commit 0a5191efe06b5103909206e4fbcff81d30283f8e upstream.
Since commit aef9a7bd9b67 ("serial/uart/8250: Add tunable RX interrupt
trigger I/F of FIFO buffers"), the port's default FCR value isn't used
in serial8250_do_set_termios anymore, but copied over once in
serial8250_config_port and then modified as needed.
Unfortunately, serial8250_config_port will never be called if the port
is shared between kernel and userspace, and the port's flag doesn't have
UPF_BOOT_AUTOCONF, which would trigger a serial8250_config_port as well.
This causes garbled output from userspace:
[ 5.220000] random: procd urandom read with 49 bits of entropy available
ers
[kee
Fix this by forcing it to be configured on boot, resulting in the
expected output:
[ 5.250000] random: procd urandom read with 50 bits of entropy available
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
Fixes: aef9a7bd9b67 ("serial/uart/8250: Add tunable RX interrupt trigger I/F of FIFO buffers")
Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com>
Cc: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Nicolas Schichan <nschichan@freebox.fr>
Cc: linux-mips@linux-mips.org
Cc: linux-serial@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/17544/
Cc: James Hogan <jhogan@kernel.org>
commit 3f7d875566d8e79c5e0b2c9a413e91b2c29e0854 upstream.
The generated assembler for the C fill RSB inline asm operations has
several issues:
- The C code sets up the loop register, which is then immediately
overwritten in __FILL_RETURN_BUFFER with the same value again.
- The C code also passes in the iteration count in another register, which
is not used at all.
Remove these two unnecessary operations. Just rely on the single constant
passed to the macro for the iterations.
Acked-by: David Woodhouse <dwmw@amazon.co.uk>
Cc: dave.hansen@intel.com
Cc: gregkh@linuxfoundation.org
Cc: torvalds@linux-foundation.org
Cc: arjan@linux.intel.com
Link: https://lkml.kernel.org/r/20180117225328.15414-1-andi@firstfloor.org
commit c86a32c09f8ced67971a2310e3b0dda4d1749007 upstream.
Since indirect jump instructions will be replaced by jump
to __x86_indirect_thunk_*, those jmp instruction must be
treated as an indirect jump. Since optprobe prohibits to
optimize probes in the function which uses an indirect jump,
it also needs to find out the function which jump to
__x86_indirect_thunk_* and disable optimization.
Add a check that the jump target address is between the
__indirect_thunk_start/end when optimizing kprobe.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org>
Link: https://lkml.kernel.org/r/151629212062.10241.6991266100233002273.stgit@devbox
commit c1804a236894ecc942da7dc6c5abe209e56cba93 upstream.
Mark __x86_indirect_thunk_* functions as blacklist for kprobes
because those functions can be called from anywhere in the kernel
including blacklist functions of kprobes.
Link: https://lkml.kernel.org/r/151629209111.10241.5444852823378068683.stgit@devbox
commit 736e80a4213e9bbce40a7c050337047128b472ac upstream.
Introduce start/end markers of __x86_indirect_thunk_* functions.
To make it easy, consolidate .text.__x86.indirect_thunk.* sections
to one .text.__x86.indirect_thunk section and put it in the
end of kernel text section and adds __indirect_thunk_start/end
so that other subsystem (e.g. kprobes) can identify it.
Link: https://lkml.kernel.org/r/151629206178.10241.6828804696410044771.stgit@devbox
commit 6f41c34d69eb005e7848716bbcafc979b35037d5 upstream.
The machine check idtentry uses an indirect branch directly from the low
level code. This evades the speculation protection.
Replace it by a direct call into C code and issue the indirect call there
so the compiler can apply the proper speculation protection.
Reviewed-by:Borislav Petkov <bp@alien8.de>
Reviewed-by: David Woodhouse <dwmw@amazon.co.uk>
Niced-by: Peter Zijlstra <peterz@infradead.org>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801181626290.1847@nanos
commit 694d99d40972f12e59a3696effee8a376b79d7c8 upstream.
AMD processors are not subject to the types of attacks that the kernel
page table isolation feature protects against. The AMD microarchitecture
does not allow memory references, including speculative references, that
access higher privileged data when running in a lesser privileged mode
when that access would result in a page fault.
