Avoid the following spew:
[ 2.083946] imx7d-pinctrl 302c0000.iomuxc-lpsr: pin MX7D_PAD_GPIO1_IO01
already requested by 302c0000.iomuxc-lpsr; cannot claim for gpio-keys
[ 2.099682] imx7d-pinctrl 302c0000.iomuxc-lpsr: pin-1 (gpio-keys) status -22
[ 2.108272] imx7d-pinctrl 302c0000.iomuxc-lpsr: could not request pin 1
(MX7D_PAD_GPIO1_IO01) from group gpiokeysgrp on device 302c0000.iomuxc-lpsr
[ 2.124626] gpio-keys gpio-keys: Error applying setting, reverse things back
[ 2.133420] gpio-keys: probe of gpio-keys failed with error -22
While at it also fix some missing new lines.
Copied from toradex_imx_4.14.78_1.0.0_ga-bring_up.
The Apalis iMX8 QM module provides this touchscreen hardware.
This is used with the USB_C port on Colibri iMX8X.
This adds the touchscreen atmel_mxt_ts driver used
by displays from toradex.
CONFIG_MODVERSIONS allows to use kernel modules slightly different from the
running kernel.
(cherry picked from commit fe0736d779d71237cba9f6ed5ebf6d7fdf71d9cd)
(cherry picked from commit eb19205dcadee79170778136e149643b20b71b62)
(cherry picked from commit 13244ea064560813f3c4b67d02838930daa56fb4)
(cherry picked from commit f45782b76f20f5adf3ac0b234c458846cd3704fc)
(cherry picked from commit e9656428bfa3a85c99e424785dea50628992e394)
(cherry picked from commit 7cbf898f1287bec82b3a25ed47633539c61ed49c)
It is used on the Colibri iMX8QXP
(cherry picked from commit 961a35836af3e5dce034018b3e010bf3499e2f25)
(cherry picked from commit 78bd4e96eaee1a103a8bd52a2568e6b033ce26ba)
Add NXP SGTL5000 codec support for Apalis iMX8.
(cherry picked from commit 1ed393a89bc808273f9653020b2fcad4d655f765)
arch/arm64/configs/defconfig
(cherry picked from commit 4f8e7db9db1bac86c6c5bc2f78793ebebbd60a14)
(cherry picked from commit ed7618f8085c7f02fb9d9bf8fe160ec0025671f4)
(cherry picked from commit 52ae1fefc8794d41ac7544fc22028ac9a04a6424)
Add DS1307 family RTC support which also supports M41T0 RTC as used
on our carrier board.
(cherry picked from commit d6ec2d954abbdf639cbb435c89cad71775e24795)
(cherry picked from commit a8fa55ea007eb29f8f18fc86cbab3bab0d45a90f)
(cherry picked from commit baf09ae0654769311a390382f22d64d195c4b167)
(cherry picked from commit 32df0ec733ee19740f2075c4501291febd722505)
(cherry picked from commit 944f626fab84a4457f36ec11270fd243f8d80edf)
(cherry picked from commit 75b89c90ac9c3a3b1374354cd3cc1aaa70cea0f0)
(cherry picked from commit 6efcd53a6bd3d4f437f4fd2362dab9685863e639)
(cherry picked from commit ff5f17d53273a644b2c8d76fbd495d9d2eb6e21b)
Add Marvell/USB Bluetooth support.
(cherry picked from commit 9fe8e87ad955c087d2fa6a35fda3287aa5dccbd7)
(cherry picked from commit 9bd23adac54773bfd2ed02d577667053cc61dd74)
(cherry picked from commit 9380becfb11a1cb2502c7938a19b84785735b9a9)
(cherry picked from commit f17e33d650885310866b300c578a3f4d31d5332f)
Add Marvell Wi-Fi support using the mwifiex driver.
(cherry picked from commit acc1f6790a86f38398da46bc30908c8e8e2c0757)
(cherry picked from commit 734a9127e49ce3592b804afb8379f8fa1fc41c9e)
(cherry picked from commit 0a3eeddc6bcf29d9ceacb4838bf26eeb1af36095)
(cherry picked from commit a7eac7df03d30f66f6b5f855727f0f1a2d4666f2)
Add GPIO fan/backlight for Apalis iMX8. Enable USB camera support.
Also enable configs relevant for MIPI CSI2 camera (OV5640) support,
but this needs further changes to the driver to work with i.MX8QM.
(cherry picked from commit 6a74107935a0d4a3a7cebf879a1ae684366bec19)
(cherry picked from commit 471a0d336d637ed1c66c96d10a9f998d0cafc510)
(cherry picked from commit 153848b2e63330fe38315f22baac7817e77f1d00)
(cherry picked from commit 3fb7df4524c6ef6002a940c12ecee199832d321a)
Remove the lpcg_xxx clocks codes, since they are HW gated.
These clocks controlled by HW, and would be turned on
automatically, if there are access operations.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
(cherry picked from commit 9b8da32493057502a912b6d1426eadeb76780e69)
arch/arm64/boot/dts/freescale/fsl-imx8qm.dtsi
drivers/pci/host/pci-imx6.c
(cherry picked from commit 7615a560c48aeb53911c7a6f025420c0f9a5a51f)
(cherry picked from commit 0507816aa4b9a4f5764d308b23332fc297e6fe0f)
(cherry picked from commit 24258f088b89df68e5fa2c54eb3334ff50fcb8f0)
Further clean-up Apalis iMX6 device trees.
