path: root/arch
2013-12-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Much smaller batch of fixes this week. Biggest one is a revert of an OMAP display change that removed some non-DT pinmux code that was still needed for 3.13 to get DSI displays to work. There's also a fix that resolves some misdescribed GPIO controller resources on shmobile. The rest are mostly smaller fixes, a couple of MAINTAINERS updates, etc" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: Revert "ARM: OMAP2+: Remove legacy mux code for display.c" MAINTAINERS: Add keystone clock drivers MAINTAINERS: Add keystone git tree information ARM: s3c64xx: dt: Fix boot failure due to double clock initialization ARM: shmobile: r8a7790: Fix GPIO resources in DTS irqchip: renesas-intc-irqpin: Fix register bitfield shift calculation ARM: shmobile: lager: phy fixup needs CONFIG_PHYLIB
2013-12-20Merge tag 'arc-fixes-for-3.13-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fix from Vineet Gupta: "Fix busted syscall table due to unistd header inclusion issue" * tag 'arc-fixes-for-3.13-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: Allow conditional multiple inclusion of uapi/asm/unistd.h
2013-12-20Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 ptrace fix from Catalin Marinas. * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: ptrace: avoid using HW_BREAKPOINT_EMPTY for disabled events
2013-12-20Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "The PPC folks had a large amount of changes queued for 3.13, and now they are fixing the bugs" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: PPC: Book3S HV: Don't drop low-order page address bits powerpc: book3s: kvm: Don't abuse host r2 in exit path powerpc/kvm/booke: Fix build break due to stack frame size warning KVM: PPC: Book3S: PR: Enable interrupts earlier KVM: PPC: Book3S: PR: Make svcpu -> vcpu store preempt savvy KVM: PPC: Book3S: PR: Export kvmppc_copy_to|from_svcpu KVM: PPC: Book3S: PR: Don't clobber our exit handler id powerpc: kvm: fix rare but potential deadlock scene KVM: PPC: Book3S HV: Take SRCU read lock around kvm_read_guest() call KVM: PPC: Book3S HV: Make tbacct_lock irq-safe KVM: PPC: Book3S HV: Refine barriers in guest entry/exit KVM: PPC: Book3S HV: Fix physical address calculations
2013-12-20Merge tag 'renesas-fixes-for-v3.13' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes From Simon Horman: Renesas ARM based SoC fixes for v3.13 * r8a7790 (R-Car H1) SoC - Correct GPIO resources in DT. This problem has been present since GPIOs were added to the r8a7790 SoC by f98e10c88aa95bf7 ("ARM: shmobile: r8a7790: Add GPIO controller devices to device tree") in v3.12-rc1. * irqchip renesas-intc-irqpin - Correct register bitfield shift calculation This bug has been present since the renesas-intc-irqpin driver was introduced by 443580486e3b9657 ("irqchip: Renesas INTC External IRQ pin driver") in v3.10-rc1 * Lager board - Do not build the phy fixup unless CONFIG_PHYLIB is enabled This problem was introduced by 48c8b96f21817aad * tag 'renesas-fixes-for-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: r8a7790: Fix GPIO resources in DTS irqchip: renesas-intc-irqpin: Fix register bitfield shift calculation ARM: shmobile: lager: phy fixup needs CONFIG_PHYLIB Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-12-20Merge tag 'signed-for-3.13' of git://github.com/agraf/linux-2.6 into kvm-masterPaolo Bonzini
Patch queue for 3.13 - 2013-12-18 This fixes some grave issues we've only found after 3.13-rc1: - Make the modularized HV/PR book3s kvm work well as modules - Fix some race conditions - Fix compilation with certain compilers (booke) - Fix THP for book3s_hv - Fix preemption for book3s_pr Alexander Graf (4): KVM: PPC: Book3S: PR: Don't clobber our exit handler id KVM: PPC: Book3S: PR: Export kvmppc_copy_to|from_svcpu KVM: PPC: Book3S: PR: Make svcpu -> vcpu store preempt savvy KVM: PPC: Book3S: PR: Enable interrupts earlier Aneesh Kumar K.V (1): powerpc: book3s: kvm: Don't abuse host r2 in exit path Paul Mackerras (5): KVM: PPC: Book3S HV: Fix physical address calculations KVM: PPC: Book3S HV: Refine barriers in guest entry/exit KVM: PPC: Book3S HV: Make tbacct_lock irq-safe KVM: PPC: Book3S HV: Take SRCU read lock around kvm_read_guest() call KVM: PPC: Book3S HV: Don't drop low-order page address bits Scott Wood (1): powerpc/kvm/booke: Fix build break due to stack frame size warning pingfan liu (1): powerpc: kvm: fix rare but potential deadlock scene