Disable page table isolation by default on AMD processors by not setting
the X86_BUG_CPU_INSECURE feature, which controls whether X86_FEATURE_PTI
is set.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20171227054354.20369.94587.stgit@tlendack-t1.amdoffice.net
Cc: Nick Lowe <nick.lowe@gmail.com>
commit acfb3b883f6d6a4b5d27ad7fdded11f6a09ae6dd upstream.
KVM doesn't follow the SMCCC when it comes to unimplemented calls,
and inject an UNDEF instead of returning an error. Since firmware
calls are now used for security mitigation, they are becoming more
common, and the undef is counter productive.
Instead, let's follow the SMCCC which states that -1 must be returned
to the caller when getting an unknown function number.
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 56aeb07c914a616ab84357d34f8414a69b140cdf upstream.
MPP7 is currently muxed as "gpio", but this function doesn't exist for
MPP7, only "gpo" is available. This causes the following error:
kirkwood-pinctrl f1010000.pin-controller: unsupported function gpio on pin mpp7
pinctrl core: failed to register map default (6): invalid type given
kirkwood-pinctrl f1010000.pin-controller: error claiming hogs: -22
kirkwood-pinctrl f1010000.pin-controller: could not claim hogs: -22
kirkwood-pinctrl f1010000.pin-controller: unable to register pinctrl driver
kirkwood-pinctrl: probe of f1010000.pin-controller failed with error -22
So the pinctrl driver is not probed, all device drivers (including the
UART driver) do a -EPROBE_DEFER, and therefore the system doesn't
really boot (well, it boots, but with no UART, and no devices that
require pin-muxing).
Back when the Device Tree file for this board was introduced, the
definition was already wrong. The pinctrl driver also always described
as "gpo" this function for MPP7. However, between Linux 4.10 and 4.11,
a hog pin failing to be muxed was turned from a simple warning to a
hard error that caused the entire pinctrl driver probe to bail
out. This is probably the result of commit 6118714275f0a ("pinctrl:
core: Fix pinctrl_register_and_init() with pinctrl_enable()").
This commit fixes the Device Tree to use the proper "gpo" function for
MPP7, which fixes the boot of OpenBlocks A7, which was broken since
Linux 4.11.
Fixes: f24b56cbcd9d ("ARM: kirkwood: add support for OpenBlocks A7 platform")
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 45d55e7bac4028af93f5fa324e69958a0b868e96 upstream.
Keith reported the following warning:
WARNING: CPU: 28 PID: 1420 at kernel/irq/matrix.c:222 irq_matrix_remove_managed+0x10f/0x120
x86_vector_free_irqs+0xa1/0x180
x86_vector_alloc_irqs+0x1e4/0x3a0
msi_domain_alloc+0x62/0x130
The reason for this is that if the vector allocation fails the error
handling code tries to free the failed vector as well, which causes the
above imbalance warning to trigger.
Adjust the error path to handle this correctly.
Fixes: b5dc8e6c21e7 ("x86/irq: Use hierarchical irqdomain to manage CPU interrupt vectors")
Reported-by: Keith Busch <keith.busch@intel.com>
Tested-by: Keith Busch <keith.busch@intel.com>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801161217300.1823@nanos
commit 28d437d550e1e39f805d99f9f8ac399c778827b7 upstream.
The PAUSE instruction is currently used in the retpoline and RSB filling
macros as a speculation trap. The use of PAUSE was originally suggested
because it showed a very, very small difference in the amount of
cycles/time used to execute the retpoline as compared to LFENCE. On AMD,
the PAUSE instruction is not a serializing instruction, so the pause/jmp
loop will use excess power as it is speculated over waiting for return
to mispredict to the correct target.
The RSB filling macro is applicable to AMD, and, if software is unable to
verify that LFENCE is serializing on AMD (possible when running under a
hypervisor), the generic retpoline support will be used and, so, is also
applicable to AMD. Keep the current usage of PAUSE for Intel, but add an
LFENCE instruction to the speculation trap for AMD.
The same sequence has been adopted by GCC for the GCC generated retpolines.
Reviewed-by: Borislav Petkov <bp@alien8.de>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Paul Turner <pjt@google.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Kees Cook <keescook@google.com>
Link: https://lkml.kernel.org/r/20180113232730.31060.36287.stgit@tlendack-t1.amdoffice.net
commit b8b9ce4b5aec8de9e23cabb0a26b78641f9ab1d6 upstream.
Remove the compile time warning when CONFIG_RETPOLINE=y and the compiler
does not have retpoline support. Linus rationale for this is:
It's wrong because it will just make people turn off RETPOLINE, and the
asm updates - and return stack clearing - that are independent of the
compiler are likely the most important parts because they are likely the
ones easiest to target.
