The iomuxc pinctrl-0 property is set with pinctrl nodes muxed for
potential user space use in the module specific device tree.
In order to keep them copy the full list here and amend the additional
pinctrl_uart24_forceoff.
voltage
Correct ldo1/ldo2 voltage as below:
ldo1 --NVCC_SNVS_1V8
ldo2 --VDD_SNVS_0V8
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
(cherry picked from commit d11796134f55d88b49d79bf25d6c42b677ff47bc)
(cherry picked from commit 1c923bdd27021b011358f9422a6a18cbf30de491)
ldo2 --VDD_SNVS_0V8
(cherry picked from commit 6e1db954c1261c9a8a40f7c4e33f03173c4d05b6)
(cherry picked from commit 8574922dd583141a332be58fe1656ee05c9e5dd4)
I understood this property as I could reset something that is on this
USB controller. This was a wrong understanding and the property
reset-gpio is meant to reset the IP inside the SoC.
Remove this for fixing the USB issue.
Related-to: ELB-2592
Fixes: d4d419f1b24e
apalis/colibri_imx6/-imx6ull/_imx7/-imx8/8x_defconfig: config refresh
Implicitly disable HDMI audio on the module level as it is disabled by
default in imx6qdl.dtsi. It can be enabled on the carrier board level
(e.g. imx6q-apalis-eval.dts, imx6q-apalis-ixora.dts,
imx6q-apalis-ixora-v1.1.dts or imx6q-apalis-ixora-v1.2.dts) if required.
Enable WIRELESS_EXT and WEXT_PRIV options for the backported
rtl81288eu driver.
Related-to: ELB-2388
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Disabling all wireless drivers and cfg80211 module makes able
to completely avoid interferences with backported drivers.
Enable WIRELESS_EXT and WEXT_PRIV options as needed for the backported
rtl81288eu driver.
As suggested by the reference manual in a note in chapter 13.2
this commit disables the keeper and enables a 100k pull-down on the
adc pins.
Related-to: ELB-2690
There are some unstable drivers in the kernel.
The stable versions of these drivers present in backported-5.4 package.
Remove duplicated mwifiex_sdio and mwifiex_usb.
Remove unstable rtl8188eu, mwifiex_sdio, mwifiex_usb.
Related-to: ELB-2684
Further clean-up modularising it some more.
BTW: Changing BT_MRVL, BT_MRVL_SDIO, CFG80211 and MAC80211 to modules
will make it co-exist with our latest backports efforts.
The driver mwifiex_sdio stucks after the wifi firmware crash.
Enabling asynchronous interrupts processing in sdio driver
fixes this issue and allows the mwifiex_sdio driver to be reloaded
and continue operates successfully.
Related-to: ELB-2596
Works better with the driver from the backported-5.4 package.
Refresh kernel configs adding some more USB as well as PCIe options
where applicable plus synchronise some more accross all modules.
Some comments made it through. SPI is tested that it works and those
comments are no longer necessary-
There is a hardware issue with the clock lines. It barely works
with 200MHz with SD-Cards but not with SDIO cards. Therefore put
a safe value in there until the hardware issue is resolved
Related-to: ELB-1974
Related-to: HAR-3252
use of rgmii-id instead of rgmii to denote use of rxc and txc delay on the phy.
Related-to: ELB-2581
Until now a PHY-fixup in mach-imx set our rgmii timing correctly. For
the PHY KSZ9131 there is no PHY-fixup in mach-imx. To support this PHY
too, use rgmii-id.
For the now used KSZ9031 nothing will change, as rgmii-id is only
implemented and supported by the KSZ9131.
(cherry picked from commit 1b68480b945e51ba879496d3f9ff5a5addd82007)
We have a PHY-fixup in our downstream Linux. However this patch makes
anyway sense to apply as it documents the rgmii mode properly and
won't brake anything.
This reverts commit 118d904a302114b323e3464bceab64bfc26868e2.
There is now a mainline solution for that. Drop this solution in favor
of the upstream one. We will use "rgmii-id" tag now to declare that
delays.
Add support of non-wifi Toradex Verdin iMX8MM module
on the Development board.
Related-to: ELB-2322
Add the mark of wi-fi version of Toradex Verdin iMX8MM module
to a devicetree file name.
Split the common devicetree file to two layers:
- Toradex Verdin iMX8MM WB;
- Toradex Verdin Development board.
Move the on-module Wi-Fi part of a Toradex Verdin iMX8MM module
to a separate file.
Fix the minor code formatting issue.
Based on imx_4.1x kernel, enable the PCIEB on i.MX8QM MEK baseboard.
Regarding to the base board HW limitation(two Disable#) are not
connected. Only the standard PCIe EP device is supported on PCIEB port.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
(cherry picked from commit d0331d84e5a14d6e2520d04540d1e893d75bd678)
The mwifiex Wi-Fi driver in kernel-4.14-2.3.x-imx works unstable.