2013-12-20Merge tag 'stable/for-linus-3.13-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: - Fix balloon driver for auto-translate guests (PVHVM, ARM) to not use scratch pages. - Fix block API header for ARM32 and ARM64 to have proper layout - On ARM when mapping guests, stick on PTE_SPECIAL - When using SWIOTLB under ARM, don't call swiotlb functions twice - When unmapping guests memory and if we fail, don't return pages which failed to be unmapped. - Grant driver was using the wrong address on ARM. * tag 'stable/for-linus-3.13-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/balloon: Seperate the auto-translate logic properly (v2) xen/block: Correctly define structures in public headers on ARM32 and ARM64 arm: xen: foreign mapping PTEs are special. xen/arm64: do not call the swiotlb functions twice xen: privcmd: do not return pages which we have failed to unmap XEN: Grant table address, xen_hvm_resume_frames, is a phys_addr not a pfn
2013-12-20Merge tag 'omap-for-v3.13/display-fix' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes I accidentally removed some mux code for omap4 that I thought was dead code as omap4 has been booting with device tree only since v3.10. Turns out I also removed some display related mux code, so let's revert that except for the dead code parts. * tag 'omap-for-v3.13/display-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (439 commits) Revert "ARM: OMAP2+: Remove legacy mux code for display.c" +Linux 3.13-rc4
2013-12-19arm64: ptrace: avoid using HW_BREAKPOINT_EMPTY for disabled eventsWill Deacon
Commit 8f34a1da35ae ("arm64: ptrace: use HW_BREAKPOINT_EMPTY type for disabled breakpoints") fixed an issue with GDB trying to zero breakpoint control registers. The problem there is that the arch hw_breakpoint code will attempt to create a (disabled), execute breakpoint of length 0. This will fail validation and report unexpected failure to GDB. To avoid this, we treated disabled breakpoints as HW_BREAKPOINT_EMPTY, but that seems to have broken with recent kernels, causing watchpoints to be treated as TYPE_INST in the core code and returning ENOSPC for any further breakpoints. This patch fixes the problem by prioritising the `enable' field of the breakpoint: if it is cleared, we simply update the perf_event_attr to indicate that the thing is disabled and don't bother changing either the type or the length. This reinforces the behaviour that the breakpoint control register is essentially read-only apart from the enable bit when disabling a breakpoint. Cc: <stable@vger.kernel.org> Reported-by: Aaron Liu <liucy214@gmail.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-12-19ARC: Allow conditional multiple inclusion of uapi/asm/unistd.hVineet Gupta
Commit 97bc386fc12d "ARC: Add guard macro to uapi/asm/unistd.h" inhibited multiple inclusion of ARCH unistd.h. This however hosed the system since Generic syscall table generator relies on it being included twice, and in lack-of an empty table was emitted by C preprocessor. Fix that by allowing one exception to rule for the special case (just like Xtensa) Suggested-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-12-18sh: always link in helper functions extracted from libgccGeert Uytterhoeven
E.g. landisk_defconfig, which has CONFIG_NTFS_FS=m: ERROR: "__ashrdi3" [fs/ntfs/ntfs.ko] undefined! For "lib-y", if no symbols in a compilation unit are referenced by other units, the compilation unit will not be included in vmlinux. This breaks modules that do reference those symbols. Use "obj-y" instead to fix this. http://kisskb.ellerman.id.au/kisskb/buildresult/8838077/ This doesn't fix all cases. There are others, e.g. udivsi3. This is also not limited to sh, many architectures handle this in the same way. A simple solution is to unconditionally include all helper functions. A more complex solution is to make the choice of "lib-y" or "obj-y" depend on CONFIG_MODULES: obj-$(CONFIG_MODULES) += ... lib-y($CONFIG_MODULES) += ... Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Paul Mundt <lethal@linux-sh.org> Tested-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Reviewed-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: fix TLB flush race between migration, and change_protection_rangeRik van Riel