And it's annoying because most people won't be able to do anything about
it. The number of people building their own compiler? Very small. So if
their distro hasn't got a compiler yet (and pretty much nobody does), the
warning is just annoying crap.
It is already properly reported as part of the sysfs interface. The
compile-time warning only encourages bad things.
Fixes: 76b043848fd2 ("x86/retpoline: Add initial retpoline support")
Requested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: gnomes@lxorguk.ukuu.org.uk
Cc: thomas.lendacky@amd.com
Link: https://lkml.kernel.org/r/CA+55aFzWgquv4i6Mab6bASqYXg3ErV3XDFEYf=GEcCDQg5uAtw@mail.gmail.com
commit 117cc7a908c83697b0b737d15ae1eb5943afe35b upstream.
In accordance with the Intel and AMD documentation, we need to overwrite
all entries in the RSB on exiting a guest, to prevent malicious branch
target predictions from affecting the host kernel. This is needed both
for retpoline and for IBRS.
[ak: numbers again for the RSB stuffing labels]
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lkml.kernel.org/r/1515755487-8524-1-git-send-email-dwmw@amazon.co.uk
Signed-off-by: Razvan Ghitulete <rga@amazon.de>
commit 7614e913db1f40fff819b36216484dc3808995d4 upstream.
Convert all indirect jumps in 32bit irq inline asm code to use non
speculative sequences.
Acked-by: Ingo Molnar <mingo@kernel.org>
Link: https://lkml.kernel.org/r/1515707194-20531-12-git-send-email-dwmw@amazon.co.uk
commit 5096732f6f695001fa2d6f1335a2680b37912c69 upstream.
Convert all indirect jumps in 32bit checksum assembler code to use
non-speculative sequences when CONFIG_RETPOLINE is enabled.
Link: https://lkml.kernel.org/r/1515707194-20531-11-git-send-email-dwmw@amazon.co.uk
commit ea08816d5b185ab3d09e95e393f265af54560350 upstream.
Convert indirect call in Xen hypercall to use non-speculative sequence,
Reviewed-by: Juergen Gross <jgross@suse.com>
Link: https://lkml.kernel.org/r/1515707194-20531-10-git-send-email-dwmw@amazon.co.uk
commit 9351803bd803cdbeb9b5a7850b7b6f464806e3db upstream.
Convert all indirect jumps in ftrace assembler code to use non-speculative
Link: https://lkml.kernel.org/r/1515707194-20531-8-git-send-email-dwmw@amazon.co.uk
commit 2641f08bb7fc63a636a2b18173221d7040a3512e upstream.
Convert indirect jumps in core 32/64bit entry assembler code to use
Don't use CALL_NOSPEC in entry_SYSCALL_64_fastpath because the return
address after the 'call' instruction must be *precisely* at the
.Lentry_SYSCALL_64_after_fastpath label for stub_ptregs_64 to work,
and the use of alternatives will mess that up unless we play horrid
games to prepend with NOPs and make the variants the same length. It's
not worth it; in the case where we ALTERNATIVE out the retpoline, the
first instruction at __x86.indirect_thunk.rax is going to be a bare
jmp *%rax anyway.
Link: https://lkml.kernel.org/r/1515707194-20531-7-git-send-email-dwmw@amazon.co.uk
commit 9697fa39efd3fc3692f2949d4045f393ec58450b upstream.
Convert all indirect jumps in crypto assembler code to use non-speculative
Link: https://lkml.kernel.org/r/1515707194-20531-6-git-send-email-dwmw@amazon.co.uk
commit da285121560e769cc31797bba6422eea71d473e0 upstream.
Add a spectre_v2= option to select the mitigation used for the indirect
branch speculation vulnerability.
Currently, the only option available is retpoline, in its various forms.
This will be expanded to cover the new IBRS/IBPB microcode features.
The RETPOLINE_AMD feature relies on a serializing LFENCE for speculation
control. For AMD hardware, only set RETPOLINE_AMD if LFENCE is a
serializing instruction, which is indicated by the LFENCE_RDTSC feature.
[ tglx: Folded back the LFENCE/AMD fixes and reworked it so IBRS
integration becomes simple ]
Link: https://lkml.kernel.org/r/1515707194-20531-5-git-send-email-dwmw@amazon.co.uk
commit 76b043848fd22dbf7f8bf3a1452f8c70d557b860 upstream.
