X-ES300-RDS.pdf seems to document that erratum and its
workarounds (according to quotes provided by Tokunori) it seems not even
Broadcom follows them.
According to the provided info Broadcom should define CONF7_ES in their
SDK's mipsinc.h and implement workaround in the si_mips_init(). Checking
both didn't reveal such code. It *could* mean Broadcom also had some
problems with the given workaround.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Reported-by: Michael Marley <michael@michaelmarley.com>
Patchwork: https://patchwork.linux-mips.org/patch/20032/
URL: https://bugs.openwrt.org/index.php?do=details&task_id=1688
Cc: Tokunori Ikegami <ikegami@allied-telesis.co.jp>
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Cc: Chris Packham <chris.packham@alliedtelesis.co.nz>
[ Upstream commit 92a4728608a8fd228c572bc8ff50dd98aa0ddf2a ]
Dirk Gouders reported that two consecutive "make" invocations on an
already compiled tree will show alternating behaviors:
$ make
CALL scripts/checksyscalls.sh
DESCEND objtool
CHK include/generated/compile.h
DATAREL arch/x86/boot/compressed/vmlinux
Kernel: arch/x86/boot/bzImage is ready (#48)
Building modules, stage 2.
MODPOST 165 modules
$ make
DESCEND objtool
LD arch/x86/boot/compressed/vmlinux
ZOFFSET arch/x86/boot/zoffset.h
AS arch/x86/boot/header.o
LD arch/x86/boot/setup.elf
OBJCOPY arch/x86/boot/setup.bin
OBJCOPY arch/x86/boot/vmlinux.bin
BUILD arch/x86/boot/bzImage
Setup is 15644 bytes (padded to 15872 bytes).
System is 6663 kB
CRC 3eb90f40
MODPOST 165 modules
He bisected it back to:
commit 98f78525371b ("x86/boot: Refuse to build with data relocations")
The root cause was the use of the "if_changed" kbuild function multiple
times for the same target. It was designed to only be used once per
target, otherwise it will effectively always trigger, flipping back and
forth between the two commands getting recorded by "if_changed". Instead,
this patch merges the two commands into a single function to get stable
build artifacts (i.e. .vmlinux.cmd), and a single build behavior.
Bisected-and-Reported-by: Dirk Gouders <dirk@gouders.net>
Fix-Suggested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Link: http://lkml.kernel.org/r/20180724230827.GA37823@beast
[ Upstream commit d2753e6b4882a637a0e8fb3b9c2e15f33265300e ]
Paul Menzel reported the following bug:
> Enabling the undefined behavior sanitizer and building GNU/Linux 4.18-rc5+
> (with some unrelated commits) with GCC 8.1.0 from Debian Sid/unstable, the
> warning below is shown.
> > [ 2.111913]
> > [ 2.111917] UBSAN: Undefined behaviour in arch/x86/events/amd/ibs.c:582:24
> > [ 2.111919] member access within null pointer of type 'struct perf_event'
> > [ 2.111926] CPU: 0 PID: 144 Comm: udevadm Not tainted 4.18.0-rc5-00316-g4864b68cedf2 #104
> > [ 2.111928] Hardware name: ASROCK E350M1/E350M1, BIOS TIMELESS 01/01/1970
> > [ 2.111930] Call Trace:
> > [ 2.111943] dump_stack+0x55/0x89
> > [ 2.111949] ubsan_epilogue+0xb/0x33
> > [ 2.111953] handle_null_ptr_deref+0x7f/0x90
> > [ 2.111958] __ubsan_handle_type_mismatch_v1+0x55/0x60
> > [ 2.111964] perf_ibs_handle_irq+0x596/0x620
The code dereferences event before checking the STARTED bit. Patch
below should cure the issue.
The warning should not trigger, if I analyzed the thing correctly.
(And Paul's testing confirms this.)