There are a few subtle races, between change_protection_range (used by mprotect and change_prot_numa) on one side, and NUMA page migration and compaction on the other side. The basic race is that there is a time window between when the PTE gets made non-present (PROT_NONE or NUMA), and the TLB is flushed. During that time, a CPU may continue writing to the page. This is fine most of the time, however compaction or the NUMA migration code may come in, and migrate the page away. When that happens, the CPU may continue writing, through the cached translation, to what is no longer the current memory location of the process. This only affects x86, which has a somewhat optimistic pte_accessible. All other architectures appear to be safe, and will either always flush, or flush whenever there is a valid mapping, even with no permissions (SPARC). The basic race looks like this: CPU A CPU B CPU C load TLB entry make entry PTE/PMD_NUMA fault on entry read/write old page start migrating page change PTE/PMD to new page read/write old page [*] flush TLB reload TLB from new entry read/write new page lose data [*] the old page may belong to a new user at this point! The obvious fix is to flush remote TLB entries, by making sure that pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may still be accessible if there is a TLB flush pending for the mm. This should fix both NUMA migration and compaction. [mgorman@suse.de: fix build] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: serialise parallel get_user_page against THP migrationMel Gorman
Base pages are unmapped and flushed from cache and TLB during normal page migration and replaced with a migration entry that causes any parallel NUMA hinting fault or gup to block until migration completes. THP does not unmap pages due to a lack of support for migration entries at a PMD level. This allows races with get_user_pages and get_user_pages_fast which commit 3f926ab945b6 ("mm: Close races between THP migration and PMD numa clearing") made worse by introducing a pmd_clear_flush(). This patch forces get_user_page (fast and normal) on a pmd_numa page to go through the slow get_user_page path where it will serialise against THP migration and properly account for the NUMA hinting fault. On the migration side the page table lock is taken for each PTE update. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18KVM: PPC: Book3S HV: Don't drop low-order page address bitsPaul Mackerras
Commit caaa4c804fae ("KVM: PPC: Book3S HV: Fix physical address calculations") unfortunately resulted in some low-order address bits getting dropped in the case where the guest is creating a 4k HPTE and the host page size is 64k. By getting the low-order bits from hva rather than gpa we miss out on bits 12 - 15 in this case, since hva is at page granularity. This puts the missing bits back in. Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-12-18powerpc: book3s: kvm: Don't abuse host r2 in exit pathAneesh Kumar K.V
We don't use PACATOC for PR. Avoid updating HOST_R2 with PR KVM mode when both HV and PR are enabled in the kernel. Without this we get the below crash (qemu) Unable to handle kernel paging request for data at address 0xffffffffffff8310 Faulting instruction address: 0xc00000000001d5a4 cpu 0x2: Vector: 300 (Data Access) at [c0000001dc53aef0] pc: c00000000001d5a4: .vtime_delta.isra.1+0x34/0x1d0 lr: c00000000001d760: .vtime_account_system+0x20/0x60 sp: c0000001dc53b170 msr: 8000000000009032 dar: ffffffffffff8310 dsisr: 40000000 current = 0xc0000001d76c62d0 paca = 0xc00000000fef1100 softe: 0 irq_happened: 0x01 pid = 4472, comm = qemu-system-ppc enter ? for help [c0000001dc53b200] c00000000001d760 .vtime_account_system+0x20/0x60 [c0000001dc53b290] c00000000008d050 .kvmppc_handle_exit_pr+0x60/0xa50 [c0000001dc53b340] c00000000008f51c kvm_start_lightweight+0xb4/0xc4 [c0000001dc53b510] c00000000008cdf0 .kvmppc_vcpu_run_pr+0x150/0x2e0 [c0000001dc53b9e0] c00000000008341c .kvmppc_vcpu_run+0x2c/0x40 [c0000001dc53ba50] c000000000080af4 .kvm_arch_vcpu_ioctl_run+0x54/0x1b0 [c0000001dc53bae0] c00000000007b4c8 .kvm_vcpu_ioctl+0x478/0x730 [c0000001dc53bca0] c0000000002140cc .do_vfs_ioctl+0x4ac/0x770 [c0000001dc53bd80] c0000000002143e8 .SyS_ioctl+0x58/0xb0 [c0000001dc53be30] c000000000009e58 syscall_exit+0x0/0x98 Signed-off-by: Alexander Graf <agraf@suse.de>