Enable the use of -mindirect-branch=thunk-extern in newer GCC, and provide
the corresponding thunks. Provide assembler macros for invoking the thunks
in the same way that GCC does, from native and inline assembler.
This adds X86_FEATURE_RETPOLINE and sets it by default on all CPUs. In
some circumstances, IBRS microcode features may be used instead, and the
retpoline can be disabled.
On AMD CPUs if lfence is serialising, the retpoline can be dramatically
simplified to a simple "lfence; jmp *\reg". A future patch, after it has
been verified that lfence really is serialising in all circumstances, can
enable this by setting the X86_FEATURE_RETPOLINE_AMD feature bit in addition
to X86_FEATURE_RETPOLINE.
Do not align the retpoline in the altinstr section, because there is no
guarantee that it stays aligned when it's copied over the oldinstr during
alternative patching.
[ Andi Kleen: Rename the macros, add CONFIG_RETPOLINE option, export thunks]
[ tglx: Put actual function CALL/JMP in front of the macros, convert to
symbolic labels ]
[ dwmw2: Convert back to numeric labels, merge objtool fixes ]
Link: https://lkml.kernel.org/r/1515707194-20531-4-git-send-email-dwmw@amazon.co.uk
[ 4.4 backport: removed objtool annotation since there is no objtool ]
commit f005f5d860e0231fe212cfda8c1a3148b99609f4 upstream.
asm/alternative.h isn't directly useful from assembly, but it
shouldn't break the build.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/e5b693fcef99fe6e80341c9e97a002fb23871e91.1461698311.git.luto@kernel.org
commit 334bb773876403eae3457d81be0b8ea70f8e4ccc upstream.
Commit 4efca4ed ("kbuild: modversions for EXPORT_SYMBOL() for asm") adds
modversion support for symbols exported from asm files. Architectures
must include C-style declarations for those symbols in asm/asm-prototypes.h
in order for them to be versioned.
Add these declarations for x86, and an architecture-independent file that
can be used for common symbols.
With f27c2f6 reverting 8ab2ae6 ("default exported asm symbols to zero") we
produce a scary warning on x86, this commit fixes that.
Signed-off-by: Adam Borowski <kilobyte@angband.pl>
Tested-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Nicholas Piggin <npiggin@gmail.com>
Tested-by: Peter Wu <peter@lekensteyn.nl>
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Michal Marek <mmarek@suse.com>
commit 196bd485ee4f03ce4c690bfcf38138abfcd0a4bc upstream.
Currently we use current_stack_pointer() function to get the value
of the stack pointer register. Since commit:
f5caf621ee35 ("x86/asm: Fix inline asm call constraints for Clang")
... we have a stack register variable declared. It can be used instead of
current_stack_pointer() function which allows to optimize away some
excessive "mov %rsp, %<dst>" instructions:
-mov %rsp,%rdx
-sub %rdx,%rax
-cmp $0x3fff,%rax
-ja ffffffff810722fd <ist_begin_non_atomic+0x2d>
+sub %rsp,%rax
+cmp $0x3fff,%rax
+ja ffffffff810722fa <ist_begin_non_atomic+0x2a>
Remove current_stack_pointer(), rename __asm_call_sp to current_stack_pointer
and use it instead of the removed function.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20170929141537.29167-1-aryabinin@virtuozzo.com
[dwmw2: We want ASM_CALL_CONSTRAINT for retpoline]
Signed-off-by: David Woodhouse <dwmw@amazon.co.ku>
commit b8b7abaed7a49b350f8ba659ddc264b04931d581 upstream.
Otherwise we might have the PCID feature bit set during cpu_init().
This is just for robustness. I haven't seen any actual bugs here.
Cc: Borislav Petkov <bpetkov@suse.de>
Fixes: cba4671af755 ("x86/mm: Disable PCID on 32-bit kernels")
Link: http://lkml.kernel.org/r/b16dae9d6b0db5d9801ddbebbfd83384097c61f3.1505663533.git.luto@kernel.org
commit 9c6a73c75864ad9fa49e5fa6513e4c4071c0e29f upstream.
With LFENCE now a serializing instruction, use LFENCE_RDTSC in preference
to MFENCE_RDTSC. However, since the kernel could be running under a
hypervisor that does not support writing that MSR, read the MSR back and
verify that the bit has been set successfully. If the MSR can be read
and the bit is set, then set the LFENCE_RDTSC feature, otherwise set the
MFENCE_RDTSC feature.