Reported-by: Paul Menzel <pmenzel@molgen.mpg.de>
Tested-by: Paul Menzel <pmenzel@molgen.mpg.de>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Paul Menzel <pmenzel+linux-x86@molgen.mpg.de>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/alpine.DEB.2.21.1807200958390.1580@nanos.tec.linutronix.de
[ Upstream commit b9c1e60e7bf4e64ac1b4f4d6d593f0bb57886973 ]
None of the JITs is allowed to implement exit paths from the BPF
insn mappings other than BPF_JMP | BPF_EXIT. In the BPF core code
we have a couple of rewrites in eBPF (e.g. LD_ABS / LD_IND) and
in eBPF to cBPF translation to retain old existing behavior where
exceptions may occur; they are also tightly controlled by the
verifier where it disallows some of the features such as BPF to
BPF calls when legacy LD_ABS / LD_IND ops are present in the BPF
program. During recent review of all BPF_XADD JIT implementations
I noticed that the ppc64 one is buggy in that it contains two
jumps to exit paths. This is problematic as this can bypass verifier
expectations e.g. pointed out in commit f6b1b3bf0d5f ("bpf: fix
subprog verifier bypass by div/mod by 0 exception"). The first
exit path is obsoleted by the fix in ca36960211eb ("bpf: allow xadd
only on aligned memory") anyway, and for the second one we need to
do a fetch, add and store loop if the reservation from lwarx/ldarx
was lost in the meantime.
Fixes: 156d0e290e96 ("powerpc/ebpf/jit: Implement JIT compiler for extended BPF")
Reviewed-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Reviewed-by: Sandipan Das <sandipan@linux.vnet.ibm.com>
Tested-by: Sandipan Das <sandipan@linux.vnet.ibm.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
commit 3b885ac1dc35b87a39ee176a6c7e2af9c789d8b8 upstream.
Now that mb() is an instruction barrier, it will slow performance if we issue
unnecessary barriers.
The spinlock defines have a number of unnecessary barriers. The __ldcw()
define is both a hardware and compiler barrier. The mb() barriers in the
routines using __ldcw() serve no purpose.
The only barrier needed is the one in arch_spin_unlock(). We need to ensure
all accesses are complete prior to releasing the lock.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # 4.0+
Signed-off-by: Helge Deller <deller@gmx.de>
commit 7797167ffde1f00446301cb22b37b7c03194cfaf upstream.
Now that we use a sync prior to releasing the locks in syscall.S, we don't need
the PA 2.0 ordered stores used to release some locks. Using an ordered store,
potentially slows the release and subsequent code.
There are a number of other ordered stores and loads that serve no purpose. I
have converted these to normal stores.
[ Upstream commit 923847413f7316b5ced3491769b3fefa6c56a79a ]
The AM3517 has a different OTG controller location than the OMAP3,
which is included from omap3.dtsi. This results in a hwmod error.
Since the AM3517 has a different OTG controller address, this patch
disabes one that is isn't available.
[ Upstream commit 2f8b5b21830aea95989a6e67d8a971297272a086 ]
Call secure services to enable ACTLR[0] (Enable invalidates of BTB with
ICIALLU) when branch hardening is enabled for kernel.
On GP devices OMAP5/DRA7, there is no possibility to update secure
side since "secure world" is ROM and there are no override mechanisms
possible. On HS devices, appropriate PPA should do the workarounds as
well.
However, the configuration is only done for secondary core, since it is
expected that firmware/bootloader will have enabled the required
configuration for the primary boot core (note: bootloaders typically
will NOT enable secondary processors, since it has no need to do so).
Signed-off-by: Nishanth Menon <nm@ti.com>
[ Upstream commit b4c7e2bd2eb4764afe3af9409ff3b1b87116fa30 ]
Dynamic ftrace requires modifying the code segments that are usually
set to read-only. To do this, a per arch function is called both before
and after the ftrace modifications are performed. The "before" function
will set kernel code text to read-write to allow for ftrace to make the
modifications, and the "after" function will set the kernel code text
back to "read-only" to keep the kernel code text protected.
The issue happens when dynamic ftrace is tested at boot up. The test is
done before the kernel code text has been set to read-only. But the
"before" and "after" calls are still performed. The "after" call will
change the kernel code text to read-only prematurely, and other boot
code that expects this code to be read-write will fail.
The solution is to add a variable that is set when the kernel code text
is expected to be converted to read-only, and make the ftrace "before"
and "after" calls do nothing if that variable is not yet set. This is
similar to the x86 solution from commit 162396309745 ("ftrace, x86:
make kernel text writable only for conversions").