2013-12-17Revert "ARM: OMAP2+: Remove legacy mux code for display.c"Tomi Valkeinen
Commit e30b06f4d5f000c31a7747a7e7ada78a5fd419a1 (ARM: OMAP2+: Remove legacy mux code for display.c) removed non-DT DSI and HDMI pinmuxing. However, DSI pinmuxing is still needed, and removing that caused DSI displays not to work. This reverts the DSI parts of the commit. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-12-17Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Three fixes for scheduler crashes, each triggers in relatively rare, hardware environment dependent situations" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/fair: Rework sched_fair time accounting math64: Add mul_u64_u32_shr() sched: Remove PREEMPT_NEED_RESCHED from generic code sched: Initialize power_orig for overlapping groups
2013-12-17Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fix from Ingo Molnar: "An x86/intel event constraint fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Fix constraint table end marker bug
2013-12-17Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes from Ben Herrenschmidt: "Uli's patch fixes a regression in ptrace caused by a mis-merge of a previous LE patch. The rest are all more endian fixes, all fairly trivial, found during testing of 3.13-rc's" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/powernv: Fix OPAL LPC access in Little Endian powerpc/powernv: Fix endian issue in opal_xscom_read powerpc: Fix endian issues in crash dump code powerpc/pseries: Fix endian issues in MSI code powerpc/pseries: Fix PCIE link speed endian issue powerpc/pseries: Fix endian issues in nvram code powerpc/pseries: Fix endian issues in /proc/ppc64/lparcfg powerpc: Fix topology core_id endian issue on LE builds powerpc: Fix endian issue in setup-common.c powerpc: PTRACE_PEEKUSR always returns FPR0
2013-12-15Merge branch 'x86/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "This is a pretty small batch: The biggest single change is to stop using EFI time services on 32-bit platforms. This matches our current behavior on 64-bit platforms as we already had ruled them out there as being too unreliable. Turns out that affects 32-bit platforms, too. One NULL pointer fix for SGI UV. Two minor build fixes, one of which only affects icc and the other which affects icc and future versions or nonstandard default settings of gcc" * 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, efi: Don't use (U)EFI time services on 32 bit x86, build, icc: Remove uninitialized_var() from compiler-intel.h x86/UV: Fix NULL pointer dereference in uv_flush_tlb_others() if the 'nobau' boot option is used x86, build: Pass in additional -mno-mmx, -mno-sse options
2013-12-13ARM: s3c64xx: dt: Fix boot failure due to double clock initializationTomasz Figa
Commit 4178bac ARM: call of_clk_init from default time_init handler added implicit call to of_clk_init() from default time_init callback, but it did not change platforms calling it from other callbacks, despite of not having custom time_init callbacks. This caused double clock initialization on such platforms, leading to boot failures. An example of such platform is mach-s3c64xx. This patch fixes boot failure on s3c64xx by dropping custom init_irq callback, which had a call to of_clk_init() and moving system reset initialization to init_machine callback. This allows us to have clocks initialized properly without a need to have custom init_time or init_irq callbacks. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-13Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "This resolves some further issues with the dma mask changes on ARM which have been found by TI and others, and also some corner cases with the updates to the virtual to physical address translations. Konstantin also found some problems with the unwinder, which now performs tighter verification that the stack is valid while unwinding" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: fix asm/memory.h build error ARM: 7917/1: cacheflush: correctly limit range of memory region being flushed ARM: 7913/1: fix framepointer check in unwind_frame ARM: 7912/1: check stack pointer in get_wchan ARM: 7909/1: mm: Call setup_dma_zone() post early_paging_init() ARM: 7908/1: mm: Fix the arm_dma_limit calculation ARM: another fix for the DMA mapping checks