Reviewed-by: Reviewed-by: Borislav Petkov <bp@suse.de>
Link: https://lkml.kernel.org/r/20180108220932.12580.52458.stgit@tlendack-t1.amdoffice.net
commit e4d0e84e490790798691aaa0f2e598637f1867ec upstream.
To aid in speculation control, make LFENCE a serializing instruction
since it has less overhead than MFENCE. This is done by setting bit 1
of MSR 0xc0011029 (DE_CFG). Some families that support LFENCE do not
have this MSR. For these families, the LFENCE instruction is already
serializing.
Link: https://lkml.kernel.org/r/20180108220921.12580.71694.stgit@tlendack-t1.amdoffice.net
commit b9e705ef7cfaf22db0daab91ad3cd33b0fa32eb9 upstream.
Where an ALTERNATIVE is used in the middle of an inline asm block, this
would otherwise lead to the following instruction being appended directly
to the trailing ".popsection", and a failed compile.
Fixes: 9cebed423c84 ("x86, alternative: Use .pushsection/.popsection")
Cc: ak@linux.intel.com
Link: https://lkml.kernel.org/r/20180104143710.8961-8-dwmw@amazon.co.uk
commit 612e8e9350fd19cae6900cf36ea0c6892d1a0dca upstream.
The alternatives code checks only the first byte whether it is a NOP, but
with NOPs in front of the payload and having actual instructions after it
breaks the "optimized' test.
Make sure to scan all bytes before deciding to optimize the NOPs in there.
Reported-by: David Woodhouse <dwmw2@infradead.org>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Andrew Lutomirski <luto@kernel.org>
Link: https://lkml.kernel.org/r/20180110112815.mgciyf5acwacphkq@pd.tnic
commit 61dc0f555b5c761cdafb0ba5bd41ecf22d68a4c4 upstream.
Implement the CPU vulnerabilty show functions for meltdown, spectre_v1 and
spectre_v2.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Linus Torvalds <torvalds@linuxfoundation.org>
Link: https://lkml.kernel.org/r/20180107214913.177414879@linutronix.de
commit 62a67e123e058a67db58bc6a14354dd037bafd0a upstream.
Should be easier when following boot paths. It probably is a left over
from the x86 unification eons ago.
No functionality change.
Link: http://lkml.kernel.org/r/20161024173844.23038-3-bp@alien8.de
commit 99c6fa2511d8a683e61468be91b83f85452115fa upstream.
Add the bug bits for spectre v1/2 and force them unconditionally for all
cpus.
Link: https://lkml.kernel.org/r/1515239374-23361-2-git-send-email-dwmw@amazon.co.uk
commit de791821c295cc61419a06fe5562288417d1bc58 upstream.
Use the name associated with the particular attack which needs page table
isolation for mitigation.
Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
Cc: Jiri Koshina <jikos@kernel.org>
Cc: Andi Lutomirski <luto@amacapital.net>
Cc: Greg KH <gregkh@linux-foundation.org>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801051525300.1724@nanos
commit a89f040fa34ec9cd682aed98b8f04e3c47d998bd upstream.
Many x86 CPUs leak information to user space due to missing isolation of
user space and kernel space page tables. There are many well documented
ways to exploit that.
The upcoming software migitation of isolating the user and kernel space
page tables needs a misfeature flag so code can be made runtime
conditional.
Add the BUG bits which indicates that the CPU is affected and add a feature
bit which indicates that the software migitation is enabled.
Assume for now that _ALL_ x86 CPUs are affected by this. Exceptions can be
made later.
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Laight <David.Laight@aculab.com>
Cc: Eduardo Valentin <eduval@amazon.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Juergen Gross <jgross@suse.com>
Cc: aliguori@amazon.com
Cc: daniel.gruss@iaik.tugraz.at
Cc: hughd@google.com
Cc: keescook@google.com
commit 6cbd2171e89b13377261d15e64384df60ecb530e upstream.
There is currently no way to force CPU bug bits like CPU feature bits. That
makes it impossible to set a bug bit once at boot and have it stick for all
upcoming CPUs.
Extend the force set/clear arrays to handle bug bits as well.
Link: https://lkml.kernel.org/r/20171204150606.992156574@linutronix.de
commit 8bf1ebca215c262e48c15a4a15f175991776f57f upstream.
There are multiple call sites that apply forced CPU caps. Factor
them into a helper.