The same driver in backports-5.4 works well.
Backports-5.4 requires the undocumented build option CRYPTO_HASH_INFO.
This option is selected by enabled ASYMMETRIC_PUBLIC_KEY_SUBTYPE.
This makes able to build and use the Wi-Fi driver mwifiex_sdio, that works
stable unlike the original driver in 4.14-2.3.x-imx.
Out-of-the-box the analogue camera adapter fails detecting with the
following error:
[ 6.503046] adv7280 2-0021: adv7280_probe:Analog Device adv7280 not detected -6!
Unfortunately, the camera seems to be held in reset due to the BL_ON pin
not being serviced.
Fix this by hogging the camera_nreset aka BL_ON pin to output high.
Related-to: ELB-2580
Related-to: ELB-2316
The dprX_channelY, pixel-combiner and prgX nodes need to be enabled
to use the g2d functionality.
Thus move those nodes into the common fsl-imx8qxp-colibri-eval-v3.dtsi, so that
fsl-imx8qxp-colibri-eval-v3.dts also gets them enabled.
Add CTRL_WAKE1_MICO# as a wakeup source.
Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
changed many more clocks than only the SPDIF core clock as stated in
the commit message.
The MLB clock has been added and this causes SPDIF regression as
reported by Xavi Drudis Ferran and also in this forum post:
https://forum.digikey.com/thread/34240
The MX6Q Reference Manual does not mention that MLB is a clock related
to SPDIF, so change it back to a dummy clock to restore SPDIF
functionality.
Thanks to Ambika for providing the fix at:
https://community.nxp.com/thread/387131
Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
Cc: <stable@vger.kernel.org> # 4.4.x
Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
(cherry picked from commit f065e9e4addd75c21bb976bb2558648bf4f61de6)
This fix was correct, but overwritten by commit 833f2cbf7091099baee28136dc68678e974c0ac5.
MLB (Media Local Bus) Clock is in fact not related to SPDIF according to the MX6Q Reference
Manual. Tested playback and record on pulseaudio with 44.1kHz samples.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
(cherry picked from commit 58e5313d36b969029d76b1ef45d3224c8557af75)
This patch enables both RXC and TXC 2ns dll delay lines on the
KSZ9131 PHY. Both are neede because the i.MX8MM SoC is RGMII v1.3
compliant. This means we need the TXC delay of the PHY.
Related-to: ELB-1299
The RXC delay is provided in both PHYs used (KSZ9031 and KSZ9131)
on the PHY itself so it is not needed on the MAC.
The MAC of the i.MX6 SoC is compliant with RGMII v1.3. The KSZ9131 PHY
is like KSZ9031 adhering to RGMII v2.0 specification. This means the
MAC should provide a delay to the TXC line. Because the i.MX6 MAC does
not provide this delay this has to be done in the PHY.
This patch adds by default ~1.4ns delay to the TXC line. This should
be good for all boards that have all RGMII signals routed with the
same length.
The KSZ9131 has relatively high tolerances on skew registers from
MMD 2.4 to MMD 2.8. Therefore the new DLL-based delay of 2ns is used
and then as little as possibly subtracted from that so we get more
accurate delay. This is actually needed because the i.MX6 SoC has
an asyn skew on TXC from -100ps to 900ps.
Add CTRL_SLEEP_MOCI required for e.g. the Dahlia carrier board.
Related-to: ELB-2520
The hardware of verdin has some bypass caps after the switch that
switches power to the sd-card. These caps are resulting in a slow
discharge.
Add off-on-delay to set a minimum off-time of the regulator so it
can fully discharge until it turns on again.
eMMC, used in Colibri iMX7D eMMC modules, supports
200Mhz mode with vccq=1.8v.
Remove the max-frequency limit, it increases the performance significantly:
== before fix ====
root@colibri-imx7-emmc:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: `^H252 MB in 3.02 seconds = 83.54 MB/sec
=== after fix ====
root@colibri-imx7-emmc:~# hdparm -t /dev/mmcblk0
/dev/mmcblk0:
Timing buffered disk reads: 408 MB in 3.00 seconds = 135.94 MB/sec
Related-to: ELB-1442
Fixes: f928a4a377e4 ("ARM: dts: imx7: add Toradex Colibri iMX7D
1GB (eMMC) support")
This commit basically deletes the devicetree for V1.0 Apalis iMX8
modules. It includes V1.1 devicetree then and only puts in the
differences and deletes the nodes that are not used in V1.0.
This is done to prevent code duplication and have better overview of
what has changed.
Related-to: ELB-1254
This commit does no code changes it just copies fsl-imx8qm-apalis.dtsi
to fsl-imx8qm-apalis-v1.1.dtsi.
This is done to be able to track changes made between those versions.
The interface of Apalis modules is MXM3, not SODIMM.
Just fix the name of the reset touch pin.
Fixes: 96458caa3562 ("ARM: dts: imx6: Add touchscreens used
on Toradex eval boards")