2013-12-13Merge tag 'arc-fixes-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fixes from Vineet Gupta: "These are couple of weeks old already, but I just couldn't get them to you earlier. - couple of fixes for recently added perf code - build time extable sort" * tag 'arc-fixes-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: [perf] Fix a few thinkos ARC: Add guard macro to uapi/asm/unistd.h ARC: extable: Enable sorting at build time
2013-12-13ARM: fix asm/memory.h build errorRussell King
Jason Gunthorpe reports a build failure when ARM_PATCH_PHYS_VIRT is not defined: In file included from arch/arm/include/asm/page.h:163:0, from include/linux/mm_types.h:16, from include/linux/sched.h:24, from arch/arm/kernel/asm-offsets.c:13: arch/arm/include/asm/memory.h: In function '__virt_to_phys': arch/arm/include/asm/memory.h:244:40: error: 'PHYS_OFFSET' undeclared (first use in this function) arch/arm/include/asm/memory.h:244:40: note: each undeclared identifier is reported only once for each function it appears in arch/arm/include/asm/memory.h: In function '__phys_to_virt': arch/arm/include/asm/memory.h:249:13: error: 'PHYS_OFFSET' undeclared (first use in this function) Fixes: ca5a45c06cd4 ("ARM: mm: use phys_addr_t appropriately in p2v and v2p conversions") Tested-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-13powerpc/powernv: Fix OPAL LPC access in Little EndianBenjamin Herrenschmidt
We are passing pointers to the firmware for reads, we need to properly convert the result as OPAL is always BE. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc/powernv: Fix endian issue in opal_xscom_readAnton Blanchard
opal_xscom_read uses a pointer to return the data so we need to byteswap it on LE builds. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc: Fix endian issues in crash dump codeAnton Blanchard
A couple more device tree properties that need byte swapping. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc/pseries: Fix endian issues in MSI codeAnton Blanchard
The MSI code is miscalculating quotas in little endian mode. Add required byteswaps to fix this. Before we claimed a quota of 65536, after the patch we see the correct value of 256. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc/pseries: Fix PCIE link speed endian issueAnton Blanchard
We need to byteswap ibm,pcie-link-speed-stats. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc/pseries: Fix endian issues in nvram codeAnton Blanchard
The NVRAM code has a number of endian issues. I noticed a very confused error log count: RTAS: 100663330 -------- RTAS event begin -------- 100663330 == 0x06000022. 0x6 LE error logs and 0x22 BE error logs. The pstore code has similar issues - if we write an oops in one endian and attempt to read it in another we get junk. Make both of these formats big endian, and byteswap as required. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc/pseries: Fix endian issues in /proc/ppc64/lparcfgAnton Blanchard
Some obvious issues: cat /proc/ppc64/lparcfg ... partition_id=16777216 ... partition_potential_processors=268435456 Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc: Fix topology core_id endian issue on LE buildsAnton Blanchard
cpu_to_core_id() is missing a byteswap: cat /sys/devices/system/cpu/cpu63/topology/core_id 201326592 Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc: Fix endian issue in setup-common.cAnton Blanchard
During on LE boot we see: Partition configured for 1073741824 cpus, operating system maximum is 2048. Clearly missing a byteswap here. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-13powerpc: PTRACE_PEEKUSR always returns FPR0Ulrich Weigand
There is a bug in using ptrace to access FPRs via PTRACE_PEEKUSR / PTRACE_POKEUSR. In effect, trying to access any of the FPRs always really accesses FPR0, which does seriously break debugging :-) The problem seems to have been introduced by commit 3ad26e5c4459d (Merge branch 'for-kvm' into next). [ It is indeed a merge conflict between Paul's FPU/VSX state rework and my LE patches - Anton ] Signed-off-by: Ulrich Weigand <Ulrich.Weigand@de.ibm.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-12Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "Four security fixes for KVM on x86. Thanks to Andrew Honig and Lars Bull from Google for reporting them" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: fix guest-initiated crash with x2apic (CVE-2013-6376) KVM: x86: Convert vapic synchronization to _cached functions (CVE-2013-6368) KVM: x86: Fix potential divide by 0 in lapic (CVE-2013-6367) KVM: Improve create VCPU parameter (CVE-2013-4587)