Cc: Matthew Whitehead <tedheadster@gmail.com>
Cc: One Thousand Gnomes <gnomes@lxorguk.ukuu.org.uk>
Cc: Yu-cheng Yu <yu-cheng.yu@intel.com>
Link: http://lkml.kernel.org/r/623ff7555488122143e4417de09b18be2085ad06.1484705016.git.luto@kernel.org
This finally resolve crash if loaded under qemu + haxm. Haitao Shan pointed
out that the reason of that crash is that NX bit get set for page tables.
It seems we missed checking if _PAGE_NX is supported in kaiser_add_user_map
Link: https://www.spinics.net/lists/kernel/msg2689835.html
Reviewed-by: Guenter Roeck <groeck@chromium.org>
Signed-off-by: Lepton Wu <ytht.net@gmail.com>
commit 75f139aaf896d6fdeec2e468ddfa4b2fe469bf40 upstream.
This adds a memory barrier when performing a lookup into
the vmcs_field_to_offset_table. This is related to
CVE-2017-5753.
Signed-off-by: Andrew Honig <ahonig@google.com>
Reviewed-by: Jim Mattson <jmattson@google.com>
commit b94b7373317164402ff7728d10f7023127a02b60 upstream.
Instead of blacklisting all model 79 CPUs when attempting a late
microcode loading, limit that only to CPUs with microcode revisions <
0x0b000021 because only on those late loading may cause a system hang.
For such processors either:
a) a BIOS update which might contain a newer microcode revision
or
b) the early microcode loading method
should be considered.
Processors with revisions 0x0b000021 or higher will not experience such
hangs.
For more details, see erratum BDF90 in document #334165 (Intel Xeon
Processor E7-8800/4800 v4 Product Family Specification Update) from
September 2017.
[ bp: Heavily massage commit message and pr_* statements. ]
Fixes: 723f2828a98c ("x86/microcode/intel: Disable late loading on model 79")
Signed-off-by: Jia Zhang <qianyue.zj@alibaba-inc.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: x86-ml <x86@kernel.org>
Link: http://lkml.kernel.org/r/1514772287-92959-1-git-send-email-qianyue.zj@alibaba-inc.com
In entry_64.S we have code like this:
/* Unconditionally use kernel CR3 for do_nmi() */
/* %rax is saved above, so OK to clobber here */
ALTERNATIVE "jmp 2f", "movq %cr3, %rax", X86_FEATURE_KAISER
/* If PCID enabled, NOFLUSH now and NOFLUSH on return */
ALTERNATIVE "", "bts $63, %rax", X86_FEATURE_PCID
pushq %rax
/* mask off "user" bit of pgd address and 12 PCID bits: */
andq $(~(X86_CR3_PCID_ASID_MASK | KAISER_SHADOW_PGD_OFFSET)), %rax
movq %rax, %cr3
2:
/* paranoidentry do_nmi, 0; without TRACE_IRQS_OFF */
call do_nmi
With this instruction:
We unconditionally switch from whatever our CR3 was to kernel page table.
But, in arch/x86/platform/efi/efi_64.c We temporarily set a different page
table, that does not have the kernel page table with 0x1000 offset from it.
Look in efi_thunk() and efi_thunk_set_virtual_address_map().
So, while CR3 points to the other page table, we get an NMI interrupt,
and clear 0x1000 from CR3, resulting in a bogus CR3 if the 0x1000 bit was
set.
The efi page table comes from realmode/rm/trampoline_64.S:
arch/x86/realmode/rm/trampoline_64.S
141 .bss
142 .balign PAGE_SIZE
143 GLOBAL(trampoline_pgd) .space PAGE_SIZE
Notice: alignment is PAGE_SIZE, so after applying KAISER_SHADOW_PGD_OFFSET
which equal to PAGE_SIZE, we can get a different page table.
But, even if we fix alignment, here the trampoline binary is later copied
into dynamically allocated memory in reserve_real_mode(), so we need to
fix that place as well.
Fixes: 8a43ddfb93a0 ("KAISER: Kernel Address Isolation")
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
commit 39380b80d72723282f0ea1d1bbf2294eae45013e upstream.
Currently it's possible for broken (or malicious) userspace to flood a
kernel log indefinitely with messages a-la
Program dmidecode tried to access /dev/mem between f0000->100000
because range_is_allowed() is case of CONFIG_STRICT_DEVMEM being turned on
dumps this information each and every time devmem_is_allowed() fails.