Link: http://lkml.kernel.org/r/20180620212906.24b7b66e@vmware.local.home
Reported-by: Stefan Agner <stefan@agner.ch>
Tested-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit e8708786d4fe21c043d38d760f768949a3d71185 ]
This is used in configs lacking hardware atomics to emulate atomic r-m-w
for user space, implemented by disabling preemption in kernel.
However there are issues in current implementation:
1. Process not terminated if invalid user pointer passed:
i.e. __get_user() failed.
2. The reason for this patch was __put_user() failure not being handled
either, specifically for the COW break scenario.
The zero page is initially wired up and read from __get_user()
succeeds. A subsequent write by __put_user() induces a
Protection Violation, but COW can't finish as Linux page fault
handler is disabled due to preempt disable.
And what's worse is we silently return the stale value to user space.
Fix this specific case by re-enabling preemption and explicitly
fixing up the fault and retrying the whole sequence over.
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
[vgupta: rewrote the changelog]
[ Upstream commit 0c1049dcb4ceec640d8bd797335bcbebdcab44d2 ]
PXA3xx platforms have 56 interrupts that are stored in two ICMR
registers. The code in pxa_irq_suspend() and pxa_irq_resume() however
does a simple division by 32 which only leads to one register being
saved at suspend and restored at resume time. The NAND interrupt
setting, for instance, is lost.
Fix this by using DIV_ROUND_UP() instead.
Signed-off-by: Daniel Mack <daniel@zonque.org>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
[ Upstream commit 2ceb2780b790b74bc408a949f6aedbad8afa693e ]
Select CONFIG_USB_CHIPIDEA_ULPI and CONFIG_USB_ULPI_BUS so that
USB ULPI can be functional on some boards like that use ULPI
interface.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
[ Upstream commit 157bcc06094c3c5800d3f4676527047b79b618e7 ]
USB ULPI can be functional on some boards like imx51-babbge.
This fixes a kernel hang in 4.18-rc1 on i.mx51-babbage, caused by commit
03e6275ae381 ("usb: chipidea: Fix ULPI on imx51").
Suggested-by: Andrey Smirnov <andrew.smirnov@gmail.com>
[ Upstream commit ecd60532e060e45c63c57ecf1c8549b1d656d34d ]
Booting a ColdFire m68k core with MMU enabled causes a "bad page state"
oops since commit 1d40a5ea01d5 ("mm: mark pages in use for page tables"):
BUG: Bad page state in process sh pfn:01ce2
page:004fefc8 count:0 mapcount:-1024 mapping:00000000 index:0x0
flags: 0x0()
raw: 00000000 00000000 00000000 fffffbff 00000000 00000100 00000200 00000000
raw: 039c4000
page dumped because: nonzero mapcount
Modules linked in:
CPU: 0 PID: 22 Comm: sh Not tainted 4.17.0-07461-g1d40a5ea01d5 #13
Fix by calling pgtable_page_dtor() in our __pte_free_tlb() code path,
so that the PG_table flag is cleared before we free the pte page.
Note that I had to change the type of pte_free() to be static from
extern. Otherwise you get a lot of warnings like this:
./arch/m68k/include/asm/mcf_pgalloc.h:80:2: warning: ‘pgtable_page_dtor’ is static but used in inline function ‘pte_free’ which is not static
pgtable_page_dtor(page);
And making it static is consistent with our use of this in the other
m68k pgalloc definitions of pte_free().
Signed-off-by: Greg Ungerer <gerg@linux-m68k.org>
CC: Matthew Wilcox <willy@infradead.org>
Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org>
[ Upstream commit f605ce5eb26ac934fb8106d75d46a2c875a2bf23 ]
If we would ever fail in the bpf_jit_prog() pass that writes the
actual insns to the image after we got header via bpf_jit_binary_alloc()
then we also need to make sure to free it through bpf_jit_binary_free()
again when bailing out. Given we had prior bpf_jit_prog() passes to
initially probe for clobbered registers, program size and to fill in
addrs arrray for jump targets, this is more of a theoretical one,
but at least make sure this doesn't break with future changes.
Fixes: 054623105728 ("s390/bpf: Add s390x eBPF JIT compiler backend")
Acked-by: Alexei Starovoitov <ast@kernel.org>