No options where added or removed in this commit. A simple
make (apalis|colibri)*_defconfig
make savedefconfig
cp defconfig arch/arm/boot/(apalis|colibri)*_defconfig
While at it, add the dtbs for Aster Carrier Board to the Makefile.
In 4.14 devicetress are based on the mainline DT's and only necessary
stuff for downstream is put into those devicetrees.
This commit holds the changes for imx6ull*colibri* from 4.9.
This commit holds the changes for imx6*(colibri|apalis)* from 4.9.
This commit adds the mipi_csi node to Toradex's evalboard as found
on the mezzanine connector
Those devices are used in conjunction with Toradex's carrier boards.
This commit adds the touchscreens from Toradex so one can enable it.
- fix the name of pinctrl set for i2c2 recovery mode;
- add recovery mode for applicable i2c buses for
Apalis/Colibri iMX6Q/D/DL modules.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Related to: #49059
(cherry picked from commit 1501883b4682178e38afc3f08b221f9477fcd7ae)
This patch prepares the devicetree for the new Ixora V1.2 where we are
able to turn off the supply of the can transceiver. This implies to use
a sleep state on transmission pins in order to prevent backfeeding.
(cherry picked from commit c1016f5da0dbb8291575949e7f4a417c6306d70a)
Provide proper configuration for VGEN3, to make sure it's is always powered
which allows that rail to be automatically switched to 1.8 volts
for proper UHS-I operation. By default it's disabled.
With UHS-I enabled:
[ 104.153898] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 104.166202] mmcblk1: mmc1:59b4 USD00 15.0 GiB
[ 104.173923] mmcblk1: p1
root@colibri-imx6:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: 226 MB in 3.01 seconds = 75.01 MB/sec
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry-picked from 7ffa92d64cc7a6331faaae3e2507458461ab90f3)
Add the phy-node and mdio bus to the fec-node, represented as is on
hardware.
This commit includes micrel,led-mode that is set to the default
value, prepared for someone who wants to change this.
(cherry-picked from 03ff3610434d89fc8e20b280e1219ce0ebb08935)
This adds the muxing for the optional pins usb-oc (overcurrent) and
usb-id.
(cherry picked from commit d1c393ddcb6937b58fa3a9314c8b6f2382b346dc)
(cherry picked from commit a9dc775e6796488a3de676e1736d88560d181138)
Reduce the current drawn from VCC_BATT when the main power on the 3V3 pins
to the module are switched off.
This switches off SoC internal pull resistors which are provided on the module
for TAMPER7 and TAMPER9 SoC pin and switches on a pull down instead of a pullup
for the USBC_DET module pin (TAMPER2).
(cherry picked from commit 9fd59b6eebd12106b5b53fc56466bcd89b9a7ee9)
arch/arm/boot/dts/imx6ull-colibri.dtsi
This patch adds the watchdog to the imx6ull-colibri devicetree
Add the pinmuxing and a inactive node for flexcan1 on SODIMM 55/63
and move the inactive flexcan modes to imx6ull-colibri-eval-v3.dtsi
where they belong.
Note that this commit does not enable flexcan functionality, but rather
eases the effort needed to do so.
(cherry picked from commit 983ff8a6b61e9466beb6b4781fb370a6a7da937a)
arch/arm/boot/dts/imx6ull-colibri-nonwifi.dtsi
arch/arm/boot/dts/imx6ull-colibri-wifi.dtsi
(cherry picked from commit a6f40c3a1d659467267a9d16355c788524bc5ca7)
Switch on 22 kOhm pull ups and lower the I2C frequency to around 40kHz
to get a more reliable communication.
All PWM clock instances have their clock gate. Add these consistently.
Fixes freezing the kernel when one of these instances is used with
IMX6UL_CLK_DUMMY as its clock source.
(cherry picked from commit cd5d7ba49df7918732915a31bfc0f72827bebc2c)
(cherry picked from commit c6306e84601b15ee0152625757aab942fa2f2d28)
The file uses linux,keycode = <KEY_POWER>;, so include
the header which defines KEY_POWER.
(cherry picked from commit 479e0bae1ddfe3ec527634c241fadae558966323)
(cherry picked from commit b8a957b9613a597123f2eb6cd562191362fb153d)
Update #pwm-cells to 3 in order to support PWM signal polarity
control.
(cherry picked from commit 6863695b931ae31fe20171e75cf8a57c990873be)
(cherry picked from commit 3465c49c05258f88ad0584bac8cc6e30d9d1d3a8)
Pass the memory unit-adress to fix the following build warnings with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
There are cases where dts passes an empty memory node, which will be filled
by the bootloader. Passing the memory base address still allows the
bootloader to fill the memory size.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
(cherry picked from commit edc05819786fd5eee330b89bd5892dad1199effc)
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
arch/arm/boot/dts/imx6dl-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6dl-ts4900.dts
arch/arm/boot/dts/imx6dl-ts7970.dts
arch/arm/boot/dts/imx6q-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6q-h100.dts
arch/arm/boot/dts/imx6q-novena.dts
arch/arm/boot/dts/imx6q-ts4900.dts
arch/arm/boot/dts/imx6q-ts7970.dts
arch/arm/boot/dts/imx6q-zii-rdu2.dts
arch/arm/boot/dts/imx6qdl-apalis.dtsi
arch/arm/boot/dts/imx6qdl-cubox-i.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard2.dtsi
arch/arm/boot/dts/imx6qp-zii-rdu2.dts
arch/arm/boot/dts/imx6ul-tx6ul.dtsi
Boards based on imx6ul have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx6ul.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
(cherry picked from commit 750d8df6e7b269b828f66631a1d39ea027afc92a)