Reportedly userspace that is able to trigger contignuous flow of these
messages exists.
It would be possible to rate limit this message, but that'd have a
questionable value; the administrator wouldn't get information about all
the failing accessess, so then the information would be both superfluous
and incomplete at the same time :)
Returning EPERM (which is what is actually happening) is enough indication
for userspace what has happened; no need to log this particular error as
some sort of special condition.
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1607081137020.24757@cbobk.fhfr.pm
commit 4ee2ec1b122599f7b10c849fa7915cebb37b7edb upstream.
The new function mp_register_ioapic_irq() is a subset of the code in
mp_override_legacy_irq().
Replace the code duplication by invoking mp_register_ioapic_irq() from
Signed-off-by: Vikas C Sajjan <vikas.cha.sajjan@hpe.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: linux-pm@vger.kernel.org
Cc: kkamagui@gmail.com
Cc: linux-acpi@vger.kernel.org
Link: https://lkml.kernel.org/r/1510848825-21965-3-git-send-email-vikas.cha.sajjan@hpe.com
Cc: Jean Delvare <jdelvare@suse.de>
commit 252714155f04c5d16989cb3aadb85fd1b5772f99 upstream.
Platforms which support only IOAPIC mode, pass the SCI information above
the legacy space (0-15) via the FADT mechanism and not via MADT.
In such cases mp_override_legacy_irq() which is invoked from
acpi_sci_ioapic_setup() to register SCI interrupts fails for interrupts
greater equal 16, since it is meant to handle only the legacy space and
emits error "Invalid bus_irq %u for legacy override".
Add a new function to handle SCI interrupts >= 16 and invoke it
conditionally in acpi_sci_ioapic_setup().
The code duplication due to this new function will be cleaned up in a
separate patch.
Co-developed-by: Sunil V L <sunil.vl@hpe.com>
Signed-off-by: Sunil V L <sunil.vl@hpe.com>
Tested-by: Abdul Lateef Attar <abdul-lateef.attar@hpe.com>
Link: https://lkml.kernel.org/r/1510848825-21965-2-git-send-email-vikas.cha.sajjan@hpe.com
commit 8705d603edd49f1cff165cd3b7998f4c7f098d27 upstream.
arch/x86/built-in.o: In function `arch_setup_additional_pages':
(.text+0x587): undefined reference to `pvclock_pvti_cpu0_va'
KVM_GUEST selects PARAVIRT_CLOCK, so we can make pvclock_pvti_cpu0_va depend
on KVM_GUEST.
Tested-by: Borislav Petkov <bp@alien8.de>
Link: http://lkml.kernel.org/r/444d38a9bcba832685740ea1401b569861d09a72.1451446564.git.luto@kernel.org
Cc: James Dingwall <james@dingwall.me.uk>
commit 0cb5b30698fdc8f6b4646012e3acb4ddce430788 upstream.
Guest GPR values are live in the hardware GPRs at VM-exit. Do not
leave any guest values in hardware GPRs after the guest GPR values are
saved to the vcpu_vmx structure.
This is a partial mitigation for CVE 2017-5715 and CVE 2017-5753.
Specifically, it defeats the Project Zero PoC for CVE 2017-5715.
Suggested-by: Eric Northup <digitaleric@google.com>
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Eric Northup <digitaleric@google.com>
Reviewed-by: Benjamin Serebrin <serebrin@google.com>
Reviewed-by: Andrew Honig <ahonig@google.com>
[Paolo: Add AMD bits, Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>]
commit c8c5a3a24d395b14447a9a89d61586a913840a3b upstream.
Complement commit c23b3d1a5311 ("MIPS: ptrace: Change GP regset to use
correct core dump register layout") and also reject outsized
PTRACE_SETREGSET requests to the NT_PRFPREG regset, like with the
NT_PRSTATUS regset.
Signed-off-by: Maciej W. Rozycki <macro@mips.com>
Fixes: c23b3d1a5311 ("MIPS: ptrace: Change GP regset to use correct core dump register layout")
Cc: James Hogan <james.hogan@mips.com>
Cc: Paul Burton <Paul.Burton@mips.com>
Cc: Alex Smith <alex@alex-smith.me.uk>
Cc: Dave Martin <Dave.Martin@arm.com>
Patchwork: https://patchwork.linux-mips.org/patch/17930/
commit 006501e039eec411842bb3150c41358867d320c2 upstream.