2013-12-12Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another week, another batch of fixes. Again, OMAP regressions due to move to DT is the bulk of the changes here, but this should be the last of it for 3.13. There are also a handful of OMAP hwmod changes (power management, reset handling) for USB on OMAP3 that fixes some longish-standing bugs around USB resets. There are a couple of other changes that also add up line count a bit: One is a long-standing bug with the keyboard layout on one of the PXA platforms. The other is a fix for highbank that moves their power-off/reset button handling to be done in-kernel since relying on userspace to handle it was fragile and awkward" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: sun6i: dt: Fix interrupt trigger types ARM: sun7i: dt: Fix interrupt trigger types MAINTAINERS: merge IMX6 entry into IMX ARM: tegra: add missing break to fuse initialization code ARM: pxa: prevent PXA270 occasional reboot freezes ARM: pxa: tosa: fix keys mapping ARM: OMAP2+: omap_device: add fail hook for runtime_pm when bad data is detected ARM: OMAP2+: hwmod: Fix usage of invalid iclk / oclk when clock node is not present ARM: OMAP3: hwmod data: Don't prevent RESET of USB Host module ARM: OMAP2+: hwmod: Fix SOFTRESET logic ARM: OMAP4+: hwmod data: Don't prevent RESET of USB Host module ARM: dts: Fix booting for secure omaps ARM: OMAP2+: Fix the machine entry for am3517 ARM: dts: Fix missing entries for am3517 ARM: OMAP2+: Fix overwriting hwmod data with data from device tree ARM: davinci: Fix McASP mem resource names ARM: highbank: handle soft poweroff and reset key events ARM: davinci: fix number of resources passed to davinci_gpio_register() gpio: davinci: fix check for unbanked gpio
2013-12-12KVM: x86: fix guest-initiated crash with x2apic (CVE-2013-6376)Gleb Natapov
A guest can cause a BUG_ON() leading to a host kernel crash. When the guest writes to the ICR to request an IPI, while in x2apic mode the following things happen, the destination is read from ICR2, which is a register that the guest can control. kvm_irq_delivery_to_apic_fast uses the high 16 bits of ICR2 as the cluster id. A BUG_ON is triggered, which is a protection against accessing map->logical_map with an out-of-bounds access and manages to avoid that anything really unsafe occurs. The logic in the code is correct from real HW point of view. The problem is that KVM supports only one cluster with ID 0 in clustered mode, but the code that has the bug does not take this into account. Reported-by: Lars Bull <larsbull@google.com> Cc: stable@vger.kernel.org Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-12-12KVM: x86: Convert vapic synchronization to _cached functions (CVE-2013-6368)Andy Honig
In kvm_lapic_sync_from_vapic and kvm_lapic_sync_to_vapic there is the potential to corrupt kernel memory if userspace provides an address that is at the end of a page. This patches concerts those functions to use kvm_write_guest_cached and kvm_read_guest_cached. It also checks the vapic_address specified by userspace during ioctl processing and returns an error to userspace if the address is not a valid GPA. This is generally not guest triggerable, because the required write is done by firmware that runs before the guest. Also, it only affects AMD processors and oldish Intel that do not have the FlexPriority feature (unless you disable FlexPriority, of course; then newer processors are also affected). Fixes: b93463aa59d6 ('KVM: Accelerated apic support') Reported-by: Andrew Honig <ahonig@google.com> Cc: stable@vger.kernel.org Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-12-12KVM: x86: Fix potential divide by 0 in lapic (CVE-2013-6367)Andy Honig