Complement commit d614fd58a283 ("mips/ptrace: Preserve previous
registers for short regset write") and like with the PTRACE_GETREGSET
ptrace(2) request also apply a BUILD_BUG_ON check for the size of the
`elf_fpreg_t' type in the PTRACE_SETREGSET request handler.
Fixes: d614fd58a283 ("mips/ptrace: Preserve previous registers for short regset write")
Patchwork: https://patchwork.linux-mips.org/patch/17929/
commit be07a6a1188372b6d19a3307ec33211fc9c9439d upstream.
Fix a commit 72b22bbad1e7 ("MIPS: Don't assume 64-bit FP registers for
FP regset") public API regression, then activated by commit 1db1af84d6df
("MIPS: Basic MSA context switching support"), that caused the FCSR
register not to be read or written for CONFIG_CPU_HAS_MSA kernel
configurations (regardless of actual presence or absence of the MSA
feature in a given processor) with ptrace(2) PTRACE_GETREGSET and
PTRACE_SETREGSET requests nor recorded in core dumps.
This is because with !CONFIG_CPU_HAS_MSA configurations the whole of
`elf_fpregset_t' array is bulk-copied as it is, which includes the FCSR
in one half of the last, 33rd slot, whereas with CONFIG_CPU_HAS_MSA
configurations array elements are copied individually, and then only the
leading 32 FGR slots while the remaining slot is ignored.
Correct the code then such that only FGR slots are copied in the
respective !MSA and MSA helpers an then the FCSR slot is handled
separately in common code. Use `ptrace_setfcr31' to update the FCSR
too, so that the read-only mask is respected.
Retrieving a correct value of FCSR is important in debugging not only
for the human to be able to get the right interpretation of the
situation, but for correct operation of GDB as well. This is because
the condition code bits in FSCR are used by GDB to determine the
location to place a breakpoint at when single-stepping through an FPU
branch instruction. If such a breakpoint is placed incorrectly (i.e.
with the condition reversed), then it will be missed, likely causing the
debuggee to run away from the control of GDB and consequently breaking
the process of investigation.
Fortunately GDB continues using the older PTRACE_GETFPREGS ptrace(2)
request which is unaffected, so the regression only really hits with
post-mortem debug sessions using a core dump file, in which case
execution, and consequently single-stepping through branches is not
possible. Of course core files created by buggy kernels out there will
have the value of FCSR recorded clobbered, but such core files cannot be
corrected and the person using them simply will have to be aware that
the value of FCSR retrieved is not reliable.
Which also means we can likely get away without defining a replacement
API which would ensure a correct value of FSCR to be retrieved, or none
at all.
This is based on previous work by Alex Smith, extensively rewritten.
Signed-off-by: Alex Smith <alex@alex-smith.me.uk>
Signed-off-by: James Hogan <james.hogan@mips.com>
Fixes: 72b22bbad1e7 ("MIPS: Don't assume 64-bit FP registers for FP regset")
Patchwork: https://patchwork.linux-mips.org/patch/17928/
commit 80b3ffce0196ea50068885d085ff981e4b8396f4 upstream.
Update commit d614fd58a283 ("mips/ptrace: Preserve previous registers
for short regset write") bug and consistently consume all data supplied
to `fpr_set_msa' with the ptrace(2) PTRACE_SETREGSET request, such that
a zero data buffer counter is returned where insufficient data has been
given to fill a whole number of FP general registers.
In reality this is not going to happen, as the caller is supposed to
only supply data covering a whole number of registers and it is verified
in `ptrace_regset' and again asserted in `fpr_set', however structuring
code such that the presence of trailing partial FP general register data
causes `fpr_set_msa' to return with a non-zero data buffer counter makes
it appear that this trailing data will be used if there are subsequent
writes made to FP registers, which is going to be the case with the FCSR
once the missing write to that register has been fixed.
Patchwork: https://patchwork.linux-mips.org/patch/17927/
commit dc24d0edf33c3e15099688b6bbdf7bdc24bf6e91 upstream.
registers for short regset write") and ensure that no partial register
write attempt is made with PTRACE_SETREGSET, as we do not preinitialize
any temporaries used to hold incoming register data and consequently
random data could be written.
It is the responsibility of the caller, such as `ptrace_regset', to
arrange for writes to span whole registers only, so here we only assert
that it has indeed happened.
Patchwork: https://patchwork.linux-mips.org/patch/17926/