Under guest controllable circumstances apic_get_tmcct will execute a divide by zero and cause a crash. If the guest cpuid support tsc deadline timers and performs the following sequence of requests the host will crash. - Set the mode to periodic - Set the TMICT to 0 - Set the mode bits to 11 (neither periodic, nor one shot, nor tsc deadline) - Set the TMICT to non-zero. Then the lapic_timer.period will be 0, but the TMICT will not be. If the guest then reads from the TMCCT then the host will perform a divide by 0. This patch ensures that if the lapic_timer.period is 0, then the division does not occur. Reported-by: Andrew Honig <ahonig@google.com> Cc: stable@vger.kernel.org Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-12-11ARM: sun6i: dt: Fix interrupt trigger typesMaxime Ripard
The Allwinner A31 uses the ARM GIC as its internal interrupts controller. The GIC can work on several interrupt triggers, and the A31 was actually setting it up to use a rising edge as a trigger, while it was actually a level high trigger, leading to some interrupts that would be completely ignored if the edge was missed. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-11ARM: sun7i: dt: Fix interrupt trigger typesMaxime Ripard
The Allwinner A20 uses the ARM GIC as its internal interrupts controller. The GIC can work on several interrupt triggers, and the A20 was actually setting it up to use a rising edge as a trigger, while it was actually a level high trigger, leading to some interrupts that would be completely ignored if the edge was missed. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Cc: stable@vger.kernel.org #3.12+ Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-11ARM: tegra: add missing break to fuse initialization codeStephen Warren
Add a missing break to the switch in tegra_init_fuse() which determines which SoC the code is running on. This prevents the Tegra30+ fuse handling code from running on Tegra20. Fixes: 3bd1ae57f7bb ("ARM: tegra: add fuses as device randomness") Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-11ARM: pxa: prevent PXA270 occasional reboot freezesSergei Ianovich
Erratum 71 of PXA270M Processor Family Specification Update (April 19, 2010) explains that watchdog reset time is just 8us insead of 10ms in EMTS. If SDRAM is not reset, it causes memory bus congestion and the device hangs. We put SDRAM in selfresh mode before watchdog reset, removing potential freezes. Without this patch PXA270-based ICP DAS LP-8x4x hangs after up to 40 reboots. With this patch it has successfully rebooted 500 times. Signed-off-by: Sergei Ianovich <ynvich@gmail.com> Tested-by: Marek Vasut <marex@denx.de> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-11ARM: pxa: tosa: fix keys mappingDmitry Eremin-Solenikov
When converting from tosa-keyboard driver to matrix keyboard, tosa keys received extra 1 column shift. Replace that with correct values to make keyboard work again. Fixes: f69a6548c9d5 ('[ARM] pxa/tosa: make use of the matrix keypad driver') Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-11arm: xen: foreign mapping PTEs are special.Ian Campbell
These mappings are in fact special and require special handling in privcmd, which already exists. Failure to mark the PTE as special on arm64 causes all sorts of bad PTE fun. e.g. e.g.: BUG: Bad page map in process xl pte:e0004077b33f53 pmd:4079575003 page:ffffffbce1a2f328 count:1 mapcount:-1 mapping: (null) index:0x0 page flags: 0x4000000000000014(referenced|dirty) addr:0000007fb5259000 vm_flags:040644fa anon_vma: (null) mapping:ffffffc03a6fda58 index:0 vma->vm_ops->fault: privcmd_fault+0x0/0x38 vma->vm_file->f_op->mmap: privcmd_mmap+0x0/0x2c CPU: 0 PID: 2657 Comm: xl Not tainted 3.12.0+ #102 Call trace: [<ffffffc0000880f8>] dump_backtrace+0x0/0x12c [<ffffffc000088238>] show_stack+0x14/0x1c [<ffffffc0004b67e0>] dump_stack+0x70/0x90 [<ffffffc000125690>] print_bad_pte+0x12c/0x1bc [<ffffffc0001268f4>] unmap_single_vma+0x4cc/0x700 [<ffffffc0001273b4>] unmap_vmas+0x68/0xb4 [<ffffffc00012c050>] unmap_region+0xcc/0x1d4 [<ffffffc00012df20>] do_munmap+0x218/0x314 [<ffffffc00012e060>] vm_munmap+0x44/0x64 [<ffffffc00012ed78>] SyS_munmap+0x24/0x34 Where unmap_single_vma contains inlined -> unmap_page_range -> zap_pud_range -> zap_pmd_range -> zap_pte_range -> print_bad_pte. Or: BUG: Bad page state in process xl pfn:4077b4d page:ffffffbce1a2f8d8 count:0 mapcount:-1 mapping: (null) index:0x0 page flags: 0x4000000000000014(referenced|dirty) Modules linked in: CPU: 0 PID: 2657 Comm: xl Tainted: G B 3.12.0+ #102 Call trace: [<ffffffc0000880f8>] dump_backtrace+0x0/0x12c [<ffffffc000088238>] show_stack+0x14/0x1c [<ffffffc0004b67e0>] dump_stack+0x70/0x90 [<ffffffc00010f798>] bad_page+0xc4/0x110 [<ffffffc00010f8b4>] free_pages_prepare+0xd0/0xd8 [<ffffffc000110e94>] free_hot_cold_page+0x28/0x178 [<ffffffc000111460>] free_hot_cold_page_list+0x38/0x60 [<ffffffc000114cf0>] release_pages+0x190/0x1dc [<ffffffc00012c0e0>] unmap_region+0x15c/0x1d4 [<ffffffc00012df20>] do_munmap+0x218/0x314 [<ffffffc00012e060>] vm_munmap+0x44/0x64 [<ffffffc00012ed78>] SyS_munmap+0x24/0x34 x86 already gets this correct. 32-bit arm gets away with this because there is not PTE_SPECIAL bit in the PTE there and the vm_normal_page fallback path does the right thing. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2013-12-11xen/arm64: do not call the swiotlb functions twiceStefano Stabellini
On arm64 the dma_map_ops implementation is based on the swiotlb. swiotlb-xen, used by default in dom0 on Xen, is also based on the swiotlb. Avoid calling into the default arm64 dma_map_ops functions from xen_dma_map_page, xen_dma_unmap_page, xen_dma_sync_single_for_cpu, and xen_dma_sync_single_for_device otherwise we end up calling into the swiotlb twice. When arm64 gets a non-swiotlb based implementation of dma_map_ops, we'll probably have to reintroduce dma_map_ops calls in page-coherent.h. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> CC: catalin.marinas@arm.com CC: Will.Deacon@arm.com CC: Ian.Campbell@citrix.com
2013-12-11math64: Add mul_u64_u32_shr()Peter Zijlstra
Introduce mul_u64_u32_shr() as proposed by Andy a while back; it allows using 64x64->128 muls on 64bit archs and recent GCC which defines __SIZEOF_INT128__ and __int128. (This new method will be used by the scheduler.) Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: fweisbec@gmail.com Cc: Andy Lutomirski <luto@amacapital.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-hxjoeuzmrcaumR0uZwjpe2pv@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-11sched: Remove PREEMPT_NEED_RESCHED from generic codePeter Zijlstra
While hunting a preemption issue with Alexander, Ben noticed that the currently generic PREEMPT_NEED_RESCHED stuff is horribly broken for load-store architectures. We currently rely on the IPI to fold TIF_NEED_RESCHED into PREEMPT_NEED_RESCHED, but when this IPI lands while we already have a load for the preempt-count but before the store, the store will erase the PREEMPT_NEED_RESCHED change. The current preempt-count only works on load-store archs because interrupts are assumed to be completely balanced wrt their preempt_count fiddling; the previous preempt_count load will match the preempt_count state after the interrupt and therefore nothing gets lost. This patch removes the PREEMPT_NEED_RESCHED usage from generic code and pushes it into x86 arch code; the generic code goes back to relying on TIF_NEED_RESCHED. Boot tested on x86_64 and compile tested on ppc64. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-and-Tested-by: Alexander Graf <agraf@suse.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20131128132641.GP10022@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-11powerpc/kvm/booke: Fix build break due to stack frame size warningScott Wood
Commit ce11e48b7fdd256ec68b932a89b397a790566031 ("KVM: PPC: E500: Add userspace debug stub support") added "struct thread_struct" to the stack of kvmppc_vcpu_run(). thread_struct is 1152 bytes on my build, compared to 48 bytes for the recently-introduced "struct debug_reg". Use the latter instead. This fixes the following error: cc1: warnings being treated as errors arch/powerpc/kvm/booke.c: In function 'kvmppc_vcpu_run': arch/powerpc/kvm/booke.c:760:1: error: the frame size of 1424 bytes is larger than 1024 bytes make[2]: *** [arch/powerpc/kvm/booke.o] Error 1 make[1]: *** [arch/powerpc/kvm] Error 2 make[1]: *** Waiting for unfinished jobs.... Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-12-10x86, efi: Don't use (U)EFI time services on 32 bitMatthew Garrett
UEFI time services are often broken once we're in virtual mode. We were already refusing to use them on 64-bit systems, but it turns out that they're also broken on some 32-bit firmware, including the Dell Venue. Disable them for now, we can revisit once we have the 1:1 mappings code incorporated. Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Link: http://lkml.kernel.org/r/1385754283-2464-1-git-send-email-matthew.garrett@nebula.com Cc: <stable@vger.kernel.org> Cc: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
